GWKAGHB2.CM-RPRQ-27S3 数据手册
OSRAM SOLERIQ Family - Details on Handling,
Mounting and Electrical Connection
Application Note
Introduction
Application Example
This application note provides information on
handling and processing the Chip on Board
Modules (CoB) from the OSRAM Opto
Semiconductors SOLERIQ Family.
This application note contains general
advice on mounting the CoB with respect to
thermal management, electrical connection
and the use of accessories such as optics. It
also
includes
general
drive
recommendations and details on the correct
handling of the CoB itself.
The picture below shows a sample
application using a SOLERIQ CoB, e.g. a
down- or a spot light.
SOLERIQ Product Characteristics
Dimensions and Construction of
SOLERIQ Products
SOLERIQ LED products are based on a
metal core printed circuit board with several
LED chips. The chips are connected with
wire bonds and covered with a silicone resin
containing
phosphorescent
and
light
diffusing particles. Different product versions
contain different numbers of LED chips and
even different chip technologies, but
handling is similar for all SOLERIQ products.
March, 2016
Figure 1: Application example with a
SOLERIQ CoB.
Page 1 of 18
Handling
In addition to general guidelines on handling
LEDs, special care must be taken to ensure
that no mechanical force is applied to the
silicone area.
The LED must not be picked up or
handled by the silicone.
The silicone resin area must not be
touched
during
the
assembly
process. Any force to the lightemitting surface may cause damage
to the wires of the LED array.
Damaged wire bonds may lead to
early device failure, even if the
product shows no immediate change
in performance.
When handling, plastic gloves should be
used and the CoB held at the sides.
Tweezers can be used but the tips must be
kept away from the solder pads and the
resin area (Figures 2, 3, 4).
GOOD
In general, all types of sharp objects (e.g.
pincers, fingernails, etc.) should be avoided
in order to prevent stress to or penetration of
the encapsulant, as this can lead to damage
of the component.
Care must also be taken to ensure that no
other components (e.g. additional optics) in
the application are mounted in mechanical
contact with sensitive components of the
SOLERIQ product.
Avoid contamination of the solder pads and
the thermal contact area when handling.
It is also recommended that SOLERIQ LEDs
are handled with appropriate ESD
protection.
For further information on ESD-compliant
handling, please also refer to the “ESD
Protection while Handling LEDs” application
note.
BAD
Figure 2: Handling with plastic gloves
GOOD
BAD
Figure 3: Handling with tweezers
GOOD
BAD
Figure 4: Storage of the SOLERIQ product
March, 2016
Page 2 of 18
Mounting Recommendations
Information on mounting and thermal
performance is discussed in this chapter.
In principle there are three different options
to mount a CoB:
Gluing (tape or liquid)
Screwing
the
product
(if screw holes available)
Connectors
Simple plastic holders
directly
With the use of gluing, direct screwing and
simple plastic holders hand soldering is
required, while connectors also provide the
electrical connection.
Each option
disadvantages.
offers
advantages
and
Thermal interface
The proper thermal design of an LED
luminaire is critical to guarantee optimum
performance and a long service life for all
components.
The CoB must be mounted with the bottom
surface fully on the heat sink.
Depending on the application and the
SOLERIQ product chosen, passive cooling
may be suitable. In critical applications with
restrictions on the heat sink size combined
with a high power CoB, active cooling may
be needed. Active cooling combines a heat
sink with an auxiliary fan or a similar device
to maximize the air-mass flow onto the heat
sink to maximize its cooling power.
When mounting a CoB, the most important
parameter is the thermal interface.
If adhesives are used, e.g. liquid glue or an
adhesive tape, they must provide a proper
thermal interface.
For efficient thermal transfer from the
SOLERIQ product to the heat sink, the two
solid surfaces must be brought into close
contact using screws, a connector or a
holder. Given that the surfaces of both are
March, 2016
never truly flat, a microscopic roughness
exists. This leads to air in the cavities
between the surfaces. As air is a poor
conductor of heat, these gaps should be
filled with thermally conductive material to
reduce the thermal resistance and to ensure
efficient heat flow from the CoB to the heat
sink.
Several Thermal Interface Materials (TIM)
are available to improve the thermal
performance.
To
optimize
thermal
performance, the TIM should be thin and
have high thermal conductivity.
On the other hand, the TIM must be thick
enough to fill the air gaps and it must be
possible to compress it where the surfaces
come in contact with each other. Thermal
grease works well in this case but may be
difficult to handle in series production.
Thermal pads or tapes are easier to handle
but typically cause a thicker thermal
interface which in turn causes higher thermal
resistance.
We recommend doing thermal tests with
different TIM materials to find the optimum
solution for the surfaces used in the
application.
Special considerations when screwing
the product directly
Some versions of SOLERIQ can be screwed
directly on to a heat sink.
Please note that screwing with too high
torque can cause the CoB to bend which
can have an adverse effect on the thermal
interface. Using a torque wrench is thus
strongly recommended. Good results have
been achieved with torques of 0.1-0.2 Nm
using M3 stainless steel screws. The use of
washers is also recommended. When using
a connector or a holder, please follow the
mounting recommendations of the specific
manufacturer.
CoBs without screw holes are not designed
for direct screwing.
Page 3 of 18
a)
b)
c)
d)
Figure 6: Comparison of different TIMs
Figure 5: Thermography with
SOLERIQ S 13
See figure 5 for thermograph pictures of
SOLERIQ S 13 with different mounting
methods all at 0.1Nm and same temperature
scale.
a)
b)
c)
d)
Screwing directly with thermal pad
Screwing directly with thermal grease
Connector with thermal pad
Connector with thermal grease
Looking at the pictures above in more detail,
screwing the product directly can result in
temperature distribution that is not uniform
as there is more pressure on the CoB at the
screw position than at the solder pad
position. Use of the correct TIM for the
appropriate heat sink roughness is highly
recommended. A connector or a holder can
be used to ensure more homogenous
temperature distribution as this will mean the
pressure on the CoB is uniform. Moreover,
with the correct use of thermal grease better
results were achieved compared to thermal
pad, but the thin application of grease to
merely fill the air gaps can be quite tedious.
Furthermore, better results may be achieved
particularly for rough surfaces with phase
change materials.
Figure 6 shows typical thermal resistances
Rth of some thermal interface materials at
typical conditions normalized to 1cm².
Taking a closer look you will see that the Rth
does not correlate with nominal layer
thickness and thermal conductivity. This is
due to the different capabilities of the
materials to adapt to the surface. Depending
on the surface quality (milled v cast v
polished), a TIM may perform differently.
The capability to equalize a burr is also
important.
A general comparison of different mounting
methods can be seen in Figure 8.
Estimating the required heat sink
To estimate the performance (the Rth) of the
cooler for your application, you need to know
or define:
TS
Maximum ambient temperature Ta max
Operating current (If)
Operating voltage (Vf)
Efficiency of the LED (η)
As a first step calculate the heat load the
heat sink must dissipate:
Pheat = If * Vf * (1- η)
As a second step calculate the temperature
drop of the thermal interface:
TTIM = Rth TIM * Pheat
March, 2016
Page 4 of 18
The remaining temperature budget for the
heat sink is:
Tcooler = TS – Ta max -TTIM
You need a heat sink with a maximum Rth of:
Once the TS has been measured, the value
can be used to calculate the junction
temperature:
Rth = Tcooler / Pheat
Example for SOLERIQ S 19:
Tj = Pheat * Rth,JS,real + TS
TS = 85 °C
Ta max = 40 °C
Vf = 46.5 V
If = 0.7 A
η = 35 %
The junction temperature can be calculated
with the Rth of the LED given in the relevant
datasheet,
OSRAM Opto Semiconductors recommends
attaching the thermocouple using thermally
conductive glue or by soldering.
Pheat = 46.5V * 0.7A * (1-0.35)
= 21.2 W
The datasheet for a common thermal pad
has rates of 1.42 Kcm2/W, the SOLERIQ
S19 has a surface of 24*24mm2.
Rth TIM = 1.42 Kcm2/W / 2.42 cm2 =
0.25 K/W
Figure 7: TS measurement point of a
SOLERIQ S 19, S 13 and S 9
TTIM = 0.25 K/W * 21.2 W = 5.2 K
Tcooler = 85 °C – 40 °C – 5.2 K
=39.8 K ~ 40 K
Rth cooler = 40 K / 21.2 W
= 1.9 K/W
A cooler with a maximum of 1.9K/W is
needed to keep a SOLERIQ S19 with
3000lm below TS = 85 °C at an ambient
temperature of 40°C.
For further information on temperature
measurement,
please
refer
to
the
”Temperature
Measurement
with
Thermocouples” application note.
All materials used for casting the luminaire
or for the thermal interface must be checked
for chemical compatibility with the specific
manufacturer. The suitability of the thermal
material and heat sink material must be
guaranteed.
Moreover, gas tight casting of the CoB LED
must be avoided in order to minimize the
interaction of the CoB with the outgassing of
potentially
critical
materials.
In all cases, the thermal design must be
verified by testing a prototype.
To do this, the case temperature must be
measured within the planned ambient and
operating conditions. The case temperature
(TS) can be measured at the designated
case temperature measurement point given
in the datasheet. This measurement point is
shown for the SOLERIQ S Family in figure 7.
March, 2016
Page 5 of 18
Figure 8: Comparison of different mounting methods
March, 2016
Page 6 of 18
Soldering
The recommended soldering process is
manual soldering. SOLERIQ products are
not suited to reflow soldering.
After soldering the stripped wire must not be
outside the area of the solder pad; otherwise
a short circuit may occur via the aluminum
board (Figure 11).
GOOD
To be RoHS-compliant,
soldering.
use
BAD
lead-free
When selecting the tip for the soldering iron,
choose the optimum size and type for the
component used (Figure 9). Good results
have been achieved with a chisel-formed tip
with a maximum width of the solder pad
length.
Figure 9: Tip selection - correct type for
each application
The maximum wire diameter is related to the
maximum current of the relevant CoB. Wires
with smaller diameter are used, depending
on the chosen forward current; please check
that with the wire supplier. The wire strip
length depends on the size of the SOLERIQ
LED and should be no longer than the
length of the solder pad.
Prepare the wire/solder in accordance with
IPC-A-610D, Chapter 6.3. The stripped wire
(lead) should be protected with a thin layer
of solder (Figure 10).
In order to avoid problems when mounting
the device, the solder used should consist of
the same alloy as the pre-tinned solder
pads.
Figure 11: Soldering of SOLERIQ product
Due to the very low thermal resistance of OS
CoBs, heat will quickly dissipate from the
solder pads while soldering. To reduce the
solder process time, use an additional
temperature-controlled heating plate to
ensure a constant temperature during the
soldering process.
It is recommended to solder the CoB before
mounting to the heat sink. Otherwise, the
heat which is necessary for the soldering
process will dissipate to the heat sink and
the process time will be extended.
When evaluating the soldering process, for
example, you should always start with the
lowest temperature; the temperature of the
soldering tip should not exceed 350°C.
When soldering one pad, a maximum
contact time of 3 seconds should not be
exceeded.
The temperature of the complete CoB, and
in particular the LES, should not exceed
150°C.
For further information on manual lead-free
soldering see also the ”Manual Lead-free
Soldering of LEDs” application note.
Figure 10: Pre-tinned solder pads and
wires
March, 2016
Page 7 of 18
Accessories
1
Connectors
2
To fasten the CoB mechanically onto the
heat sink, you can either screw it or glue it
on. However, manual soldering is needed
afterwards. As an alternative, the CoB can
be attached mechanically to the heat sink
using connectors. These connectors will also
provide the electrical contact at the same
time with push-in terminals for the cables.
A clamping feature for the LED is commonly
used when fixing the LED onto the
connector during mounting. Moreover, most
connectors offer mounting features for
secondary optics.
Please refer to the datasheet/webpage of
the
specific
manufacturer
for
the
recommended maximum torque of the
screws and the wire size if using a
connector.
Several opto-electrical manufacturers have
developed or are currently developing
connectors to simplify mechanical and
electrical connection of SOLERIQ products.
Company
Webpage
BJB
Molex
A.A.G. STUCCHI
TE Connectivity
IDEAL
Bender + Wirth
www.bjb.com
www.molex.com
www.aagstucchi.it
www.te.com
www.idealindustries.com
www.bender-wirth.com
Table 1 shows an overview of part numbers
of available connectors and table 2 shows
the available simple plastic holders without
electrical connection for SOLERIQ CoB.
Each part number gives a link to additional
information on the connector and its use.
March, 2016
3
Figure 12: Sample connector from BJB
with push-in for the cables (1), mounting
feature for secondary optics (2) and a
clamping feature for the LED (3).
Secondary optics
The radiation characteristic of SOLERIQ
products is lambertian. If a viewing angle
narrower than 120° is required, secondary
optics are required. To collect all light from
the SOLERIQ LED, the secondary optics
must be large enough to cover the complete
LES. For example, a reflector must be
mounted on the CoB outside the white ring
that surrounds the yellow resin. Do not use
the white ring for mechanical alignment of
the secondary optics. Otherwise, the LED
array might get damaged (Figure 13).
Figure 13: Secondary optics must be
mounted outside the white ring.
There are many manufacturers who provide
off-the-shelf lenses or reflectors for
SOLERIQ products, see some reference
optics in Table 2 and Table 3.
Page 8 of 18
SOLERIQ LED
BJB
TE
S9
(13.5mmx13.5mm)
S 13 1st gen
(18x18mm)
47.319.6060.50
6-2154874-1
47.319.6111.50
8502-G2
S 13 2nd/3rd gen
(19x19mm)
47.319.2025.50
47.319.2021.50
47.319.2026.50
47.319.2170.50
2213401-1
2213401-2
2-2154857-2
2213254-2
8101/G2
1804140001
1804140103
2213407-1
2213407-2
6-2154874-3
2-2154857-2
8503-G2
180810-0001
S 19
(24mmx24mm)
A.A.G.
STUCCHI
Molex
Ideal
Bender +
Wirth
1804140001
1804140102
50-2002CT
50-2101CR
434 Type 1
434 Type 2
437
50-2103CT
477
462
Table 1: SOLERIQ connector part numbers
SOLERIQ LED
S 9 (13.5mmx13.5mm)
S 13 1st gen (18x18mm)
S 13 2nd/3rd gen (19x19mm)
S 19 (24x24mm)
Darkoo DK1313-FS-B
Darkoo DK1818-14-FS-B
Darkoo DK-S13-FS-B
Darkoo DK-S19-FS-B
Table 2: Overview of simple plastic holders for SOLERIQ CoB
Table 3 shows an overview of some of the available optics, which can be directly mounted onto
the connector with e.g. some twist-and-lock function.
For more optics without regard to mounting feature, see Table 5.
March, 2016
Page 9 of 18
SOLERIQ
LED
Connector
Vendor
Connector Part
No
BJB
47.319.6060.50
Bender +
Wirth
BJB
434
S9
(13.5x
13.5mm)
S 13
2nd/3rd gen
(19x19mm)
A.A.G.
STUCCHI
TE
47.319.2025.50
47.319.2021.50
8101/G2
2213254-2
Ideal
50-2103CT
Molex
1804140001
1804140103
477
Bender +
Wirth
Optic part number
Ledil
Gaggione
Kathod
Almeco
BJB
47.940.311/312/313
Barbara/Mirella
(Typ L1)
Angela-x-B
Angelina-x-B
Angela-x-B
Angelina-x-B
Angela-x
Angelina-x
Angelette-WAS
with metal clip
2213194-1
LLR07M
LLR27M
12684
12685
KCLP1429STKCLP1433ST*
KCLP1429ST
KCLP1430ST
KCLP1431ST
KCLP1432ST
KCLP1433ST
With metal clip
2213349-1
Evo74n/m/
w/xw
Lena/Lenina
(with optic
adapter 502100LN)
Angela/Angelina
(with optic
adapter
50-2100AN)
Angela-x
Angelina-x
Angelette-x
(Typ L1)
LLR01N
(Typ G1)
* With Kathod optic adapter KE1784
March, 2016
Carclo
Page 10 of 18
12796
(Typ
C1)
108n
108w
(Typ A1)
SOLERIQ
LED
Connector
Vendor
Connector Part
No
BJB
47.319.6111.50
A.A.G.
STUCCHI
8502-G2
TE
2213401-2
Ideal
50-2101CR
Bender +
Wirth
437
BJB
47.319.2170.50
Angela-S/M/W-B
AngelinaS/M/W-B
A.A.G.
STUCCHI
8503-G2
TE
2213407-1
2213407-2
Angela-S/M/W-B
AngelinaS/M/W-B
Angela-S/M/W
Angelina-S/M/W
with metal clip
2213194-1
Bender +
Wirth
462
S 13
1st gen
Optic part number
Ledil
Gaggione
Carclo
Kathod
Almeco
75n***
(18x18mm)
S 19
(24x24mm)
Angela-S/M/W-B
AngelinaS/M/W-B
Angela-S/M/W
Angelina-S/M/W
with metal clip
2213194-1
75n***
12684
Newton M
12685
Newton W
Mirella-S/M/WPF
(with 502100MR)
Lena (with 502100LN)
Angela &
Angelina (with
50-2100AN)
Angela/Angelina
Angelette/
Winnie/Stella
Lena/Lenina
Mirella/Barbara
with Ledil plastic
adapter
12684
Newton M
12685
Newton W
with
Carclo
plastic
adapter
LLR07M2
2AA0
LLR27M2
2AA0
Angela/Angelina
Angelette/
Winnie/Stella
Lena/Lenina
Mirella/Barbara
with Ledil plastic
adapter
Evo74n/m/w/xw
Evo106m/w
108n/w
(V98D80)
Evo74n/m/w/xw
Evo106m/w
12684
Newton M
12685
Newton W
with
Carclo
plastic
adapter
Table 3: SOLERIQ connectors and directly mountable optics
Page 11 of 18
108n/108w
DKL97/DKL194
DKL-SQ120
KCLP1429ST
KCLP1430ST
KCLP1431ST
KCLP1432ST
KCLP1433ST**
** With Kathod optic adapter KE1782
*** Customization on demand
March, 2016
KCLP1429ST
KCLP1430ST
KCLP1431ST
KCLP1432ST
KCLP1433ST
With metal clip
2213349-1
108n/108w
DKL97/DKL194
DKL-SQ120
BJB
47.940
.351.56
47.940
.352.56
If you wish to design your own secondary
optics or analyze your optical system, ray
files containing all optical characteristics of
the specific LED are provided on our website
http://catalog.osram-os.com/
(click
Applications/Ray Files).
handling are available; see some examples
in table 4.
Many manufacturers provide solutions for
thermal interface materials (TIM) and for
passive or active cooling depending on the
power class and the specific application.
Drivers
Active and passive cooling solutions:
A number of manufacturers offer electronic
solutions to drive SOLERIQ products. Their
portfolio covers a diverse range, e.g. drivers
with fixed constant current output to
intelligent, dimmable devices.
Company
Company
Webpage
OSRAM
OPTOTRONIC
ROAL
ELECTRONICS
RECOM Lighting
Inventronics
www.osram.de/optotronic
Webpage
www.fischerelektronik.de
www.wisefull.com
www.sarnikon.com
www.led-heatsink.com
www.coolermaster.com
www.sunon.com
www.elr-group.com
www.roallivingenergy.com
www.recom-lighting.com
www.inventronics-co.com
Thermal Accessoires
Many thermally conductive pastes, foils and
compounds with different thermal resistance
and different requirements for careful
Supplier
Fischer
Elektronik
Wisefull
Technology
Sarnikon
MechaTronix
Cooler Master
Sunon
ELR
Thermal pad
Thermal grease
TIM solutions:
Company
Webpage
Bergquist
DENKA
TTM
Laird
www.bergquistcompany.com
www.denka.co.jp
www.coolttm.com
www.lairdtech.com
Thermal
adhesive tape
Thermal liquid
adhesive
Thermal phase
change material
Thermal gap
filler
Liqui-Bond® SA
3505
Hi-Flow 565U
Gap Filler
4000
Bergquist
Sil-Pad 1500ST
TIC 1000A
Bond-Ply® 800
Denka
SPACER Pad
SPACER Grease
ELETHERMAL
TTM
NANOTIM® SPS
NANOTIM® TGS
SPACER Phase
Change
NANOTIM® PCM
Laird
Tgard™ / Tgon™
Tgrease™
Tpcm™ / Tmate™
3M
5590H
Grease TCG-2035
8810
Tpli™ /
Tflex™ /
Tputty™
TC-2810
Table 4: Examples for thermal interface materials
You will find a large number of partners
offering accessories on the website of the
“LED Light for you” network.
The network provides details on experts for
optical-, thermal- and electrical management
as well as system integration partners. It
supports you and your customer in the
implementation of your idea...be it for a
component, partial project or complete
solution.
March, 2016
You can find more accessories for the
SOLERIQ products like secondary optics,
connectors, thermal solutions and drivers by
visiting the LLFY Selector App:
http://www.ledlightforyou.com/Services/enApp.php
The LLFY Selector App can be used on
smartphones, tablets with an iOS or Android
operating system and it is also available in a
desktop version.
Page 12 of 18
Figure 14: Example for an easy search for
available accessories for a SOLERIQ
product with the LLFY Selector App.
Optical considerations
Optical mounting
There are several options to attach secondary optics to SOLERIQ products:
Fix the optics within the luminaire housing and attach them on top of the SOLERIQ CoB.
Attach the optics on top of a connector with e.g. a twist-and-lock function.
Some optics are supplied with a holder which can be directly applied on the SOLERIQ.
Optical manufacturers
There are many LED optical manufacturers around the world to offer optical solutions for
SOLERIQ LEDs. Table 5 shows some examples of optics solutions from different optical
manufacturers to have a first reference for designing an optical system.
Optical
manufacturer
Ledil
March, 2016
SOLERIQ
LED
Beam Angle FWHM
< 15°
S9
(13.5x13.5mm)
S 13 2nd/3rd
gen
(19x19mm)
S 13 1st gen
(18x18mm)
Angela-S
S 19
(24x24mm)
Angela-S
Angela-S
Link
15 – 30°
Mirella-S-PF
Mirella-M-PF
Winnie-S
Angela-M
Angelina-S
> 30°
Mirella-W-PF
Winnie-M
Winnie-W
Angela-W/XW
Angelina-M/W/XW
Angela-M/W
Angelina-S
Mirella-S-PF
Angelina-S
Angela-M
Angelina-M/W
Saga
Mirella-M/W-PF
Angelina-M/W
Angela-W
Page 13 of 18
www.ledil.com
Optical
manufacturer
SOLERIQ LED
Gaggione
S9
(13.5x13.5mm)
Beam Angle FWHM
< 15°
LLR05N
S 13 2nd/3rd gen
(19x19mm)
LLR27M
S 13 1st gen
(18x18mm)
LLC56N
LLR01N
LLR05N
S 19(24x24mm)
Kathod
S9
(13.5x13.5mm)
S 13 2nd/3rd gen
(19x19mm)
Alux Luxar
S 19
(24x24mm)
March, 2016
www.lednlight.com
www.khatod.com
KCLP1858CR
KCLP1429ST
KCLP1430ST
KCLP1429ST
KCLP1430ST
PL50SIL
KCLP1429ST
S 19
(24x24mm)
S9
(13.5x13.5mm)
S 13 2nd/3rd gen
(19x19mm)
S 13 1st gen
(18x18mm)
S 19
(24x24mm)
S 13 2nd/3rd gen
(19x19mm)
S 13 1st gen
(18x18mm)
Link
> 30°
LLC05M
LLC05W
LLC15W
LLR01NxlLLD01M1
LLR01NxLLD01S1
LLR05NxLLD05S1
LLC15W
LLR07M22AA0
LLR27M22AA0
S 13 1st gen
(18x18mm)
Carclo
15 – 30°
LLC15M
LLC56N
LLC66N7
LLC66M7
LLR01N
LLR05NxLLD05M1
LLC56N7
LLR05N
LLR07M
LLR01N
LLR05N
KCLP1431ST
KCLP1432ST
KCLP1433ST
KCLP1431ST
KCLP1432ST
KCLP1433ST
KCLP1430ST
KCLP1431ST
KCLP1432ST
KCLP1433ST
www.carclo-optics.com
12684 Newton M
12685 Newton W
12684 Newton M
12685 Newton W
12684 Newton M
12685 Newton W
PLC 6900
PLC 7500
PLC 7800
PLC 7900
PLC 10600
PLC 7000
PLC 7100
PLC 7200
PLC 7300
PLC 7400
PLC 7600
PLC 7700
PLC 8000
PLC 9600
PLC 9700
PLC 9800
PLC 9900
PLC 10000
PLC 10100
PLC 10200
PLC 10300
PLC 10400
PLC 10700
Page 14 of 18
PLC 8100
PLC 10500
PLC 10800
Optical
manufacturer
SOLERIQ LED
Almeco
S9
(13.5x13.5mm)
S 13
(18x18mm) &
(19x19mm)
S 19
(24x24mm)
Darkoo
Beam Angle FWHM
S9
(13.5x13.5mm)
S 13 2nd/3rd gen
(19x19mm)
S 13 1st gen
(18x18mm)
DK5812-H32-Z
DK9212-R&L
DK7514-R&L-B
DK8512-R&L-B
S 13 2nd/3rd gen
(19x19mm)
S 13 1st gen
(18x18mm)
S 19
(24x24mm)
108w
Evo74n
108n
Evo106n
Evo74n
Evo106m
108n
DK3530-JC
DK4224-JC
DK4524-JC
DK5024-JC
DK6924-JC
DK4720-JC
DK4730-JC
DK4740-JC
Evo74m/w/xw
108w
Evo74m/w/xw
Evo106w
108w
DK3540-JC
DK3560-JC
DK4238-JC-B
DK4238-JC
DK4260-JC
DK4538-JC
DK4560-JC
DK4560-JC-Z
www.almecogroup.com/en
www.darkoo.cc
DK9224-R&L
DK6916-R&L-B
DK5038-REF-B
DK90638-JC
DK90660-JC
www.nata.cn
2934-E
3-1097-E
4-1500-E
4-1501-E
Table 5: Secondary optics for SOLERIQ CoB
March, 2016
> 30°
108n
S 19
(24x24mm)
Nata
Link
15 – 30°
< 15°
Page 15 of 18
3-1099-E
3-1098-E
4-1407-E
General Electrical Drive
recommendations
Driver information
The light output of an LED corresponds to
the forward current. OSRAM Opto
Semiconductors recommends operating
CoBs with constant current ECGs (electric
control gear) to maintain a constant light
output from the system. Do not apply
reverse voltage to the CoB.
The selected driver device must meet the
input requirements specified by the user
(110V AC / 220V AC input) as well as the
output requirements. For example, the range
of Vout (DC), Iout (DC) and electrical power
must be checked. Moreover, it is the
responsibility of the luminaire designer to
ensure that the chosen driver fulfils all the
local regulatory requirements.
Precautions for inrush current
If you switch on a power supply on the
output side while the input side is on, an
immediate inrush current may occur. These
inrush currents can damage the LED so they
must be avoided in all circumstances.
Only a small number of power supplies can
handle hot plug-in. The majority uses large
output capacitors to eliminate the current
ripple without an additional current peak
limiter which can harm the CoB.
Therefore, OSRAM Opto Semiconductors
recommends that you avoid inrush currents
by not switching on the output side while the
input side is powered unless there are other
current limiter precautions in place and
verified by measurements. In any case, the
maximum surge current must not be
exceeded to ensure proper operation of the
device.
Multiple array circuit design
For some luminaire designs, it may be
desired to drive more CoB LEDs with one
power supply. If using a single power supply
with one output channel for constant current
mode, series connection of all CoB LEDs is
March, 2016
recommended. This guarantees the same
current and therefore the same brightness
for all CoB LEDs.
The luminaire designer must ensure that the
driver can operate at the resulting forward
voltage for the specific current. Moreover,
ensure that the luminaire still complies with
electrical regulations (SELV etc.) with the
resulting higher voltages on the output side
of the power supply.
Use a proper electrically isolated TIM in the
case of serial connection.
Ripple
The ripple of an LED power supply is the
unwanted residual periodic variation of the
direct current output after conversion from
AC to DC by the driver. The residual ripple
of the various drivers differs – values from
5% to 40% are common. For some sensitive
applications, a DC output with low ripple (<
10%) is required to ensure very stable light
of a high quality.
Please ensure that the peak forward current
(including ripple) does not exceed the
maximum current specified in the relevant
datasheet.
Dimming
An adjustable light intensity is necessary in
some applications. PWM dimming of the
CoB
is
recommended
as
current
dependency exists among several LED
parameters. If dimming is achieved by
adjusting the DC-current, a chromaticity
coordinate shift occurs which may be
detected in sensitive applications. With a
PWM-controlled system, only one current
level is used. The light intensity is adjusted
by switching the current on/off periodically
with a specified duty circle and frequency.
As the response of the human eye is not
linear, a linearization of the brightness can
also be achieved via PWM control by
increasing the duty cycle exponentially
(Figure 19).
Page 16 of 18
Conclusion
The intention of the methods for mounting
and electrical connection and optical
considerations described above is to provide
concepts or examples which show the basic
design and principal process.
Figure 19: Exponential PWM control for
linear increase in brightness.
The frequency of the PWM control should be
above 300Hz to avoid noticeable flickering
to the human eye. PWM frequencies up to 1
kHz are applicable for switching mode
drivers and around 10 kHz for linear drivers.
For certain applications, such as rotating
parts or for camera illumination, some
frequencies are suitable and some are not
applicable.
March, 2016
In all cases, the luminaire design must be
OSRAM OPTO Semiconductors is able to
support
its
customers
during
their
development and design processes in
finding the best solution for their specific
applications.
For further information or application
support, please contact your sales
representative
or
OSRAM
Opto
Semiconductors.
Page 17 of 18
Appendix
Don't forget: LED Light for you is your place to be whenever you are looking
for information or worldwide partners for your LED Lighting project.
Authors: Alfons Siedersbeck, Dr. Roland Schulz, Alexander Wilm, Manfred Scheubeck, Horst
Varga, Kurt-Jürgen Lang
ABOUT OSRAM OPTO SEMICONDUCTORS
OSRAM, Munich, Germany is one of the two leading light manufacturers in the world. Its
subsidiary, OSRAM Opto Semiconductors GmbH in Regensburg (Germany), offers its customers
solutions based on semiconductor technology for lighting, sensor and visualization applications.
Osram Opto Semiconductors has production sites in Regensburg (Germany), Penang (Malaysia)
and Wuxi (China). Its headquarters for North America is in Sunnyvale (USA), and for Asia in Hong
Kong. Osram Opto Semiconductors also has sales offices throughout the world.
For more information go to www.osram-os.com.
DISCLAIMER
All information contained in this document has been collected, analyzed and verified with great
care by OSRAM Opto Semiconductors GmbH. However, OSRAM Opto Semiconductors GmbH is
not responsible for the correctness and completeness of the information contained in this
document and OSRAM Opto Semiconductors GmbH cannot be made liable for any damage that
occurs in connection with the use of and/or reliance on the content of this document. The
information contained in this report represents the state of knowledge as of [March 2016].
March, 2016
Page 18 of 18
