CXA1304-0000-000C0HB240H
    WOLFSPEED
    SMD
    LED COB CXA1304 NEUTRAL WHT SQ
CXA1304-0000-000C0HB240H 数据手册
PRODUCT FAMILY DATA SHEET XLamp® CXA1304 LED PRODUCT DESCRIPTION FEATURES TABLE OF CONTENTS The XLamp® CXA1304 LED array expands • Available in 4-step, 3‑step and 2-step Characteristics................................................ 2 Cree LED’s family of high‑flux, multi‑die EasyWhite bins at 2700 K, 3000 K, Operating Limits.............................................. 3 arrays in a smaller, easy‑to‑use platform. 3500 K, 4000 K & 5000 K CCT and Flux Characteristics, EasyWhite® Order With XLamp LED lighting‑class reliability, 4-step EasyWhite bins at 5700 K & Codes and Bins - 9 V....................................... 5 the CXA1304’s small, uniform emitting 6500 K CCT Flux Characteristics, ANSI White Order ® surface enables both directional and • Available in ANSI white bins at 4000 K, Codes and Bins - 9 V....................................... 8 non‑directional lighting Flux Characteristics, EasyWhite® Order including retrofit lamp applications and 5000 K, 5700 K & 6500 K CCT luminaire • Available in 70-, 80-, 90- and designs. Available in 2-step, 3‑step and 93‑minimum CRI options Codes and Bins - 18 V..................................... 9 Flux Characteristics, ANSI White Order 4-step color consistency, and featuring a • Forward voltage options: 9‑V class, Codes and Bins - 18 V................................... 12 6‑mm optical source, the CXA1304 brings Flux Characteristics, EasyWhite® Order 18‑V class & 36‑V class new levels of flux and efficacy to this form • 85 °C binning and characterization Codes and Bins - 36 V................................... 13 factor. • Maximum drive current: 1000 mA (9 V), Flux Characteristics, ANSI White Order 500 mA (18 V), 250 mA (36 V) Codes and Bins - 36 V................................... 16 The CX Family LED Design Guide provides • 115° viewing angle, uniform Relative Spectral Power Distribution........... 17 basic information on the requirements Electrical Characteristics.............................. 17 chromaticity profile to use the CXA1304 LED successfully in • Top-side solder connections Relative Luminous Flux................................. 19 luminaire designs. • Thermocouple attach point Typical Spatial Distribution........................... 22 • NEMA SSL-3 2011 standard flux bins Performance Groups - Brightness............... 22 • RoHS and REACh compliant Performance Groups - Chromaticity............ 23 • UL® recognized component (E349212) EasyWhite® Bins Plotted on the 1931 CIE Color Space................................................... 26 ANSI White Bins Plotted on the 1931 CIE Color Space................................................... 26 Bin and Order Code Formats........................ 27 Mechanical Dimensions............................... 27 Thermal Design............................................. 28 Notes............................................................. 30 Packaging...................................................... 31 Cree LED / 4400 Silicon Drive / Durham, NC 27703 USA / +1.919.313.5330 / www.cree-led.com © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS73 REV 10A 1 XLAMP ® CXA1304 LED CHARACTERISTICS Characteristics Viewing angle (FWHM) ESD withstand voltage (HBM per Mil-Std-883D) Unit Minimum Typical degrees Maximum 115 V 8000 DC forward current (9 V) mA 1000* DC forward current (18 V) mA 500* DC forward current (36 V) mA 250* Reverse current (9 V, 18V, 36 V) mA 0.1 Forward voltage (9 V, 400 mA, 85 °C) V Forward voltage (9 V, 400 mA, 25 °C) V Forward voltage (18 V, 200 mA, 85 °C) V Forward voltage (18 V, 200 mA, 25 °C) V Forward voltage (36 V, 100 mA, 85 °C) V Forward voltage (36 V, 100 mA, 25 °C) V * 9 10.5 18 21 36 42 Refer to the Operating Limits section. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS73 REV 10A 2 XLAMP ® CXA1304 LED OPERATING LIMITS The maximum current rating of the CXA1304 depends on the case temperature (Tc) when the LED has reached thermal equilibrium under steady-state operation. The graphs shown below assume that the system design employs good thermal management (thermal interface material and heat sink) and may vary when poor thermal management is employed. Please refer to the Mechanical Dimensions section on page 27 for the location of the Tc measurement point. Another important factor in good thermal management is the temperature of the Light Emitting Surface (LES). Cree LED recommends a maximum LES temperature of 135 °C to ensure optimal LED lifetime. Please refer to the Thermal Design section on page 28 for more information on LES temperature measurement. CXA1304-9V 1200 1000 If (mA) 800 9V 600 400 200 0 0 25 50 75 100 125 150 Case Temperature (°C) CXA1304-18V 600 500 If (mA) 400 18 V 300 200 100 0 0 25 50 75 100 125 150 Case Temperature (°C) © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS73 REV 10A 3 XLAMP ® CXA1304 LED OPERATING LIMITS - CONTINUED CXA1304-36V 300 250 If (mA) 200 36 V 150 100 50 0 0 25 50 75 100 125 150 Case Temperature (°C) © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS73 REV 10A 4 XLAMP ® CXA1304 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 9 V (IF = 400 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA1304 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 27). Nominal CCT CRI Min 70 Minimum Luminous Flux Typ 75 2-Step 3-Step 4-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* B4 410 457 C2 440 490 C4 475 527 CXA1304-0000000C00C465F B4 410 457 CXA1304-0000000C0HB465F C2 440 490 C4 475 527 C2 440 490 Group Order Code Group Order Code Group CXA1304-0000000C00B465F 65F 6500 K 80 70 --- 80 70 80 65F --- 57F 95 CXA1304-0000000C00C257F 475 527 CXA1304-0000000C00C457F B4 410 457 CXA1304-0000000C0HB457F C2 440 490 C4 475 527 C2 440 490 C4 475 527 CXA1304-0000000C00C450H B4 410 457 CXA1304-0000000C0HB450H C2 440 490 C4 475 527 CXA1304-0000000C0HC450H CXA1304-0000000C0HC450G CXA1304-0000000C0HC450F A2 330 366 CXA1304-0000000C0UA250H CXA1304-0000000C0UA250G CXA1304-0000000C0UA250F A4 355 396 B2 380 423 57F CXA1304-0000000C0HC257F CXA1304-0000000C0HC457F 50H 50H 5000 K 90 CXA1304-0000000C0HC265F C4 75 --- CXA1304-0000000C00C265F CXA1304-0000000C0HC465F 75 5700 K Order Code 50H CXA1304-0000000C00C250H CXA1304-0000000C0HC250H CXA1304-0000000C0UA450H CXA1304-0000000C0UB250H 50F CXA1304-0000000C00C250F CXA1304-0000000C00C450F CXA1304-0000000C0HB450F 50G 50G CXA1304-0000000C0HC250G CXA1304-0000000C0UA450G CXA1304-0000000C0UB250G 50F 50F CXA1304-0000000C0HC250F CXA1304-0000000C0UA450F CXA1304-0000000C0UB250F Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 30). • CXA1304 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS73 REV 10A 5 XLAMP ® CXA1304 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 9 V (IF = 400 mA, TJ = 85 °C) - CONTINUED Nominal CCT CRI Min 70 4000 K 80 90 80 Minimum Luminous Flux Typ 75 --- 95 --- 3500 K 93 80 95 4-Step Flux (lm) @ 85 °C Flux (lm) @ 25 °C* B4 410 457 C2 440 490 C4 475 527 CXA1304-0000000C00C440H CXA1304-0000000C00C440F B4 410 457 CXA1304-0000000C0HB440H CXA1304-0000000C0HB440F C2 440 490 C4 475 527 CXA1304-0000000C0HC440H CXA1304-0000000C0HC440G CXA1304-0000000C0HC440F 94 290 327 CXA1304-0000000C0U9440H CXA1304-0000000C0U9440G CXA1304-0000000C0U9440F A2 330 366 A4 355 396 CXA1304-0000000C0UA440H B2 380 423 CXA1304-0000000C00B235H B4 410 457 C2 440 490 CXA1304-0000000C00C235H 94 290 327 CXA1304-0000000C0Y9435H A2 330 366 CXA1304-0000000C0YA235H B2 380 423 CXA1304-0000000C00B230H B4 410 457 C2 440 490 CXA1304-0000000C00C230H 92 250 281 CXA1304-0000000C0Y9230H 94 290 327 A2 330 366 Group Order Code Group Order Code Group CXA1304-0000000C00B440H 40H 40H 40H 35H 35H 30H 3000 K 93 3-Step Group 95 --- 2-Step 30H CXA1304-0000000C00B440F CXA1304-0000000C00C240H CXA1304-0000000C0HC240H CXA1304-0000000C0UA240H CXA1304-0000000C00B435H CXA1304-0000000C00B430H CXA1304-0000000C0Y9430H CXA1304-0000000C0YA230H Order Code 40F 40G 40G CXA1304-0000000C0HC240G CXA1304-0000000C0UA240G 40F 40F CXA1304-0000000C0UA440G CXA1304-0000000C00C240F CXA1304-0000000C0HC240F CXA1304-0000000C0UA240F CXA1304-0000000C0UA440F CXA1304-0000000C00B235F 35G CXA1304-0000000C00B435G 35F CXA1304-0000000C00C235G 35G CXA1304-0000000C0YA235G CXA1304-0000000C00B435F CXA1304-0000000C00C235F 35F CXA1304-0000000C0Y9435F CXA1304-0000000C0YA235F CXA1304-0000000C00B230F 30G CXA1304-0000000C00B430G 30F CXA1304-0000000C00C230G CXA1304-0000000C00B430F CXA1304-0000000C00C230F CXA1304-0000000C0Y9230F 30G CXA1304-0000000C0Y9430G CXA1304-0000000C0YA230G 30F CXA1304-0000000C0Y9430F CXA1304-0000000C0YA230F Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 30). • CXA1304 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS73 REV 10A 6 XLAMP ® CXA1304 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 9 V (IF = 400 mA, TJ = 85 °C) - CONTINUED Nominal CCT CRI Min 80 Minimum Luminous Flux Typ --- 2-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* A4 355 396 B2 380 423 B4 410 457 CXA1304-0000000C00B427H 84 220 248 CXA1304-0000000C0Y8427H 92 250 281 94 290 327 Group 95 Group Order Code 4-Step Group CXA1304-0000000C00A427H 27H 2700 K 93 Order Code 3-Step 27H CXA1304-0000000C00B227H CXA1304-0000000C0Y9227H CXA1304-0000000C0Y9427H Order Code CXA1304-0000000C00A427F 27G CXA1304-0000000C00B227G 27F CXA1304-0000000C00B427G CXA1304-0000000C00B227F CXA1304-0000000C00B427F CXA1304-0000000C0Y8427F 27G CXA1304-0000000C0Y9227G CXA1304-0000000C0Y9427G 27F CXA1304-0000000C0Y9227F CXA1304-0000000C0Y9427F Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 30). • CXA1304 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS73 REV 10A 7 XLAMP ® CXA1304 LED FLUX CHARACTERISTICS, ANSI WHITE ORDER CODES AND BINS - 9 V (IF = 400 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA1304 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 27). Nominal CCT CRI Min 70 Minimum Luminous Flux Typ 75 6500 K 80 70 --- 75 5700 K 80 70 --- 75 5000 K 80 4000 K 70 --- 75 Chromaticity Regions Order Code Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* B4 410 457 C2 440 490 C4 475 527 CXA1304-0000-000C00C40E1 B4 410 457 CXA1304-0000-000C0HB40E1 C2 440 490 C4 475 527 C2 440 490 C4 475 527 B4 410 457 C2 440 490 C4 475 527 C2 440 490 C4 475 527 B4 410 457 C2 440 490 C4 475 527 CXA1304-0000-000C0HC40E3 B4 410 457 CXA1304-0000-000C00B40E5 C2 440 490 C4 475 527 CXA1304-0000-000C00B40E1 1A0, 1B0, 1C0, 1D0, 65F 1A0, 1B0, 1C0, 1D0, 65F CXA1304-0000-000C00C20E1 CXA1304-0000-000C0HC20E1 CXA1304-0000-000C0HC40E1 2A0, 2B0, 2C0, 2D0, 57F CXA1304-0000-000C00C20E2 CXA1304-0000-000C00C40E2 CXA1304-0000-000C0HB40E2 2A0, 2B0, 2C0, 2D0, 57F CXA1304-0000-000C0HC20E2 CXA1304-0000-000C0HC40E2 3A0, 3B0, 3C0, 3D0, 50F CXA1304-0000-000C00C20E3 CXA1304-0000-000C00C40E3 CXA1304-0000-000C0HB40E3 3A0, 3B0, 3C0, 3D0, 50F 5A0, 5B0, 5C.0, 5D0, 40F CXA1304-0000-000C0HC20E3 CXA1304-0000-000C00C20E5 CXA1304-0000-000C00C40E5 Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 30). • CXA1304 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS73 REV 10A 8 XLAMP ® CXA1304 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 18 V (IF = 200 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA1304 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 27). Nominal CCT CRI Min 70 Minimum Luminous Flux Typ 75 2-Step 3-Step 4-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* B4 410 457 C2 440 490 C4 475 527 CXA1304-0000000F00C465F B4 410 457 CXA1304-0000000F0HB465F C2 440 490 C4 475 527 C2 440 490 Group Order Code Group Order Code Group CXA1304-0000000F00B465F 65F 6500 K 80 70 --- 80 70 80 65F --- 57F 95 CXA1304-0000000F00C257F 475 527 CXA1304-0000000F00C457F B4 410 457 CXA1304-0000000F0HB457F C2 440 490 C4 475 527 C2 440 490 C4 475 527 CXA1304-0000000F00C450H B4 410 457 CXA1304-0000000F0HB450H C2 440 490 C4 475 527 CXA1304-0000000F0HC450H CXA1304-0000000F0HC450G CXA1304-0000000F0HC450F A2 330 366 CXA1304-0000000F0UA250H CXA1304-0000000F0UA250G CXA1304-0000000F0UA250F A4 355 396 B2 380 423 57F CXA1304-0000000F0HC257F CXA1304-0000000F0HC457F 50H 50H 5000 K 90 CXA1304-0000000F0HC265F C4 75 --- CXA1304-0000000F00C265F CXA1304-0000000F0HC465F 75 5700 K Order Code 50H CXA1304-0000000F00C250H CXA1304-0000000F0HC250H CXA1304-0000000F0UA450H CXA1304-0000000F0UB250H 50F CXA1304-0000000F00C250F CXA1304-0000000F00C450F CXA1304-0000000F0HB450F 50G 50G CXA1304-0000000F0HC250G CXA1304-0000000F0UA450G CXA1304-0000000F0UB250G 50F 50F CXA1304-0000000F0HC250F CXA1304-0000000F0UA450F CXA1304-0000000F0UB250F Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 30). • CXA1304 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS73 REV 10A 9 XLAMP ® CXA1304 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 18 V (IF = 200 mA, TJ = 85 °C) - CONTINUED Nominal CCT CRI Min 70 4000 K 80 90 80 Minimum Luminous Flux Typ 75 --- 95 --- 3500 K 93 80 95 4-Step Flux (lm) @ 85 °C Flux (lm) @ 25 °C* B4 410 457 C2 440 490 C4 475 527 CXA1304-0000000F00C440H CXA1304-0000000F00C440F B4 410 457 CXA1304-0000000F0HB440H CXA1304-0000000F0HB440F C2 440 490 C4 475 527 CXA1304-0000000F0HC440H CXA1304-0000000F0HC440G CXA1304-0000000F0HC440F 94 290 327 CXA1304-0000000F0U9440H CXA1304-0000000F0U9440G CXA1304-0000000F0U9440F A2 330 366 A4 355 396 CXA1304-0000000F0UA440H B2 380 423 CXA1304-0000000F00B235H B4 410 457 C2 440 490 CXA1304-0000000F00C235H 94 290 327 CXA1304-0000000F0Y9435H A2 330 366 CXA1304-0000000F0YA235H B2 380 423 CXA1304-0000000F00B230H B4 410 457 C2 440 490 CXA1304-0000000F00C230H 92 250 281 CXA1304-0000000F0Y9230H 94 290 327 A2 330 366 Group Order Code Group Order Code Group CXA1304-0000000F00B440H 40H 40H 40H 35H 35H 30H 3000 K 93 3-Step Group 95 --- 2-Step 30H CXA1304-0000000F00B440F CXA1304-0000000F00C240H CXA1304-0000000F0HC240H CXA1304-0000000F0UA240H CXA1304-0000000F00B435H CXA1304-0000000F00B430H CXA1304-0000000F0Y9430H CXA1304-0000000F0YA230H Order Code 40F 40G 40G CXA1304-0000000F0HC240G CXA1304-0000000F0UA240G 40F 40F CXA1304-0000000F0UA440G CXA1304-0000000F00C240F CXA1304-0000000F0HC240F CXA1304-0000000F0UA240F CXA1304-0000000F0UA440F CXA1304-0000000F00B235F 35G CXA1304-0000000F00B435G 35F CXA1304-0000000F00C235G 35G CXA1304-0000000F0YA235G CXA1304-0000000F00B435F CXA1304-0000000F00C235F 35F CXA1304-0000000F0Y9435F CXA1304-0000000F0YA235F CXA1304-0000000F00B230F 30G CXA1304-0000000F00B430G 30F CXA1304-0000000F00C230G CXA1304-0000000F00B430F CXA1304-0000000F00C230F CXA1304-0000000F0Y9230F 30G CXA1304-0000000F0Y9430G CXA1304-0000000F0YA230G 30F CXA1304-0000000F0Y9430F CXA1304-0000000F0YA230F Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 30). • CXA1304 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS73 REV 10A 10 XLAMP ® CXA1304 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 18 V (IF = 200 mA, TJ = 85 °C) - CONTINUED Nominal CCT CRI Min 80 Minimum Luminous Flux Typ --- 2-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* A4 355 396 B2 380 423 B4 410 457 CXA1304-0000000F00B427H 84 220 248 CXA1304-0000000F0Y8427H 92 250 281 94 290 327 Group 95 Group Order Code 4-Step Group CXA1304-0000000F00A427H 27H 2700 K 93 Order Code 3-Step 27H CXA1304-0000000F00B227H CXA1304-0000000F0Y9227H CXA1304-0000000F0Y9427H Order Code CXA1304-0000000F00A427F 27G CXA1304-0000000F00B227G 27F CXA1304-0000000F00B427G CXA1304-0000000F00B227F CXA1304-0000000F00B427F CXA1304-0000000F0Y8427F 27G CXA1304-0000000F0Y9227G CXA1304-0000000F0Y9427G 27F CXA1304-0000000F0Y9227F CXA1304-0000000F0Y9427F Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 30). • CXA1304 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS73 REV 10A 11 XLAMP ® CXA1304 LED FLUX CHARACTERISTICS, ANSI WHITE ORDER CODES AND BINS - 18 V (IF = 200 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA1304 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 27). Nominal CCT CRI Min 70 Minimum Luminous Flux Typ 75 6500 K 80 70 --- 75 5700 K 80 70 --- 75 5000 K 80 4000 K 70 --- 75 Chromaticity Regions Order Code Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* B4 410 457 C2 440 490 C4 475 527 CXA1304-0000-000F00C40E1 B4 410 457 CXA1304-0000-000F0HB40E1 C2 440 490 C4 475 527 C2 440 490 C4 475 527 B4 410 457 C2 440 490 C4 475 527 C2 440 490 C4 475 527 B4 410 457 C2 440 490 C4 475 527 CXA1304-0000-000F0HC40E3 B4 410 457 CXA1304-0000-000F00B40E5 C2 440 490 C4 475 527 CXA1304-0000-000F00B40E1 1A0, 1B0, 1C0, 1D0, 65F 1A0, 1B0, 1C0, 1D0, 65F CXA1304-0000-000F00C20E1 CXA1304-0000-000F0HC20E1 CXA1304-0000-000F0HC40E1 2A0, 2B0, 2C0, 2D0, 57F CXA1304-0000-000F00C20E2 CXA1304-0000-000F00C40E2 CXA1304-0000-000F0HB40E2 2A0, 2B0, 2C0, 2D0, 57F CXA1304-0000-000F0HC20E2 CXA1304-0000-000F0HC40E2 3A0, 3B0, 3C0, 3D0, 50F CXA1304-0000-000F00C20E3 CXA1304-0000-000F00C40E3 CXA1304-0000-000F0HB40E3 3A0, 3B0, 3C0, 3D0, 50F 5A0, 5B0, 5C.0, 5D0, 40F CXA1304-0000-000F0HC20E3 CXA1304-0000-000F00C20E5 CXA1304-0000-000F00C40E5 Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 30). • CXA1304 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS73 REV 10A 12 XLAMP ® CXA1304 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 36 V (IF = 100 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA1304 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 27). Nominal CCT CRI Min 70 Minimum Luminous Flux Typ 75 2-Step 3-Step 4-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* B4 410 457 C2 440 490 C4 475 527 CXA1304-0000000N00C465F B4 410 457 CXA1304-0000000N0HB465F C2 440 490 C4 475 527 C2 440 490 Group Order Code Group Order Code Group CXA1304-0000000N00B465F 65F 6500 K 80 70 --- 80 70 80 65F --- 57F 95 CXA1304-0000000N00C257F 475 527 CXA1304-0000000N00C457F B4 410 457 CXA1304-0000000N0HB457F C2 440 490 C4 475 527 C2 440 490 C4 475 527 CXA1304-0000000N00C450H B4 410 457 CXA1304-0000000N0HB450H C2 440 490 C4 475 527 CXA1304-0000000N0HC450H CXA1304-0000000N0HC450G CXA1304-0000000N0HC450F A2 330 366 CXA1304-0000000N0UA250H CXA1304-0000000N0UA250G CXA1304-0000000N0UA250F A4 355 396 B2 380 423 57F CXA1304-0000000N0HC257F CXA1304-0000000N0HC457F 50H 50H 5000 K 90 CXA1304-0000000N0HC265F C4 75 --- CXA1304-0000000N00C265F CXA1304-0000000N0HC465F 75 5700 K Order Code 50H CXA1304-0000000N00C250H CXA1304-0000000N0HC250H CXA1304-0000000N0UA450H CXA1304-0000000N0UB250H 50F CXA1304-0000000N00C250F CXA1304-0000000N00C450F CXA1304-0000000N0HB450F 50G 50G CXA1304-0000000N0HC250G CXA1304-0000000N0UA450G CXA1304-0000000N0UB250G 50F 50F CXA1304-0000000N0HC250F CXA1304-0000000N0UA450F CXA1304-0000000N0UB250F Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 30). • CXA1304 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS73 REV 10A 13 XLAMP ® CXA1304 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 36 V (IF = 100 mA, TJ = 85 °C) - CONTINUED Nominal CCT CRI Min 70 4000 K 80 90 80 Minimum Luminous Flux Typ 75 --- 95 --- 3500 K 93 80 95 4-Step Flux (lm) @ 85 °C Flux (lm) @ 25 °C* B4 410 457 C2 440 490 C4 475 527 CXA1304-0000000N00C440H CXA1304-0000000N00C440F B4 410 457 CXA1304-0000000N0HB440H CXA1304-0000000N0HB440F C2 440 490 C4 475 527 CXA1304-0000000N0HC440H CXA1304-0000000N0HC440G CXA1304-0000000N0HC440F 94 290 327 CXA1304-0000000N0U9440H CXA1304-0000000N0U9440G CXA1304-0000000N0U9440F A2 330 366 A4 355 396 CXA1304-0000000N0UA440H B2 380 423 CXA1304-0000000N00B235H B4 410 457 C2 440 490 CXA1304-0000000N00C235H 94 290 327 CXA1304-0000000N0Y9435H A2 330 366 CXA1304-0000000N0YA235H B2 380 423 CXA1304-0000000N00B230H B4 410 457 C2 440 490 CXA1304-0000000N00C230H 92 250 281 CXA1304-0000000N0Y9230H 94 290 327 A2 330 366 Group Order Code Group Order Code Group CXA1304-0000000N00B440H 40H 40H 40H 35H 35H 30H 3000 K 93 3-Step Group 95 --- 2-Step 30H CXA1304-0000000N00B440F CXA1304-0000000N00C240H CXA1304-0000000N0HC240H CXA1304-0000000N0UA240H CXA1304-0000000N00B435H CXA1304-0000000N00B430H CXA1304-0000000N0Y9430H CXA1304-0000000N0YA230H Order Code 40F 40G 40G CXA1304-0000000N0HC240G CXA1304-0000000N0UA240G 40F 40F CXA1304-0000000N0UA440G CXA1304-0000000N00C240F CXA1304-0000000N0HC240F CXA1304-0000000N0UA240F CXA1304-0000000N0UA440F CXA1304-0000000N00B235F 35G CXA1304-0000000N00B435G 35F CXA1304-0000000N00C235G 35G CXA1304-0000000N0YA235G CXA1304-0000000N00B435F CXA1304-0000000N00C235F 35F CXA1304-0000000N0Y9435F CXA1304-0000000N0YA235F CXA1304-0000000N00B230F 30G CXA1304-0000000N00B430G 30F CXA1304-0000000N00C230G CXA1304-0000000N00B430F CXA1304-0000000N00C230F CXA1304-0000000N0Y9230F 30G CXA1304-0000000N0Y9430G CXA1304-0000000N0YA230G 30F CXA1304-0000000N0Y9430F CXA1304-0000000N0YA230F Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 30). • CXA1304 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS73 REV 10A 14 XLAMP ® CXA1304 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 36 V (IF = 100 mA, TJ = 85 °C) - CONTINUED Nominal CCT CRI Min 80 Minimum Luminous Flux Typ --- 2-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* A4 355 396 B2 380 423 B4 410 457 CXA1304-0000000N00B427H 84 220 248 CXA1304-0000000N0Y8427H 92 250 281 94 290 327 Group 95 Group Order Code 4-Step Group CXA1304-0000000N00A427H 27H 2700 K 93 Order Code 3-Step 27H CXA1304-0000000N00B227H CXA1304-0000000N0Y9227H CXA1304-0000000N0Y9427H Order Code CXA1304-0000000N00A427F 27G CXA1304-0000000N00B227G 27F CXA1304-0000000N00B427G CXA1304-0000000N00B227F CXA1304-0000000N00B427F CXA1304-0000000N0Y8427F 27G CXA1304-0000000N0Y9227G CXA1304-0000000N0Y9427G 27F CXA1304-0000000N0Y9227F CXA1304-0000000N0Y9427F Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 30). • CXA1304 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS73 REV 10A 15 XLAMP ® CXA1304 LED FLUX CHARACTERISTICS, ANSI WHITE ORDER CODES AND BINS - 36 V (IF = 100 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA1304 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 27). Nominal CCT CRI Min 70 Minimum Luminous Flux Typ 75 6500 K 80 70 --- 75 5700 K 80 70 --- 75 5000 K 80 4000 K 70 --- 75 Chromaticity Regions Order Code Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* B4 410 457 C2 440 490 C4 475 527 CXA1304-0000-000N00C40E1 B4 410 457 CXA1304-0000-000N0HB40E1 C2 440 490 C4 475 527 C2 440 490 C4 475 527 B4 410 457 C2 440 490 C4 475 527 C2 440 490 C4 475 527 B4 410 457 C2 440 490 C4 475 527 CXA1304-0000-000N0HC40E3 B4 410 457 CXA1304-0000-000N00B40E5 C2 440 490 C4 475 527 CXA1304-0000-000N00B40E1 1A0, 1B0, 1C0, 1D0, 65F 1A0, 1B0, 1C0, 1D0, 65F CXA1304-0000-000N00C20E1 CXA1304-0000-000N0HC20E1 CXA1304-0000-000N0HC40E1 2A0, 2B0, 2C0, 2D0, 57F CXA1304-0000-000N00C20E2 CXA1304-0000-000N00C40E2 CXA1304-0000-000N0HB40E2 2A0, 2B0, 2C0, 2D0, 57F CXA1304-0000-000N0HC20E2 CXA1304-0000-000N0HC40E2 3A0, 3B0, 3C0, 3D0, 50F CXA1304-0000-000N00C20E3 CXA1304-0000-000N00C40E3 CXA1304-0000-000N0HB40E3 3A0, 3B0, 3C0, 3D0, 50F 5A0, 5B0, 5C.0, 5D0, 40F CXA1304-0000-000N0HC20E3 CXA1304-0000-000N00C20E5 CXA1304-0000-000N00C40E5 Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 30). • CXA1304 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS73 REV 10A 16 XLAMP ® CXA1304 LED Relative Spectral Power Distribution RELATIVE SPECTRAL POWER DISTRIBUTION The following graph is the result of a series of pulsed measurements at 400 mA for the 9-V CXA1304 LED, 200 mA for the 18-V CXA1304 LED and 100 mA for the 36-V CXA1304 LED and TJ = 85 °C. 100% Relative Spectral Power 90% 80% 70% 60% 5000 K, 70 CRI 50% 4000 K, 70 CRI 40% 3000 K, 80 CRI 30% 3000 K, 93 CRI 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) ELECTRICAL CHARACTERISTICS The following graphs are the result of a series of steady-state measurements. 10.75 9V Voltage (V) 10.25 Tc = 25 °C 9.75 Tc = 55 °C Tc = 85 °C 9.25 Tc = 105 °C 8.75 8.25 200 300 400 500 600 700 800 900 1000 Current (mA) © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS73 REV 10A 17 XLAMP ® CXA1304 LED ELECTRICAL CHARACTERISTICS - CONTINUED 21.5 18 V Voltage (V) 20.5 Tc = 25 °C 19.5 Tc = 55 °C Tc = 85 °C 18.5 Tc = 105 °C 17.5 16.5 100 150 200 250 300 350 400 450 500 Current (mA) 43 36 V Voltage (V) 41 Tc = 25 °C 39 Tc = 55 °C Tc = 85 °C 37 Tc = 105 °C 35 33 50 75 100 125 150 175 200 225 250 Current (mA) © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS73 REV 10A 18 XLAMP ® CXA1304 LED RELATIVE LUMINOUS FLUX The relative luminous flux values provided below are the ratio of: • Measurements of CXA1304 at steady-state operation at the given conditions, divided by • Flux measured during binning, which is a pulsed measurement at 400 mA at TJ = 85 °C for the 9-V CXA1304 LED. Using the 9-V CXA1304 LED as an example, at steady-state operation of Tc = 55 °C, IF = 700 mA, the relative luminous flux ratio is 160% in the chart below. A 9-V CXA1304 LED that measures 380 lm during binning will deliver 608 lm (380 * 1.6) at steady-state operation of Tc = 55 °C, IF = 700 mA. 240% Relative Luminous Flux 200% 9V 160% Tc = 25 °C Tc = 55 °C 120% Tc = 85 °C Tc = 105 °C 80% 40% 0% 200 300 400 500 600 700 800 900 1000 Current (mA) © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS73 REV 10A 19 XLAMP ® CXA1304 LED RELATIVE LUMINOUS FLUX - CONTINUED The relative luminous flux values provided below are the ratio of: • Measurements of CXA1304 at steady-state operation at the given conditions, divided by • Flux measured during binning, which is a pulsed measurement at 200 mA at TJ = 85 °C for the 18-V CXA1304 LED. Using the 18-V CXA1304 LED as an example, at steady-state operation of Tc = 55 °C, IF = 350 mA, the relative luminous flux ratio is 160% in the chart below. An 18-V CXA1304 LED that measures 380 lm during binning will deliver 608 lm (380 * 1.6) at steady-state operation of Tc = 55 °C, IF = 350 mA. 240% Relative Luminous Flux 200% 18 V 160% Tc = 25 °C Tc = 55 °C 120% Tc = 85 °C Tc = 105 °C 80% 40% 0% 100 150 200 250 300 350 400 450 500 Current (mA) © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS73 REV 10A 20 XLAMP ® CXA1304 LED RELATIVE LUMINOUS FLUX - CONTINUED The relative luminous flux values provided below are the ratio of: • Measurements of CXA1304 at steady-state operation at the given conditions, divided by • Flux measured during binning, which is a pulsed measurement at 100 mA at TJ = 85 °C for the 36-V CXA1304 LED. Using the 36-V CXA1304 LED as an example, at steady-state operation of Tc = 55 °C, IF = 175 mA, the relative luminous flux ratio is 160% in the chart below. A 36-V CXA1304 LED that measures 380 lm during binning will deliver 608 lm (380 * 1.6) at steady-state operation of Tc = 55 °C, IF = 175 mA. 240% Relative Luminous Flux 200% 36 V 160% Tc = 25 °C Tc = 55 °C 120% Tc = 85 °C Tc = 105 °C 80% 40% 0% 50 75 100 125 150 175 200 225 250 Current (mA) © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS73 REV 10A 21 XLAMP ® CXA1304 LED TYPICAL SPATIAL DISTRIBUTION 100% Relative Luminous Intensity 80% 60% 40% 20% -90 -70 -50 -30 -10 0% 10 30 50 70 90 Angle (º) PERFORMANCE GROUPS - BRIGHTNESS (9 V, IF = 400 mA; 18 V, IF = 200 mA; 36 V, IF = 100 mA, TJ = 85 °C) XLamp CXA1304 LEDs are tested for luminous flux and placed into one of the following bins. Group Code Minimum Luminous Flux Maximum Luminous Flux 84 220 250 92 250 290 94 290 330 A2 330 355 A4 355 380 B2 380 410 B4 410 440 C2 440 475 C4 475 510 D2 510 550 D4 550 590 © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS73 REV 10A 22 XLAMP ® CXA1304 LED PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) XLamp CXA1304 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. EasyWhite Color Temperatures – 2-Step Code 50H 40H 35H 30H 27H CCT 5000 K 4000 K 3500 K 3000 K 2700 K x y 0.3429 0.3507 0.3434 0.3571 0.3475 0.3604 0.3469 0.3539 0.3784 0.3741 0.3804 0.3818 0.3867 0.3857 0.3844 0.3778 0.4030 0.3857 0.4061 0.3941 0.4132 0.3976 0.4099 0.3890 0.4291 0.3973 0.4333 0.4062 0.4395 0.4084 0.4351 0.3994 0.4528 0.4046 0.4578 0.4138 0.4638 0.4152 0.4586 0.4060 EasyWhite Color Temperatures – 3-Step Ellipse Bin Code CCT 50G 40G Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 5000 K 0.3447 0.3553 0.00840 0.00312 65.0 4000 K 0.3818 0.3797 0.00939 0.00402 53.7 35G 3500 K 0.4073 0.3917 0.00927 0.00414 54.0 30G 3000 K 0.4338 0.4030 0.00834 0.00408 53.2 27G 2700 K 0.4577 0.4099 0.00834 0.00420 48.5 © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS73 REV 10A 23 XLAMP ® CXA1304 LED PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) - CONTINUED EasyWhite Color Temperatures – 4-Step Code 65F 57F 50F 40F 35F 30F 27F CCT 6500 K 5700 K 5000 K 4000 K 3500 K 3000 K 2700 K x y 0.3097 0.3196 0.3079 0.3297 0.3164 0.3382 0.3176 0.3275 0.3253 0.3325 0.3249 0.3439 0.3331 0.3514 0.3330 0.3393 0.3407 0.3459 0.3415 0.3586 0.3499 0.3654 0.3484 0.3521 0.3744 0.3685 0.3782 0.3837 0.3912 0.3917 0.3863 0.3758 0.3981 0.3800 0.4040 0.3966 0.4186 0.4037 0.4116 0.3865 0.4242 0.3919 0.4322 0.4096 0.4449 0.4141 0.4359 0.3960 0.4475 0.3994 0.4573 0.4178 0.4695 0.4207 0.4589 0.4021 © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS73 REV 10A 24 XLAMP ® CXA1304 LED PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) - CONTINUED ANSI White Bins Code Bin Code CCT 1A0 1B0 0E1 6500 K 1C0 1D0 ANSI White Bins x y 0.3048 0.3207 0.3130 0.3290 0.3144 0.3186 0.3068 Code x y 0.3215 0.3350 0.3290 0.3417 0.3290 0.3300 0.3113 0.3222 0.3243 0.3028 0.3304 0.3207 0.3462 0.3115 0.3391 0.3290 0.3538 0.3130 0.3290 0.3290 0.3417 0.3048 0.3207 0.3215 0.3350 0.3115 0.3391 0.3290 0.3538 0.3205 0.3481 0.3376 0.3616 0.3213 0.3373 0.3371 0.3490 0.3130 0.3290 0.3290 0.3417 0.3130 0.3290 0.3290 0.3417 0.3213 0.3373 0.3371 0.3490 0.3221 0.3261 0.3366 0.3369 0.3144 0.3186 0.3290 0.3300 2A0 2B0 0E2 5700 K 2C0 2D0 ANSI White Bins Code CCT Bin Code 3A0 3B0 0E3 5000 K 3C0 3D0 Bin Code CCT ANSI White Bins x y Code CCT Bin Code x y .3371 .3490 .3670 .3578 .3451 .3554 .3702 .3722 .3440 .3427 .3825 .3798 .3366 .3369 .3783 .3646 .3376 .3616 .3702 .3722 .3463 .3687 .3736 .3874 .3451 .3554 .3869 .3958 .3371 .3490 .3825 .3798 .3825 .3798 .3869 .3958 .4006 .4044 5A0 5B0 0E5 4000 K .3463 .3687 .3551 .3760 .3533 .3620 .3451 .3554 .3950 .3875 .3451 .3554 .3783 .3646 .3533 .3620 .3825 .3798 .3515 .3487 .3950 .3875 .3440 .3427 .3898 .3716 5C0 5D0 © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS73 REV 10A 25 XLAMP ® CXA1304 LED EASYWHITE® BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) 0.44 2700 K ANSI C78.377 Quadrangle 0.43 3000 K EasyWhite 4-Step EasyWhite 3-Step 0.42 EasyWhite 2-Step 3500 K 0.41 4000 K 0.40 4500 K CCy 0.39 5000 K 0.38 0.37 5700 K 0.36 6500 K 0.35 0.34 0.33 0.32 0.49 0.48 0.47 0.45 0.41 0.46 0.44 0.40 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.31 CCx ANSI WHITE BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) 0.41 4000 K ANSI C78.377 Quadrangle 0.40 4500 K 5C 0.39 5D 0.37 CCy 5B 5000 K 0.38 5700 K 0.36 5A 3C 3B 6500 K 0.35 2B 0.34 1C 1B 0.33 3D 2C 1D 3A 2D 2A 1A 0.32 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.31 CCx © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS73 REV 10A 26 XLAMP ® CXA1304 LED BIN AND ORDER CODE FORMATS Bin codes and order codes are configured as follows: Order Code Bin Code Series = CXA13 Series = CXA13 Internal code Chromaticity bin CRI Specification 0 = Standard CRI H = 80 CRI minimum U = 90 CRI minimum Y = 93 CRI minimum Vf class C0 = 9-V class F0 = 18-V class N0 = 36-V class SSSSSCC-HHHH-HHHGGRNNNNN Internal code SSSSSCC-WWW-FF-GGR-AAAAA Kit code CRI Specification B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Y = 93 CRI minimum Vf class C0 = 9-V class F0 = 18-V class N0 = 36-V class Flux bin Performance class Performance class MECHANICAL DIMENSIONS Dimensions are in mm. Tolerances unless otherwise specified: ±.13 x° ± 1° Meaning of 1304X 1304F = 18‑V CXA1304 1304N = 36‑V CXA1304 1304X 1304C = 9‑V CXA1304 © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS73 REV 10A 27 XLAMP ® CXA1304 LED THERMAL DESIGN The CXA family of LED arrays can include over a hundred different LED die inside one package, and thus over a hundred different junction temperatures (TJ). Cree LED has intentionally removed junction-temperature-based operating limits and replaced the commonplace maximum TJ calculations with maximum ratings based on forward current (IF) and case temperature (Tc). No additional calculations are required to ensure that the CXA LED is being operated within its designed limits. LES temperature measurement provides additional verification of good thermal design. Please refer to page 3 for the Operating Limit specifications. There is no need to calculate for TJ inside the package, as the thermal management design process, specifically from TSP to ambient (Ta), remains identical to any other LED component. For more information on thermal management of XLamp LEDs, please refer to the Thermal Management application note. For CXA soldering recommendations and more information on thermal interface materials (TIM), LES temperature measurement, and connection methods, please refer to the XLamp CX Family LEDs soldering and handling document. The CX Family LED Design Guide provides basic information on the requirements to use XLamp CXA LEDs successfully in luminaire designs. To keep the CXA1304 LED at or below the maximum rated Tc, the case to ambient temperature thermal resistance (R_c-a) must be at or below the maximum R_c-a value shown on the following R_j-c R_j-c scale. Tc Tc As the figure at right shows, the R_c-a value is the sum of the thermal resistance of the TIM (R_tim) R_tim graphs, depending on the operating environment. The y‑axis in each graph is a base 10 logarithmic R_c-a plus the thermal resistance of the heat sink (R_hs). R_hs CXA1304-9V Ta Ta Maximum R_c-a 100.00 9V 10.00 Ta = 25 °C Ta = 55 °C 1.00 Ta = 85 °C Ta = 105 °C 0.10 0.01 200 300 400 500 600 700 800 900 1000 Current (mA) © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS73 REV 10A 28 XLAMP ® CXA1304 LED CXA1304-18V THERMAL DESIGN - CONTINUED Maximum R_c-a 100.00 18 V 10.00 Ta = 25 °C Ta = 55 °C 1.00 Ta = 85 °C Ta = 105 °C 0.10 0.01 100 150 200 250 300 350 400 450 500 Current (mA) CXA1304-36V Maximum R_c-a 100.00 36 V 10.00 Ta = 25 °C Ta = 55 °C 1.00 Ta = 85 °C Ta = 105 °C 0.10 0.01 50 75 100 125 150 175 200 225 250 Current (mA) © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS73 REV 10A 29 XLAMP ® CXA1304 LED NOTES Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs. Lumen Maintenance Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. REACh Compliance REACh substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative to insure you get the most up-to-date REACh Declaration. REACh banned substance information (REACh Article 67) is also available upon request. UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS73 REV 10A 30 XLAMP ® CXA1304 LED PACKAGING CXA1304 LEDs are packaged in trays of 20. Five trays are sealed in an anti-static bag and placed inside a carton, for a total of 100 LEDs per carton. Each carton contains 100 LEDs from the same performance bin. Dimensions are in inches. REV 5.875 4 5 5.875 DESC. 6 NOTICE FIDENTIAL. THIS PLOT AND THE INFORMATION D WITHIN ARE THE PROPRIETARY AND TIAL INFORMATION OF CREE, INC. THIS PLOT NSENT E COPIED, REPRODUCED OR DISCLOSED TO ANY IZED PERSON WITHOUTTHE WRITTEN CONSENT C. REV CHK. DESC. Tolerances:DATE ±.13BY CHK. x° ±1° 2 R.375 4 3 1 2 1 .562 .562 5.875 BY 3 R.375 5 DATE 5.875 R .375 .875 .875 R.375 5.875 .875 .875 5.875 .875 .38 .38 .58 PATENT LABEL IS LOCATED WITH CREE ON LABEL UNDERSIDE OF CARTON BIN CODE, QTY, LOT# SECTION C-C TH CREE BIN .875LABEL PATENT OF NOT ANTITY, LOTIS# LOCATED ON UNDERSIDEDO THIS DRAWING CONTAINS PROPRIETARY DESIGN INFORMATION .38 .875ALONG WITH THE PRODUCT OR PRODUCTS AND REMAINS REPRESENTED HEREIN THE PROPERTY OF TEK PAK, INCORPORATED. THIS DOCUMENT AND THE INFORMATION IT CONTAINS DWG.TITLE MAY NOT BE COPIED, TRANSMITTED, OR USED BY ANY THIRD PARTY WITHOUT THE EXPRESS WRITTEN APPROVAL OF TEK PAK, INCORPORATED. SECTION C-C SCALE CARTON DWG. .38 THIS DRAWING CONTAINS PROPRIETARY DESIGN INFORMATION BAG AND REMAINS ALONG WITH THE PRODUCT OR PRODUCTS REPRESENTED HEREIN THE PROPERTY OF TEK PAK, INCORPORATED. THIS DOCUMENT AND THE INFORMATION IT CONTAINS DWG.TITLE MAY NOT BE COPIED, TRANSMITTED, OR USED BY ANY THIRD PARTY WITHOUT THE EXPRESS WRITTEN APPROVAL OF TEK PAK, INCORPORATED. PART DRAWING PART DRAWING BAG UNLESS OTHERWISE NOTED ALL DATE: DR. BY: CHK. BY: 1.000 ARE AS FOLLOWS: DATE: DO NOT 4-3-13 TOLERANCES SIZE SCALE: DR. BY: SCALE DWG. KJS 022490-00 UNLESS OTHERWISE NOTED ALL TOLERANCES ARE AS FOLLOWS: FRACT ±1/64 X.X" ±.030 X.0mm ±.75mm ANGLES ±0°-30' X.XX" ±.015 X.Xmm ±.30mm DRAFT ±1° X.XXX" ±.005 X.XXmm ±.10mm CHK. BY: B FRACT ±1/64 X.X" DWG. ±.030 NO. X.0mm ±.75mm ANGLES ±0°-30' X.XX" ±.015 X.Xmm ±.30mm DRAFT ±1° X.XXX" ±.005 X.XXmm ±.10mm SHEET 2 OF 2 4-3-13 KJS SIZE B SCALE: 1.000 DWG. NO. 022490-00 SHEET 2 OF 2 L IS LOCATED IDE OF COVER LABEL WITH CREE BIN CODE, QTY, LOT# LABEL WITH CREE BIN CODE, QUANTITY, LOT # LABEL WITH CREE BIN CODE, QUANTITY, LOT # UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS & BEFORE FINISH. TOLERANCE UNLESS SPECIFIED: LABEL WITH CREE BIN CODE, QTY, LOT# .X ± .XX ± .XXX ± X° ± THIRD ANGLE PROJECTION WITH CREE BIN 6 QUANTITY, LOT # 0.1 .05 .005 1° FOR SHEET METAL PARTS ONLY .X ± .06 .XX ± .03 .XXX DRAWN ± .010 BY X° ± 2° UNLESS OTHERWISE SPECIFIED 5 4 DIMENSIONS ARE IN 3 MILLIMETERS & BEFORE FINISH. TOLERANCE UNLESS SPECIFIED: CHECK © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered and APPROVED .X ± trademarks, 0.1 .XXUL logo ± .05 the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the are registered .XXX ± .005 trademarks of UL LLC. THIRD ANGLE PROJECTION MATERIAL X° ± DRAWN BY DATE CHECK DATE APPROVED DATE Fax (919) 313-5 CXA15XX_DATASHEET MATERIAL SIZE FINAL PROTECTIVE FINISH DATE DATE SCALE C DRAWING NO. CXA15XX_DATASHEET_BAG2013 SHEET 0.500 OF 4600 Silicon Drive 1 27703 Durham, N.C 2 Phone (919) 361-4770 DATE TITLE CLD-DS73 REV 10A 31 Fax (919) 313-5303 CXA15XX_DATASHEET SIZE FINAL PROTECTIVE FINISH Phone (919) 361 TITLE 1 ° FOR SHEET METAL PARTS ONLY .X ± .06 4600 Silicon Dri Durham, N.C 27 DRAWING NO. CXA15XX_DATASHEET_BAG2013
物料型号:CREE XLamp® CXA1304 LED阵列
器件简介: - 该LED阵列属于CREE的XLamp®系列,是一款高通量、多芯片阵列,具有较小的尺寸和易于使用的特性。 - 它具有高可靠性,适用于定向和非定向照明应用,如灯具改造和照明设计。
引脚分配:文档中未明确列出具体的引脚分配图,但提到了顶侧焊接连接。
参数特性: - 视场角度:115° - 静电抗电压:至少8000V (HBM per Mil-Std-883D) - 直流正向电流:9V时最大1000mA,18V时最大500mA,36V时最大250mA - 反向电流:小于0.1mA - 正向电压:随温度和电流变化
功能详解: - 提供了不同色温(CCT)和颜色一致性等级的EasyWhite®和ANSI白色选项。 - 有多种CRI(色彩还原指数)选项,包括70、80、90和93。 - 符合NEMA SSL-3 2011标准通量箱,RoHS和REACh合规,UL®认可组件。
应用信息: - 适用于照明设计,包括灯具改造和照明设计。
封装信息: - 封装尺寸和公差在文档中有详细描述,但未提供具体封装类型。
CXA1304-0000-000C0HB240H 价格&库存
很抱歉,暂时无法提供与“CXA1304-0000-000C0HB240H”相匹配的价格&库存,您可以联系我们找货
