FFMD-10-D-02.00-01
FFMD-10-D-02.00-01
    SAMTEC(申泰)
FFMD-10-D-02.00-01 数据手册
REVISION AF FFMD-XX-X-XX.XX-01-X-X-XXX FIG 1 (FFMD-10-D-XX.XX-01-X SHOWN) OPTION -RW: REVERSE WIRING -BXX: BREAKOUT OPTION -O: OUTSIDE REVERSED -M: MIDDLE REVERSED -R: REVERSE -DXX: DAISY CHAIN (MINIMUM 2.00[50.8], 1.00[25.4] INCREMENTS) -SR: STRAIN RELIEF (NOT AVAILABLE WITH -O, -M, -R, -DXX OR -BXX) (SOLD AS ASSEMBLIES ONLY) No OF POSITIONS -03 TO -25 C DO NOT SCALE FROM THIS PRINT END ASSEMBLY -D: DOUBLE END -S: SINGLE END *-T: TRANSFER END XX.XX [XX.X x 25.4] 1% (SEE NOTE 7 & 9) ASSEMBLY LENGTH (2.00[50.8] MINIMUM) C LEAD STYLE (No. OF POS x .050) [1.27])+.165[4.19] REF TRANSFER OPTION -N: SOCKET HAS NOTCH POLARIZATION (-T END ASSEMBLY ONLY) (LEAVE BLANK FOR -S AND -D END OPTIONS) (NOT AVAILABLE ON POSITIONS -02 THRU -04) PLATING OPTIONS LEAVE BLANK FOR STANDARD (USE T-1S57-01-T AND C-67-L) -L: SELECTIVE LIGHT GOLD (USE T-1S57-01-L AND C-67-L) -F: FLASH SELECTIVE GOLD (USE T-1S57-01-F AND C-67-F) -S: SELECTIVE GOLD (USE T-1S57-01-S AND C-67-S) C .120 3.05 REF *16-25 POS TRANSFER END STRAIN RELIEF NOT RELEASED FOR PRODUCTION FMC-XX-D FLUSH TO .010 0.25 MAX CABLE OVERHANG (SEE NOTE 7) FIG 2 COLORED WIRE TO SIDE OF FIRST POS INDICATOR (FFMD-10-S-XX.XX-01-X SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) 2 C C .200±.010 5.08±0.25 T-1S57-01-X XX.XX[XX.XX x 25.4] ±1% (SEE NOTE 7 & 9) 3 FMB-XX-D-XX NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. FFSD ASSEMBLY TO BE USED FOR TRANSFER END ONLY. C 3. ALL ASSEMBLIES TO BE 100% ELECTRONICALLY TESTED FOR SHORTS AND OPENS. 4. ALL ASSEMBLIES TO BE 100% HI-POT TESTED AT 630V. 5. STRAIN RELIEF TO WITHSTAND 5LB[22N] STRAIGHT PULL. 6. FFMD CABLE ASSEMBLIES ARE LEAD FREE. 7.WHEN CUTTING CABLE TO LENGTH, CONDUCTORS SHOULD NOT EXTEND PAST THE CABLE INSULATION, EXTENDING LESS THAN 25% OF CABLE THICKNESS ON CONSECUTIVE AND LESS THAN 50% OF CABLE THICKNESS ON NON-CONSECUTIVE STRANDS IS CONSIDERED A PROCESS INDICATOR. 8. REFERENCE FFMD-XX-XX-X-XX (AND FFSD-XX-XX-X-N-XX FOR -T OPTION)DRAWING FOR CONNECTOR ASSEMBLY DIMENSIONS AND ITS REQUIREMENTS. 9. FOR LENGTHS LESS THAN 12.5" TOLERANCE SHALL BE +/-.125, ALL OTHER LENGTHS SHALL BE +/-1%. 10. PACKAGE PER IDC STYLE CABLE SECTION OF PACKAGING MANUAL. F:\DWG\MISC\MKTG\FFMD-XX-X-XX.XX-01-X-X-XXX-MKT.SLDDRW .121 3.07 REF C NOTCH DENOTES FIRST POSITION UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01 [.3] 2 .XXX: .005 [.13] .XXXX: .0020 [.051] MATERIAL: * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING INSULATOR: PBT, COLOR: BLACK CONTACT: BeCu TERMINAL: PHOS BRONZE WIRE: 30 AWG, 7/38, TINNED, STRANDED WITH PVC INSULATOR SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: .050 X .050 DOUBLE ROW MALE IDC CABLE ASSEMBLY DWG. NO. FFMD-XX-X-XX.XX-01-X-X-XXX BY: T NEWTON 02/15/2008 SHEET 1 OF 5 REVISION AF FIG 3 FIG 5 (FFMD-10-D-XX.XX-01-X-SR SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) FIG 4 (FFMD-10-X-XX.XX-01-X-RW SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) (FFMD-10-X-XX.XX-01-X-N SHOWN) (SAME AS FIG 1 AND FIG 6, DIFFERENT AS SHOWN) (FOR -T ONLY) (IF OPTION IS SPECIFIED USE FFSD-XX-01-X-N) 02 01 03 COLORED WIRE TO OPPOSITE SIDE OF FIRST POS INDICATOR C (No. OF POS. x .050[1.27]) + .315[8.00] REF NOTCH DENOTES FIRST POSITION XX.XX[XX.X x 25.4] .13[3.2] C .075 1.91 REF .040 1.02 REF .039 1.00 5 C .335±.01 8.51±0.254 FIG 6 4 (FFMD-10-T-XX.XX-01-X-N SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) FIG 7 (FFMD-10-T-XX.XX-01-X-N-B05 SHOWN) (SAME AS FIG 1 AND FIG 6, DIFFERENT AS SHOWN) "XX" = NO. OF CONDUCTORS PER ROW BROKEN OUT FROM THE FIRST POSITION "XX" 5.00[127.0] MAX 2.00[50.8] MIN (MAY BE SMALLER THAN 2.00 ON AN ASSEMBLY LENGTH OF 2.00, MUST BE SPLIT BACK TO THE FIRST CONNECTOR) IN-PROCESS 1 -SR ONLY (XX.XX[XX.X x 25.4] + .4375[11.113]) .125[3.18] C +.006 +0.152 .200 - .003 5.08 - 0.076 IN-PROCESS 2 C -SR ONLY * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. C XX.XX[XX.X x 25.4] .13[3.2] DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\FFMD-XX-X-XX.XX-01-X-X-XXX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: .050 X .050 DOUBLE ROW MALE IDC CABLE ASSEMBLY DWG. NO. FFMD-XX-X-XX.XX-01-X-X-XXX BY: T NEWTON 02/15/2008 SHEET 2 OF 5 FIG 8 REVISION AF FIG 9 (FFMD-10-D-XX.XX-01-X-DXX-O SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) (2.00[50.8] MINIMUM LENGTH, 1.00[25.4] INCREMENTS) (NOT AVAILABLE WITH -R OR -M OPTIONS) XX.00[XX.0 x 25.4] .13[3.2] (MIN 2", SEE CALLOUT OPTION DXX) (FFMD-10-D-XX.XX-01-X-DXX-M SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) (2.00[50.8] MINIMUM LENGTH, 1.00[25.4] INCREMENTS) (NOT AVAILABLE WITH -R OR -O OPTIONS) FIRST POSITION INDICATOR FIRST POSITION INDICATOR OUTSIDE CONNECTOR REVERSED WHEN DAISY CHAINED XX.00[XX.0 x 25.4] .13[3.2] (MIN 2", SEE CALLOUT OPTION DXX) MIDDLE CONNECTOR REVERSED WHEN DAISY CHAINED FIG 11 FIG 10 (FFMD-10-T-XX.XX-01-X-N-DXX-M SHOWN) (SAME AS FIG 1 AND FIG 6, DIFFERENT AS SHOWN) (2.00[50.8] MINIMUM LENGTH, 1.00[25.4] INCREMENTS) (NOT AVAILABLE WITH -R OR -O OPTIONS) (FFMD-10-T-XX.XX-01-X-N-DXX-O SHOWN) (SAME AS FIG 1 AND FIG 6, DIFFERENT AS SHOWN) (2.00[50.8] MINIMUM LENGTH, 1.00[25.4] INCREMENTS) (NOT AVAILABLE WITH -R OR -M OPTIONS) XX.00(XX.0 x 25.4) ±.13[3.2] (MIN 2", SEE CALLOUT OPTION DXX) FIRST POSITION INDICATOR FIRST POSITION INDICATOR XX.00[XX.0 x 25.4] .13[3.2] (MIN 2", SEE CALLOUT OPTION DXX) MIDDLE CONNECTOR REVERSED WHEN DAISY CHAINED * OUTSIDE CONNECTOR REVERSED WHEN DAISY CHAINED PROPRIETARY NOTE DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\FFMD-XX-X-XX.XX-01-X-X-XXX-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: .050 X .050 DOUBLE ROW MALE IDC CABLE ASSEMBLY DWG. NO. FFMD-XX-X-XX.XX-01-X-X-XXX BY: T NEWTON 02/15/2008 SHEET 3 OF 5 REVISION AF FIG 12 FIG 13 (FFMD-10-D-XX.XX-01-DXX-R SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) (2.00[50.8] MINIMUM LENGTH, 1.00[25.4] INCREMENTS) (NOT AVAILABLE WITH -M OR -O OPTIONS) (FFMD-10-D-XX.XX-01-X-DXX) (SAME AS FIG 1, DIFFERENT AS SHOWN) (2.00[50.8] MINIMUM LENGTH, 1.00[25.4] INCREMENTS) BOTH CONNECTORS REVERSED WHEN DAISY CHAINED FIRST POSITION INDICATOR FIRST POSITION INDICATOR XX.00[XX.0 x 25.4] .13[3.2] (MIN 2", SEE CALLOUT OPTION DXX) XX.00[XX.0 x 25.4] .13[3.2] (MIN 2", SEE CALLOUT OPTION DXX) FIG 15 FIG 14 (FFMD-10-T-XX.XX-01-X-N-DXX) (SAME AS FIG 1 AND FIG 6, DIFFERENT AS SHOWN) (2.00[50.8] MINIMUM LENGTH, 1.00[25.4] INCREMENTS) (FFMD-10-T-XX.XX-01-X-N-DXX-R SHOWN) (SAME AS FIG 1 AND FIG 6, DIFFERENT AS SHOWN) (2.00[50.8] MINIMUM LENGTH, 1.00[25.4] INCREMENTS) (NOT AVAILABLE WITH -M OR -O OPTIONS) XX.00[XX.0 x 25.4] .13[3.2] (MIN 2", SEE CALLOUT OPTION DXX) FIRST POSITION INDICATOR FIRST POSITION INDICATOR BOTH CONNECTORS REVERSED WHEN DAISY CHAINED * XX.00[XX.0 x 25.4] .13[3.2] (MIN 2", SEE CALLOUT OPTION DXX) PROPRIETARY NOTE DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\FFMD-XX-X-XX.XX-01-X-X-XXX-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: .050 X .050 DOUBLE ROW MALE IDC CABLE ASSEMBLY DWG. NO. FFMD-XX-X-XX.XX-01-X-X-XXX BY: T NEWTON 02/15/2008 SHEET 4 OF 5 REVISION AF FIG 17 FIG 16 (FFMD-25-T-XX.XX-01-X-N-SR SHOWN) (SAME AS FIG 1 AND FIG 16, DIFFERENT AS SHOWN) (FOR POSITIONS 16-25 ONLY) (FFMD-10-T-XX.XX-01-X-N-SR SHOWN) (SAME AS FIG 1 AND FIG 3, DIFFERENT AS SHOWN) (FOR POSITIONS 2-15 ONLY) *NOT RELEASED FOR PRODUCTION 5 .335±.010 8.51±0.254 C 6 7 8 * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\FFMD-XX-X-XX.XX-01-X-X-XXX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: .050 X .050 DOUBLE ROW MALE IDC CABLE ASSEMBLY DWG. NO. FFMD-XX-X-XX.XX-01-X-X-XXX BY: T NEWTON 02/15/2008 SHEET 5 OF 5
FFMD-10-D-02.00-01 价格&库存
很抱歉,暂时无法提供与“FFMD-10-D-02.00-01”相匹配的价格&库存,您可以联系我们找货
