LCGH9RM-KZLZ-1
LCGH9RM-KZLZ-1
    AMSOSRAM(艾迈斯半导体)
    SMD
    LEDCOBOSTARGREEN550NMSQUARE
LCGH9RM-KZLZ-1 数据手册
2012-05-23 OSRAM OSTAR Projection Cube Datasheet Version 1.0 LCG H9RM OSRAM OSTAR Projection Cube is a new high flux LED for slim designs especially for Projection applications OSRAM OSTAR Projection Cube ist eine neue, hoch effiziente Lichtquelle für platzsparende Designs speziell für Projektionsanwendungen Features: • Package: SMD epoxy package • Technology: ThinGaN (UX:3) • Color: Cx = 0.318, Cy = 0.642 acc. to CIE 1931 Besondere Merkmale: • Gehäusetyp: SMD Epoxid Gehäuse • Technologie: ThinGaN (UX:3) • Farbe: Cx = 0.318, Cy = 0.642 acc. to CIE 1931 (konvertiertes grün) im Bereich λ = 500 ... 600 nm; 0.32 / 0.54 für den gesamten Spektralbereich • ESD-Festigkeit: 8 kV nach JESD22-A114-F (converted green) within λ = 500 ... 600 nm; 0.32 / 0.54 for full spectral range • ESD-withstand voltage: 8 kV acc. to JESD22-A114-F • Viewing angle at 50 % IV: 120° • Abstrahlwinkel bei 50 % IV: 120° Applications Anwendungen • Projection • Projektion 2012-05-23 1 Version 1.0 LCG H9RM Ordering Information Bestellinformation Luminous Flux 1) page Type Typ Lichtstrom 1) Seite 22 22 Ordering Code Bestellnummer IF = 350 mA ΦV [lm] LCG H9RM-KZLZ-1 Note: 97 ... 180 Q65111A1779 The above Type Numbers represent the order groups which include only a few brightness groups (see page 5 for explanation). Only one group will be shipped on each packing unit (there will be no mixing of two groups on each packing unit). E. g. LCG H9RM-KZLZ-1 means that only one group KZ, LX, LY, LZ will be shippable for any packing unit. In order to ensure availability, single brightness groups will not be orderable. In a similar manner for colors where color chromaticity coordinate groups are measured and binned, single groups will be shipped on any one packing unit. LCG H9RM-KZLZ-1 means that the device will be shipped within the specified limits as stated on page 6 In order to ensure availability, single color chromaticity groups groups will not be orderable (see page 6 for explanation). Anm.: Die oben genannten Typbezeichnungen umfassen die bestellbaren Selektionen. Diese bestehen aus wenigen Helligkeitsgruppen (siehe Seite 5 für nähere Informationen). Es wird nur eine einzige Helligkeitsgruppe pro Verpackungseinheit geliefert. Z. B. LCG H9RM-KZLZ-1 bedeutet, dass in einer Verpackungseinheit nur eine der Helligkeitsgruppen KZ, LX, LY, LZ enhalten ist. Um die Liefersicherheit zu gewährleisten, können einzelne Helligkeitsgruppen nicht bestellt werden. Gleiches gilt für die Farben, bei denen Farbortgruppen gemessen und gruppiert werden. Pro Verpackungseinheit wird nur eine Farbortgruppe geliefert. Z.B. LCG H9RM-KZLZ-1 bedeutet, dass in einer Verpackungseinheit nur eine der Farbortgruppen enthalten ist (siehe Seite 6 für nähere Informationen). LCG H9RM-KZLZ-1 bedeutet, dass das Bauteil innerhalb der auf Seite 6 spezifizierten Grenzen geliefert wird. Um die Liefersicherheit zu gewährleisten, können einzelne Farbortgruppen nicht bestellt werden. 2012-05-23 2 Version 1.0 LCG H9RM Maximum Ratings Grenzwerte Parameter Symbol Values Bezeichnung Symbol Werte Unit Einheit Operating temperature range Betriebstemperatur Top -40 ... 100 °C Storage temperature range Lagertemperatur Tstg -40 ... 100 °C Junction temperature Sperrschichttemperatur Tj 150 °C Forward current Durchlassstrom (TS = 25 °C) IF 100 ... 500 mA Forward current pulsed Durchlassstrom gepulst (D = 0.5; f = 120 Hz; TS = 25 °C) IF pulse 1000 mA Reverse voltage Sperrspannung (TS = 25 °C) VR 2012-05-23 not designed for reverse operation V 3 Version 1.0 LCG H9RM Characteristics (TS = 25 °C; IF = 350 mA) Kennwerte Parameter Symbol Values Bezeichnung Symbol Werte Chromaticity coordinates acc. to CIE 1931 2) page 22 Farbkoordinaten nach CIE 1931 2) Unit Einheit (typ.) (typ.) Cx Cy 0.318 0.642 - (typ.) 2ϕ 120 ° (min.) (typ.) (max.) VF VF VF 3.00 3.30 4.00 V V V IR not designed for reverse operation Seite 22 (within λ = 500 ... 600 nm) Viewing angle at 50 % IV Abstrahlwinkel bei 50 % IV Forward voltage 3) page 22 Durchlassspannung 3) Seite 22 Reverse current Sperrstrom Partial Flux acc. CIE 127:2007 Partieller Fluss (typ.) ΦE/V, 120° Radiating surface Abstrahlende Fläche (typ.) Acolor Real thermal resistance junction / solder point 4) page 22 Realer Wärmewiderstand Sperrschicht / Lötpad 4) Seite 22 (typ.) (max.) "Electrical" thermal resistance junction / solder point 4) page 22 "Elektrischer" Wärmewiderstand Sperrschicht / Lötpad 4) Seite 22 (with efficiency ηe = 29 %) (typ.) (max.) 2012-05-23 0.77 0.72 x 0.72 mm2 Rth JS real Rth JS real 20 25 K/W K/W Rth JS el Rth JS el 14 18 K/W K/W 4 Version 1.0 LCG H9RM Brightness Groups Helligkeits-Gruppierungsschema Group Luminous Flux 1) page Luminous Flux 1) page Luminous Intensity 5) 22 22 page 22 Gruppe Lichtstrom 1) Seite 22 Lichtstrom 1) Seite 22 Lichtstärke 5) Seite (min.) ΦV [lm] (max.) ΦV [lm] (typ.) IV [cd] KZ 97 112 35 LX 112 130 40 LY 130 150 45 LZ 150 180 55 22 Note: The standard shipping format for serial types includes either a lower family group, an upper family group or a grouping of all individual brightness groups of only a few brightness groups. Individual brightness groups cannot be ordered. Anm.: Die Standardlieferform von Serientypen beinhaltet entweder eine untere Familiengruppe, eine obere Familiengruppe oder eine Sammelgruppe, die aus nur wenigen Helligkeitsgruppen bestehen. Einzelne Helligkeitsgruppen sind nicht bestellbar. Chromaticity coordinate groups 2) page Farbortgruppen 2) Seite 22 22 within λ = 500 ... 600 nm 0,650 0,90 Cy Cy 0,80 0,70 0,60 0,50 0,640 0,40 0,30 0,20 0,10 0,00 0,00 2012-05-23 0,10 0,20 0,30 0,40 0,50 0,60 Cx 0,630 0,310 0,70 Coordinates in reference to CIE 1931 (cx cy) 5 0,320 0,330 Cx Version 1.0 LCG H9RM Color Chromaticity Groups 2) page Farbortgruppen 2) Seite 22 Group Gruppe 1 Cx 22 Cy 0.3123 0.6378 0.3190 0.6478 0.3223 0.6311 0.3290 0.6411 Group Name on Label Gruppenbezeichnung auf Etikett Example: KZ-1 Beispiel: KZ-1 Brightness Helligkeit Wavelength Wellenlänge KZ 1 Note: No packing unit / tape ever contains more than one group for each selection. Anm.: In einer Verpackungseinheit / Gurt ist immer nur eine Gruppe für jede Selektion enthalten. 2012-05-23 6 Version 1.0 LCG H9RM Relative Spectral Emission - V(λ) = Standard eye response curve 5) page 22 , 1) page 22 Relative spektrale Emission - V(λ) = spektrale Augenempfindlichkeit 5) Seite 22 , 1) Seite 22 Φrel = f (λ); TJ = 25 °C; IF = 350 mA Φrel 1,0 : Vλ : converted green 0,9 0,8 0,7 0,6 0,5 0,4 0,3 0,2 0,1 0,0 400 450 Radiation Characteristics 5) page Abstrahlcharakteristik 5) Seite 22 500 550 600 650 700 750 800 λ [nm] 22 Irel = f (ϕ); TJ = 25 °C 40˚ 30˚ 20˚ 10˚ 0˚ ϕ 50˚ OHL01660 1.0 0.8 0.6 60˚ 0.4 70˚ 0.2 80˚ 0 90˚ 100˚ 1.0 2012-05-23 0.8 0.6 0.4 0˚ 20˚ 7 40˚ 60˚ 80˚ 100˚ 120˚ Version 1.0 LCG H9RM Relative partial flux 5) page 22 Relativer zonaler Lichtstromanteil 5) Seite 22 ΦV(2ϕ)/ΦV(180°) = f (ϕ); TJ = 25 °C ΦV(2ϕ) 1,0 ΦV(180°) 0,9 0,8 0,7 0,6 0,5 0,4 0,3 0,2 0,1 0,0 0 10 20 30 40 50 60 70 80 90 100 110 120 130 140 150 160 170 180 2*ϕ [°] Relative cumulated Luminous flux 5) page 22 , 1) page 22 Relativer kummulierter Lichtstrom 5) Seite 22 , 1) Seite 22 Rel. cum. flux Φvrel-cum ΦVrel - cum = f(λ), TJ = 25 °C, IF = 350 mA 1,0 0,9 0,8 0,7 0,6 0,5 0,4 0,3 0,2 0,1 0,0 2012-05-23 400 450 500 550 600 8 650 700 750 800 λ [nm] Version 1.0 LCG H9RM Forward Current 5) page 22 Durchlassstrom 5) Seite 22 Relative Luminous Flux 5) page 22 , 6) page Relativer Lichtstrom 5) Seite 22 , 6) Seite 22 IF = f (VF); TJ = 25 °C ΦV/ΦV(350 mA) = f(IF); TJ = 25 °C IF [mA] Φv 2.5 Φv(350 mA ) 18UI10010004 1000 22 18IB210010004 900 2.0 800 700 1.5 600 500 1.0 400 300 0.5 200 100 2.6 2.8 3.0 3.2 3.4 3.6 0.0 3.8 UF [V] 2012-05-23 200 400 600 800 1000 IF [mA] 9 Version 1.0 LCG H9RM Chromaticity Coordinate Shift 5) page Farbortverschiebung 5) Seite 22 22 Chromaticity Coordinate Shift 5) page Farbortverschiebung 5) Seite 22 ΔCx, ΔCy = f(IF); TJ = 25 °C within λ = 500 ... 600 nm ΔCx, ΔCy = f(IF); TJ = 25 °C full spectral range 18IDC10010004 ΔCx 0.03 ΔCy 0.02 0.01 0.01 0.00 0.00 -0.01 -0.01 -0.02 -0.02 200 400 600 800 -0.03 1000 IF [mA] 2012-05-23 18IDC10010004 ΔCx 0.03 ΔCy : ΔCx : ΔCy 0.02 -0.03 22 : ΔCx : ΔCy 200 400 600 800 1000 IF [mA] 10 Version 1.0 LCG H9RM Relative Forward Voltage 5) page 22 Relative Vorwärtsspannung 5) Seite Relative Luminous Flux 5) page Relative Lichtstrom 5) Seite 22 22 ΔVF = VF - VF(25°C) = f(Tj); IF = 350 mA ΔUF [V] ΦV/ΦV(25 °C) = f(Tj); IF = 350 mA ΦV ΦV (25°C) 18UT-40120 0.3 22 1,0 0.2 0,8 0.1 0,6 0.0 0,4 -0.1 -0.2 -0.3 -40 -20 0,2 0 0,0 -40 -20 20 40 60 80 100 120 Tj [°C] 2012-05-23 0 20 40 60 80 100 120 Tj [°C] 11 Version 1.0 LCG H9RM Chromaticity Coordinate Shift 5) page Farbortverschiebung 5) Seite 22 22 Chromaticity Coordinate Shift 5) page Farbortverschiebung 5) Seite 22 ΔCx, ΔCy = f(Tj); IF = 350 mA within λ = 500 ... 600 nm ΔCx, ΔCy = f(Tj); IF = 350 mA full spectral range 0,03 ΔCx; ΔCy ΔCx 0.03 ΔCy : Cx : Cy 0,02 0.02 0,01 0.01 0,00 0.00 -0,01 -0.01 -0,02 -0.02 -0,03 -40 -20 0 20 40 60 80 LCG H9RM : Δ Cx : Δ Cy -0.03 -40 -20 0 20 40 60 80 100 120 100 120 Tj [°C] Tj [°C] 2012-05-23 22 12 Version 1.0 LCG H9RM Max. Permissible Forward Current 7) page 22 Maximal zulässiger Durchlassstrom 7) Seite 22 IF = f (T) IF [mA] 500 400 300 200 100 0 0 2012-05-23 20 40 60 80 100 120 TS [°C] 13 Version 1.0 LCG H9RM Package Outline 8) page 22 Maßzeichnung 8) Seite 22 Note For dimension „A“ please refer to page 4 Anm. Die Angabe des Maßes „A“ bezieht sich auf die Angabe auf Seite 4. Approximate Weight: 22 mg Gewicht: 22 mg ESD information: LED is protected by ESD device which is connected in parallel to LED-Chip. ESD Information: Die LED enthält ein ESD-Bauteil, das parallel zum Chip geschalten ist. 2012-05-23 14 Version 1.0 LCG H9RM Recommended Solder Pad 8) page 22 Empfohlenes Lötpaddesign 8) Seite 22 2012-05-23 Reflow soldering Reflow-Löten 15 Version 1.0 LCG H9RM Reflow Soldering Profile Reflow Lötprofil Preconditioning: JEDEC Level 2 acc. to J-STD-020D.01 OHA04525 300 ˚C T 250 Tp 245 ˚C 240 ˚C tP 217 ˚C 200 tL 150 tS 100 50 25 ˚C 0 50 0 100 150 200 250 s 300 t OHA04612 Profil-Charakteristik Profile Feature Symbol Symbol Pb-Free (SnAgCu) Assembly Minimum Ramp-up Rate to Preheat*) 25 °C to 150 °C Time tS TSmin to TSmax Ramp-up Rate to Peak* TSmax to TP tS 60 ) Recommendation Maximum 2 3 100 120 2 3 Einheit Unit K/s s K/s Liquidus Temperature TL 217 Time above Liquidus temperature tL 80 100 s Peak Temperature TP 245 260 °C Time within 5 °C of the specified peak temperature TP - 5 K tP 20 30 s 3 6 K/s 10 Ramp-down Rate* TP to 100 °C 480 Time 25 °C to TP All temperatures refer to the center of the package, measured on the top of the component * slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range 2012-05-23 °C 16 s Version 1.0 Method of Taping 8) page Gurtung 8) Seite 22 2012-05-23 LCG H9RM 22 17 Version 1.0 LCG H9RM Tape and Reel Gurtverpackung 8 mm tape with 2000 pcs. on ∅ 180 mm reel W1 D0 P0 A N F W E 13.0 ±0.25 P2 Label P1 Direction of unreeling Direction of unreeling W2 Gurtvorlauf: 400 mm 400 mm Leader: Gurtende: Trailer: 160 mm 160 mm OHAY0324 Tape dimensions in mm (inch) Tape dimensions in mm (inch) W P0 P1 P2 D0 E F 8 +0.3/-0.1 4 ± 0.1 (0.157 ± 0.004) 2 ± 0.05 (0.079 ± 0.002) or 4 ± 0.1 (0.157 ± 0.004) 2 ± 0.05 (0.079 ± 0.002) 1.5 ± 0.1 (0.059 + 0.004) 1.75 ± 0.1 (0.069 ± 0.004) 3.5 ± 0.05 (0.217 ± 0.002) Reel dimensions in mm (inch) Reel dimensions in mm (inch) A W Nmin W1 W2max 180 (7) 8 (0.315) 60 (2.362) 8.4 + 2 (0.331 + 0.079) 14.4 (0.567) 2012-05-23 18 Version 1.0 LCG H9RM Barcode-Product-Label (BPL) Barcode-Produkt-Etikett (BPL) OSRAM Opto BIN1: XX-XX-X-XXX-X LX XXXX Semiconductors RoHS Compliant (6P) BATCH NO: 1234567890 ML Temp ST 2 260 °C R (1T) LOT NO: 1234567890 (9D) D/C: 1234 Pack: R18 DEMY 022 B_R999_1880.1642 R (X) PROD NO: 123456789(Q)QTY: 9999 (G) GROUP: XX-XX-X-X OHA04563 Dry Packing Process and Materials Trockenverpackung und Materialien Moisture-sensitive label or print L VE l LE k, If see labe code blan bar ). (RH . RH idity hum 0% e tive ˚C/6 red kag S rela 30 s pac _ < infra IVE of TOR rs tain 90% to ak SIT rs < ns ed (pe UC e). or rs con Hou SEN rs Hou ND and ject ditio cod ˚C, 72 sing Hou e 5 bag E 48 ˚C sub Hou con ± s UR ICO ces 24 6 dat 40 be time ˚C ory ThiISTSEM r pro < time r 23 time at t will ˚C). l with fact r ent MO . Floo time TO at at r Floo l ths tha tica d ival ure OP Floo 4 if: rea w Floo labe mon iden 5 ced equ el ices g, n e 5a is el belo or 24 pro 6 Lev e dev : ntin el whe cod e , w, e Lev el see e bag Lev l dat mou bak bar ned stur e Lev reflo 10% led stur e time sea for ore> ope e Moi r see stur k, is . sea is has k, Moi stur bef d 033 Moi in Floo RH blan Moi or-p blan in bag Car ing, r TD(if life . If r lf J-S thisvapp. d with 10%bak or Yea _ eks rs < r w, icat met 1 Yea tem d, She at nte uire not > y 1 WeHou DEC Afte Ind 4 uire reflo is bod Mou red req /JE time 168 req : 2b r a) Sto ices idity time is IPC r or time b) ned Floo r Hum ing ce time Dev 2a e r Floo a) ope 3. b) bakren Floo 1 l dat Floo If 2 refe time el 4. 2a el sea 3 Lev el and e Lev el Bag e e Lev stur e Lev Dat stur e Moi stur Moi stur Moi Moi TI U A C 1. Barcode label N O O S R A M 2. Humidity indicator Barcode label Please check the HIC immidiately after bag opening. Discard if circles overrun. Avoid metal contact. Do not eat. Comparator check dot WET If wet, examine units, if necessary bake units 15% If wet, examine units, if necessary bake units 10% 5% If wet, parts still adequately dry. change desiccant Humidity Indicator MIL-I-8835 AM Desiccant OSR OHA00539 Note: Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card. Regarding dry pack you will find further information in the internet and in the Short Form Catalog in chapter “Tape and Reel” under the topic “Dry Pack”. Here you will also find the normative references like JEDEC. Anm.: Feuchteempfindliche Produkte sind verpackt in einem Trockenbeutel zusammen mit einem Trockenmittel und einer Feuchteindikatorkarte. Bezüglich Trockenverpackung finden Sie weitere Hinweise im Internet und in unserem Short Form Catalog im Kapitel “Gurtung und Verpackung” unter dem Punkt “Trockenverpackung”. Hier sind Normenbezüge, unter anderem ein Auszug der JEDEC-Norm, enthalten. 2012-05-23 19 Version 1.0 LCG H9RM Transportation Packing and Materials Kartonverpackung und Materialien Barcode label MY DE 8 Q- 1 R1 lti LS TO Y T6 PL 76 1+ Mu POU GR 44 D/C ) (9D 4 20 23 Y: QT H1 TC BA 3G ) : 12 (6P 00 : 01 998 021 210 O Se SR mi AM co nd O uc pt to o H rs NO : ). 5 14 2 110 0 (X) PR OD NO : (1T ) LO T NO see labe (G) l k, N O TI U A C (Q) L VE LE code (RH blan If y bar . idit RH hum 60% e tive d ˚C/ kag rela are 30 E S s _ < infr pac OR of tainITIV 90% to ak urs CT < e). or urs ted (pe ons con NS Ho g urs SE DU Ho and jec diti cod ˚C, 72 sin Ho urs e 5 bag E ON 48 ˚C sub e Ho con ± s UR ces 24 6 dat e MIC 40 be tim ˚C e ThiISTSE pro < tory tim . or t with 23 tim e at t will ˚C) or fac MO . Flo al len tim TO s at or at Flo d or iva ure el nth s tha OP ntic Flo 4 if: rea Flo , lab ow mo ice equ ide 5 ced el e 5a is el ingen bel or 24 pro 6 Lev e dev, : el cod e , unt wh Lev el re ow see bag Lev l dat re mo bak e bar ned Lev refl istu 10% re led tim sea for istu ore> re ope e Mo see 3 istu is or . sea is has Mo nk, bef istu nk, Flo , rd -03 Mo RH bla in Mo or-p bla bag ingCa r TD life (if If with t. r lf vapp. 10%baktor J-S this Yea , _ eks < r ed ica med, C 1 urs Yea tem She ow at uire not > y 1 WeHo unt DE Afte Ind 1. e 4 uire refl red req 2. bod Mo e ity is /JE tim s 168 req : e 2b a) Sto tim or mid is IPC tim e vice or b) or ned Flo Hu tim ing ce or De e 2a Flo a) ope or 3. b) bakren Flo e 1 l dat Flo If 2 el refe tim 2a 4. el sea 3 Lev el and Lev el re Bag te Lev re Lev istu Da re istu re Mo istu Mo istu Mo Mo P: Muster ED Bin Bin 1: Bin 2: P-1 3: Q-1 -20 ML -20 2 Tem 2a 220 3 240 p ST Ad 260 C R C R0 diti R ona C RT PA 77 l TE CK VA XT R: Barcode label MY DE T6 PL 76 8 1 R1 lti LS TO Y 1+ QP- Mu 8 : 01 99 D/C ) O SR AM 21 00 (9D 00 21 : 4 20 23 QT O H1 (Q) TC 3G BA ) : 12 5 (X) PR OD NO : (1T ) 11 00 LO T 14 2 NO (6P Y: Se SR m A ico M nd O uc pt to o H rs NO 44 (G) GR OU P: Muster ED Bin Bin 1: Bin 2: P-1 3: Q-1 -20 ML -20 2 Te 2a 220 mp 3 240 ST Ad 260 C R C R0 diti R ona C RT PA 77 l TE CK VA XT R: in Packing Sealing label OHA02044 Dimensions of transportation box in mm (inch) Width / Breite Length / Länge Height / Höhe 200 ±5 (7,874 ±0,196) 195 ±5 (7,677 ±0,1968) 30 ±5 (1,181 ±0,196) Notes Hinweise The evaluation of eye safety occurs according to the standard IEC 62471:2006 ("photobiological safety of lamps and lamp systems"). Within the risk grouping system of this CIE standard, the LED specified in this data sheet fall into the class Low risk (exposure time 100 s). Under real circumstances (for exposure time, eye pupils, observation distance), it is assumed that no endangerment to the eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light sources have a high secondary exposure potential due to their blinding effect. As is also true when viewing other bright light sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation. Die Bewertung der Augensicherheit erfolgt nach dem Standard IEC 62471:2006 ("photobiological safety of lamps and lamp systems"). Im Risikogruppensystem dieser CIE- Norm erfüllen die in diesem Datenblatt angegebenen LEDs folgende Gruppenanforderung - Low risk (Expositionsdauer 100s). Unter realen Umständen (für Expositionsdauer, Augenpupille, Betrachtungsabstand) geht damit von diesen Bauelementen keinerlei Augengefährdung aus. Grundsätzlich sollte jedoch erwähnt werden, dass intensive Lichtquellen durch ihre Blendwirkung ein hohes sekundäres Gefahrenpotenzial besitzen. Nach einem Blick in eine helle Lichtquelle (z.B. Autoscheinwerfer), kann ein temporär eingeschränktes Sehvermögen oder auch Nachbilder zu Irritationen, Belästigungen, Beeinträchtigungen oder sogar Unfällen führen. 2012-05-23 20 Version 1.0 LCG H9RM Disclaimer Disclaimer Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version in the Internet. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Components used in life-support devices or systems must be expressly authorized for such purpose! Critical components* may only be used in life-support devices** or systems with the express written approval of OSRAM OS. Bitte beachten! Lieferbedingungen und Änderungen im Design vorbehalten. Aufgrund technischer Anforderungen können die Bauteile Gefahrstoffe enthalten. Für weitere Informationen zu gewünschten Bauteilen, wenden Sie sich bitte an unseren Vertrieb.Falls Sie diese Datenblatt ausgedruckt oder heruntergeladen haben, finden Sie die aktuellste Version im Internet. Verpackung Benutzen Sie bitte die Ihnen bekannten Recyclingwege. Wenn diese nicht bekannt sein sollten, wenden Sie sich bitte an das nächstgelegene Vertriebsbüro. Wir nehmen das Verpackungsmaterial zurück, falls dies vereinbart wurde und das Material sortiert ist. Sie tragen die Transportkosten. Für Verpackungsmaterial, das unsortiert an uns zurückgeschickt wird oder das wir nicht annehmen müssen, stellen wir Ihnen die anfallenden Kosten in Rechnung. Bauteile, die in lebenserhaltenden Apparaten und Systemen eingesetzt werden, müssen für diese Zwecke ausdrücklich zugelassen sein! Kritische Bauteile* dürfen in lebenserhaltenden Apparaten und Systemen nur dann eingesetzt werden, wenn ein schriftliches Einverständnis von OSRAM OS vorliegt. *) A critical component is a component used in a life-support device or system whose failure can reasonably be expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that device or system. **) Life support devices or systems are intended(a) to be implanted in the human body,or(b) to support and/or maintain and sustain human life.If they fail, it is reasonable to assume that the health and the life of the user may be endangered. 2012-05-23 *) Ein kritisches Bauteil ist ein Bauteil, das in lebenserhaltenden Apparaten oder Systemen eingesetzt wird und dessen Defekt voraussichtlich zu einer Fehlfunktion dieses lebenserhaltenden Apparates oder Systems führen wird oder die Sicherheit oder Effektivität dieses Apparates oder Systems beeinträchtigt. **) Lebenserhaltende Apparate oder Systeme sind für (a) die Implantierung in den menschlichen Körper oder (b) für die Lebenserhaltung bestimmt. Falls Sie versagen, kann davon ausgegangen werden, dass die Gesundheit und das Leben des Patienten in Gefahr ist. 21 Version 1.0 LCG H9RM Glossary Glossar 1) 1) Brightness: Brightness values are measured during a current pulse of typical 25 ms, with an internal reproducibility of +/- 8 % and an expanded uncertainty of +/- 11 % (acc. to GUM with a coverage factor of k = 3). 2) Strompulses einer typischen Dauer von 25 ms, mit einer internen Reproduzierbarkeit von +/- 8 % und einer erweiterten Messunsicherheit von +/- 11 % gemessen (gemäß GUM mit Erweiterungsfaktor k = 3). 2) Farbortgruppen: Farbkoordinaten werden während eines Strompulses einer typischen Dauer von 25 ms, mit einer internen Reproduzierbarkeit von +/- 0,005 und einer erweiterten Messunsicherheit von +/- 0,01 gemessen (gemäß GUM mit Erweiterungsfaktor k = 3). Forward Voltage: The forward voltage is measured during a current pulse of typical 8 ms, with an internal reproducibility of +/- 0,05 V and an expanded uncertainty of +/- 0,1 V (acc. to GUM with a coverage factor of k=3). 3) Durchlassspannung: Vorwärtsspannungen Thermal Resistance: Rth max based on statistic 4) Chromaticity coordinate groups: Chromaticity coordinates are measured during a current pulse of typical 25 ms, with an internal reproducibility of +/- 0,005 and an expanded uncertainty of +/- 0,01 (acc. to GUM with a coverage factor of k = 3). 3) 4) werden während eines Strompulses einer typischen Dauer von 8 ms, mit einer internen Reproduzierbarkeit von +/- 0,05 V und einer erweiterten Messunsicherheit von +/- 0,1 V gemessen (gemäß GUM mit Erweiterungsfaktor k=3). values (6ó) 5) Helligkeit: Helligkeitswerte werden während eines Wärmewiderstand: Rth max Typical Values: Due to the special conditions of 5) Typische Werte: Wegen the manufacturing processes of LED, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. auf der besonderen Prozessbedingungen bei der Herstellung von LED können typische oder abgeleitete technische Parameter nur aufgrund statistischer Werte wiedergegeben werden. Diese stimmen nicht notwendigerweise mit den Werten jedes einzelnen Produktes überein, dessen Werte sich von typischen und abgeleiteten Werten oder typischen Kennlinien unterscheiden können. Falls erforderlich, z.B. aufgrund technischer Verbesserungen, werden diese typischen Werte ohne weitere Ankündigung geändert. 6) Relative Brightness Curve: In the range where the line of the graph is broken, you must expect higher brightness differences between single LEDs within one packing unit. 6) Relative Helligkeitskurve: Im 7) Thermal Resistance: RthJA results from mounting on PC board FR 4 (pad size 16mm2 per pad) 7) Wärmewiderstand: RthJA 8) Tolerance of Measure: Dimensions 8) Maßtoleranz: Maße angegeben: mm (inch). are specified as follows: mm (inch). 2012-05-23 basiert statistischen Werten (6ó) 22 gestrichelten Bereich der Kennlinien muss mit erhöhten Helligkeitsunterschieden zwischen Leuchtdioden innerhalb einer Verpackungseinheit gerechnet werden. ergibt sich bei Montage auf PC-Board FR 4 (Padgröße 16mm2 je pad) werden wie folgt Version 1.0 LCG H9RM Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 2012-05-23 23
LCGH9RM-KZLZ-1 价格&库存
很抱歉,暂时无法提供与“LCGH9RM-KZLZ-1”相匹配的价格&库存,您可以联系我们找货
