REVISION Y
DO NOT
SCALE FROM
THIS PRINT
HPM-XX-XX-XX-X-XX-X
NOTES:
1. C REPRESENTS A CRITICAL DIMENSION.
2. MAXIMUM HEIGHT VARIATION BETWEEN ANY TWO PINS: .005[0.13]
3. MAXIMUM PIN ROTATION IN BODY: 2°
4. TAILS TO BE SHEARED TO ACHIEVE DIMENSIONAL CALLOUT ±.010[0.25]
5. MINIMUM PUSHOUT FORCE: 3 LBS.
6. MAXIMUM ALLOWABLE BURR: .0015[0.038]
7. THROUGH HOLES (-S & -RA) ARE TO BE BULK PACKAGED.
8. SURFACE MOUNT (-VS) IS TO BE PACKAGED AS FOLLOWS:
POSITIONS -04 THRU -20 ARE TO BE TUBE PACKAGED;
POSITION -02 TO BE LAYER PACKAGED,
-03 POSITION TO BE TUBE OR LAYER PACKAGED.
9. MAXIMUM CUT FLASH: .020[0.51]
10. COPLANARITY (-VS); POSITIONS -02 THRU -15: .008[0.20],
POSITIONS -16 THRU -20: .010[0.25]
OPTION
-P: PICK PLACE PAD
(USE PPP-47)
(-VS ONLY, 3 POS MIN,
NOT AVAILABLE IN -05
LEAD STYLE)
No OF POSITIONS
-01 THRU -20
LEAD STYLE
SEE TABLE 1
OPTION
-RA: RIGHT ANGLE POST
(-02 & -04 LEAD STYLE ONLY)
-VS: VERTICAL SURFACE MOUNT
(-01 & -02 LEAD STYLE ONLY)
(2 POSITION MINIMUM)
PLATING SPECIFICATIONS
-T: MATTE TIN CONTACT
AND TAIL
-TM:MATTE TIN CONTACT
AND TAIL
(No OF POS X .20[5.1])
ROW SPECIFICATION
-S: SINGLE
SEE TABLE 2
(No OF POS-1)X.200[5.08]
.100 2.54 REF
TABLE 2
BODY
FORM
.250 6.35 REF
T/H
FSW-20-200
RA
FSW-20-200
VS
HFSW-20-200
BLACK, PBT,
UL 94 VO
.125 3.18 REF
.045 1.14
SQ REF
MATERIAL
NATURAL, LCP,
UL 94 VO
2 MAX SWAY
(EITHER DIRECTION)
90°
C
"B" C
(SEE NOTE 2)
"E"
"C"
+4°
90° - 0°
"A" REF
(SEE NOTE 4 & 6 FOR
-05 LEAD STYLE)
.100 2.54 REF
T-1S8-XX-XX
.200 5.08
SEE NOTE 10
"D" REF
.04 1.02
2 MAX SWAY
(EITHER DIRECTION)
ANGLES
.XX: .01 [0.3]
2
.XXX: .005 [0.13]
.XXXX: .0020 [0.051]
MATERIAL:
-02 & -04 ONLY
-01 & -02 ONLY
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
-RA: RIGHT ANGLE
-VS: SURFACE MOUNT
-S: SINGLE
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
BODY: SEE TABLE 2
TERMINAL: CDA7025
GRADE TL02
MAX BOW ALLOWED: .003 IN/IN
F:\DWG\MISC\MKTG\HPM-XX-XX-XX-X-XX-X-MKT.SLDDRW
SHEET SCALE: 2:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
DWG. NO.
.200 HIGH POWER BLOCK, ASM
HPM-XX-XX-XX-X-XX-X
BY: BURRES
08/21/98
SHEET 1 OF 2
REVISION Y
NOTE:
"R"=No OF POS X .200[5.08] REF
"S"= {("R" -.450[11.43])/2}±.020[.51]
"G"= POST HEIGHT +.050[1.27] REF
"R"
"S"
"B"
"E"
"G"
.300 7.62 REF
.213±.010
(SEE NOTES 4 & 6)
.450 11.43
PPP-47
REF
IN-PROCESS
-VS
-P: PICK & PLACE PAD OPTION
(-VS ONLY, 3 POS MIN)
(NOT AVAILABLE IN -05 LEAD STYLE)
PT-1-24-01-67
TP-13
-VS
01
PT-1-24-01-67
IN-PROCESS
-RA
TP-13
-VS-P
PACKAGING VIEW
(SEE NOTE 7 & 8)
PROPRIETARY NOTE
SHEET SCALE: 1:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
HPM-XX-XX-XX-X-XX-X
BY: BURRES
08/21/98
SHEET 2 OF 2
很抱歉,暂时无法提供与“HPM-04-01-T-S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+8.00280
- 10+7.78680
- 30+7.64640
- 国内价格 香港价格
- 8+12.993368+1.68630
- 国内价格 香港价格
- 1+13.141851+1.70558
- 50+10.1959850+1.32326
- 100+8.24025100+1.06944
- 500+7.02099500+0.91120
- 1000+6.428541000+0.83431
- 国内价格 香港价格
- 1+13.429071+1.74285
- 50+10.4234750+1.35278
- 100+8.42028100+1.09280
- 500+7.17483500+0.93117
- 1000+6.426091000+0.83399
- 国内价格 香港价格
- 8+6.355918+0.82488
- 国内价格 香港价格
- 8+11.151158+1.44722
- 国内价格 香港价格
- 1+11.139501+1.44570
- 100+9.37880100+1.21720
- 500+8.36060500+1.08510
- 1000+7.282601000+0.94520
- 2000+6.995202000+0.90790
- 5000+5.689605000+0.73840
- 10000+5.1745010000+0.67160
- 国内价格 香港价格
- 25+22.6194425+2.93559
- 250+11.17299250+1.45005
- 500+9.37528500+1.21674
