CXM-9-30-80-36-AC12-F3-3 数据手册
Sensus™ LED Series Product Datasheet
Generation 2
Sensus™ LED Series
Pure White Targeted COB Arrays
Below the Black Body Locus (BBL)
Preliminary Data Sheet
Features:
• Matching the human perception of “Pure white” light
Table of Contents
Technology Overview. . . . . . 2
Test Specifications . . . . . . . . . 2
• Designed to provide the look and feel of ceramic metal halide lights
• Wide product range from 300lm to over 5,000lm
• 3000K and 3500K, 80 and 90CRI standard
• 3 SDCM color binning accuracy
Chromaticity Bins. . . . . . . . . . 3
• Excellent optical emission uniformity and color over angle consistency
Product Ordering & Shipping
Part Numbers. . . . . . . . . . . . . . 4
• Exceptional long term color stability
Product Typical Flux Range. 5
• Environmentally friendly: RoHS and REACH compliant
Operating Characteristics . . 6
• Package thermal conductivity more than the industry average
• UL Recognized, File # E465703
Optical and Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . . . 9
Spectra. . . . . . . . . . . . . . . . . . . 13
Mechanical Dimensions. . . 14
Packaging Information. . . . 14
Handling Notes. . . . . . . . . . . 21
Applications
• Retail Shop Lighting
• Halogen replacement LED lamps
• Spotlights/Track Lights
• Hospitality Lighting
• CMH replacement LED lamps
• Architectural and Specialty
1
PDS-002710 Rev 04
© 2016 Luminus Devices, Inc. - All Rights Reserved
Sensus LED™ Series Product Datasheet
Technology Overview
Luminus Chip-on-Board (COB) LED series offers a complete lighting class solution designed for high performance illumination
applications. The Sensus LED series has been specially design for retail shop lighting where enhanced red coloring is a preferred lighting
standard. The selection covers a wide lumen range from less than 500lm to over 5,000lm, and is focused on the major market color and
CRI of 3000K and both 80 and 90 CRI. These breakthroughs allow illumination engineers and designers to develop beautifully lit spaces
without sacrificing efficacy, brightness and overall quality.
Reliability
Designed from the ground up, the Luminus COB LED is one of
the most reliable light sources in the world today. Having
passed a rigorous suite of environmental and mechanical stress
tests, including mechanical shock, vibration, temperature
cycling and humidity. Only then are the devices qualified for
use in a wide range of lighting application including some of the
most demanding commercial applications. Delivered with fully
qualified LM-80 test data and TM-21 lifetime results that certify
lumen maintenance at 35,000 hours or more, Luminus COB
LEDs are ready for the toughest challenges.
UL Recognized Compliance
Luminus COB arrays are tested in accordance with ANSI/UL 8750
to ensure safe operation for their intended applications.
REACH & RoHS Compliance
All LED products manufactured by Luminus are REACH and
RoHS compliant and free of hazardous materials, including lead
and mercury.
Understanding Luminus COB LED Test Specifications
Every Luminus LED is fully tested to ensure it meets the high quality standards customers have come to expect from Luminus’ products.
Traceability
Chromaticity Bin Range
Each Luminus COB LED is marked with a 2D bar code that
contains a unique serial number. With this serial number,
Luminus has the ability to provide customers with actual test
data measurements for a specific LED. In addition, the 2D bar
code is linked to manufacturing date codes that enables
traceability of production processes and materials.
Chromaticity binning delivers color consistency for every order.
Standard products are delivered with a 3-step MacAdam ellipse.
This ensures color performance matching in the application.
These tightly controlled, small distribution bins provide
customers predictable, repeatable colors.
Testing Temperature
Luminus COB products are measured at temperatures typical for
the LED operating in the fixture. Each device is tested at 85ºC
junction temperature eliminating the need to scale data sheet
specifications to real world situations.
2
PDS-002710 Rev 04
Chromaticity Bin Structure
Chromaticity Bins: 1931 CIE Curve
ANSI
C78.377-2008
ANSI
C78.377-2008
3-SDCM
3-SDCM
0.45
0.4500
2-SDCM
3000K
3000K
0.4300
0.43
3500K
3500K
CIEy
CIEy
0.4100
0.41
Black
Locus
Black Body
Body Locus
0.3900
0.39
0.3700
0.37
0.3500
0.35
0.3300
0.3700
0.33
0.37
0.3800
0.3900
0.4000
0.4100
0.4200
0.4300
0.4400
0.4500
0.4600
0.4700
0.38
0.39
0.4
0.41
0.42
CIEx
0.43
0.44
0.45
0.46
0.47
CIEx
Sensus™ LED White Chromaticity Bins
The following tables describe the ANSI bin center points, the orientation angle for the MacAdam ellipse (θ °), and the maximum radii for
the ellipses. The ANSI Bin is provided for reference.
3-step Bin
Center Point
*Note:
CCT
CIEx
CIEy
θ (°)
a
b
3000K
0.4252
0.3877
53.6
0.00834
0.00408
3500K
0.4067
0.3845
54
0.00927
0.00414
Luminus maintains a +/- 0.005 tolerance on chromaticity (CIEx and CIEy) measurements.
3
PDS-002710 Rev 04
Product Ordering and Shipping Part Number Nomenclature
All Sensus LED products are packaged and labeled with part numbers as outlined in the table on page 5. Luminus will include any
smaller chromaticity bin that is contained in the larger bin as part of the ordered part. When shipped, each package will contain only a
single flux and chromaticity bin. The part number designation is as follows:
Sensus™ LED Series
CXM
XX
30
80
Light Emitting
Color
Color RenderSurface Diameter1 Temperature2 ing Index (CRI)3
Product Family
XX: LES
Diameter (mm) Approximate
CHM: Chip on
Board
CT
XX
36
QQPP
FG
W
Voltage
(typical)
Package
Configurator
Flux Bin
Chromaticity
Bin
Volts
AA12
(Basic package)
Lumens
See page 3 for
bins
Note 1 : XX nomenclature corresponds to the following:
9 = 9mm
14 = 13.5mm
18 = 17.5mm
22 = 22mm
Note 2: CT Nomenclature corresponds to the following
30 is 3000K
35 is 3500K
Note 3: XX Color Rendering nomenclature corresponds to the following
80 = 80 CRI
90 = 90 CRI
95 = 95 CRI
Note 4: AA12 is a standard package configurator
AC12 is an alternative substrate size
Color Temperature, CRI and R9 Values
Color Temperatures
3000K, 3500K
Note:
XX Value
CRI
R9
80
>80
>0
90
>90
>50
Luminus part numbers may be accompanied by prefixes or suffixes. The most common is the “Rev01” suffix indicating a part is fully released
and carries a full warranty. These additional characters may appear on shipping labels, packing slips and invoices. In all cases the basic part
number described above will always be included.
4
PDS-002710 Rev 04
Sensus™ LED
Product
Datasheet
(PartSeries
#) Product
Datasheet
Sensus™ LED Series Part Numbers (Typical)
The following tables describe products with typical flux and minimum flux measured at typical currents and specified at 85ºC. The values
at 25ºC are calculated and shown for reference only. All product is measured and specified at 85ºC junction temperature.
Output Flux (lm)
Ordering Part Number
Typ.
Typ.
(85ºC)
Min.
(85ºC)
(calculated)
1,025
975
1,130
CRI
(25ºC)
1,000
1,175
870
825
965
865
1,000
2,125
1,980
2,825
2,040
2,425
1,795
1,675
1,995
CXM-9-35-80-36-AC12-F3-3
240
CXM-9-30-90-36-AA12-F3-3
CXM-9-35-90-36-AC12-F3-3
CXM-9-35-90-36-AA12-F3-3
CXM-14-30-80-36-AC12-F3-3
480
CXM-14-30-80-36-AA12-F3-3
CXM-14-35-80-36-AC12-F3-3
CXM-14-35-80-36-AA12-F3-3
CXM-14-30-90-36-AC12-F3-3
90
1,725
1,755
1,910
3,535
3,355
3,920
80
3,010
2,855
3,335
90
5,645
5,360
6,210
80
4,800
4,555
5,280
90
5,020
4,670
5,520
90
480
CXM-14-30-90-36-AA12-F3-3
CXM-14-35-90-36-AC12-F3-3
CXM-14-35-90-36-AA12-F3-3
800
CXM-18-30-80-36-AA12-F3-3
CXM-18-30-90-36-AA12-F3-3
CXM-22-30-80-36-AC12-F3-3
1,280
*Note:
Luminus maintains a +/- 6% tolerance on flux measurements.
Luminus maintains a +/- 2% tolerance on CRI measurements.
5
PDS-002710 Rev 04
CXM-9-30-80-36-AA12-F3-3
CXM-9-30-90-36-AC12-F3-3
80
2,185
240
CXM-9-35-80-36-AA12-F3-3
90
910
3 SDCM
80
1,055
Typ.
Current
(mA)
CXM-22-30-90-36-AC12-F3-3
CXM-22-35-90-36-AC12-F3-3
Output Flux (lm)
Typ. (85ºC)
Min. (85ºC)
1,530
1,420
Typ.
(calculated) (25ºC)
CRI
1,200
1,115
1,320
1,290
1,200
1,420
1,480
1,750
3,080
2,860
3,380
2,260
2,670
2,610
2,430
2,870
CHM-9-35-90-36-AC12-F3-3
720
CHM-14-30-80-36-AA12-F3-3
CHM-14-35-80-36-AC12-F3-3
CHM-14-30-90-36-AC12-F3-3
CHM-9-30-90-36-AA12-F3-3
CHM-14-35-80-36-AA12-F3-3
*Note:
PDS-002710 Rev 04
360
CHM-14-30-80-36-AC12-F3-3
2,530
6
CHM-9-35-80-36-AC12-F3-3
CHM-9-35-90-36-AA12-F3-3
90
2,980
CHM-9-30-80-36-AA12-F3-3
CHM-9-30-90-36-AC12-F3-3
80
2,430
360
CHM-9-35-80-36-AA12-F3-3
90
1,590
3 SDCM
CHM-9-30-80-36-AC12-F3-3
1,680
80
3,210
Typ. Current
(mA)
720
CHM-14-30-90-36-AA12-F3-3
CHM-14-35-90-36-AC12-F3-3
CHM-14-35-90-36-AA12-F3-3
Sensus™ LED
Product
Datasheet
(PartSeries
#) Product
Datasheet
CXM-9 Operating Characteristics1
Parameter
Symbol
2
Forward Current
If
Forward Voltage3
Vf
Minimum
Typical
Maximum
Unit
240
550
mA
35
37.5
V
8.6
21
W
100
ºC
32
Power
Operating Case Temperature4
Tc
Light Emitting Surface Diameter
LES
9
mm
Thermal Resisitance (junction-to-case)
Qjc
1.51
ºC/W
Junction Temperature
Tj
140
Viewing Angle
120
ºC
Degree
CXM-14 Operating Characteristics1
Parameter
Symbol
Forward Current2
If
Forward Voltage
Vf
3
Minimum
Maximum
Unit
480
1,,090
mA
35
37.5
V
17.3
41
W
105
ºC
32
Power
Typical
Tc
LES
13.5
mm
Qjc
0.87
ºC/W
Tj
140
Viewing Angle
120
ºC
Degree
CXM-18 Operating Characteristics1
Parameter
Symbol
2
Forward Current
If
Forward Voltage3
Vf
Power
Minimum
32
Typical
Maximum
Unit
800
1,800
mA
35
37.5
V
29
67.5
W
105
ºC
Tc
LES
17.5
mm
Qjc
0.56
ºC/W
Viewing Angle
140
120
7
PDS-002710 Rev 04
Tj
ºC
Degree
CXM-22 Operating Characteristics1
Parameter
Symbol
Forward Current2
If
Forward Voltage
Vf
3
Minimum
32
Power
Typical
Maximum
Unit
1,280
2,900
mA
35
37.5
V
45
109
W
105
ºC
Tc
LES
22
mm
Qjc
N/A
ºC/W
Tj
140
Viewing Angle
120
ºC
Degree
CHM-9 Operating Characteristics1
Parameter
Symbol
Forward Current2
If
Forward Voltage
Vf
3
Minimum
32
Power
4
Typical
Maximum
Unit
360
550
mA
34.5
37.5
V
12.5
21
W
105
ºC
Tc
LES
9
mm
Qjc
0.85
ºC/W
Tj
140
Viewing Angle
120
ºC
Degree
CHM-14 Operating Characteristics1
Parameter
Symbol
Forward Current2
If
Forward Voltage
Vf
3
Power
4
Minimum
32
Typical
Maximum
Unit
720
1,090
mA
34.5
37.5
V
24.8
41
W
105
ºC
Tc
LES
13.5
mm
Qjc
0.45
ºC/W
Tj
Viewing Angle
140
120
ºC
Degree
Operating Characteristics Notes
Note 1: Ratings are based on operation at a constant junction temperature Tj = 85ºC.
Note 2: To prevent damage refer to operating conditions and derating curves for appropriate maximum operating conditions
Note 3: Forward voltage is rated at typical forward current. For voltage at different forward currents, refer to the voltage versus current performance graphs.
Note 4: COB LEDs are designed for operation to a minimum of 20% of the typical forward current value. Operation at currents lower than this value will not
harm the device but may result in uneven light emission across the LES surface.
Note 5: Luminus may change any specifications without prior notice. Please refer to the company web site for the latest data sheet revision
Note 6: Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye.
9
PDS-002710 Rev 04
CXM-9 Optical & Electrical Characteristics
Relative Output Flux vs. Forward Current @ 85ºC
Forward Current vs. Forward Voltage @ 85ºC
250.0%
500
450
Forward Current (mA)
Relative Luminous Flux
200.0%
150.0%
100.0%
400
350
300
250
200
50.0%
150
0.0%
100
150
200
250
300
350
400
450
100
500
32
33
34
35
Relative Output Flux vs. Junction Temperature
37
38
39
40
Change in Voltage vs. Junction Temperature
1.2
40
1
38
Forward Voltage (V)
36
Forward Voltage (V)
0.8
0.6
0.4
36
34
32
0.2
30
15
25
35
45
55
65
75
Junction Temperature (ºC)
10
PDS-002710 Rev 04
85
95
105
5
15
25
35
45
55
65
75
85
95
105
CXM-14 Optical & Electrical Characteristics
250%
1000
200%
150%
100%
50%
800
600
400
200
0%
350
450
550
650
750
850
950
1050
34
35
36
38
39
40
40
120%
100%
38
Forward Voltage (V)
37
Forward Voltage (V)
80%
60%
40%
36
34
32
20%
30
0%
5
15
25
35
45
55
65
75
85
95
5
105
15
25
35
45
55
65
75
85
95
105
CXM-18 Optical & Electrical Characteristics
250%
1700
1500
200%
150%
100%
50%
1300
1100
900
700
500
0%
600
800
1000
1200
1400
11
PDS-002710 Rev 04
1600
1800
33
34
35
36
Forward Voltage (V)
37
38
39
120%
40
38
Forward Voltage (V)
100%
80%
60%
40%
36
34
32
20%
30
0%
5
15
25
35
45
55
65
75
85
95
105
5
15
25
35
45
55
65
75
85
95
105
CXM-22 Optical & Electrical Characteristics
250.00%
2900
2500
200.00%
150.00%
100.00%
2100
1700
1300
900
50.00%
500
0.00%
600
800
1000
1200
1400
1600
1800
2000
2200
2400
2600
100
32.0
2800
32.5
33.0
33.5
34.5
35.0
35.5
36.0
36.5
37.0
120.00%
35.50
115.00%
35.00
Forward Voltage (V)
34.0
Forward Voltage (V)
34.50
34.00
33.50
110.00%
105.00%
100.00%
95.00%
90.00%
33.00
5
15
25
35
45
55
65
75
Junction Temperature (℃)
12
PDS-002710 Rev 04
85
95
105
5
15
25
35
45
55
65
75
85
95
105
Sensus™ LED
Product
Datasheet
(PartSeries
#) Product
Datasheet
CHM-9 Optical & Electrical Characteristics
160%
550
140%
450
120%
100%
80%
60%
40%
350
250
150
20%
0%
100
150
200
250
300
350
400
450
500
50
550
31
32
33
35
36
37
38
120.0%
40
100.0%
38
Forward Voltage (V)
34
Forward Voltage (V)
80.0%
60.0%
40.0%
36
34
32
20.0%
0.0%
30
5
15
25
35
45
55
65
75
85
95
105
5
15
25
35
45
55
65
75
85
95
105
CHM-14 Optical & Electrical Characteristics
180%
1100
160%
1000
140%
120%
100%
80%
60%
900
800
700
600
40%
500
20%
0%
400
300
400
500
600
700
800
900
13
PDS-002710 Rev 04
1000
1100
34
34.5
35
35.5
36
Forward Voltage (V)
36.5
37
37.5
Sensus™ LED
Product
Datasheet
(PartSeries
#) Product
Datasheet
120%
40
100%
38
Forward Voltage (V)
80%
60%
40%
36
34
32
20%
0%
30
5
15
25
35
45
55
65
75
85
95
105
5
15
25
35
45
55
65
75
85
95
105
Chromaticity Shift Characteristics
Change CIEx vs. Junction Temperature (3000K, 80CRI)
Change CIEy vs. Junction Temperature (3000K, 80CRI)
0.02
40
38
Forward Voltage (V)
Δ CIEx
0.01
36
34
32
-0.02
5
15
25
35
45
55
65
75
14
PDS-002710 Rev 04
85
95
105
30
5
15
25
35
45
55
65
75
85
95
105
Optical Characteristics
Typical Spectrum
120.00%
Relative Intensity
100.00%
80.00%
60.00%
40.00%
20.00%
0.00%
400
450
500
550
600
650
700
750
800
Wavelength (nm)
Typical Polar Radiation Pattern
Typical Angular Radiation Pattern
120%
100%
Relative Intensity (%)
80%
60%
40%
20%
0%
-80
-60
-40
-20
Anglular Displacement (Degrees)
15
PDS-002710 Rev 04
40
60
80
Mechanical Dimensions, CHM/CXM-9 (AA10)
Mechanical Dimensions, CHM/CXM-9 (AC10)
16
PDS-002710 Rev 04
Shipping Container, CHM/CXM-9 (AA00)
Shipping Container, CHM/CXM-9 (AC00)
Each bag is boxed for
easier storage/stacking
Trays are sealed in an
anti-static bag
Label
Customer
Part Number
Lot ID
Quantity
17
PDS-002710 Rev 04
5 trays are stacked together
with one tray as a cover
Sensus™ LED
Product
Datasheet
(PartSeries
#) Product
Datasheet
Mechanical Dimensions, CHM/CXM-14 (AA10)
Mechanical Dimensions, CHM/CXM-14 (AC10)
18
PDS-002710 Rev 04
Shipping Container
anti-static bag
Label
Customer
Part Number
Lot ID
Quantity
19
PDS-002710 Rev 04
Mechanical Dimensions, CXM-18
Shipping Container, CXM-18
anti-static bag
Label
Customer
Part Number
Lot ID
Quantity
PDS-002710 Rev 04
Mechanical Dimensions, CXM-22
Shipping Container, CXM-22
anti-static bag
Label
Customer
Part Number
Lot ID
Quantity
21
PDS-002710 Rev 04
Sensus™ LED
Product
Datasheet
(PartSeries
#) Product
Datasheet
Handling Notes for Luminus COBs
Luminus products are designed for robust performance in general lighting application. However, care must be taken when handling and
assembling the LEDs into their fixtures. To avoid damaging Luminus COBs please follow these guide lines.
The following is an overview of the application notes detailing some of the practices to follow when working with these devices. More
detailed information is available on the Luminus web site at www.luminus.com.
General Handling
Electrical Contact
Devices are made to be lifted or carried with tweezers on two
adjacent corners opposite the contact pads. At no time should
the devices be handled by or should anything come in contact
with the light emitting surface (LES) area. This area includes the
yellow colored circular area and the ring surrounding it. There
are electrical connections under the LES which if damaged will
cause the device to fail.
Luminus COBs are designed with contact pads on their top
surface. These pads are clearly marked with + and – polarity.
Wires can be soldered to the contact pads for electrical
connections or other solderless connector products are
available.
In addition, the ring frame itself should not be used for moving,
lifting or carrying the device. Also do not attach any optics or
mechanical holders to the ring as it is not capable to handle the
mechanical stress.
If wires are being soldered to the COB product, we recommend
attaching these wires prior to mounting the devices to a heat
sink. Please contact Luminus for specific recommendations on
how to solder wires if not familiar with the standard practice.
Luminus can also offer design recommendations for jigs to
allow easily soldering multiple products in rapid succession.
Static Electricity
Chemical Compatibility
Luminus COBs are electronic devices which can be damaged by
electrostatic discharge (ESD). Please use appropriate measures
to assure the devices do not experience ESD during their
handling and or storage. ESD protection guidelines should be
used at all times when working with Luminus COBs.
The resin material used to form the LES can getter hydrocarbons
from the surrounding environment. As a results, certain
chemical compounds are not recommended for use with the
Luminus products. Use of these compounds can cause damage
to the light output of the device and may permanently damage
the device. Please refer to www.luminus.com for a list of the
compounds not recommended for use with the Luminus COB
products.
Storage: Luminus products are delivered in ESD shielded bags
and should be stored in these bags until used.
Assembly: Individuals handling Luminus COBs during assembly
should be trained in ESD protection practices. Assemblers
should maintain constant conductive contact with a path to
ground by means of a wrist strap, ankle straps, mat or other ESD
protection system.
Transporting: When transporting the devices from one
assembly area to another, ESD shielded carts and carriers should
be used.
22
PDS-002710 Rev 04
Thermal Interface Material (TIM)
Proper thermal management is critical for successful operation
of any LED system. Excess operating temperature can reduce
the light output of the device. And excessive heating can cause
permanent damage to the device. Proper TIM material is a
crucial component for effective heat transfer away from the LED
during normal operation. Please refer to www.luminus.com for
specific recommendations for TIM solutions.
