2617/22-WH-500
2617/22-WH-500
    DABURNELECTRONICS
    2617/22-WH-500
2617/22-WH-500 数据手册
Ultra-Flexible Silicone Rubber Wire UL 3212 150°C 600V Daburn Ultra-Flexible Silicone Rubber Wire, has high temperature resistance and high flexibility due to silicone rubber insulation and high strand count conductors. Applications include whole sealed cooking appliances, lighting equipment, computers, electronic equipment, internal combustion engines and mercury switch leads. This wire meets UL Style 3212. Description: Single conductor stranded tinned copper insulated with .045” silicone rubber insulation. This construction allows for a uniform, flexible, concentric, quality construction. Operating Temperature: -40°C to +150°C Voltage Rating: 600 Volts UL (Spark voltage 6,000 V) FT2 Flame Rating. This series is RoHS compliant. Catalog Nom. Wall Number AWG Strand Nom. O.D. Inches mm Inches mm Resistance dc at 20°C Ohm/mft Nom. Wt. lbs./mft 2617/10 10 105/30 .045 1.15 .207 5.30 1.08 46.69 2617/12 12 65/30 .045 1.15 .183 4.66 1.72 32.26 2617/14 14 41/30 .045 1.15 .165 4.20 2.73 23.21 2617/16 16 55/33 .045 1.15 .155 3.93 4.45 17.75 2617/18 18 34/33 .045 1.15 .142 3.61 7.06 13.56 2617/20 20 19/33 .045 1.15 .132 3.35 11.2 10.69 2617/22 22 17/34 .045 1.15 .124 3.16 18.1 8.84 2617/24 24 7/32 .045 1.15 .114 2.90 28.7 7.59 2617/26 26 7/34 .045 1.15 .110 2.80 45.8 6.73 Standard Put-Ups: 50 feet, 100 feet, 500 feet, 1,000 feet Colors Available: Black, Red, White, Green, Yellow, Blue, Brown, Grey, Violet, Orange
2617/22-WH-500 价格&库存
很抱歉,暂时无法提供与“2617/22-WH-500”相匹配的价格&库存,您可以联系我们找货
2617/22-WH-500
  • 500+5.10104500+0.65996
