10064-30-1-0500-007-1-TS
    CNC
10064-30-1-0500-007-1-TS 数据手册
P/N 10064-30-1-0500-0XX-1-TS (Conductor: Tinned strands) (Insulation: FEP Material) UL10064 - FEP Insulated Hook-Up Wire 105°C 30V (30 AWG) CONSTRUCTION: CERTIFICATION & APPROVALS: Tinned Strands, copper conductor, 7/0.100 mm strands. Overall Diameter = 0.60 mm ± 0.05 mm Insulation Thickness: 0.15mm (small AWG's = >Flexibility) UL RATED AWM: Can be used in the USA. UL Subject 758 UL FILE NO:E108485 Printed Markings: “AWM 10064 105℃ 30V E108485 30AWG REIHSING VW-1 ” Passes UL VW-1 Vertical Flame Test. PHYSICAL & ELECTRICAL PROPERTIES: APPLICATIONS: PACKAGING: ENVIRONMENTAL APPROVALS: Rated Temperature: 105℃ ~ -80℃ Rated Voltage: 30V Insulation Potential Strength: 500 VAC/min Flexibility: hard FEP material, is slightly more rigid than PVC insulation material. Maximum Conductor Resistance: 397.0 Ω/km Resistant to: Chemical solvents, abrasion, cutting, extremes of hot & cold, flexing, shock, compression. FEP wire, has good resistance to extremes of temp., compression and repeat flexing. Suitable for use in microelectronic appliances that require a more durable wire, when shock or movement within portable devices are a “wear and tear” factor. Resistant to frigid environments 500ft per reel. Conforms to all current RoHS directives as laid out in EU Directive 2011/65/EC. Current SGS reports for this wire are available upon request. P/N's & COLORS 10064-30-1-0500-001-1-TS 10064-30-1-0500-002-1-TS BLACK WHITE 10064-30-1-0500-006-1-TS 10064-30-1-0500-007-1-TS BROWN GREEN 10064-30-1-0500-003-1-TS 10064-30-1-0500-004-1-TS 10064-30-1-0500-005-1-TS YELLOW RED BLUE 10064-30-1-0500-008-1-TS 10064-30-1-0500-010-1-TS ORANGE VIOLET 10064-30-1-0500-012-1-TS GRAY
10064-30-1-0500-007-1-TS 价格&库存
很抱歉,暂时无法提供与“10064-30-1-0500-007-1-TS”相匹配的价格&库存,您可以联系我们找货
  • 1+218.810161+28.36197
  • 2+208.337582+27.00452
库存:2
  • 1+5.979761+0.77509
  • 5+5.367935+0.69579
  • 10+5.1238410+0.66415
  • 25+4.8059825+0.62295
  • 50+4.5774550+0.59333
  • 100+4.35809100+0.56489
库存:10940
  • 500+1.31306500+0.17020
  • 1000+1.249491000+0.16196
  • 1500+1.213541500+0.15730
  • 2500+1.169482500+0.15159
  • 3500+1.141203500+0.14792
  • 5000+1.111845000+0.14412
库存:10940
