CXM-9-30-90-36-AC12-F3-3
    LUMINUS(朗明纳斯)
CXM-9-30-90-36-AC12-F3-3 数据手册
Sensus™ LED Series Product Datasheet Generation 2 Sensus™ LED Series Pure White Targeted COB Arrays Below the Black Body Locus (BBL) Preliminary Data Sheet Features: • Matching the human perception of “Pure white” light Table of Contents Technology Overview. . . . . . 2 Test Specifications . . . . . . . . . 2 • Designed to provide the look and feel of ceramic metal halide lights • Wide product range from 300lm to over 5,000lm • 3000K and 3500K, 80 and 90CRI standard • 3 SDCM color binning accuracy Chromaticity Bins. . . . . . . . . . 3 • Excellent optical emission uniformity and color over angle consistency Product Ordering & Shipping Part Numbers. . . . . . . . . . . . . . 4 • Exceptional long term color stability Product Typical Flux Range. 5 • Environmentally friendly: RoHS and REACH compliant Operating Characteristics . . 6 • Package thermal conductivity more than the industry average • UL Recognized, File # E465703 Optical and Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . . . 9 Spectra. . . . . . . . . . . . . . . . . . . 13 Mechanical Dimensions. . . 14 Packaging Information. . . . 14 Handling Notes. . . . . . . . . . . 21 Applications • Retail Shop Lighting • Halogen replacement LED lamps • Spotlights/Track Lights • Hospitality Lighting • CMH replacement LED lamps • Architectural and Specialty 1 PDS-002710 Rev 04 © 2016 Luminus Devices, Inc. - All Rights Reserved Sensus LED™ Series Product Datasheet Technology Overview Luminus Chip-on-Board (COB) LED series offers a complete lighting class solution designed for high performance illumination applications. The Sensus LED series has been specially design for retail shop lighting where enhanced red coloring is a preferred lighting standard. The selection covers a wide lumen range from less than 500lm to over 5,000lm, and is focused on the major market color and CRI of 3000K and both 80 and 90 CRI. These breakthroughs allow illumination engineers and designers to develop beautifully lit spaces without sacrificing efficacy, brightness and overall quality. Reliability Designed from the ground up, the Luminus COB LED is one of the most reliable light sources in the world today. Having passed a rigorous suite of environmental and mechanical stress tests, including mechanical shock, vibration, temperature cycling and humidity. Only then are the devices qualified for use in a wide range of lighting application including some of the most demanding commercial applications. Delivered with fully qualified LM-80 test data and TM-21 lifetime results that certify lumen maintenance at 35,000 hours or more, Luminus COB LEDs are ready for the toughest challenges. UL Recognized Compliance Luminus COB arrays are tested in accordance with ANSI/UL 8750 to ensure safe operation for their intended applications. REACH & RoHS Compliance All LED products manufactured by Luminus are REACH and RoHS compliant and free of hazardous materials, including lead and mercury. Understanding Luminus COB LED Test Specifications Every Luminus LED is fully tested to ensure it meets the high quality standards customers have come to expect from Luminus’ products. Traceability Chromaticity Bin Range Each Luminus COB LED is marked with a 2D bar code that contains a unique serial number. With this serial number, Luminus has the ability to provide customers with actual test data measurements for a specific LED. In addition, the 2D bar code is linked to manufacturing date codes that enables traceability of production processes and materials. Chromaticity binning delivers color consistency for every order. Standard products are delivered with a 3-step MacAdam ellipse. This ensures color performance matching in the application. These tightly controlled, small distribution bins provide customers predictable, repeatable colors. Testing Temperature Luminus COB products are measured at temperatures typical for the LED operating in the fixture. Each device is tested at 85ºC junction temperature eliminating the need to scale data sheet specifications to real world situations. 2 PDS-002710 Rev 04 © 2016 Luminus Devices, Inc. - All Rights Reserved Sensus™ LED Series Product Datasheet Chromaticity Bin Structure Chromaticity Bins: 1931 CIE Curve ANSI C78.377-2008 ANSI C78.377-2008 3-SDCM 3-SDCM 0.45 0.4500 2-SDCM 3000K 3000K 0.4300 0.43 3500K 3500K CIEy CIEy 0.4100 0.41 Black Locus Black Body Body Locus 0.3900 0.39 0.3700 0.37 0.3500 0.35 0.3300 0.3700 0.33 0.37 0.3800 0.3900 0.4000 0.4100 0.4200 0.4300 0.4400 0.4500 0.4600 0.4700 0.38 0.39 0.4 0.41 0.42 CIEx 0.43 0.44 0.45 0.46 0.47 CIEx Sensus™ LED White Chromaticity Bins The following tables describe the ANSI bin center points, the orientation angle for the MacAdam ellipse (θ °), and the maximum radii for the ellipses. The ANSI Bin is provided for reference. 3-step Bin Center Point *Note: CCT CIEx CIEy θ (°) a b 3000K 0.4252 0.3877 53.6 0.00834 0.00408 3500K 0.4067 0.3845 54 0.00927 0.00414 Luminus maintains a +/- 0.005 tolerance on chromaticity (CIEx and CIEy) measurements. 3 PDS-002710 Rev 04 © 2016 Luminus Devices, Inc. - All Rights Reserved Sensus™ LED Series Product Datasheet Product Ordering and Shipping Part Number Nomenclature All Sensus LED products are packaged and labeled with part numbers as outlined in the table on page 5. Luminus will include any smaller chromaticity bin that is contained in the larger bin as part of the ordered part. When shipped, each package will contain only a single flux and chromaticity bin. The part number designation is as follows: Sensus™ LED Series CXM XX 30 80 Light Emitting Color Color RenderSurface Diameter1 Temperature2 ing Index (CRI)3 Product Family XX: LES Diameter (mm) Approximate CHM: Chip on Board CT XX 36 QQPP FG W Voltage (typical) Package Configurator Flux Bin Chromaticity Bin Volts AA12 (Basic package) Lumens See page 3 for bins Note 1 : XX nomenclature corresponds to the following: 9 = 9mm 14 = 13.5mm 18 = 17.5mm 22 = 22mm Note 2: CT Nomenclature corresponds to the following 30 is 3000K 35 is 3500K Note 3: XX Color Rendering nomenclature corresponds to the following 80 = 80 CRI 90 = 90 CRI 95 = 95 CRI Note 4: AA12 is a standard package configurator AC12 is an alternative substrate size Color Temperature, CRI and R9 Values Color Temperatures 3000K, 3500K Note: XX Value CRI R9 80 >80 >0 90 >90 >50 Luminus part numbers may be accompanied by prefixes or suffixes. The most common is the “Rev01” suffix indicating a part is fully released and carries a full warranty. These additional characters may appear on shipping labels, packing slips and invoices. In all cases the basic part number described above will always be included. 4 PDS-002710 Rev 04 © 2016 Luminus Devices, Inc. - All Rights Reserved Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet Sensus™ LED Series Part Numbers (Typical) The following tables describe products with typical flux and minimum flux measured at typical currents and specified at 85ºC. The values at 25ºC are calculated and shown for reference only. All product is measured and specified at 85ºC junction temperature. Output Flux (lm) Ordering Part Number Typ. Typ. (85ºC) Min. (85ºC) (calculated) 1,025 975 1,130 CRI (25ºC) 1,000 1,175 870 825 965 865 1,000 2,125 1,980 2,825 2,040 2,425 1,795 1,675 1,995 CXM-9-35-80-36-AC12-F3-3 240 CXM-9-30-90-36-AA12-F3-3 CXM-9-35-90-36-AC12-F3-3 CXM-9-35-90-36-AA12-F3-3 CXM-14-30-80-36-AC12-F3-3 480 CXM-14-30-80-36-AA12-F3-3 CXM-14-35-80-36-AC12-F3-3 CXM-14-35-80-36-AA12-F3-3 CXM-14-30-90-36-AC12-F3-3 90 1,725 1,755 1,910 3,535 3,355 3,920 80 3,010 2,855 3,335 90 5,645 5,360 6,210 80 4,800 4,555 5,280 90 5,020 4,670 5,520 90 480 CXM-14-30-90-36-AA12-F3-3 CXM-14-35-90-36-AC12-F3-3 CXM-14-35-90-36-AA12-F3-3 800 CXM-18-30-80-36-AA12-F3-3 CXM-18-30-90-36-AA12-F3-3 CXM-22-30-80-36-AC12-F3-3 1,280 *Note: Luminus maintains a +/- 6% tolerance on flux measurements. Luminus maintains a +/- 2% tolerance on CRI measurements. 5 PDS-002710 Rev 04 CXM-9-30-80-36-AA12-F3-3 CXM-9-30-90-36-AC12-F3-3 80 2,185 240 CXM-9-35-80-36-AA12-F3-3 90 910 3 SDCM CXM-9-30-80-36-AC12-F3-3 80 1,055 Typ. Current (mA) © 2016 Luminus Devices, Inc. - All Rights Reserved CXM-22-30-90-36-AC12-F3-3 CXM-22-35-90-36-AC12-F3-3 Sensus™ LED Series Product Datasheet Sensus™ LED Series Part Numbers (Typical) The following tables describe products with typical flux and minimum flux measured at typical currents and specified at 85ºC. The values at 25ºC are calculated and shown for reference only. All product is measured and specified at 85ºC junction temperature. Output Flux (lm) Typ. (85ºC) Min. (85ºC) 1,530 1,420 Ordering Part Number Typ. (calculated) (25ºC) CRI 1,200 1,115 1,320 1,290 1,200 1,420 1,480 1,750 3,080 2,860 3,380 2,260 2,670 2,610 2,430 2,870 CHM-9-35-90-36-AC12-F3-3 720 CHM-14-30-80-36-AA12-F3-3 CHM-14-35-80-36-AC12-F3-3 CHM-14-30-90-36-AC12-F3-3 Luminus maintains a +/- 6% tolerance on flux measurements. Luminus maintains a +/- 2% tolerance on CRI measurements. © 2016 Luminus Devices, Inc. - All Rights Reserved CHM-9-30-90-36-AA12-F3-3 CHM-14-35-80-36-AA12-F3-3 *Note: PDS-002710 Rev 04 360 CHM-14-30-80-36-AC12-F3-3 2,530 6 CHM-9-35-80-36-AC12-F3-3 CHM-9-35-90-36-AA12-F3-3 90 2,980 CHM-9-30-80-36-AA12-F3-3 CHM-9-30-90-36-AC12-F3-3 80 2,430 360 CHM-9-35-80-36-AA12-F3-3 90 1,590 3 SDCM CHM-9-30-80-36-AC12-F3-3 1,680 80 3,210 Typ. Current (mA) 720 CHM-14-30-90-36-AA12-F3-3 CHM-14-35-90-36-AC12-F3-3 CHM-14-35-90-36-AA12-F3-3 Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet CXM-9 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol 2 Forward Current If Forward Voltage3 Vf Minimum Typical Maximum Unit 240 550 mA 35 37.5 V 8.6 21 W 100 ºC 32 Power Operating Case Temperature4 Tc Light Emitting Surface Diameter LES 9 mm Thermal Resisitance (junction-to-case) Qjc 1.51 ºC/W Junction Temperature Tj 140 Viewing Angle 120 ºC Degree CXM-14 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol Forward Current2 If Forward Voltage Vf 3 Minimum Maximum Unit 480 1,,090 mA 35 37.5 V 17.3 41 W 105 ºC 32 Power Operating Case Temperature Typical Tc Light Emitting Surface Diameter LES 13.5 mm Thermal Resisitance (junction-to-case) Qjc 0.87 ºC/W Junction Temperature Tj 140 Viewing Angle 120 ºC Degree CXM-18 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol 2 Forward Current If Forward Voltage3 Vf Power Operating Case Temperature4 Minimum 32 Typical Maximum Unit 800 1,800 mA 35 37.5 V 29 67.5 W 105 ºC Tc Light Emitting Surface Diameter LES 17.5 mm Thermal Resisitance (junction-to-case) Qjc 0.56 ºC/W Junction Temperature Viewing Angle 140 120 7 PDS-002710 Rev 04 Tj © 2016 Luminus Devices, Inc. - All Rights Reserved ºC Degree Sensus™ LED Series Product Datasheet CXM-22 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol Forward Current2 If Forward Voltage Vf 3 Minimum 32 Power Operating Case Temperature4 Typical Maximum Unit 1,280 2,900 mA 35 37.5 V 45 109 W 105 ºC Tc Light Emitting Surface Diameter LES 22 mm Thermal Resisitance (junction-to-case) Qjc N/A ºC/W Junction Temperature Tj 140 Viewing Angle 120 ºC Degree CHM-9 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol Forward Current2 If Forward Voltage Vf 3 Minimum 32 Power Operating Case Temperature 4 Typical Maximum Unit 360 550 mA 34.5 37.5 V 12.5 21 W 105 ºC Tc Light Emitting Surface Diameter LES 9 mm Thermal Resisitance (junction-to-case) Qjc 0.85 ºC/W Junction Temperature Tj 140 Viewing Angle 120 ºC Degree CHM-14 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol Forward Current2 If Forward Voltage Vf 3 Power Operating Case Temperature 4 Minimum 32 Typical Maximum Unit 720 1,090 mA 34.5 37.5 V 24.8 41 W 105 ºC Tc Light Emitting Surface Diameter LES 13.5 mm Thermal Resisitance (junction-to-case) Qjc 0.45 ºC/W Junction Temperature Tj Viewing Angle 140 120 ºC Degree Sensus™ LED Series Product Datasheet Operating Characteristics Notes Note 1: Ratings are based on operation at a constant junction temperature Tj = 85ºC. Note 2: To prevent damage refer to operating conditions and derating curves for appropriate maximum operating conditions Note 3: Forward voltage is rated at typical forward current. For voltage at different forward currents, refer to the voltage versus current performance graphs. Note 4: COB LEDs are designed for operation to a minimum of 20% of the typical forward current value. Operation at currents lower than this value will not harm the device but may result in uneven light emission across the LES surface. Note 5: Luminus may change any specifications without prior notice. Please refer to the company web site for the latest data sheet revision Note 6: Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye. 9 PDS-002710 Rev 04 © 2016 Luminus Devices, Inc. - All Rights Reserved Sensus™ LED Series Product Datasheet CXM-9 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 250.0% 500 450 Forward Current (mA) Relative Luminous Flux 200.0% 150.0% 100.0% 400 350 300 250 200 50.0% 150 0.0% 100 150 200 250 300 350 400 450 100 500 32 33 34 35 Forward Current (mA) Relative Output Flux vs. Junction Temperature 37 38 39 40 Change in Voltage vs. Junction Temperature 1.2 40 1 38 Forward Voltage (V) Relative Luminous Flux 36 Forward Voltage (V) 0.8 0.6 0.4 36 34 32 0.2 30 0 5 15 25 35 45 55 65 75 Junction Temperature (ºC) 10 PDS-002710 Rev 04 © 2016 Luminus Devices, Inc. - All Rights Reserved 85 95 105 5 15 25 35 45 55 65 Junction Temperature (ºC) 75 85 95 105 Sensus™ LED Series Product Datasheet CXM-14 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 250% 1000 Forward Current (mA) Relative Luminous Flux 200% 150% 100% 50% 800 600 400 200 0% 0 250 350 450 550 650 750 850 950 1050 34 35 36 Forward Current (mA) Relative Output Flux vs. Junction Temperature 38 39 40 Change in Voltage vs. Junction Temperature 40 120% 100% 38 Forward Voltage (V) Relative Luminous Flux 37 Forward Voltage (V) 80% 60% 40% 36 34 32 20% 30 0% 5 15 25 35 45 55 65 75 85 95 5 105 15 25 35 45 55 65 75 85 95 105 Junction Temperature (ºC) Junction Temperature (ºC) CXM-18 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 250% 1700 1500 Forward Current (mA) Relative Luminous Flux 200% 150% 100% 50% 1300 1100 900 700 500 0% 600 800 1000 1200 1400 Forward Current (mA) 11 PDS-002710 Rev 04 © 2016 Luminus Devices, Inc. - All Rights Reserved 1600 1800 33 34 35 36 Forward Voltage (V) 37 38 39 Sensus™ LED Series Product Datasheet CXM-18 Optical & Electrical Characteristics Relative Output Flux vs. Junction Temperature Change in Voltage vs. Junction Temperature 120% 40 38 Forward Voltage (V) Relative Luminous Flux 100% 80% 60% 40% 36 34 32 20% 30 0% 5 15 25 35 45 55 65 75 85 95 105 5 15 25 35 45 Junction Temperature (ºC) 55 65 75 85 95 105 Junction Temperature (ºC) CXM-22 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 250.00% 2900 2500 Forward Current (mA) Relative Luminous Flux 200.00% 150.00% 100.00% 2100 1700 1300 900 50.00% 500 0.00% 600 800 1000 1200 1400 1600 1800 2000 2200 2400 2600 100 32.0 2800 32.5 33.0 33.5 Forward Current (mA) Relative Output Flux vs. Junction Temperature 34.5 35.0 35.5 36.0 36.5 37.0 Change in Voltage vs. Junction Temperature 120.00% 35.50 115.00% Relative Luminous Flux 35.00 Forward Voltage (V) 34.0 Forward Voltage (V) 34.50 34.00 33.50 110.00% 105.00% 100.00% 95.00% 90.00% 33.00 5 15 25 35 45 55 65 75 Junction Temperature (℃) 12 PDS-002710 Rev 04 © 2016 Luminus Devices, Inc. - All Rights Reserved 85 95 105 5 15 25 35 45 55 65 Junction Temperature (℃) 75 85 95 105 Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet CHM-9 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 160% 550 140% 450 Forward Current (mA) Relative Luminous Flux 120% 100% 80% 60% 40% 350 250 150 20% 0% 100 150 200 250 300 350 400 450 500 50 550 31 32 33 Forward Current (mA) Relative Output Flux vs. Junction Temperature 35 36 37 38 Change in Voltage vs. Junction Temperature 120.0% 40 100.0% 38 Forward Voltage (V) Relative Luminous Flux 34 Forward Voltage (V) 80.0% 60.0% 40.0% 36 34 32 20.0% 0.0% 30 5 15 25 35 45 55 65 75 85 95 105 5 15 25 35 Junction Temperature (ºC) 45 55 65 75 85 95 105 Junction Temperature (ºC) CHM-14 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 180% 1100 160% 1000 Forward Current (mA) Relative Luminous Flux 140% 120% 100% 80% 60% 900 800 700 600 40% 500 20% 0% 400 300 400 500 600 700 800 900 Forward Current (mA) 13 PDS-002710 Rev 04 © 2016 Luminus Devices, Inc. - All Rights Reserved 1000 1100 34 34.5 35 35.5 36 Forward Voltage (V) 36.5 37 37.5 Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet CHM-14 Optical & Electrical Characteristics Relative Output Flux vs. Junction Temperature Change in Voltage vs. Junction Temperature 120% 40 Relative Luminous Flux 100% 38 Forward Voltage (V) 80% 60% 40% 36 34 32 20% 0% 30 5 15 25 35 45 55 65 75 85 95 105 5 15 25 35 Junction Temperature (ºC) 45 55 65 75 85 95 105 Junction Temperature (ºC) Chromaticity Shift Characteristics Change CIEx vs. Junction Temperature (3000K, 80CRI) Change CIEy vs. Junction Temperature (3000K, 80CRI) 0.02 40 38 Forward Voltage (V) Δ CIEx 0.01 0 -0.01 36 34 32 -0.02 5 15 25 35 45 55 65 75 Junction Temperature (ºC) 14 PDS-002710 Rev 04 © 2016 Luminus Devices, Inc. - All Rights Reserved 85 95 105 30 5 15 25 35 45 55 65 Junction Temperature (ºC) 75 85 95 105 Sensus™ LED Series Product Datasheet Optical Characteristics Typical Spectrum 120.00% Relative Intensity 100.00% 80.00% 60.00% 40.00% 20.00% 0.00% 400 450 500 550 600 650 700 750 800 Wavelength (nm) Typical Polar Radiation Pattern Typical Angular Radiation Pattern 120% 100% Relative Intensity (%) 80% 60% 40% 20% 0% -80 -60 -40 -20 0 20 Anglular Displacement (Degrees) 15 PDS-002710 Rev 04 © 2016 Luminus Devices, Inc. - All Rights Reserved 40 60 80 Sensus™ LED Series Product Datasheet Mechanical Dimensions, CHM/CXM-9 (AA10) Mechanical Dimensions, CHM/CXM-9 (AC10) 16 PDS-002710 Rev 04 © 2016 Luminus Devices, Inc. - All Rights Reserved Sensus™ LED Series Product Datasheet Shipping Container, CHM/CXM-9 (AA00) Shipping Container, CHM/CXM-9 (AC00) Each bag is boxed for easier storage/stacking • • • Trays are sealed in an anti-static bag Label Customer Part Number Lot ID Quantity 17 PDS-002710 Rev 04 © 2016 Luminus Devices, Inc. - All Rights Reserved 5 trays are stacked together with one tray as a cover Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet Mechanical Dimensions, CHM/CXM-14 (AA10) Mechanical Dimensions, CHM/CXM-14 (AC10) 18 PDS-002710 Rev 04 © 2016 Luminus Devices, Inc. - All Rights Reserved Sensus™ LED Series Product Datasheet Shipping Container Each bag is boxed for easier storage/stacking • • • Trays are sealed in an anti-static bag Label Customer Part Number Lot ID Quantity 19 PDS-002710 Rev 04 © 2016 Luminus Devices, Inc. - All Rights Reserved 5 trays are stacked together with one tray as a cover Sensus™ LED Series Product Datasheet Mechanical Dimensions, CXM-18 Shipping Container, CXM-18 Each bag is boxed for easier storage/stacking • • • Trays are sealed in an anti-static bag Label Customer Part Number Lot ID Quantity 20 PDS-002710 Rev 04 © 2016 Luminus Devices, Inc. - All Rights Reserved 5 trays are stacked together with one tray as a cover Sensus™ LED Series Product Datasheet Mechanical Dimensions, CXM-22 Shipping Container, CXM-22 Each bag is boxed for easier storage/stacking • • • Trays are sealed in an anti-static bag Label Customer Part Number Lot ID Quantity 21 PDS-002710 Rev 04 © 2016 Luminus Devices, Inc. - All Rights Reserved 5 trays are stacked together with one tray as a cover Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet Handling Notes for Luminus COBs Luminus products are designed for robust performance in general lighting application. However, care must be taken when handling and assembling the LEDs into their fixtures. To avoid damaging Luminus COBs please follow these guide lines. The following is an overview of the application notes detailing some of the practices to follow when working with these devices. More detailed information is available on the Luminus web site at www.luminus.com. General Handling Electrical Contact Devices are made to be lifted or carried with tweezers on two adjacent corners opposite the contact pads. At no time should the devices be handled by or should anything come in contact with the light emitting surface (LES) area. This area includes the yellow colored circular area and the ring surrounding it. There are electrical connections under the LES which if damaged will cause the device to fail. Luminus COBs are designed with contact pads on their top surface. These pads are clearly marked with + and – polarity. Wires can be soldered to the contact pads for electrical connections or other solderless connector products are available. In addition, the ring frame itself should not be used for moving, lifting or carrying the device. Also do not attach any optics or mechanical holders to the ring as it is not capable to handle the mechanical stress. If wires are being soldered to the COB product, we recommend attaching these wires prior to mounting the devices to a heat sink. Please contact Luminus for specific recommendations on how to solder wires if not familiar with the standard practice. Luminus can also offer design recommendations for jigs to allow easily soldering multiple products in rapid succession. Static Electricity Chemical Compatibility Luminus COBs are electronic devices which can be damaged by electrostatic discharge (ESD). Please use appropriate measures to assure the devices do not experience ESD during their handling and or storage. ESD protection guidelines should be used at all times when working with Luminus COBs. The resin material used to form the LES can getter hydrocarbons from the surrounding environment. As a results, certain chemical compounds are not recommended for use with the Luminus products. Use of these compounds can cause damage to the light output of the device and may permanently damage the device. Please refer to www.luminus.com for a list of the compounds not recommended for use with the Luminus COB products. Storage: Luminus products are delivered in ESD shielded bags and should be stored in these bags until used. Assembly: Individuals handling Luminus COBs during assembly should be trained in ESD protection practices. Assemblers should maintain constant conductive contact with a path to ground by means of a wrist strap, ankle straps, mat or other ESD protection system. Transporting: When transporting the devices from one assembly area to another, ESD shielded carts and carriers should be used. 22 PDS-002710 Rev 04 © 2016 Luminus Devices, Inc. - All Rights Reserved Thermal Interface Material (TIM) Proper thermal management is critical for successful operation of any LED system. Excess operating temperature can reduce the light output of the device. And excessive heating can cause permanent damage to the device. Proper TIM material is a crucial component for effective heat transfer away from the LED during normal operation. Please refer to www.luminus.com for specific recommendations for TIM solutions.
CXM-9-30-90-36-AC12-F3-3 价格&库存
很抱歉,暂时无法提供与“CXM-9-30-90-36-AC12-F3-3”相匹配的价格&库存,您可以联系我们找货
