REVISION CK
ESQ-1XX-XX-X-X-XXX-XX-X-XX
NOTES:
1. MINIMUM CONTACT PUSHOUT: 1.5 LBS.
2. FOR A 1 POSITION SINGLE ROW
ALL SPACERS ARE TO BE TSW-XX-S.
3. NOTE DELETED.
4. MAXIMUM ALLOWABLE BOW .003[0.08] INCH/INCH AFTER ASSMBLY
5. DO NOT USE DSB SPACER BODY FOR THIS OPTION.
6. MAXIMUM CUT FLASH : .010[0.25];
MAXIMUM CUT FLASH ON TAIL SIDE: .020[0.51] NOT TO EXTEND BELOW
STANDOFFS.
7. ORDERS WILL BE PACKAGED ACCORDING TO THE SAMTEC PACKAGING
EFFICIENCY STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM
CONTACT STYLE
SQUARE TAIL: USE C-15-X-X
LOW INSERTION FORCE: C-60-X-X
(SEE TABLE 1, SHT 2)
METAL WASHER OPTION
#* -H-MW: (SEE FIG 3, SHT 2)
(N/A ON TRIPLE ROW)
(.300 [7.62] MAX TAIL)
(AVAILABLE ON POS
-02 THRU -32 ONLY)
NO. OF POSITIONS
POSITIONS 01 THRU 36
(SEE FIG1)
FOR A ONE POSITION
SINGLE ROW SEE NOTE 2
LOCKING LEAD OPTION
-LL (SEE FIG 2, SHT 2)
[N/A ON 1 OR 2 POSITION
SINGLE ROW]
LEAD STYLE
PLATING SPECIFICATION
-G: 20µ" GOLD IN CONTACT AREA, 3µ" GOLD TAIL
-T: MATTE TIN CONTACT AND TAIL
-S: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN TAIL
-H: 30µ" HEAVY GOLD IN CONTACT AREA, 3µ" GOLD TAIL
-L: 10µ" SELECTIVE LIGHT GOLD IN CONTACT AREA, MATTE TIN TAIL
DO NOT
SCALE FROM
THIS PRINT
POLARIZATION OPTION
INDICATES POSITION (SEE FIG 4, SHT 2)
ROW SPECIFICATION (SEE TABLE 1, SHT 2)
-S: SINGLE (USE SSW-50-S)
-D: DOUBLE (USE SSW-50-D)
-T: TRIPLE (USE SSW-50-T)
(No OF POS x .10[2.5] + .02[0.5])
.295 7.49 REF
(-T ONLY)
.100 2.54 REF
.195 4.95 REF
(-D ONLY)
.100 2.54 REF
(-D & -T ONLY)
SSW-XX-S
.335 8.51 REF
SSW-XX-D
SUB-SSB-32
OR ESS-XX-S
(SEE NOTE 2)
"C" .010[0.25] C
"D"±.010[0.25]
#-MW OPTION, DO NOT DESIGN IN. SAMTEC WILL
ONLY SUPPORT EXISTING BUSINESS 2/12/02
.200 5.08 REF
(-T ONLY)
.095 2.41 REF
(-S ONLY)
*SEE NOTE 6
SSW-XX-T
DSB-XX &
SUB-SSB-32
OR ESS-XX-S
DSB-XX
RTSW-XX-D
TSW-XX-S
TSW-XX-T
.100 2.54 REF
.100 2.54 REF
"B" REF
C-60-X-X
.025 0.64 SQ REF (TYP)
(No OF POS X .100[2.54])
REF
2° MAX SWAY
(EITHER DIRECTION)
FIG 1
ESQ-110-XX-X-T
F:\DWG\MISC\MKTG\ESQ-1XX-XX-X-X-XXX-XX-X-XX-MKT.SLDDRW
-S
2° MAX SWAY
(EITHER DIRECTION)
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
ANGLES
.XX: .01 [0.3]
2
.XXX: .005 [0.13]
.XXXX: .0020 [0.051]
MATERIAL:
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
INSULATOR: LCP, UL 94 V0
COLOR: BLACK
CONTACT : PHOS BRONZE
-T
-D
SHEET SCALE: 3:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
ESQ STRIP ASM
DWG. NO.
BY: JORDAN
7-16-85
SHEET 1 OF 4
REVISION CK
SSW-XX-D
SSW-XX-S
ESQ-110-XX-X-D-MW-T
DETAIL A
SCALE 4 : 1
108
6
3
.005 0.13 MAX
MEASURE AT
THE TAIL
4
-T
1
.003 0.08 MAX
MEASURE AT
THE TAIL
FIG 3
-S
#-H-MW: METAL WASHER
ESQ-110-XX-X-X-MWT
(ONE PER POSITION)
(-S & -D BODY SPECS ONLY)
(SEE NOTE 5)
(SAME AS FIG 1 UNLESS OTHERWISE NOTED)
3° MAX SWAY
ANY DIRECTION
DETAIL B
SCALE 6 : 1
-D
4 2
72
1
106
HTSW-XX-D
HTSW-XX-S
71
3
36
2
1
-D
-S
.04 1.02
.0080 0.20
(TYP)
CL
CL
CL
-S
FIG 4
-T
-D
-S
-D
-T
CRIMP LOCATIONS
XXX: POLARIZATION LOCATION
INSERT PK-06-N INTO SPECIFIED POS
AND BREAK OFF TAB
ODD POSITIONS
= CRIMP LOCATION
CL
CL
CL
-S
-D
CRIMP LOCATIONS
-T
EVEN POSITIONS
= CRIMP LOCATION
FIG 2
-LL: LOCKING LEAD OPTION
LOCATED ON OR ABOUT CENTERLINE
[N/A IN 1 OR 2 POSITION SINGLE ROW]
PROPRIETARY NOTE
SHEET SCALE: 1:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
ESQ STRIP ASM
DWG. NO.
BY: WHITTAKER
9-11-98
SHEET 2 OF 4
REVISION CK
"D" .010[0.25]
.09 2.29
.09 2.29
LOAD CONTACT
PRESS ON
SSW BODY
PRESS ON -MW
IN-PROCESS
-12, -33, -37, -58
"C" .010[0.25]
"D" .010[0.25]
.18 4.57
"C" .010[0.25]
"D" .010[0.25]
.18 4.57
LOAD CONTACT
"B"
PRESS ON
SSW BODY
PRESS ON -MW
REPRESS STACKER BODY
AND -MW TO PROPER "C" DIM
IN-PROCESS
-13, -14, -23, -24, -34, -38
-39, -44, -48, -49, -59, -69
PROPRIETARY NOTE
SHEET SCALE: 1:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
ESQ STRIP ASM
DWG. NO.
BY: WITHTTAKER 9-11-98
SHEET 3 OF 4
REVISION CK
SSW-50-X
"B" + "E"
STEP 1
1. FOR -12 & -37 LEAD STYLES TUBE PAC KAGE -04 THRU -36 POSITION ONLY.
2. FOR -13, -23, -33, -38, -48, & -58 LEAD STYLES TUBE PACKAGE -08 THRU -36 POSITIONS ONLY.
3. FOR -14, -24, -34, -44, -39, -49, -59, & -69 LEAD STYLES -05 THRU -36 POSITIONS ONLY.
MACHINE FILL SSW-50-X
"C" .010[0.25]
"D" .010[0.25]
TSW-XX-X
(RTSW-XX-X)
"B"
-D
PT-1-24-01-51
STEP 2
MULTI-CUT TSW-50-X TO POS (RTSW-50-D FOR DOUBLE ROW)
AND MOUNT AS SHOWN.
(IF RTSW-50-D NOT AVAILABLE, TSW-50-D MAY BE USED)
(No OF POS X .100[2.54]+.020[0.51])
.010[0.25]
"B"
-D
PT-1-24-02-47
FIG 6
ESQ-110-XX-X-D
IN PROCESS "A"
(LEAD STYLE -12-T, -13, -14, -23, -24, -33, -34,
-44, -37-T, -38, -48, -49, -58, -59, -69)
-D
PT-1-24-03-44
STEP 3
ROTO CUT TO POS
PROPRIETARY NOTE
-T
PT-1-24-03-51
-S
PT-ESQ001
SHEET SCALE: 1:1
-S
PT-ESQ002
FIG 5
ESQ-110-XX-X-S
IN PROCESS "B"
(LEAD STYLE -12 & -37)
(-S & -D ONLY)
-S
PT-1-24-01-47
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
ESQ STRIP ASM
DWG. NO.
BY: WHITTAKER
9-11-98
SHEET 4 OF 4
