SFML-115-02-S-D-LC
SFML-115-02-S-D-LC
    SAMTEC(申泰)
    SMD,P=1.27mm
    排母 间距:1.27mm 2x15P SMT
SFML-115-02-S-D-LC 数据手册
REVISION AV SFML-1XX-XX-XXX-D-XXX DO NOT SCALE FROM THIS PRINT FIG 1 THROUGH HOLE/STRAIGHT MODIFIED (SHOWN: SFML-125-X1-XXX-D) "A" "B" 01 02 .120 3.05 REF "B" .050 1.27 REF OPTIONS (LEAVE BLANK FOR STANDARD AND USE SFML-XX-D) -A: ALIGNMENT PIN (USE SFML-XX-D-A) (SEE FIG 5, SHT 3) -LC: LOCKING CLIP (SEE FIG 7, SHT 3) (USE (2) LC-05-TM & SFML-XX-D) (SEE NOTE 9) -P: PICK & PLACE PAD (SEE FIG 6, SHT 3) (USE PPP-02) (NOT AVAILABLE IN 5 POS) -TR: TAPE & REEL PACKAGING (N/A with -X1 AND -X3 LEAD STYLE, SEE FIG 2, SHT 1) -K: POLYIMIDE FILM PAD (USE K-DOT-.157-.250-.005)(SEE FIG 4, SHT 2) -SN: SOLDER NAIL (USE SFML-XX-D-SN & WT-27-01-T) (SEE FIG 8, SHT 4) (AVAILABLE ON -X2 LEAD STYLES ONLY) -SN2: SOLDER NAIL FOR .093 BOARD (USE SFML-XX-D-SN & WT-27-02-T) (SEE FIG 8, SHT 4) (ONLY AVAILABLE WITH -02, L2, AND T2 LEAD STYLE. NOT AVAILABLE WITH -A, -LC OPTIONS) ROW SPECIFICATION -D: DOUBLE ROW (USE SFML-XX-D-X) No OF POSITIONS .020 0.51 -05, -07, -08, -10 THRU -50 REF (PER ROW) .060 1.52 LEAD STYLE REF DETAIL 'D' -01: THROUGH HOLE (USE C-44-01-XXX, SEE FIG 1, SHT 1) ALTERNATE CONSTRUCTION -02: SURFACE MOUNT (USE C-44-02-XXX, SEE FIG 3, SHT 2) "A" -03: STRAIGHT MODIFIED (USE C-44-03-XXX, SEE FIG 1, SHT 1) 'D' -L1: THROUGH HOLE (LOW INSERTION) (USE C-61-01-XXX, SEE FIG 1, SHT 1) .145 3.68 REF -L2: SURFACE MOUNT (LOW INSERTION) (USE C-61-02-XXX, SEE FIG 3, SHT 2) -L3: STRAIGHT MODIFIED (LOW INSERTION) (USE C-61-03-XXX, SEE FIG 1, SHT 1) -T1: THROUGH HOLE (PHOS BRONZE) (USE C-119-01-XXX, SEE FIG 1, SHT 1) .080 2.03 -T2: SURFACE MOUNT (PHOS BRONZE) REF (USE C-119-02-XXX, SEE FIG 3, SHT 2) .100 2.54 REF (TYP) "C" REF (TYP) (SEE NOTE 5 & TABLE 3) C (No OF POS x .050 [1.27] + .155 [3.94] REF SFML-XX-D (No OF POS x .050 [1.27]) + .015 [.38] REF .035 0.89 REF (TYP) .180 4.57 REF .065 1.65 REF "A" C (SEE TABLE 1) .110 2.79 REF "B" REF (SEE TABLE 1) .050 1.27 REF .005 0.13 REF 1 MAX SWAY 2 MAX SWAY (EITHER DIRECTION) (EITHER DIRECTION) C (No OF POS x .050 [1.27]) - .050 [1.27] SECTION "A"-"A" SECTION "B"-"B" POS 1 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. USER DIRECTION OF UN-REELING POCKET NOT DETAILED TOLERANCES ARE: DECIMALS F:\DWG\MISC\MKTG\SFML-1XX-XX-XXX-D-XXX-MKT.SLDDRW FIG 2 -TR: TAPE & REEL PACKAGING (ALTERNATE KEYING OPTION SHOWN) ANGLES .XX: .01[0.3] 2 .XXX: .005[0.13] .XXXX: .0020[0.051] MATERIAL: SEE NOTE 6 LOCKING TAB PLATING SPECIFICATION -S: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -F: 3µ" FLASH SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -H: 30µ" HEAVY GOLD IN CONTACT AREA, 3µ" GOLD ON TAIL -L: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -STL: 30µ" SELECTIVE GOLD IN CONTACT AREA, TIN/LEAD (90/10+/-5%) TAIL (ONLY AVAILABLE ON -02 AND -L2 LEADSTYLES) -SM: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -LM: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -FM: 3µ" FLASH SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL .050 1.27 C NOTES: C REPRESENTS A CRITICAL DIMENSION. 1. C 2. COPLANARITY: .004 [.10] FOR POS. 04 THRU 26 .006 [.15] FOR POS. 27 THRU 50 3. MINIMUM PUSHOUT FORCE: .5 LB. 4. MAXIMUM ALLOWABLE BOW: .002 INCH/INCH [MM/MM] AFTER ASSEMBLY. 5. POSITIONS -05, 07 AND -08 WILL HAVE ONLY ONE LOCKING TAB AT DIMENSION SHOWN AND WILL NOT HAVE POLARIZATION NOTCH; POSITIONS -10 THROUGH -24 WILL HAVE ONLY ONE LOCKING TAB AT DIMENSION SHOWN; POSITIONS -25 THROUGH -34 WILL HAVE TWO LOCKING TABS AT DIMENSION SHOWN; POSITIONS -35- THROUGH -50 WILL HAVE THREE LOCKING TABS: TWO AT DIMENSION SHOWN & ONE CENTERED ON INSULATOR. 6. SEE NOTCH FOR PROPER ORIENTATION. 7. PINS CAN BE ORIENTED IN ANY DIRECTION; BOTH ROWS MUST FACE SAME WAY. C 8. MAXIMUM PIN HEIGHT VARIATION: .003[0.08] FROM PIN TO PIN AND ROW TO ROW, MUST BE MEASURED BETWEEN ADJACENT PINS. 9. DUE TO THE HIGH AMOUNT OF INSERTION FORCE NEEDED, THE –LC OPTION IS NOT COMPATIBLE WITH AUTO PLACEMENT. SAMTEC RECOMMENDS MANUAL PLACEMENT FOR ALL ASSEMBLIES WITH THE –LC OPTION." 10. TUBE PARTS WITH NOTCH AND/OR LOCKING TAB TOWARD ARROW. NOTCH NOT AVAILABLE ON -05, -07 AND -08 POSITION PARTS. * DO NOT SCALE DRAWING INSULATOR: VECTRA E130i, LCP UL 94 VO COLOR: BLACK CONTACT: BeCu PHOS BRONZE PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: .050 [1.27] x .050 [1.27] LOCKING SOCKET ASSEMBLY DWG. NO. SFML-1XX-XX-XXX-D-XXX BY: BRATCHER 4/19/99 SHEET 1 OF 4 REVISION AV (No OF POS x .050 [1.27]) - .050 [1.27] (TOL ACCUM .005 [0.13] C-XX-X2-XXX 3 MAX SWAY C (EITHER DIRECTION) "C" +.002 +0.05 C .185 - .005 4.70 - 0.13 4° SEE NOTE 2 SEE NOTE 8 "C" 2° .161 4.09 REF FIG 3 SECTION "C"-"C" -X2: SURFACE MOUNT (SAME AS FIG 1, UNLESS OTHERWISE STATED) "M" .190 4.83 C "P" .019±.020 0.47±0.51 .1575±.0050 4.000±0.127 NOTE: "M" = USED MEASURED DIMENSION (REF) "P" = {("M" - .1575 [4.000]) /2} .020 [0.51] FIG 4 -K: POLYIMIDE FILM PAD OPTION (SHOWN: SFML-110-X2-X-D-K) (ALTERNATE CONSTRUCTION SHOWN) F:\DWG\MISC\MKTG\SFML-1XX-XX-XXX-D-XXX-MKT.SLDDRW * C +.003 +0.08 .190 - .007 4.83 - 0.18 DIMENSION APPLIES PRIOR TO RE-PRESS, SEE SECTION "C"-"C" FOR FINISHED DIMENSION PROPRIETARY NOTE DO NOT SCALE DRAWING SHEET SCALE: 4:1 IN-PROCESS * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: .050 [1.27] x .050 [1.27] LOCKING SOCKET ASSEMBLY DWG. NO. SFML-1XX-XX-XXX-D-XXX BY: BRATCHER 4/19/99 SHEET 2 OF 4 PACKAGE PARTS IN TUBES AS SHOWN REVISION AV ( SEE NOTE 10) PT-1-24-13-09 (No OF POS x .050 [1.27]) + .125 [3.18] REF SFML-XX-D-A SAMTEC ANTI-STATIC SAMTEC ANTI-STATIC SAMTEC ANTI-STATIC PT-1-24-14-09 .050 1.27 REF .050 1.27 REF PT-1-24-15-09 (No OF POS x .050 [1.27]) + .075 [1.91] REF FIG 5 -A: ALIGNMENT PIN OPTION (SAME AS FIG 1, UNLESS OTHERWISE STATED) (ALTERNATE CONSTRUCTION SHOWN) PPP-02 .394 10.01 REF .225 5.72 REF "A" .010 [.25] (SEE TABLE 2) .062 1.57 SFML-XX-D LOCKING TAB FIG 6 -P: PICK & PLACE PAD OPTION (SAME AS FIG 1, UNLESS OTHERWISE STATED) (ALTERNATE CONSTRUCTION SHOWN) C .065 1.65 .056 1.42 REF .010 0.25 REF 2 MAX SWAY (EITHER DIRECTION) LC-05-TM (No OF POS x .050 [1.27]) + .075 [1.91] 2 MAX SWAY (EITHER DIRECTION) FIG 7 -LC: LOCKING CLIP OPTION (SAME AS FIG 1, UNLESS OTHERWISE STATED) (ALTERNATE CONSTRUCTION SHOWN) F:\DWG\MISC\MKTG\SFML-1XX-XX-XXX-D-XXX-MKT.SLDDRW * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 3:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: .050 [1.27] x .050 [1.27] LOCKING SOCKET ASSEMBLY DWG. NO. SFML-1XX-XX-XXX-D-XXX BY: BRATCHER 4/19/99 SHEET 3 OF 4 REVISION AV (No OF POS x .050[1.27]) + .185[4.70] REF SFML-XX-D-SN "D" CL C CL FLUSH TO .005[0.13] ABOVE "B" REF WT-27-XX-T .026 0.66 REF (2 PLCS) "D" 2 MAX SWAY (EITHER DIRECTION) SECTION "D"-"D" C (No OF POS x .050[1.27]) + .085[2.16] OPTION -SN SN2 FIG 8 -SNX: SOLDER NAIL OPTION (SHOWN: SFML-125-02-XXX-D-SN (SAME AS FIG 1, UNLESS OTHERWISE STATED) (ONLY AVAILABLE ON -X2 LEAD STYLES) * PROPRIETARY NOTE SHEET SCALE: 4:1 F:\DWG\MISC\MKTG\SFML-1XX-XX-XXX-D-XXX-MKT.SLDDRW "B" .066[1.68] .101[1.80] * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING TABLE 3 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: .050 [1.27] x .050 [1.27] LOCKING SOCKET ASSEMBLY DWG. NO. SFML-1XX-XX-XXX-D-XXX BY: BRATCHER 4/19/99 SHEET 4 OF 4
SFML-115-02-S-D-LC
- 物料型号:SFML-1XX-XX-XXX-D-XXX - 器件简介:文档中没有提供具体的器件简介,但提到了不同的引脚分配和样式。 - 引脚分配:提供了不同配置的引脚分配,例如-X1、-X2、-X3等,以及对应的物理构造。 - 参数特性:包括了引脚样式、包装管、插头等的详细尺寸和规格。 - 功能详解:文档描述了不同选项的功能,如对齐销(-A)、锁定夹(-LC)、拾取放置垫(-P)、胶带和卷轴包装(-TR)、聚酰亚胺薄膜垫(-K)等。 - 应用信息:文档中提及了器件的应用信息,例如推荐的使用环境和特定的应用选项。 - 封装信息:包含了封装的详细尺寸和设计,例如绝缘体材料、接触材料等。
SFML-115-02-S-D-LC 价格&库存
很抱歉,暂时无法提供与“SFML-115-02-S-D-LC”相匹配的价格&库存,您可以联系我们找货
SFML-115-02-S-D-LC
  • 25+67.59294
  • 50+64.11617
  • 100+56.93412
  • 500+51.84139
  • 1000+45.83458
  • 2000+42.58633
库存:2149
