GWKAGHB2.CM-RQRR-40S3
    AMSOSRAM(艾迈斯半导体)
    LEDCOBSOLERIQ4000KSQUARE
GWKAGHB2.CM-RQRR-40S3 数据手册
2015-10-29 SOLERIQ® S 13 Datasheet Version 1.0 GW KAGHB2.CM The SOLERIQ® S products were specifically designed for applications requiring large flux packages out of a compact area. Die SOLERIQ® S Produkte wurden speziell für Anwendungen entwickelt, die großen Lichtstrom aus einer kompakten Fläche benötigen. Features: • Package: Chip-on-Board • Viewing angle at 50 % IV: 120° • Color: 2700 K - 4000 K (white) • CRI: min. 90 • Luminous Flux: typ. 1190 lm @ 3000 K, 85 °C • Luminous efficacy: typ. 98 lm/W @ 3000 K, 85 °C Besondere Merkmale: • Gehäusetyp: Chip-on-Board • Abstrahlwinkel bei 50 % IV: 120° • Farbe: 2700 K - 4000 K (weiß) • CRI: min. 90 • Lichtstrom: typ. 1190 lm @ 3000 K, 85 °C • Lichtausbeute: typ. 98 lm/W @ 3000 K, 85 °C Applications • Spot lights • Indoor General Lighting • Professional downlights Anwendungen • Spot-Leuchten • Innen-Allgemeinbeleuchtung • Professionelle Downlights 2015-10-29 1 Version 1.0 GW KAGHB2.CM Ordering Information Bestellinformation Type: Typ: Color Temperature Luminous Flux Farbtemperatur Lichtstrom Ordering Code 1) page 16 Bestellnummer 1) Seite 16 IF = 350 mA, TS = 85 °C [K] ΦV [lm] GW KAGHB2.CM-QURP-27S3 2700 1042 ... 1210 Q65111A9019 GW KAGHB2.CM-RPRQ-30S3 3000 1120 ... 1300 Q65111A9028 GW KAGHB2.CM-RQRR-35S3 3500 1210 ... 1400 Q65111A9017 GW KAGHB2.CM-RQRR-40S3 4000 1210 ... 1400 Q65111A9010 GW KAGHB2.CM-QURP--27B3 2700 Brilliant White 1042 ... 1210 Q65111A9169 GW KAGHB2.CM-RPRQ-30B3 3000 Brilliant White 1120 ... 1300 Q65111A9168 GW KAGHB2.CM-RQRR-35B3 3500 Brilliant White 1210 ... 1400 Q65111A9167 Note: The above Type Numbers represent the order groups which include only a few brightness groups (see page 5). Only one group will be shipped on each packing unit (there will be no mixing of two groups on each packing unit). E. g. GW KAGHB2.CM-RPRQ-30S3 means that only one group RP, RQ will be shippable for any packing unit. Anm.: Die oben genannten Typbezeichnungen umfassen die bestellbaren Selektionen. Diese bestehen aus wenigen Helligkeitsgruppen (siehe Seite 5). Es wird nur eine einzige Helligkeitsgruppe pro Verpackungseinheit geliefert. Z. B. GW KAGHB2.CM-RPRQ-30S3 bedeutet, dass in einer Verpackungseinheit nur eine der Helligkeitsgruppen RP, RQ enhalten ist. 2015-10-29 2 Version 1.0 GW KAGHB2.CM Maximum Ratings Grenzwerte Parameter Symbol Values Unit Bezeichnung Symbol Werte Einheit Operating temperature range Betriebstemperatur Top -40 ... 105 °C Storage temperature range Lagertemperatur Tstg -40 ... 100 °C Junction temperature Sperrschichttemperatur Tj 125 °C Forward current Durchlassstrom (TS = 85 °C) IF 30 ... 700 mA ESD withstand voltage ESD Festigkeit (acc. to ANSI/ESDA/JEDEC JS-001 - HBM) VESD up to 2 kV 2015-10-29 3 Version 1.0 GW KAGHB2.CM Characteristics (TS = 85 °C; IF = 350 mA) Kennwerte Parameter Symbol Values Unit Bezeichnung Symbol Werte Einheit Viewing angle at 50 % IV Abstrahlwinkel bei 50 % IV (typ.) 2ϕ 120 ° Forward voltage 2) page 16 , 3) page 16 Durchlassspannung 2) Seite 16 , 3) Seite 16 (min.) (typ.) (max.) VF VF VF 33 35 37 V V V Color rendering index 4) page 16 Farbwiedergabe Index 4) Seite 16 (2700K - 4000K) (min.) Ra 90 - Real thermal resistance junction / solder point (typ.) (max.) Rth JS real Rth JS real 1.68 2.09 K/W K/W Rth JS el Rth JS el 1.0 1.3 K/W K/W 5) page 16 Realer Wärmewiderstand Sperrschicht / Lötpad 5) Seite 16 "Electrical" thermal resistance junction / solder point (typ.) 5) page 16 (max.) "Elektrischer" Wärmewiderstand Sperrschicht / Lötpad 5) Seite 16 (with efficiency ηe = 38 %) 2015-10-29 4 Version 1.0 GW KAGHB2.CM Brightness Groups Helligkeitsgruppen Group Luminous Flux 1) page 16 Luminous Flux 1) page 16 Luminous Intensity 6) page 16 Lichtstrom 1) Seite 16 Lichtstrom 1) Seite 16 Lichtstärke 6) Seite 16 (min.) ΦV [lm] (max.) ΦV [lm] (typ.) IV [cd] QU 1042 1120 344 RP 1120 1210 370.8 RQ 1210 1300 399.4 RR 1300 1400 429.7 Gruppe 2015-10-29 5 Version 1.0 GW KAGHB2.CM Chromaticity Coordinate Groups 7) page 16 , 8) page 16 Farbortgruppen 7) Seite 16 , 8) Seite 16 Color Chromaticity Groups 7) page 16 , 8) page 16 Farbortgruppen 7) Seite 16 , 8) Seite 16 Group Cx Cy a b Θ 40S3 0.3823 0.3790 0.0094 0.0040 53 35S3 0.4077 0.3908 0.0093 0.0041 53 30S3 0.4339 0.4020 0.0085 0.0041 53 27S3 0.4578 0.4092 0.0079 0.0041 54 35B3 0.4035 0.3837 0.0093 0.0041 54 30B3 0.4300 0.3950 0.0083 0.0041 53 27B3 0.4540 0.4021 0.0081 0.0042 54 2015-10-29 6 Version 1.0 GW KAGHB2.CM Group Name on Label Gruppenbezeichnung auf Etikett Example: QU-30S3 Beispiel: QU-30S3 Brightness Helligkeit Chromaticity Coordinate Farbort QU 30S3 Note: No packing unit / tape ever contains more than one group for each selection. Anm.: In einer Verpackungseinheit / Gurt ist immer nur eine Gruppe für jede Selektion enthalten. 2015-10-29 7 Version 1.0 GW KAGHB2.CM Relative Spectral Emission - V(λ) = Standard eye response curve 6) page 16 Relative spektrale Emission - V(λ) = spektrale Augenempfindlichkeit 6) Seite 16 Φrel = f (λ); TS = 85 °C; IF = 350 mA Irel GW KAGHB2.CM 1,0 : Vλ 0,8 0,6 0,4 0,2 0,0 350 400 450 500 550 600 650 700 750 800 λ [nm] Radiation Characteristics 6) page 16 Abstrahlcharakteristik 6) Seite 16 Irel = f (ϕ); TS = 85 °C GW KAGHB2.CM ϕ [°] -10° 0° 10° -20° 20° 30° 40° 50° 60° 70° 80° 90° 1,0 -30° -40° 0,8 -50° 0,6 -60° 0,4 -70° 0,2 -80° -90° 0,0 -100° 2015-10-29 8 Irel Version 1.0 GW KAGHB2.CM Forward Current 6) page 16 , 3) page 16 Durchlassstrom 6) Seite 16 , 3) Seite 16 IF = f (VF); TS = 85 °C IF [mA] Relative Luminous Flux 6) page 16 , 3) page 16 Relativer Lichtstrom 6) Seite 16 , 3) Seite 16 ΦV/ΦV(350 mA) = f(IF); TS = 85 °C ΦV GW KAGHB2.CM 700 GW KAGHB2.CM 1,8 ΦV(350mA) 1,6 600 1,4 500 1,2 400 1,0 300 0,8 0,6 200 0,4 100 0,2 30 31 32 33 34 35 36 30 100 37 VF [V] GW KAGHB2.CM 0,02 0,01 0,00 -0,01 -0,02 30 100 0 20 0 30 0 40 0 50 0 60 0 70 IF [mA] 2015-10-29 0 30 0 40 0 50 0 60 0 70 IF [mA] Chromaticity Coordinate Shift 6) page 16 Farbortverschiebung 6) Seite 16 ΔCx, ΔCy = f(IF); TS = 85 °C ∆Cx ∆Cy 0 20 9 Version 1.0 GW KAGHB2.CM Relative Forward Voltage 6) page 16 Relative Vorwärtsspannung 6) Seite 16 ΔVF = VF - VF(85 °C) = f(Tj); IF = 350 mA Relative Luminous Flux 6) page 16 Relativer Lichtstrom 6) Seite 16 ΦV/ΦV(85 °C) = f(Tj); IF = 350 mA GW KAGHB2.CM Φv ∆VF [V] 3,0 GW KAGHB2.CM 1,2 Φv(85°C) 2,5 1,0 2,0 0,8 1,5 0,6 1,0 0,4 0,5 0,2 0,0 0,0 -40 -20 0 20 40 60 80 100 120 Chromaticity Coordinate Shift 6) page 16 Farbortverschiebung 6) Seite 16 ΔCx, ΔCy = f(Tj); IF = 350 mA GW KAGHB2.CM 0,02 : Cx : Cy - 0,01 0,00 -0,01 -0,02 0 20 40 60 80 100 120 Tj [°C] 2015-10-29 20 40 60 80 100 120 Tj [°C] Tj [°C] ∆Cx ∆Cy 0 10 Version 1.0 GW KAGHB2.CM Max. Permissible Forward Current Max. zulässiger Durchlassstrom IF = f (T) IF [mA] GW KAGHB2.CM 800 700 600 500 400 300 200      100 0 2015-10-29 Do not use below 30mA 0 20 40 60 80 100 Ts [°C] 11 Version 1.0 GW KAGHB2.CM Package Outline 9) page 16 Maßzeichnung 9) Seite 16 Approximate Weight: 1.06 g Gewicht: 1.06 g 2015-10-29 12 Version 1.0 GW KAGHB2.CM Tray Bauteilträger Min. 210 pcs. per packing unit (42 units per tray, min. 5 trays per vacuum bag) / 42 Teile pro Bauteilträger, 5 Bauteilträger pro Vakuumverpackung Barcode-Product-Label (BPL) Barcode-Produkt-Etikett (BPL) OSRAM Opto EX A RoHS Compliant (6P) BATCH NO: 1234567890 (1T) LOT NO: 1234567890 BIN1: XX-XX-X-XXX-X LX XXXX Semiconductors MP ML Temp ST X XXX °C X (9D) D/C: 1234 Pack: RXX LE DEMY XXX X_X123_1234.1234 X (X) PROD NO: 123456789(Q)QTY: 9999 (G) GROUP: XX-XX-X-X OHA04563 Note: Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card. Regarding dry pack you will find further information in the internet and in the Short Form Catalog in chapter “Tape and Reel” under the topic “Dry Pack”. Here you will also find the normative references like JEDEC. Anm.: Feuchteempfindliche Produkte sind verpackt in einem Trockenbeutel zusammen mit einem Trockenmittel und einer Feuchteindikatorkarte. Bezüglich Trockenverpackung finden Sie weitere Hinweise im Internet und in unserem Short Form Catalog im Kapitel “Gurtung und Verpackung” unter dem Punkt “Trockenverpackung”. Hier sind Normenbezüge, unter anderem ein Auszug der JEDEC-Norm, enthalten. 2015-10-29 13 Version 1.0 GW KAGHB2.CM Transportation Packing and Materials Kartonverpackung und Materialien Dimensions of transportation box in mm Width Length Height Breite Länge Höhe 284 ± 3 268 ± 3 55 ± 3 2015-10-29 14 Version 1.0 GW KAGHB2.CM Notes Hinweise The evaluation of eye safety occurs according to the standard IEC 62471:2008 ("photobiological safety of lamps and lamp systems"). Within the risk grouping system of this CIE standard, the LED specified in this data sheet fall into the class Low risk (exposure time 100 s). Under real circumstances (for exposure time, eye pupils, observation distance), it is assumed that no endangerment to the eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light sources have a high secondary exposure potential due to their blinding effect. As is also true when viewing other bright light sources (e.g. spotlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation. Die Bewertung der Augensicherheit erfolgt nach dem Standard IEC 62471:2008 ("photobiological safety of lamps and lamp systems"). Im Risikogruppensystem dieser CIE- Norm erfüllen die in diesem Datenblatt angegebenen LEDs folgende Gruppenanforderung - Low risk (Expositionsdauer 100 s). Unter realen Umständen (für Expositionsdauer, Augenpupille, Betrachtungsabstand) geht damit von diesen Bauelementen keinerlei Augengefährdung aus. Grundsätzlich sollte jedoch erwähnt werden, dass intensive Lichtquellen durch ihre Blendwirkung ein hohes sekundäres Gefahrenpotenzial besitzen. Nach einem Blick in eine helle Lichtquelle (z.B. Spotlights), kann ein temporär eingeschränktes Sehvermögen oder auch Nachbilder zu Irritationen, Belästigungen, Beeinträchtigungen oder sogar Unfällen führen. This LED contains metal materials. Corroded metal may lead to a worsening of the optical performance of the LED and can in the worst case lead to a failure of the LED. Do not expose this LED to aggressive atmospheres. Note, that corrosive gases may as well be emitted from materials close to the LED in the final product. Diese LED enthält teilweise metallische Bestandteile. Korrodiertes Metall kann zu einer Verschlechterung der optischen Eigenschaften und im schlimmsten Fall zum Ausfall der LED führen. Diese LED darf aggressiven Bedingungen nicht ausgesetzt werden. Es ist zu beachten, dass korrosive Gase auch von Materialien emittiert werden können, die sich im Endprodukt in unmittelbarer Umgebung der LED befinden. This LED is designed for specific/recommended applications only. Please consult OSRAM Opto Semiconductors Sales Staff in advance for detailed information on other non-recommended applications (e.g. automotive) OR Please visit www.osram-os.com/appnotes. Change management for this component is aligned with the requirements of the lighting market. Die LED ist ausschließlich für spezifisch empfohlene Anwendungen konzipiert. Bitte kontaktieren Sie das OSRAM Opto Semiconductors Vertriebspersonal für detailierte Informationen über nicht empfohlene Anwendungsbereiche (z.B. Automobilbereich). oder besuchen Sie www.osram-os.com/appnotes Das Änderungsmanagement dieses Bauteils ist an den Anforderungen des Lichtmarktes ausgerichtet. 2015-10-29 15 Version 1.0 GW KAGHB2.CM Disclaimer Disclaimer Language english will prevail in case of any discrepancies or deviations between the two language wordings. Bei abweichenden Angaben im zweisprachigen Wortlaut haben die Angaben in englischer Sprache Vorrang. Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version in the Internet. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Components used in life-support devices or systems must be expressly authorized for such purpose! Critical components* may only be used in life-support devices** or systems with the express written approval of OSRAM OS. Bitte beachten! Lieferbedingungen und Änderungen im Design vorbehalten. Aufgrund technischer Anforderungen können die Bauteile Gefahrstoffe enthalten. Für weitere Informationen zu gewünschten Bauteilen, wenden Sie sich bitte an unseren Vertrieb. Falls Sie dieses Datenblatt ausgedruckt oder heruntergeladen haben, finden Sie die aktuellste Version im Internet. Verpackung Benutzen Sie bitte die Ihnen bekannten Recyclingwege. Wenn diese nicht bekannt sein sollten, wenden Sie sich bitte an das nächstgelegene Vertriebsbüro. Wir nehmen das Verpackungsmaterial zurück, falls dies vereinbart wurde und das Material sortiert ist. Sie tragen die Transportkosten. Für Verpackungsmaterial, das unsortiert an uns zurückgeschickt wird oder das wir nicht annehmen müssen, stellen wir Ihnen die anfallenden Kosten in Rechnung. Bauteile, die in lebenserhaltenden Apparaten und Systemen eingesetzt werden, müssen für diese Zwecke ausdrücklich zugelassen sein! Kritische Bauteile* dürfen in lebenserhaltenden Apparaten und Systemen** nur dann eingesetzt werden, wenn ein schriftliches Einverständnis von OSRAM OS vorliegt. *) A critical component is a component used in a life-support device or system whose failure can reasonably be expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that device or system. **) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be endangered. 2015-10-29 *) Ein kritisches Bauteil ist ein Bauteil, das in lebenserhaltenden Apparaten oder Systemen eingesetzt wird und dessen Defekt voraussichtlich zu einer Fehlfunktion dieses lebenserhaltenden Apparates oder Systems führen wird oder die Sicherheit oder Effektivität dieses Apparates oder Systems beeinträchtigt. **) Lebenserhaltende Apparate oder Systeme sind für (a) die Implantierung in den menschlichen Körper oder (b) für die Lebenserhaltung bestimmt. Falls Sie versagen, kann davon ausgegangen werden, dass die Gesundheit und das Leben des Patienten in Gefahr ist. 16 Version 1.0 GW KAGHB2.CM Glossary Glossar 1) Brightness: Brightness values are measured during a current pulse of typically 10 ms, with a tolerance of ± 7 %. 1) Helligkeit: Helligkeitswerte werden während eines Strompulses einer typischen Dauer von 10 ms, mit einer Genauigkeit von ± 7 % ermittelt. 2) Forward Voltage: The forward voltage is measured during a current pulse duration of typically 1 ms with a tolerance of ± 0.05 V. 2) Durchlassspannung: Spannungswerte werden mit einer Stromeinprägedauer von 1 ms, mit einer Genauigkeit von ± 0.05 V ermittelt. 3) Characteristic curve: In the range where the line of the graph is broken, you must expect higher differences between single LEDs within one packing unit. 3) Kennlinien: Im gestrichelten Bereich der Kennlinien muss mit erhöhten Abweichungen zwischen Leuchtdioden innerhalb einer Verpackungseinheit gerechnet werden. 4) Color reproduction index: Color reproduction index values (CRI-RA) are measured during a current pulse of typically 10 ms and with a tolerance of ± 2. 4) Farbwiedergabe Index: Werte des Farbwiedergabe Index (CRI-RA) werden während eines Strompulses einer typischen Dauer von 10 ms, mit einer Genauigkeit ± 2 ermittelt. 5) Thermal Resistance: Rth max is based on statistic values (6σ). 5) Wärmewiderstand: Rth statistischen Werten (6σ). 6) Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 6) Typische Werte: Wegen der besonderen Prozessbedingungen bei der Herstellung von LED können typische oder abgeleitete technische Parameter nur aufgrund statistischer Werte wiedergegeben werden. Diese stimmen nicht notwendigerweise mit den Werten jedes einzelnen Produktes überein, dessen Werte sich von typischen und abgeleiteten Werten oder typischen Kennlinien unterscheiden können. Falls erforderlich, z.B. aufgrund technischer Verbesserungen, werden diese typischen Werte ohne weitere Ankündigung geändert. 7) Chromaticity coordinate groups: Chromaticity coordinate groups are measured during a current pulse duration of typically 10 ms with a tolerance of ±0.005. 7) 8) Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and dimensions are specified in mm. 8) 2015-10-29 17 max basiert auf Farbortgruppen: Farbortgruppen werden mit einer Stromeinprägedauer von 10 ms, mit einer Genauigkeit von ±0.005 ermittelt. Maßtoleranz: Wenn in der Zeichnung nicht anders angegeben, gilt eine Toleranz von ±0,1. Maße werden in mm angegeben. Version 1.0 GW KAGHB2.CM Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 2015-10-29 18
GWKAGHB2.CM-RQRR-40S3 价格&库存
很抱歉,暂时无法提供与“GWKAGHB2.CM-RQRR-40S3”相匹配的价格&库存,您可以联系我们找货
