CLY6D-FKC-CNP1ST1E1BB7D3D3 数据手册
PRODUCT FAMILY DATA SHEET
CLY6D-FKC: PLCC6 3 in 1 SMD LED
PRODUCT DESCRIPTION
FEATURES
APPLICATIONS
This SMD LED features an IPx8 water
• Size (mm): 2.8 x 2.8 x 2.5
• Outdoor Full-Color Video Screen
resistant rating in a PLCC6 package. These • Dominant Wavelength
high performance tricolor SMT
LEDs are designed to work in a wide
range of applications. A wide viewing angle
and high brightness make
these LEDs suitable for outdoor and
full color video signage applications.
The encapsulation resin contains UV
inhibitors to minimize the effects of
long-term exposure to direct
sunlight, resulting in stable light
output over the life of the LED. This PLCC6
Red (619 - 624nm)
Green (520 - 540nm)
Blue (460 - 480nm)
• Decorative Lighting
• Amusement
• Luminous Intensity (mcd)
Red (560 - 1120)
Green (900 - 1800)
Blue (140 - 355)
• Water-Resistant (IPx8)*
• Moisture Sensitivity Level: 5a
• Lead-Free
• RoHS Compliant
package has an increased
package height to ease in the
manufacturing process.
*:This part is tested under the condition of assembling it on a PCB with isolating the electrical path by silicone.
The leads area of the LED is not IPx8 rated and it’s required to insulate for moisture by customer in outdoor
application.
Cree LED / 4400 Silicon Drive / Durham, NC 27703 USA / +1.919.313.5330 / www.cree-led.com
© 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the
Cree LED logo is a trademark, of Cree, Inc.
CLD-CT1321
REV 9
1
CLY6D-FKC: PLCC6 3 IN 1 SMD LED
ABSOLUTE MAXIMUM RATINGS (TA = 25°C)
Items
Symbol
Absolute Maximum Rating
Unit
R
G
B
IF
50
35
mA
IFP
200
100
100
mA
Reverse Voltage
VR
5
5
5
V
Power Dissipation
PD
130
119
76
mW
Operation Temperature
Topr
-40 ~ +85
°C
Storage Temperature
Tstg
-40 ~ +100
°C
Junction Temperature
TJ
110
110
110
°C
Junction/ambient
RTHJA
440
480
420
°C/W
Junction/solder point
RTHJS
180
230
200
°C/W
Electrostatic Discharge
Classification(MIL-STD-883E)
ESD
Forward Current Note 1
Peak Forward Current
Note 2
1000V
Note:
1.
Single-color light
2.
Pulse width ≤0.1 msec, duty ≤1/10.
TYPICAL ELECTRICAL & OPTICAL CHARACTERISTICS (TA = 25°C)
Characteristics
Condition
Symbol
Dominant Wavelength
IF = 15mA(R)
IF = 10mA(G)
IF = 10mA(B)
Spectral bandwidth at 50% IREL max
IF = 15mA(R)
IF = 10mA(G)
IF = 10mA(B)
Forward Voltage
IF = 15mA(R)
IF = 10mA(G)
IF = 10mA(B)
Luminous Intensity
Luminous Intensity(Reference)
Reverse Current (max)
Values
Unit
R
G
B
λDOM
619~624
520~540
460~480
nm
Δλ
24
38
28
nm
VF(avg)
2.1
2.7
3.0
V
VF(max)
2.6
3.4
3.8
V
IF = 15mA(R)
IF = 10mA(G)
IF = 10mA(B)
IV(min)
560
900
140
mcd
IV(avg)
750
1350
240
mcd
IF = 20mA(R/G/B)
IV(avg)
1000
2250
460
mcd
VR = 5 V
IR
10
10
10
μA
Continuous reverse voltage can cause LED damage.
CLD-CT1321
REV 9
2
INTENSITY BIN LIMIT
Red (15 mA)
Green (10 mA)
Bin Code
Min.(mcd)
Max.(mcd)
Bin Code
Blue (10 mA)
Min.(mcd)
Max.(mcd)
Bin Code
Min.(mcd)
Max.(mcd)
K
560
710
N
900
1120
D
140
180
np
635
805
st
1010
1260
9a
160
202
M
710
900
P
1120
1400
E
180
224
qr
805
1010
vw
1260
1600
bc
202
252
N
900
1120
Q
1400
1800
F
224
280
de
252
318
G
280
355
Tolerance of measurement of luminous intensity is ±10%.
COLOR BIN LIMIT
Red (15 mA)
Green (10 mA)
Blue (10 mA)
Bin Code
Min.(nm)
Max.(nm)
Bin Code
Min.(nm)
Max.(nm)
Bin Code
Min.(nm)
Max.(nm)
RB
619
624
G7
520
525
B3
460
465
G23
522.5
527.5
B23
462.5
467.5
G8
525
530
B4
465
470
G45
527.5
532.5
B45
467.5
472.5
G9
530
535
B5
470
475
G67
532.5
537.5
B67
472.5
477.5
Ga
535
540
B6
475
480
Tolerance of measurement of dominant wavelength is ±1 nm.
CLD-CT1321
REV 9
3
ORDER CODE TABLE
Kit Number
CLY6D-FKC-CKNNQDGBB7a363
CLY6D-FKC-CK1N1D1BB7D3D3
CLY6D-FKC-Cnp1st1E1BB7D3D3
Color
Dominant Wavelength (nm)
Package
Min.
Max.
Color
Bin
Min.(nm)
Color
Bin
Max.
(nm)
Red
560
1120
RB
619
RB
624
Reel
Green
900
1800
G7
520
Ga
540
Reel
Blue
140
355
B3
460
B6
480
Reel
RB
619
RB
624
Reel
Red
Any 1 Intensity bin from
K(560) - N(1120)
Green
N(900) - Q(1800)
Any 1 hue bin from G7(520)-Ga(540)
Reel
Blue
D(140) - G(355)
Any 1 hue bin from B3(460)-B6(480)
Reel
Red
np(635) - N(1120)
Green
st(1010) - Q(1800)
Reel
Blue
E(180) - G(355)
Reel
RB
619
RB
624
Reel
Notes:
The above kit numbers represent order codes that include multiple intensity-bin and color-bin codes. Only one intensity-bin code and one color-bin
code will be shipped on each bulk. Single intensity-bin code and single color-bin codes will not be orderable.
Please refer to the HB LED Lamp Reliability Test Standards document for reliability test conditions.
Please refer to the HB LED Lamp Soldering & Handling document for information about how to use this LED product safely.
CLD-CT1321
REV 9
4
GRAPHS
The data below are collected from statistical figures that do not necessarily correspond to the actual parameters of each single LED.
Hence, these data will be changed without further notice.
CLD-CT1321
REV 9
5
GRAPHS
CLD-CT1321
REV 9
6
MECHANICAL DIMENSIONS
All dimensions are in mm.
适用于
PRODUCED BY AN AUTODESK EDUCATIONAL PRODUCT
Tolerance of measurement of the dimension is ±0.1.
NOTES
RoHS Compliance
The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold
limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as
implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product
Ecology section of the Cree LED website.
Vision Advisory
WARNING: Do not look at an exposed lamp in operation. Eye injury can result.
CLD-CT1321
REV 9
7
KIT NUMBER SYSTEM
Cree LED lamps are tested and sorted into performance bins. A bin is specified by ranges of color, forward voltage, and brightness.
Cree LEDs are sold by order codes in combinations of bins called kits. Order codes are configured in the following manner:
CLD-CT1321
REV 9
8
REFLOW SOLDERING
The CLY6D-FKC is rated as a MSL 5a product.
The recommended floor life out of bag is 24hrs.
The temperature profile is as below
Document No.: COTCO-05-0057
Rev. NO. : 13
Temperature
Melting-point
Pre-heat
Use all SMD besides LP6-NPP1-01-N1
Soak
Reflow
Cooling
Time
Solder = Sn63-Pb37
Solder = Lead-free
Average
ramp-up rate = 4ºC/s max.
Use only
with CLX6D-FKC
Average ramp-up rate = 4ºC/s max
Preheat temperature = 100ºC ~150ºC
Preheat temperature = 150ºC ~200ºC
Preheat time = 100s max.
Ramp-down rate = 6ºC/s max.
Peak
Preheat
time =temperature
120s max
= 230ºC max.
Peak temperature = 250ºC max.
actual Peak Temperature = 10s max.
Time within 5ºC of actual Peak Temperature = 10s max.
Solder
Ramp-down
= 6ºC/s
max
Timerate
within
5ºC
of
Peak temperature
= 235ºC 183ºC
max
Duration above
is 80s max.
Time within 5ºC of actual Peak Temperaturepick
= 10s up
maxSMD
[13]
Duration above 217ºC is 80s max.
Document No.: CREE-05-0
Rev. NO. :
16
products during the process of SMT production . If handling is necessary, it should ta
Only
use
LP6-NPP1-01-N1
Duration
above
217ºC
is 45s max
careful to pick up these products. The following two methods are necessary :
Solder = Low Lead-free
NOTES
Average ramp-up rate = 3ºC/s max.
Preheat
temperature
= 130ºC
~170ºCare very small and the resin is still soft after solidification. Users are required to handle with care.
The
packaging
sizes of these
SMD products
Never touch the resin surface of SMD products.
time = 120s
max. surface and interior
Fig. device,
1a: For
Small
Top SMD
1b:upFor
0.8mm
ToPreheat
avoid damaging
the product’s
it is
recommended
to choose a special nozzleFig.
to pick
theMini
SMD side
products
duringSMD
the
process of SMT production. If handling is necessary, take special care when picking up these products. The following method is necessary:
Peak temperature = 213ºC max.
Time within 3ºC of actual Peak Temperature = 25s max.
Duration above 200ºC is 40s max.
Recommended solder pad design for heat dissipation (2-pin SMD LED):
7.0 series , it is recommended to use rubber material Nozzle to pick up SMD produ
For Small Top SMD
figure size for reference :
2.6
CLD-CT1321
REV 9
a.) Circular Nozzle: inner diameter: Ø1.8mm+/-0.05mm, outer diameter: Ø2.3mm+/-0.05mm.
9
PACKAGING
The boxes are not water resistant and they must be kept away from water and moisture.
The LEDs are packed in cardboard boxes after packaging in normal or anti-electrostatic bags.
Cardboard boxes will be used to protect the LEDs from mechanical shocks during transportation.
The reel pack is applied in SMD LED.
Max 6500 pcs per reel.
A
AAA C
CCC
CCoba
oba ltlt Free
Free
CLD-CT1321
REV 9
10
CLY6D-FKC-CNP1ST1E1BB7D3D3 价格&库存
很抱歉,暂时无法提供与“CLY6D-FKC-CNP1ST1E1BB7D3D3”相匹配的价格&库存,您可以联系我们找货
