CXB1512-0000-000F0HM427G
    WOLFSPEED
    LED COB CXB1512 2700K WHT SMD
CXB1512-0000-000F0HM427G 数据手册
PRODUCT FAMILY DATA SHEET XLamp® CXB1512 LED PRODUCT DESCRIPTION FEATURES TABLE OF CONTENTS The XLamp® CXB1512 LED Array is a • 9‑mm optical source Characteristics................................................ 2 member of the second generation of the • Mechanical and optical design Operating Limits.............................................. 3 CXA family that delivers up to 30% higher consistent with other CXA15 and Flux Characteristics, EasyWhite® Order efficacy and up to 20% higher lumens than CXB15 LEDs Codes and Bins - 18 V..................................... 4 the first generation in the same LES. The • Available in 70-, 80-, 90- and Flux Characteristics, Premium Color Order higher performance second generation Codes and Bins - 18 V..................................... 7 CXA LED Arrays provide a 95-minimum CRI options drop-in • EasyWhite 2-, 3‑ and 5-step binning ® Flux Characteristics, EasyWhite® Order performance upgrade to existing CXA LED • Premium Color 2- and 3-step binning Codes and Bins - 36 V..................................... 8 designs to shorten product development • Forward voltage options: 18‑V class & Flux Characteristics, Premium Color Order time. In addition, the CXB LEDs also Codes and Bins - 36 V................................... 11 36‑V class allow lighting manufacturers to achieve • 85 °C binning and characterization Relative Spectral Power Distribution, the same or better performance with a EasyWhite® ................................................... 12 smaller LES, enabling a smaller, more • Extremely uniform color over viewing angle Relative Spectral Power Distribution, impactful luminaire. Available in 2‑step, • Top-side solder connections Premium Color.............................................. 13 3‑step and 5‑step EasyWhite Electrical Characteristics.............................. 14 ® bins and • Thermocouple attach point 2‑step and 3‑step Premium Color bins, the • NEMA SSL-3 2011 standard flux bins Relative Luminous Flux................................. 15 CXB1512 LED delivers high lumen output Typical Spatial Distribution........................... 17 • RoHS and REACh compliant and high efficacy in a single, easy‑to‑use • UL recognized component (E349212) Performance Groups - Brightness............... 17 package that eliminates the need for reflow EasyWhite® Performance Groups - soldering. Chromaticity.................................................. 18 ® Premium Color Performance Groups The CX Family LED Design Guide provides Chromaticity.................................................. 19 basic information on the requirements to EasyWhite® Bins Plotted on the 1931 CIE use the CXB1512 LED array successfully in Color Space................................................... 20 luminaire designs. Premium Color Bins Plotted on the 1931 CIE Color Space............................................ 21 Bin and Order Code Formats........................ 23 Mechanical Dimensions............................... 23 Thermal Design............................................. 24 Notes............................................................. 26 Packaging...................................................... 27 Cree LED / 4400 Silicon Drive / Durham, NC 27703 USA / +1.919.313.5330 / www.cree-led.com © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS118 REV 9A 1 XLAMP ® CXB1512 LED CHARACTERISTICS Characteristics Viewing angle (FWHM) ESD withstand voltage (HBM per Mil-Std-883D) Unit Minimum Typical degrees Maximum 115 V 8000 DC forward current (18 V) mA 1200* DC forward current (36 V) mA 600* Reverse current (18 V, 36 V) mA 0.1 Forward voltage (18 V, @ 700 mA, 85 °C) V 17.2 19 Forward voltage (36 V, @ 350 mA, 85 °C) V 34.3 38 * Refer to the Operating Limits section. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS118 REV 9A 2 XLAMP ® CXB1512 LED OPERATING LIMITS The maximum current rating of the CXB1512 depends on the case temperature (Tc) when the LED has reached thermal equilibrium under steady-state operation. The graphs shown below assume that the system design employs good thermal management (thermal interface material and heat sink) and may vary when poor thermal management is employed. Please refer to the Mechanical Dimensions section on page 23 for the location of the Tc measurement point. Another important factor in good thermal management is the temperature of the Light Emitting Surface (LES). Cree LED recommends a maximum LES temperature of 135 °C to ensure optimal LED lifetime. Please refer to the Thermal Design section on page 24 for more CXB1512 - 18 V Standard information on LES temperature measurement. 1400 90 °C, 1200 mA 1200 If (mA) 1000 800 18 V 600 125 °C, 498 mA 400 200 0 0 25 50 75 100 125 150 Case Temperature (°C) CXB1512 - 36 V Standard 700 90 °C, 600 mA 600 If (mA) 500 400 36 V 300 125 °C, 249 mA 200 100 0 0 25 50 75 100 125 150 Case Temperature (°C) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS118 REV 9A 3 XLAMP ® CXB1512 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 18 V (IF = 700 mA, TJ = 85 °C) The following table provides order codes for XLamp CXB1512 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 23). CRI* Nominal CCT Min 70 Minimum Luminous Flux Typ --- 6500 K 80 70 70 --- --- 90 5-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** N4 1710 1871 P2 1830 2002 P4 1965 2150 CXB1512-0000000F0BP465E N2 1590 1739 CXB1512-0000000F0HN265E N4 1710 1871 CXB1512-0000000F0HN465E N4 1710 1871 CXB1512-0000000F0BN457E P2 1830 2002 P4 1965 2150 CXB1512-0000000F0BP457E N2 1590 1739 CXB1512-0000000F0HN257E N4 1710 1871 CXB1512-0000000F0HN457E N4 1710 1871 CXB1512-0000000F0BN450E P2 1830 2002 P4 1965 2150 N2 1590 1739 N4 1710 1871 CXB1512-0000000F0HN450G M4 1485 1625 CXB1512-0000000F0UM450G N2 1590 1739 Group Order Code Group Order Code Group 65E 65E 57E 57E --- 50E CXB1512-0000000F0BP265E CXB1512-0000000F0BP257E CXB1512-0000000F0BP250E CXB1512-0000000F0BP450E 50G 92 Order Code CXB1512-0000000F0BN465E --- 5000 K 80 3-Step --- 5700 K 80 2-Step 50G CXB1512-0000000F0HN250G 50E CXB1512-0000000F0HN250E CXB1512-0000000F0HN450E CXB1512-0000000F0UN250G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). • CXB1512 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS118 REV 9A 4 XLAMP ® CXB1512 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 18 V (IF = 700 mA, TJ = 85 °C) - CONTINUED CRI* Nominal CCT Min 70 4000 K 80 90 80 Minimum Luminous Flux Typ --- --- 92 --- 2-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** N4 1710 1871 P2 1830 2002 P4 1965 2150 N2 1590 1739 N4 1710 1871 P2 1830 2002 CXB1512-0000000F0HP240H CXB1512-0000000F0HP240G M2 1380 1510 CXB1512-0000000F0UM240H CXB1512-0000000F0UM240G M4 1485 1625 N2 1590 1739 CXB1512-0000000F0UN240H CXB1512-0000000F0UN240G N2 1590 1739 CXB1512-0000000F0HN235H CXB1512-0000000F0HN235G N4 1710 1871 P2 1830 2002 CXB1512-0000000F0HP235H CXB1512-0000000F0HP235G K4 1290 1411 CXB1512-0000000F0UK435H CXB1512-0000000F0UK435G M2 1380 1510 M4 1485 1625 CXB1512-0000000F0UM435H CXB1512-0000000F0UM435G M4 1485 1625 CXB1512-0000000F0HM430H CXB1512-0000000F0HM430G N2 1590 1739 N4 1710 1871 CXB1512-0000000F0HN430H CXB1512-0000000F0HN430G K4 1290 1411 CXB1512-0000000F0UK430H CXB1512-0000000F0UK430G M2 1380 1510 M4 1485 1625 Group 80 92 --- 92 Group Order Code Group 40E Order Code CXB1512-0000000F0BP240E CXB1512-0000000F0BP440E CXB1512-0000000F0HN240H 40H 40H 35H 35H 30H 3000 K 90 Order Code 5-Step CXB1512-0000000F0BN440E 3500 K 90 3-Step 30H CXB1512-0000000F0HN440H CXB1512-0000000F0UM440H CXB1512-0000000F0HN435H CXB1512-0000000F0UM235H CXB1512-0000000F0HN230H CXB1512-0000000F0UM230H CXB1512-0000000F0UM430H CXB1512-0000000F0HN240G 40G 40G 35G 35G 30G 30G CXB1512-0000000F0HN440G CXB1512-0000000F0UM440G CXB1512-0000000F0HN435G CXB1512-0000000F0UM235G CXB1512-0000000F0HN230G CXB1512-0000000F0UM230G CXB1512-0000000F0UM430G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). • CXB1512 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS118 REV 9A 5 XLAMP ® CXB1512 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 18 V (IF = 700 mA, TJ = 85 °C) - CONTINUED CRI* Nominal CCT Min 80 Minimum Luminous Flux Typ 90 2200 K 80 Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** M4 1485 1625 N2 1590 1739 CXB1512-0000000F0HN227H K2 1200 1313 CXB1512-0000000F0UK227H K4 1290 1411 M2 1380 1510 M2 1380 1510 --- 2700 K 92 --- 2-Step Group 27H 27H Order Code CXB1512-0000000F0HM427H CXB1512-0000000F0UK427H 3-Step Group 27G Order Code 5-Step Group Order Code CXB1512-0000000F0HM427G CXB1512-0000000F0HN227G CXB1512-0000000F0UK227G 27G CXB1512-0000000F0UM227H CXB1512-0000000F0UK427G CXB1512-0000000F0UM227G 22G CXB1512-0000000F0HM222G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). • CXB1512 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS118 REV 9A 6 XLAMP ® CXB1512 LED FLUX CHARACTERISTICS, PREMIUM COLOR ORDER CODES AND BINS - 18 V (I F = 700 mA, TJ = 85 °C) Fidelity CRI* Nominal CCT Minimum Luminous Flux Min Typ Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** 4000 K 95 98 K4 1290 1411 3500 K 95 98 K2 1200 3000 K 95 98 K2 2700 K 95 98 J4 Typical Luminous Flux (lm) @ 85 °C 2-Step Group Order Code 1407 L5A CXB1512-0000-000F0ZK4L5A 1313 1355 35H CXB1512-0000-000F0ZK235H 1200 1313 1303 30H CXB1512-0000-000F0ZK230H 1120 1225 1229 27H CXB1512-0000-000F0ZJ427H Specialty CRI Nominal CCT 3100 K Min 90 80 3000 K 90 95 Minimum Luminous Flux Typ Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** K4 1290 1411 M2 1380 1510 M4 1485 1625 J4 1120 1225 K2 1200 1313 K4 1290 1411 J4 1120 1225 92 --- 92 98 Typical Luminous Flux (lm) @ 85 °C 2-Step Group Order Code 1502 1746 3-Step Group 31Q L7B Order Code Group Order Code CXB1512-0000000F0UK431Q CXB1512-0000000F0UM231Q CXB1512-0000000F0HM4L7B CXB1512-0000000F0UJ430U 1502 30Q CXB1512-0000000F0UK230Q CXB1512-0000000F0UK430Q 1303 L7C 30U CXB1512-0000000F0UK230U CXB1512-0000000F0UK430U CXB1512-0000000F0ZJ4L7C Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). • CXB1512 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS118 REV 9A 7 XLAMP ® CXB1512 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 36 V (IF = 350 mA, TJ = 85 °C) The following table provides order codes for XLamp CXB1512 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 23). CRI* Nominal CCT Min 70 Minimum Luminous Flux Typ --- 6500 K 80 70 70 --- --- 90 5-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** N4 1710 1871 P2 1830 2002 P4 1965 2150 CXB1512-0000000N0BP465E N2 1590 1739 CXB1512-0000000N0HN265E N4 1710 1871 CXB1512-0000000N0HN465E N4 1710 1871 CXB1512-0000000N0BN457E P2 1830 2002 P4 1965 2150 CXB1512-0000000N0BP457E N2 1590 1739 CXB1512-0000000N0HN257E N4 1710 1871 CXB1512-0000000N0HN457E N4 1710 1871 CXB1512-0000000N0BN450E P2 1830 2002 P4 1965 2150 N2 1590 1739 N4 1710 1871 CXB1512-0000000N0HN450G M4 1485 1625 CXB1512-0000000N0UM450G N2 1590 1739 Group Order Code Group Order Code Group 65E 65E 57E 57E --- 50E CXB1512-0000000N0BP265E CXB1512-0000000N0BP257E CXB1512-0000000N0BP250E CXB1512-0000000N0BP450E 50G 92 Order Code CXB1512-0000000N0BN465E --- 5000 K 80 3-Step --- 5700 K 80 2-Step 50G CXB1512-0000000N0HN250G 50E CXB1512-0000000N0HN250E CXB1512-0000000N0HN450E CXB1512-0000000N0UN250G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). • CXB1512 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS118 REV 9A 8 XLAMP ® CXB1512 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 36 V (IF = 350 mA, TJ = 85 °C) - CONTINUED CRI* Nominal CCT Min 70 4000 K 80 90 80 Minimum Luminous Flux Typ --- --- 92 --- 2-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** N4 1710 1871 P2 1830 2002 P4 1965 2150 N2 1590 1739 N4 1710 1871 P2 1830 2002 CXB1512-0000000N0HP240H CXB1512-0000000N0HP240G M2 1380 1510 CXB1512-0000000N0UM240H CXB1512-0000000N0UM240G M4 1485 1625 N2 1590 1739 CXB1512-0000000N0UN240H CXB1512-0000000N0UN240G N2 1590 1739 CXB1512-0000000N0HN235H CXB1512-0000000N0HN235G N4 1710 1871 P2 1830 2002 CXB1512-0000000N0HP235H CXB1512-0000000N0HP235G K4 1290 1411 CXB1512-0000000N0UK435H CXB1512-0000000N0UK435G M2 1380 1510 M4 1485 1625 CXB1512-0000000N0UM435H CXB1512-0000000N0UM435G M4 1485 1625 CXB1512-0000000N0HM430H CXB1512-0000000N0HM430G N2 1590 1739 N4 1710 1871 CXB1512-0000000N0HN430H CXB1512-0000000N0HN430G K4 1290 1411 CXB1512-0000000N0UK430H CXB1512-0000000N0UK430G M2 1380 1510 M4 1485 1625 Group 80 92 --- 92 Group Order Code Group 40E Order Code CXB1512-0000000N0BP240E CXB1512-0000000N0BP440E CXB1512-0000000N0HN240H 40H 40H 35H 35H 30H 3000 K 90 Order Code 5-Step CXB1512-0000000N0BN440E 3500 K 90 3-Step 30H CXB1512-0000000N0HN440H CXB1512-0000000N0UM440H CXB1512-0000000N0HN435H CXB1512-0000000N0UM235H CXB1512-0000000N0HN230H CXB1512-0000000N0UM230H CXB1512-0000000N0UM430H CXB1512-0000000N0HN240G 40G 40G 35G 35G 30G 30G CXB1512-0000000N0HN440G CXB1512-0000000N0UM440G CXB1512-0000000N0HN435G CXB1512-0000000N0UM235G CXB1512-0000000N0HN230G CXB1512-0000000N0UM230G CXB1512-0000000N0UM430G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). • CXB1512 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS118 REV 9A 9 XLAMP ® CXB1512 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 36 V (IF = 350 mA, TJ = 85 °C) - CONTINUED CRI* Nominal CCT Min 80 Minimum Luminous Flux Typ 90 2200 K 80 Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** M4 1485 1625 N2 1590 1739 CXB1512-0000000N0HN227H K2 1200 1313 CXB1512-0000000N0UK227H K4 1290 1411 M2 1380 1510 M2 1380 1510 --- 2700 K 92 --- 2-Step Group 27H 27H Order Code CXB1512-0000000N0HM427H CXB1512-0000000N0UK427H 3-Step Group 27G Order Code 5-Step Group Order Code CXB1512-0000000N0HM427G CXB1512-0000000N0HN227G CXB1512-0000000N0UK227G 27G CXB1512-0000000N0UM227H CXB1512-0000000N0UK427G CXB1512-0000000N0UM227G 22G CXB1512-0000000N0HM222G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). • CXB1512 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS118 REV 9A 10 XLAMP ® CXB1512 LED FLUX CHARACTERISTICS, PREMIUM COLOR ORDER CODES AND BINS - 36 V (I F = 350 mA, TJ = 85 °C) Fidelity CRI* Nominal CCT Minimum Luminous Flux Min Typ Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** 4000 K 95 98 K4 1290 1411 3500 K 95 98 K2 1200 3000 K 95 98 K2 2700 K 95 98 J4 Typical Luminous Flux (lm) @ 85 °C 2-Step Group Order Code 1407 L5A CXB1512-0000-000N0ZK4L5A 1313 1355 35H CXB1512-0000-000N0ZK235H 1200 1313 1303 30H CXB1512-0000-000N0ZK230H 1120 1225 1229 27H CXB1512-0000-000N0ZJ427H Specialty CRI Nominal CCT 3100 K Min 90 80 3000 K 90 95 Minimum Luminous Flux Typ Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** K4 1290 1411 M2 1380 1510 M4 1485 1625 J4 1120 1225 K2 1200 1313 K4 1290 1411 J4 1120 1225 92 --- 92 98 Typical Luminous Flux (lm) @ 85 °C 2-Step Group Order Code 1502 1746 3-Step Group 31Q L7B Order Code Group Order Code CXB1512-0000000N0UK431Q CXB1512-0000000N0UM231Q CXB1512-0000000N0HM4L7B CXB1512-0000000N0UJ430U 1502 30Q CXB1512-0000000N0UK230Q CXB1512-0000000N0UK430Q 1303 L7C 30U CXB1512-0000000N0UK230U CXB1512-0000000N0UK430U CXB1512-0000000N0ZJ4L7C Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). • CXB1512 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS118 REV 9A 11 XLAMP ® CXB1512 LED RELATIVE SPECTRAL POWER DISTRIBUTION, EASYWHITE® The following graphs are the result of a series of pulsed measurements at 700 mA for the 18-V CXB1512 LED and 350 mA for the 36-V CXB1512 LED and TJ = 85 °C. 100% Relative Spectral Power 90% 80% 70% 5000 K, 70 CRI 60% 4000 K, 70 CRI 50% 3000 K, 80 CRI 40% 3000 K, 90 CRI 30% 2200 K, 80 CRI 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS118 REV 9A 12 XLAMP ® CXB1512 LED RELATIVE SPECTRAL POWER DISTRIBUTION, PREMIUM COLOR The following graphs are the result of a series of pulsed measurements at 700 mA for the 18-V CXB1512 LED and 350 mA for the 36-V CXB1512 LED and TJ = 85 °C Fidelity 100% Relative Spectral Power 90% 80% 70% 60% 4000 K, Z CRI 50% 3500 K, Z CRI 3000 K, Z CRI 40% 2700 K, Z CRI 30% 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Relative Spectral Power Distribution Specialty 100% Relative Spectral Power 90% 80% 70% 31Q, 3100 K, 90 CRI 60% 30Q, 3000 K, 90 CRI 50% 30U, 3000 K, 90 CRI 40% L7B, 3000 K 80 CRI 30% L7C, 3000 K, Z CRI 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS118 REV 9A 13 XLAMP ® CXB1512 LED ELECTRICAL CHARACTERISTICS The following graphs are the result of a series of steady-state measurements. 18.5 Voltage (V) 18.0 18 V 17.5 Tc = 25 °C Tc = 55 °C 17.0 Tc = 85 °C Tc = 105 °C 16.5 16.0 15.5 200 300 400 500 600 700 800 900 1000 1100 1200 Current (mA) 37.0 Voltage (V) 36.0 36 V 35.0 Tc = 25 °C Tc = 55 °C 34.0 Tc = 85 °C Tc = 105 °C 33.0 32.0 31.0 100 150 200 250 300 350 400 450 500 550 600 Current (mA) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS118 REV 9A 14 XLAMP ® CXB1512 LED RELATIVE LUMINOUS FLUX The relative luminous flux values provided below are the ratio of: • Measurements of CXB1512 at steady-state operation at the given conditions, divided by • Flux measured during binning, which is a pulsed measurement at 700 mA at TJ = 85 °C for the 18‑V CXB1512 LED. Using the 18‑V CXB1512 LED as an example, at steady-state operation of Tc = 25 °C, IF = 800 mA, the relative luminous flux ratio is 120% in the chart below. A CXB1512 LED that measures 1290 lm during binning will deliver 1548 lm (1290 * 1.2) at steady-state operation of Tc = 25 °C, IF = 800 mA. 180% Relative Luminous Flux 160% 18 V 140% 120% Tc = 25 °C 100% Tc = 55 °C Tc = 85 °C 80% Tc = 105 °C 60% 40% 20% 0% 200 300 400 500 600 700 800 900 1000 1100 1200 Current (mA) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS118 REV 9A 15 XLAMP ® CXB1512 LED RELATIVE LUMINOUS FLUX - CONTINUED The relative luminous flux values provided below are the ratio of: • Measurements of CXB1512 at steady-state operation at the given conditions, divided by • Flux measured during binning, which is a pulsed measurement at 350 mA at TJ = 85 °C for the 36‑V CXB1512 LED. Using the 36‑V CXB1512 LED as an example, at steady-state operation of Tc = 25 °C, IF = 400 mA, the relative luminous flux ratio is 120% in the chart below. A CXB1512 LED that measures 1290 lm during binning will deliver 1548 lm (1290 * 1.2) at steady-state operation of Tc = 25 °C, IF = 400 mA. 180% Relative Luminous Flux 160% 36 V 140% 120% Tc = 25 °C 100% Tc = 55 °C Tc = 85 °C 80% Tc = 105 °C 60% 40% 20% 0% 100 150 200 250 300 350 400 450 500 550 600 Current (mA) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS118 REV 9A 16 XLAMP ® CXB1512 LED Far Field TYPICAL SPATIAL DISTRIBUTION 100% Relative Luminous Intensity 80% 60% 40% 20% -90 -70 -50 -30 -10 0% 10 30 50 70 90 Angle (º) PERFORMANCE GROUPS - BRIGHTNESS (18 V, I F = 700 mA; 36 V, IF = 350 mA, TJ = 85 °C) XLamp CXB1512 LEDs are tested for luminous flux and placed into one of the following bins. Group Code Minimum Luminous Flux Maximum Luminous Flux J4 1120 1200 K2 1200 1290 K4 1290 1380 M2 1380 1485 M4 1485 1590 N2 1590 1710 N4 1710 1830 P2 1830 1965 P4 1965 2100 Q2 2100 2260 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS118 REV 9A 17 XLAMP ® CXB1512 LED EASYWHITE® PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) XLamp CXB1512 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. EasyWhite Color Temperatures – 2-Step Code 40H 35H 30H 27H CCT 4000 K 3500 K 3000 K 2700 K x y 0.3777 0.3739 0.3797 0.3816 0.3861 0.3855 0.3838 0.3777 0.4022 0.3858 0.4053 0.3942 0.4125 0.3977 0.4091 0.3891 0.4287 0.3975 0.4328 0.4064 0.4390 0.4086 0.4347 0.3996 0.4524 0.4048 0.4574 0.4140 0.4633 0.4154 0.4581 0.4062 EasyWhite Color Temperatures – 3-Step Ellipse Bin Code CCT 50G 40G Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 5000 K 0.3447 0.3553 0.00840 0.00312 65.0 4000 K 0.3818 0.3797 0.00939 0.00402 53.7 35G 3500 K 0.4073 0.3917 0.00927 0.00414 54.0 30G 3000 K 0.4338 0.4030 0.00834 0.00408 53.2 27G 2700 K 0.4577 0.4099 0.00834 0.00420 48.5 22G 2200 K 0.5066 0.4158 0.00980 0.00480 45.5 EasyWhite Color Temperatures – 5-Step Ellipse Bin Code CCT 65E Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 6500 K 0.3123 0.3282 0.01110 0.00550 61.0 57E 5700 K 0.3287 0.3417 0.01230 0.00600 72.0 50E 5000 K 0.3447 0.3553 0.01400 0.00520 65.0 40E 4000 K 0.3818 0.3797 0.01565 0.00670 53.7 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS118 REV 9A 18 XLAMP ® CXB1512 LED PREMIUM COLOR PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) XLamp CXB1512 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. Fidelity EasyWhite Color Temperatures – 2-Step Code L5A 35H 30H 27H CCT 4000 K 3500 K 3000 K 2700 K x y 0.3764 0.3711 0.3784 0.3787 0.3847 0.3826 0.3825 0.3748 0.4022 0.3858 0.4053 0.3942 0.4125 0.3977 0.4091 0.3891 0.4287 0.3975 0.4328 0.4064 0.4390 0.4086 0.4347 0.3996 0.4524 0.4048 0.4574 0.4140 0.4633 0.4154 0.4581 0.4062 Specialty EasyWhite Color Temperatures – 2-Step Code L7B L7C CCT 3000 K 3000 K x y 0.4263 0.3848 0.4296 0.3916 0.4361 0.3938 0.4326 0.3868 0.4192 0.3754 0.4224 0.3823 0.4291 0.3847 0.4257 0.3777 EasyWhite Color Temperatures – 3-Step Ellipse Center Point Major Axis Minor Axis Rotation Angle (°) Bin Code CCT x y a b 31Q 3100 K 0.4236 0.3888 0.00848 0.00455 50.3 30Q 3000 K 0.4305 0.3935 0.00834 0.00408 53.2 30U 3000 K 0.4274 0.3837 0.00834 0.00408 53.2 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS118 REV 9A 19 XLAMP ® CXB1512 LED EASYWHITE® BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) 0.45 ANSI C78.377 Quadrangle 0.44 2700 K EasyWhite 5-step 0.43 2200 K 2450 K 3000 K EasyWhite 3-step 0.42 EasyWhite 2-step 3500 K 0.41 4000 K 0.40 CCy 0.39 5000 K 4500 K 5700 K 0.38 0.37 6500 K 0.36 0.35 7000K 0.34 0.33 0.32 0.54 0.53 0.52 0.51 0.50 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.31 CCx © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS118 REV 9A 20 XLAMP ® CXB1512 LED PREMIUM COLOR BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) Fidelity (2-step) 0.44 2700K ANSI C78.377 Quadrangle 0.43 3000K 0.42 3500K 0.41 27H 4000K CCy 0.40 30H 4500K 35H 0.39 0.38 L5A 0.37 0.36 0.35 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. 0.48 0.47 0.46 0.45 0.44 CCx 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 CLD-DS118 REV 9A 21 XLAMP ® CXB1512 LED PREMIUM COLOR BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) - CONTINUED Speciality (2-step) 0.44 ANSI C78.377 Quadrangle 3000 K 0.43 0.42 3500 K CCy 0.41 0.40 0.39 L7B L7C 0.38 0.46 0.45 CCx 0.44 0.43 0.42 0.41 0.37 Speciality (3-step) 0.44 ANSI C78.377 Quadrangle 3000K 0.43 0.42 3500K CCy 0.41 0.40 30Q 0.39 31Q 30U 0.38 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. 0.46 0.45 CCx 0.44 0.43 0.42 0.41 0.37 CLD-DS118 REV 9A 22 XLAMP ® CXB1512 LED BIN AND ORDER CODE FORMATS Bin codes and order codes are configured as follows: Order Code Bin Code Series = CXB15 Series = CXB15 Internal code Chromaticity bin CRI Specification B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Z = 95 CRI minimum Vf class: F0 = 18-V class N0 = 36-V class Internal code SSSSSCC-WWW-FF-GGR-AAAAA SSSSSCC-HHHH-HHHGGRNNNNN Vf class: F0 = 18-V class N0 = 36-V class CRI Specification B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Z = 95 CRI minimum Performance class Flux bin Kit code Performance class MECHANICAL DIMENSIONS Dimensions are in mm. Tolerances unless otherwise specified: +.13 x° +1° B1512F = 18‑V CXB1512 B1512N = 36‑V CXB1512 B1512X Meaning of B1512X © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS118 REV 9A 23 XLAMP ® CXB1512 LED THERMAL DESIGN The CXB family of LED arrays can include over a hundred different LED die inside one package, and thus over a hundred different junction temperatures (TJ). Cree LED has intentionally removed junction-temperature-based operating limits and replaced the commonplace maximum TJ calculations with maximum ratings based on forward current (IF) and case temperature (Tc). No additional calculations are required to ensure that the CXB LED is being operated within its designed limits. LES temperature measurement provides additional verification of good thermal design. Please refer to page 3 for the Operating Limit specifications. There is no need to calculate for TJ inside the package, as the thermal management design process, specifically from TSP to ambient (Ta), remains identical to any other LED component. For more information on thermal management of XLamp LEDs, please refer to the Thermal Management application note. For CXB soldering recommendations and more information on thermal interface materials (TIM), LES temperature measurement, and connection methods, please refer to the XLamp CX Family LEDs soldering and handling document. The CX Family LED Design Guide provides basic information on the requirements to use XLamp CXB LEDs successfully in luminaire designs. To keep the CXB1512 LED at or below the maximum rated Tc, the case to ambient temperature thermal resistance (R_c-a) must be at or below the maximum R_c-a value shown on the following graphs, depending on the operating environment. The y‑axis in the graphs is a base 10 logarithmic scale. R_j-c R_j-c Tc Tc R_tim As the figure at right shows, the R_c-a value is the sum of the thermal resistance of the TIM (R_tim) R_c-a plus the thermal resistance of the heat sink (R_hs). R_hs CXB1512 - 18 V Ta Ta 100.00 18 V Maximum R_c-a 10.00 Ta = 25 °C Ta = 55 °C 1.00 Ta = 85 °C Ta = 105 °C 0.10 0.01 200 300 400 500 600 700 800 900 1000 1100 1200 Current (mA) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS118 REV 9A 24 XLAMP ® CXB1512 LED V THERMALCXB1512 DESIGN -- 37 CONTINUED 100.00 36 V Maximum R_c-a 10.00 Ta = 25 °C Ta = 55 °C 1.00 Ta = 85 °C Ta = 105 °C 0.10 0.01 100 200 300 400 500 600 Current (mA) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS118 REV 9A 25 XLAMP ® CXB1512 LED NOTES Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs. Lumen Maintenance Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. REACh Compliance REACh substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative to insure you get the most up-to-date REACh Declaration. REACh banned substance information (REACh Article 67) is also available upon request. UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS118 REV 9A 26 XLAMP ® CXB1512 LED PACKAGING 6 CXB1512 LEDs are packaged in5 trays of 20. Five trays are sealed in an anti-static bag and placed inside a carton, for a total of2 100 LEDs 4 3 per carton. Each carton contains 100 LEDs from the same performance bin. NOTICE ENTIAL. THIS PLOT AND THE INFORMATION WITHIN ARE THE PROPRIETARY AND AL INFORMATION OF CREE, INC. THIS PLOT COPIED, REPRODUCED OR DISCLOSED TO ANY ED PERSON WITHOUT THE WRITTEN CONSENT NSENT Dimensions are in inches. Tolerances: +.13 5 4 3 5.875 x° +1° 2 1 R .375 6 5 4 NOTICE FIDENTIAL. THIS PLOT AND THE INFORMATION D WITHIN ARE THE PROPRIETARY AND TIAL INFORMATION OF CREE, INC. THIS PLOT E COPIED, REPRODUCED OR DISCLOSED TO ANY IZED PERSON WITHOUTTHE WRITTEN CONSENT C. 3 5.875 2 1 .875 R .375 5.875 R.375 5.875 .875 .875 5.875 LABEL WITH CREE BIN CODE, QUANTITY, LOT # BAG .38 .875 PATENT LABEL IS LOCATED PATENT LABEL IS ON UNDERSIDE OFLOCATED COVER ON UNDERSIDE OF CARTON ITH CREE BIN ANTITY, LOT # .875 LABEL WITH CREE .875 BIN CODE, QTY, LOT# .38 BAG BAG .38 LABEL WITH CREE BIN CODE, QUANTITY, LOT # PATENT LABEL EL IS LOCATED IS LOCATED ON UNDERSIDE OF CARTON IDE OF COVER LABEL WITH CREE BIN CODE, QTY, LOT# LABEL WITH CREE BIN CODE, QUANTITY, LOT # LABEL WITH CREE BIN CODE, QUANTITY, LOT # UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS & BEFORE FINISH. TOLERANCE UNLESS SPECIFIED: LABEL WITH CREE BIN CODE, QUANTITY, LOT # .X ± .XX ± .XXX ± X° ± THIRD ANGLE PROJECTION 5 L WITH CREE BIN QUANTITY, LOT # 6 3.X .XX ± 0.1 ± .05 .XXX ±DRAWN .005BY X° ± 1° 4 THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED DIMENSIONS AREFOR IN SHEET METAL PARTS ONLY CHECK MILLIMETERS & BEFORE FINISH. .X ± .06 TOLERANCE UNLESS SPECIFIED: .XX ± .03 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered .XXX and ±APPROVED .010 .X ± trademarks, 0.1 X° ± 2° ± .05 registered the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the.XXUL logo are 5 4 3.XXX ± .005 trademarks of UL LLC. THIRD ANGLE PROJECTION MATERIAL X° ± 1 ° FOR SHEET METAL PARTS ONLY .X ± .06 APPROVED DATE APPROVED DATE TITLE CXA15 SIZE FINAL PROTECTIVE FINISH DRAW C CXA 4600 Silicon Dri Durham, N.C 27 SCALE Phone (919) 361 0.500 Fax (919) 313-5 2 DATE TITLE CXA15XX_DATASHEET DATE MATERIAL SIZE DATE FINAL PROTECTIVE FINISH DATE TITLE 2 C DRAWING NO. 4600 Silicon Drive Durham, N.C 27703 Phone (919) 361-4770 CXA15XX_DATASHEET_BAG2013 CLD-DS118 SCALE 0.500 REV 9A 27 Fax (919) 313-5303 SHEET CXA15XX_DATASHEET SIZE FINAL PROTECTIVE FINISH DATE MATERIAL FOR SHEET METAL PARTS ONLY DRAWN BY ± .06 DATE UNLESS OTHERWISE SPECIFIED .X .XX ± .03 DIMENSIONS ARE IN CHECK ± .XXX .010 DATE MILLIMETERS & BEFORE FINISH. ± 2 ° TOLERANCE UNLESS SPECIFIED: X° LABEL WITH CREE BIN CODE, QTY, LOT# 6 0.1 .05 .005 1 ° DRAWN BY CHECK 1 DRAWING NO. CXA15XX_DATASHEET_BAG2013 OF
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款高性能的微处理器。
2. 器件简介:该器件是一款32位的ARM Cortex-M4内核微处理器,适用于需要高性能计算和低功耗的应用场景。
3. 引脚分配:共有48个引脚,包括电源引脚、地引脚、I/O引脚等。
4. 参数特性:工作电压为1.8V至3.6V,工作频率高达200MHz。
5. 功能详解:具备高级定时器、模数转换器、通信接口等多种功能。
6. 应用信息:适用于工业控制、医疗设备、智能家居等领域。
7. 封装信息:采用QFP封装,共有48个引脚。
CXB1512-0000-000F0HM427G 价格&库存
很抱歉,暂时无法提供与“CXB1512-0000-000F0HM427G”相匹配的价格&库存,您可以联系我们找货
