CXA1507-0000-000F0HG440G
    WOLFSPEED
    LED_15.9X15.9MM_SM
    LEDCOBCXA15074000KWHITESMD
CXA1507-0000-000F0HG440G 数据手册
Cree® XLamp® CXA1507 LED PRODUCT DESCRIPTION FEATURES The XLamp® CXA1507 LED array • Available in 4-step, 3‑step and 2-step TABLE OF CONTENTS Characteristics.............................................2 expands Cree’s family of high‑flux, EasyWhite bins at 2700 K, 3000 K, Operating Limits...........................................3 multi‑die arrays in a smaller, easy‑to‑use 3500 K, 4000 K & 5000 K CCT and Flux Characteristics, EasyWhite® Order platform. With XLamp LED lighting‑class 4-step EasyWhite bins at 5700 K & Codes and Bins - 18 V..................................4 reliability, 6500 K CCT Flux Characteristics, ANSI White Order the CXA1507’s small, uniform emitting surface enables both directional and non‑directional lighting applications including lamp retrofit and ® • Available in ANSI white bins at Flux Characteristics, EasyWhite® Order CCT Codes and Bins - 36 V..................................8 • Available in 70-, 80-, 90- and 3‑step and 4‑step color consistency, 93‑minimum CRI options the CXA1507 brings new levels of flux and efficacy to this form factor. The CX Family LED Design Guide provides basic information on the requirements to use the CXA1507 LED successfully in luminaire designs. Codes and Bins - 18 V..................................7 4000 K, 5000 K, 5700 K & 6500 K luminaire designs. Available in 2‑step, and featuring a 9‑mm optical source, • Forward voltage options: 18‑V class & 36‑V class Flux Characteristics, ANSI White Order Codes and Bins - 36 V............................... 11 Relative Spectral Power Distribution....... 12 Electrical Characteristics.......................... 13 • 85 °C binning and characterization Relative Luminous Flux............................. 14 • Maximum drive current: 750 mA Typical Spatial Distribution....................... 16 (18 V), 375 mA (36 V) • 115° viewing angle, uniform chromaticity profile Performance Groups - Brightness........... 16 Performance Groups - Chromaticity........ 17 Cree EasyWhite® Bins Plotted on the • Top-side solder connections 1931 CIE Color Space............................... 20 • Thermocouple attach point Cree ANSI White Bins Plotted on the • NEMA SSL-3 2011 standard flux bins 1931 CIE Color Space............................... 20 • RoHS and REACh compliant Bin and Order Code Formats.................... 21 • UL recognized component Mechanical Dimensions........................... 21 ® (E349212) CLD-DS50 REV 12C PRODUCT FAMILY DATA SHEET Thermal Design......................................... 22 Notes......................................................... 24 WWW.CREE.COM/XLAMP Packaging.................................................. 25 Copyright © 2012-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 XLAMP ® CXA1507 LED CHARACTERISTICS Characteristics Viewing angle (FWHM) ESD withstand voltage (HBM per Mil-Std-883D) Unit degrees Minimum Typical Maximum 115 V 8000 DC forward current (18 V) mA 750* DC forward current (36 V) mA 375* Reverse current 18 V, 36 V) mA 0.1 Forward voltage (18 V, 400 mA, 85 °C) V Forward voltage (18 V, 400 mA, 25 °C) V Forward voltage (36 V, 200 mA, 85 °C) V Forward voltage (36 V, 200 mA, 25 °C) V * 17.5 21 35 42 Refer to the Operating Limits section. Copyright © 2012-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 2 XLAMP ® CXA1507 LED OPERATING LIMITS The maximum current rating of the CXA1507 depends on the case temperature (Tc) when the LED has reached thermal equilibrium under steady-state operation. The graphs shown below assume that the system design employs good thermal management (thermal interface material and heat sink) and may vary when poor thermal management is employed. Please refer to the Mechanical Dimensions section on page 21 for the location of the Tc measurement point. Another important factor in good thermal management is the temperature of the Light Emitting Surface (LES). Cree recommends a maximum LES temperature of 135 °C to ensure optimal LED lifetime. Please refer to the Thermal Design section on page 22 for more CXA1507 - 18 V Standard information on LES temperature measurement. 800 104 °C, 750 mA 700 600 If (mA) 500 125 °C, 408 mA 400 18 V 300 200 100 0 0 25 CXA1507 - 36 V Standard 50 75 100 125 150 Case Temperature (°C) 400 104 °C, 375 mA 350 300 If (mA) 250 125 °C, 204 mA 200 36 V 150 100 50 0 0 25 50 75 100 125 150 Case Temperature (°C) Copyright © 2012-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 3 XLAMP ® CXA1507 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 18 V (IF = 400 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA1507 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 21). Nominal CCT CRI Min 70 Minimum Luminous Flux Typ 75 2-Step 3-Step 4-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* G4 840 938 H2 900 1005 H4 970 1084 CXA1507-0000000F00H465F G2 780 871 CXA1507-0000000F0HG265F G4 840 938 H2 900 1005 CXA1507-0000000F0HH265F G4 840 938 CXA1507-0000000F00G457F H2 900 1005 H4 970 1084 CXA1507-0000000F00H457F G2 780 871 CXA1507-0000000F0HG257F G4 840 938 H2 900 1005 G4 840 938 H2 900 1005 H4 970 1084 CXA1507-0000000F00H450H CXA1507-0000000F00H450F G2 780 871 CXA1507-0000000F0HG250H CXA1507-0000000F0HG250F G4 840 938 H2 900 1005 CXA1507-0000000F0HH250H F2 680 759 CXA1507-0000000F0UF250H F4 730 815 G2 780 871 Group Order Code Group Order Code Group CXA1507-0000000F00G465F 65F 6500 K 80 70 --- 75 65F 57F 5700 K 80 70 5000 K 80 90 --- 75 --- 95 Order Code 57F CXA1507-0000000F00H265F CXA1507-0000000F0HG465F CXA1507-0000000F00H257F CXA1507-0000000F0HG457F CXA1507-0000000F0HH257F CXA1507-0000000F00G450H 50H 50H 50H CXA1507-0000000F00G450F CXA1507-0000000F00H250H CXA1507-0000000F0HG450H CXA1507-0000000F0UF450H CXA1507-0000000F0UG250H 50F 50G CXA1507-0000000F0HG450G 50F CXA1507-0000000F0HH250G CXA1507-0000000F00H250F CXA1507-0000000F0HG450F CXA1507-0000000F0HH250F CXA1507-0000000F0UF250F 50G CXA1507-0000000F0UF450G CXA1507-0000000F0UG250G 50F CXA1507-0000000F0UF450F CXA1507-0000000F0UG250F Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 24). • Cree XLamp CXA1507 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. Copyright © 2012-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 4 XLAMP ® CXA1507 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 18 V (IF = 400 mA, TJ = 85 °C) - CONTINUED Nominal CCT CRI Min 70 4000 K 80 90 80 Minimum Luminous Flux Typ 75 --- 95 --- 2-Step 80 95 --- Group G4 840 938 H2 900 1005 H4 970 1084 CXA1507-0000000F00H440H CXA1507-0000000F00H440F G2 780 871 CXA1507-0000000F0HG240H CXA1507-0000000F0G240F G4 840 938 H2 900 1005 CXA1507-0000000F0HH240H E4 635 709 CXA1507-0000000F0UE440H F2 680 759 F4 730 815 CXA1507-0000000F0UF440H G2 780 871 CXA1507-0000000F00G235H G4 840 938 H2 900 1005 CXA1507-0000000F00H235H E2 590 659 CXA1507-0000000F0YE235H E4 635 709 F2 680 759 CXA1507-0000000F0YF235H F4 730 815 CXA1507-0000000F00F430H G2 780 871 G4 840 938 CXA1507-0000000F00G430H D4 550 614 CXA1507-0000000F0YD430H E2 590 659 E4 635 709 Group 95 Order Code Group Order Code Group CXA1507-0000000F00G440H 40H 40H 40H 35H 35H 30H 3000 K 93 4-Step Flux (lm) @ 25 °C* 3500 K 93 3-Step Flux (lm) @ 85 °C 30H CXA1507-0000000F00G440F CXA1507-0000000F00H240H CXA1507-0000000F0HG440H CXA1507-0000000F0UF240H CXA1507-0000000F00G435H CXA1507-0000000F0YE435H CXA1507-0000000F00G230H CXA1507-0000000F0YE230H CXA1507-0000000F0YE430H Order Code 40F 40G CXA1507-0000000F0HG440G 40F CXA1507-0000000F0HH240G CXA1507-0000000F00H240F CXA1507-0000000F0HG440F CXA1507-0000000F0HH240F CXA1507-0000000F0UE440F 40G CXA1507-0000000F0UF240G 40F CXA1507-0000000F0UF440G CXA1507-0000000F0UF240F CXA1507-0000000F0UF440F CXA1507-0000000F00G235F 35G CXA1507-0000000F00G435G 35F CXA1507-0000000F00H235G CXA1507-0000000F00G435F CXA1507-0000000F00H235F CXA1507-0000000F0YE235F 35G CXA1507-0000000F0YE435G 35F CXA1507-0000000F0YF235G CXA1507-0000000F0YE435F CXA1507-0000000F0YF235F CXA1507-0000000F00F430F 30G CXA1507-0000000F00G230G 30F CXA1507-0000000F00G430G CXA1507-0000000F00G230F CXA1507-0000000F00G430F CXA1507-0000000F0YD430F 30G CXA1507-0000000F0YE230G CXA1507-0000000F0YE430G 30F CXA1507-0000000F0YE230F CXA1507-0000000F0YE430F Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 24). • Cree XLamp CXA1507 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. Copyright © 2012-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 5 XLAMP ® CXA1507 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 18 V (IF = 400 mA, TJ = 85 °C) - CONTINUED Nominal CCT CRI Min 80 Minimum Luminous Flux Typ --- 2-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* F4 730 815 G2 780 871 G4 840 938 CXA1507-0000000F00G427H D2 510 569 CXA1507-0000000F0YD227H D4 550 614 E2 590 659 Group 95 Group Order Code 4-Step Group CXA1507-0000000F00F427H 27H 2700 K 93 Order Code 3-Step 27H CXA1507-0000000F00G227H CXA1507-0000000F0YD427H CXA1507-0000000F0YE227H Order Code CXA1507-0000000F00F427F 27G CXA1507-0000000F00G227G 27F CXA1507-0000000F00G427G CXA1507-0000000F00G227F CXA1507-0000000F00G427F CXA1507-0000000F0YD227F 27G CXA1507-0000000F0YD427G CXA1507-0000000F0YE227G 27F CXA1507-0000000F0YD427F CXA1507-0000000F0YE227F Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 24). • Cree XLamp CXA1507 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. Copyright © 2012-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 6 XLAMP ® CXA1507 LED FLUX CHARACTERISTICS, ANSI WHITE ORDER CODES AND BINS - 18 V (IF = 400 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA1507 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 21). Nominal CCT CRI Min 70 Minimum Luminous Flux Typ 75 6500 K 80 70 --- 75 5700 K 80 70 --- 75 5000 K 80 4000 K 70 --- 75 Chromaticity Regions Order Code Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* G4 840 938 H2 900 1005 H4 970 1084 CXA1507-0000-000F00H40E1 G2 780 871 CXA1507-0000-000F0HG20E1 G4 840 938 H2 900 1005 CXA1507-0000-000F0HH20E1 G4 840 938 CXA1507-0000-000F00G40E2 H2 900 1005 H4 970 1084 CXA1507-0000-000F00H40E2 G2 780 871 CXA1507-0000-000F0HG20E2 G4 840 938 H2 900 1005 CXA1507-0000-000F0HH20E2 G4 840 938 CXA1507-0000-000F00G40E3 H2 900 1005 H4 970 1084 CXA1507-0000-000F00H40E3 G2 780 871 CXA1507-0000-000F0HG20E3 G4 840 938 H2 900 1005 CXA1507-0000-000F0HH20E3 G4 840 938 CXA1507-0000-000F00G40E5 H2 900 1005 H4 970 1084 CXA1507-0000-000F00G40E1 1A0, 1B0, 1C0, 1D0, 65F 1A0, 1B0, 1C0, 1D0, 65F 2A0, 2B0, 2C0, 2D0, 57F 2A0, 2B0, 2C0, 2D0, 57F 3A0, 3B0, 3C0, 3D0, 50F 3A0, 3B0, 3C0, 3D0, 50F 5A0, 5B0, 5C0, 5D0, 40F CXA1507-0000-000F00H20E1 CXA1507-0000-000F0HG40E1 CXA1507-0000-000F00H20E2 CXA1507-0000-000F0HG40E2 CXA1507-0000-000F00H20E3 CXA1507-0000-000F0HG40E3 CXA1507-0000-000F00H20E5 CXA1507-0000-000F00H40E5 Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 24). • Cree XLamp CXA1507 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. Copyright © 2012-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 7 XLAMP ® CXA1507 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 36 V (IF = 200 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA1507 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 21). Nominal CCT CRI Min 70 Minimum Luminous Flux Typ 75 2-Step 3-Step 4-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* G4 840 938 H2 900 1005 H4 970 1084 CXA1507-0000000N00H465F G2 780 871 CXA1507-0000000N0HG265F G4 840 938 H2 900 1005 CXA1507-0000000N0HH265F G4 840 938 CXA1507-0000000N00G457F H2 900 1005 H4 970 1084 CXA1507-0000000N00H457F G2 780 871 CXA1507-0000000N0HG257F G4 840 938 H2 900 1005 G4 840 938 H2 900 1005 H4 970 1084 CXA1507-0000000N00H450H CXA1507-0000000N00H450F G2 780 871 CXA1507-0000000N0HG250H CXA1507-0000000N0HG250F G4 840 938 H2 900 1005 CXA1507-0000000N0HH250H F2 680 759 CXA1507-0000000N0UF250H F4 730 815 G2 780 871 Group Order Code Group Order Code Group CXA1507-0000000N00G465F 65F 6500 K 80 70 --- 75 65F 57F 5700 K 80 70 5000 K 80 90 --- 75 --- 95 Order Code 57F CXA1507-0000000N00H265F CXA1507-0000000N0HG465F CXA1507-0000000N00H257F CXA1507-0000000N0HG457F CXA1507-0000000N0HH257F CXA1507-0000000N00G450H 50H 50H 50H CXA1507-0000000N00G450F CXA1507-0000000N00H250H CXA1507-0000000N0HG450H CXA1507-0000000N0UF450H CXA1507-0000000N0UG250H 50F 50G CXA1507-0000000N0HG450G 50F CXA1507-0000000N0HH250G CXA1507-0000000N00H250F CXA1507-0000000N0HG450F CXA1507-0000000N0HH250F CXA1507-0000000N0UF250F 50G CXA1507-0000000N0UF450G CXA1507-0000000N0UG250G 50F CXA1507-0000000N0UF450F CXA1507-0000000N0UG250F Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 24). • Cree XLamp CXA1507 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. Copyright © 2012-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 8 XLAMP ® CXA1507 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 36 V (IF = 200 mA, TJ = 85 °C) - CONTINUED Nominal CCT CRI Min 70 4000 K 80 90 80 Minimum Luminous Flux Typ 75 --- 95 --- 2-Step 80 95 --- Group G4 840 938 H2 900 1005 H4 970 1084 CXA1507-0000000N00H440H CXA1507-0000000N00H440F G2 780 871 CXA1507-0000000N0HG240H CXA1507-0000000N0G240F G4 840 938 H2 900 1005 CXA1507-0000000N0HH240H E4 635 709 CXA1507-0000000N0UE440H F2 680 759 F4 730 815 CXA1507-0000000N0UF440H G2 780 871 CXA1507-0000000N00G235H G4 840 938 H2 900 1005 CXA1507-0000000N00H235H E2 590 659 CXA1507-0000000N0YE235H E4 635 709 F2 680 759 CXA1507-0000000N0YF235H F4 730 815 CXA1507-0000000N00F430H G2 780 871 G4 840 938 CXA1507-0000000N00G430H D4 550 614 CXA1507-0000000N0YD430H E2 590 659 E4 635 709 Group 95 Order Code Group Order Code Group CXA1507-0000000N00G440H 40H 40H 40H 35H 35H 30H 3000 K 93 4-Step Flux (lm) @ 25 °C* 3500 K 93 3-Step Flux (lm) @ 85 °C 30H CXA1507-0000000N00G440F CXA1507-0000000N00H240H CXA1507-0000000N0HG440H CXA1507-0000000N0UF240H CXA1507-0000000N00G435H CXA1507-0000000N0YE435H CXA1507-0000000N00G230H CXA1507-0000000N0YE230H CXA1507-0000000N0YE430H Order Code 40F 40G CXA1507-0000000N0HG440G 40F CXA1507-0000000N0HH240G CXA1507-0000000N00H240F CXA1507-0000000N0HG440F CXA1507-0000000N0HH240F CXA1507-0000000N0UE440F 40G CXA1507-0000000N0UF240G 40F CXA1507-0000000N0UF440G CXA1507-0000000N0UF240F CXA1507-0000000N0UF440F CXA1507-0000000N00G235F 35G CXA1507-0000000N00G435G 35F CXA1507-0000000N00H235G CXA1507-0000000N00G435F CXA1507-0000000N00H235F CXA1507-0000000N0YE235F 35G CXA1507-0000000N0YE435G 35F CXA1507-0000000N0YF235G CXA1507-0000000N0YE435F CXA1507-0000000N0YF235F CXA1507-0000000N00F430F 30G CXA1507-0000000N00G230G 30F CXA1507-0000000N00G430G CXA1507-0000000N00G230F CXA1507-0000000N00G430F CXA1507-0000000N0YD430F 30G CXA1507-0000000N0YE230G CXA1507-0000000N0YE430G 30F CXA1507-0000000N0YE230F CXA1507-0000000N0YE430F Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 24). • Cree XLamp CXA1507 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. Copyright © 2012-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 9 XLAMP ® CXA1507 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 36 V (IF = 200 mA, TJ = 85 °C) - CONTINUED Nominal CCT CRI Min 80 Minimum Luminous Flux Typ --- 2-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* F4 730 815 G2 780 871 G4 840 938 CXA1507-0000000N00G427H D2 510 569 CXA1507-0000000N0YD227H D4 550 614 E2 590 659 Group 95 Group Order Code 4-Step Group CXA1507-0000000N00F427H 27H 2700 K 93 Order Code 3-Step 27H CXA1507-0000000N00G227H CXA1507-0000000N0YD427H CXA1507-0000000N0YE227H Order Code CXA1507-0000000N00F427F 27G CXA1507-0000000N00G227G 27F CXA1507-0000000N00G427G CXA1507-0000000N00G227F CXA1507-0000000N00G427F CXA1507-0000000N0YD227F 27G CXA1507-0000000N0YD427G CXA1507-0000000N0YE227G 27F CXA1507-0000000N0YD427F CXA1507-0000000N0YE227F Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 24). • Cree XLamp CXA1507 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. Copyright © 2012-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 10 XLAMP ® CXA1507 LED FLUX CHARACTERISTICS, ANSI WHITE ORDER CODES AND BINS - 36 V (IF = 200 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA1507 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 21). Nominal CCT CRI Min 70 Minimum Luminous Flux Typ 75 6500 K 80 70 --- 75 5700 K 80 70 --- 75 5000 K 80 4000 K 70 --- 75 Chromaticity Regions Order Code Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* G4 840 938 H2 900 1005 H4 970 1084 CXA1507-0000-000N00H40E1 G2 780 871 CXA1507-0000-000N0HG20E1 G4 840 938 H2 900 1005 CXA1507-0000-000N0HH20E1 G4 840 938 CXA1507-0000-000N00G40E2 H2 900 1005 H4 970 1084 CXA1507-0000-000N00H40E2 G2 780 871 CXA1507-0000-000N0HG20E2 G4 840 938 H2 900 1005 CXA1507-0000-000N0HH20E2 G4 840 938 CXA1507-0000-000N00G40E3 H2 900 1005 H4 970 1084 CXA1507-0000-000N00H40E3 G2 780 871 CXA1507-0000-000N0HG20E3 G4 840 938 H2 900 1005 CXA1507-0000-000N0HH20E3 G4 840 938 CXA1507-0000-000N00G40E5 H2 900 1005 H4 970 1084 CXA1507-0000-000N00G40E1 1A0, 1B0, 1C0, 1D0, 65F 1A0, 1B0, 1C0, 1D0, 65F 2A0, 2B0, 2C0, 2D0, 57F 2A0, 2B0, 2C0, 2D0, 57F 3A0, 3B0, 3C0, 3D0, 50F 3A0, 3B0, 3C0, 3D0, 50F 5A0, 5B0, 5C0, 5D0, 40F CXA1507-0000-000N00H20E1 CXA1507-0000-000N0HG40E1 CXA1507-0000-000N00H20E2 CXA1507-0000-000N0HG40E2 CXA1507-0000-000N00H20E3 CXA1507-0000-000N0HG40E3 CXA1507-0000-000N00H20E5 CXA1507-0000-000N00H40E5 Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 24). • Cree XLamp CXA1507 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. Copyright © 2012-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 11 XLAMP ® CXA1507 LED Relative Spectral Power Distribution RELATIVE SPECTRAL POWER DISTRIBUTION The following graph is the result of a series of pulsed measurements at 400 mA for the 18-V CXA1507 LED and 200 mA for the 36-V CXA1507 LED and TJ = 85 °C. 100% Relative Spectral Power 90% 80% 70% 60% 5000 K, 70 CRI 50% 4000 K, 70 CRI 40% 3000 K, 80 CRI 30% 3000 K, 93 CRI 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Copyright © 2012-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 12 XLAMP ® CXA1507 LED ELECTRICAL CHARACTERISTICS The following graphs are the result of a series of steady-state measurements. 19.5 18 V Voltage (V) 19.0 18.5 Tc = 25 °C 18.0 Tc = 55 °C 17.5 Tc = 105 °C Tc = 85 °C 17.0 16.5 200 250 300 350 400 450 500 550 600 650 700 750 Current (mA) 39 36 V 38 Voltage (V) 37 Tc = 25 °C Tc = 55 °C 36 Tc = 85 °C Tc = 105 °C 35 34 33 100 125 150 175 200 225 250 275 300 325 350 375 Current (mA) Copyright © 2012-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 13 XLAMP ® CXA1507 LED RELATIVE LUMINOUS FLUX The relative luminous flux values provided below are the ratio of: • Measurements of CXA1507 at steady-state operation at the given conditions, divided by • Flux measured during binning, which is a pulsed measurement at 400 mA at TJ = 85 °C for the 18-V CXA1507 LED. Using the 18-V CXA1507 LED as an example, at steady-state operation of Tc = 25 °C, IF = 650 mA, the relative luminous flux ratio is 160% in the chart below. A CXA1507 LED that measures 710 lm during binning will deliver 1136 lm (710 * 1.6) at steady-state operation of Tc = 25 °C, IF = 650 mA. 180% Relative Luminous Flux 160% 18 V 140% 120% Tc = 25 °C 100% Tc = 55 °C 80% Tc = 85 °C Tc = 105 °C 60% 40% 20% 0% 200 250 300 350 400 450 500 550 600 650 700 750 Current (mA) Copyright © 2012-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 14 XLAMP ® CXA1507 LED RELATIVE LUMINOUS FLUX - CONTINUED The relative luminous flux values provided below are the ratio of: • Measurements of CXA1507 at steady-state operation at the given conditions, divided by • Flux measured during binning, which is a pulsed measurement at 200 mA at TJ = 85 °C for the 36-V CXA1507 LED. Using the 36-V CXA1507 LED as an example, at steady-state operation of Tc = 25 °C, IF = 325 mA, the relative luminous flux ratio is 150% in the chart below. A CXA1507 LED that measures 710 lm during binning will deliver 1136 lm (710 * 1.6) at steady-state operation of Tc = 25 °C, IF = 325 mA. 180% 160% 36 V Relative Luminous Flux 140% 120% Tc = 25 °C 100% Tc = 55 °C Tc = 85 °C 80% Tc = 105 °C 60% 40% 20% 0% 100 125 150 175 200 225 250 275 300 325 350 375 Current (mA) Copyright © 2012-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 15 XLAMP ® CXA1507 LED Far Field TYPICAL SPATIAL DISTRIBUTION 100% Relative Luminous Intensity 80% 60% 40% 20% -90 -70 -50 -30 -10 0% 10 30 50 70 90 Angle (º) PERFORMANCE GROUPS - BRIGHTNESS (18 V, I F = 400 mA; 36 V, IF = 200 mA, TJ = 85 °C) XLamp CXA1507 LEDs are tested for luminous flux and placed into one of the following bins. Group Code Minimum Luminous Flux Maximum Luminous Flux D2 510 550 D4 550 590 E2 590 635 E4 635 680 F2 680 730 F4 730 780 G2 780 840 G4 840 900 H2 900 970 H4 970 1040 J2 1040 1120 Copyright © 2012-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 16 XLAMP ® CXA1507 LED PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) XLamp CXA1507 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. EasyWhite Color Temperatures – 2-Step Code 50H 40H 35H 30H 27H CCT 5000 K 4000 K 3500 K 3000 K 2700 K x y 0.3429 0.3507 0.3434 0.3571 0.3475 0.3604 0.3469 0.3539 0.3784 0.3741 0.3804 0.3818 0.3867 0.3857 0.3844 0.3778 0.4030 0.3857 0.4061 0.3941 0.4132 0.3976 0.4099 0.3890 0.4291 0.3973 0.4333 0.4062 0.4395 0.4084 0.4351 0.3994 0.4528 0.4046 0.4578 0.4138 0.4638 0.4152 0.4586 0.4060 EasyWhite Color Temperatures – 3-Step Ellipse Major Axis Minor Axis x y a b Rotation Angle (°) 5000 K 0.3447 0.3553 0.00840 0.00312 65.0 40G 4000 K 0.3818 0.3797 0.00939 0.00402 53.7 35G 3500 K 0.4073 0.3917 0.00927 0.00414 54.0 30G 3000 K 0.4338 0.4030 0.00834 0.00408 53.2 27G 2700 K 0.4577 0.4099 0.00834 0.00420 48.5 Bin Code CCT 50G Center Point Copyright © 2012-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 17 XLAMP ® CXA1507 LED PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) - CONTINUED EasyWhite Color Temperatures – 4-Step Code 65F 57F 50F 40F 35F 30F 27F CCT 6500 K 5700 K 5000 K 4000 K 3500 K 3000 K 2700 K x y 0.3097 0.3196 0.3079 0.3297 0.3164 0.3382 0.3176 0.3275 0.3253 0.3325 0.3249 0.3439 0.3331 0.3514 0.3330 0.3393 0.3407 0.3459 0.3415 0.3586 0.3499 0.3654 0.3484 0.3521 0.3744 0.3685 0.3782 0.3837 0.3912 0.3917 0.3863 0.3758 0.3981 0.3800 0.4040 0.3966 0.4186 0.4037 0.4116 0.3865 0.4242 0.3919 0.4322 0.4096 0.4449 0.4141 0.4359 0.3960 0.4475 0.3994 0.4573 0.4178 0.4695 0.4207 0.4589 0.4021 Copyright © 2012-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 18 XLAMP ® CXA1507 LED PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) - CONTINUED ANSI White Bins Code Bin Code CCT 1A0 1B0 0E1 6500 K 1C0 1D0 ANSI White Bins x y 0.3048 0.3130 0.3144 0.3186 0.3068 0.3028 CCT y 0.3207 0.3215 0.3350 0.3290 0.3290 0.3417 0.3290 0.3300 0.3113 0.3222 0.3243 0.3304 0.3207 0.3462 0.3115 0.3391 0.3290 0.3538 0.3130 0.3290 0.3290 0.3417 0.3048 0.3207 0.3215 0.3350 0.3115 0.3391 0.3290 0.3538 0.3205 0.3481 0.3376 0.3616 0.3213 0.3373 0.3371 0.3490 0.3130 0.3290 0.3290 0.3417 0.3130 0.3290 0.3290 0.3417 0.3213 0.3373 0.3371 0.3490 0.3221 0.3261 0.3366 0.3369 0.3290 0.3300 2A0 2B0 0E2 5700 K 2C0 2D0 0.3186 ANSI White Bins Code CCT Bin Code 3A0 3B0 0E3 5000 K 3C0 3D0 Bin Code x 0.3144 Code ANSI White Bins x y .3371 .3451 .3440 .3427 .3366 .3369 .3376 .3463 .3451 .3554 .3371 .3490 .3463 .3687 .3551 .3760 .3533 .3620 .3451 .3554 .3451 .3533 .3515 .3487 .3440 .3427 Code CCT Bin Code x y .3490 .3670 .3578 .3554 .3702 .3722 .3825 .3798 .3783 .3646 .3616 .3702 .3722 .3687 .3736 .3874 .3869 .3958 .3825 .3798 .3825 .3798 .3869 .3958 .4006 .4044 .3950 .3875 .3554 .3783 .3646 .3620 .3825 .3798 .3950 .3875 .3898 .3716 5A0 5B0 0E5 4000 K 5C0 5D0 Copyright © 2012-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 19 XLAMP ® CXA1507 LED CREE EASYWHITE® BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) 0.44 2700 K ANSI C78.377 Quadrangle 0.43 3000 K EasyWhite 4-Step EasyWhite 3-Step 0.42 EasyWhite 2-Step 3500 K 0.41 4000 K 0.40 4500 K CCy 0.39 5000 K 0.38 0.37 5700 K 0.36 6500 K 0.35 0.34 0.33 0.32 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.31 CCx CREE ANSI WHITE BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) 0.41 4000 K ANSI C78.377 Quadrangle 0.40 4500 K 5C 0.39 5D 0.37 CCy 5B 5000 K 0.38 5700 K 0.36 5A 3C 3B 6500 K 0.35 2B 0.34 1C 1B 0.33 3D 2C 1D 3A 2D 2A 1A 0.32 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.31 CCx Copyright © 2012-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 20 XLAMP ® CXA1507 LED BIN AND ORDER CODE FORMATS Bin codes and order codes are configured as follows: Order Code Bin Code Series = CXA15 Series = CXA15 Internal code Chromaticity bin CRI Specification 0 = Standard CRI H = 80 CRI minimum U = 90 CRI minimum Y = 93 CRI minimum Vf class F0 = 18-V class N0 = 36-V class SSSSSCC-HHHH-HHHGGRNNNNN Internal code SSSSSCC-WWW-FF-GGR-AAAAA CRI Specification B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Y = 93 CRI minimum Kit code Vf class F0 = 18-V class N0 = 36-V class Flux bin Performance class Performance class MECHANICAL DIMENSIONS Dimensions are in mm. Tolerances unless otherwise specified: +.13 x° +1° 1507F = 18‑V CXA1507 1507N = 36‑V CXA1507 1507X Meaning of 1507X Copyright © 2012-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 21 XLAMP ® CXA1507 LED THERMAL DESIGN The CXA family of LED arrays can include over a hundred different LED die inside one package, and thus over a hundred different junction temperatures (TJ). Cree has intentionally removed junction-temperature-based operating limits and replaced the commonplace maximum TJ calculations with maximum ratings based on forward current (IF) and case temperature (Tc). No additional calculations are required to ensure that the CXA LED is being operated within its designed limits. LES temperature measurement provides additional verification of good thermal design. Please refer to page 3 for the Operating Limit specifications. There is no need to calculate for TJ inside the package, as the thermal management design process, specifically from TSP to ambient (Ta), remains identical to any other LED component. For more information on thermal management of Cree XLamp LEDs, please refer to the Thermal Management application note. For CXA soldering recommendations and more information on thermal interface materials (TIM), LES temperature measurement, and connection methods, please refer to the Cree XLamp CX Family LEDs soldering and handling document. The CX Family LED Design Guide provides basic information on the requirements to use Cree XLamp CXA LEDs successfully in luminaire designs. To keep the CXA1507 LED at or below the maximum rated Tc, the case to ambient temperature thermal resistance (R_c-a) must be at or below the maximum R_c-a value shown on the following R_j-c R_j-c scale. Tc Tc As the figure at right shows, the R_c-a value is the sum of the thermal resistance of the TIM (R_tim) R_tim graphs, depending on the operating environment. The y‑axis in the graphs is a base 10 logarithmic R_c-a plus the thermal resistance of the heat sink (R_hs). R_hs CXA1507 - 18 V Ta Ta 100.00 18 V Maximum R_c-a 10.00 Ta = 25 °C Ta = 55 °C 1.00 Ta = 85 °C Ta = 105 °C 0.10 0.01 200 250 300 350 400 450 500 550 600 650 700 750 Current (mA) Copyright © 2012-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 22 XLAMP ® CXA1507 LED CXA1507 - 36-VCONTINUED THERMAL DESIGN 100.00 36 V Maximum R_c-a 10.00 Ta = 25 °C Ta = 55 °C 1.00 Ta = 85 °C Ta = 105 °C 0.10 0.01 100 125 150 175 200 225 250 275 300 325 350 375 Current (mA) Copyright © 2012-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 23 XLAMP ® CXA1507 LED NOTES Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree applies to ensure long-term reliability for XLamp LEDs and details of Cree’s pre-release qualification testing for XLamp LEDs. Lumen Maintenance Cree now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree representative or from the Product Ecology section of the Cree website. REACh Compliance REACh substances of high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree representative to insure you get the most up-to-date REACh SVHC Declaration. REACh banned substance information (REACh Article 67) is also available upon request. UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. Copyright © 2012-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 24 XLAMP ® CXA1507 LED PACKAGING 6 Cree CXA1507 LEDs are packaged in trays of 20. Five trays are4 sealed in an anti-static bag and placed inside a carton, for a total of 100 5 3 2 LEDs per carton. Each carton contains 100 LEDs from the same performance bin. NOTICE ENTIAL. THIS PLOT AND THE INFORMATION WITHIN ARE THE PROPRIETARY AND AL INFORMATION OF CREE, INC. THIS PLOT COPIED, REPRODUCED OR DISCLOSED TO ANY ED PERSON WITHOUT THE WRITTEN CONSENT Dimensions are in inches. Tolerances: +.13 x° +1° 5.875 4 5 6 3 5 2 R .375 4 1 3 2 1 NOTICE ENTIAL. THIS PLOT AND THE INFORMATION WITHIN ARE THE PROPRIETARY AND L INFORMATION OF CREE, INC. THIS PLOT COPIED, REPRODUCED OR DISCLOSED TO ANY NSENT ED PERSON WITHOUT THE WRITTEN CONSENT 5.875 .875 5.875 R .375 R .375 5.875 .875 .875 5.875 LABEL WITH CREE BIN CODE, QUANTITY, LOT # PATENT LABEL IS LOCATED ON UNDERSIDE OF COVER PATENT LABEL ISBIN LOCATED LABEL WITH CREE CODE, QUANTITY, OF LOTCARTON # ON UNDERSIDE TH CREE BIN ANTITY, LOT # PATENT LABEL IS LOCATED ON UNDERSIDE .875 OF COVER BAG .38 .875 BAG .38 .875 BAG .38 LABEL WITH CREE BIN CODE, QUANTITY, LOT # L IS LOCATED IDE OF COVER LABEL WITH CREE BIN CODE, QUANTITY, LOT # LABEL WITH CREE BIN CODE, QUANTITY, LOT # LABEL WITH CREE BIN CODE, QUANTITY, LOT # UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS & BEFORE FINISH. TOLERANCE UNLESS SPECIFIED: LABEL WITH CREE BIN CODE, QUANTITY, LOT # UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN THIRD ANGLE PROJECTION MILLIMETERS & BEFORE FINISH. TOLERANCE UNLESS SPECIFIED: LABEL WITH CREE BIN CODE, QUANTITY, LOT # THIRD ANGLE PROJECTION 6 5 6 WITH CREE BIN QUANTITY, LOT # 5 Copyright © 2012-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without Inc. UL® and the UR logo are registered trademarks of UL LLC. THIRD ANGLE PROJECTION 3.X ± .XX ± .XXX ± X° ± UNLESS OTHERWISE SPECIFIED 3 DIMENSIONS ARE IN MILLIMETERS & BEFORE FINISH. ® notice. Cree , the Cree logo, TOLERANCE UNLESS SPECIFIED: .X ± .XX ± .XXX ± X° ± 0.1 .05 .005 1 ° DATE 0.1 .05 .005 1 ° FOR SHEET METAL PARTS ONLY .X ± .06 0.1 .05 .005 1 ° .06 .03 .010 2 ° DRAWN BY DATE DATE APPROVED DATE DATE FOR SHEET METAL PARTS ONLYDATE APPROVED .X ± .06 .XX ± .03 MATERIAL .XXX ± .010 X° ± 2 ° FOR SHEET METAL PARTS ONLY .X ± .XX ± .XXX ± X° ± 4 4 .X ± DRAWN BY .XX ± .XXX ± CHECK ± X° DRAWN BY CHECK TITLE CXA15 Phone (919) 361- Fax (919) 313-530 SIZE C CXA15XX_DATASHEET TITLE SCALE SIZE SCALE C 2 DATE APPROVED DATE CXA15XX_DATASHEET_BAG2013 0.500 SHEET OF 1 Drive 4600 Silicon Durham, N.C 27703 XLamp® and EasyWhite® are registered trademarks of Cree, Phone (919) 361-4770 Fax (919) 313-5303 TITLE CXA15XX_DATASHEET 25 MATERIAL SIZE FINAL PROTECTIVE FINISH CXA 0.500 DRAWING NO. 2 CHECK DRAW FINAL PROTECTIVE FINISH FINAL PROTECTIVE FINISH DATE 4600 Silicon Drive Durham, N.C 277 MATERIAL DRAWING NO. CXA15XX_DATASHEET_BAG2013
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件可以实现多路信号的切换和分配,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为4mm x 4mm。
CXA1507-0000-000F0HG440G 价格&库存
很抱歉,暂时无法提供与“CXA1507-0000-000F0HG440G”相匹配的价格&库存,您可以联系我们找货
