SQP500JB-24R
SQP500JB-24R
    YAGEO(国巨)
    插件,22x9.5mm
    插件电阻 AXIAL_22X9.5MM_TM 24Ω ±5% 5W ±300ppm/℃
SQP500JB-24R 数据手册
無法顯示連結的影像。檔案可能已移動、重新命名或刪除。請檢查連結是否指向正確的檔案及位置。 DATA SHEET CEMENT RESISTORS High Power, Axial Lead SQP Series NSP Series ±1%, ±5% 1W to 40W Product specification – August 31, 2023 V.2 RoHS compliant & Halogen Free Through Hole Resistors Cement Resistors Product Specification ORDERING INFORMATION Part number of the cement resistor is identified by the series, power rating, tolerance, packing, temperature coefficient and resistance value. PART NUMBER APPLICATIONS  Power applications  Home appliance  Industry SQP 500 J B - 22R (1) (2) (3) (4) (5) (6) (1) SERIES SQP Series = General purpose NSP Series = Non inductive (2) POWER RATING 100 = 1W 10A = 10W 200= 2W 15A = 15W  High power rating 300 = 3W 20A = 20W  Excellent pulse load capability 5WS = 5W 25A= 25W 500 = 5W 30A = 30W 700 = 7W 40A= 40W FEATURES  Axial terminal  Flameproof ceramic case  RoHS compliant & halogen-free (3) TOLERANCE F = ±1% (Wirewound) J = ±5% (4) PACKAGING B = Bulk for wirewound or metal oxide or fiberglass element W = Bulk for wirewound element M = Bulk for metal oxide element (5) TEMPERATURE COEFFICIENT OF RESISTANCE F=±100ppm/°C (Wirewound) - = Based on spec. (6) RESISTANCE VALUE E24 & E96 Series Example: 100R = 100Ω, 10K = 10,000Ω, 1M = 1,000,000Ω www.yageo.com Aug. 31, 2023 V.2 2 9 SQP / NSP Through Hole Resistors Product Specification Cement Resistors DIMENSIONS Unit: mm Normal NonInductive L W H ψd SQP100 NSP100 13±1.0 5.5±1.0 5.5±1.0 0.6±0.05 SQP200 NSP200 18±1.0 7.0±1.0 7.0±1.0 0.65±0.05 SQP300 NSP300 22±1.5 8.0±1.0 8.0±1.0 0.8±0.05 SQP5WS - 25±1.5 6.0±1.0 6.0±1.0 0.65±0.05 SQP500 NSP500 22±1.5 9.5±1.0 9.0±1.0 0.8±0.05 SQP700 NSP700 35±1.5 9.5±1.0 9.0±1.0 0.8±0.05 SQP10A NSP10A 48±1.5 9.5±1.0 9.0±1.0 0.8±0.05 SQP15A NSP15A 48±1.5 12.5±1.0 12.5±1.0 0.8±0.05 SQP20A NSP20A 60±5.0 12.5±1.0 12.5±1.0 0.8±0.05 SQP25A NSP25A 60±5.0 14.0±1.5 13.0±1.5 0.8±0.05 SQP30A NSP30A 77±5.0 18.0±1.5 17-1.0 0.8±0.05 Normal NonInductive L W H h 90±5.0 19.0±1.5 20.5±1.5 19.5±1.5 B C E ψd 15.0±1.0 32±3 9.0±0.5 0.8±0.05 SQP40A NSP40A +2.5 DERATING CURVE SQP100 ~ SQP200 NSP100 ~ NSP200 Rated Power (%) 100 80 60 58 40 20 70 155 275 Ambient Temperature (°C) www.yageo.com Aug. 31, 2023 V.2 3 9 SQP / NSP Through Hole Resistors Cement Resistors Product Specification SQP300 ~ SQP10A NSP300 ~ NSP10A Rated Power (%) 100 80 60 51 40 20 40 155 275 Ambient Temperature (°C) 155 275 Ambient Temperature (°C) SQP15A ~ SQP40A NSP15A ~ NSP40A Rated Power (%) 100 80 60 48 40 20 25 TEMPERATURE CURVE www.yageo.com Aug. 31, 2023 V.2 4 9 SQP / NSP Through Hole Resistors Product Specification Cement Resistors ELECTRICAL CHARACTERISTICS CHARACTERISTICS SQP100 SQP200 Power Rating at 70 °C 1W 2W SQP300 SQP5WS SQP500 SQP700 SQP10A 3W 5W 5W 7W 10A Power Rating at 40 °C Maximum Working Voltage 200V 250V 350V 350V 350V 500V 500V Maximum Overload Voltage 500V 500V 700V 700V 700V 1000V 1000V Voltage Proof on Insulation 500V 500V 700V 700V 700V 1000V 1000V Resistance Range(Wirewound) 0.1Ω ~ 27Ω 0.03Ω ~ 36Ω 0.015Ω ~ 68Ω 0.015Ω ~ 130Ω 0.015Ω ~ 130Ω 0.05Ω ~ 330Ω 0.08Ω ~ 510Ω Resistance Range(Film) 30Ω ~ 47KΩ 39Ω ~ 1MΩ 75Ω ~ 1MΩ 150Ω ~ 1MΩ 150Ω ~ 1MΩ 360Ω ~ 100KΩ 560Ω ~ 100KΩ Operating Temp. Range - 55°C to +155°C Temperature Coefficient Wirewound :±100ppm/°C , ±300ppm/°C, Film: ±300ppm/°C Note: For resistance value out of above range is by request. CHARACTERISTICS SQP15A SQP20A SQP25A SQP30A SQP40A Power Rating at 25 °C 15W 20W 25W 30W 40W Maximum Working Voltage 500V 500V 1000V 1000V 1000V Maximum Overload Voltage 1000V 1000V 2000V 2000V 2000V Voltage Proof on Insulation 1000V 1000V 2000V 2000V 2000V Resistance Range(Wirewound) 0.1Ω ~ 680Ω 0.15Ω ~ 1KΩ 0.15Ω ~ 1KΩ 0.15Ω ~ 1KΩ 0.15Ω ~ 1KΩ Operating Temp. Range - 55°C to +155°C Temperature Coefficient Wirewound :±100ppm/°C , ±300ppm/°C Note: For resistance value out of above range is by request. CHARACTERISTICS NSP100 NSP200 Power Rating at 70 °C 1W 2W Power Rating at 40 °C NSP300 NSP500 NSP700 NSP10A 3W 5W 7W 10A Voltage Proof on Insulation 500V 500V 700V 700V 1000V 1000V Resistance Range(Wirewound) 0.08Ω ~ 10Ω 0.08Ω ~ 10Ω 0.033Ω ~ 30Ω 0.03Ω ~ 40Ω 0.15Ω ~ 65Ω 0.25Ω ~ 100Ω Maximum Working Voltage √(P X R) Operating Temp. Range - 55°C to +155°C Temperature Coefficient ±300ppm/°C Note: For resistance value out of above range is by request. www.yageo.com Aug. 31, 2023 V.2 5 9 SQP / NSP Through Hole Resistors Product Specification Cement Resistors CHARACTERISTICS NSP15A NSP20A NSP25A NSP30A NSP40A Power Rating at 25 °C 15W 20W 25W 30W 40W Voltage Proof on Insulation 1000V 1000V 2000V 2000V 2000V Resistance Range(Wirewound) 0.25Ω ~ 120Ω 0.36Ω ~ 160Ω 0.36Ω ~ 160Ω 0.36Ω ~ 160Ω 0.36Ω ~ 160Ω Maximum Working Voltage √(P X R) Operating Temp. Range - 55°C to +155°C Temperature Coefficient ±300ppm/°C Note: For resistance value out of above range is by request. TEST AND REQUIRMENTS TEST TEST METHOD Short Time Overload IEC 60115-1 4.13 PROCEDURE APPRAISE 2.5 times RCWV for 5 sec.(Not more than ±2.0%+0.05Ω maximum overload voltage) Voltage Proof on IEC 60115-1 4.7 Insulation In V-Block for 60 sec. test voltage as No Breakdown above table Temperature Coefficient IEC 60115-1 4.8 Between -55°C to +155°C By Type Insulation Resistance IEC 60115-1 4.6 In V-Block for 60 sec. >1,000MΩ Solderability IEC 60115-1 4.17 245±5°C for 3±0.5 Sec. 95% Min. coverage Solvent Resistance of IEC 60115-1 4.30 IPA for 5±0.5 Min. with ultrasonic No deterioration of Marking Robustness of coatings and markings IEC 60115-1 4.16 Terminations Periodic-pulse Overload Direct load for 10 Sec. in the direction of ≥2.5Kg(24.5N)D the terminal leads IEC 60115-1 4.39 4 times RCWV 10,000 cycles (1 Sec. on, ±2.0%+0.05Ω 25 Sec.off) Damp Heat Steady State IEC 60115-1 4.24 40±2°C,90-95% RH for 56 days, loaded ±5.0%+0.05Ω with 0.1 times RCWV Endurance at 70°C IEC 60115-1 4.25 70±2°C at RCWV(or Umax., whichever ±5.0%+0.05Ω less) for 1,000 Hr.(1.5 Hr.on,0.5 Hr. off) Temperature Cycling IEC 60115-1 4.19  -55°C  Room Temp.  ±2.0%+0.05Ω +155°C Room Temp.(5 cycles) Resistance to Soldering Heat IEC 60115-1 4.18 260±3°C for 10±1 Sec., immersed to a ±1.0%+0.05Ω point 3±0.5mm from the body www.yageo.com Aug. 31, 2023 V.2 6 9 SQP / NSP Through Hole Resistors Cement Resistors Product Specification Note: RCWV (Rated Continuous Working Voltage): The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V=√(P X R) or max. working voltage whichever is less Where V=Continuous rated DC or AC (rms) working voltage (V) P=Rated power (W) R=Resistance value (Ω) BULK PACKING Unit: Piece Normal Non-Inductive PACKAGE Quantity SQP200 NSP200 Bulk 1,400 SQP300 NSP300 Bulk 1,000 SQP500 NSP500 Bulk 900 SQP700 NSP700 Bulk 600 SQP10A NSP10A Bulk 500 SQP15A NSP15A Bulk 360 SQP20A NSP20A Bulk 360 SQP25A NSP25A Bulk 360 SQP30A NSP30A Bulk 50 SQP40A NSP40A Bulk 50 MARKING Example: YAGEO = Brand 1801 = Date code 10W = Power rating 100R = Resistance J = Tolerance www.yageo.com Aug. 31, 2023 V.2 7 9 SQP / NSP Through Hole Resistors Cement Resistors Product Specification REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 2 Aug.31, 2023 - - Revised LEGAL DISCLAIMER Version 1 Feb.16, 2023 - - Update packaging quantity of SQP20A&25A Version 0 Aug.2, 2021 - - First issue of this specification “ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products itse lf are unchanged. Any product change will be announced by PCN.” www.yageo.com Aug. 31, 2023 V.2 8 9 SQP / NSP Through Hole Resistors Cement Resistors Product Specification LEGAL DISCLAIMER YAGEO, its distributors and agents (collectively, “YAGEO”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. YAGEO may make changes, modifications and/or improvements to product related information at any time and without notice. YAGEO makes no representation, warranty, and/or guarantee about the fitness of its products for any particular purpose or the continuing production of any of its products. To the maximum extent permitted by law, YAGEO disclaims (i) any and all liability arising out of the application or use of any YAGEO product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non -infringement and merchantability. YAGEO products are designed for general purpose applications under normal operation and usage conditions. Please contact YAGEO for the applications listed below which require especially high reliability for the prevention of defects which might directly cause damage to the third party's life, body or property: Aerospace equipment (artificial satellite, rocket, etc.), Atomic energy-related equipment, Aviation equipment, Disaster prevention equipment, crime prevention equipment, Electric heating apparatus, burning equipment, Highly public information network equipment, data-processing equipment , Medical devices, Military equipment, Power generation control equipment, Safety equipment, Traffic signal equipment, Transportation equipment and Undersea equipment, or for any other application or use in which the failure of YAGEO products could result in personal injury or death, or serious property damage. Particularly YAGEO Corporation and its affiliates do not recommend the use of commercial or automotive grade products for high reliability applications or manned space flight. Information provided here is intended to indicate product specifications only. YAGEO reserves all the rights for revising this content without further notification, as long as products are unchanged. Any product change will be announced by PCN. www.yageo.com Aug. 31, 2023 V.2 9 9 SQP / NSP
SQP500JB-24R 价格&库存
很抱歉,暂时无法提供与“SQP500JB-24R”相匹配的价格&库存,您可以联系我们找货
