PRODUCT FAMILY DATA SHEET
XLamp® CXA1304 LED
PRODUCT DESCRIPTION
FEATURES
TABLE OF CONTENTS
The XLamp® CXA1304 LED array expands • Available in 4-step, 3‑step and 2-step
Characteristics................................................ 2
Cree LED’s family of high‑flux, multi‑die
EasyWhite bins at 2700 K, 3000 K,
Operating Limits.............................................. 3
arrays in a smaller, easy‑to‑use platform.
3500 K, 4000 K & 5000 K CCT and
Flux Characteristics, EasyWhite® Order
With XLamp LED lighting‑class reliability,
4-step EasyWhite bins at 5700 K &
Codes and Bins - 9 V....................................... 5
the CXA1304’s small, uniform emitting
6500 K CCT
Flux Characteristics, ANSI White Order
surface enables both directional and • Available in ANSI white bins at 4000 K,
Codes and Bins - 9 V....................................... 8
non‑directional
lighting
including
retrofit
lamp
applications
and
5000 K, 5700 K & 6500 K CCT
luminaire • Available in 70-, 80-, 90- and
designs. Available in 2-step, 3‑step and
93‑minimum CRI options
Codes and Bins - 18 V..................................... 9
4-step color consistency, and featuring a • Forward voltage options: 9‑V class,
Codes and Bins - 18 V................................... 12
6‑mm optical source, the CXA1304 brings
18‑V class & 36‑V class
new levels of flux and efficacy to this form
• 85 °C binning and characterization
Codes and Bins - 36 V................................... 13
factor.
• Maximum drive current: 1000 mA (9 V),
500 mA (18 V), 250 mA (36 V)
Codes and Bins - 36 V................................... 16
The CX Family LED Design Guide provides • 115° viewing angle, uniform
Relative Spectral Power Distribution........... 17
basic information on the requirements
Electrical Characteristics.............................. 17
chromaticity profile
to use the CXA1304 LED successfully in • Top-side solder connections
Relative Luminous Flux................................. 19
luminaire designs.
• Thermocouple attach point
Typical Spatial Distribution........................... 22
• NEMA SSL-3 2011 standard flux bins
Performance Groups - Brightness............... 22
• RoHS and REACh compliant
Performance Groups - Chromaticity............ 23
• UL® recognized component (E349212)
EasyWhite® Bins Plotted on the 1931 CIE
Color Space................................................... 26
ANSI White Bins Plotted on the 1931 CIE
Bin and Order Code Formats........................ 27
Mechanical Dimensions............................... 27
Thermal Design............................................. 28
Notes............................................................. 30
Packaging...................................................... 31
Cree LED / 4400 Silicon Drive / Durham, NC 27703 USA / +1.919.313.5330 / www.cree-led.com
© 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and
the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered
trademarks of UL LLC.
CLD-DS73
REV 10A
1
XLAMP ® CXA1304 LED
CHARACTERISTICS
Characteristics
Viewing angle (FWHM)
ESD withstand voltage (HBM per Mil-Std-883D)
Unit
Minimum
Typical
degrees
Maximum
115
V
8000
DC forward current (9 V)
mA
1000*
DC forward current (18 V)
mA
500*
DC forward current (36 V)
mA
250*
Reverse current (9 V, 18V, 36 V)
mA
0.1
Forward voltage (9 V, 400 mA, 85 °C)
V
Forward voltage (9 V, 400 mA, 25 °C)
V
Forward voltage (18 V, 200 mA, 85 °C)
V
Forward voltage (18 V, 200 mA, 25 °C)
V
Forward voltage (36 V, 100 mA, 85 °C)
V
Forward voltage (36 V, 100 mA, 25 °C)
V
9
10.5
18
21
36
42
Refer to the Operating Limits section.
CLD-DS73
REV 10A
2
XLAMP ® CXA1304 LED
OPERATING LIMITS
The maximum current rating of the CXA1304 depends on the case temperature (Tc) when the LED has reached thermal equilibrium under
steady-state operation. The graphs shown below assume that the system design employs good thermal management (thermal interface
material and heat sink) and may vary when poor thermal management is employed. Please refer to the Mechanical Dimensions section
on page 27 for the location of the Tc measurement point.
Another important factor in good thermal management is the temperature of the Light Emitting Surface (LES). Cree LED recommends a
maximum LES temperature of 135 °C to ensure optimal LED lifetime. Please refer to the Thermal Design section on page 28 for more
information on LES temperature measurement.
CXA1304-9V
1200
1000
If (mA)
800
9V
600
400
200
50
75
100
125
150
Case Temperature (°C)
CXA1304-18V
600
500
If (mA)
400
18 V
300
200
100
50
75
100
125
150
CLD-DS73
REV 10A
3
XLAMP ® CXA1304 LED
OPERATING LIMITS - CONTINUED
CXA1304-36V
300
250
If (mA)
200
36 V
150
100
50
50
75
100
125
150
CLD-DS73
REV 10A
4
XLAMP ® CXA1304 LED
FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 9 V (IF = 400 mA, TJ = 85 °C)
The following table provides order codes for XLamp CXA1304 LEDs. For a complete description of the order code nomenclature, please
see the Bin and Order Code Formats section (page 27).
Nominal
CCT
CRI
Min
70
Minimum Luminous Flux
Typ
75
2-Step
3-Step
4-Step
Group
Flux (lm)
@ 85 °C
Flux (lm)
@ 25 °C*
B4
410
457
C2
440
490
C4
475
527
CXA1304-0000000C00C465F
B4
410
457
CXA1304-0000000C0HB465F
C2
440
490
C4
475
527
C2
440
490
Group
Order Code
Group
Order Code
Group
CXA1304-0000000C00B465F
65F
6500 K
80
70
80
70
80
65F
57F
95
CXA1304-0000000C00C257F
475
527
CXA1304-0000000C00C457F
B4
410
457
CXA1304-0000000C0HB457F
C2
440
490
C4
475
527
C2
440
490
C4
475
527
CXA1304-0000000C00C450H
B4
410
457
CXA1304-0000000C0HB450H
C2
440
490
C4
475
527
CXA1304-0000000C0HC450H
CXA1304-0000000C0HC450G
CXA1304-0000000C0HC450F
A2
330
366
CXA1304-0000000C0UA250H
CXA1304-0000000C0UA250G
CXA1304-0000000C0UA250F
A4
355
396
B2
380
423
57F
CXA1304-0000000C0HC257F
CXA1304-0000000C0HC457F
50H
50H
5000 K
90
CXA1304-0000000C0HC265F
C4
75
CXA1304-0000000C00C265F
CXA1304-0000000C0HC465F
75
5700 K
Order Code
50H
CXA1304-0000000C00C250H
CXA1304-0000000C0HC250H
CXA1304-0000000C0UA450H
CXA1304-0000000C0UB250H
50F
CXA1304-0000000C00C250F
CXA1304-0000000C00C450F
CXA1304-0000000C0HB450F
50G
50G
CXA1304-0000000C0HC250G
CXA1304-0000000C0UA450G
CXA1304-0000000C0UB250G
50F
50F
CXA1304-0000000C0HC250F
CXA1304-0000000C0UA450F
CXA1304-0000000C0UB250F
Notes
Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on
CRI measurements. See the Measurements section (page 30).
CXA1304 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum
specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code.
Flux values @ 25 °C are calculated and for reference only.
CLD-DS73
REV 10A
5
XLAMP ® CXA1304 LED
FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 9 V (IF = 400 mA, TJ = 85 °C) - CONTINUED
Nominal
CCT
CRI
Min
70
4000 K
80
90
80
Typ
75
95
3500 K
93
80
95
4-Step
Flux (lm)
@ 85 °C
Flux (lm)
@ 25 °C*
B4
410
457
C2
440
490
C4
475
527
CXA1304-0000000C00C440H
CXA1304-0000000C00C440F
B4
410
457
CXA1304-0000000C0HB440H
CXA1304-0000000C0HB440F
C2
440
490
C4
475
527
CXA1304-0000000C0HC440H
CXA1304-0000000C0HC440G
CXA1304-0000000C0HC440F
94
290
327
CXA1304-0000000C0U9440H
CXA1304-0000000C0U9440G
CXA1304-0000000C0U9440F
A2
330
366
A4
355
396
CXA1304-0000000C0UA440H
B2
380
423
CXA1304-0000000C00B235H
B4
410
457
C2
440
490
CXA1304-0000000C00C235H
94
290
327
CXA1304-0000000C0Y9435H
A2
330
366
CXA1304-0000000C0YA235H
B2
380
423
CXA1304-0000000C00B230H
B4
410
457
C2
440
490
CXA1304-0000000C00C230H
92
250
281
CXA1304-0000000C0Y9230H
94
290
327
A2
330
366
Group
Order Code
Group
Order Code
Group
CXA1304-0000000C00B440H
40H
40H
40H
35H
35H
30H
3000 K
93
3-Step
Group
95
2-Step
30H
CXA1304-0000000C00B440F
CXA1304-0000000C00C240H
CXA1304-0000000C0HC240H
CXA1304-0000000C0UA240H
CXA1304-0000000C00B435H
CXA1304-0000000C00B430H
CXA1304-0000000C0Y9430H
CXA1304-0000000C0YA230H
Order Code
40F
40G
40G
CXA1304-0000000C0HC240G
CXA1304-0000000C0UA240G
40F
40F
CXA1304-0000000C0UA440G
CXA1304-0000000C00C240F
CXA1304-0000000C0HC240F
CXA1304-0000000C0UA240F
CXA1304-0000000C0UA440F
CXA1304-0000000C00B235F
35G
CXA1304-0000000C00B435G
35F
CXA1304-0000000C00C235G
35G
CXA1304-0000000C0YA235G
CXA1304-0000000C00B435F
CXA1304-0000000C00C235F
35F
CXA1304-0000000C0Y9435F
CXA1304-0000000C0YA235F
CXA1304-0000000C00B230F
30G
CXA1304-0000000C00B430G
30F
CXA1304-0000000C00C230G
CXA1304-0000000C00B430F
CXA1304-0000000C00C230F
CXA1304-0000000C0Y9230F
30G
CXA1304-0000000C0Y9430G
CXA1304-0000000C0YA230G
30F
CXA1304-0000000C0Y9430F
CXA1304-0000000C0YA230F
Notes
CLD-DS73
REV 10A
6
XLAMP ® CXA1304 LED
Nominal
CCT
CRI
Min
80
Typ
2-Step
Group
Flux (lm)
@ 85 °C
Flux (lm)
@ 25 °C*
A4
355
396
B2
380
423
B4
410
457
CXA1304-0000000C00B427H
84
220
248
CXA1304-0000000C0Y8427H
92
250
281
94
290
327
Group
95
Group
Order Code
4-Step
Group
CXA1304-0000000C00A427H
27H
2700 K
93
Order Code
3-Step
27H
CXA1304-0000000C00B227H
CXA1304-0000000C0Y9227H
CXA1304-0000000C0Y9427H
Order Code
CXA1304-0000000C00A427F
27G
CXA1304-0000000C00B227G
27F
CXA1304-0000000C00B427G
CXA1304-0000000C00B227F
CXA1304-0000000C00B427F
CXA1304-0000000C0Y8427F
27G
CXA1304-0000000C0Y9227G
CXA1304-0000000C0Y9427G
27F
CXA1304-0000000C0Y9227F
CXA1304-0000000C0Y9427F
Notes
CLD-DS73
REV 10A
7
XLAMP ® CXA1304 LED
FLUX CHARACTERISTICS, ANSI WHITE ORDER CODES AND BINS - 9 V (IF = 400 mA, TJ = 85 °C)
Nominal
CCT
CRI
Min
70
Typ
75
6500 K
80
70
75
5700 K
80
70
75
5000 K
80
4000 K
70
75
Chromaticity Regions
Order Code
Group
Flux (lm)
@ 85 °C
Flux (lm)
@ 25 °C*
B4
410
457
C2
440
490
C4
475
527
CXA1304-0000-000C00C40E1
B4
410
457
CXA1304-0000-000C0HB40E1
C2
440
490
C4
475
527
C2
440
490
C4
475
527
B4
410
457
C2
440
490
C4
475
527
C2
440
490
C4
475
527
B4
410
457
C2
440
490
C4
475
527
CXA1304-0000-000C0HC40E3
B4
410
457
CXA1304-0000-000C00B40E5
C2
440
490
C4
475
527
CXA1304-0000-000C00B40E1
1A0, 1B0, 1C0, 1D0, 65F
CXA1304-0000-000C00C20E1
CXA1304-0000-000C0HC20E1
CXA1304-0000-000C0HC40E1
2A0, 2B0, 2C0, 2D0, 57F
CXA1304-0000-000C00C20E2
CXA1304-0000-000C00C40E2
CXA1304-0000-000C0HB40E2
CXA1304-0000-000C0HC20E2
CXA1304-0000-000C0HC40E2
3A0, 3B0, 3C0, 3D0, 50F
CXA1304-0000-000C00C20E3
CXA1304-0000-000C00C40E3
CXA1304-0000-000C0HB40E3
5A0, 5B0, 5C.0, 5D0, 40F
CXA1304-0000-000C0HC20E3
CXA1304-0000-000C00C20E5
CXA1304-0000-000C00C40E5
Notes
CLD-DS73
REV 10A
8
XLAMP ® CXA1304 LED
FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 18 V (IF = 200 mA, TJ = 85 °C)
Nominal
CCT
CRI
Min
70
Typ
75
2-Step
3-Step
4-Step
Group
Flux (lm)
@ 85 °C
Flux (lm)
@ 25 °C*
B4
410
457
C2
440
490
C4
475
527
CXA1304-0000000F00C465F
B4
410
457
CXA1304-0000000F0HB465F
C2
440
490
C4
475
527
C2
440
490
Group
Order Code
Group
Order Code
Group
CXA1304-0000000F00B465F
65F
6500 K
80
70
80
70
80
65F
57F
95
CXA1304-0000000F00C257F
475
527
CXA1304-0000000F00C457F
B4
410
457
CXA1304-0000000F0HB457F
C2
440
490
C4
475
527
C2
440
490
C4
475
527
CXA1304-0000000F00C450H
B4
410
457
CXA1304-0000000F0HB450H
C2
440
490
C4
475
527
CXA1304-0000000F0HC450H
CXA1304-0000000F0HC450G
CXA1304-0000000F0HC450F
A2
330
366
CXA1304-0000000F0UA250H
CXA1304-0000000F0UA250G
CXA1304-0000000F0UA250F
A4
355
396
B2
380
423
57F
CXA1304-0000000F0HC257F
CXA1304-0000000F0HC457F
50H
50H
5000 K
90
CXA1304-0000000F0HC265F
C4
75
CXA1304-0000000F00C265F
CXA1304-0000000F0HC465F
75
5700 K
Order Code
50H
CXA1304-0000000F00C250H
CXA1304-0000000F0HC250H
CXA1304-0000000F0UA450H
CXA1304-0000000F0UB250H
50F
CXA1304-0000000F00C250F
CXA1304-0000000F00C450F
CXA1304-0000000F0HB450F
50G
50G
CXA1304-0000000F0HC250G
CXA1304-0000000F0UA450G
CXA1304-0000000F0UB250G
50F
50F
CXA1304-0000000F0HC250F
CXA1304-0000000F0UA450F
CXA1304-0000000F0UB250F
Notes
CLD-DS73
REV 10A
9
XLAMP ® CXA1304 LED
FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 18 V (IF = 200 mA, TJ = 85 °C) - CONTINUED
Nominal
CCT
CRI
Min
70
4000 K
80
90
80
Typ
75
95
3500 K
93
80
95
4-Step
Flux (lm)
@ 85 °C
Flux (lm)
@ 25 °C*
B4
410
457
C2
440
490
C4
475
527
CXA1304-0000000F00C440H
CXA1304-0000000F00C440F
B4
410
457
CXA1304-0000000F0HB440H
CXA1304-0000000F0HB440F
C2
440
490
C4
475
527
CXA1304-0000000F0HC440H
CXA1304-0000000F0HC440G
CXA1304-0000000F0HC440F
94
290
327
CXA1304-0000000F0U9440H
CXA1304-0000000F0U9440G
CXA1304-0000000F0U9440F
A2
330
366
A4
355
396
CXA1304-0000000F0UA440H
B2
380
423
CXA1304-0000000F00B235H
B4
410
457
C2
440
490
CXA1304-0000000F00C235H
94
290
327
CXA1304-0000000F0Y9435H
A2
330
366
CXA1304-0000000F0YA235H
B2
380
423
CXA1304-0000000F00B230H
B4
410
457
C2
440
490
CXA1304-0000000F00C230H
92
250
281
CXA1304-0000000F0Y9230H
94
290
327
A2
330
366
Group
Order Code
Group
Order Code
Group
CXA1304-0000000F00B440H
40H
40H
40H
35H
35H
30H
3000 K
93
3-Step
Group
95
2-Step
30H
CXA1304-0000000F00B440F
CXA1304-0000000F00C240H
CXA1304-0000000F0HC240H
CXA1304-0000000F0UA240H
CXA1304-0000000F00B435H
CXA1304-0000000F00B430H
CXA1304-0000000F0Y9430H
CXA1304-0000000F0YA230H
Order Code
40F
40G
40G
CXA1304-0000000F0HC240G
CXA1304-0000000F0UA240G
40F
40F
CXA1304-0000000F0UA440G
CXA1304-0000000F00C240F
CXA1304-0000000F0HC240F
CXA1304-0000000F0UA240F
CXA1304-0000000F0UA440F
CXA1304-0000000F00B235F
35G
CXA1304-0000000F00B435G
35F
CXA1304-0000000F00C235G
35G
CXA1304-0000000F0YA235G
CXA1304-0000000F00B435F
CXA1304-0000000F00C235F
35F
CXA1304-0000000F0Y9435F
CXA1304-0000000F0YA235F
CXA1304-0000000F00B230F
30G
CXA1304-0000000F00B430G
30F
CXA1304-0000000F00C230G
CXA1304-0000000F00B430F
CXA1304-0000000F00C230F
CXA1304-0000000F0Y9230F
30G
CXA1304-0000000F0Y9430G
CXA1304-0000000F0YA230G
30F
CXA1304-0000000F0Y9430F
CXA1304-0000000F0YA230F
Notes
CLD-DS73
REV 10A
10
XLAMP ® CXA1304 LED
Nominal
CCT
CRI
Min
80
Typ
2-Step
Group
Flux (lm)
@ 85 °C
Flux (lm)
@ 25 °C*
A4
355
396
B2
380
423
B4
410
457
CXA1304-0000000F00B427H
84
220
248
CXA1304-0000000F0Y8427H
92
250
281
94
290
327
Group
95
Group
Order Code
4-Step
Group
CXA1304-0000000F00A427H
27H
2700 K
93
Order Code
3-Step
27H
CXA1304-0000000F00B227H
CXA1304-0000000F0Y9227H
CXA1304-0000000F0Y9427H
Order Code
CXA1304-0000000F00A427F
27G
CXA1304-0000000F00B227G
27F
CXA1304-0000000F00B427G
CXA1304-0000000F00B227F
CXA1304-0000000F00B427F
CXA1304-0000000F0Y8427F
27G
CXA1304-0000000F0Y9227G
CXA1304-0000000F0Y9427G
27F
CXA1304-0000000F0Y9227F
CXA1304-0000000F0Y9427F
Notes
CLD-DS73
REV 10A
11
XLAMP ® CXA1304 LED
FLUX CHARACTERISTICS, ANSI WHITE ORDER CODES AND BINS - 18 V (IF = 200 mA, TJ = 85 °C)
Nominal
CCT
CRI
Min
70
Typ
75
6500 K
80
70
75
5700 K
80
70
75
5000 K
80
4000 K
70
75
Order Code
Group
Flux (lm)
@ 85 °C
Flux (lm)
@ 25 °C*
B4
410
457
C2
440
490
C4
475
527
CXA1304-0000-000F00C40E1
B4
410
457
CXA1304-0000-000F0HB40E1
C2
440
490
C4
475
527
C2
440
490
C4
475
527
B4
410
457
C2
440
490
C4
475
527
C2
440
490
C4
475
527
B4
410
457
C2
440
490
C4
475
527
CXA1304-0000-000F0HC40E3
B4
410
457
CXA1304-0000-000F00B40E5
C2
440
490
C4
475
527
CXA1304-0000-000F00B40E1
CXA1304-0000-000F00C20E1
CXA1304-0000-000F0HC20E1
CXA1304-0000-000F0HC40E1
CXA1304-0000-000F00C20E2
CXA1304-0000-000F00C40E2
CXA1304-0000-000F0HB40E2
CXA1304-0000-000F0HC20E2
CXA1304-0000-000F0HC40E2
CXA1304-0000-000F00C20E3
CXA1304-0000-000F00C40E3
CXA1304-0000-000F0HB40E3
CXA1304-0000-000F0HC20E3
CXA1304-0000-000F00C20E5
CXA1304-0000-000F00C40E5
Notes
CLD-DS73
REV 10A
12
XLAMP ® CXA1304 LED
FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 36 V (IF = 100 mA, TJ = 85 °C)
Nominal
CCT
CRI
Min
70
Typ
75
2-Step
3-Step
4-Step
Group
Flux (lm)
@ 85 °C
Flux (lm)
@ 25 °C*
B4
410
457
C2
440
490
C4
475
527
CXA1304-0000000N00C465F
B4
410
457
CXA1304-0000000N0HB465F
C2
440
490
C4
475
527
C2
440
490
Group
Order Code
Group
Order Code
Group
CXA1304-0000000N00B465F
65F
6500 K
80
70
80
70
80
65F
57F
95
CXA1304-0000000N00C257F
475
527
CXA1304-0000000N00C457F
B4
410
457
CXA1304-0000000N0HB457F
C2
440
490
C4
475
527
C2
440
490
C4
475
527
CXA1304-0000000N00C450H
B4
410
457
CXA1304-0000000N0HB450H
C2
440
490
C4
475
527
CXA1304-0000000N0HC450H
CXA1304-0000000N0HC450G
CXA1304-0000000N0HC450F
A2
330
366
CXA1304-0000000N0UA250H
CXA1304-0000000N0UA250G
CXA1304-0000000N0UA250F
A4
355
396
B2
380
423
57F
CXA1304-0000000N0HC257F
CXA1304-0000000N0HC457F
50H
50H
5000 K
90
CXA1304-0000000N0HC265F
C4
75
CXA1304-0000000N00C265F
CXA1304-0000000N0HC465F
75
5700 K
Order Code
50H
CXA1304-0000000N00C250H
CXA1304-0000000N0HC250H
CXA1304-0000000N0UA450H
CXA1304-0000000N0UB250H
50F
CXA1304-0000000N00C250F
CXA1304-0000000N00C450F
CXA1304-0000000N0HB450F
50G
50G
CXA1304-0000000N0HC250G
CXA1304-0000000N0UA450G
CXA1304-0000000N0UB250G
50F
50F
CXA1304-0000000N0HC250F
CXA1304-0000000N0UA450F
CXA1304-0000000N0UB250F
Notes
CLD-DS73
REV 10A
13
XLAMP ® CXA1304 LED
FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 36 V (IF = 100 mA, TJ = 85 °C) - CONTINUED
Nominal
CCT
CRI
Min
70
4000 K
80
90
80
Typ
75
95
3500 K
93
80
95
4-Step
Flux (lm)
@ 85 °C
Flux (lm)
@ 25 °C*
B4
410
457
C2
440
490
C4
475
527
CXA1304-0000000N00C440H
CXA1304-0000000N00C440F
B4
410
457
CXA1304-0000000N0HB440H
CXA1304-0000000N0HB440F
C2
440
490
C4
475
527
CXA1304-0000000N0HC440H
CXA1304-0000000N0HC440G
CXA1304-0000000N0HC440F
94
290
327
CXA1304-0000000N0U9440H
CXA1304-0000000N0U9440G
CXA1304-0000000N0U9440F
A2
330
366
A4
355
396
CXA1304-0000000N0UA440H
B2
380
423
CXA1304-0000000N00B235H
B4
410
457
C2
440
490
CXA1304-0000000N00C235H
94
290
327
CXA1304-0000000N0Y9435H
A2
330
366
CXA1304-0000000N0YA235H
B2
380
423
CXA1304-0000000N00B230H
B4
410
457
C2
440
490
CXA1304-0000000N00C230H
92
250
281
CXA1304-0000000N0Y9230H
94
290
327
A2
330
366
Group
Order Code
Group
Order Code
Group
CXA1304-0000000N00B440H
40H
40H
40H
35H
35H
30H
3000 K
93
3-Step
Group
95
2-Step
30H
CXA1304-0000000N00B440F
CXA1304-0000000N00C240H
CXA1304-0000000N0HC240H
CXA1304-0000000N0UA240H
CXA1304-0000000N00B435H
CXA1304-0000000N00B430H
CXA1304-0000000N0Y9430H
CXA1304-0000000N0YA230H
Order Code
40F
40G
40G
CXA1304-0000000N0HC240G
CXA1304-0000000N0UA240G
40F
40F
CXA1304-0000000N0UA440G
CXA1304-0000000N00C240F
CXA1304-0000000N0HC240F
CXA1304-0000000N0UA240F
CXA1304-0000000N0UA440F
CXA1304-0000000N00B235F
35G
CXA1304-0000000N00B435G
35F
CXA1304-0000000N00C235G
35G
CXA1304-0000000N0YA235G
CXA1304-0000000N00B435F
CXA1304-0000000N00C235F
35F
CXA1304-0000000N0Y9435F
CXA1304-0000000N0YA235F
CXA1304-0000000N00B230F
30G
CXA1304-0000000N00B430G
30F
CXA1304-0000000N00C230G
CXA1304-0000000N00B430F
CXA1304-0000000N00C230F
CXA1304-0000000N0Y9230F
30G
CXA1304-0000000N0Y9430G
CXA1304-0000000N0YA230G
30F
CXA1304-0000000N0Y9430F
CXA1304-0000000N0YA230F
Notes
CLD-DS73
REV 10A
14
XLAMP ® CXA1304 LED
Nominal
CCT
CRI
Min
80
Typ
2-Step
Group
Flux (lm)
@ 85 °C
Flux (lm)
@ 25 °C*
A4
355
396
B2
380
423
B4
410
457
CXA1304-0000000N00B427H
84
220
248
CXA1304-0000000N0Y8427H
92
250
281
94
290
327
Group
95
Group
Order Code
4-Step
Group
CXA1304-0000000N00A427H
27H
2700 K
93
Order Code
3-Step
27H
CXA1304-0000000N00B227H
CXA1304-0000000N0Y9227H
CXA1304-0000000N0Y9427H
Order Code
CXA1304-0000000N00A427F
27G
CXA1304-0000000N00B227G
27F
CXA1304-0000000N00B427G
CXA1304-0000000N00B227F
CXA1304-0000000N00B427F
CXA1304-0000000N0Y8427F
27G
CXA1304-0000000N0Y9227G
CXA1304-0000000N0Y9427G
27F
CXA1304-0000000N0Y9227F
CXA1304-0000000N0Y9427F
Notes
CLD-DS73
REV 10A
15
XLAMP ® CXA1304 LED
FLUX CHARACTERISTICS, ANSI WHITE ORDER CODES AND BINS - 36 V (IF = 100 mA, TJ = 85 °C)
Nominal
CCT
CRI
Min
70
Typ
75
6500 K
80
70
75
5700 K
80
70
75
5000 K
80
4000 K
70
75
Order Code
Group
Flux (lm)
@ 85 °C
Flux (lm)
@ 25 °C*
B4
410
457
C2
440
490
C4
475
527
CXA1304-0000-000N00C40E1
B4
410
457
CXA1304-0000-000N0HB40E1
C2
440
490
C4
475
527
C2
440
490
C4
475
527
B4
410
457
C2
440
490
C4
475
527
C2
440
490
C4
475
527
B4
410
457
C2
440
490
C4
475
527
CXA1304-0000-000N0HC40E3
B4
410
457
CXA1304-0000-000N00B40E5
C2
440
490
C4
475
527
CXA1304-0000-000N00B40E1
CXA1304-0000-000N00C20E1
CXA1304-0000-000N0HC20E1
CXA1304-0000-000N0HC40E1
CXA1304-0000-000N00C20E2
CXA1304-0000-000N00C40E2
CXA1304-0000-000N0HB40E2
CXA1304-0000-000N0HC20E2
CXA1304-0000-000N0HC40E2
CXA1304-0000-000N00C20E3
CXA1304-0000-000N00C40E3
CXA1304-0000-000N0HB40E3
CXA1304-0000-000N0HC20E3
CXA1304-0000-000N00C20E5
CXA1304-0000-000N00C40E5
Notes
CLD-DS73
REV 10A
16
XLAMP ® CXA1304 LED
RELATIVE SPECTRAL POWER DISTRIBUTION
The following graph is the result of a series of pulsed measurements at 400 mA for the 9-V CXA1304 LED, 200 mA for the 18-V CXA1304
LED and 100 mA for the 36-V CXA1304 LED and TJ = 85 °C.
100%
90%
80%
70%
60%
5000 K, 70 CRI
50%
4000 K, 70 CRI
40%
3000 K, 80 CRI
30%
3000 K, 93 CRI
20%
10%
0%
380
430
480
530
580
630
680
730
780
Wavelength (nm)
ELECTRICAL CHARACTERISTICS
The following graphs are the result of a series of steady-state measurements.
10.75
9V
Voltage (V)
10.25
Tc = 25 °C
9.75
Tc = 55 °C
Tc = 85 °C
9.25
Tc = 105 °C
8.75
8.25
200
300
400
500
600
700
800
900
1000
Current (mA)
CLD-DS73
REV 10A
17
XLAMP ® CXA1304 LED
ELECTRICAL CHARACTERISTICS - CONTINUED
21.5
18 V
Voltage (V)
20.5
Tc = 25 °C
19.5
Tc = 55 °C
Tc = 85 °C
18.5
Tc = 105 °C
17.5
16.5
100
150
200
250
300
350
400
450
500
Current (mA)
43
36 V
Voltage (V)
41
Tc = 25 °C
39
Tc = 55 °C
Tc = 85 °C
37
Tc = 105 °C
35
33
50
75
100
125
150
175
200
225
250
Current (mA)
CLD-DS73
REV 10A
18
XLAMP ® CXA1304 LED
RELATIVE LUMINOUS FLUX
The relative luminous flux values provided below are the ratio of:
• Measurements of CXA1304 at steady-state operation at the given conditions, divided by
• Flux measured during binning, which is a pulsed measurement at 400 mA at TJ = 85 °C for the 9-V CXA1304 LED.
Using the 9-V CXA1304 LED as an example, at steady-state operation of Tc = 55 °C, IF = 700 mA, the relative luminous flux ratio is 160%
in the chart below. A 9-V CXA1304 LED that measures 380 lm during binning will deliver 608 lm (380 * 1.6) at steady-state operation of
Tc = 55 °C, IF = 700 mA.
240%
200%
9V
160%
Tc = 25 °C
Tc = 55 °C
120%
Tc = 85 °C
Tc = 105 °C
80%
40%
0%
200
300
400
500
600
700
800
900
1000
Current (mA)
CLD-DS73
REV 10A
19
XLAMP ® CXA1304 LED
RELATIVE LUMINOUS FLUX - CONTINUED
• Flux measured during binning, which is a pulsed measurement at 200 mA at TJ = 85 °C for the 18-V CXA1304 LED.
Using the 18-V CXA1304 LED as an example, at steady-state operation of Tc = 55 °C, IF = 350 mA, the relative luminous flux ratio is 160%
in the chart below. An 18-V CXA1304 LED that measures 380 lm during binning will deliver 608 lm (380 * 1.6) at steady-state operation
of Tc = 55 °C, IF = 350 mA.
240%
200%
18 V
160%
Tc = 25 °C
Tc = 55 °C
120%
Tc = 85 °C
Tc = 105 °C
80%
40%
0%
100
150
200
250
300
350
400
450
500
Current (mA)
CLD-DS73
REV 10A
XLAMP ® CXA1304 LED
• Flux measured during binning, which is a pulsed measurement at 100 mA at TJ = 85 °C for the 36-V CXA1304 LED.
Using the 36-V CXA1304 LED as an example, at steady-state operation of Tc = 55 °C, IF = 175 mA, the relative luminous flux ratio is 160%
in the chart below. A 36-V CXA1304 LED that measures 380 lm during binning will deliver 608 lm (380 * 1.6) at steady-state operation of
Tc = 55 °C, IF = 175 mA.
240%
200%
36 V
160%
Tc = 25 °C
Tc = 55 °C
120%
Tc = 85 °C
Tc = 105 °C
80%
40%
0%
50
75
100
125
150
175
200
225
250
Current (mA)
CLD-DS73
REV 10A
21
XLAMP ® CXA1304 LED
TYPICAL SPATIAL DISTRIBUTION
100%
Relative Luminous Intensity
80%
60%
40%
20%
-90
-70
-50
-30
-10
0%
10
30
50
70
90
Angle (º)
PERFORMANCE GROUPS - BRIGHTNESS (9 V, IF = 400 mA; 18 V, IF = 200 mA; 36 V, IF = 100 mA, TJ = 85 °C)
XLamp CXA1304 LEDs are tested for luminous flux and placed into one of the following bins.
Group Code
Maximum Luminous Flux
84
220
250
92
250
290
94
290
330
A2
330
355
A4
355
380
B2
380
410
B4
410
440
C2
440
475
C4
475
510
D2
510
550
D4
550
590
CLD-DS73
REV 10A
22
XLAMP ® CXA1304 LED
PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C)
XLamp CXA1304 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates.
EasyWhite Color Temperatures – 2-Step
Code
50H
40H
35H
30H
27H
CCT
5000 K
4000 K
3500 K
3000 K
2700 K
x
y
0.3429
0.3507
0.3434
0.3571
0.3475
0.3604
0.3469
0.3539
0.3784
0.3741
0.3804
0.3818
0.3867
0.3857
0.3844
0.3778
0.4030
0.3857
0.4061
0.3941
0.4132
0.3976
0.4099
0.3890
0.4291
0.3973
0.4333
0.4062
0.4395
0.4084
0.4351
0.3994
0.4528
0.4046
0.4578
0.4138
0.4638
0.4152
0.4586
0.4060
EasyWhite Color Temperatures – 3-Step Ellipse
Bin Code
CCT
50G
40G
Center Point
Major Axis
Minor Axis
Rotation Angle
x
y
a
b
5000 K
0.3447
0.3553
0.00840
0.00312
65.0
4000 K
0.3818
0.3797
0.00939
0.00402
53.7
35G
3500 K
0.4073
0.3917
0.00927
0.00414
54.0
30G
3000 K
0.4338
0.4030
0.00834
0.00408
53.2
27G
2700 K
0.4577
0.4099
0.00834
0.00420
48.5
CLD-DS73
REV 10A
23
XLAMP ® CXA1304 LED
PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) - CONTINUED
EasyWhite Color Temperatures – 4-Step
Code
65F
57F
50F
40F
35F
30F
27F
CCT
6500 K
5700 K
5000 K
4000 K
3500 K
3000 K
2700 K
x
y
0.3097
0.3196
0.3079
0.3297
0.3164
0.3382
0.3176
0.3275
0.3253
0.3325
0.3249
0.3439
0.3331
0.3514
0.3330
0.3393
0.3407
0.3459
0.3415
0.3586
0.3499
0.3654
0.3484
0.3521
0.3744
0.3685
0.3782
0.3837
0.3912
0.3917
0.3863
0.3758
0.3981
0.3800
0.4040
0.3966
0.4186
0.4037
0.4116
0.3865
0.4242
0.3919
0.4322
0.4096
0.4449
0.4141
0.4359
0.3960
0.4475
0.3994
0.4573
0.4178
0.4695
0.4207
0.4589
0.4021
CLD-DS73
REV 10A
24
XLAMP ® CXA1304 LED
ANSI White Bins
Code
Bin
Code
CCT
1A0
1B0
0E1
6500 K
1C0
1D0
ANSI White Bins
x
y
0.3048
0.3207
0.3130
0.3290
0.3144
0.3186
0.3068
Code
x
y
0.3215
0.3350
0.3290
0.3417
0.3290
0.3300
0.3113
0.3222
0.3243
0.3028
0.3304
0.3207
0.3462
0.3115
0.3391
0.3290
0.3538
0.3130
0.3290
0.3290
0.3417
0.3048
0.3207
0.3215
0.3350
0.3115
0.3391
0.3290
0.3538
0.3205
0.3481
0.3376
0.3616
0.3213
0.3373
0.3371
0.3490
0.3130
0.3290
0.3290
0.3417
0.3130
0.3290
0.3290
0.3417
0.3213
0.3373
0.3371
0.3490
0.3221
0.3261
0.3366
0.3369
0.3144
0.3186
0.3290
0.3300
2A0
2B0
0E2
5700 K
2C0
2D0
ANSI White Bins
Code
CCT
Bin
Code
3A0
3B0
0E3
5000 K
3C0
3D0
Bin
Code
CCT
ANSI White Bins
x
y
Code
CCT
Bin
Code
x
y
.3371
.3490
.3670
.3578
.3451
.3554
.3702
.3722
.3440
.3427
.3825
.3798
.3366
.3369
.3783
.3646
.3376
.3616
.3702
.3722
.3463
.3687
.3736
.3874
.3451
.3554
.3869
.3958
.3371
.3490
.3825
.3798
.3825
.3798
.3869
.3958
.4006
.4044
5A0
5B0
0E5
4000 K
.3463
.3687
.3551
.3760
.3533
.3620
.3451
.3554
.3950
.3875
.3451
.3554
.3783
.3646
.3533
.3620
.3825
.3798
.3515
.3487
.3950
.3875
.3440
.3427
.3898
.3716
5C0
5D0
CLD-DS73
REV 10A
25
XLAMP ® CXA1304 LED
EASYWHITE® BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C)
0.44
2700 K
ANSI C78.377 Quadrangle
0.43
3000 K
EasyWhite 4-Step
EasyWhite 3-Step
0.42
EasyWhite 2-Step
3500 K
0.41
4000 K
0.40
4500 K
CCy
0.39
5000 K
0.38
0.37
5700 K
0.36
6500 K
0.35
0.34
0.33
0.32
0.49
0.48
0.47
0.45
0.41
0.46
0.44
0.40
0.43
0.42
0.41
0.40
0.39
0.38
0.37
0.36
0.35
0.34
0.33
0.32
0.31
0.30
0.31
CCx
ANSI WHITE BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C)
0.41
4000 K
0.40
4500 K
5C
0.39
5D
0.37
CCy
5B
5000 K
0.38
5700 K
0.36
5A
3C
3B
6500 K
0.35
2B
0.34
1C
1B
0.33
3D
2C
1D
3A
2D
2A
1A
0.32
0.39
0.38
0.37
0.36
0.35
0.34
0.33
0.32
0.31
0.30
0.31
CCx
CLD-DS73
REV 10A
26
XLAMP ® CXA1304 LED
BIN AND ORDER CODE FORMATS
Bin codes and order codes are configured as follows:
Order Code
Bin Code
Series = CXA13
Series = CXA13
Internal code
Chromaticity bin
CRI Specification
0 = Standard CRI
H = 80 CRI minimum
U = 90 CRI minimum
Y = 93 CRI minimum
Vf class
C0 = 9-V class
F0 = 18-V class
N0 = 36-V class
SSSSSCC-HHHH-HHHGGRNNNNN
Internal code
SSSSSCC-WWW-FF-GGR-AAAAA
Kit code
CRI Specification
B = 70 CRI minimum
H = 80 CRI minimum
U = 90 CRI minimum
Y = 93 CRI minimum
Vf class
C0 = 9-V class
F0 = 18-V class
N0 = 36-V class
Flux bin
Performance class
Performance class
MECHANICAL DIMENSIONS
Dimensions are in mm.
Tolerances unless otherwise
specified: ±.13
x° ± 1°
Meaning of 1304X
1304F = 18‑V CXA1304
1304N = 36‑V CXA1304
1304X
1304C = 9‑V CXA1304
CLD-DS73
REV 10A
27
XLAMP ® CXA1304 LED
THERMAL DESIGN
The CXA family of LED arrays can include over a hundred different LED die inside one package, and thus over a hundred different junction
temperatures (TJ). Cree LED has intentionally removed junction-temperature-based operating limits and replaced the commonplace
maximum TJ calculations with maximum ratings based on forward current (IF) and case temperature (Tc). No additional calculations
are required to ensure that the CXA LED is being operated within its designed limits. LES temperature measurement provides additional
verification of good thermal design. Please refer to page 3 for the Operating Limit specifications.
There is no need to calculate for TJ inside the package, as the thermal management design process, specifically from TSP to ambient (Ta),
remains identical to any other LED component. For more information on thermal management of XLamp LEDs, please refer to the Thermal
Management application note. For CXA soldering recommendations and more information on thermal interface materials (TIM), LES
temperature measurement, and connection methods, please refer to the XLamp CX Family LEDs soldering and handling document. The
CX Family LED Design Guide provides basic information on the requirements to use XLamp CXA LEDs successfully in luminaire designs.
To keep the CXA1304 LED at or below the maximum rated Tc, the case to ambient temperature
thermal resistance (R_c-a) must be at or below the maximum R_c-a value shown on the following
R_j-c
R_j-c
scale.
Tc
Tc
As the figure at right shows, the R_c-a value is the sum of the thermal resistance of the TIM (R_tim)
R_tim
graphs, depending on the operating environment. The y‑axis in each graph is a base 10 logarithmic
R_c-a
plus the thermal resistance of the heat sink (R_hs).
R_hs
CXA1304-9V
Ta
Ta
Maximum R_c-a
100.00
9V
10.00
Ta = 25 °C
Ta = 55 °C
1.00
Ta = 85 °C
Ta = 105 °C
0.10
0.01
200
300
400
500
600
700
800
900
1000
Current (mA)
CLD-DS73
REV 10A
28
XLAMP ® CXA1304 LED
CXA1304-18V
THERMAL
DESIGN - CONTINUED
Maximum R_c-a
100.00
18 V
10.00
Ta = 25 °C
Ta = 55 °C
1.00
Ta = 85 °C
Ta = 105 °C
0.10
0.01
100
150
200
250
300
350
400
450
500
Current (mA)
CXA1304-36V
Maximum R_c-a
100.00
36 V
10.00
Ta = 25 °C
Ta = 55 °C
1.00
Ta = 85 °C
Ta = 105 °C
0.10
0.01
50
75
100
125
150
175
200
225
250
Current (mA)
CLD-DS73
REV 10A
29
XLAMP ® CXA1304 LED
NOTES
Measurements
The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only
and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number
of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated
values are provided for informational purposes only and are not intended or provided as specifications.
Pre‑Release Qualification Testing
Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp
LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs.
Lumen Maintenance
Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen
maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document.
Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and
forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive
current affect the LED junction temperature.
RoHS Compliance
The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold
limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as
implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product
Ecology section of the Cree LED website.
REACh Compliance
REACh substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA)
has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative
to insure you get the most up-to-date REACh Declaration. REACh banned substance information (REACh Article 67) is also available upon
request.
UL® Recognized Component
This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED
package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750.
Vision Advisory
WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please
refer to the LED Eye Safety application note.
CLD-DS73
REV 10A
30
XLAMP ® CXA1304 LED
PACKAGING
CXA1304 LEDs are packaged in trays of 20. Five trays are sealed in an anti-static bag and placed inside a carton, for a total of 100 LEDs
per carton. Each carton contains 100 LEDs from the same performance bin.
Dimensions are in inches.
REV
5.875 4
5
5.875
DESC.
6
NOTICE
FIDENTIAL. THIS PLOT AND THE INFORMATION
D WITHIN ARE THE PROPRIETARY AND
TIAL
INFORMATION OF CREE, INC. THIS PLOT
NSENT
E COPIED, REPRODUCED OR DISCLOSED TO ANY
IZED PERSON WITHOUTTHE WRITTEN CONSENT
C.
REV
CHK.
DESC.
Tolerances:DATE
±.13BY
CHK.
x° ±1°
2
R.375
4
3
1
2
1
.562
.562
5.875
BY
3
R.375
5
DATE
5.875
R .375
.875
.875
R.375
5.875
.875
.875
5.875
.875
.38
.38
.58
PATENT LABEL IS LOCATED
WITH CREE
ON LABEL
UNDERSIDE
OF CARTON
BIN CODE, QTY, LOT#
SECTION C-C
TH CREE BIN
.875LABEL
PATENT
OF NOT
ANTITY, LOTIS# LOCATED ON UNDERSIDEDO
THIS DRAWING CONTAINS PROPRIETARY DESIGN INFORMATION
.38
.875ALONG WITH THE PRODUCT OR PRODUCTS
AND REMAINS
REPRESENTED HEREIN THE PROPERTY OF TEK PAK, INCORPORATED.
THIS DOCUMENT AND THE INFORMATION IT CONTAINS
DWG.TITLE
MAY NOT BE COPIED, TRANSMITTED, OR USED BY ANY
THIRD PARTY WITHOUT THE EXPRESS WRITTEN APPROVAL
SECTION C-C
SCALE
CARTON DWG.
.38
BAG
AND REMAINS ALONG WITH THE PRODUCT OR PRODUCTS
DWG.TITLE
PART DRAWING
PART DRAWING
BAG
UNLESS OTHERWISE NOTED ALL
DATE:
DR. BY:
CHK. BY:
1.000
ARE AS
FOLLOWS:
DATE:
DO
NOT 4-3-13 TOLERANCES
SIZE SCALE:
DR. BY:
SCALE
DWG. KJS
022490-00
TOLERANCES ARE AS FOLLOWS:
FRACT ±1/64 X.X" ±.030 X.0mm ±.75mm
ANGLES ±0°-30' X.XX" ±.015 X.Xmm ±.30mm
DRAFT ±1°
X.XXX" ±.005 X.XXmm ±.10mm
CHK. BY:
B
FRACT ±1/64 X.X" DWG.
±.030 NO.
X.0mm ±.75mm
DRAFT ±1°
SHEET 2 OF 2
4-3-13
KJS
SIZE
B
SCALE: 1.000
DWG. NO.
022490-00
SHEET 2 OF 2
L IS LOCATED
IDE OF COVER
LABEL WITH CREE
BIN CODE, QTY, LOT#
LABEL WITH CREE BIN
CODE, QUANTITY, LOT #
LABEL WITH CREE BIN
UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN
MILLIMETERS & BEFORE FINISH.
TOLERANCE UNLESS SPECIFIED:
LABEL WITH CREE
BIN CODE, QTY, LOT#
.X
.XX ±
.XXX ±
X°
THIRD ANGLE PROJECTION
WITH CREE
BIN
6
QUANTITY, LOT #
0.1
.05
.005
1°
FOR SHEET METAL PARTS ONLY
.X
.06
.XX ±
.03
.XXX DRAWN
.010
BY
X°
2°
5
4
DIMENSIONS
ARE IN
3
CHECK
and
APPROVED
.X
± trademarks,
0.1
.XXUL logo
.05
are registered
.XXX ± .005
MATERIAL
X°
DRAWN BY
DATE
CHECK
DATE
APPROVED
DATE
Fax (919) 313-5
CXA15XX_DATASHEET
MATERIAL
SIZE
FINAL PROTECTIVE FINISH
DATE
DATE
SCALE
C
DRAWING NO.
CXA15XX_DATASHEET_BAG2013
SHEET
0.500
OF
4600 Silicon Drive
1 27703
Durham, N.C
2
Phone (919) 361-4770
DATE
TITLE
CLD-DS73
REV 10A
31
Fax (919) 313-5303
CXA15XX_DATASHEET
SIZE
Phone (919) 361
TITLE
1 °
.X
.06
4600 Silicon Dri
Durham, N.C 27
DRAWING NO.
