CXB1304-0000-000C0UA427G
    WOLFSPEED
    LED ARRAY 6MM 2700K 90CRI 355LM
CXB1304-0000-000C0UA427G 数据手册
PRODUCT FAMILY DATA SHEET XLamp® CXB1304 LED PRODUCT DESCRIPTION FEATURES The XLamp® CXB1304 LED Array is the most compact member • 6‑mm optical source of the second generation of the CXA family that delivers up to • Mechanical and optical design consistent with other CXA13 30% higher efficacy and up to 20% higher lumens than the first LEDs generation in the same small LES. The higher performance • Available in 70-, 80-, 90- and 95-minimum CRI options second generation CXA LED Arrays are compatible with the first • EasyWhite® 2-, 3‑ and 5-step binning generation, providing a drop-in performance upgrade to existing • Premium Color 2- and 3-step binning CXA LED designs to shorten the luminaire design cycle and • Forward voltage options: 9‑V class, 18‑V class & 36‑V class improve time to market. Available in 2‑step, 3‑step and 5‑step • 85 °C binning and characterization EasyWhite® bins and 2‑step and 3‑step Premium Color bins, the • Extremely uniform color over viewing angle CXB1304 LED delivers high lumen output and high efficacy in a • Top-side solder connections single, easy‑to‑use package that eliminates the need for reflow • Thermocouple attach point soldering, enabling lighting manufacturers to rapidly address • NEMA SSL-3 2011 standard flux bins small form factor lighting applications. • RoHS and REACh compliant • UL® recognized component (E349212) The CX Family LED Design Guide provides basic information on the requirements to use the CXB1304 LED successfully in luminaire designs. Cree LED / 4400 Silicon Drive / Durham, NC 27703 USA / +1.919.313.5330 / www.cree-led.com © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS116 REV 9A 1 XLAMP ® CXB1304 LED TABLE OF CONTENTS Characteristics........................................................................................................................................................................................................ 3 Operating Limits...................................................................................................................................................................................................... 3 Flux Characteristics, EasyWhite® Order Codes and Bins - 9 V............................................................................................................................. 5 Flux Characteristics, Premium Color Order Codes and Bins - 9 V....................................................................................................................... 8 Flux Characteristics, EasyWhite® Order Codes and Bins - 18 V........................................................................................................................... 9 Flux Characteristics, Premium Color Order Codes and Bins - 18 V................................................................................................................... 12 Flux Characteristics, EasyWhite® Order Codes and Bins - 36 V......................................................................................................................... 13 Flux Characteristics, Premium Color Order Codes and Bins - 36 V................................................................................................................... 16 Relative Spectral Power Distribution, EasyWhite® ............................................................................................................................................. 17 Relative Spectral Power Distribution, Premium Color........................................................................................................................................ 18 Electrical Characteristics...................................................................................................................................................................................... 19 Relative Luminous Flux......................................................................................................................................................................................... 21 Typical Spatial Distribution................................................................................................................................................................................... 24 Performance Groups - Brightness....................................................................................................................................................................... 24 Performance Groups - Chromaticity.................................................................................................................................................................... 25 Premium Color Performance Groups - Chromaticity.......................................................................................................................................... 26 EasyWhite® Bins Plotted on the 1931 CIE Color Space...................................................................................................................................... 27 Premium Color Bins Plotted on the 1931 CIE Color Space................................................................................................................................ 28 Bin and Order Code Formats................................................................................................................................................................................ 30 Mechanical Dimensions....................................................................................................................................................................................... 30 Thermal Design..................................................................................................................................................................................................... 31 Notes..................................................................................................................................................................................................................... 33 Packaging.............................................................................................................................................................................................................. 34 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS116 REV 9A 2 XLAMP ® CXB1304 LED CHARACTERISTICS Characteristics Unit Viewing angle (FWHM) Minimum Typical degrees ESD withstand voltage (HBM per Mil-Std-883D) Maximum 115 V 8000 DC forward current (9 V) mA 1000* DC forward current (18 V) mA 500* DC forward current (36 V) mA 250* Reverse current (9 V, 18V, 36 V) mA 0.1 Forward voltage (9 V, 400 mA, 85 °C) V 8.45 9.5 Forward voltage (18 V, 200 mA, 85 °C) V 16.9 19 Forward voltage (36 V, 100 mA, 85 °C) V 33.8 38 * Refer to the Operating Limits section. OPERATING LIMITS The maximum current rating of the CXB1304 depends on the case temperature (Tc) when the LED has reached thermal equilibrium under steady-state operation. The graphs shown below assume that the system design employs good thermal management (thermal interface material and heat sink) and may vary when poor thermal management is employed. Please refer to the Mechanical Dimensions section on page 30 for the location of the Tc measurement point. Another important factor in good thermal management is the temperature of the Light Emitting Surface (LES). Cree LED recommends a maximum LES temperature of 135 °C to ensure optimal LED lifetime. Please refer to the Thermal Design section on page 31 for more information on LES temperature measurement. CXB1304-9V Standard 1200 85 °C, 1000 mA 1000 If (mA) 800 9V 600 125 °C, 384 mA 400 200 0 0 25 50 75 100 125 150 Case Temperature (°C) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS116 REV 9A 3 XLAMP ® CXB1304 LED OPERATING LIMITS - CONTINUED CXB1304-18V Standard 600 85 °C, 500 mA 500 If (mA) 400 18 V 300 125 °C, 192 mA 200 100 0 0 25 50 75 100 125 150 Case Temperature (°C) CXB1304-36V Standard 300 85 °C, 250 mA 250 If (mA) 200 36 V 150 125 °C, 96 mA 100 50 0 0 25 50 75 100 125 150 Case Temperature (°C) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS116 REV 9A 4 XLAMP ® CXB1304 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 9 V (IF = 400 mA, TJ = 85 °C) The following table provides order codes for XLamp CXB1304 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 30). CRI* Nominal CCT Min 70 Minimum Luminous Flux Typ --- 2-Step 3-Step 5-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** C4 475 525 D2 510 563 D4 550 607 CXB1304-0000000C0BD465E C2 440 486 CXB1304-0000000C0HC265E C4 475 525 D2 510 563 CXB1304-0000000C0HD265E C4 475 525 CXB1304-0000000C0BC457E D2 510 563 D4 550 607 CXB1304-0000000C0BD457E C2 440 486 CXB1304-0000000C0HC257E C4 475 525 D2 510 563 Group Order Code Group Order Code Group CXB1304-0000000C0BC465E 65E 6500 K 80 70 --- --- 65E 57E 5700 K 80 --- Order Code 57E CXB1304-0000000C0BD265E CXB1304-0000000C0HC465E CXB1304-0000000C0BD257E CXB1304-0000000C0HC457E CXB1304-0000000C0HD257E Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 33). • CXB1304 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS116 REV 9A 5 XLAMP ® CXB1304 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 9 V (IF = 400 mA, TJ = 85 °C) - CONTINUED CRI* Nominal CCT Min 70 5000 K 80 90 70 4000 K 80 90 Minimum Luminous Flux Typ --- --- 92 --- --- 92 2-Step 3-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** C4 475 525 D2 510 563 D4 550 607 C2 440 486 C4 475 525 D2 510 563 CXB1304-0000000C0HD250G B4 410 453 CXB1304-0000000C0UB450G C2 440 486 C4 475 525 C4 475 525 D2 510 563 D4 550 607 C2 440 486 C4 475 525 D2 510 563 CXB1304-0000000C0HD240H CXB1304-0000000C0HD240G B2 380 420 CXB1304-0000000C0UB240H CXB1304-0000000C0UB240G B4 410 453 C2 440 486 Group Order Code Group Order Code 5-Step Group Order Code CXB1304-0000000C0BC450E 50E CXB1304-0000000C0BD250E CXB1304-0000000C0BD450E CXB1304-0000000C0HC250G 50G 50G CXB1304-0000000C0HC450G CXB1304-0000000C0HC250E 50E CXB1304-0000000C0HC450E CXB1304-0000000C0UC250G CXB1304-0000000C0UC450G CXB1304-0000000C0BC440E 40E CXB1304-0000000C0BD240E CXB1304-0000000C0BD440E CXB1304-0000000C0HC240H 40H 40H CXB1304-0000000C0HC440H CXB1304-0000000C0UB440H CXB1304-0000000C0UC240H CXB1304-0000000C0HC240G 40G 40G CXB1304-0000000C0HC440G CXB1304-0000000C0UB440G CXB1304-0000000C0UC240G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 33). • CXB1304 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS116 REV 9A 6 XLAMP ® CXB1304 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 9 V (IF = 400 mA, TJ = 85 °C) - CONTINUED CRI* Nominal CCT Min 80 Minimum Luminous Flux Typ --- 3500 K 90 80 Flux (lm) @ 85 °C Flux (lm) @ 25 °C** B4 410 453 C2 440 486 C4 475 525 CXB1304-0000000C0HC435H CXB1304-0000000C0HC435G A4 355 392 CXB1304-0000000C0UA435H CXB1304-0000000C0UA435G B2 380 420 CXB1304-0000000C0UB235H CXB1304-0000000C0UB235G B4 410 453 CXB1304-0000000C0UB435H C2 440 486 CXB1304-0000000C0UC235H CXB1304-0000000C0UC235G B4 410 453 CXB1304-0000000C0HB430H CXB1304-0000000C0HB430G C2 440 486 C4 475 525 CXB1304-0000000C0HC430H CXB1304-0000000C0HC430G A4 355 392 CXB1304-0000000C0UA430H CXB1304-0000000C0UA430G B2 380 420 B4 410 453 CXB1304-0000000C0UB430H CXB1304-0000000C0UB430G B4 410 453 CXB1304-0000000C0HB427H CXB1304-0000000C0HB427G C2 440 486 C4 475 525 CXB1304-0000000C0HC427H CXB1304-0000000C0HC427G A2 330 364 CXB1304-0000000C0UA227H CXB1304-0000000C0UA227G A4 355 392 B2 380 420 B2 380 420 Group 80 92 --- 35H 35H 30H 30H 27H 2700 K 90 2200 K 80 92 --- Order Code Group CXB1304-0000000C0HB435H 3000 K 90 3-Step Group 92 --- 2-Step 27H CXB1304-0000000C0HC235H CXB1304-0000000C0HC230H CXB1304-0000000C0UB230H CXB1304-0000000C0HC227H CXB1304-0000000C0UA427H Order Code 5-Step Group Order Code CXB1304-0000000C0HB435G 35G 35G 30G 30G 27G 27G CXB1304-0000000C0UB227H CXB1304-0000000C0HC235G CXB1304-0000000C0UB435G CXB1304-0000000C0HC230G CXB1304-0000000C0UB230G CXB1304-0000000C0HC227G CXB1304-0000000C0UA427G CXB1304-0000000C0UB227G 22G CXB1304-0000000C0HB222G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 33). • CXB1304 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS116 REV 9A 7 XLAMP ® CXB1304 LED FLUX CHARACTERISTICS, PREMIUM COLOR ORDER CODES AND BINS - 9 V (I F = 400 mA, TJ = 85 °C) Fidelity CRI* Nominal CCT Minimum Luminous Flux Min Typ Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** 4000 K 95 98 B2 380 420 3500 K 95 98 A4 355 3000 K 95 98 A4 2700 K 95 98 A2 Typical Luminous Flux (lm) @ 85 °C 2-Step Group Order Code 402 L5A CXB1304-0000-000C0ZB2L5A 392 387 35H CXB1304-0000-000C0ZA435H 355 392 372 30H CXB1304-0000-000C0ZA430H 330 361 351 27H CXB1304-0000-000C0ZA227H Specialty CRI Nominal CCT 3100 K 3000 K Minimum Luminous Flux Typical Luminous Flux (lm) @ 85 °C Min Typ Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** 90 92 B4 410 453 430 80 82 C2 440 486 490 90 92 B4 410 453 425 95 98 A2 330 361 355 2-Step Group L7B L7C Order Code 3-Step Group Order Code 31Q CXB1304-0000000C0UB431Q 30Q CXB1304-0000000C0UB430Q Group Order Code 30U CXB1304-0000000C0UB430U CXB1304-0000000C0HC2L7B CXB1304-0000000C0ZA2L7C Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 33). • CXB1304 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS116 REV 9A 8 XLAMP ® CXB1304 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 18 V (IF = 200 mA, TJ = 85 °C) The following table provides order codes for XLamp CXB1304 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 30). CRI* Nominal CCT Min 70 Minimum Luminous Flux Typ --- 2-Step 3-Step 5-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** C4 475 525 D2 510 563 D4 550 607 CXB1304-0000000F0BD465E C2 440 486 CXB1304-0000000F0HC265E C4 475 525 D2 510 563 CXB1304-0000000F0HD265E C4 475 525 CXB1304-0000000F0BC457E D2 510 563 D4 550 607 CXB1304-0000000F0BD457E C2 440 486 CXB1304-0000000F0HC257E C4 475 525 D2 510 563 Group Order Code Group Order Code Group CXB1304-0000000F0BC465E 65E 6500 K 80 70 --- --- 65E 57E 5700 K 80 --- Order Code 57E CXB1304-0000000F0BD265E CXB1304-0000000F0HC465E CXB1304-0000000F0BD257E CXB1304-0000000F0HC457E CXB1304-0000000F0HD257E Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 33). • CXB1304 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS116 REV 9A 9 XLAMP ® CXB1304 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 18 V (IF = 200 mA, TJ = 85 °C) - CONTINUED CRI* Nominal CCT Min 70 5000 K 80 90 70 4000 K 80 90 Minimum Luminous Flux Typ --- --- 92 --- --- 92 2-Step 3-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** C4 475 525 D2 510 563 D4 550 607 C2 440 486 C4 475 525 D2 510 563 CXB1304-0000000F0HD250G B4 410 453 CXB1304-0000000F0UB450G C2 440 486 C4 475 525 C4 475 525 D2 510 563 D4 550 607 C2 440 486 C4 475 525 D2 510 563 CXB1304-0000000F0HD240H CXB1304-0000000F0HD240G B2 380 420 CXB1304-0000000F0UB240H CXB1304-0000000F0UB240G B4 410 453 C2 440 486 Group Order Code Group Order Code 5-Step Group Order Code CXB1304-0000000F0BC450E 50E CXB1304-0000000F0BD250E CXB1304-0000000F0BD450E CXB1304-0000000F0HC250G 50G 50G CXB1304-0000000F0HC450G CXB1304-0000000F0HC250E 50E CXB1304-0000000F0HC450E CXB1304-0000000F0UC250G CXB1304-0000000F0UC450G CXB1304-0000000F0BC440E 40E CXB1304-0000000F0BD240E CXB1304-0000000F0BD440E CXB1304-0000000F0HC240H 40H 40H CXB1304-0000000F0HC440H CXB1304-0000000F0UB440H CXB1304-0000000F0UC240H CXB1304-0000000F0HC240G 40G 40G CXB1304-0000000F0HC440G CXB1304-0000000F0UB440G CXB1304-0000000F0UC240G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 33). • CXB1304 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS116 REV 9A 10 XLAMP ® CXB1304 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 18 V (IF = 200 mA, TJ = 85 °C) - CONTINUED CRI* Nominal CCT Min 80 Minimum Luminous Flux Typ --- 3500 K 90 80 Flux (lm) @ 85 °C Flux (lm) @ 25 °C** B4 410 453 C2 440 486 C4 475 525 CXB1304-0000000F0HC435H CXB1304-0000000F0HC435G A4 355 392 CXB1304-0000000F0UA435H CXB1304-0000000F0UA435G B2 380 420 CXB1304-0000000F0UB235H CXB1304-0000000F0UB235G B4 410 453 CXB1304-0000000F0UB435H C2 440 486 CXB1304-0000000F0UC235H CXB1304-0000000F0UC235G B4 410 453 CXB1304-0000000F0HB430H CXB1304-0000000F0HB430G C2 440 486 C4 475 525 CXB1304-0000000F0HC430H CXB1304-0000000F0HC430G A4 355 392 CXB1304-0000000F0UA430H CXB1304-0000000F0UA430G B2 380 420 B4 410 453 CXB1304-0000000F0UB430H CXB1304-0000000F0UB430G B4 410 453 CXB1304-0000000F0HB427H CXB1304-0000000F0HB427G C2 440 486 C4 475 525 CXB1304-0000000F0HC427H CXB1304-0000000F0HC427G A2 330 364 CXB1304-0000000F0UA227H CXB1304-0000000F0UA227G A4 355 392 B2 380 420 B2 380 420 Group 80 92 --- 35H 35H 30H 30H 27H 2700 K 90 2200 K 80 92 --- Order Code Group CXB1304-0000000F0HB435H 3000 K 90 3-Step Group 92 --- 2-Step 27H CXB1304-0000000F0HC235H CXB1304-0000000F0HC230H CXB1304-0000000F0UB230H CXB1304-0000000F0HC227H CXB1304-0000000F0UA427H Order Code 5-Step Group Order Code CXB1304-0000000F0HB435G 35G 35G 30G 30G 27G 27G CXB1304-0000000F0UB227H CXB1304-0000000F0HC235G CXB1304-0000000F0UB435G CXB1304-0000000F0HC230G CXB1304-0000000F0UB230G CXB1304-0000000F0HC227G CXB1304-0000000F0UA427G CXB1304-0000000F0UB227G 22G CXB1304-0000000F0HB222G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 33). • CXB1304 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS116 REV 9A 11 XLAMP ® CXB1304 LED FLUX CHARACTERISTICS, PREMIUM COLOR ORDER CODES AND BINS - 18 V (I F = 200 mA, TJ = 85 °C) Fidelity CRI* Nominal CCT Minimum Luminous Flux Min Typ Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** 4000 K 95 98 B2 380 420 3500 K 95 98 A4 355 3000 K 95 98 A4 2700 K 95 98 A2 Typical Luminous Flux (lm) @ 85 °C 2-Step Group Order Code 402 L5A CXB1304-0000-000F0ZB2L5A 392 387 35H CXB1304-0000-000F0ZA435H 355 392 372 30H CXB1304-0000-000F0ZA430H 330 361 351 27H CXB1304-0000-000F0ZA227H Specialty CRI Nominal CCT 3100 K 3000 K Minimum Luminous Flux Typical Luminous Flux (lm) @ 85 °C Min Typ Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** 90 92 B4 410 453 430 80 82 C2 440 486 490 90 92 B4 410 453 425 95 98 A2 330 361 355 2-Step Group L7B L7C Order Code 3-Step Group Order Code 31Q CXB1304-0000000F0UB431Q 30Q CXB1304-0000000F0UB430Q Group Order Code 30U CXB1304-0000000F0UB430U CXB1304-0000000F0HC2L7B CXB1304-0000000F0ZA2L7C Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 33). • CXB1304 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS116 REV 9A 12 XLAMP ® CXB1304 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 36 V (IF = 100 mA, TJ = 85 °C) The following table provides order codes for XLamp CXB1304 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 30). CRI* Nominal CCT Min 70 Minimum Luminous Flux Typ --- 2-Step 3-Step 5-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** C4 475 525 D2 510 563 D4 550 607 CXB1304-0000000N0BD465E C2 440 486 CXB1304-0000000N0HC265E C4 475 525 D2 510 563 CXB1304-0000000N0HD265E C4 475 525 CXB1304-0000000N0BC457E D2 510 563 D4 550 607 CXB1304-0000000N0BD457E C2 440 486 CXB1304-0000000N0HC257E C4 475 525 D2 510 563 Group Order Code Group Order Code Group CXB1304-0000000N0BC465E 65E 6500 K 80 70 --- --- 65E 57E 5700 K 80 --- Order Code 57E CXB1304-0000000N0BD265E CXB1304-0000000N0HC465E CXB1304-0000000N0BD257E CXB1304-0000000N0HC457E CXB1304-0000000N0HD257E Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 33). • CXB1304 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS116 REV 9A 13 XLAMP ® CXB1304 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 36 V (IF = 100 mA, TJ = 85 °C) - CONTINUED CRI* Nominal CCT Min 70 5000 K 80 90 70 4000 K 80 90 Minimum Luminous Flux Typ --- --- 92 --- --- 92 2-Step 3-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** C4 475 525 D2 510 563 D4 550 607 C2 440 486 C4 475 525 D2 510 563 CXB1304-0000000N0HD250G B4 410 453 CXB1304-0000000N0UB450G C2 440 486 C4 475 525 C4 475 525 D2 510 563 D4 550 607 C2 440 486 C4 475 525 D2 510 563 CXB1304-0000000N0HD240H CXB1304-0000000N0HD240G B2 380 420 CXB1304-0000000N0UB240H CXB1304-0000000N0UB240G B4 410 453 C2 440 486 Group Order Code Group Order Code 5-Step Group Order Code CXB1304-0000000N0BC450E 50E CXB1304-0000000N0BD250E CXB1304-0000000N0BD450E CXB1304-0000000N0HC250G 50G 50G CXB1304-0000000N0HC450G CXB1304-0000000N0HC250E 50E CXB1304-0000000N0HC450E CXB1304-0000000N0UC250G CXB1304-0000000N0UC450G CXB1304-0000000N0BC440E 40E CXB1304-0000000N0BD240E CXB1304-0000000N0BD440E CXB1304-0000000N0HC240H 40H 40H CXB1304-0000000N0HC440H CXB1304-0000000N0UB440H CXB1304-0000000N0UC240H CXB1304-0000000N0HC240G 40G 40G CXB1304-0000000N0HC440G CXB1304-0000000N0UB440G CXB1304-0000000N0UC240G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 33). • CXB1304 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS116 REV 9A 14 XLAMP ® CXB1304 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 36 V (IF = 100 mA, TJ = 85 °C) - CONTINUED CRI* Nominal CCT Min 80 Minimum Luminous Flux Typ --- 3500 K 90 80 Flux (lm) @ 85 °C Flux (lm) @ 25 °C** B4 410 453 C2 440 486 C4 475 525 CXB1304-0000000N0HC435H CXB1304-0000000N0HC435G A4 355 392 CXB1304-0000000N0UA435H CXB1304-0000000N0UA435G B2 380 420 CXB1304-0000000N0UB235H CXB1304-0000000N0UB235G B4 410 453 CXB1304-0000000N0UB435H C2 440 486 CXB1304-0000000N0UC235H CXB1304-0000000N0UC235G B4 410 453 CXB1304-0000000N0HB430H CXB1304-0000000N0HB430G C2 440 486 C4 475 525 CXB1304-0000000N0HC430H CXB1304-0000000N0HC430G A4 355 392 CXB1304-0000000N0UA430H CXB1304-0000000N0UA430G B2 380 420 B4 410 453 CXB1304-0000000N0UB430H CXB1304-0000000N0UB430G B4 410 453 CXB1304-0000000N0HB427H CXB1304-0000000N0HB427G C2 440 486 C4 475 525 CXB1304-0000000N0HC427H CXB1304-0000000N0HC427G A2 330 364 CXB1304-0000000N0UA227H CXB1304-0000000N0UA227G A4 355 392 B2 380 420 B2 380 420 Group 80 92 --- 35H 35H 30H 30H 27H 2700 K 90 2200 K 80 92 --- Order Code Group CXB1304-0000000N0HB435H 3000 K 90 3-Step Group 92 --- 2-Step 27H CXB1304-0000000N0HC235H CXB1304-0000000N0HC230H CXB1304-0000000N0UB230H CXB1304-0000000N0HC227H CXB1304-0000000N0UA427H Order Code 5-Step Group Order Code CXB1304-0000000N0HB435G 35G 35G 30G 30G 27G 27G CXB1304-0000000N0UB227H CXB1304-0000000N0HC235G CXB1304-0000000N0UB435G CXB1304-0000000N0HC230G CXB1304-0000000N0UB230G CXB1304-0000000N0HC227G CXB1304-0000000N0UA427G CXB1304-0000000N0UB227G 22G CXB1304-0000000N0HB222G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 33). • CXB1304 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS116 REV 9A 15 XLAMP ® CXB1304 LED FLUX CHARACTERISTICS, PREMIUM COLOR ORDER CODES AND BINS - 36 V (I F = 100 mA, TJ = 85 °C) Fidelity CRI* Nominal CCT Minimum Luminous Flux Min Typ Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** 4000 K 95 98 B2 380 420 3500 K 95 98 A4 355 3000 K 95 98 A4 2700 K 95 98 A2 Typical Luminous Flux (lm) @ 85 °C 2-Step Group Order Code 402 L5A CXB1304-0000-000N0ZB2L5A 392 387 35H CXB1304-0000-000N0ZA435H 355 392 372 30H CXB1304-0000-000N0ZA430H 330 361 351 27H CXB1304-0000-000N0ZA227H Specialty CRI Nominal CCT 3100 K 3000 K Minimum Luminous Flux Typical Luminous Flux (lm) @ 85 °C Min Typ Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** 90 92 B4 410 453 430 80 82 C2 440 486 490 90 92 B4 410 453 425 95 98 A2 330 361 355 2-Step Group L7B L7C Order Code 3-Step Group Order Code 31Q CXB1304-0000000N0UB431Q 30Q CXB1304-0000000N0UB430Q Group Order Code 30U CXB1304-0000000N0UB430U CXB1304-0000000N0HC2L7B CXB1304-0000000N0ZA2L7C Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 33). • CXB1304 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS116 REV 9A 16 XLAMP ® CXB1304 LED RELATIVE SPECTRAL POWER DISTRIBUTION, EASYWHITE® The following graph is the result of a series of pulsed measurements at 400 mA for the 9-V CXB1304 LED, 200 mA for the 18-V CXB1304 LED and 100 mA for the 36-V CXB1304 LED and TJ = 85 °C. 100% Relative Spectral Power 90% 80% 70% 5000 K, 70 CRI 60% 4000 K, 70 CRI 50% 3000 K, 80 CRI 40% 3000 K, 90 CRI 30% 2200 K, 80 CRI 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS116 REV 9A 17 XLAMP ® CXB1304 LED RELATIVE SPECTRAL POWER DISTRIBUTION, PREMIUM COLOR The following graphs are the result of a series of pulsed measurements at 400  mA for the 9-V CXB1304 LED, 200  mA for the 18-V CXB1304 LED and 100 mA for the 36-V CXB1304 LED and TJ = 85 °C Fidelity 100% Relative Spectral Power 90% 80% 70% 60% 4000 K, Z CRI 50% 3500 K, Z CRI 3000 K, Z CRI 40% 2700 K, Z CRI 30% 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Relative Spectral Power Distribution Specialty 100% Relative Spectral Power 90% 80% 70% 31Q, 3100 K, 90 CRI 60% 30Q, 3000 K, 90 CRI 50% L7B, 3000 K 80 CRI 40% L7C, 3000 K, Z CRI 30% 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS116 REV 9A 18 XLAMP ® CXB1304 LED ELECTRICAL CHARACTERISTICS The following graphs are the result of a series of steady-state measurements. 9.50 9V Voltage (V) 9.25 9.00 Tc = 25 °C Tc = 55 °C 8.75 Tc = 85 °C Tc = 105 °C 8.50 8.25 8.00 200 300 400 500 600 700 800 900 1000 Current (mA) 19.0 18 V Voltage (V) 18.5 18.0 Tc = 25 °C Tc = 55 °C 17.5 Tc = 85 °C Tc = 105 °C 17.0 16.5 16.0 100 150 200 250 300 350 400 450 500 Current (mA) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS116 REV 9A 19 XLAMP ® CXB1304 LED ELECTRICAL CHARACTERISTICS - CONTINUED 38 36 V Voltage (V) 37 36 Tc = 25 °C Tc = 55 °C 35 Tc = 85 °C Tc = 105 °C 34 33 32 50 75 100 125 150 175 200 225 250 Current (mA) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS116 REV 9A 20 XLAMP ® CXB1304 LED RELATIVE LUMINOUS FLUX The relative luminous flux values provided below are the ratio of: • Measurements of CXB1304 at steady-state operation at the given conditions, divided by • Flux measured during binning, which is a pulsed measurement at 400 mA at TJ = 85 °C for the 9-V CXB1304 LED. Using the 9-V CXB1304 LED as an example, at steady-state operation of Tc = 55 °C, IF = 300 mA, the relative luminous flux ratio is 80% in the chart below. A 9-V CXB1304 LED that measures 380 lm during binning will deliver 304 lm (380 * 0.8) at steady-state operation of Tc = 55 °C, IF = 300 mA. 240% 9V Relative Luminous Flux 200% 160% Tc = 25 °C Tc = 55 °C 120% Tc = 85 °C Tc = 105 °C 80% 40% 0% 200 300 400 500 600 700 800 900 1000 Current (mA) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS116 REV 9A 21 XLAMP ® CXB1304 LED RELATIVE LUMINOUS FLUX - CONTINUED The relative luminous flux values provided below are the ratio of: • Measurements of CXB1304 at steady-state operation at the given conditions, divided by • Flux measured during binning, which is a pulsed measurement at 200 mA at TJ = 85 °C for the 18-V CXB1304 LED. Using the 18-V CXB1304 LED as an example, at steady-state operation of Tc = 55 °C, IF = 150 mA, the relative luminous flux ratio is 80% in the chart below. An 18-V CXB1304 LED that measures 380 lm during binning will deliver 304 lm (380 * 0.8) at steady-state operation of Tc = 55 °C, IF = 150 mA. 240% 18 V Relative Luminous Flux 200% 160% Tc = 25 °C Tc = 55 °C 120% Tc = 85 °C Tc = 105 °C 80% 40% 0% 100 150 200 250 300 350 400 450 500 Current (mA) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS116 REV 9A 22 XLAMP ® CXB1304 LED RELATIVE LUMINOUS FLUX - CONTINUED The relative luminous flux values provided below are the ratio of: • Measurements of CXB1304 at steady-state operation at the given conditions, divided by • Flux measured during binning, which is a pulsed measurement at 100 mA at TJ = 85 °C for the 36-V CXB1304 LED. Using the 36-V CXB1304 LED as an example, at steady-state operation of Tc = 55 °C, IF = 75 mA, the relative luminous flux ratio is 80% in the chart below. A 36-V CXB1304 LED that measures 380 lm during binning will deliver 304 lm (380 * 0.8) at steady-state operation of Tc = 55 °C, IF = 75 mA. 240% 36 V Relative Luminous Flux 200% 160% Tc = 25 °C Tc = 55 °C 120% Tc = 85 °C Tc = 105 °C 80% 40% 0% 50 75 100 125 150 175 200 225 250 Current (mA) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS116 REV 9A 23 XLAMP ® CXB1304 LED TYPICAL SPATIAL DISTRIBUTION 100% Relative Luminous Intensity 80% 60% 40% 20% -90 -70 -50 -30 -10 0% 10 30 50 70 90 Angle (º) PERFORMANCE GROUPS - BRIGHTNESS (9 V, IF = 400 mA; 18 V, IF = 200 mA; 36 V, IF = 100 mA, TJ = 85 °C) XLamp CXB1304 LEDs are tested for luminous flux and placed into one of the following bins. Group Code Minimum Luminous Flux Maximum Luminous Flux A2 330 355 A4 355 380 B2 380 410 B4 410 440 C2 440 475 C4 475 510 D2 510 550 D4 550 590 E2 590 635 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS116 REV 9A 24 XLAMP ® CXB1304 LED PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) XLamp CMB1304 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. EasyWhite Color Temperatures – 2-Step Code 40H 35H 30H 27H CCT 4000 K 3500 K 3000 K 2700 K x y 0.3777 0.3739 0.3797 0.3816 0.3861 0.3855 0.3838 0.3777 0.4022 0.3858 0.4053 0.3942 0.4125 0.3977 0.4091 0.3891 0.4287 0.3975 0.4328 0.4064 0.4390 0.4086 0.4347 0.3996 0.4524 0.4048 0.4574 0.4140 0.4633 0.4154 0.4581 0.4062 EasyWhite Color Temperatures – 3-Step Ellipse Bin Code CCT 50G 40G Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 5000 K 0.3447 0.3553 0.00840 0.00312 65.0 4000 K 0.3818 0.3797 0.00939 0.00402 53.7 35G 3500 K 0.4073 0.3917 0.00927 0.00414 54.0 30G 3000 K 0.4338 0.4030 0.00834 0.00408 53.2 27G 2700 K 0.4577 0.4099 0.00834 0.00420 48.5 22G 2200 K 0.5066 0.4158 0.00980 0.00480 45.5 EasyWhite Color Temperatures – 5-Step Ellipse Bin Code CCT 65E Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 6500 K 0.3123 0.3282 0.01110 0.00550 61.0 57E 5700 K 0.3287 0.3417 0.01230 0.00600 72.0 50E 5000 K 0.3447 0.3553 0.01400 0.00520 65.0 40E 4000 K 0.3818 0.3797 0.01565 0.00670 53.7 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS116 REV 9A 25 XLAMP ® CXB1304 LED PREMIUM COLOR PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) XLamp CXB1304 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. Fidelity EasyWhite Color Temperatures – 2-Step Code L5A 35H 30H 27H CCT 4000 K 3500 K 3000 K 2700 K x y 0.3764 0.3711 0.3784 0.3787 0.3847 0.3826 0.3825 0.3748 0.4022 0.3858 0.4053 0.3942 0.4125 0.3977 0.4091 0.3891 0.4287 0.3975 0.4328 0.4064 0.4390 0.4086 0.4347 0.3996 0.4524 0.4048 0.4574 0.4140 0.4633 0.4154 0.4581 0.4062 Specialty EasyWhite Color Temperatures – 2-Step Code L7B L7C CCT 3000 K 3000 K x y 0.4263 0.3848 0.4296 0.3916 0.4361 0.3938 0.4326 0.3868 0.4192 0.3754 0.4224 0.3823 0.4291 0.3847 0.4257 0.3777 EasyWhite Color Temperatures – 3-Step Ellipse Bin Code CCT 31Q Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 3100 K 0.4236 0.3888 0.00848 0.00455 50.3 30Q 3000 K 0.4305 0.3935 0.00834 0.00408 53.2 30U 3000 K 0.4274 0.3837 0.00834 0.00408 53.2 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS116 REV 9A 26 XLAMP ® CXB1304 LED EASYWHITE® BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) 0.45 ANSI C78.377 Quadrangle 0.44 2700 K EasyWhite 5-step 0.43 2200 K 2450 K 3000 K EasyWhite 3-step 0.42 EasyWhite 2-step 3500 K 0.41 4000 K 0.40 CCy 0.39 5000 K 4500 K 5700 K 0.38 0.37 6500 K 0.36 0.35 7000K 0.34 0.33 0.32 0.54 0.53 0.52 0.51 0.50 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.31 CCx © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS116 REV 9A 27 XLAMP ® CXB1304 LED PREMIUM COLOR BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) Fidelity (2-step) 0.44 2700K ANSI C78.377 Quadrangle 0.43 3000K 0.42 3500K 0.41 27H 4000K CCy 0.40 30H 4500K 35H 0.39 0.38 L5A 0.37 0.36 0.35 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. 0.48 0.47 0.46 0.45 0.44 CCx 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 CLD-DS116 REV 9A 28 XLAMP ® CXB1304 LED PREMIUM COLOR BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) - CONTINUED Speciality (2-step) 0.44 ANSI C78.377 Quadrangle 3000 K 0.43 0.42 3500 K CCy 0.41 0.40 0.39 L7B L7C 0.38 0.46 0.45 CCx 0.44 0.43 0.42 0.41 0.37 Speciality (3-step) 0.44 ANSI C78.377 Quadrangle 3000K 0.43 0.42 3500K CCy 0.41 0.40 30Q 0.39 31Q 30U 0.38 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. 0.46 0.45 CCx 0.44 0.43 0.42 0.41 0.37 CLD-DS116 REV 9A 29 XLAMP ® CXB1304 LED BIN AND ORDER CODE FORMATS Bin codes and order codes are configured as follows: Order Code Bin Code Series = CXB13 Series = CXB13 Internal code Chromaticity bin CRI Specification B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Z = 95 CRI minimum Vf class C0 = 9-V class F0 = 18-V class N0 = 36-V class SSSSSCC-HHHH-HHHGGRNNNNN Internal code Kit code SSSSSCC-WWW-FF-GGR-AAAAA CRI Specification B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Z = 95 CRI minimum Vf class C0 = 9-V class F0 = 18-V class N0 = 36-V class Performance class Flux bin Performance class MECHANICAL DIMENSIONS Dimensions are in mm. Tolerances unless otherwise specified: +.13 x° +1° B1304C = 9‑V CXB1304 B1304F = 18‑V CXB1304 B1304N = 36‑V CXB1304 B1304X Meaning of B1304X © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS116 REV 9A 30 XLAMP ® CXB1304 LED THERMAL DESIGN The CXB family of LED arrays can include over a hundred different LED die inside one package, and thus over a hundred different junction temperatures (TJ). Cree LED has intentionally removed junction-temperature-based operating limits and replaced the commonplace maximum TJ calculations with maximum ratings based on forward current (IF) and case temperature (Tc). No additional calculations are required to ensure that the CXB LED is being operated within its designed limits. LES temperature measurement provides additional verification of good thermal design. Please refer to page 3 for the Operating Limit specifications. There is no need to calculate for TJ inside the package, as the thermal management design process, specifically from TSP to ambient (Ta), remains identical to any other LED component. For more information on thermal management of XLamp LEDs, please refer to the Thermal Management application note. For CXB soldering recommendations and more information on thermal interface materials (TIM), LES temperature measurement, and connection methods, please refer to the XLamp CX Family LEDs soldering and handling document. The CX Family LED Design Guide provides basic information on the requirements to use XLamp CXB LEDs successfully in luminaire designs. To keep the CXB1304 LED at or below the maximum rated Tc, the case to ambient temperature thermal resistance (R_c-a) must be at or below the maximum R_c-a value shown on the following graphs, depending on the operating environment. The y‑axis in each graph is a base 10 logarithmic scale. As the figure at right shows, the R_c-a value is the sum of the thermal resistance of the TIM (R_tim) R_j-c R_j-c Tc Tc R_tim R_c-a plus the thermal resistance of the heat sink (R_hs). R_hs CXB1304-9V Ta Ta 100.00 9V Maximum R_c-a 10.00 Ta = 25 °C Ta = 55 °C 1.00 Ta = 85 °C Ta = 105 °C 0.10 0.01 200 300 400 500 600 700 800 900 1000 Current (mA) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS116 REV 9A 31 XLAMP ® CXB1304 LED CXB1304-18V THERMAL DESIGN - CONTINUED 100.00 18 V Maximum R_c-a 10.00 Ta = 25 °C Ta = 55 °C 1.00 Ta = 85 °C Ta = 105 °C 0.10 0.01 100 150 200 250 300 350 400 450 500 Current (mA) CXB1304-36V 100.00 36 V Maximum R_c-a 10.00 Ta = 25 °C Ta = 55 °C 1.00 Ta = 85 °C Ta = 105 °C 0.10 0.01 50 75 100 125 150 175 200 225 250 Current (mA) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS116 REV 9A 32 XLAMP ® CXB1304 LED NOTES Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs. Lumen Maintenance Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. REACh Compliance REACh substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative to insure you get the most up-to-date REACh Declaration. REACh banned substance information (REACh Article 67) is also available upon request. UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS116 REV 9A 33 XLAMP ® CXB1304 LED PACKAGING CXB1304 LEDs are packaged in trays of 20. Five trays are sealed in an anti-static bag and placed inside a carton, for a total of 100 LEDs per carton. Each carton contains 100 LEDs from the same performance bin. Dimensions are in inches. REV 5 5.875 NSENT 5.875 DESC. 4 6 5 Tolerances: +.13 DATE BY REV CHK. DESC. 3 R.375 NOTICE ENTIAL. THIS PLOT AND THE INFORMATION WITHIN ARE THE PROPRIETARY AND L INFORMATION OF CREE, INC. THIS PLOT COPIED, REPRODUCED OR DISCLOSED TO ANY ED PERSON WITHOUT THE WRITTEN CONSENT DATE 2 BY CHK. x° +1° 1 R.375 4 .562 3 .562 2 1 5.875 R .375 .875 .875 5.875 R .375 5.875 .875 .875 5.875 .38 .875 .58 PATENT LABEL IS LOCATED ON UNDERSIDE OF CARTON SECTION C-C ITH CREE BIN ANTITY, LOT # EL IS LOCATED IDE OF COVER LABEL WITH CREE BIN .875 CODE, QUANTITY, LOT DO# SECTION C-C NOT SCALE DWG. PATENT LABEL IS LOCATED ON UNDERSIDE OF COVER THIS DRAWING CONTAINS PROPRIETARY DESIGN INFORMATION AND REMAINS ALONG WITH THE PRODUCT OR PRODUCTS REPRESENTED HEREIN THE PROPERTY OF TEK PAK, INCORPORATED. THIS DOCUMENT AND THE INFORMATION IT CONTAINS DWG.TITLE MAY NOT BE COPIED, TRANSMITTED, OR USED BY ANY THIRD PARTY WITHOUT THE EXPRESS WRITTEN APPROVAL OF TEK PAK, INCORPORATED. .38 .875 .38 UNLESS OTHERWISE NOTED ALL THIS DRAWING CONTAINS PROPRIETARY DESIGN INFORMATION AND REMAINS ALONG WITH THE PRODUCT OR PRODUCTS REPRESENTED HEREIN THE PROPERTY OF TEK PAK, INCORPORATED. THIS DOCUMENT AND THE INFORMATION IT CONTAINS DWG.TITLE MAY NOT BE COPIED, TRANSMITTED, OR USED BY ANY THIRD PARTY WITHOUT THE EXPRESS WRITTEN APPROVAL BAG OF TEK PAK, INCORPORATED. PART DRAWING BAG DATE: NOTED ALL SCALE: 1.000 4-3-13 UNLESS SIZE OTHERWISE DWG. NO. TOLERANCES ARE AS FOLLOWS: ±1/64 X.X" ±.030 X.0mm ±.75mm KJS FRACT ANGLES ±0°-30' X.XX" ±.015 X.Xmm ±.30mm DO NOT DR. BY: SCALE DWG. CHK. BY: TOLERANCES ARE AS FOLLOWS: FRACT ±1/64 X.X" ±.030 X.0mm ±.75mm ANGLES ±0°-30' X.XX" ±.015 X.Xmm ±.30mm DRAFT ±1° X.XXX" ±.005 X.XXmm ±.10mm .38 B DRAFT ±1° 022490-00 X.XXX" ±.005 X.XXmm ±.10mm SHEET 2 OF 2 PART DRAWING DATE: DR. BY: CHK. BY: 4-3-13 KJS SIZE B SCALE: 1.000 DWG. NO. 022490-00 SHEET 2 OF 2 LABEL WITH CREE BIN CODE, QUANTITY, LOT # LABEL WITH CREE BIN CODE, QUANTITY, LOT # LABEL WITH CREE BIN CODE, QUANTITY, LOT # UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS & BEFORE FINISH. TOLERANCE UNLESS SPECIFIED: LABEL WITH CREE BIN CODE, QUANTITY, LOT # L WITH CREE BIN QUANTITY, LOT # 6 .X ± 0.1 .XX ± .05 .XXX ±DRAWN .005BY X° ± 1 ° THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED DIMENSIONS AREFOR IN SHEET METAL PARTS ONLY CHECK MILLIMETERS & BEFORE FINISH. .X ± .06 TOLERANCE UNLESS SPECIFIED: .XX ± .03 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered .XXX and ±APPROVED .010 .X ± trademarks, 0.1 X° ± 2 ° ± .05 registered the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the.XXUL logo are 5 4 3 .XXX ± .005 trademarks of UL LLC. THIRD ANGLE PROJECTION MATERIAL X° ± 1 ° FOR SHEET METAL PARTS ONLY .X ± .06 DRAWN BY DATE CHECK DATE APPROVED DATE Phone (919) 361- Fax (919) 313-530 TITLE CXA15XX_DATASHEET DATE MATERIAL SIZE DATE FINAL PROTECTIVE FINISH DATE TITLE C DRAWING NO. 4600 Silicon Drive Durham, N.C 27703 Phone (919) 361-4770 CXA15XX_DATASHEET_BAG2013 CLD-DS116 SCALE 0.500 REV 9A 34 Fax (919) 313-5303 SHEET CXA15XX_DATASHEET 2 SIZE FINAL PROTECTIVE FINISH 4600 Silicon Drive Durham, N.C 277 1 DRAWING NO. CXA15XX_DATASHEET_BAG2013 OF
物料型号:XLamp® CXB1304 LED
器件简介:XLamp® CXB1304 LED阵列是CXA系列第二代中最紧凑的成员,与第一代相比,在相同的小尺寸封装(LES)中提供高达30%的更高效率和高达20%的更高流明输出。第二代CXA LED阵列与第一代兼容,为现有的CXA LED设计提供了性能升级,缩短了照明设计周期并加快了上市时间。
引脚分配:文档中未明确提供引脚分配的详细信息,但提到了顶部侧面焊接连接。
参数特性: - 6-mm光学光源 - 与CXA13系列LEDs在机械和光学设计上一致 - 提供70-95的最小CRI选项 - EasyWhite® 2步、3步和5步分选 - 高级颜色2步和3步分选 - 符合CE、RoHS和REACh标准 - UL®认可组件(E349212) - 提供9V、18V和36V的正向电压选项 - 85°C分选和特性描述
功能详解: - 非常均匀的颜色在视角上 - 热电偶附着点
应用信息:CXB1304 LED提供高流明输出和高效率,适用于小型尺寸照明应用。
封装信息:LED阵列包含100多个不同的LED芯片,具有多个结温(T_J)。Cree LED有意移除了基于结温的操作限制,并用基于正向电流(IF)和外壳温度(Tc)的最大额定值取代了常见的最大T_J计算。不需要额外的计算来确保CXB LED在其设计限制内运行。
CXB1304-0000-000C0UA427G 价格&库存
很抱歉,暂时无法提供与“CXB1304-0000-000C0UA427G”相匹配的价格&库存,您可以联系我们找货
