GWKAGHB1.EM-RTSP-57H3 数据手册
2014-12-11
SOLERIQ ® S 13
Datasheet
Version 1.1
GW KAGHB1.EM
The SOLERIQ® S products were specifically designed
for applications requiring large flux packages out of a
compact area.
Die SOLERIQ® S Produkte wurden speziell für
Anwendungen entwickelt, die großen Lichtstrom aus
einer kompakten Fläche benötigen.
Features:
Besondere Merkmale:
Package: Chip-on-Board
Viewing angle at 50 % IV: 120°
Color: 2700 K - 6500 K (white)
CRI: min. 80 ( typ. 85 )
Luminous Flux: typ. 1860 lm @ 4000 K
Luminous efficacy: typ. 116 lm/W @ 4000 K
Gehäusetyp: Chip-on-Board
Abstrahlwinkel bei 50 % IV: 120°
Farbe: 2700 K - 6500 K (weiß)
Lichtstrom: typ. 1860 lm @ 4000 K
Lichtausbeute: typ. 116 lm/W @ 4000 K
Applications
Anwendungen
• Spot lights
• Indoor General Lighting
• Spot-Leuchten
• Innen-Allgemeinbeleuchtung
2014-12-11
1
Version 1.1
GW KAGHB1.EM
Ordering Information
Bestellinformation
Type:
Typ:
Color
Temperature
Luminous Flux
Farbtemperatur
Lichtstrom
Ordering Code
1) page 17
Bestellnummer
1) Seite 17
IF = 500 mA
GW KAGHB1.EM-RRRU-27H3
[K]
ΦV [lm]
2700
1300 ... 1800
Q65111A4645
GW KAGHB1.EM-RTSP-27H3
2700
1500 ... 1940
Q65111A7265
GW KAGHB1.EM-RSRU-30H3
3000
1400 ... 1800
Q65111A4644
GW KAGHB1.EM-RTSP-30H3
3000
1500 ... 1940
Q65111A7264
GW KAGHB1.EM-RTSP-40H3
4000
1500 ... 1940
Q65111A4643
GW KAGHB1.EM-RUSQ-40H3
4000
1640 ... 2100
Q65111A7263
GW KAGHB1.EM-RTSP-50H3
5000
1500 ... 1940
Q65111A4642
GW KAGHB1.EM-RUSQ-50H3
5000
1640 ... 2100
Q65111A7262
GW KAGHB1.EM-RTSP-57H3
5700
1500 ... 1940
Q65111A4640
GW KAGHB1.EM-RUSQ-57H3
5700
1640 ... 2100
Q65111A7261
GW KAGHB1.EM-RTSP-65H3
6500
1500 ... 1940
Q65111A4641
GW KAGHB1.EM-RUSQ-65H3
6500
1640 ... 2100
Q65111A7260
Note:
The above Type Numbers represent the order groups which include only a few brightness groups (see page 5). Only one group will be shipped on each
packing unit (there will be no mixing of two groups on each packing unit). E. g. GW KAGHB1.EM-RSRU-30H3 means that only one group RSRU will
be shippable for any packing unit. In order to ensure availability, single brightness groups will not be orderable.
In a similar manner for colors where color chromaticity coordinate groups are measured and binned, single groups will be shipped on any one packing
unit. GW KAGHB1.EM-RSRU-30H3 means that the device will be shipped within the specified limits. In order to ensure availability, single color
chromaticity groups groups will not be orderable.
Anm.:
Die oben genannten Typbezeichnungen umfassen die bestellbaren Selektionen. Diese bestehen aus wenigen Helligkeitsgruppen (siehe Seite 5). Es
wird nur eine einzige Helligkeitsgruppe pro Verpackungseinheit geliefert. Z. B. GW KAGHB1.EM-RSRU-30H3 bedeutet, dass in einer
Verpackungseinheit nur eine der Helligkeitsgruppen RSRU enhalten ist. Um die Liefersicherheit zu gewährleisten, können einzelne Helligkeitsgruppen
nicht bestellt werden.
Gleiches gilt für die Farben, bei denen Farbortgruppen gemessen und gruppiert werden. Pro Verpackungseinheit wird nur eine Farbortgruppe geliefert.
Z.B. GW KAGHB1.EM-RSRU-30H3 bedeutet, dass in einer Verpackungseinheit nur eine der Farbortgruppen enthalten ist. GW
KAGHB1.EM-RSRU-30H3 bedeutet, dass das Bauteil innerhalb der spezifizierten Grenzen geliefert wird. Um die Liefersicherheit zu gewährleisten,
können einzelne Farbortgruppen nicht bestellt werden.
2014-12-11
2
Version 1.1
GW KAGHB1.EM
Maximum Ratings
Grenzwerte
Parameter
Symbol
Values
Unit
Bezeichnung
Symbol
Werte
Einheit
Operating temperature range
Betriebstemperatur
Top
-30 ... 85
°C
Storage temperature range
Lagertemperatur
Tstg
-40 ... 100
°C
Junction temperature
Sperrschichttemperatur
Tj
125
°C
Forward current
Durchlassstrom
(TS = 25 °C)
IF
720
mA
ESD withstand voltage
ESD Festigkeit
(acc. to ANSI/ESDA/JEDEC JS-001 - HBM)
VESD
up to 2
kV
2014-12-11
3
Version 1.1
GW KAGHB1.EM
Characteristics (TS = 25 °C; IF = 500 mA)
Kennwerte
Parameter
Symbol
Values
Unit
Bezeichnung
Symbol
Werte
Einheit
(typ.)
2ϕ
120
Forward voltage 2) page 17 , 3) page 17
Durchlassspannung 2) Seite 17 , 3) Seite 17
(min.)
(typ.)
(max.)
VF
VF
VF
29
32
36
V
V
V
Color reproduction index 4) page 17
Farbwiedergabe Index 4) Seite 17
(typ.)
(min.)
Ra
Ra
85
80
Real thermal resistance junction / solder point
(typ.)
(max.)
Rth JS real
Rth JS real
1.6
2.6
K/W
K/W
"Electrical" thermal resistance junction / solder
point 5) page 17
"Elektrischer" Wärmewiderstand Sperrschicht /
Lötpad 5) Seite 17
(with efficiency η e = 30 %)
(typ.)
(max.)
Rth JS el
Rth JS el
1.1
1.8
K/W
K/W
2014-12-11
4
5) page 17
Realer Wärmewiderstand Sperrschicht / Lötpad
5) Seite 17
Version 1.1
GW KAGHB1.EM
Brightness Groups
Helligkeitsgruppen
Group
Luminous Flux
Luminous Flux
Luminous Flux
Luminous Flux
1) page 17
1) page 17
6) page 17
6) page 17
Lichtstrom
Lichtstrom
Lichtstrom
Lichtstrom
1) Seite 17
1) Seite 17
6) Seite 17
6) Seite 17
TS = 25 °C
TS = 25 °C
TS = 85 °C
TS = 85 °C
(min.) ΦV [lm]
(max.) ΦV [lm]
(extrapolated min.) (extrapolated
ΦV [lm]
max.) ΦV [lm]
RRRU
1300
1800
1140
1580
RSRU
1400
1800
1230
1580
Gruppe
RTSP
1500
1940
1320
1710
RUSQ
1640
2100
1440
1850
Note:
The standard shipping format for serial types includes either a lower family group, an upper family group or
a grouping of all individual brightness groups of only a few brightness groups. Individual brightness groups
cannot be ordered.
Anm.:
Die Standardlieferform von Serientypen beinhaltet entweder eine untere Familiengruppe, eine obere
Familiengruppe oder eine Sammelgruppe, die aus nur wenigen Helligkeitsgruppen besteht. Einzelne
Helligkeitsgruppen sind nicht bestellbar.
2014-12-11
5
Version 1.1
GW KAGHB1.EM
Chromaticity Coordinate Groups 7) page 17 , 6) page 17
Farbortgruppen 7) Seite 17 , 6) Seite 17
extrapolated to TJ = 85 °C
Cy
0.440
0.420
0.400
27H3
30H3
0.380
30 00
40H3
0.360
400
50H3
0.340
50
57H3
0.320
57
00
K
0K
350
0K
K
K
00
K
65H3
65
0.300
0.300
00
45
27 00 K
00
K
0.320
0.340
0.360
0.380
0.400
0.420
0.440
0.460
0.480
0.500
Cx
Coordinates in reference to CIE 1931 (cx cy)
Color Chromaticity Groups 7) page 17 , 6) page 17
Group
Gruppe
27H3
30H3
40H3
2014-12-11
Cx
Cy
0.4505
0.4027
0.4572
0.4583
Group
Gruppe
Cx
Cy
0.3418
0.3487
0.4158
0.3422
0.3576
0.4045
0.3471
0.3529
0.4662
0.4179
0.3484
0.3627
0.4270
0.3953
0.3258
0.3433
0.4324
0.4078
0.3264
0.3355
0.4351
0.3981
0.3315
0.3400
0.4418
0.4112
0.3319
0.3488
0.3765
0.3719
0.3089
0.3290
0.3789
0.3825
0.3103
0.3222
0.3847
0.3768
0.3152
0.3353
0.3885
0.3885
0.3158
0.3275
50H3
57H3
65H3
6
Version 1.1
GW KAGHB1.EM
Group Name on Label
Gruppenbezeichnung auf Etikett
Example: RRRU-30H3
Beispiel: RRRU-30H3
Brightness
Helligkeit
Farbort
RRRU
30H3
Note:
No packing unit / tape ever contains more than one group for each selection.
Anm.:
In einer Verpackungseinheit / Gurt ist immer nur eine Gruppe für jede Selektion enthalten.
2014-12-11
7
Version 1.1
GW KAGHB1.EM
Relative Spectral Emission - V(λ) = Standard eye response curve 8) page 17
Relative spektrale Emission - V(λ) = spektrale Augenempfindlichkeit 8) Seite 17
Φrel = f (λ); TS = 25 °C; IF = 500 mA
Irel
GW KAGHB1.EM-MS
1.0
: Vλ
: warm white
: cool white
0.8
0.6
0.4
0.2
0.0
350
400
450
500
550
600
650
700
750
800
λ [nm]
Radiation Characteristics 8) page 17
Abstrahlcharakteristik 8) Seite 17
Irel = f (ϕ); TS = 25 °C
40˚
30˚
20˚
10˚
0˚
ϕ
50˚
OHL01660
1.0
0.8
0.6
60˚
0.4
70˚
0.2
80˚
90˚
100˚
1.0
2014-12-11
0.8
0.6
0.4
0˚
20˚
8
40˚
60˚
80˚
100˚
120˚
Version 1.1
GW KAGHB1.EM
Forward Current 8) page 17 , 3) page 17
Durchlassstrom 8) Seite 17 , 3) Seite 17
IF = f (VF); TS = 25 °C
Relative Luminous Flux 8) page 17 , 3) page 17
Relativer Lichtstrom 8) Seite 17 , 3) Seite 17
ΦV/ΦV (500 mA) = f(IF); TS = 25 °C
GW KAGHB1.xM
ΦV
IF [mA] 700
GW KAGHB1.EM
1.4
ΦV(500mA)
1.2
600
1.0
500
0.8
400
0.6
300
0.4
200
0.2
100
0.0
28
30
32
40
VF [V]
Chromaticity Coordinate Shift
Farbortverschiebung 8) Seite 17
Cx, Cy = f(IF); TS = 25 °C
Cx
Cy
Cx
Cy
GW KAGHB1.EM
0.36
0.44
0.34
0.42
0.32
0.40
0.30
8) page 17
: Cx - 3000 K
: Cy - 3000 K
: Cx - 6500 K
: Cy - 6500 K
0.38
0.28
IF [mA]
2014-12-11
IF [mA]
8) page 17
GW KAGHB1.EM
0.46
IF [mA]
9
Version 1.1
GW KAGHB1.EM
Relative Forward Voltage 8) page 17
Relative Vorwärtsspannung 8) Seite 17
ΔVF = VF - VF(25 °C) = f(Tj); IF = 500 mA
ΦV/ΦV (25 °C) = f(Tj); IF = 500 mA
GW KAGHB1.xM
Φv
∆VF [V]
GW KAGHB1.EM
1.2
Φv(25°C)
0.0
1.0
-0.2
0.8
-0.4
0.6
-0.6
0.4
-0.8
0.2
-1.0
0.0
40
60
80
100
40
120
60
80
100
Chromaticity Coordinate Shift 8) page 17
Cx, Cy = f(Tj); IF = 500 mA
Cx
Cy
GW KAGHB1.EM
0.46
Cx
Cy
: Cx - 3000 K
: Cy - 3000 K
8) page 17
GW KAGHB1.EM
0.36
: Cx - 6500 K
: Cy - 6500 K
0.44
0.34
0.42
0.32
0.40
0.30
0.38
0.28
40
60
80
100
120
40
Tj [°C]
2014-12-11
120
Tj [°C]
Tj [°C]
60
80
100
120
Tj [°C]
10
Version 1.1
GW KAGHB1.EM
Max. Permissible Forward Current
Max. zulässiger Durchlassstrom
IF = f (T)
IF [mA]
GW KAGHB1.EM
800
700
600
500
400
300
200
100
Do not use below 20 mA
60
80
100
TS [°C]
2014-12-11
11
Version 1.1
GW KAGHB1.EM
Package Outline 9) page 17
Maßzeichnung 9) Seite 17
Approximate Weight:
0.97 g
Gewicht:
0.97 g
2014-12-11
12
Version 1.1
GW KAGHB1.EM
Tray
Bauteilträger
Min. 210 pcs. per packing unit (42 units per tray, min. 5 trays per vacuum bag) / 42 Teile pro
Bauteilträger, 5 Bauteilträger pro Vakuumverpackung
Barcode-Product-Label (BPL)
Barcode-Produkt-Etikett (BPL)
OSRAM Opto
EX
A
RoHS Compliant
(6P) BATCH NO: 1234567890
(1T) LOT NO: 1234567890
BIN1: XX-XX-X-XXX-X
LX XXXX
Semiconductors
MP
ML Temp ST
X XXX °C X
(9D) D/C: 1234
Pack: RXX
LE
DEMY
XXX
X_X123_1234.1234 X
(X) PROD NO: 123456789(Q)QTY:
9999
(G) GROUP:
XX-XX-X-X
OHA04563
Note:
Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card.
Regarding dry pack you will find further information in the internet and in the Short Form Catalog in
chapter “Tape and Reel” under the topic “Dry Pack”. Here you will also find the normative references
like JEDEC.
2014-12-11
13
Version 1.1
Anm.:
GW KAGHB1.EM
Feuchteempfindliche Produkte sind verpackt in einem Trockenbeutel zusammen mit einem
Trockenmittel und einer Feuchteindikatorkarte.
Bezüglich Trockenverpackung finden Sie weitere Hinweise im Internet und in unserem Short Form
Catalog im Kapitel “Gurtung und Verpackung” unter dem Punkt “Trockenverpackung”. Hier sind
Normenbezüge, unter anderem ein Auszug der JEDEC-Norm, enthalten.
Transportation Packing and Materials
Kartonverpackung und Materialien
Dimensions of transportation box in mm
Width
Length
Height
Breite
Länge
Höhe
284 ± 3
268 ± 3
55 ± 3
2014-12-11
14
Version 1.1
GW KAGHB1.EM
Notes
Hinweise
The evaluation of eye safety occurs according to the
standard IEC 62471:2008 ("photobiological safety of
lamps and lamp systems"). Within the risk grouping
system of this CIE standard, the LED specified in this
data sheet fall into the class Low risk (exposure time
100 s). Under real circumstances (for exposure time,
eye pupils, observation distance), it is assumed that
no endangerment to the eye exists from these
devices. As a matter of principle, however, it should
be mentioned that intense light sources have a high
secondary exposure potential due to their blinding
effect. As is also true when viewing other bright light
sources (e.g. headlights), temporary reduction in
visual acuity and afterimages can occur, leading to
irritation, annoyance, visual impairment, and even
accidents, depending on the situation.
Die Bewertung der Augensicherheit erfolgt nach
dem Standard IEC 62471:2008 ("photobiological
safety of lamps and lamp systems"). Im
Risikogruppensystem dieser CIE- Norm erfüllen die
in diesem Datenblatt angegebenen LEDs folgende
Gruppenanforderung - Low risk (Expositionsdauer
100 s). Unter realen Umständen (für
Expositionsdauer, Augenpupille,
Betrachtungsabstand) geht damit von diesen
Bauelementen keinerlei Augengefährdung aus.
Grundsätzlich sollte jedoch erwähnt werden, dass
intensive Lichtquellen durch ihre Blendwirkung ein
hohes sekundäres Gefahrenpotenzial besitzen.
Nach einem Blick in eine helle Lichtquelle (z.B.
Autoscheinwerfer), kann ein temporär
eingeschränktes Sehvermögen oder auch
Nachbilder zu Irritationen, Belästigungen,
Beeinträchtigungen oder sogar Unfällen führen.
This LED contains metal materials. Corroded metal
may lead to a worsening of the optical performance
of the LED and can in the worst case lead to a failure
of the LED. Do not expose this LED to aggressive
atmospheres. Note, that corrosive gases may as
well be emitted from materials close to the LED in the
final product.
Diese LED enthält teilweise metallische
Bestandteile. Korrodiertes Metall kann zu einer
Verschlechterung der optischen Eigenschaften und
im schlimmsten Fall zum Ausfall der LED führen.
Diese LED darf aggressiven Bedingungen nicht
ausgesetzt werden. Es ist zu beachten, dass
korrosive Gase auch von Materialien emittiert
werden können, die sich im Endprodukt in
unmittelbarer Umgebung der LED befinden.
For further application related informations
please visit www.osram-os.com/appnotes
Für weitere applikationsspezifische
Informationen besuchen Sie bitte
Change management for this component is aligned
with the requirements of the lighting market.
Das Änderungsmanagement dieses Bauteils ist an
den Anforderungen des Lichtmarktes ausgerichtet.
2014-12-11
15
Version 1.1
GW KAGHB1.EM
Disclaimer
Disclaimer
Attention please!
The information describes the type of component and
shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved.
Due to technical requirements components may contain
dangerous substances.
For information on the types in question please contact
our Sales Organization.
If printed or downloaded, please find the latest version in
the Internet.
Packing
Please use the recycling operators known to you. We
can also help you – get in touch with your nearest sales
office.
By agreement we will take packing material back, if it is
sorted. You must bear the costs of transport. For
packing material that is returned to us unsorted or which
we are not obliged to accept, we shall have to invoice
you for any costs incurred.
Components used in life-support devices or
systems must be expressly authorized for such
purpose!
Critical components* may only be used in life-support
devices** or systems with the express written approval
of OSRAM OS.
Bitte beachten!
Lieferbedingungen und Änderungen im Design
vorbehalten. Aufgrund technischer Anforderungen
können die Bauteile Gefahrstoffe enthalten. Für weitere
Informationen zu gewünschten Bauteilen, wenden Sie
sich bitte an unseren Vertrieb. Falls Sie dieses
Datenblatt ausgedruckt oder heruntergeladen haben,
finden Sie die aktuellste Version im Internet.
Verpackung
Benutzen Sie bitte die Ihnen bekannten Recyclingwege.
Wenn diese nicht bekannt sein sollten, wenden Sie sich
bitte an das nächstgelegene Vertriebsbüro. Wir nehmen
das Verpackungsmaterial zurück, falls dies vereinbart
wurde und das Material sortiert ist. Sie tragen die
Transportkosten. Für Verpackungsmaterial, das
unsortiert an uns zurückgeschickt wird oder das wir nicht
annehmen müssen, stellen wir Ihnen die anfallenden
Kosten in Rechnung.
Bauteile, die in lebenserhaltenden Apparaten und
Systemen eingesetzt werden, müssen für diese
Zwecke ausdrücklich zugelassen sein!
Kritische Bauteile* dürfen in lebenserhaltenden
Apparaten und Systemen** nur dann eingesetzt
werden, wenn ein schriftliches Einverständnis von
OSRAM OS vorliegt.
*) A critical component is a component used in a
life-support device or system whose failure can
reasonably be expected to cause the failure of that
life-support device or system, or to affect its safety or the
effectiveness of that device or system.
**) Life support devices or systems are intended (a) to be
implanted in the human body, or (b) to support and/or
maintain and sustain human life. If they fail, it is
reasonable to assume that the health and the life of the
user may be endangered.
*) Ein kritisches Bauteil ist ein Bauteil, das in
lebenserhaltenden
Apparaten
oder
Systemen
eingesetzt wird und dessen Defekt voraussichtlich zu
einer Fehlfunktion dieses lebenserhaltenden Apparates
oder Systems führen wird oder die Sicherheit oder
Effektivität
dieses
Apparates
oder
Systems
beeinträchtigt.
**) Lebenserhaltende Apparate oder Systeme sind für
(a) die Implantierung in den menschlichen Körper oder
(b) für die Lebenserhaltung bestimmt. Falls Sie
versagen, kann davon ausgegangen werden, dass die
Gesundheit und das Leben des Patienten in Gefahr ist.
2014-12-11
16
Version 1.1
GW KAGHB1.EM
Glossary
Glossar
1)
Brightness: Brightness groups are tested at a
current pulse duration of 25 ms and a tolerance of
± 11%.
1)
Helligkeit: Helligkeitswerte werden mit
Stromeinprägedauer von 25 ms und
Genauigkeit von ± 11% ermittelt.
2)
Forward Voltage: Forward voltages are tested at a
current pulse duration of 1 ms and a tolerance of ±
0.1 V.
2)
Durchlassspannung: Spannungswerte werden mit
einer Stromeinprägedauer von 1 ms und einer
Genauigkeit von ± 0,1 V ermittelt.
3)
Specification Curve: In the range where the line of
the graph is broken, you must expect higher
differences between single LEDs within one packing
unit.
3)
Kennlinien: Im gestrichelten Bereich der Kennlinien
muss mit erhöhten Abweichungen zwischen
Leuchtdioden innerhalb einer Verpackungseinheit
gerechnet werden.
4)
Color reproduction index: Color
reproduction
index values (CRI-RA) are measured during a
current pulse of typically 25 ms and with a tolerance
of ± 3.
4)
Farbwiedergabe Index: Werte
des
Farbwiedergabe Index (CRI-RA) werden während
eines Strompulses einer typischen Dauer von 25 ms
und mit einer Genauigkeit ± 3 gemessen.
5)
Thermal Resistance: Rth max is based on statistic
values (6σ).
5)
Wärmewiderstand: Rth
statistischen Werten (6σ).
6)
Extrapolated Values: The stated values are
extrapolated data. These values are based on the
devices testing limits. The extrapolation is based on
the typical temperature and forward current
characteristics of the device.
6)
Extrapolierte Werte: Bei den angegebenen Werten
handelt es sich um extrapolierte Angaben. Diese
basieren auf den für das Bauteil spezifizierten
Testgrenzen. Die Extrapolation erfolgte anhand der
typischen Temperatur- und Stromabhängigkeit des
Bauteils.
7)
Chromaticity coordinate groups: Chromaticity
coordinate groups are tested at a junction
temperature of 25 °C, a current pulse duration of
25 ms and a tolerance of ±0.01.
7)
Farbortgruppen: Farbortgruppen werden bei einer
Sperrschichttemperatur von 25 °C, mit einer
Stromeinprägedauer von 25 ms und einer
Genauigkeit von ±0,01 ermittelt.
8)
Typical Values: Due to the special conditions of the
manufacturing processes of LED, the typical data or
calculated correlations of technical parameters can
only reflect statistical figures. These do not
necessarily correspond to the actual parameters of
each single product, which could differ from the
typical data and calculated correlations or the typical
characteristic line. If requested, e.g. because of
technical improvements, these typ. data will be
changed without any further notice.
8)
Typische Werte: Wegen
der
besonderen
Prozessbedingungen bei der Herstellung von LED
können typische oder abgeleitete technische
Parameter nur aufgrund statistischer Werte
wiedergegeben werden. Diese stimmen nicht
notwendigerweise mit den Werten jedes einzelnen
Produktes überein, dessen Werte sich von typischen
und abgeleiteten Werten oder typischen Kennlinien
unterscheiden können. Falls erforderlich, z.B.
aufgrund technischer Verbesserungen, werden
diese typischen Werte ohne weitere Ankündigung
geändert.
9)
Tolerance of Measure: Unless otherwise noted in
drawing, tolerances are specified with ±0.1 and
dimensions are specified in mm.
9)
Maßtoleranz: Wenn in der Zeichnung nicht anders
angegeben, gilt eine Toleranz von ±0,1. Maße
werden in mm angegeben.
max
basiert
einer
einer
auf
Published by OSRAM Opto Semiconductors GmbH
Leibnizstraße 4, D-93055 Regensburg
www.osram-os.com © All Rights Reserved.
2014-12-11
17
Version 1.1
2014-12-11
GW KAGHB1.EM
18
