CXA1512-0000-000F00M227F
    WOLFSPEED
    LED COB CXA1512 WARM WHT SQUARE
CXA1512-0000-000F00M227F 数据手册
PRODUCT FAMILY DATA SHEET XLamp® CXA1512 LED PRODUCT DESCRIPTION FEATURES TABLE OF CONTENTS The XLamp® CXA1512 LED array expands • Available in 4-step, 3‑step and 2-step Characteristics................................................ 2 Cree LED’s family of high‑flux, multi‑die EasyWhite bins at 2700 K, 3000 K, Operating Limits.............................................. 3 arrays in a smaller, easy‑to‑use platform. 3500 K, 4000 K & 5000 K CCT and Flux Characteristics, EasyWhite® Order With XLamp LED lighting‑class reliability, 4-step EasyWhite bins at 5700 K & Codes and Bins - 18 V..................................... 4 the CXA1512’s small, uniform emitting 6500 K CCT Flux Characteristics, ANSI White Order ® surface enables both directional and non- • Available in ANSI white bins at 4000 K, Codes and Bins - 18 V..................................... 7 directional lighting applications including Flux Characteristics, EasyWhite® Order lamp retrofit and luminaire 5000 K, 5700 K & 6500 K CCT designs. • Available in 70-, 80-, 90- and Available in 2-step, 3‑step and 4-step color 93‑minimum CRI options Codes and Bins - 36 V..................................... 8 Flux Characteristics, ANSI White Order consistency, and featuring a 9‑mm optical • Forward voltage options: 18‑V class & Codes and Bins - 36 V................................... 11 source, the CXA1512 brings new levels of Relative Spectral Power Distribution........... 12 flux and efficacy to this form factor. The CX Family LED Design Guide provides 36‑V class • 85 °C binning and characterization Electrical Characteristics.............................. 13 • Maximum drive current: 1200 mA Relative Luminous Flux................................. 14 (18 V), 600 mA (36 V) Typical Spatial Distribution........................... 16 basic information on the requirements • 115° viewing angle, uniform Performance Groups - Brightness............... 16 to use the CXA1512 LED successfully in Performance Groups - Chromaticity............ 17 luminaire designs. chromaticity profile • Top-side solder connections EasyWhite® Bins Plotted on the 1931 CIE • Thermocouple attach point Color Space................................................... 20 • NEMA SSL-3 2011 standard flux bins ANSI White Bins Plotted on the 1931 CIE • RoHS and REACh compliant Color Space................................................... 20 • UL® recognized component (E349212) Bin and Order Code Formats........................ 21 Mechanical Dimensions............................... 21 Thermal Design............................................. 22 Notes............................................................. 24 Packaging...................................................... 25 Cree LED / 4400 Silicon Drive / Durham, NC 27703 USA / +1.919.313.5330 / www.cree-led.com © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS55 REV 12A 1 XLAMP ® CXA1512 LED CHARACTERISTICS Characteristics Viewing angle (FWHM) ESD withstand voltage (HBM per Mil-Std-883D) Unit Minimum Typical degrees Maximum 115 V 8000 DC forward current (18 V) mA 1200* DC forward current (36 V) mA 600* Reverse current (18 V, 36 V) mA 0.1 Forward voltage (18 V, @ 700 mA, 85 °C) V Forward voltage (18 V, @ 700 mA, 25 °C) V Forward voltage (36 V, @ 350 mA, 85 °C) V Forward voltage (36 V, @ 350 mA, 25 °C) V * 18.2 21 36.4 42 Refer to the Operating Limits section. © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS55 REV 12A 2 XLAMP ® CXA1512 LED OPERATING LIMITS The maximum current rating of the CXA1512 depends on the case temperature (Tc) when the LED has reached thermal equilibrium under steady-state operation. The graphs shown below assume that the system design employs good thermal management (thermal interface material and heat sink) and may vary when poor thermal management is employed. Please refer to the Mechanical Dimensions section on page 21 for the location of the Tc measurement point. Another important factor in good thermal management is the temperature of the Light Emitting Surface (LES). Cree LED recommends a maximum LES temperature of 135 °C to ensure optimal LED lifetime. Please refer to the Thermal Design section on page 22 for more CXA1512 - 18 V information on LES temperature measurement. 1400 1200 If (mA) 1000 800 18 V 600 400 200 0 0 CXA1512 - 36 V 25 50 75 100 125 150 Case Temperature (°C) 700 600 If (mA) 500 400 36 V 300 200 100 0 0 25 50 75 100 125 150 Case Temperature (°C) © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS55 REV 12A 3 XLAMP ® CXA1512 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 18 V (IF = 700 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA1512 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 21). Nominal CCT CRI Min 70 Minimum Luminous Flux Typ 75 2-Step 3-Step 4-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* M2 1380 1563 M4 1485 1682 N2 1590 1710 CXA1512-0000000F00N265F M2 1380 1563 CXA1512-0000000F0HM265F M4 1485 1685 N2 1590 1710 CXA1512-0000000F0HN265F M2 1380 1563 CXA1512-0000000F00M257F M4 1485 1682 N2 1590 1710 CXA1512-0000000F00N257F M2 1380 1563 CXA1512-0000000F0HM257F M4 1485 1682 N2 1590 1710 M2 1380 1563 M4 1485 1682 N2 1590 1710 CXA1512-0000000F00N250H CXA1512-0000000F00N250F M2 1380 1563 CXA1512-0000000F0HM250H CXA1512-0000000F0HM250F M4 1485 1682 N2 1590 1710 CXA1512-0000000F0HN250H CXA1512-0000000F0HN250G CXA1512-0000000F0HN250F J4 1120 1269 CXA1512-0000000F0UJ450H CXA1512-0000000F0UJ450G CXA1512-0000000F0UJ450F K2 1200 1359 K4 1290 1461 Group Order Code Group Order Code Group CXA1512-0000000F00M265F 65F 6500 K 80 70 --- 75 65F 57F 5700 K 80 70 5000 K 80 90 --- 75 --- 95 Order Code 57F CXA1512-0000000F00M465F CXA1512-0000000F0HM465F CXA1512-0000000F00M457F CXA1512-0000000F0HM457F CXA1512-0000000F0HN257F CXA1512-0000000F00M250H 50H 50H 50H CXA1512-0000000F00M250F CXA1512-0000000F00M450H CXA1512-0000000F0HM450H CXA1512-0000000F0UK250H CXA1512-0000000F0UK450H 50F 50G 50G CXA1512-0000000F0HM450G CXA1512-0000000F0UK250G CXA1512-0000000F0UK450G 50H 50F CXA1512-0000000F00M450F CXA1512-0000000F0HM450F CXA1512-0000000F0UK250F CXA1512-0000000F0UK450F Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 24). • CXA1512 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS55 REV 12A 4 XLAMP ® CXA1512 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 18 V (IF = 700 mA, TJ = 85 °C) - CONTINUED Nominal CCT CRI Min 70 4000 K 80 90 80 Minimum Luminous Flux Typ 75 --- 95 --- 2-Step 80 95 --- Flux (lm) @ 85 °C Flux (lm) @ 25 °C* M2 1380 1563 M4 1485 1682 N2 1590 1710 CXA1512-0000000F00N240H CXA1512-0000000F00N240F K4 1290 1461 CXA1512-0000000F0HK440H CXA1512-0000000F0HK440F M2 1380 1563 M4 1485 1682 CXA1512-0000000F0HM440H CXA1512-0000000F0HM440G CXA1512-0000000F0HM440F J2 1040 1178 CXA1512-0000000F0UJ240H CXA1512-0000000F0UJ240G CXA1512-0000000F0UJ240F J4 1120 1269 K2 1200 1359 CXA1512-0000000F0UK240H K4 1290 1461 CXA1512-0000000F00K435H M2 1380 1563 M4 1485 1682 CXA1512-0000000F00M435H CXA1512-0000000F00M435G CXA1512-0000000F00M435F H4 970 1099 CXA1512-0000000F0YH435H CXA1512-0000000F0YH435G CXA1512-0000000F0YH435F J2 1040 1178 J4 1120 1269 CXA1512-0000000F0YJ435H K4 1290 1461 CXA1512-0000000F00K430H M2 1380 1563 M4 1485 1682 CXA1512-0000000F00M430H H4 970 1099 CXA1512-0000000F0YH430H J2 1040 1178 J4 1120 1269 Group 95 Order Code Group Order Code Group CXA1512-0000000F00M240H 40H 40H 40H 35H 35H 30H 3000 K 93 4-Step Group 3500 K 93 3-Step 30H CXA1512-0000000F00M240F CXA1512-0000000F00M440H CXA1512-0000000F0HM240H CXA1512-0000000F0UJ440H CXA1512-0000000F00M235H CXA1512-0000000F0YJ235H CXA1512-0000000F00M230H CXA1512-0000000F0YJ230H CXA1512-0000000F0YJ430H Order Code 40F 40G 40G CXA1512-0000000F0HM240G CXA1512-0000000F0UJ440G 40F 40F CXA1512-0000000F0UK240G CXA1512-0000000F00M440F CXA1512-0000000F0HM240F CXA1512-0000000F0UJ440F CXA1512-0000000F0UK240F CXA1512-0000000F00K435F 35G 35G CXA1512-0000000F00M235G CXA1512-0000000F0YJ235G 35F 35F CXA1512-0000000F0YJ435G CXA1512-0000000F00M235F CXA1512-0000000F0YJ235F CXA1512-0000000F0YJ435F CXA1512-0000000F00K430F 30G CXA1512-0000000F00M230G 30F CXA1512-0000000F00M430G CXA1512-0000000F00M230F CXA1512-0000000F00M430F CXA1512-0000000F0YH430F 30G CXA1512-0000000F0YJ230G CXA1512-0000000F0YJ430G 30F CXA1512-0000000F0YJ230F CXA1512-0000000F0YJ430F Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 24). • CXA1512 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS55 REV 12A 5 XLAMP ® CXA1512 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 18 V (IF = 700 mA, TJ = 85 °C) - CONTINUED Nominal CCT CRI Min 80 Minimum Luminous Flux Typ --- 2-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* K2 1200 1359 K4 1290 1461 M2 1380 1563 CXA1512-0000000F00M227H H2 900 1019 CXA1512-0000000F0YH227H H4 970 1099 J2 1040 1178 Group 95 Group Order Code 4-Step Group CXA1512-0000000F00K227H 27H 2700 K 93 Order Code 3-Step 27H CXA1512-0000000F00K427H CXA1512-0000000F0YH427H CXA1512-0000000F0YJ227H Order Code CXA1512-0000000F00K227F 27G CXA1512-0000000F00K427G 27F CXA1512-0000000F00M227G CXA1512-0000000F00K427F CXA1512-0000000F00M227F CXA1512-0000000F0YH227F 27G CXA1512-0000000F0YH427G CXA1512-0000000F0YJ227G 27F CXA1512-0000000F0YH427F CXA1512-0000000F0YJ227F Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 24). • CXA1512 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS55 REV 12A 6 XLAMP ® CXA1512 LED FLUX CHARACTERISTICS, ANSI WHITE ORDER CODES AND BINS - 18 V (IF = 700 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA1512 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 21). Nominal CCT CRI Min 70 Minimum Luminous Flux Typ 75 6500 K 80 70 --- 75 5700 K 80 70 --- 75 5000 K 80 4000 K 70 --- 75 Chromaticity Regions Order Code Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* M2 1380 1563 M4 1485 1685 N2 1590 1710 CXA1512-0000-000F00N20E1 M2 1380 1563 CXA1512-0000-000F0HM20E1 M4 1485 1685 N2 1590 1710 CXA1512-0000-000F0HN20E1 M2 1380 1563 CXA1512-0000-000F00M20E2 M4 1485 1685 N2 1590 1710 CXA1512-0000-000F00N20E2 M2 1380 1563 CXA1512-0000-000F0HM20E2 M4 1485 1685 N2 1590 1710 CXA1512-0000-000F0HN20E2 M2 1380 1563 CXA1512-0000-000F00M20E3 M4 1485 1685 N2 1590 1710 CXA1512-0000-000F00N20E3 M2 1380 1563 CXA1512-0000-000F0HM20E3 M4 1485 1685 CXA1512-0000-000F00M20E1 1A0, 1B0, 1C0, 1D0, 65F 1A0, 1B0, 1C0, 1D0, 65F 2A0, 2B0, 2C0, 2D0, 57F 2A0, 2B0, 2C0, 2D0, 57F 3A0, 3B0, 3C0, 3D0, 50F 3A0, 3B0, 3C0, 3D0, 50F CXA1512-0000-000F00M40E1 CXA1512-0000-000F0HM40E1 CXA1512-0000-000F00M40E2 CXA1512-0000-000F0HM40E2 CXA1512-0000-000F00M40E3 CXA1512-0000-000F0HM40E3 N2 1590 1710 CXA1512-0000-000F0HN20E3 M2 1380 1563 CXA1512-0000-000F00M40E5 M4 1485 1685 N2 1590 1710 5A0, 5B0, 5C0, 5D0, 40F CXA1512-0000-000F00M40E5 CXA1512-0000-000F00N20E5 Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 24). • CXA1512 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS55 REV 12A 7 XLAMP ® CXA1512 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 36 V (IF = 350 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA1512 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 21). Nominal CCT CRI Min 70 Minimum Luminous Flux Typ 75 2-Step 3-Step 4-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* M2 1380 1563 M4 1485 1682 N2 1590 1710 CXA1512-0000000N00N265F M2 1380 1563 CXA1512-0000000N0HM265F M4 1485 1685 N2 1590 1710 CXA1512-0000000N0HN265F M2 1380 1563 CXA1512-0000000N00M257F M4 1485 1682 N2 1590 1710 CXA1512-0000000N00N257F M2 1380 1563 CXA1512-0000000N0HM257F M4 1485 1682 N2 1590 1710 M2 1380 1563 M4 1485 1682 N2 1590 1710 CXA1512-0000000N00N250H CXA1512-0000000N00N250F M2 1380 1563 CXA1512-0000000N0HM250H CXA1512-0000000N0HM250F M4 1485 1682 N2 1590 1710 CXA1512-0000000N0HN250H CXA1512-0000000N0HN250G CXA1512-0000000N0HN250F J4 1120 1269 CXA1512-0000000N0UJ450H CXA1512-0000000N0UJ450G CXA1512-0000000N0UJ450F K2 1200 1359 K4 1290 1461 Group Order Code Group Order Code Group CXA1512-0000000N00M265F 65F 6500 K 80 70 --- 75 65F 57F 5700 K 80 70 5000 K 80 90 --- 75 --- 95 Order Code 57F CXA1512-0000000N00M465F CXA1512-0000000N0HM465F CXA1512-0000000N00M457F CXA1512-0000000N0HM457F CXA1512-0000000N0HN257F CXA1512-0000000N00M250H 50H 50H 50H CXA1512-0000000N00M250F CXA1512-0000000N00M450H CXA1512-0000000N0HM450H CXA1512-0000000N0UK250H CXA1512-0000000N0UK450H 50F 50G 50G CXA1512-0000000N0HM450G CXA1512-0000000N0UK250G CXA1512-0000000N0UK450G 50H 50F CXA1512-0000000N00M450F CXA1512-0000000N0HM450F CXA1512-0000000N0UK250F CXA1512-0000000N0UK450F Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 24). • CXA1512 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS55 REV 12A 8 XLAMP ® CXA1512 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 36 V (IF = 350 mA, TJ = 85 °C) - CONTINUED Nominal CCT CRI Min 70 4000 K 80 90 80 Minimum Luminous Flux Typ 75 --- 95 --- 2-Step 80 95 --- Flux (lm) @ 85 °C Flux (lm) @ 25 °C* M2 1380 1563 M4 1485 1682 N2 1590 1710 CXA1512-0000000N00N240H CXA1512-0000000N00N240F K4 1290 1461 CXA1512-0000000N0HK440H CXA1512-0000000N0HK440F M2 1380 1563 M4 1485 1682 CXA1512-0000000N0HM440H CXA1512-0000000N0HM440G CXA1512-0000000N0HM440F J2 1040 1178 CXA1512-0000000N0UJ240H CXA1512-0000000N0UJ240G CXA1512-0000000N0UJ240F J4 1120 1269 K2 1200 1359 CXA1512-0000000N0UK240H K4 1290 1461 CXA1512-0000000N00K435H M2 1380 1563 M4 1485 1682 CXA1512-0000000N00M435H CXA1512-0000000N00M435G CXA1512-0000000N00M435F H4 970 1099 CXA1512-0000000N0YH435H CXA1512-0000000N0YH435G CXA1512-0000000N0YH435F J2 1040 1178 J4 1120 1269 CXA1512-0000000N0YJ435H K4 1290 1461 CXA1512-0000000N00K430H M2 1380 1563 M4 1485 1682 CXA1512-0000000N00M430H H4 970 1099 CXA1512-0000000N0YH430H J2 1040 1178 J4 1120 1269 Group 95 Order Code Group Order Code Group CXA1512-0000000N00M240H 40H 40H 40H 35H 35H 30H 3000 K 93 4-Step Group 3500 K 93 3-Step 30H CXA1512-0000000N00M240F CXA1512-0000000N00M440H CXA1512-0000000N0HM240H CXA1512-0000000N0UJ440H CXA1512-0000000N00M235H CXA1512-0000000N0YJ235H CXA1512-0000000N00M230H CXA1512-0000000N0YJ230H CXA1512-0000000N0YJ430H Order Code 40F 40G 40G CXA1512-0000000N0HM240G CXA1512-0000000N0UJ440G 40F 40F CXA1512-0000000N0UK240G CXA1512-0000000N00M440F CXA1512-0000000N0HM240F CXA1512-0000000N0UJ440F CXA1512-0000000N0UK240F CXA1512-0000000N00K435F 35G 35G CXA1512-0000000N00M235G CXA1512-0000000N0YJ235G 35F 35F CXA1512-0000000N0YJ435G CXA1512-0000000N00M235F CXA1512-0000000N0YJ235F CXA1512-0000000N0YJ435F CXA1512-0000000N00K430F 30G CXA1512-0000000N00M230G 30F CXA1512-0000000N00M430G CXA1512-0000000N00M230F CXA1512-0000000N00M430F CXA1512-0000000N0YH430F 30G CXA1512-0000000N0YJ230G CXA1512-0000000N0YJ430G 30F CXA1512-0000000N0YJ230F CXA1512-0000000N0YJ430F Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 24). • CXA1512 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS55 REV 12A 9 XLAMP ® CXA1512 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 36 V (IF = 350 mA, TJ = 85 °C) - CONTINUED Nominal CCT CRI Min 80 Minimum Luminous Flux Typ --- 2-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* K2 1200 1359 K4 1290 1461 M2 1380 1563 CXA1512-0000000N00M227H H2 900 1019 CXA1512-0000000N0YH227H H4 970 1099 J2 1040 1178 Group 95 Group Order Code 4-Step Group CXA1512-0000000N00K227H 27H 2700 K 93 Order Code 3-Step 27H CXA1512-0000000N00K427H CXA1512-0000000N0YH427H CXA1512-0000000N0YJ227H Order Code CXA1512-0000000N00K227F 27G CXA1512-0000000N00K427G 27F CXA1512-0000000N00M227G CXA1512-0000000N00K427F CXA1512-0000000N00M227F CXA1512-0000000N0YH227F 27G CXA1512-0000000N0YH427G CXA1512-0000000N0YJ227G 27F CXA1512-0000000N0YH427F CXA1512-0000000N0YJ227F Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 24). • CXA1512 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS55 REV 12A 10 XLAMP ® CXA1512 LED FLUX CHARACTERISTICS, ANSI WHITE ORDER CODES AND BINS - 36 V (IF = 350 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA1512 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 21). Nominal CCT CRI Min 70 Minimum Luminous Flux Typ 75 6500 K 80 70 --- 75 5700 K 80 70 --- 75 5000 K 80 4000 K 70 --- 75 Chromaticity Regions Order Code Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* M2 1380 1563 M4 1485 1685 N2 1590 1710 CXA1512-0000-000N00N20E1 M2 1380 1563 CXA1512-0000-000N0HM20E1 M4 1485 1685 N2 1590 1710 CXA1512-0000-000N0HN20E1 M2 1380 1563 CXA1512-0000-000N00M20E2 M4 1485 1685 N2 1590 1710 CXA1512-0000-000N00N20E2 M2 1380 1563 CXA1512-0000-000N0HM20E2 M4 1485 1685 N2 1590 1710 CXA1512-0000-000N0HN20E2 M2 1380 1563 CXA1512-0000-000N00M20E3 M4 1485 1685 N2 1590 1710 CXA1512-0000-000N00N20E3 M2 1380 1563 CXA1512-0000-000N0HM20E3 M4 1485 1685 CXA1512-0000-000N00M20E1 1A0, 1B0, 1C0, 1D0, 65F 1A0, 1B0, 1C0, 1D0, 65F 2A0, 2B0, 2C0, 2D0, 57F 2A0, 2B0, 2C0, 2D0, 57F 3A0, 3B0, 3C0, 3D0, 50F 3A0, 3B0, 3C0, 3D0, 50F CXA1512-0000-000N00M40E1 CXA1512-0000-000N0HM40E1 CXA1512-0000-000N00M40E2 CXA1512-0000-000N0HM40E2 CXA1512-0000-000N00M40E3 CXA1512-0000-000N0HM40E3 N2 1590 1710 CXA1512-0000-000N0HN20E3 M2 1380 1563 CXA1512-0000-000N00M40E5 M4 1485 1685 N2 1590 1710 5A0, 5B0, 5C0, 5D0, 40F CXA1512-0000-000N00M40E5 CXA1512-0000-000N00N20E5 Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 24). • CXA1512 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS55 REV 12A 11 XLAMP ® CXA1512 LED Relative Spectral Power Distribution RELATIVE SPECTRAL POWER DISTRIBUTION The following graph is the result of a series of pulsed measurements at 700 mA for the 18-V CXA1512 LED and 350 mA for the 36-V CXA1512 LED and TJ = 85 °C. 100% Relative Spectral Power 90% 80% 70% 60% 5000 K, 70 CRI 50% 4000 K, 70 CRI 40% 3000 K, 80 CRI 30% 3000 K, 93 CRI 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS55 REV 12A 12 XLAMP ® CXA1512 LED ELECTRICAL CHARACTERISTICS The following graphs are the result of a series of steady-state measurements. 20.5 20.0 18 V Voltage (V) 19.5 Tc = 25 °C 19.0 Tc = 55 °C Tc = 85 °C 18.5 Tc = 105 °C 18.0 17.5 17.0 400 500 600 700 800 900 1000 1100 1200 Current (mA) 41 40 36 V Voltage (V) 39 Tc = 25 °C 38 Tc = 55 °C Tc = 85 °C 37 Tc = 105 °C 36 35 34 200 250 300 350 400 450 500 550 600 Current (mA) © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS55 REV 12A 13 XLAMP ® CXA1512 LED RELATIVE LUMINOUS FLUX The relative luminous flux values provided below are the ratio of: • Measurements of CXA1512 at steady-state operation at the given conditions, divided by • Flux measured during binning, which is a pulsed measurement at 700 mA at TJ = 85 °C for the 18‑V CXA1512 LED. Using the 18-V CXA1512 LED as an example, at steady-state operation of Tc = 105 °C, IF = 600 mA, the relative luminous flux ratio is 80% in the chart below. A CXA1512 LED that measures 1200 lm during binning will deliver 960 lm (1200 * 0.8) at steady-state operation of Tc = 105 °C, IF = 600 mA. 180% Relative Luminous Flux 160% 18 V 140% 120% Tc = 25 °C 100% Tc = 55 °C 80% Tc = 85 °C Tc = 105 °C 60% 40% 20% 0% 400 500 600 700 800 900 1000 1100 1200 Current (mA) © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS55 REV 12A 14 XLAMP ® CXA1512 LED RELATIVE LUMINOUS FLUX - CONTINUED The relative luminous flux values provided below are the ratio of: • Measurements of CXA1512 at steady-state operation at the given conditions, divided by • Flux measured during binning, which is a pulsed measurement at 350 mA at TJ = 85 °C for the 36‑V CXA1512 LED. Using the 36-V CXA1512 LED as an example, at steady-state operation of Tc = 105 °C, IF = 300 mA, the relative luminous flux ratio is 80% in the chart below. A CXA1512 LED that measures 1200 lm during binning will deliver 960 lm (1200 * 0.8) at steady-state operation of Tc = 105 °C, IF = 300 mA. 180% 160% 36 V Relative Luminous Flux 140% 120% Tc = 25 °C 100% Tc = 55 °C Tc = 85 °C 80% Tc = 105 °C 60% 40% 20% 0% 200 250 300 350 400 450 500 550 600 Current (mA) © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS55 REV 12A 15 XLAMP ® CXA1512 LED Far Field TYPICAL SPATIAL DISTRIBUTION 100% Relative Luminous Intensity 80% 60% 40% 20% -90 -70 -50 -30 -10 0% 10 30 50 70 90 Angle (º) PERFORMANCE GROUPS - BRIGHTNESS (18 V, I F = 700 mA; 36 V, IF = 350 mA, TJ = 85 °C) XLamp CXA1512 LEDs are tested for luminous flux and placed into one of the following bins. Group Code Minimum Luminous Flux Maximum Luminous Flux H2 900 970 H4 970 1040 J2 1040 1120 J4 1120 1200 K2 1200 1290 K4 1290 1380 M2 1380 1485 M4 1485 1590 N2 1590 1710 N4 1710 1830 P2 1830 1965 © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS55 REV 12A 16 XLAMP ® CXA1512 LED PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) XLamp CXA1512 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. EasyWhite Color Temperatures – 2-Step Code 50H 40H 35H 30H 27H CCT 5000 K 4000 K 3500 K 3000 K 2700 K x y 0.3429 0.3507 0.3434 0.3571 0.3475 0.3604 0.3469 0.3539 0.3784 0.3741 0.3804 0.3818 0.3867 0.3857 0.3844 0.3778 0.4030 0.3857 0.4061 0.3941 0.4132 0.3976 0.4099 0.3890 0.4291 0.3973 0.4333 0.4062 0.4395 0.4084 0.4351 0.3994 0.4528 0.4046 0.4578 0.4138 0.4638 0.4152 0.4586 0.4060 EasyWhite Color Temperatures – 3-Step Ellipse Bin Code CCT 50G Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 5000 K 0.3447 0.3553 0.00840 0.00312 65.0 40G 4000 K 0.3818 0.3797 0.00939 0.00402 53.7 35G 3500 K 0.4073 0.3917 0.00927 0.00414 54.0 30G 3000 K 0.4338 0.4030 0.00834 0.00408 53.2 27G 2700 K 0.4577 0.4099 0.00834 0.00420 48.5 © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS55 REV 12A 17 XLAMP ® CXA1512 LED PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) - CONTINUED EasyWhite Color Temperatures – 4-Step Code 65F 57F 50F 40F 35F 30F 27F CCT 6500 K 5700 K 5000 K 4000 K 3500 K 3000 K 2700 K x y 0.3097 0.3196 0.3079 0.3297 0.3164 0.3382 0.3176 0.3275 0.3253 0.3325 0.3249 0.3439 0.3331 0.3514 0.3330 0.3393 0.3407 0.3459 0.3415 0.3586 0.3499 0.3654 0.3484 0.3521 0.3744 0.3685 0.3782 0.3837 0.3912 0.3917 0.3863 0.3758 0.3981 0.3800 0.4040 0.3966 0.4186 0.4037 0.4116 0.3865 0.4242 0.3919 0.4322 0.4096 0.4449 0.4141 0.4359 0.3960 0.4475 0.3994 0.4573 0.4178 0.4695 0.4207 0.4589 0.4021 © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS55 REV 12A 18 XLAMP ® CXA1512 LED PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) - CONTINUED ANSI White Bins Code Bin Code CCT 1A0 1B0 0E1 6500 K 1C0 1D0 ANSI White Bins x y 0.3048 0.3207 0.3130 0.3290 0.3144 0.3186 0.3068 Code x y 0.3215 0.3350 0.3290 0.3417 0.3290 0.3300 0.3113 0.3222 0.3243 0.3028 0.3304 0.3207 0.3462 0.3115 0.3391 0.3290 0.3538 0.3130 0.3290 0.3290 0.3417 0.3048 0.3207 0.3215 0.3350 0.3115 0.3391 0.3290 0.3538 0.3205 0.3481 0.3376 0.3616 0.3213 0.3373 0.3371 0.3490 0.3130 0.3290 0.3290 0.3417 0.3130 0.3290 0.3290 0.3417 0.3213 0.3373 0.3371 0.3490 0.3221 0.3261 0.3366 0.3369 0.3144 0.3186 0.3290 0.3300 2A0 2B0 0E2 5700 K 2C0 2D0 ANSI White Bins Code CCT Bin Code 3A0 3B0 0E3 5000 K 3C0 3D0 Bin Code CCT ANSI White Bins x y Code CCT Bin Code x y .3371 .3490 .3670 .3578 .3451 .3554 .3702 .3722 .3440 .3427 .3825 .3798 .3366 .3369 .3783 .3646 .3376 .3616 .3702 .3722 .3463 .3687 .3736 .3874 .3451 .3554 .3869 .3958 .3371 .3490 .3825 .3798 .3825 .3798 .3869 .3958 .4006 .4044 5A0 5B0 0E5 4000 K .3463 .3687 .3551 .3760 .3533 .3620 .3451 .3554 .3950 .3875 .3451 .3554 .3783 .3646 .3533 .3620 .3825 .3798 .3515 .3487 .3950 .3875 .3440 .3427 .3898 .3716 5C0 5D0 © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS55 REV 12A 19 XLAMP ® CXA1512 LED EASYWHITE® BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) 0.44 2700 K ANSI C78.377 Quadrangle 0.43 3000 K EasyWhite 4-Step EasyWhite 3-Step 0.42 EasyWhite 2-Step 3500 K 0.41 4000 K 0.40 4500 K CCy 0.39 5000 K 0.38 0.37 5700 K 0.36 6500 K 0.35 0.34 0.33 0.32 0.49 0.48 0.47 0.45 0.41 0.46 0.44 0.40 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.31 CCx ANSI WHITE BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) 0.41 4000 K ANSI C78.377 Quadrangle 0.40 4500 K 5C 0.39 5D 0.37 CCy 5B 5000 K 0.38 5700 K 0.36 5A 3C 3B 6500 K 0.35 2B 0.34 1C 1B 0.33 3D 2C 1D 3A 2D 2A 1A 0.32 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.31 CCx © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS55 REV 12A 20 XLAMP ® CXA1512 LED BIN AND ORDER CODE FORMATS Bin codes and order codes are configured as follows: Order Code Bin Code Series = CXA15 Series = CXA15 Internal code Chromaticity bin CRI Specification 0 = Standard CRI H = 80 CRI minimum U = 90 CRI minimum Y = 93 CRI minimum Vf class F0 = 18-V class N0 = 36-V class SSSSSCC-HHHH-HHHGGRNNNNN Internal code SSSSSCC-WWW-FF-GGR-AAAAA CRI Specification B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Y = 93 CRI minimum Kit code Vf class F0 = 18-V class N0 = 36-V class Flux bin Performance class Performance class MECHANICAL DIMENSIONS Dimensions are in mm. Tolerances unless otherwise specified: ±.13 x° ± 1° 1512F = 18‑V CXA1512 1512N = 36‑V CXA1512 1512X Meaning of 1512X © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS55 REV 12A 21 XLAMP ® CXA1512 LED THERMAL DESIGN The CXA family of LED arrays can include over a hundred different LED die inside one package, and thus over a hundred different junction temperatures (TJ). Cree LED has intentionally removed junction-temperature-based operating limits and replaced the commonplace maximum TJ calculations with maximum ratings based on forward current (IF) and case temperature (Tc). No additional calculations are required to ensure that the CXA LED is being operated within its designed limits. LES temperature measurement provides additional verification of good thermal design. Please refer to page 3 for the Operating Limit specifications. There is no need to calculate for TJ inside the package, as the thermal management design process, specifically from TSP to ambient (Ta), remains identical to any other LED component. For more information on thermal management of XLamp LEDs, please refer to the Thermal Management application note. For CXA soldering recommendations and more information on thermal interface materials (TIM), LES temperature measurement, and connection methods, please refer to the XLamp CX Family LEDs soldering and handling document. The CX Family LED Design Guide provides basic information on the requirements to use XLamp CXA LEDs successfully in luminaire designs. To keep the CXA1512 LED at or below the maximum rated Tc, the case to ambient temperature thermal resistance (R_c-a) must be at or below the maximum R_c-a value shown on the following R_j-c R_j-c scale. Tc Tc As the figure at right shows, the R_c-a value is the sum of the thermal resistance of the TIM (R_tim) R_tim graphs, depending on the operating environment. The y‑axis in the graphs is a base 10 logarithmic R_c-a plus the thermal resistance of the heat sink (R_hs). R_hs CXA1512 - 18 V Ta Ta 100.00 18 V Maximum R_c-a 10.00 Ta = 25 °C Ta = 55 °C 1.00 Ta = 85 °C Ta = 105 °C 0.10 0.01 400 500 600 700 800 900 1000 1100 1200 Current (mA) © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS55 REV 12A 22 XLAMP ® CXA1512 LED CXA1512 - 36 V- CONTINUED THERMAL DESIGN 100.00 36 V Maximum R_c-a 10.00 Ta = 25 °C Ta = 55 °C 1.00 Ta = 85 °C Ta = 105 °C 0.10 0.01 200 250 300 350 400 450 500 550 600 Current (mA) © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS55 REV 12A 23 XLAMP ® CXA1512 LED NOTES Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs. Lumen Maintenance Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. REACh Compliance REACh substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative to insure you get the most up-to-date REACh Declaration. REACh banned substance information (REACh Article 67) is also available upon request. UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS55 REV 12A 24 XLAMP ® CXA1512 LED PACKAGING 6 4 3 CXA1512 LEDs are packaged in5 trays of 20. Five trays are sealed in an anti-static bag and placed inside a carton, for a total of2 100 LEDs NOTICE ENTIAL. THIS PLOT AND THE INFORMATION WITHIN ARE THE PROPRIETARY AND AL INFORMATION OF CREE, INC. THIS PLOT COPIED, REPRODUCED OR DISCLOSED TO ANY ED PERSON WITHOUT THE WRITTEN CONSENT per carton. Each carton contains 100 LEDs from the same performance bin. Dimensions are in inches. Tolerances: ±.13 5.875 4 5 6 3 5 R .375 4 x° ±1° 2 3 1 2 1 NOTICE ENTIAL. THIS PLOT AND THE INFORMATION WITHIN ARE THE PROPRIETARY AND L INFORMATION OF CREE, INC. THIS PLOT COPIED, REPRODUCED OR DISCLOSED TO ANY NSENT ED PERSON WITHOUT THE WRITTEN CONSENT 5.875 .875 5.875 R .375 R .375 5.875 .875 .875 5.875 LABEL WITH CREE BIN CODE, QUANTITY, LOT # PATENT LABEL IS LOCATED ON UNDERSIDE OF COVER PATENT LABEL ISBIN LOCATED LABEL WITH CREE CODE, QUANTITY, OF LOTCARTON # ON UNDERSIDE TH CREE BIN ANTITY, LOT # PATENT LABEL IS LOCATED ON UNDERSIDE .875 OF COVER BAG .38 .875 BAG .38 .875 BAG .38 LABEL WITH CREE BIN CODE, QUANTITY, LOT # L IS LOCATED IDE OF COVER LABEL WITH CREE BIN CODE, QUANTITY, LOT # LABEL WITH CREE BIN CODE, QUANTITY, LOT # LABEL WITH CREE BIN CODE, QUANTITY, LOT # UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS & BEFORE FINISH. TOLERANCE UNLESS SPECIFIED: LABEL WITH CREE BIN CODE, QUANTITY, LOT # UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN THIRD ANGLE PROJECTION MILLIMETERS & BEFORE FINISH. TOLERANCE UNLESS SPECIFIED: LABEL WITH CREE BIN CODE, QUANTITY, LOT # THIRD ANGLE PROJECTION 6 6 WITH CREE BIN QUANTITY, LOT # 5 5 .X ± .XX ± .XXX ± X° ± 3.X ± .XX ± .XXX ± X° ± UNLESS OTHERWISE SPECIFIED 3 DIMENSIONS ARE IN MILLIMETERS & BEFORE FINISH. TOLERANCE UNLESS SPECIFIED: .06 .03 .010 2 ° DRAWN BY FOR SHEET METAL PARTS ONLY .X ± .06 DATE DATE APPROVED DATE DATE DATE 0.1 .05 .005 1 ° TITLE CXA15 Phone (919) 361- Fax (919) 313-530 SIZE C CXA15XX_DATASHEET TITLE CHECK SCALE SIZE SCALE C 2 CXA 0.500 DRAWING NO. CXA15XX_DATASHEET_BAG2013 SHEET 0.500 OF 1 Drive 4600 Silicon Durham, N.C 27703 DATE Phone (919) 361-4770 DATE TITLE CLD-DS55 REV 12A 25 Fax (919) 313-5303 CXA15XX_DATASHEET SIZE FINAL PROTECTIVE FINISH DRAW FINAL PROTECTIVE FINISH FINAL PROTECTIVE FINISH DATE 4600 Silicon Drive Durham, N.C 277 MATERIAL 2 © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree and the Cree logo are registered and APPROVED .X ± trademarks, 0.1 ± .05 registered the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the.XXUL logo are .XXX ± .005 trademarks of UL LLC. THIRD ANGLE PROJECTION MATERIAL X° ± 1 ° ® 0.1 .05 .005 1 ° FOR SHEET METAL PARTS ONLYDATE APPROVED .X ± .06 .XX ± .03 MATERIAL .XXX ± .010 X° ± 2 ° FOR SHEET METAL PARTS ONLY 4 4 .X ± DRAWN BY .XX ± .XXX ± CHECK ± X° DRAWN BY CHECK DRAWING NO. CXA15XX_DATASHEET_BAG2013
物料型号:XLamp® CXA1512 LED
器件简介: - Cree XLamp® CXA1512 LED阵列扩展了Cree LED的高通量多芯片阵列产品线,采用更小、易于使用的平台。 - 该LED阵列具有XLamp LED照明级的可靠性,小而均匀的发射面,适用于包括灯具改造和照明设计在内的定向和非定向照明应用。
引脚分配:文档中未明确列出引脚分配,但提到了顶侧焊接连接。
参数特性: - 色温(CCT)范围从2700K到6500K,提供2步、3步和4步色温一致性选项。 - 色容差(CRI)选项包括70、80、90和93。 - 正向电压选项包括18V和36V级别。 - 最大驱动电流为1200mA (18V)和600mA (36V)。 - 符合NEMA SSL-3 2011标准通量箱、RoHS和REACh合规性。
功能详解: - 提供115°的视场角和均匀的色度特性。 - 热电偶附着点,用于温度测量。 - 85°C的分选和特性化。
应用信息: - 适用于灯具改造和照明设计,包括定向和非定向照明应用。
封装信息: - 9mm的光学光源。 - Cree LED的包装信息显示,CXA1512 LED以每盘20个的托盘形式包装,每5盘密封在一个防静电袋内,每箱总共100个LED,每个纸箱包含同一性能箱的100个LED。
CXA1512-0000-000F00M227F 价格&库存
很抱歉,暂时无法提供与“CXA1512-0000-000F00M227F”相匹配的价格&库存,您可以联系我们找货
