BXRC-17E10K0-C-74-SE
    BRIDGELUX(普瑞)
BXRC-17E10K0-C-74-SE 数据手册
Bridgelux Décor Series™ on Vero SE Series LED Array ® ® Product Data Sheet DS124 BXRC-27H1000 BXRC-17E4000 | 27H2000 | 27H4000 | 30H1000 | 30H2000 | 30H4000 | 25E4000 | 56G4001 | 17E10K0 | 25E10K0 | 56G10K1 Vero SE Introduction The Bridgelux Décor SeriesTM on Vero® SE Series line of products produce unmatched quality of light with brilliant color rendering options designed specifically for high end, niche applications. The Bridgelux Décor Series line of specialty LED products is available on the Bridgelux Vero SE Series of chip on board products. Décor SeriesTM Ultra products provide a high CRI of 97, befitting of the most luxurious retail shops and world renowned museums. Décor SeriesTM Food products offer color points developed to address the unique requirements of the food, grocery, and restaurant industries. Highlighting the distinctive colors and nuanced patterns found in meats and breads, the Décor Food products are a must have for any butcher counter or bakery. Décor SeriesTM Specialty products provide color points developed specifically for the healthcare and entertainment industries. The 5600K color point combined with a CRI of 90 provides the bright white required by these industries. Décor Series on Vero SE is available in four different light emitting surface (LES) configurations and has been engineered to reliably operate over a broad current range, enabling new degrees of flexibility in luminaire design optimization. Décor Series on Vero SE arrays deliver increased lumen density to enable improved beam control and precision lighting with 2, 3 and 4 SDCM color control standard for clean and consistent uniform lighting. Décor includes poke-in connectivity to enable simplified manufacturing and assembly processes. Secondary connector and holder components are not required, allowing the integration of arrays into fixtures more streamlined without the need for soldering. Features • Poke-in connectivity • Typical 97 CRI with a 95 CRI minimum (Décor Series Ultra) • Application specific color points • Typical R9 value of 98 for brilliant rendering of red colors and skin tones (Décor Series Ultra) • 2 and 3 SDCM color control • Reliable operation at up to 2X nominal drive current • Radial die pattern and improved lumen density • Top side part number markings • No exposed solder pads or electrical connections Benefits • Poke-in connectivity enables solderless and connector free installation • Broad application coverage for interior lighting requiring state of the art color rendering • Flexibility for application driven lighting design requirements • High quality true color reproduction • Uniform consistent white light • Flexibility in design optimization • Improved optical control • Enhanced ease of use and manufacturability • Ability to configure multiple arrays in series and parallel reduces customer driver cost • Improved inventory management and quality control Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Performance at Commonly Used Drive Currents 5 Electrical Characteristics 10 Eye Safety 11 Absolute Maximum Ratings 12 Performance Curves 13 Typical Radiation Pattern 20 Typical Color Spectrum 21 Mechanical Dimensions 22 Color Binning Information 26 Packaging and Labeling 27 Design Resources 30 Precautions 30 Disclaimers 30 About Bridgelux 31 1 Product Feature Map In addition to delivering the performance and light quality required for many lighting applications, Décor Series on Vero SE LED arrays incorporate several features to simplify the design integration and manufacturing process, accelerate time to market and reduce system costs. Décor Series on Vero SE incorporates several features to simplify the design integration and manufacturing process, accelerate time to market and reduce system costs. Polarity indication marks simplify manufacturing operator instructions Wire release mechanisms x4 2D Bar code provides full manufacturing traceability Optic mounting holes Tc Measurement point Radial die configuration improves lumen density and beam control Mounting location Zhaga Book 3 compatible mounting locations Top side part number marking improves inventory management and outgoing quality control Test port for probing Dual poke-in connectors Product Nomenclature The part number designation for Bridgelux Décor Series on Vero SE LED arrays is explained as follows: 1 2 3 4 5 6 7 8 9 10 11 – 12 – 13 14 - 16 17 BXRC – 30 H 100 0 – B – 7 3 - SE Special Edition Product Family Nominal CCT 17 = 1,750K 25 = 2,500K 27 = 2,700K 30 = 3,000K 56 = 5,600K Typical CRI E = 80 CRI G = 90 CRI H = 97 CRI CCT Bin Options 3 = 3 SDCM 4 = 4 SDCM Gen. 7 Array Configuration Nominal Flux 100x = 1000lm 200x = 2000lm 400x = 4000lm 10Kx = 10,000lm Color Targeting Designator 0 = Cold Targeted (1750K-4000K) 1 = Hot Targeted (5000K-6500K) 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) Product Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) Décor Ultra Vero SE 10B BXRC-27H1000-B-7x-SE 2700 97 270 1028 905 35.0 9.5 109 Décor Ultra Vero SE 10C BXRC-27H1000-C-7x-SE 2700 97 360 1371 1206 35.0 12.6 109 Décor Ultra Vero SE 10D BXRC-27H1000-D-7x-SE 2700 97 350 999 880 26.0 9.1 110 Décor Ultra Vero SE 10B BXRC-30H1000-B-7x-SE 3000 97 270 1101 969 35.0 9.5 117 Décor Ultra Vero SE 10C BXRC-30H1000-C-7x-SE 3000 97 360 1468 1292 35.0 12.6 116 Décor Ultra Vero SE 10D BXRC-30H1000-D-7x-SE 3000 97 350 1070 942 26.0 9.1 118 Décor Ultra Vero SE 13B BXRC-27H2000-B-7x-SE 2700 97 450 1789 1611 35.0 15.8 114 Décor Ultra Vero SE 13C BXRC-27H2000-C-7x-SE 2700 97 630 2505 2255 35.0 22.1 114 Décor Ultra Vero SE 13D BXRC-27H2000-D-7x-SE 2700 97 500 1823 1641 31.8 15.9 115 121 Décor Ultra Vero SE 13B BXRC-30H2000-B-7x-SE 3000 97 450 1912 1721 35.0 15.8 Décor Ultra Vero SE 13C BXRC-30H2000-C-7x-SE 3000 97 630 2676 2409 35.0 22.1 121 Décor Ultra Vero SE 13D BXRC-30H2000-D-7x-SE 3000 97 500 1947 1752 31.8 15.9 122 114 Décor Ultra Vero SE 18B BXRC-27H4000-B-7x-SE 2700 97 900 3605 3243 35.0 31.5 Décor Ultra Vero SE 18C BXRC-27H4000-C-7x-SE 2700 97 1170 4686 4217 35.0 41.0 114 Décor Ultra Vero SE 18D BXRC-27H4000-D-7x-SE 2700 97 1050 3504 3153 29.0 30.5 115 122 Décor Ultra Vero SE 18B BXRC-30H4000-B-7x-SE 3000 97 900 3850 3465 35.0 31.5 Décor Ultra Vero SE 18C BXRC-30H4000-C-7x-SE 3000 97 1170 5007 4506 35.0 41.0 122 Décor Ultra Vero SE 18D BXRC-30H4000-D-7x-SE 3000 97 1050 3744 3370 29.0 30.5 123 Décor Food Vero SE 18B BXRC-17E4000-B-74-SE 1750 80 900 2649 2385 35.0 31.5 84 Décor Food Vero SE 18C BXRC-17E4000-C-74-SE 1750 80 1170 3445 3100 35.0 41.0 84 Décor Food Vero SE 18D BXRC-17E4000-D-74-SE 1750 80 1050 2576 2318 29.0 30.5 85 Décor Food Vero SE 18B BXRC-25E4000-B-74-SE 2500 80 900 4282 3853 35.0 31.5 136 136 Décor Food Vero SE 18C BXRC-25E4000-C-74-SE 2500 80 1170 5568 5011 35.0 41.0 Décor Food Vero SE 18D BXRC-25E4000-D-74-SE 2500 80 1050 4163 3747 29.0 30.5 137 Décor Specialty Vero SE 18B BXRC-56G4001-B-74-SE 5600 90 900 4559 4103 35.0 31.5 145 Décor Specialty Vero SE 18C BXRC-56G4001-C-74-SE 5600 90 1170 5928 5335 35.0 41.0 145 Décor Specialty Vero SE 18D BXRC-56G4001-D-74-SE 5600 90 1050 4433 3989 29.0 30.5 146 Décor Food Vero SE 29B BXRC-17E10K0-B-74-SE 1750 80 1800 8033 7230 52.0 93.6 86 Décor Food Vero SE 29C BXRC-17E10K0-C-74-SE 1750 80 1710 10175 9157 69.4 118.7 86 Décor Food Vero SE 29D BXRC-17E10K0-D-74-SE 1750 80 2100 6768 6092 37.6 79.0 86 Décor Food Vero SE 29B BXRC-25E10K0-B-74-SE 2500 80 1800 12983 11685 52.0 93.6 139 139 Décor Food Vero SE 29C BXRC-25E10K0-C-74-SE 2500 80 1710 16446 14801 69.4 118.7 Décor Food Vero SE 29D BXRC-25E10K0-D-74-SE 2500 80 2100 10940 9845 37.6 79.0 139 Décor Specialty Vero SE 29B BXRC-56G10K1-B-74-SE 5600 90 1800 13824 12442 52.0 93.6 148 Décor Specialty Vero SE 29C BXRC-56G10K1-C-74-SE 5600 90 1710 17510 15760 69.4 118.7 148 Décor Specialty Vero SE 29D BXRC-56G10K1-D-74-SE 5600 90 2100 11648 10483 37.6 79.0 148 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with CCTs 5000K-6500K are hot targeted to 85°C. 2. CRI Values are minimums. Minimum R9 value at Tj = Tc = 25°C for 80 CRI products is 0, the minimum R9 values for warm white and neutral white 90 CRI products is 60, the minimum R9 values for cool white 90 CRI products is 50. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and not a guarantee of performance. 6. Bridgelux maintains a ± 7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 3 Product Selection Guide The following product configurations are available: Table 2: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 Product Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) 101 Décor Ultra Vero SE 10B BXRC-27H1000-B-7x-SE 2700 97 270 926 814 34.0 9.2 Décor Ultra Vero SE 10C BXRC-27H1000-C-7x-SE 2700 97 360 1233 1086 34.0 12.3 101 Décor Ultra Vero SE 10D BXRC-27H1000-D-7x-SE 2700 97 350 899 792 25.3 8.9 102 Décor Ultra Vero SE 10B BXRC-30H1000-B-7x-SE 3000 97 270 991 872 34.0 9.2 108 Décor Ultra Vero SE 10C BXRC-30H1000-C-7x-SE 3000 97 360 1321 1163 34.0 12.3 108 Décor Ultra Vero SE 10D BXRC-30H1000-D-7x-SE 3000 97 350 963 848 25.3 8.9 109 Décor Ultra Vero SE 13B BXRC-27H2000-B-7x-SE 2700 97 450 1611 1450 34.1 15.3 105 Décor Ultra Vero SE 13C BXRC-27H2000-C-7x-SE 2700 97 630 2254 3468 34.1 21.5 105 Décor Ultra Vero SE 13D BXRC-27H2000-D-7x-SE 2700 97 500 1641 4510 30.9 15.5 106 112 Décor Ultra Vero SE 13B BXRC-30H2000-B-7x-SE 3000 97 450 1721 1549 34.1 15.3 Décor Ultra Vero SE 13C BXRC-30H2000-C-7x-SE 3000 97 630 2409 2168 34.1 21.5 112 Décor Ultra Vero SE 13D BXRC-30H2000-D-7x-SE 3000 97 500 1753 1577 30.9 15.5 113 Décor Ultra Vero SE 18B BXRC-27H4000-B-7x-SE 2700 97 900 3244 2919 34.1 30.7 106 Décor Ultra Vero SE 18C BXRC-27H4000-C-7x-SE 2700 97 1170 4218 3796 34.3 40.1 105 Décor Ultra Vero SE 18D BXRC-27H4000-D-7x-SE 2700 97 1050 3153 2838 28.1 29.5 107 Décor Ultra Vero SE 18B BXRC-30H4000-B-7x-SE 3000 97 900 3465 3119 34.1 30.7 113 Décor Ultra Vero SE 18C BXRC-30H4000-C-7x-SE 3000 97 1170 4506 4055 34.3 40.1 112 Décor Ultra Vero SE 18D BXRC-30H4000-D-7x-SE 3000 97 1050 3369 3033 28.1 29.5 114 Décor Food Vero SE 18B BXRC-17E4000-B-74-SE 1750 80 900 2384 2146 34.1 30.7 78 Décor Food Vero SE 18C BXRC-17E4000-C-74-SE 1750 80 1170 3100 2790 34.3 40.1 77 Décor Food Vero SE 18D BXRC-17E4000-D-74-SE 1750 80 1050 2318 2087 28.1 29.5 79 Décor Food Vero SE 18B BXRC-25E4000-B-74-SE 2500 80 900 3853 3468 34.1 30.7 126 Décor Food Vero SE 18C BXRC-25E4000-C-74-SE 2500 80 1170 5011 4510 34.3 40.1 125 Décor Food Vero SE 18D BXRC-25E4000-D-74-SE 2500 80 1050 3747 3372 28.1 29.5 127 Décor Specialty Vero SE 18B BXRC-56G4001-B-74-SE 5600 90 900 4103 3693 34.1 30.7 134 Décor Specialty Vero SE 18C BXRC-56G4001-C-74-SE 5600 90 1170 5335 4801 34.3 40.1 133 Décor Specialty Vero SE 18D BXRC-56G4001-D-74-SE 5600 90 1050 3989 3591 28.1 29.5 135 Décor Food Vero SE 29B BXRC-17E10K0-B-74-SE 1750 80 1800 7230 6507 50.7 91.2 79 Décor Food Vero SE 29C BXRC-17E10K0-C-74-SE 1750 80 1710 9157 8241 68.4 116.9 78 Décor Food Vero SE 29D BXRC-17E10K0-D-74-SE 1750 80 2100 6091 5483 36.3 76.2 80 Décor Food Vero SE 29B BXRC-25E10K0-B-74-SE 2500 80 1800 11685 10516 50.7 91.2 128 Décor Food Vero SE 29C BXRC-25E10K0-C-74-SE 2500 80 1710 14801 13321 68.4 116.9 127 Décor Food Vero SE 29D BXRC-25E10K0-D-74-SE 2500 80 2100 9846 8861 36.3 76.2 129 136 Décor Specialty Vero SE 29B BXRC-56G10K1-B-74-SE 5600 90 1800 12442 11198 50.7 91.2 Décor Specialty Vero SE 29C BXRC-56G10K1-C-74-SE 5600 90 1710 15759 14184 68.4 116.9 135 Décor Specialty Vero SE 29D BXRC-56G10K1-D-74-SE 5600 90 2100 10483 9434 36.3 76.2 138 Notes for Tables 2: 1. Nominal CCT as defined by ANSI C78.377-2011. Prodcuts with a CCT of 5000K-6500K are hot targetd to 85°C. 2. CRI Values are minimums. Minimum R9 value at Tj = Tc = 25°C for 80 CRI products is 0, the minimum R9 values for warm white and neutral white 90 CRI products is 60, the minimum R9 values for cool white 90 CRI products is 50. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux 4 test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. Performance at Commonly Used Drive Currents Vero SE LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. Vero SE may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figure 1-12 and the flux vs. current characteristics shown in Figures 13-24. The performance at commonly used drive currents is summarized in Table 3. Table 3: Product Performance at Commonly Used Drive Currents Product Décor Ultra Vero SE 10 Décor Ultra Vero SE 10 Décor Ultra Vero SE 10 Décor Ultra Vero SE 10 Décor Ultra Vero SE 10 Décor Ultra Vero SE 10 Part Number BXRC-27H1000-B-7x-SE BXRC-27H1000-C-7x-SE BXRC-27H1000-D-7x-SE BXRC-30H1000-B-7x-SE BXRC-30H1000-C-7x-SE BXRC-30H1000-D-7x-SE CRI 97 97 97 97 97 97 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 122 135 33.3 4.5 548 493 180 33.8 6.1 719 647 118 270 35.0 9.5 1028 926 109 405 36.4 14.8 1509 1358 102 540 37.8 20.4 1933 1740 95 180 33.3 6.0 729 656 122 240 33.8 8.1 955 859 118 360 35.0 12.6 1371 1233 109 540 36.4 19.7 1996 1796 102 720 37.7 27.1 2549 2294 94 175 24.9 4.4 534 480 122 233 25.4 5.9 700 630 118 350 26.0 9.1 999 899 110 102 525 27.4 14.4 1471 1324 700 28.4 19.9 1884 1696 95 135 33.3 4.5 587 528 131 180 33.8 6.1 769 693 126 270 35.0 9.5 1101 991 117 405 36.4 14.8 1616 1454 109 540 37.8 20.4 2070 1863 102 180 33.3 6.0 780 702 130 240 33.8 8.1 1022 920 126 360 35.0 12.6 1468 1321 116 540 36.4 19.7 2137 1923 109 720 37.7 27.1 2730 2457 101 175 24.9 4.4 571 514 131 233 25.4 5.9 750 675 127 350 26.0 9.1 1070 963 118 525 27.4 14.4 1575 1418 110 700 28.4 19.9 2018 1816 101 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and not a guarantee of performance. 5 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (continued) Product Décor Ultra Vero SE 13 Décor Ultra Vero SE 13 Décor Ultra Vero SE 13 Décor Ultra Vero SE 13 Décor Ultra Vero SE 13 Décor Ultra Vero SE 13 Décor Ultra Vero SE 18 Décor Ultra Vero SE 18 Décor Ultra Vero SE 18 Part Number BXRC-27H2000-B-7x-SE BXRC-27H2000-C-7x-SE BXRC-27H2000-D-7x-SE BXRC-30H2000-B-7x-SE BXRC-30H2000-C-7x-SE BXRC-30H2000-D-7x-SE BXRC-27H4000-B-7x-SE BXRC-27H4000-C-7x-SE BXRC-27H4000-D-7x-SE CRI 97 97 97 97 97 97 97 97 97 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 113 32.3 3.7 487 439 133 225 33.2 7.5 943 849 126 450 35.0 15.8 1789 1611 114 675 36.3 24.5 2586 2327 106 900 37.5 33.7 3299 2969 98 158 32.3 5.1 677 609 132 315 33.2 10.5 1310 1179 125 630 35.0 22.1 2505 2254 114 104 945 36.4 34.4 3595 3236 1260 37.8 47.6 4589 4130 96 125 29.6 3.7 483 434 131 250 30.3 7.6 935 842 123 500 31.8 15.9 1823 1641 115 103 750 33.2 24.9 2576 2318 1000 34.4 34.4 3294 2964 96 113 32.3 3.7 521 469 143 225 33.2 7.5 1008 907 135 450 35.0 15.8 1912 1721 121 675 36.3 24.5 2763 2487 113 900 37.5 33.7 3525 3172 104 158 32.3 5.1 723 651 142 315 33.2 10.5 1400 1260 134 630 35.0 22.1 2676 2409 121 945 36.4 34.4 3841 3457 112 1260 37.8 47.6 4903 4413 103 140 125 29.6 3.7 515 464 250 30.3 7.6 999 899 132 500 31.8 15.9 1947 1753 122 750 33.2 24.9 2752 2477 111 1000 34.4 34.4 3519 3167 102 129 450 33.3 15.0 1935 1742 600 33.9 20.4 2539 2285 125 900 35.0 31.5 3605 3244 114 108 1350 36.7 49.5 5361 4825 1800 38.0 68.4 6899 6209 101 585 33.4 19.5 2449 2204 125 780 34.0 26.5 3209 2888 121 1170 35.0 41.0 4686 4218 114 104 1755 36.8 64.5 6742 6068 2340 38.1 89.3 8648 7783 97 525 27.7 14.6 1867 1680 128 700 28.2 19.8 2427 2184 123 1050 29.0 30.5 3504 3153 115 1575 30.4 47.9 5005 4504 104 2100 31.5 66.2 6371 5734 96 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and not a guarantee of performance. 6 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (continued) Product Décor Ultra Vero SE 18 Décor Ultra Vero SE 18 Décor Ultra Vero SE 18 Décor Food Vero SE 18 Décor Food Vero SE 18 Décor Food Vero SE 18 Décor Food Vero SE 18 Décor Food Vero SE 18 Décor Food Vero SE 18 Part Number BXRC-30H4000-B-7x-SE BXRC-30H4000-C-7x-SE BXRC-30H4000-D-7x-SE BXRC-17E4000-B-74-SE BXRC-17E4000-C-74-SE BXRC-17E4000-D-74-SE BXRC-25E4000-B-74-SE BXRC-25E4000-C-74-SE BXRC-25E4000-D-74-SE CRI 97 97 97 80 80 80 80 80 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 138 450 33.3 15.0 2067 1860 600 33.9 20.4 2712 2441 133 900 35.0 31.5 3850 3465 122 1350 36.7 49.5 5727 5154 116 1800 38.0 68.4 7369 6632 108 585 33.4 19.5 2616 2355 134 780 34.0 26.5 3428 3085 129 1170 35.0 41.0 5007 4506 122 1755 36.8 64.5 7203 6483 112 2340 38.1 89.3 9240 8316 104 137 525 27.7 14.6 1994 1795 700 28.2 19.8 2593 2334 131 1050 29.0 30.5 3744 3369 123 1575 30.4 47.9 5347 4813 112 2100 31.5 66.2 6807 6126 103 95 450 33.3 15.0 1422 1280 600 33.9 20.4 1866 1679 92 900 35.0 31.5 2649 2384 84 80 1350 36.7 49.5 3940 3546 1800 38.0 68.4 5070 4563 74 585 33.4 19.5 1800 1620 92 780 34.0 26.5 2358 2123 89 1170 35.0 41.0 3445 3100 84 1755 36.8 64.5 4955 4460 77 2340 38.1 89.3 6356 5721 71 525 27.7 14.6 1372 1235 94 700 28.2 19.8 1784 1606 90 1050 29.0 30.5 2576 2318 85 1575 30.4 47.9 3680 3312 77 2100 31.5 66.2 4684 4216 71 450 33.3 15.0 2299 2069 153 600 33.9 20.4 3016 2714 148 900 35.0 31.5 4282 3853 136 1350 36.7 49.5 6368 5731 129 1800 38.0 68.4 8195 7375 120 149 585 33.4 19.5 2909 2618 780 34.0 26.5 3812 3431 144 1170 35.0 41.0 5568 5011 136 124 1755 36.8 64.5 8010 7209 2340 38.1 89.3 10274 9247 115 525 27.7 14.6 2218 1996 152 700 28.2 19.8 2884 2595 146 1050 29.0 30.5 4163 3747 137 1575 30.4 47.9 5946 5352 124 2100 31.5 66.2 7570 6813 114 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and not a guarantee of performance. 7 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (continued) Product Décor Specialty Vero SE 18 Décor Specialty Vero SE 18 Décor Specialty Vero SE 18 Décor Food Vero SE 29 Décor Food Vero SE 29 Décor Food Vero SE 29 Part Number BXRC-56G4001-B-74-SE BXRC-56G4001-C-74-SE BXRC-56G4001-D-74-SE BXRC-17E10K0-B-74-SE BXRC-17E10K0-C-74-SE BXRC-17E10K0-D-74-SE CRI 90 90 90 80 80 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 450 33.3 15.0 2448 2203 163 600 33.9 20.4 3211 2890 158 145 900 35.0 31.5 4559 4103 1350 36.7 49.5 6781 6102 137 1800 38.0 68.4 8725 7853 127 585 33.4 19.5 3097 2788 159 780 34.0 26.5 4059 3653 153 1170 35.0 41.0 5928 5335 145 1755 36.8 64.5 8528 7675 132 2340 38.1 89.3 10939 9845 123 162 525 27.7 14.6 2361 2125 700 28.2 19.8 3070 2763 155 1050 29.0 30.5 4433 3989 146 1575 30.4 47.9 6331 5698 132 2100 31.5 66.2 8060 7254 122 94 900 49.6 44.7 4209 3788 1200 50.5 60.6 5554 4999 92 1800 52.0 93.6 8033 7230 86 2700 54.1 146.1 11844 10659 81 3600 55.8 201.0 15270 13743 76 855 66.2 56.6 5780 5202 102 1140 67.3 76.7 7346 6611 96 1710 69.4 118.7 10175 9157 86 78 2565 72.1 185.0 14434 12990 3420 74.4 254.6 18091 16282 71 1050 35.4 37.2 3723 3350 100 1400 36.2 50.7 4791 4312 95 2100 37.6 78.9 6768 6091 86 3150 39.5 124.4 6828 6145 55 4200 41.2 173.0 9635 8672 56 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and not a guarantee of performance. 8 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (continued) Product Décor Food Vero SE 29 Décor Food Vero SE 29 Décor Food Vero SE 29 Décor Specialty Vero SE 29 Décor Specialty Vero SE 29 Décor Specialty Vero SE 29 Part Number BXRC-25E10K0-B-74-SE BXRC-25E10K0-C-74-SE BXRC-25E10K0-D-74-SE BXRC-56G10K1-B-74-SE BXRC-56G10K1-C-74-SE BXRC-56G10K1-D-74-SE CRI 80 80 80 90 90 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 900 49.6 44.7 6803 6123 152 1200 50.5 60.6 8977 8079 148 1800 52.0 93.6 12983 11685 139 2700 54.1 146.1 19143 17229 131 3600 55.8 201.0 24682 22213 123 855 66.2 56.6 9342 8408 165 1140 67.3 76.7 11874 10687 155 1710 69.4 118.7 16446 14801 139 2565 72.1 185.0 23330 20997 126 3420 74.4 254.6 29242 26318 115 162 1050 35.4 37.2 6017 5416 1400 36.2 50.7 7744 6970 153 2100 37.6 78.9 10940 9846 139 3150 39.5 124.4 15574 14017 125 4200 41.2 173.0 19629 17666 113 900 49.6 44.7 7244 6520 162 1200 50.5 60.6 9558 8602 158 1800 52.0 93.6 13824 12442 148 140 2700 54.1 146.1 20383 18344 3600 55.8 201.0 26280 23652 131 855 66.2 56.6 9947 8952 176 1140 67.3 76.7 12643 11378 165 1710 69.4 118.7 17510 15759 148 134 2565 72.1 185.0 24840 22356 3420 74.4 254.6 31135 28021 122 1050 35.4 37.2 6407 5766 172 1400 36.2 50.7 8245 7421 163 2100 37.6 78.9 11648 10483 148 3150 39.5 124.4 16582 14924 133 4200 41.2 173.0 20900 18810 121 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and not a guarantee of performance. 9 Electrical Characteristics Table 4: Electrical Characteristics Part Number BXRC-xxx100x-B-7x-SE BXRC-xxx100x-C-7x-SE BXRC-xxx100x-D-7x-SE BXRC-xxx200x-B-7x-SE BXRC-xxx200x-C-7x-SE BXRC-xxx200x-D-7x-SE BXRC-xxx400x-B-7x-SE BXRC-xxx400x-C-7x-SE BXRC-xxx400x-D-7x-SE BXRC-xxx10Kx-B-7x-SE BXRC-xxx10Kx-C-7x-SE BXRC-xxx10Kx-D-7x-SE Nominal Drive Current 1 (mA) Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2,3, 8 Maximum Typical Coefficient of Forward Voltage4 ∆Vf/∆TC (mV/ºC) Typical Thermal Resistance Junction to Case5,6 Rj-c (C/W) Minimum Typical 270 32.4 35.0 37.6 -16.1 540 34.9 37.8 40.6 -16.1 360 32.4 35.0 37.6 -16.1 720 34.9 37.7 40.5 -16.1 Driver Selection Voltages7 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold4 Tc = -40ºC (V) 0.49 31.1 38.7 0.57 33.6 41.6 0.37 31.1 38.7 0.43 33.6 41.6 350 24.1 26.0 28.0 -11.8 0.49 23.1 28.7 700 26.3 28.4 30.5 -11.8 0.57 25.3 31.3 450 32.4 35.0 37.6 -14.3 0.28 31.2 38.6 900 34.7 37.5 40.3 -14.3 0.35 33.5 41.2 630 32.4 35.0 37.6 -14.3 0.20 31.2 38.6 1260 34.9 37.8 40.6 -14.3 0.24 33.8 41.5 500 29.4 31.8 34.2 -13.3 0.34 28.4 35.0 1000 31.8 34.4 37.0 -13.3 0.41 30.8 37.9 900 32.4 35.0 37.6 -14.9 0.15 31.2 38.6 1800 35.2 38.0 40.9 -14.9 0.19 34.0 41.8 1170 32.4 35.0 37.6 -14.9 0.11 31.2 38.6 2340 35.3 38.1 41.0 -14.9 0.13 34.1 42.0 1050 26.8 29.0 31.2 -12.2 0.16 25.8 32.0 2100 29.2 31.5 33.9 -12.2 0.19 28.2 34.7 1800 48.1 52.0 55.9 -24.9 0.06 46.1 57.5 3600 51.7 55.8 60.0 -24.9 0.07 49.7 61.6 1710 64.2 69.4 74.6 -33.2 0.04 61.5 76.8 3420 68.8 74.4 80.0 -33.2 0.05 66.2 82.2 2100 34.8 37.6 40.4 -17.4 0.06 33.4 41.6 4200 38.1 41.2 44.3 -17.4 0.07 36.7 45.4 Notes for Table 4: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± O.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± O.1mV for nominal current. 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 8. This product has been designed and manufactured per IEC 62031:2014. This product has passed dielectric withstand voltage testing at 1160 V. The working voltage designated for the insulation is 80V d.c. The maximum allowable voltage across the array must be determined in the end product application. 10 Eye Safety Table 5: Eye Safety Classification Part Number BXRC-xxx100x-B-7x-SE BXRC-xxx100x-C-7x-SE BXRC-xxx100x-D-7x-SE BXRC-xxx200x-B-7x-SE BXRC-xxx200x-C-7x-SE BXRC-xxx200x-D-7x-SE BXRC-xxx400x-B-7x-SE BXRC-xxx400x-C-7x-SE BXRC-xxx400x-D-7x-SE CCT1,2 Drive Current (mA) 2700K 3000K 270 RG1 RG1 405 RG1 RG1 540 RG1 RG1 360 RG1 RG1 540 RG1 RG1 720 3000K 350 RG1 RG1 RG1 RG1 525 RG1 RG1 700 RG1 RG1 450 RG1 RG1 675 RG1 RG1 900 RG1 RG1 630 RG1 RG1 945 RG1 RG1 1260 RG1 RG1 500 RG1 RG1 750 RG1 RG1 1000 RG1 RG1 900 RG1 RG1 1350 RG1 RG1 1800 RG1 RG1 1170 RG1 RG1 1755 RG1 RG1 2340 RG1 RG1 1050 RG1 RG1 1575 RG1 RG1 2100 RG1 RG1 Notes for Table 5: 1. Eye safety classification for the use of Bridgelux Vero Series LED arrays is in accordance with specification IEC/TR 62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. 2. Please contact your Bridgelux sales representative for Ethr values at specific drive currents and CCTs not listed. 11 Absolute Maximum Ratings Table 6: Maximum Ratings Parameter Maximum Rating LED Junction Temperature 125°C Storage Temperature -40°C to +105°C Operating Case Temperature1 105°C BXRC-xxx100x-B-7x-SE BXRC-xxx100x-C-7x-SE BXRC-xxx100x-D-7x-SE Maximum Drive Current2 540mA 720mA 700mA Maximum Peak Pulsed Drive Current3 770mA 1030mA 1000mA Maximum Reverse Voltage4 -60V -60V -45V BXRC-xxx200x-B-7x-SE BXRC-xxx200x-C-7x-SE BXRC-xxx200x-D-7x-SE Maximum Drive Current2 900mA 1260mA 1000mA Maximum Peak Pulsed Drive Current3 1290mA 1800mA 1430mA Maximum Reverse Voltage4 -60V -60V -55V BXRC-xxx400x-B-7x-SE BXRC-xxx400x-C-7x-SE BXRC-xxx400x-D-7x-SE Maximum Drive Current2 1800mA 2340mA 2100mA Maximum Peak Pulsed Drive Current3 2570mA 3340mA 3000mA Maximum Reverse Voltage4 -60V -60V -50V BXRC-xxx10Kx-B-7x-SE BXRC-xxx10Kx-C-7x-SE BXRC-xxx10Kx-D-7x-SE Maximum Drive Current2 3600mA 3420mA 4200mA Maximum Peak Pulsed Drive Current3 5140mA 4890mA 6000mA Maximum Reverse Voltage4 -90V -120V -65V Notes for Table 6: 1. For IEC 62717 requirement, please contact Bridgelux Sales Support. 2. Arrays may be driven at higher currents however lumen maintenance may be reduced. 3. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20ms when operating LED Arrays at the maximum peak pulsed current specified. Maximum peak pulsed current indicate values where the LED array can be driven without catastrophic failures. 4. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 12 Performance Curves Figure 1: Vero SE 10B Drive Current vs. Forward Voltage (Tj=Tc=25°C) Figure 2: Vero SE 10C Drive Current vs. Forward Voltage (Tj=Tc=25°C) 800 600 700 600 Forward Current (mA) Forward Current (mA) 500 400 300 200 500 400 300 200 100 0 100 32 33 34 35 36 37 0 38 32 33 34 Figure 3: Vero SE 10D Drive Current vs. Forward Voltage (Tj=Tc=25°C) 38 900 800 600 Forward Current (mA) Forward Current (mA) 37 1000 700 500 400 300 200 700 600 500 400 300 200 100 100 24 25 26 27 28 0 29 32 33 34 35 36 37 38 Forward Voltage (V) Forward Voltage (V) Figure 5: Vero SE 13C Drive Current vs. Forward Voltage (Tj=Tc=25°C) Figure 6: Vero SE 13D Drive Current vs. Forward Voltage (Tj=Tc=25°C) 1400 1100 1000 1200 900 1000 Forward Current (mA) Forward Current (mA) 36 Figure 4: Vero SE 13B Drive Current vs. Forward Voltage (Tj=Tc=25°C) 800 0 35 Forward Voltage (V) Forward Voltage (V) 800 600 400 800 700 600 500 400 300 200 200 100 0 32 33 34 35 Forward Voltage (V) 36 37 38 0 29 30 31 32 33 34 35 Forward Voltage (V) 13 Performance Curves Figure 8: Vero SE 18C Drive Current vs. Forward Voltage (Tj=Tc=25°C) 2000 2700 1800 2400 1600 2100 1400 Forward Current (mA) Forward Current (mA) Figure 7: Vero SE 18B Drive Current vs. Forward Voltage (Tj=Tc=25°C) 1200 1000 800 600 400 1500 1200 900 600 300 200 0 1800 32 33 34 35 36 37 38 0 39 32 33 34 Figure 9: Vero SE 18D Drive Current vs. Forward Voltage (Tj=Tc=25°C) Forward Current (mA) Forward Current (mA) 38 39 3500 1750 1500 1250 1000 750 500 3000 2500 2000 1500 1000 500 250 0 26 27 28 29 30 31 32 47 48 49 50 51 52 53 54 55 56 57 58 Forward Voltage (V) Forward Voltage (V) Figure 11: Vero SE 29C Drive Current vs. Forward Voltage (Tj=Tc=25°C) Figure 12: Vero SE 29D Drive Current vs. Forward Voltage (Tj=Tc=25°C) 4000 4500 3500 4000 3000 3500 Forward Current (mA) Forward Current (mA) 37 4000 2000 2500 2000 1500 1000 3000 2500 2000 1500 1000 500 500 0 36 Figure 10: Vero SE 29B Drive Current vs. Forward Voltage (Tj=Tc=25°C) 2250 0 35 Forward Voltage (V) Forward Voltage (V) 0 63 64 65 66 67 68 69 70 71 Forward Voltage (V) 72 73 74 75 76 33 34 35 36 37 38 39 40 41 42 Forward Voltage (V) 14 Performance Curves Figure 14: Vero SE 10C Typical Relative Luminous Flux vs. Drive Current 200% 200% 180% 180% 160% 160% 140% 140% Relative Luminous Flux Relative Luminous Flux Figure 13: Vero SE 10B Typical Relative Luminous Flux vs. Drive Current 120% 100% 80% 60% 120% 100% 80% 60% 40% 40% 20% 20% 0% 0 100 200 300 400 500 0% 600 0 100 200 300 Forward Current (mA) 600 700 800 Figure 16: Vero SE 13B Typical Relative Luminous Flux vs. Drive Current 200% 200% 180% 180% 160% 160% 140% 140% Relative Luminous Flux Relative Luminous Flux 500 Forward Current (mA) Figure 15: Vero SE 10D Typical Relative Luminous Flux vs. Drive Current 120% 100% 80% 60% 120% 100% 40% 80% 60% 40% 20% 20% 0% 0 100 200 300 400 500 600 700 0% 800 0 100 200 300 Forward Current (mA) 400 500 600 700 800 900 1000 Forward Current (mA) Figure 17: Vero SE 13C Typical Relative Luminous Flux vs. Drive Current Figure 18: Vero SE 13D Typical Relative Luminous Flux vs. Drive Current 200% 200% 180% 180% 160% 160% 140% 140% Relative Luminous Flux Relative Luminous Flux 400 120% 100% 80% 60% 120% 100% 80% 60% 40% 40% 20% 20% 0% 0% 100 250 400 550 700 850 Forward Current (mA) 1000 1150 1300 0 100 200 300 400 500 600 700 800 900 1000 1100 Forward Current (mA) 15 Performance Curves Figure 20: Vero SE 18C Typical Relative Luminous Flux vs. Drive Current 200% 200% 180% 180% 160% 160% 140% 140% Relative Luminous Flux Relative Luminous Flux Figure 19: Vero SE 18B Typical Relative Luminous Flux vs. Drive Current 120% 100% 80% 60% 120% 100% 80% 60% 40% 40% 20% 20% 0% 0 200 400 600 800 1000 1200 1400 1600 1800 0% 2000 100 400 700 Forward Current (mA) 1000 1300 1600 1900 2200 2500 Forward Current (mA) Figure 21: Vero SE 18D Typical Relative Luminous Flux vs. Drive Current Figure 22: Vero SE 29B Typical Relative Luminous Flux vs. Drive Current 200% 200% 180% 180% 160% 160% 140% 140% Relative Luminous Flux Relative Luminous Flux y = -7E-08x2 + 0.001x + 0.027 120% 100% 80% 60% 120% 100% 80% 60% 40% 40% 20% 20% 0% 0% 200 400 600 800 1000 1200 1400 1600 1800 2000 2200 0 2400 500 1000 Forward Current (mA) 200% 200% 180% 180% 160% 160% 140% 140% 120% 100% 80% 60% 2000 2400 Forward Current (mA) 4000 60% 20% 0% 1600 3500 80% 40% 1200 3000 100% 20% 800 2500 120% 40% 400 2000 Figure 24: Vero SE 29D Typical Relative Luminous Flux vs. Drive Current Relative Luminous Flux Relative Luminous Flux Figure 23: Vero SE 29C Typical Relative Luminous Flux vs. Drive Current 0 1500 Forward Current (mA) 2800 3200 3600 4000 0% 0 500 1000 1500 2000 2500 3000 3500 4000 4500 Forward Current (mA) 16 Performance Curves Figure 25: Vero SE 10 Typical DC Flux vs. Case Temperature Figure 26: Vero SE 13 Typical DC Flux vs. Case Temperature 103% Neutral White 100% Cool White 25°C Pulsed 97% 94% 91% 88% Warm White Neutral White 100% Relative Luminous Flux Relative Luminous Flux 103% Warm White 85% Cool White 25°C Pulsed 97% 94% 91% 88% 85% 82% 82% 0 25 50 75 100 125 0 25 Case Temperature (°C) Figure 27: Vero SE 18 Typical DC Flux vs. Case Temperature 75 100 125 Figure 28: Vero SE 29 Typical DC Flux vs. Case Temperature 103% 103% Warm White Neutral White 100% 25°C Pulsed 97% 94% 91% 88% 85% Warm White Neutral White 100% Cool White Relative Luminous Flux Relative Luminous Flux 50 Case Temperature (°C) Cool White 25°C Pulsed 97% 94% 91% 88% 85% 82% 0 25 50 75 100 125 Case Temperature (°C) 82% 0 25 50 75 100 125 Case Temperature (°C) Note for Figures 25-28: 1. Flux measurements taken under DC conditions. 2. Characteristics shown for warm white based on 3000K and 80 CRI. 3. Characteristics shown for neutral white based on 4000K and 80 CRI. 4. Characteristics shown for cool white based on 5000K and 70 CRI. 5. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. 17 Performance Curves Figure 29: 1750K Color Shift vs. Case Temperature1 Figure 30: 2500K Color Shift vs. Case Temperature1 0.4145 0.3705 0.37 Pulsed Center Point Color Tc = 25°C 15°C 15°C 0.414 25°C 0.4135 25°C 0.413 0.3695 0.369 ccy ccy 45°C 45°C 0.4125 70°C 0.412 70°C 85°C 85°C 0.4115 0.3685 0.368 0.5196 105°C 0.411 105°C 0.5198 0.52 0.5202 0.5204 0.4105 0.468 0.5206 0.47 0.472 0.474 0.476 0.478 ccx ccx Figure 31: 2700K Color Shift vs. Case Temperature1 0.412 Figure 32: 3000K Color Shift vs. Case Temperature1 0.405 Pulsed Center Point Color Tc = 25°C 15°C 0.411 Pulsed Center Point Color Tc = 25°C 15°C 0.410 0.403 45°C 0.401 ccy 45°C 0.408 70°C 0.407 0.406 0.399 85°C 105°C 0.4574 0.4576 0.4578 0.458 ccx 0.4582 0.4584 70°C 85°C 0.397 0.405 0.404 0.4572 25°C 25°C 0.409 ccy Pulsed Center Point Color Tc = 25°C 0.4586 105°C 0.395 0.4325 0.4329 0.4333 0.4337 0.4341 ccx 0.4345 0.4349 0.4353 Note for Figures 29-32: 1. Measurements made under DC test conditions at the nominal drive current. 2. Typical color shift is shown with a tolerance of ±0.002. 18 Performance Curves Figure 33: 5600K Color Shift vs. Case Temperature1 0.344 0.342 15°C 0.34 25°C 0.338 ccy 0.336 Pulsed Center Point Color Tc = 25°C 45°C 0.334 0.332 70°C 0.33 85°C 0.328 0.326 105°C 0.324 0.322 0.32 0.322 0.324 0.326 0.328 0.33 ccx Note for Figure 33: 1. Measurements made under DC test conditions at the nominal drive current. 2. Typical color shift is shown with a tolerance of ±0.002. 19 Typical Radiation Pattern Figure 34: Typical Spatial Radiation Pattern Notes for Figure 34: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where Iv is ½ of the peak value. Figure 35: Typical Polar Radiation Pattern 20 Typical Color Spectrum 97 CRI- Wavelength & CRI Characteristics at Drive Current, Tc=25°C The high CRI light delivered by the Bridgelux Décor products reproduces colors faithfully compared with natural light. Figure 36 displays the spectral curve of Décor. Table 6 compares CRI R values of Décor to other light sources. The typical overall CRI (Ra) of 97 results in excellent color representation - especially for colors which the human eye is particularly sensitive. Décor delivers high typical values of R9 (98) and R15 (98). These are important attributes for the perception of realistic colors. R9 enhances red colors and R15 enables realistic rendering of human skin tones. Figure 36: Typical Color Spectrum 1 17E 25E 0.9 27H 0.8 30H 56G Relative Intensity 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 400 450 500 550 600 650 700 750 800 Wavelength (nm) Table 6: CRI Spectra for Décor Ultra Products vs. Alternative Light Sources Light Source Ra R1 R2 R3 R4 R5 R6 R7 R8 R9 R10 R11 R12 R13 R14 R15 Bridgelux Décor Ultra 97 97 100 96 96 98 98 99 98 98 99 92 87 98 97 98 Typical Halogen 98 98 99 99 99 98 98 99 97 92 97 98 97 98 99 97 Typcal Metal Halide 82 90 94 69 82 81 81 87 71 27 59 62 55 93 78 88 Typical Compact Fluorescent 87 91 93 86 91 89 90 88 70 17 76 91 81 93 92 81 21 Mechanical Dimensions Figure 37: Drawing for Vero SE 10 LED Array Notes for Figure 37: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Unless otherwise specified, tolerances are ±0.10mm. 4. Mounting slots (2X) are for M2.5 screws. 5. Bridgelux recommends two tapped holes for mounting screws with 19.0 ± 0.10mm center-to-center spacing. 6. Screws with flat shoulders (pan, dome, button, round, truss, mushroom) provide optimal torque control. Do NOT use flat, countersink, or raised head screws. 7. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 8. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 22 Mechanical Dimensions Figure 38: Drawing for Vero SE 13 LED Array Notes for Figure 38: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Unless otherwise specified, tolerances are ±0.10mm. 4. Mounting holes (2X) are for M2.5 screws. 5. Bridgelux recommends two tapped holes for mounting screws with 31.4 ± 0.10mm center-to-center spacing. 6. Screws with flat shoulders (pan, dome, button, round, truss, mushroom) provide optimal torque control. Do NOT use flat, countersink, or raised head screws. 7. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 8. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 23 Mechanical Dimensions Figure 39: Drawing for Vero SE 18 LED Array Notes for Figure 39: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Unless otherwise specified, tolerances are ±0.10mm. 4. Mounting holes (2X) are for M2.5 screws. 5. Bridgelux recommends two tapped holes for mounting screws with 31.4 ± 0.10mm center-to-center spacing. 6. Screws with flat shoulders (pan, dome, button, round, truss, mushroom) provide optimal torque control. Do NOT use flat, countersink, or raised head screws. 7. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 8. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 24 Mechanical Dimensions Figure 40: Drawing for Vero SE 29 LED Array Notes for Figure 40: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Unless otherwise specified, tolerances are ±0.10mm. 4. Mounting holes (4X) are for M3 screws. 5. Bridgelux recommends two tapped holes for mounting screws with 43.0 ± 0.10mm center-to-center spacing. 6. Screws with flat shoulders (pan, dome, button, round, truss, mushroom) provide optimal torque control. Do NOT use flat, countersink, or raised head screws. 7. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 8. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 25 Color Binning Information Figure 41: Graph of Warm and Neutral White Test Bins in xy Color Space Note: Pulsed Test Conditions, Tc = 25°C Table 7: Warm White xy Bin Coordinates and Associated Typical CCT Bin Code 1750K 2500K 2700K 3000K ANSI Bin (for reference only) - - (2580K - 2870K) (2870K - 3220K) 3 (3 SDCM) - - (2651K - 2794K) (2968K - 3136K) 2 (2 SDCM) - - (2674K - 2769K) (2995K - 3107K) Center Point (x,y) (0.5167, 0.336) (0.4765, 0.4137) (0.4578, 0.4101) (0.4338, 0.403) Figure 42: Graph of Cool White Test Bins in xy Color Space Note: Pulsed Test Conditions, Tc = 25°C Table 8: Cool White xy Bin Coordinates and Associated Typical CCT (product is hot targeted to Tc = 85°C) Bin Code 5600K ANSI Bin (for reference only) (5310K - 6020K) 4 (4 SDCM) (5475K - 5830K) Center Point (x,y) (0.3293, 0.3423) 26 Packaging and Labeling Figure 16: Drawing for Vero SE 10 Packaging Tray Notes for Figure 16: 1. Dimensions are in millimeters. 2. Drawings are not to scale. Figure 17: Drawing for Vero SE 13 Packaging Tray Notes for Figure 17: 1. Dimensions are in millimeters. 2. Drawings are not to scale. 27 Packaging and Labeling Figure 18: Drawing for Vero SE 18 Packaging Tray Notes for Figure 18: 1. Dimensions are in millimeters. 2. Drawings are not to scale. Figure 19: Drawing for Vero SE 29 Packaging Tray Notes for Figure 19: 1. Dimensions are in millimeters. 2. Drawings are not to scale. 28 Packaging and Labeling Figure 20: Vero SE Packaging and Labeling Notes for Figure 17: 1. Each tray holds 100 COBs for Vero SE 10, 100 COBs for Vero SE 13, 100 COBs for Vero SE 18, and 50 COBs for Vero SE 29. 2. Each tray is vacuum sealed in ansalesfanti-static bag and placed in its own box. 3. Each tray, bag and box is to be labeled as shown above. Figure 21: Vero SE Product Labeling Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the COB array. Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number 30E1000C 73 29 Design Resources Optical Source Models LM80 Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. LM80 testing is on going. Please contact your Bridgelux sales representative for more information. 3D CAD Models Three dimensional CAD models depicting the product outline of all Bridgelux Vero LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN31 for additional information. CAUTION: RISK OF BURN Do not touch the Vero LED array during operation. Allow the array to cool for a sufficient period of time before handling. The Vero LED array may reach elevated temperatures such that could burn skin when touched. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Optical devices may be mounted on the top surface of the plastic housing of the Vero SE LED array. Use the mechanical features of the LED array housing, edges and/or mounting holes to locate and secure optical devices as needed. Disclaimers MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, array testing is performed at the nominal drive current. 30 About Bridgelux: We Build Light That Transforms At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux linkedin.com/company/Bridgelux-inc-_2 WeChat ID: BridgeluxInChina 101 Portola Avenue Livermore, CA 94551 Tel (925) 583-8400 Fax (925) 583-8401 www.bridgelux.com © 2016 Bridgelux, Inc. All rights reserved 2016. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design and Vero are registered trademarks, and Décor Series is a trademark of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux Décor Series on Vero SE Product Data Sheet DS124 Rev. A (10/2016) 31
BXRC-17E10K0-C-74-SE 价格&库存
很抱歉,暂时无法提供与“BXRC-17E10K0-C-74-SE”相匹配的价格&库存,您可以联系我们找货
