BXRE-35E0800-B-23
BXRE-35E0800-B-23
    BRIDGELUX(普瑞)
    LED V8 3500K 800LM 80CRI WW
BXRE-35E0800-B-23 数据手册
Bridgelux V8 Array Series ® Product Data Sheet DS41 BXRE-27x0800 | 30x0800 | 35x0800 | 40x0800 | 50x0800 V Series Introduction The V Series LED Array products deliver high quality light in a compact and cost-effective solid-state lighting package. These Chip-on-Board (CoB) arrays can be efficiently driven at twice the nominal drive current, enabling design flexibility not previously possible. This high flux density light source is designed to support a wide range of high quality, low cost directional luminaires and replacement lamps for commercial and residential applications. The V8 LED Array is available in a variety of electrical, CCT and CRI combinations providing substantial design flexibility and energy efficiencies. Lighting system designs incorporating these LED Arrays deliver comparable performance to 7-13 Watt compact fluorescent and 40-75 Watt incandescent and halogen based luminaires, delivering increased system level efficacy and longer service life. Typical applications include, but are not limited to, replacement lamps, task, accent, spot, track, down light, wide area, security, and wall pack. Features Benefits • Efficacy of 130 lm/W typical • Enhanced optical control • Compact high flux density light source • Clean white light without pixilation • Uniform high quality illumination • High quality true color reproduction • Minimum 70, 80 and 90 CRI options • Significantly reduced thermal resistance and increased operating temperatures • Streamlined thermal path • Energy Star / ANSI compliant color binning structure with 3SDCM and 4SDCM options • Uniform consistent white light • Lower operating costs • More energy efficient than incandescent, halogen and fluorescent lamps • Easy to use with daylight and motion detectors to enable increased energy savings • Low voltage DC operation • Reduced maintenance costs • Instant light with unlimited dimming • Environmentally friendly, no disposal issue Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Performance at Commonly Used Drive Currents 4 Electrical Characteristics 7 Absolute Maximum Ratings 8 Performance Curves 9 Typical Radiation Pattern 13 Typical Color Spectrum 14 Mechanical Dimensions 15 Color Binning Information 16 Packaging and Labeling 17 Design Resources 19 Precautions 19 Disclaimers 19 About Bridgelux 20 1 Product Feature Map Bridgelux arrays are fully engineered devices that provide consistent thermal and optical performance on an engineered mechanical platform. The V Series arrays are the most compact chip-on-board devices across all of Bridgelux’s LED Array products. The arrays incorporate several features to simplify design integration and assembly. Polarity symbols Fully engineered substrate for consistent thermal, mechanical and optical properties Solder Pads White ring around LES Case Temperature (Tc) Measurement Point Yellow phosphor Light Emitting Surface (LES) Note: Part number and lot codes are scribed on back of array Product Nomenclature The part number designation for Bridgelux V Series LED arrays is explained as follows: 1 2 3 4 5 6 7 8 9 10 11 – 12 – 13 14 BXRE – 30 E 0800 – A – 23 Product Family Nominal CCT 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K 50 = 5,000K Color Control Bin Options 23 = 3 SDCM 24 = 4 SDCM Array Configuration Minimum CRI C = 70 CRI E = 80 CRI G = 90 CRI Flux Indicator 0800 = 800lm 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) BXRE-27E0800-A-2x BXRE-27E0800-B-2x BXRE-27G0800-A-2x BXRE-27G0800-B-2x BXRE-30E0800-A-2x BXRE-30E0800-B-2x BXRE-30G0800-A-2x BXRE-30G0800-B-2x BXRE-35E0800-A-2x BXRE-35E0800-B-2x BXRE-35G0800-A-2x BXRE-35G0800-B-2x BXRE-40E0800-A-2x BXRE-40E0800-B-2x BXRE-40G0800-A-2x BXRE-40G0800-B-2x BXRE-50C0800-A-24 BXRE-50C0800-B-24 BXRE-50E0800-A-24 BXRE-50E0800-B-24 2700 2700 2700 2700 3000 3000 3000 3000 3500 3500 3500 3500 4000 4000 4000 4000 5000 5000 5000 5000 80 80 90 90 80 80 90 90 80 80 90 90 80 80 90 90 70 70 80 80 175 350 175 350 175 350 175 350 175 350 175 350 175 350 175 350 175 350 175 350 Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) 742 742 642 642 785 785 657 657 807 807 679 679 831 831 724 724 896 896 853 853 Minimum Pulsed Flux6,7 Tc = 25ºC (lm) 699 699 600 600 708 708 617 617 736 736 595 595 772 772 632 632 834 834 811 811 Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) 35.6 17.8 35.6 17.8 35.6 17.8 35.6 17.8 35.6 17.8 35.6 17.8 35.6 17.8 35.6 17.8 35.6 17.8 35.6 17.8 6.2 6.2 6.2 6.2 6.2 6.2 6.2 6.2 6.2 6.2 6.2 6.2 6.2 6.2 6.2 6.2 6.2 6.2 6.2 6.2 119 119 103 103 126 126 105 105 130 130 109 109 133 133 116 116 144 144 137 137 Table 2: Selection Guide, Stabilized DC Performance (Tc = 85°C) 8,9 Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux Tc = 85ºC (lm) Minimum DC Flux10 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRE-27E0800-A-2x BXRE-27E0800-B-2x BXRE-27G0800-A-2x BXRE-27G0800-B-2x BXRE-30E0800-A-2x BXRE-30E0800-B-2x BXRE-30G0800-A-2x BXRE-30G0800-B-2x BXRE-35E0800-A-2x BXRE-35E0800-B-2x BXRE-35G0800-A-2x BXRE-35G0800-B-2x BXRE-40E0800-A-2x BXRE-40E0800-B-2x BXRE-40G0800-A-2x BXRE-40G0800-B-2x BXRE-50C0800-A-24 BXRE-50C0800-B-24 BXRE-50E0800-A-24 BXRE-50E0800-B-24 2700 2700 2700 2700 3000 3000 3000 3000 3500 3500 3500 3500 4000 4000 4000 4000 5000 5000 5000 5000 80 80 90 90 80 80 90 90 80 80 90 90 80 80 90 90 70 70 80 80 175 350 175 350 175 350 175 350 175 350 175 350 175 350 175 350 175 350 175 350 666 666 565 565 703 703 578 578 723 723 598 598 749 749 637 637 788 788 751 751 628 628 528 528 634 634 543 543 659 659 524 524 696 696 556 556 734 734 714 714 34.6 17.4 34.6 17.4 34.6 17.4 34.6 17.4 34.6 17.4 34.6 17.4 34.6 17.4 34.6 17.4 34.6 17.4 34.6 17.4 6.1 6.1 6.1 6.1 6.1 6.1 6.1 6.1 6.1 6.1 6.1 6.1 6.1 6.1 6.1 6.1 6.1 6.1 6.1 6.1 110 110 93 93 116 116 96 95 119 119 99 98 124 123 105 105 130 130 124 123 Notes for Tables 1 & 2: 1. Nominal CCT as defined by ANSI C78.377-2011. 2. CRI Values are minimums. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 9. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 10. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 3 Performance at Commonly Used Drive Currents V Series LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. V Series may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figures 1 & 2 and the flux vs. current characteristics shown in Figures 3 & 4. The performance at commonly used drive currents is summarized in Table 3. Table 3: Product Performance at Commonly Used Drive Currents Part Number BXRE-27E0800-A-2x BXRE-27E0800-B-2x BXRE-27G0800-A-2x BXRE-27G0800-B-2x BXRE-30E0800-A-2x BXRE-30E0800-B-2x BXRE-30G0800-A-2x CRI 80 80 90 90 80 80 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 175 35.6 6.2 742 666 119 250 36.7 9.2 998 895 109 350 38.1 13.3 1288 1151 97 175 16.9 3.0 396 358 134 350 17.8 6.2 742 666 119 500 18.4 9.2 998 895 108 700 19.2 13.4 1288 1151 96 175 35.6 6.2 642 565 103 250 36.7 9.2 863 759 94 350 38.1 13.3 1115 976 84 175 16.9 3.0 343 304 116 350 17.8 6.2 642 565 103 500 18.4 9.2 863 759 94 700 19.2 13.4 1115 976 83 175 35.6 6.2 785 703 126 250 36.7 9.2 1056 945 115 350 38.1 13.3 1363 1215 102 175 16.9 3.0 419 378 142 350 17.8 6.2 785 703 126 500 18.4 9.2 1056 945 115 700 19.2 13.4 1363 1215 101 175 35.6 6.2 657 578 105 250 36.7 9.2 883 777 96 350 38.1 13.3 1141 998 86 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 4 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (Continued) Part Number BXRE-30G0800-B-03 BXRE-35E0800-A-2x BXRE-35E0800-B-2x BXRE-35G0800-A-2x BXRE-35G0800-B-03 BXRE-40E0800-A-24 BXRE-40E0800-B-2x CRI 90 80 80 90 90 80 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 175 16.9 3.0 351 311 119 350 17.8 6.2 657 578 105 500 18.4 9.2 883 777 96 700 19.2 13.4 1141 998 85 175 35.6 6.2 807 723 130 250 36.7 9.2 1085 972 118 350 38.1 13.3 1401 1249 105 175 16.9 3.0 431 389 146 350 17.8 6.2 807 723 130 500 18.4 9.2 1085 972 118 700 19.2 13.4 1401 1249 104 175 35.6 6.2 679 598 109 250 36.7 9.2 913 803 100 350 38.1 13.3 1179 1032 88 175 16.9 3.0 362 321 123 350 17.8 6.2 679 598 109 500 18.4 9.2 913 803 99 700 19.2 13.4 1179 1032 88 175 35.6 6.2 831 749 133 250 36.7 9.2 1117 1006 122 350 38.1 13.3 1443 1293 108 175 16.9 3.0 444 403 150 350 17.8 6.2 831 749 133 500 18.4 9.2 1117 1006 121 700 19.2 13.4 1443 1293 107 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (Continued) Part Number BXRE-40G0800-A-2x BXRE-40G0800-B-2x BXRE-50C0800-A-24 BXRE-50C0800-B-24 BXRE-50E0800-A-24 BXRE-50E0800-B-24 CRI 90 90 70 70 80 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 175 35.6 6.2 724 637 116 250 36.7 9.2 974 856 106 350 38.1 13.3 1257 1100 94 175 16.9 3.0 386 343 131 350 17.8 6.2 724 637 116 500 18.4 9.2 974 856 106 700 19.2 13.4 1257 1100 94 175 35.6 6.2 896 788 144 250 36.7 9.2 1205 1060 131 350 38.1 13.3 1555 1362 117 175 16.9 3.0 478 424 162 350 17.8 6.2 896 788 144 500 18.4 9.2 1205 1060 131 700 19.2 13.4 1555 1362 116 175 35.6 6.2 853 751 137 250 36.7 9.2 1147 1009 125 350 38.1 13.3 1481 1296 111 175 16.9 3.0 455 404 154 350 17.8 6.2 853 751 137 500 18.4 9.2 1147 1009 125 700 19.2 13.4 1481 1296 110 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 6 Electrical Characteristics Table 4: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2 Part Number Drive Current (mA) Typical Coefficient of Forward Voltage3 ∆Vf/∆Tc (mV/ºC) Typical Thermal Resistance Junction to Case4 Rj-c (ºC/W) Driver Selection Voltages5 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 0.71 31.5 39.4 -17 0.81 33.7 42.5 19.2 -7 0.71 15.9 19.7 20.8 -7 0.81 17.1 21.3 Minimum Typical Maximum 175 32.9 35.6 38.3 -17 350 35.1 38.1 41.4 350 16.5 17.8 700 17.7 19.3 BXRE-xxx0800-A-2x BXRE-xxx0800-B-2x Notes for Table 4: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± O.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± O.1mV for nominal current. 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 7 Absolute Maximum Ratings Table 5: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 150°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C Soldering Temperature2 350°C or lower for a maximum of 10 seconds BXRE-xxx0800-A-2x BXRE-xxx0800-B-2x Maximum Drive Current3,4,5 350 mA 700 mA Maximum Peak Pulsed Drive Current6 500 mA 1000mA Maximum Reverse Voltage7 -60 V -30 V Notes for Table 5: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Refer to Bridgelux Application Note AN41: Assembly Considerations for Bridgelux V Series LED Arrays. 3. DC Forward Current for LM-80 is the maximum drive current for which LM-80 data is currently available. 4. Lumen maintenance (L70) and lifetime predictions are valid for drive current and case temperature conditions used for LM-80 testing as included in the applicable LM-80 test report for these arrays. Contact your Bridgelux sales representatives for LM-80 report. 5. Arrays may be driven at higher currents however lumen maintenance may be reduced. 6. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20 ms when operating LED Arrays at maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where LED Arrays can be driven without catastrophic failures. 7. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 8 Performance Curves Figure 1: Drive Current vs. Voltage (Tj=Tc=25°C) – BXRE-xxx0800-A-2x Figure 2: Drive Current vs. Voltage (Tj=Tc=25°C) – BXRE-xxx0800-B-2x 9 Performance Curves Figure 3: Typical Relative Luminous Flux vs. Current – BXRE-xxx0800-A-2x Figure 4: Typical Relative Luminous Flux vs. Current – BXRE-xxx0800-B-2x Note for Figures 3-4: 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. 10 Performance Curves Figure 5: Typical DC Flux vs. Case Temperature Figure 6: Typical DC ccx Shift vs. Case Temperature Notes for Figures 5-6: 1. 2. 3. 4. Characteristics shown for warm white based on 3000K and 80 CRI. Characteristics shown for neutral white based on 4000K and 80 CRI. Characteristics shown for cool white based on 5000K and 70 CRI. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. 11 Performance Curves Figure 7: Typical DC ccy Shift vs. Case Temperature Notes for Figure 7: 1. 2. 3. 4. Characteristics shown for warm white based on 3000K and 80 CRI. Characteristics shown for neutral white based on 4000K and 80 CRI. Characteristics shown for cool white based on 5000K and 70 CRI. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. 12 Typical Radiation Pattern Figure 8: Typical Spatial Radiation Pattern Notes for Figure 8: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle form the centerline where Iv is ½ of the peak value. Figure 9: Typical Polar Radiation Pattern 13 Typical Color Spectrum Figure 10: Typical Color Spectrum Notes for Figure 10: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 2. Color spectra shown for warm white is 3000K and 80 CRI. 3. Color spectra shown for neutral white is 4000K and 80 CRI. 4. Color spectra shown for cool white is 5000K and 70 CRI. 14 Mechanical Dimensions Figure 11: Drawing for V8 Arrays Notes for Figure 11: 1. Solder pads are labeled “+” and “-“to denote positive and negative polarity, respectively. 2. It is not necessary to provide electrical connections to both sets of solder pads. Either set may be used depending on application specific design requirements. 3. Drawings are not to scale. 4. Drawing dimensions are in millimeters. 5. Unless otherwise specified, tolerances are ± 0.10mm. 6. The optical center of the LED Array is nominally defined by the mechanical center of the array. The light emitting surface (LES) is centered on the mechanical center of the array to a tolerance of ± 0.2 mm 7. Bridgelux maintains a flatness of 0.1 mm across the mounting surface of the array. Refer to Application Notes AN40 and AN41 for product handling, mounting and heat sink recommendations. 15 Color Binning Information Figure 12: Graph of Warm and Neutral White Test Bins in xy Color Space Note: Pulsed Test Conditions, Tc = 25°C Table 6: Warm and Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code 2700K 3000K 3500K 4000K ANSI Bin (for reference only) (2580K - 2870K) (2870K - 3220K) (3220K - 3710K) (3710K - 4260K) 23 (3SDCM) (2651K - 2794K) (2968K - 3136K) (3369K - 3586K) (3851K - 4130K) Center Point (x,y) (0.4578, 0.4101) (0.4338, 0.403) (0.4073, 0.3917) (0.3818, 0.3797) Figure 13: Graph of Cool White Test Bins in xy Color Space Note: Pulsed Test Conditions, Tc = 25°C Table 7: Cool White xy Bin Coordinates and Associated Typical CCT Bin Code 5000K ANSI Bin (for reference only) (4745K - 5311K) 24 (4SDCM) (4801K - 5282K) Center Point (x,y) (0.3447, 0.3553) 16 Packaging and Labeling Figure 14: Drawing for V8 Packaging Tray Notes for Figure 14: 1. Dimensions are in millimeters 2. Tolerances: X.X = ± 0.25, X.XX = ± 0.13, X°0’ = ±0°30’ 3. Trays are stackable without interference and will not stick together during unstacking operation 17 Packaging and Labeling Figure 15: V Series Packaging and Labeling Notes for Figure 15: 1. Each tray holds 60 COB arrays, 10 trays are stacked and one empty tray placed on top to cover the top tray. 2. Stacked trays are to contain only 1 part number and be vacuum sealed in an anti-static bag and placed in its own individual box. 3. Each bag and box is to be labeled as shown above. Figure 16: Product Labeling Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the COB array. Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number Internal Bridgelux use only. 18 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the V Series product family of LED array products. For a list of of resources under development, visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux V Series LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN41 for additional information. CAUTION: EYE SAFETY Eye safety classification for the use of Bridgelux V Series LED arrays is in accordance with IEC specification EN62471: Photobiological Safety of Lamps and Lamp Systems. V Series LED arrays are classified as Risk Group 1 (Low Risk) when operated at or below the maximum drive current. Please use appropriate precautions. It is important that employees working with LEDs are trained to use them safely. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Use the mechanical features of the LED array housing, edges and/or mounting holes to locate and secure optical devices as needed. CAUTION: RISK OF BURN Do not touch the V Series LED array during operation. Allow the array to cool for a sufficient period of time before handling. The V Series LED array may reach elevated temperatures such that could burn skin when touched. Disclaimers MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, array testing is performed at the nominal drive current. 19 About Bridgelux: We Build Light That Transforms At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux WeChat ID: BridgeluxInChina 101 Portola Avenue Livermore, CA 94551 Tel (925) 583-8400 Fax (925) 583-8410 www.bridgelux.com © 2016 Bridgelux, Inc. All rights reserved 2016. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design and V Series are registered trademarks of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux V8 Array Series Product Data Sheet DS41 Rev. F (06/2016) 20
BXRE-35E0800-B-23 价格&库存
很抱歉,暂时无法提供与“BXRE-35E0800-B-23”相匹配的价格&库存,您可以联系我们找货
