C512A-WNS-CZ0B0152
C512A-WNS-CZ0B0152
    WOLFSPEED
    插件
    LED COOL WHITE CLEAR 5MM RND T/H
C512A-WNS-CZ0B0152 数据手册
PRODUCT FAMILY DATA SHEET C512A-WNS/WNN: 5-mm Round White LEDs PRODUCT DESCRIPTION FEATURES APPLICATIONS Round LEDs offer superior light output • Size (mm): 5 • Torch for excellent readability in sunlight and • Channel Letter dependable performance. They provide • Color Temperatures: extremely stable light output over long periods of time. These lamps are made with an advanced optical grade epoxy • Retail Display Lighting Cool White : Min . (4600K) / Typical (9000K) • Luminous Intensity (mcd) C512A-WNS/WNN: (8200-32900) offering superior high temperature and high moisture resistance performance in lighting and • Viewing angles: 25°: C512A-WNS/WNN illumination applications. • Lead - Free • RoHS Compliant Cree LED / 4400 Silicon Drive / Durham, NC 27703 USA / +1.919.313.5330 / www.cree-led.com © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT942 REV 8 1 C512A-WNS/WNN: 5-mm ROUND WHITE LEDs ABSOLUTE MAXIMUM RATINGS (TA = 25°C) Items Symbol Absolute Maximum Rating Unit IF 25 mA IFP 100 mA Reverse Voltage VR 5 V Power Dissipation PD 100 mW Operation Temperature Topr -40 ~ +95 °C Storage Temperature Tstg -40 ~ +100 °C Lead Soldering Temperature Tsol Forward Current Peak Forward Current Note 1 Max. 260°C for 3 sec. max. (3 mm from the base of the epoxy bulb) Note: 1. Pulse width ≤0.1 msec, duty ≤1/10. TYPICAL ELECTRICAL & OPTICAL CHARACTERISTICS (TA = 25°C) Characteristics Color Symbol Condition Unit Forward Voltage WNS/WNN VF IF = 20 mA V Reverse Current WNS/WNN IR VR = 5 V μA Luminous Intensity WNS/WNN IV IF = 20 mA mcd x IF = 20 mA y IF = 20 mA 2θ½ IF = 20 mA Chromaticity Coordinates WNS/WNN 50% Power Angle WNS/WNN * Minimum Typical 3.2 Maximum 4.0 100 8200 18000 0.2877 0.2831 deg 25 Continuous reverse voltage can cause LED damage. © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT942 REV 8 2 C512A-WNS/WNN: 5-mm ROUND WHITE LEDs INTENSITY BIN LIMIT Cool White (20 mA) - C512A-WNS/WNN Bin Code * Min.(mcd) Max.(mcd) Z0 8200 12000 A0 12000 16800 B0 16800 23500 C0 23500 32900 Tolerance of measurement of luminous intensity is ±15% VOLTAGE BIN LIMIT Cool White (20 mA) - C512A-WNS/WNN * Bin Code Min. (V) Max. (V) 27 2.8 3.0 28 3.0 3.2 29 3.2 3.4 2a 3.4 3.6 2b 3.6 3.8 2c 3.8 4.0 Tolerance of measurement of voltage is ±0.05V © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT942 REV 8 3 C512A-WNS/WNN: 5-mm ROUND WHITE LEDs COLOR BIN LIMIT Cool White (20 mA) - C512A-WNS/WNN Bin Code Sub-bin Wa1 Wa2 Wa3 Wa4 W1 Wb1 Wb2 Wb3 Wb4 * x y 0.2449 0.2497 0.2543 0.2356 0.2497 0.2267 0.2497 0.2543 0.2589 0.2328 0.2545 0.2245 0.2497 0.2545 0.2589 0.2445 0.2543 0.2356 0.2543 0.2589 0.2633 0.2410 0.2589 0.2328 0.2545 0.2245 0.2589 0.2328 0.2635 0.2299 0.2593 0.2223 0.2593 0.2223 0.2635 0.2299 0.2680 0.2270 0.2640 0.2589 0.2633 0.2410 0.2677 0.2375 0.2635 0.2635 0.2677 0.2375 0.2720 0.2340 0.2680 0.2270 Bin Code Sub-bin x y 0.2288 0.2545 0.2384 0.2593 0.2635 0.2534 0.2589 0.2445 0.2267 0.2589 0.2356 0.2635 0.2677 0.2493 0.2633 0.2410 0.2384 0.2593 0.2480 0.2640 0.2680 0.2623 0.2635 0.2534 0.2356 0.2635 0.2445 0.2680 0.2720 0.2575 0.2677 0.2493 0.2633 0.2410 0.2677 0.2493 0.2718 0.2451 0.2677 0.2375 0.2677 0.2375 0.2718 0.2451 0.2760 0.2410 0.2200 0.2720 0.2328 0.2677 0.2720 0.2575 0.2760 0.2528 0.2299 0.2718 0.2299 0.2718 0.2760 0.2528 0.2800 0.2480 0.2760 0.2410 Wc1 Wc2 Wc3 Wc4 W1 Wd1 Wd2 Wd3 Wd4 Bin Code Sub-bin x y 0.2480 0.2640 0.2670 0.2575 0.2688 0.2765 0.2726 0.2711 0.2680 0.2623 0.2445 0.2680 0.2623 0.2534 0.2726 0.2711 0.2764 0.2658 0.2720 0.2575 0.2575 0.2688 0.2765 0.2670 0.2735 0.2860 0.2772 0.2800 0.2726 0.2711 0.2534 0.2726 0.2711 0.2623 0.2772 0.2800 0.2808 0.2740 0.2764 0.2658 0.2720 0.2575 0.2764 0.2658 0.2802 0.2604 0.2760 0.2528 0.2760 0.2528 0.2802 0.2604 0.2840 0.2550 0.2340 0.2800 0.2480 0.2493 0.2764 0.2658 0.2808 0.2740 0.2844 0.2680 0.2451 0.2802 0.2604 0.2451 0.2802 0.2604 0.2844 0.2680 0.2880 0.2620 0.2840 0.2550 We1 We2 We3 We4 W2 Wf1 Wf2 Wf3 Wf4 Tolerance of measurement of the color coordinates is ±0.01 © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT942 REV 8 4 C512A-WNS/WNN: 5-mm ROUND WHITE LEDs COLOR BIN LIMIT Cool White (20 mA) - C512A-WNS/WNN Bin Code Sub-bin Wg1 Wg2 Wg3 Wg4 W2 Wh1 Wh2 Wh3 Wh4 * x y 0.2735 0.2783 0.2817 0.2889 0.2772 0.2800 0.2772 0.2817 0.2852 0.2823 0.2808 0.2740 0.2783 0.2830 0.2863 0.2978 0.2817 0.2889 0.2817 0.2863 0.2895 0.2905 0.2852 0.2823 0.2808 0.2740 0.2852 0.2823 0.2886 0.2756 0.2844 0.2680 0.2844 0.2680 0.2886 0.2756 0.2920 0.2690 0.2880 0.2852 0.2895 0.2905 0.2928 0.2833 0.2886 0.2886 0.2928 0.2833 0.2960 0.2760 0.2920 0.2690 Bin Code Sub-bin x y 0.2860 0.2830 0.2955 0.2890 0.2918 0.3048 0.2863 0.2978 0.2800 0.2863 0.2889 0.2918 0.2947 0.2967 0.2895 0.2905 0.2955 0.2890 0.3050 0.2950 0.2974 0.3119 0.2918 0.3048 0.2889 0.2918 0.2978 0.2974 0.2998 0.3028 0.2947 0.2967 0.2895 0.2905 0.2947 0.2967 0.2975 0.2890 0.2928 0.2833 0.2928 0.2833 0.2975 0.2890 0.3003 0.2813 0.2620 0.2960 0.2823 0.2947 0.2998 0.3028 0.3022 0.2946 0.2756 0.2975 0.2756 0.2975 0.3022 0.2946 0.3045 0.2865 0.3003 0.2813 Wj1 Wj2 Wj3 Wj4 W3 Wk1 Wk2 Wk3 Wk4 Bin Code Sub-bin x y 0.3050 0.2950 0.3210 0.3130 0.3010 0.3290 0.3030 0.3190 0.2974 0.3119 0.2978 0.2974 0.3119 0.3048 0.3030 0.3119 0.3050 0.3090 0.2998 0.3028 0.3130 0.3010 0.3290 0.3210 0.3070 0.3370 0.3085 0.3260 0.3030 0.3190 0.3048 0.3030 0.3190 0.3119 0.3085 0.3260 0.3100 0.3150 0.3050 0.3090 0.2998 0.3028 0.3050 0.3090 0.3070 0.3005 0.3022 0.2946 0.3022 0.2946 0.3070 0.3005 0.3090 0.2920 0.2760 0.3045 0.2865 0.2967 0.3050 0.3090 0.3100 0.3150 0.3115 0.3060 0.2890 0.3070 0.3005 0.2890 0.3070 0.3005 0.3115 0.3060 0.3130 0.2970 0.3090 0.2920 Wm1 Wm2 Wm3 Wm4 W3 Wn1 Wn2 Wn3 Wn4 Tolerance of measurement of the color coordinates is ±0.01 © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT942 REV 8 5 C512A-WNS/WNN: 5-mm ROUND WHITE LEDs COLOR BIN LIMIT Cool White (20 mA) - C512A-WNS/WNN Bin Code Sub-bin Wp1 Wp2 Wp3 Wp4 W4 Wq1 Wq2 Wq3 Wq4 * x y 0.3070 0.3130 0.3140 0.3320 0.3085 0.3260 0.3085 0.3140 0.3150 0.3210 0.3100 0.3150 0.3130 0.3190 0.3195 0.3380 0.3140 0.3320 0.3140 0.3195 0.3200 0.3270 0.3150 0.3210 0.3100 0.3150 0.3150 0.3210 0.3163 0.3118 0.3115 0.3060 0.3115 0.3060 0.3163 0.3118 0.3175 0.3025 0.3130 0.3150 0.3200 0.3270 0.3208 0.3173 0.3163 0.3163 0.3208 0.3173 0.3215 0.3075 0.3175 0.3025 Bin Code Sub-bin x y 0.3370 0.3190 0.3430 0.3245 0.3248 0.3438 0.3195 0.3380 0.3260 0.3195 0.3320 0.3248 0.3250 0.3330 0.3200 0.3270 0.3430 0.3245 0.3490 0.3300 0.3300 0.3495 0.3248 0.3438 0.3320 0.3248 0.3380 0.3300 0.3300 0.3390 0.3250 0.3330 0.3200 0.3270 0.3250 0.3330 0.3255 0.3230 0.3208 0.3173 0.3208 0.3173 0.3255 0.3230 0.3260 0.3130 0.2970 0.3215 0.3210 0.3250 0.3300 0.3390 0.3300 0.3285 0.3118 0.3255 0.3118 0.3255 0.3300 0.3285 0.3300 0.3180 0.3260 0.3130 Wr1 Wr2 Wr3 Wr4 W4 Ws1 Ws2 Ws3 Ws4 Bin Code Sub-bin x y 0.3490 0.3300 0.3600 0.3545 0.3378 0.3663 0.3375 0.3563 0.3300 0.3495 0.3380 0.3300 0.3495 0.3438 0.3375 0.3563 0.3372 0.3463 0.3300 0.3390 0.3545 0.3378 0.3663 0.3600 0.3455 0.3725 0.3449 0.3630 0.3375 0.3563 0.3438 0.3375 0.3563 0.3495 0.3449 0.3630 0.3443 0.3535 0.3372 0.3463 0.3300 0.3390 0.3372 0.3463 0.3368 0.3363 0.3300 0.3285 0.3300 0.3285 0.3368 0.3363 0.3365 0.3263 0.3075 0.3300 0.3180 0.3330 0.3372 0.3463 0.3443 0.3535 0.3437 0.3440 0.3230 0.3368 0.3363 0.3230 0.3368 0.3363 0.3437 0.3440 0.3430 0.3345 0.3365 0.3263 Wt1 Wt2 Wt3 Wt4 W5 Wu1 Wu2 Wu3 Wu4 Tolerance of measurement of the color coordinates is ±0.01 © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT942 REV 8 6 C512A-WNS/WNN: 5-mm ROUND WHITE LEDs COLOR BIN LIMIT Cool White (20 mA) - C512A-WNS/WNN Bin Code Sub-bin Wv1 Wv2 Wv3 Wv4 W5 Ww1 Ww2 Ww3 Ww4 * x y 0.3455 0.3725 0.3533 0.3788 0.3523 0.3698 0.3449 0.3630 0..3449 0.3630 0.3523 0.3698 0.3514 0.3608 0.3443 0.3535 0.3533 0.3788 0.3610 0.3850 0.3598 0.3765 0.3523 0.3698 0.3523 0.3698 0.3598 0.3765 0.3585 0.3680 0.3514 0.3608 0.3443 0.3535 0.3514 0.3608 0.3505 0.3518 0.3437 0.3440 0.3437 0.3440 0.3505 0.3518 0.3495 0.3428 0.3430 0.3345 0.3514 0.3608 0.3585 0.3680 0.3573 0.3595 0.3505 0.3518 0.3505 0.3518 0.3573 0.3595 0.3560 0.3510 0.3495 0.3428 Tolerance of measurement of the color coordinates is ±0.01 © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT942 REV 8 7 C512A-WNS/WNN: 5-mm ROUND WHITE LEDs CIE CHROMATICITY DIAGRAM W q n W 5 W W W j 0.1700 0.1700 0.2300 W 1 W W W 0.2300 b a W d W c W f 2 W e 1 W h W 3 W W k g 0.2900 W 4 m W 90 00 0K 10 y W s 00 K W p 80 00 u 4 K W r 70 0.3500 W w 00 W K t W v 60 00 K 50 0 0K 0.4100 0.2900 0.3500 0.4100 x © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT942 REV 8 8 C512A-WNS/WNN: 5-mm ROUND WHITE LEDs ORDER CODE TABLE Color Cool White Viewing Angle 25° Kit Number Luminous Intensity (mcd) Color Bin Code Package Standoff 32900 W1,W2,W3,W4,W5 Bulk Yes 23500 W1,W2,W3,W4,W5 Bulk Yes 12000 32900 W1,W2,W3,W4,W5 Bulk Yes 8200 32900 W1,W2,W3,W4,W5 Ammo Yes Min. Max. C512A-WNS-CZ0C0151 8200 C512A-WNS-CZ0B0151 8200 C512A-WNS-CA0C0151 C512A-WNS-CZ0C0152 C512A-WNS-CZ0B0152 8200 23500 W1,W2,W3,W4,W5 Ammo Yes C512A-WNS-CA0C0152 12000 32900 W1,W2,W3,W4,W5 Ammo Yes C512A-WNN-CZ0C0151 8200 32900 W1,W2,W3,W4,W5 Bulk No C512A-WNN-CZ0B0151 8200 23500 W1,W2,W3,W4,W5 Bulk No C512A-WNN-CA0C0151 12000 32900 W1,W2,W3,W4,W5 Bulk No C512A-WNN-CZ0C0152 8200 32900 W1,W2,W3,W4,W5 Ammo No C512A-WNN-CZ0B0152 8200 23500 W1,W2,W3,W4,W5 Ammo No C512A-WNN-CA0C0152 12000 32900 W1,W2,W3,W4,W5 Ammo No Notes: • The above kit numbers represent order codes that include multiple intensity-bin and color-bin codes. Only one intensity-bin code and one color-bin code will be shipped on each bulk. Single intensity-bin code and single color-bin codes will not be orderable. • Please refer to the HB LED Lamp Reliability Test Standards document for reliability test conditions. • Please refer to the HB LED Lamp Soldering & Handling document for information about how to use this LED product safely. © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT942 REV 8 9 C512A-WNS/WNN: 5-mm ROUND WHITE LEDs GRAPHS The data below are collected from statistical figures that do not necessarily correspond to the actual parameters of each single LED. Hence, these data will be changed without further notice.                                                                                                © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT942 REV 8 10 C512A-WNS/WNN: 5-mm ROUND WHITE LEDs MECHANICAL DIMENSIONS All dimensions are in mm. Tolerance is ±0.25 mm unless otherwise noted. An epoxy meniscus may extend about 1.5 mm down the leads. Burr around bottom of epoxy may be 0.5 mm max. C512A-WNS: C512A-WNN: NOTES RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website.  Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT942 REV 8 11  C512A-WNS/WNN: 5-mm ROUND WHITE LEDs KIT NUMBER SYSTEM Cree LED lamps are tested and sorted into performance bins. A bin is specified by ranges of color, forward voltage, and brightness. Sorted LEDs are packaged for shipping in various convenient options. Cree LEDs are sold by order codes in combinations of bins called kits. Order codes are configured in the following manner: © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT942 REV 8 12 C512A-WNS/WNN: 5-mm ROUND WHITE LEDs SOLDERING GUIDELINES The LED soldering specification is shown below(suitable for both leaded solder & lead-free solder): Manual Soldering Soldering iron 35 W max Temperature 300 ºC max Soldering time Position Solder Dipping Preheat 110 ºC max Preheat time 60 seconds max Solder-bath temperature 260 ºC Max 3 seconds max Dipping time 5 seconds max Not less than 3 mm from the base of the package. Position Not less than 3 mm from the base of the package. • Manual soldering onto the PCB is not recommended because soldering time is uncontrollable. • The recommended wave soldering is as below: 300 laminar wave Temperature ºC 250 200 150 100 50 30 0 Fluxing Preheat 10 20 30 40 50 60 70 Times (sec) 80 90 100 110 120 • Do not apply any stress to the LED package, particularly when heated. • Only bottom preheat is suggested & should not preheat on top in order to reduce thermal stress experienced by the LEDs. • The LEDs must not be re used once they have been extracted from PCB. • After soldering the LEDs, the package should be protected from mechanical shock or vibration until the LEDs have reached 40 ºC or below. • Precautions must be taken as mechanical stress on the LEDs may be caused by PCB warpage or from the clinching and cutting of the LED leads. • When it is necessary to clam the LEDs during soldering, it is important to ensure no mechanical stress is exerted on the LEDs. • Cut the LED lead at normal room temperature. Lead cutting at high temperature may cause failure of the LEDs. • Please refer to the HB LED Lamp Soldering & Handling document for information about how to use this LED product safely. © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT942 REV 8 13 C512A-WNS/WNN: 5-mm ROUND WHITE LEDs PACKAGING • The LEDs are packed in cardboard boxes after packaging in normal or anti-electrostatic bags. • Cardboard boxes will be used to protect the LEDs from mechanical shock during transportation. • The boxes are not water resistant, and they must be kept away from water and moisture. • Max 500 pcs per bulk and Max 2500 pcs per ammo. Bulk Pack Packaging Type: Ammo Pack Packaging Type: xxx xxx R COLOR LED LAMP TYPE LXXXXXXXX-XXX LOT JOWAXXXXX -XX-XXX QTY RANK PCS Iv X ( ) Vf XX ( ) Hue XX ( ) AXXXXXXXXXXX Label (anti-electrostatic bag) 20 bags/carton © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT942 REV 8 14
C512A-WNS-CZ0B0152 价格&库存
很抱歉,暂时无法提供与“C512A-WNS-CZ0B0152”相匹配的价格&库存,您可以联系我们找货
