BNC7T-J-P-GN-ST-EM2
BNC7T-J-P-GN-ST-EM2
    SAMTEC(申泰)
    BNC
BNC7T-J-P-GN-ST-EM2 数据手册
REVISION F BNC7T-J-P-XX-ST-EM2 DESIGNED & DIMENSIONED IN MILLIMETERS[INCHES] TERMINATION -EM2: EDGE MOUNT(FOR 2.29[.090] THICK PCB) ORIENTATION -ST: STRAIGHT PLATING SPECIFICATION -HN: HEAVY GOLD/NICKEL (SEE NOTES 5 & 6) (SUB-BNC7T-J-P-HN-ST-EM2) (BTNC-NUT-003-N) (BTNC-LWAS-001-N) GENDER -J: JACK TYPE -P: PCB DO NOT SCALE FROM THIS PRINT *-MN: MEDIUM GOLD/NICKEL (SEE NOTES 5 & 6) (SUB-BNC7T-J-P-GN-ST-EM2) (BTNC-NUT-003-N) (BTNC-LWAS-001-N) BTNC-NUT-003-X -GN: GOLD/NICKEL (SEE NOTES 5 & 6) (SUB-BNC7T-J-P-GN-ST-EM2) (BTNC-NUT-003-N) *= FOR EXISTING CUSTOMERS ONLY (BTNC-LWAS-001-N) RECOMMENDED MOUNTING HOLE 4.00[.157] MAX. PANEL THICKNESS 12.89 .507 SUB-BNC7T-J-P-XX-ST-EM2 11.30 .445 BTNC-LWAS-001-X RECOMMENDED LAYOUT FOR 2.29[.090] PCB 1.98 .078 PCB TOP 1.35 .053 (2 PLCS) FIG 1 6.80 .268 (2 PLCS) BNC7T-J-P-XX-ST-EM2 SHOWN F:\DWG\MISC\MKTG\BNC7T-J-P-XX-ST-EM2-MKT.SLDDRW 4.83 .190 9.65 .380 0.25 .010 (2 PLCS) 7.51 .295 0.25 .010 (2 PLCS) 6.80 .268 (2 PLCS) NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. FABRICATED PARTS MUST BE FREE OF SCRATCHES, TOOL MARKS, ETC. 3. SUPPLIER TO REMOVE BURRS. 4. RoHs COMPLIANT. 5. COMPONENT PLATING DESIGNATIONS: -H: 0.000030" MIN. GOLD OVER 0.000050" MIN. NICKEL. -G: 0.000010" MIN. GOLD OVER 0.000050" MIN. NICKEL. -N: 0.000100" MIN. NICKEL. 6. ASSEMBLY PLATING DESIGNATIONS: -HN: (CENTER CONTACT)-H (OUTER CONTACT) -N (REMAINING METAL PARTS) -N -MN, -GN:(CENTER CONTACT)-G (OUTER CONTACT) -N (REMAINING METAL PARTS) -N 7. NOTE DELETED 8. FINSHED ASSEMBLIES TO BE PACKAGED PER PACKAGING STANDARDS CO-RF-WI-3040-M. 3.10 .122 1.83 .072 PCB BOTTOM 1.65 .065 (2 PLCS) UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MILLIMETERS. TOLERANCES ARE: DECIMALS ANGLES .X: 0.3 [.01] 2 .XX: 0.13 [.005] .XXX: 0.051 [.0020] PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: BNC7T EDGE MOUNT STRAIGHT JACK DWG. NO. BNC7T-J-P-XX-ST-EM2 BY: G.HERMAN 09-09-2010 SHEET 1 OF 2 REVISION F 16.00 .630 REF 14.30 .563 REF 1.02 .040 REF 1/2-28 UNEF 2B THREAD REF 12.80 .504 REF 2.54 .100 REF 2.54 .100 REF 0.50 .020 REF 18.11 .713 REF 12.70 .500 REF 10.92 .430 REF 1.25 .049 REF 9.65 .380 REF 1/2-28 UNEF 2A THREAD 2.48 .098 REF 6.35 .250 REF 2.44 .096 REF F:\DWG\MISC\MKTG\BNC7T-J-P-XX-ST-EM2-MKT.SLDDRW PROPRIETARY NOTE 25.48 1.003 REF THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: BNC7T EDGE MOUNT STRAIGHT JACK DWG. NO. BNC7T-J-P-XX-ST-EM2 BY: G.HERMAN 09-09-2010 SHEET 2 OF 2
BNC7T-J-P-GN-ST-EM2 价格&库存
很抱歉,暂时无法提供与“BNC7T-J-P-GN-ST-EM2”相匹配的价格&库存,您可以联系我们找货
