CXA1507-0000-000N0YE227F
    WOLFSPEED
    LEDCOBCXA15072700KWHITESMD
CXA1507-0000-000N0YE227F 数据手册
PRODUCT FAMILY DATA SHEET XLamp® CXB1507 LED PRODUCT DESCRIPTION FEATURES TABLE OF CONTENTS The XLamp® CXB1507 LED Array is a • 9‑mm optical source Characteristics................................................ 2 member of the second generation of the • Mechanical and optical design Operating Limits.............................................. 3 CXA family that delivers up to 30% higher consistent with other CXA15 and Flux Characteristics, EasyWhite® Order efficacy and up to 20% higher lumens than CXB15 LEDs Codes and Bins - 18 V..................................... 4 the first generation in the same LES. The • Available in 70-, 80-, 90- and Flux Characteristics, Premium Color Order higher performance second generation Codes and Bins - 18 V..................................... 7 95-minimum CRI options CXA LED Arrays are compatible with • EasyWhite 2-, 3‑ and 5-step binning Flux Characteristics, EasyWhite® Order the first generation, providing a drop-in • Premium Color 2- and 3-step binning Codes and Bins - 36 V..................................... 8 performance upgrade to existing CXA LED • Forward voltage options: 18‑V class & Flux Characteristics, Premium Color Order designs to shorten the luminaire design Codes and Bins - 36 V................................... 11 ® 36‑V class cycle and improve time to market. Available • 85 °C binning and characterization Relative Spectral Power Distribution, in 2‑step, 3‑step and 5‑step EasyWhite EasyWhite® ................................................... 12 ® bins and 2‑step and 3‑step Premium • Extremely uniform color over viewing angle Relative Spectral Power Distribution, Color bins, the CXB1507 LED delivers high • Top-side solder connections Premium Color.............................................. 13 lumen output and high efficacy in a single, • Thermocouple attach point Electrical Characteristics.............................. 14 easy‑to‑use package that eliminates the • NEMA SSL-3 2011 standard flux bins Relative Luminous Flux................................. 15 need for reflow soldering, enabling lighting • RoHS and REACh compliant Typical Spatial Distribution........................... 17 manufacturers to rapidly address small • UL recognized component (E349212) Performance Groups - Brightness............... 17 form factor lighting applications. Performance Groups - Chromaticity............ 18 ® Premium Color Performance Groups The CX Family LED Design Guide provides Chromaticity.................................................. 19 basic information on the requirements to EasyWhite® Bins Plotted on the 1931 CIE use the CXB1507 LED array successfully in Curve.............................................................. 20 luminaire designs. Premium Color Bins Plotted on the 1931 CIE Color Space............................................ 21 Bin and Order Code Formats........................ 23 Mechanical Dimensions............................... 23 Thermal Design............................................. 24 Notes............................................................. 26 Packaging...................................................... 27 Cree LED / 4400 Silicon Drive / Durham, NC 27703 USA / +1.919.313.5330 / www.cree-led.com © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS117 REV 9A 1 XLAMP ® CXB1507 LED CHARACTERISTICS Characteristics Viewing angle (FWHM) ESD withstand voltage (HBM per Mil-Std-883D) Unit Minimum Typical degrees Maximum 115 V 8000 DC forward current (18 V) mA 750* DC forward current (36 V) mA 375* Reverse current 18 V, 36 V) mA 0.1 Forward voltage (18 V, 400 mA, 85 °C) V 16.9 19 Forward voltage (36 V, 200 mA, 85 °C) V 33.8 38 * Refer to the Operating Limits section. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS117 REV 9A 2 XLAMP ® CXB1507 LED OPERATING LIMITS The maximum current rating of the CXB1507 depends on the case temperature (Tc) when the LED has reached thermal equilibrium under steady-state operation. The graphs shown below assume that the system design employs good thermal management (thermal interface material and heat sink) and may vary when poor thermal management is employed. Please refer to the Mechanical Dimensions section on page 23 for the location of the Tc measurement point. Another important factor in good thermal management is the temperature of the Light Emitting Surface (LES). Cree LED recommends a maximum LES temperature of 135 °C to ensure optimal LED lifetime. Please refer to the Thermal Design section on page 24 for more CXB1507 - 18 V Standard information on LES temperature measurement. 800 85 °C, 750 mA 700 600 If (mA) 500 400 18 V 125 °C, 288 mA 300 200 100 0 0 25 50 75 100 125 150 Case Temperature (°C) CXB1507 - 36 V Standard 400 85 °C, 375 mA 350 300 If (mA) 250 200 36 V 125 °C, 144 mA 150 100 50 0 0 25 50 75 100 125 150 Case Temperature (°C) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS117 REV 9A 3 XLAMP ® CXB1507 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 18 V (IF = 400 mA, TJ = 85 °C) The following table provides order codes for XLamp CXB1507 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 23). CRI* Nominal CCT Min 70 Minimum Luminous Flux Typ --- 6500 K 80 70 70 5000 K 80 90 3-Step --- Flux (lm) @ 85 °C Flux (lm) @ 25 °C** H4 970 1080 J2 1040 1158 J4 1120 1247 CXB1507-0000000F0BJ465E H4 970 1080 CXB1507-0000000F0HH465E J2 1040 1158 CXB1507-0000000F0HJ265E H4 970 1080 CXB1507-0000000F0BH457E J2 1040 1158 J4 1120 1247 CXB1507-0000000F0BJ457E H4 970 1080 CXB1507-0000000F0HH457E J2 1040 1158 CXB1507-0000000F0HJ257E H4 970 1080 CXB1507-0000000F0BH450E J2 1040 1158 J4 1120 1247 H4 970 1080 J2 1040 1158 CXB1507-0000000F0HJ250G G4 840 935 CXB1507-0000000F0UG450G H2 900 1002 H4 970 1080 Group Order Code Group Order Code 65E 65E 57E 57E --- 92 Group Order Code CXB1507-0000000F0BH465E --- --- 5-Step Group --- 5700 K 80 2-Step 50E CXB1507-0000000F0BJ265E CXB1507-0000000F0BJ257E CXB1507-0000000F0BJ250E CXB1507-0000000F0BJ450E 50G 50G CXB1507-0000000F0HH450G 50E CXB1507-0000000F0HH450E CXB1507-0000000F0HJ250E CXB1507-0000000F0UH250G CXB1507-0000000F0UH450G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). • CXB1507 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS117 REV 9A 4 XLAMP ® CXB1507 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 18 V (IF = 400 mA, TJ = 85 °C) - CONTINUED CRI* Nominal CCT Min 70 4000 K 80 90 80 Minimum Luminous Flux Typ --- --- 92 --- 2-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** H4 970 1080 J2 1040 1158 J4 1120 1247 H2 900 1002 H4 970 1080 J2 1040 1158 CXB1507-0000000F0HJ240H CXB1507-0000000F0HJ240G G2 780 869 CXB1507-0000000F0UG240H CXB1507-0000000F0UG240G G4 840 935 H2 900 1002 CXB1507-0000000F0UH240H CXB1507-0000000F0UH240G H2 900 1002 CXB1507-0000000F0HH235H CXB1507-0000000F0HH235G H4 970 1080 J2 1040 1158 CXB1507-0000000F0HJ235H CXB1507-0000000F0HJ235G G2 780 869 CXB1507-0000000F0UG235H CXB1507-0000000F0UG235G G4 840 935 H2 900 1002 CXB1507-0000000F0UH235H CXB1507-0000000F0UH235G G4 840 935 CXB1507-0000000F0HG430H CXB1507-0000000F0HG430G H2 900 1002 H4 970 1080 CXB1507-0000000F0HH430H CXB1507-0000000F0HH430G F4 730 813 CXB1507-0000000F0UF430H CXB1507-0000000F0UF430G G2 780 869 G4 840 935 Group 80 92 --- 92 Group Order Code Group 40E Order Code CXB1507-0000000F0BJ240E CXB1507-0000000F0BJ440E CXB1507-0000000F0HH240H 40H 40H 35H 35H 30H 3000 K 90 Order Code 5-Step CXB1507-0000000F0BH440E 3500 K 90 3-Step 30H CXB1507-0000000F0HH440H CXB1507-0000000F0UG440H CXB1507-0000000F0HH435H CXB1507-0000000F0UG435H CXB1507-0000000F0HH230H CXB1507-0000000F0UG230H CXB1507-0000000F0UG430H CXB1507-0000000F0HH240G 40G 40G 35G 35G 30G 30G CXB1507-0000000F0HH440G CXB1507-0000000F0UG440G CXB1507-0000000F0HH435G CXB1507-0000000F0UG435G CXB1507-0000000F0HH230G CXB1507-0000000F0UG230G CXB1507-0000000F0UG430G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). • CXB1507 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS117 REV 9A 5 XLAMP ® CXB1507 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 18 V (IF = 400 mA, TJ = 85 °C) - CONTINUED CRI* Nominal CCT Min 80 Minimum Luminous Flux Typ --- 2-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** G4 840 935 H2 900 1002 H4 970 1080 CXB1507-0000000F0HH427H CXB1507-0000000F0HH427G F2 680 757 CXB1507-0000000F0UF227H CXB1507-0000000F0UF227G F4 730 813 G2 780 869 G2 780 869 Group 2200 K 80 92 --- Order Code Group CXB1507-0000000F0HG427H 27H 2700 K 90 3-Step 27H CXB1507-0000000F0HH227H CXB1507-0000000F0UF427H Order Code 5-Step Group Order Code CXB1507-0000000F0HG427G 27G 27G CXB1507-0000000F0UG227H CXB1507-0000000F0HH227G CXB1507-0000000F0UF427G CXB1507-0000000F0UG227G 22G CXB1507-0000000F0HG222G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). • CXB1507 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS117 REV 9A 6 XLAMP ® CXB1507 LED FLUX CHARACTERISTICS, PREMIUM COLOR ORDER CODES AND BINS - 18 V (I F = 400 mA, TJ = 85 °C) Fidelity CRI* Nominal CCT Minimum Luminous Flux Min Typ Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** 4000 K 95 98 G2 780 869 3500 K 95 98 F4 730 3000 K 95 98 F2 2700 K 95 98 F2 Typical Luminous Flux (lm) @ 85 °C 2-Step Group Order Code 818 L5A CXB1507-0000-000F0ZG2L5A 813 788 35H CXB1507-0000-000F0ZF435H 680 757 757 30H CXB1507-0000-000F0ZF230H 680 757 714 27H CXB1507-0000-000F0ZF227H Specialty CRI Nominal CCT 3100 K 3000 K Minimum Luminous Flux Typical Luminous Flux (lm) @ 85 °C Min Typ Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** 90 92 G4 840 935 870 80 --- H2 900 1002 1000 90 92 G4 840 935 870 95 98 F2 680 757 730 2-Step Group L7B L7C Order Code 3-Step Group Order Code 31Q CXB1507-0000000F0UG431Q 30Q CXB1507-0000000F0UG430Q Group Order Code 30U CXB1507-0000000F0UG430U CXB1507-0000000F0HH2L7B CXB1507-0000000F0ZF2L7C Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). • CXB1507 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS117 REV 9A 7 XLAMP ® CXB1507 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 36 V (IF = 200 mA, TJ = 85 °C) The following table provides order codes for XLamp CXB1507 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 23). CRI* Nominal CCT Min 70 Minimum Luminous Flux Typ --- 6500 K 80 70 70 5000 K 80 90 3-Step --- Flux (lm) @ 85 °C Flux (lm) @ 25 °C** H4 970 1080 J2 1040 1158 J4 1120 1247 CXB1507-0000000N0BJ465E H4 970 1080 CXB1507-0000000N0HH465E J2 1040 1158 CXB1507-0000000N0HJ265E H4 970 1080 CXB1507-0000000N0BH457E J2 1040 1158 J4 1120 1247 CXB1507-0000000N0BJ457E H4 970 1080 CXB1507-0000000N0HH457E J2 1040 1158 CXB1507-0000000N0HJ257E H4 970 1080 CXB1507-0000000N0BH450E J2 1040 1158 J4 1120 1247 H4 970 1080 J2 1040 1158 CXB1507-0000000N0HJ250G G4 840 935 CXB1507-0000000N0UG450G H2 900 1002 H4 970 1080 Group Order Code Group Order Code 65E 65E 57E 57E --- 92 Group Order Code CXB1507-0000000N0BH465E --- --- 5-Step Group --- 5700 K 80 2-Step 50E CXB1507-0000000N0BJ265E CXB1507-0000000N0BJ257E CXB1507-0000000N0BJ250E CXB1507-0000000N0BJ450E 50G 50G CXB1507-0000000N0HH450G 50E CXB1507-0000000N0HH450E CXB1507-0000000N0HJ250E CXB1507-0000000N0UH250G CXB1507-0000000N0UH450G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). • CXB1507 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS117 REV 9A 8 XLAMP ® CXB1507 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 36 V (IF = 200 mA, TJ = 85 °C) - CONTINUED CRI* Nominal CCT Min 70 4000 K 80 90 80 Minimum Luminous Flux Typ --- --- 92 --- 2-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** H4 970 1080 J2 1040 1158 J4 1120 1247 H2 900 1002 H4 970 1080 J2 1040 1158 CXB1507-0000000N0HJ240H CXB1507-0000000N0HJ240G G2 780 869 CXB1507-0000000N0UG240H CXB1507-0000000N0UG240G G4 840 935 H2 900 1002 CXB1507-0000000N0UH240H CXB1507-0000000N0UH240G H2 900 1002 CXB1507-0000000N0HH235H CXB1507-0000000N0HH235G H4 970 1080 J2 1040 1158 CXB1507-0000000N0HJ235H CXB1507-0000000N0HJ235G G2 780 869 CXB1507-0000000N0UG235H CXB1507-0000000N0UG235G G4 840 935 H2 900 1002 CXB1507-0000000N0UH235H CXB1507-0000000N0UH235G G4 840 935 CXB1507-0000000N0HG430H CXB1507-0000000N0HG430G H2 900 1002 H4 970 1080 CXB1507-0000000N0HH430H CXB1507-0000000N0HH430G F4 730 813 CXB1507-0000000N0UF430H CXB1507-0000000N0UF430G G2 780 869 G4 840 935 Group 80 92 --- 92 Group Order Code Group 40E Order Code CXB1507-0000000N0BJ240E CXB1507-0000000N0BJ440E CXB1507-0000000N0HH240H 40H 40H 35H 35H 30H 3000 K 90 Order Code 5-Step CXB1507-0000000N0BH440E 3500 K 90 3-Step 30H CXB1507-0000000N0HH440H CXB1507-0000000N0UG440H CXB1507-0000000N0HH435H CXB1507-0000000N0UG435H CXB1507-0000000N0HH230H CXB1507-0000000N0UG230H CXB1507-0000000N0UG430H CXB1507-0000000N0HH240G 40G 40G 35G 35G 30G 30G CXB1507-0000000N0HH440G CXB1507-0000000N0UG440G CXB1507-0000000N0HH435G CXB1507-0000000N0UG435G CXB1507-0000000N0HH230G CXB1507-0000000N0UG230G CXB1507-0000000N0UG430G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). • CXB1507 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS117 REV 9A 9 XLAMP ® CXB1507 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 36 V (IF = 200 mA, TJ = 85 °C) - CONTINUED CRI* Nominal CCT Min 80 Minimum Luminous Flux Typ --- 2-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** G4 840 935 H2 900 1002 H4 970 1080 CXB1507-0000000N0HH427H CXB1507-0000000N0HH427G F2 680 757 CXB1507-0000000N0UF227H CXB1507-0000000N0UF227G F4 730 813 G2 780 869 G2 780 869 Group 2200 K 80 92 --- Order Code Group CXB1507-0000000N0HG427H 27H 2700 K 90 3-Step 27H CXB1507-0000000N0HH227H CXB1507-0000000N0UF427H Order Code 5-Step Group Order Code CXB1507-0000000N0HG427G 27G 27G CXB1507-0000000N0UG227H CXB1507-0000000N0HH227G CXB1507-0000000N0UF427G CXB1507-0000000N0UG227G 22G CXB1507-0000000N0HG222G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). • CXB1507 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS117 REV 9A 10 XLAMP ® CXB1507 LED FLUX CHARACTERISTICS, PREMIUM COLOR ORDER CODES AND BINS - 36 V (I F = 200 mA, TJ = 85 °C) Fidelity CRI* Nominal CCT Minimum Luminous Flux Min Typ Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** 4000 K 95 98 G2 780 869 3500 K 95 98 F4 730 3000 K 95 98 F2 2700 K 95 98 F2 Typical Luminous Flux (lm) @ 85 °C 2-Step Group Order Code 818 L5A CXB1507-0000-000N0ZG2L5A 813 788 35H CXB1507-0000-000N0ZF435H 680 757 757 30H CXB1507-0000-000N0ZF230H 680 757 714 27H CXB1507-0000-000N0ZF227H Specialty CRI Nominal CCT 3100 K 3000 K Minimum Luminous Flux Typical Luminous Flux (lm) @ 85 °C Min Typ Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** 90 92 G4 840 935 870 80 --- H2 900 1002 1000 90 92 G4 840 935 870 95 98 F2 680 757 730 2-Step Group L7B L7C Order Code 3-Step Group Order Code 31Q CXB1507-0000000N0UG431Q 30Q CXB1507-0000000N0UG430Q Group Order Code 30U CXB1507-0000000N0UG430U CXB1507-0000000N0HH2L7B CXB1507-0000000N0ZF2L7C Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). • CXB1507 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS117 REV 9A 11 XLAMP ® CXB1507 LED RELATIVE SPECTRAL POWER DISTRIBUTION, EASYWHITE® The following graph is the result of a series of pulsed measurements at 400 mA for the 18-V CXB1507 LED and 200 mA for the 36-V CXB1507 LED and TJ = 85 °C. 100% Relative Spectral Power 90% 80% 70% 5000 K, 70 CRI 60% 4000 K, 70 CRI 50% 3000 K, 80 CRI 40% 3000 K, 90 CRI 30% 2200 K, 80 CRI 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS117 REV 9A 12 XLAMP ® CXB1507 LED RELATIVE SPECTRAL POWER DISTRIBUTION, PREMIUM COLOR The following graphs are the result of a series of pulsed measurements at 400 mA for the 18-V CXB1507 LED and 200 mA for the 36-V CXB1507 LED and TJ = 85 °C. Fidelity 100% Relative Spectral Power 90% 80% 70% 60% 4000 K, Z CRI 50% 3500 K, Z CRI 3000 K, Z CRI 40% 2700 K, Z CRI 30% 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Relative Spectral Power Distribution Specialty 100% Relative Spectral Power 90% 80% 70% 31Q, 3100 K, 90 CRI 60% 30Q, 3000 K, 90 CRI 50% L7B, 3000 K 80 CRI 40% L7C, 3000 K, Z CRI 30% 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS117 REV 9A 13 XLAMP ® CXB1507 LED ELECTRICAL CHARACTERISTICS The following graphs are the result of a series of steady-state measurements. 18.5 18 V Voltage (V) 18.0 Tc = 25 °C 17.5 Tc = 55 °C Tc = 85 °C 17.0 Tc = 105 °C 16.5 16.0 200 250 300 350 400 450 500 550 600 650 700 750 Current (mA) 37 36 V Voltage (V) 36 Tc = 25 °C 35 Tc = 55 °C Tc = 85 °C 34 Tc = 105 °C 33 32 100 125 150 175 200 225 250 275 300 325 350 375 Current (mA) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS117 REV 9A 14 XLAMP ® CXB1507 LED RELATIVE LUMINOUS FLUX The relative luminous flux values provided below are the ratio of measurements of the CXB1507 LED at steady-state operation at the given conditions, divided by flux measured during binning, which is a pulsed measurement at 400 mA at TJ = 85 °C for the 18-V CXB1507 LED. Using the 18-V CXB1507 LED as an example, at steady-state operation of Tc = 105 °C, IF = 550 mA, the relative luminous flux ratio is 120% in the chart below. A CXB1507 LED that measures 900 lm during binning will deliver 1080 lm (900 * 1.2) at steady-state operation of Tc = 105 °C, IF = 550 mA. 200% 18 V 180% Relative Luminous Flux 160% 140% Tc = 25 °C 120% Tc = 55 °C 100% Tc = 85 °C 80% Tc = 105 °C 60% 40% 20% 0% 200 250 300 350 400 450 500 550 600 650 700 750 Current (mA) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS117 REV 9A 15 XLAMP ® CXB1507 LED RELATIVE LUMINOUS FLUX - CONTINUED The relative luminous flux values provided below are the ratio of measurements of the CXB1507 LED at steady-state operation at the given conditions, divided by flux measured during binning, which is a pulsed measurement at 200 mA at TJ = 85 °C for the 36-V CXB1507 LED. Using the 36-V CXB1507 LED as an example, at steady-state operation of Tc = 105 °C, IF = 275 mA, the relative luminous flux ratio is 120% in the chart below. A CXB1507 LED that measures 900 lm during binning will deliver 1080 lm (900 * 1.2) at steady-state operation of Tc = 105 °C, IF = 275 mA. 200% 36 V 180% Relative Luminous Flux 160% 140% Tc = 25 °C 120% Tc = 55 °C 100% Tc = 85 °C 80% Tc = 105 °C 60% 40% 20% 0% 100 125 150 175 200 225 250 275 300 325 350 375 Current (mA) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS117 REV 9A 16 XLAMP ® CXB1507 LED Far Field TYPICAL SPATIAL DISTRIBUTION 100% Relative Luminous Intensity 80% 60% 40% 20% -90 -70 -50 -30 -10 0% 10 30 50 70 90 Angle (º) PERFORMANCE GROUPS - BRIGHTNESS (18 V, I F = 400 mA; 36 V, IF = 200 mA, TJ = 85 °C) XLamp CXB1507 LEDs are tested for luminous flux and placed into one of the following bins. Group Code Minimum Luminous Flux Maximum Luminous Flux F2 680 730 F4 730 780 G2 780 840 G4 840 900 H2 900 970 H4 970 1040 J2 1040 1120 J4 1120 1200 K2 1200 1290 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS117 REV 9A 17 XLAMP ® CXB1507 LED PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) XLamp CXB1507 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. EasyWhite Color Temperatures – 2-Step Code 40H 35H 30H 27H CCT 4000 K 3500 K 3000 K 2700 K x y 0.3777 0.3739 0.3797 0.3816 0.3861 0.3855 0.3838 0.3777 0.4022 0.3858 0.4053 0.3942 0.4125 0.3977 0.4091 0.3891 0.4287 0.3975 0.4328 0.4064 0.4390 0.4086 0.4347 0.3996 0.4524 0.4048 0.4574 0.4140 0.4633 0.4154 0.4581 0.4062 EasyWhite Color Temperatures – 3-Step Ellipse Bin Code CCT 50G 40G Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 5000 K 0.3447 0.3553 0.00840 0.00312 65.0 4000 K 0.3818 0.3797 0.00939 0.00402 53.7 35G 3500 K 0.4073 0.3917 0.00927 0.00414 54.0 30G 3000 K 0.4338 0.4030 0.00834 0.00408 53.2 27G 2700 K 0.4577 0.4099 0.00834 0.00420 48.5 22G 2200 K 0.5066 0.4158 0.00980 0.00480 45.5 EasyWhite Color Temperatures – 5-Step Ellipse Bin Code CCT 65E Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 6500 K 0.3123 0.3282 0.01110 0.00550 61.0 57E 5700 K 0.3287 0.3417 0.01230 0.00600 72.0 50E 5000 K 0.3447 0.3553 0.01400 0.00520 65.0 40E 4000 K 0.3818 0.3797 0.01565 0.00670 53.7 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS117 REV 9A 18 XLAMP ® CXB1507 LED PREMIUM COLOR PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) XLamp CXB1507 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. Fidelity EasyWhite Color Temperatures – 2-Step Code L5A 35H 30H 27H CCT 4000 K 3500 K 3000 K 2700 K x y 0.3764 0.3711 0.3784 0.3787 0.3847 0.3826 0.3825 0.3748 0.4022 0.3858 0.4053 0.3942 0.4125 0.3977 0.4091 0.3891 0.4287 0.3975 0.4328 0.4064 0.4390 0.4086 0.4347 0.3996 0.4524 0.4048 0.4574 0.4140 0.4633 0.4154 0.4581 0.4062 Specialty EasyWhite Color Temperatures – 2-Step Code L7B L7C CCT 3000 K 3000 K x y 0.4263 0.3848 0.4296 0.3916 0.4361 0.3938 0.4326 0.3868 0.4192 0.3754 0.4224 0.3823 0.4291 0.3847 0.4257 0.3777 EasyWhite Color Temperatures – 3-Step Ellipse Center Point Major Axis Minor Axis Rotation Angle (°) Bin Code CCT x y a b 31Q 3100 K 0.4236 0.3888 0.00848 0.00455 50.3 30Q 3000 K 0.4305 0.3935 0.00834 0.00408 53.2 30U 3000 K 0.4274 0.3837 0.00834 0.00408 53.2 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS117 REV 9A 19 XLAMP ® CXB1507 LED EASYWHITE® BINS PLOTTED ON THE 1931 CIE CURVE 0.45 ANSI C78.377 Quadrangle 0.44 2700 K EasyWhite 5-step 0.43 2200 K 2450 K 3000 K EasyWhite 3-step 0.42 EasyWhite 2-step 3500 K 0.41 4000 K 0.40 CCy 0.39 5000 K 4500 K 5700 K 0.38 0.37 6500 K 0.36 0.35 7000K 0.34 0.33 0.32 0.54 0.53 0.52 0.51 0.50 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.31 CCx © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS117 REV 9A 20 XLAMP ® CXB1507 LED PREMIUM COLOR BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) Fidelity (2-step) 0.44 2700K ANSI C78.377 Quadrangle 0.43 3000K 0.42 3500K 0.41 27H 4000K CCy 0.40 30H 4500K 35H 0.39 0.38 L5A 0.37 0.36 0.35 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. 0.48 0.47 0.46 0.45 0.44 CCx 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 CLD-DS117 REV 9A 21 XLAMP ® CXB1507 LED PREMIUM COLOR BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) - CONTINUED Speciality (2-step) 0.44 ANSI C78.377 Quadrangle 3000 K 0.43 0.42 3500 K CCy 0.41 0.40 0.39 L7B L7C 0.38 0.46 0.45 CCx 0.44 0.43 0.42 0.41 0.37 Speciality (3-step) 0.44 ANSI C78.377 Quadrangle 3000K 0.43 0.42 3500K CCy 0.41 0.40 30Q 0.39 31Q 30U 0.38 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. 0.46 0.45 CCx 0.44 0.43 0.42 0.41 0.37 CLD-DS117 REV 9A 22 XLAMP ® CXB1507 LED BIN AND ORDER CODE FORMATS Bin codes and order codes are configured as follows: Order Code Bin Code Series = CXB15 Series = CXB15 Internal code Chromaticity bin CRI Specification B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Vf class: F0 = 18-V class N0 = 36-V class SSSSSCC-HHHH-HHHGGNNNNNN Internal code Kit code SSSSSCC-WWW-FF-GGR-AAAAA CRI Specification B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Vf class: F0 = 18-V class N0 = 36-V class Performance class Flux bin Performance class MECHANICAL DIMENSIONS Dimensions are in mm. Tolerances unless otherwise specified: +.13 x° +1° B1507F = 18‑V CXB1507 B1507N = 36‑V CXB1507 B1507X Meaning of B1507X © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS117 REV 9A 23 XLAMP ® CXB1507 LED THERMAL DESIGN The CXB family of LED arrays can include over a hundred different LED die inside one package, and thus over a hundred different junction temperatures (TJ). Cree LED has intentionally removed junction-temperature-based operating limits and replaced the commonplace maximum TJ calculations with maximum ratings based on forward current (IF) and case temperature (Tc). No additional calculations are required to ensure that the CXB LED is being operated within its designed limits. LES temperature measurement provides additional verification of good thermal design. Please refer to page 3 for the Operating Limit specifications. There is no need to calculate for TJ inside the package, as the thermal management design process, specifically from TSP to ambient (Ta), remains identical to any other LED component. For more information on thermal management of XLamp LEDs, please refer to the Thermal Management application note. For CXB soldering recommendations and more information on thermal interface materials (TIM), LES temperature measurement, and connection methods, please refer to the XLamp CX Family LEDs soldering and handling document. The CX Family LED Design Guide provides basic information on the requirements to use XLamp CXB LEDs successfully in luminaire designs.. To keep the CXB1507 LED at or below the maximum rated Tc, the case to ambient temperature thermal resistance (R_c-a) must be at or below the maximum R_c-a value shown on the following graphs, depending on the operating environment. The y‑axis in the graphs is a base 10 logarithmic scale. As the figure at right shows, the R_c-a value is the sum of the thermal resistance of the TIM (R_tim) plus the thermal resistance of the heat sink (R_hs). R_j-c R_j-c Tc Tc R_tim R_c-a R_hs CXA1507 - 18 V Ta Ta 100.00 18 V Maximum R_c-a 10.00 Ta = 25 °C Ta = 55 °C 1.00 Ta = 85 °C Ta = 105 °C 0.10 0.01 200 250 300 350 400 450 500 550 600 650 700 750 Current (mA) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS117 REV 9A 24 XLAMP ® CXB1507 LED THERMALCXB1507 DESIGN -- CONTINUED 36 V 100.00 36 V Maximum R_c-a 10.00 Ta = 25 °C Ta = 55 °C 1.00 Ta = 85 °C Ta = 105 °C 0.10 0.01 100 125 150 175 200 225 250 275 300 325 350 375 Current (mA) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS117 REV 9A 25 XLAMP ® CXB1507 LED NOTES Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs. Lumen Maintenance Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. REACh Compliance REACh substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative to insure you get the most up-to-date REACh Declaration. REACh banned substance information (REACh Article 67) is also available upon request. UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS117 REV 9A 26 XLAMP ® CXB1507 LED PACKAGING 6 CXB1507 LEDs are packaged in5 trays of 20. Five trays are sealed in an anti-static bag and placed inside a carton, for a total of2 100 LEDs 4 3 per carton. Each carton contains 100 LEDs from the same performance bin. NOTICE ENTIAL. THIS PLOT AND THE INFORMATION WITHIN ARE THE PROPRIETARY AND AL INFORMATION OF CREE, INC. THIS PLOT COPIED, REPRODUCED OR DISCLOSED TO ANY ED PERSON WITHOUT THE WRITTEN CONSENT NSENT Dimensions are in inches. Tolerances: +13 5 4 x° +1° 3 5.875 2 1 R .375 6 5 4 NOTICE FIDENTIAL. THIS PLOT AND THE INFORMATION D WITHIN ARE THE PROPRIETARY AND TIAL INFORMATION OF CREE, INC. THIS PLOT E COPIED, REPRODUCED OR DISCLOSED TO ANY IZED PERSON WITHOUTTHE WRITTEN CONSENT C. 3 5.875 2 1 .875 R .375 5.875 R.375 5.875 .875 .875 5.875 LABEL WITH CREE BIN CODE, QUANTITY, LOT # BAG .38 .875 PATENT LABEL IS LOCATED PATENT LABEL IS ON UNDERSIDE OFLOCATED COVER ON UNDERSIDE OF CARTON ITH CREE BIN ANTITY, LOT # .875 LABEL WITH CREE .875 BIN CODE, QTY, LOT# .38 BAG BAG .38 LABEL WITH CREE BIN CODE, QUANTITY, LOT # PATENT LABEL EL IS LOCATED IS LOCATED ON UNDERSIDE OF CARTON IDE OF COVER LABEL WITH CREE BIN CODE, QTY, LOT# LABEL WITH CREE BIN CODE, QUANTITY, LOT # LABEL WITH CREE BIN CODE, QUANTITY, LOT # UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS & BEFORE FINISH. TOLERANCE UNLESS SPECIFIED: LABEL WITH CREE BIN CODE, QUANTITY, LOT # .X ± .XX ± .XXX ± X° ± THIRD ANGLE PROJECTION 5 L WITH CREE BIN QUANTITY, LOT # 6 3.X .XX ± 0.1 ± .05 .XXX ±DRAWN .005BY X° ± 1° 4 THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED DIMENSIONS AREFOR IN SHEET METAL PARTS ONLY CHECK MILLIMETERS & BEFORE FINISH. .X ± .06 TOLERANCE UNLESS SPECIFIED: .XX ± .03 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered .XXX and ±APPROVED .010 .X ± trademarks, 0.1 X° ± 2° ± .05 registered the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the.XXUL logo are 5 4 3.XXX ± .005 trademarks of UL LLC. THIRD ANGLE PROJECTION MATERIAL X° ± 1 ° FOR SHEET METAL PARTS ONLY .X ± .06 APPROVED DATE APPROVED DATE TITLE CXA15 SIZE FINAL PROTECTIVE FINISH DRAW C CXA 4600 Silicon Dri Durham, N.C 27 SCALE Phone (919) 361 0.500 Fax (919) 313-5 2 DATE TITLE CXA15XX_DATASHEET DATE MATERIAL SIZE DATE FINAL PROTECTIVE FINISH DATE TITLE 2 C DRAWING NO. 4600 Silicon Drive Durham, N.C 27703 Phone (919) 361-4770 CXA15XX_DATASHEET_BAG2013 CLD-DS117 SCALE 0.500 REV 9A 27 Fax (919) 313-5303 SHEET CXA15XX_DATASHEET SIZE FINAL PROTECTIVE FINISH DATE MATERIAL FOR SHEET METAL PARTS ONLY DRAWN BY ± .06 DATE UNLESS OTHERWISE SPECIFIED .X .XX ± .03 DIMENSIONS ARE IN CHECK ± .XXX .010 DATE MILLIMETERS & BEFORE FINISH. ± 2 ° TOLERANCE UNLESS SPECIFIED: X° LABEL WITH CREE BIN CODE, QTY, LOT# 6 0.1 .05 .005 1 ° DRAWN BY CHECK 1 DRAWING NO. CXA15XX_DATASHEET_BAG2013 OF
物料型号:XLamp® CXB1507 LED
器件简介: - 属于CXA家族的第二代产品,提供比第一代更高的光效和光通量。 - 设计用于缩短灯具设计周期,提供2步和3步的高级易白(EasyWhite®)色温分选。
引脚分配: - 文档中未明确列出引脚分配,但提到了顶侧焊接连接。
参数特性: - 光学源尺寸为9毫米。 - 色温范围从2700K至6500K,CRI从70至95。 - 正向电压选项包括18V和36V类别。 - 热电偶附着点,符合NEMA SSL-3 2011标准。
功能详解: - 提供高光通量和高效率的单一封装,无需重新焊接,便于照明制造商快速响应市场需求。 - 符合RoHS和REACh标准,UL®认可的组件。
应用信息: - 适用于需要高性能照明的应用,如灯具设计。
封装信息: - 封装类型未在文档中明确说明,但提到了与CXA15和CXB15 LED兼容的机械和光学设计。
电气特性: - 正向电流在18V时为750mA,在36V时为375mA。 - 反向电流在18V和36V时为0.1mA。
热设计: - 强调了良好的热管理,包括适当的热界面材料和散热器。
注意事项: - 文档中提到了测量值的容差,以及产品在发货时的测量规格,这些测量值会随时间变化。
包装: - 每个托盘包含20个LED,每箱总共包含100个LED。
CXA1507-0000-000N0YE227F 价格&库存
很抱歉,暂时无法提供与“CXA1507-0000-000N0YE227F”相匹配的价格&库存,您可以联系我们找货
