CXA2520-0000-000N0HR440F
    WOLFSPEED
    LED COB CXA2520 4000K WHITE SMD
CXA2520-0000-000N0HR440F 数据手册
PRODUCT FAMILY DATA SHEET XLamp® CXA2520 LED PRODUCT DESCRIPTION FEATURES TABLE OF CONTENTS The XLamp® CXA2520 LED array expands • Available in 4-step, 3‑step and 2-step Characteristics................................................ 2 Cree LED’s family of high‑flux, multi‑die EasyWhite bins at 2700 K, 3000 K, Operating Limits.............................................. 2 arrays, offering high performance in an 3500 K, 4000 K & 5000 K CCT and Flux Characteristics, EasyWhite® Order easy-to-use platform. With XLamp LED 4-step EasyWhite bins at 5700 K & Codes and Bins............................................... 3 lighting‑class reliability, the CXA2520’s 6500 K CCT Flux Characteristics, ANSI White Order ® uniform emitting surface enables both • Available in ANSI white bins at 4000 K, Codes and Bins............................................... 6 directional and non‑directional lighting Relative Spectral Power Distribution............. 7 applications and luminaire 5000 K, 5700 K & 6500 K CCT designs. • Available in 70-, 80-, 90- and Available in 2-step, 3‑step and 4-step color 93‑minimum CRI options Electrical Characteristics................................ 7 Relative Luminous Flux................................... 8 consistency, and featuring a 19‑mm optical • Forward voltage option: 36‑V class Typical Spatial Distribution............................. 9 source, the CXA2520 brings new levels of • 85 °C binning and characterization Performance Groups - Brightness................. 9 flux and efficacy to this form factor. • Maximum drive current: 1250 mA Performance Groups - Chromaticity............ 10 • 115° viewing angle, uniform EasyWhite® Bins Plotted on the 1931 CIE The CX Family LED Design Guide provides chromaticity profile Color Space................................................... 13 basic information on the requirements • Top-side solder connections ANSI White Bins Plotted on the 1931 CIE to use the CXA2520 LED successfully in • Thermocouple attach point Color Space................................................... 13 luminaire designs. • NEMA SSL-3 2011 standard flux bins Bin and Order Code Formats........................ 14 • RoHS and REACh compliant Mechanical Dimensions............................... 14 • UL recognized component (E349212) Thermal Design............................................. 15 ® Notes............................................................. 16 Packaging...................................................... 17 Cree LED / 4400 Silicon Drive / Durham, NC 27703 USA / +1.919.313.5330 / www.cree-led.com © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS53 REV 10A 1 XLAMP ® CXA2520 LED CHARACTERISTICS Characteristics Unit Viewing angle (FWHM) Minimum Typical degrees ESD withstand voltage (HBM per Mil-Std-883D) Maximum 115 V 8000 DC forward current mA 1250* Reverse current mA 0.1 Forward voltage (@ 550 mA, 85 °C) V Forward voltage (@ 550 mA, 25 °C) V * 35 42 Refer to the Operating Limits section. OPERATING LIMITS The maximum current rating of the CXA2520 depends on the case temperature (Tc) when the LED has reached thermal equilibrium under steady-state operation. The graph shown below assumes that the system design employs good thermal management (thermal interface material and heat sink) and may vary when poor thermal management is employed. Please refer to the Mechanical Dimensions section on page 14 for the location of the Tc measurement point. Another important factor in good thermal management is the temperature of the Light Emitting Surface (LES). Cree LED recommends a maximum LES temperature of 135 °C to ensure optimal LED lifetime. Please refer to the Thermal Design section on page 15 for more information on LES temperature measurement. CXA2520 1500 1250 If (mA) 1000 750 500 250 0 0 25 50 75 100 125 150 Case Temperature (°C) © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS53 REV 10A 2 XLAMP ® CXA2520 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS (IF = 550 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA2520 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 14). Nominal CCT CRI Min 70 Minimum Luminous Flux Typ 75 2-Step 3-Step 4-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* R2 2420 2741 R4 2600 2916 S2 2780 3066 CXA2520-0000000N00S265F Q4 2260 2560 CXA2520-0000000N0HQ465F R2 2420 2741 R4 2600 2916 CXA2520-0000000N0HR465F R2 2420 2741 CXA2520-0000000N00R257F R4 2600 2916 S2 2780 3066 CXA2520-0000000N00S257F Q4 2260 2560 CXA2520-0000000N0HQ457F R2 2420 2741 R4 2600 2916 R2 2420 2741 R4 2600 2916 S2 2780 3066 CXA2520-0000000N00S250H CXA2520-0000000N00S250F Q4 2260 2560 CXA2520-0000000N0HQ450H CXA2520-0000000N0HQ450F R2 2420 2741 R4 2600 2916 CXA2520-0000000N0HR450H P4 1965 2226 CXA2520-0000000N0UP450H Q2 2100 2379 Q4 2260 2560 Group Order Code Group Order Code Group CXA2520-0000000N00R265F 65F 6500 K 80 70 --- 75 65F 57F 5700 K 80 70 5000 K 80 90 --- 75 --- 95 Order Code 57F CXA2520-0000000N00R465F CXA2520-0000000N0HR265F CXA2520-0000000N00R457F CXA2520-0000000N0HR257F CXA2520-0000000N0HR457F CXA2520-0000000N00R250H 50H 50H 50H CXA2520-0000000N00R250F CXA2520-0000000N00R450H CXA2520-0000000N0HR250H CXA2520-0000000N0UQ250H CXA2520-0000000N0UQ450H 50F 50G CXA2520-0000000N0HR250G 50F CXA2520-0000000N0HR450G CXA2520-0000000N00R450F CXA2520-0000000N0HR250F CXA2520-0000000N0HR450F CXA2520-0000000N0UP450F 50G CXA2520-0000000N0UQ250G CXA2520-0000000N0UQ450G 50F CXA2520-0000000N0UQ250F CXA2520-0000000N0UQ450F Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 16). • CXA2520 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS53 REV 10A 3 XLAMP ® CXA2520 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS (IF = 550 mA, TJ = 85 °C) - CONTINUED Nominal CCT CRI Min 70 4000 K 80 90 80 Minimum Luminous Flux Typ 75 --- 95 --- 2-Step 95 4-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* R2 2420 2741 R4 2600 2916 S2 2780 3066 CXA2520-0000000N00S240H CXA2520-0000000N00S240F Q4 2260 2560 CXA2520-0000000N0HQ440H CXA2520-0000000N0HQ440F R2 2420 2741 R4 2600 2916 CXA2520-0000000N0HR440H P2 1830 2073 CXA2520-0000000N0UP240H P4 1965 2226 Q2 2100 2379 CXA2520-0000000N0UQ240H Q4 2260 2560 CXA2520-0000000N00Q435H R2 2420 2741 R4 2600 2916 CXA2520-0000000N00R435H N4 1710 1937 CXA2520-0000000N0YN435H P2 1830 2073 P4 1965 2226 Group Order Code Group Order Code Group CXA2520-0000000N00R240H 40H 40H 40H 35H 3500 K 93 3-Step 35H CXA2520-0000000N00R240F CXA2520-0000000N00R440H CXA2520-0000000N0HR240H CXA2520-0000000N0UP440H CXA2520-0000000N00R235H CXA2520-0000000N0YP235H CXA2520-0000000N0YP435H Order Code 40F 40G CXA2520-0000000N0HR240G 40F CXA2520-0000000N0HR440G CXA2520-0000000N00R440F CXA2520-0000000N0HR240F CXA2520-0000000N0HR440F CXA2520-0000000N0UP240F 40G CXA2520-0000000N0UP440G 40F CXA2520-0000000N0UQ240G CXA2520-0000000N0UP440F CXA2520-0000000N0UQ240F CXA2520-0000000N00Q435F 35G CXA2520-0000000N00R235G 35F CXA2520-0000000N00R435G CXA2520-0000000N00R235F CXA2520-0000000N00R435F CXA2520-0000000N0YN435F 35G CXA2520-0000000N0YP235G CXA2520-0000000N0YP435G 35F CXA2520-0000000N0YP235F CXA2520-0000000N0YP435F Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 16). • CXA2520 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS53 REV 10A 4 XLAMP ® CXA2520 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS (IF = 550 mA, TJ = 85 °C) - CONTINUED Nominal CCT CRI Min 80 3000 K 90 93 80 2700 K 90 93 Minimum Luminous Flux Typ --- 95 95 --- 95 95 2-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* Q2 2100 2379 Q4 2260 2535 R2 2420 2741 CXA2520-0000000N00R230H N2 1590 1801 CXA2520-0000000N0UN230H N4 1710 1937 P2 1830 2073 CXA2520-0000000N0UP230H N2 1590 1801 CXA2520-0000000N0YN230H N4 1710 1937 P2 1830 2073 CXA2520-0000000N0YP230H Q2 2100 2379 CXA2520-0000000N00Q227H Q4 2260 2535 R2 2420 2741 CXA2520-0000000N00R227H M4 1485 1682 CXA2520-0000000N0UM427H N2 1590 1801 N4 1710 1937 CXA2520-0000000N0UN427H M4 1485 1682 CXA2520-0000000N0YM427H N2 1590 1801 N4 1710 1937 Group Order Code 3-Step Group Order Code 4-Step Group CXA2520-0000000N00Q230H 30H 30H 30H 27H 27H 27H CXA2520-0000000N00Q430H CXA2520-0000000N0UN430H CXA2520-0000000N0YN430H CXA2520-0000000N00Q427H CXA2520-0000000N0UN227H CXA2520-0000000N0YN227H CXA2520-0000000N0YN427H Order Code CXA2520-0000000N00Q230F 30G CXA2520-0000000N00Q430G 30F CXA2520-0000000N00R230G CXA2520-0000000N00Q430F CXA2520-0000000N00R230F CXA2520-0000000N0UN230F 30G CXA2520-0000000N0UN430G 30F CXA2520-0000000N0UP230G CXA2520-0000000N0UN430F CXA2520-0000000N0UP230F CXA2520-0000000N0YN230F 30G CXA2520-0000000N0YN430G 30F CXA2520-0000000N0YP230G CXA2520-0000000N0YN430F CXA2520-0000000N0YP230F CXA2520-0000000N00Q227F 27G CXA2520-0000000N00Q427G 27F CXA2520-0000000N00R227G CXA2520-0000000N00Q427F CXA2520-0000000N00R227F CXA2520-0000000N0UM427F 27G CXA2520-0000000N0UN227G 27F CXA2520-0000000N0UN427G CXA2520-0000000N0UN227F CXA2520-0000000N0UN427F CXA2520-0000000N0YM427F 27G CXA2520-0000000N0YN227G CXA2520-0000000N0YN427G 27F CXA2520-0000000N0YN227F CXA2520-0000000N0YN427F Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 16). • CXA2520 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS53 REV 10A 5 XLAMP ® CXA2520 LED FLUX CHARACTERISTICS, ANSI WHITE ORDER CODES AND BINS (IF = 550 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA2520 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 14). Nominal CCT CRI Min 70 Minimum Luminous Flux Typ 75 6500 K 80 70 --- 75 5700 K 80 70 --- 75 5000 K 80 4000 K 70 --- 75 Chromaticity Regions Order Code Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* R2 2420 2741 R4 2600 2916 S2 2780 3066 CXA2520-0000-000N00S20E1 Q4 2260 2560 CXA2520-0000-000N0HQ40E1 R2 2420 2741 R4 2600 2916 CXA2520-0000-000N0HR40E1 R2 2420 2741 CXA2520-0000-000N00R20E2 R4 2600 2916 S2 2780 3066 CXA2520-0000-000N00S20E2 Q4 2260 2560 CXA2520-0000-000N0HQ40E2 R2 2420 2741 R4 2600 2916 CXA2520-0000-000N0HR40E2 R2 2420 2741 CXA2520-0000-000N00R20E3 R4 2600 2916 S2 2780 3066 CXA2520-0000-000N00S20E3 Q4 2260 2560 CXA2520-0000-000N0HQ40E3 R2 2420 2741 R4 2600 2916 CXA2520-0000-000N0HR40E3 R2 2420 2741 CXA2520-0000-000N00R20E5 R4 2600 2916 S2 2780 3066 CXA2520-0000-000N00R20E1 1A0, 1B0, 1C0, 1D0, 65F 1A0, 1B0, 1C0, 1D0, 65F 2A0, 2B0, 2C0, 2D0, 57F 2A0, 2B0, 2C0, 2D0, 57F 3A0, 3B0, 3C0, 3D0, 50F 3A0, 3B0, 3C0, 3D0, 50F 5A0, 5B0, 5C0, 5D0, 40F CXA2520-0000-000N00R40E1 CXA2520-0000-000N0HR20E1 CXA2520-0000-000N00R40E2 CXA2520-0000-000N0HR20E2 CXA2520-0000-000N00R40E3 CXA2520-0000-000N0HR20E3 CXA2520-0000-000N00R40E5 CXA2520-0000-000N00S20E5 Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 16). • CXA2520 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS53 REV 10A 6 XLAMP ® CXA2520 LED Relative Spectral Power Distribution RELATIVE SPECTRAL POWER DISTRIBUTION The following graph is the result of a series of pulsed measurements at 550 mA and TJ = 85 °C. 100% Relative Spectral Power 90% 80% 70% 60% 5000 K, 70 CRI 50% 4000 K, 70 CRI 40% 3000 K, 80 CRI 30% 3000 K, 93 CRI 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) ELECTRICAL CHARACTERISTICS The following graph is the result of a series of steady-state measurements. 39 38 Voltage (V) 37 Tc = 25 °C 36 Tc = 55 °C Tc = 85 °C 35 Tc = 105 °C 34 33 32 200 375 550 725 900 1075 1250 Current (mA) © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS53 REV 10A 7 XLAMP ® CXA2520 LED RELATIVE LUMINOUS FLUX The relative luminous flux values provided below are the ratio of: • Measurements of CXA2520 at steady-state operation at the given conditions, divided by • Flux measured during binning, which is a pulsed measurement at 550 mA at TJ = 85 °C. For example, at steady-state operation of Tc = 25 °C, IF = 725 mA, the relative luminous flux ratio is 140% in the chart below. A CXA2520 LED that measures 2100 lm during binning will deliver 3300 lm (2940 * 1.4) at steady-state operation of Tc = 25 °C, IF = 725 mA. 220% 200% Relative Luminous Flux 180% 160% 140% Tc = 25 °C 120% Tc = 55 °C 100% Tc = 85 °C Tc = 105 °C 80% 60% 40% 20% 0% 200 375 550 725 900 1075 1250 Current (mA) © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS53 REV 10A 8 XLAMP ® CXA2520 LED Far Field TYPICAL SPATIAL DISTRIBUTION 100% Relative Luminous Intensity 80% 60% 40% 20% -90 -70 -50 -30 -10 0% 10 30 50 70 90 Angle (º) PERFORMANCE GROUPS - BRIGHTNESS (I F = 550 mA, TJ = 85 °C) XLamp CXA2520 LEDs are tested for luminous flux and placed into one of the following bins. Group Code Minimum Luminous Flux Maximum Luminous Flux M4 1485 1590 N2 1590 1710 N4 1710 1830 P2 1830 1965 P4 1965 2100 Q2 2100 2260 Q4 2260 2420 R2 2420 2600 R4 2600 2780 S2 2780 2990 S4 2990 3200 © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS53 REV 10A 9 XLAMP ® CXA2520 LED PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) XLamp CXA2520 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. EasyWhite Color Temperatures – 2-Step Code 50H 40H 35H 30H 27H CCT 5000 K 4000 K 3500 K 3000 K 2700 K x y 0.3429 0.3507 0.3434 0.3571 0.3475 0.3604 0.3469 0.3539 0.3784 0.3741 0.3804 0.3818 0.3867 0.3857 0.3844 0.3778 0.4030 0.3857 0.4061 0.3941 0.4132 0.3976 0.4099 0.3890 0.4291 0.3973 0.4333 0.4062 0.4395 0.4084 0.4351 0.3994 0.4528 0.4046 0.4578 0.4138 0.4638 0.4152 0.4586 0.4060 EasyWhite Color Temperatures – 3-Step Ellipse Bin Code CCT 50G 40G Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 5000 K 0.3447 0.3553 0.00840 0.00312 65.0 4000 K 0.3818 0.3797 0.00939 0.00402 53.7 35G 3500 K 0.4073 0.3917 0.00927 0.00414 54.0 30G 3000 K 0.4338 0.4030 0.00834 0.00408 53.2 27G 2700 K 0.4577 0.4099 0.00834 0.00420 48.5 © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS53 REV 10A 10 XLAMP ® CXA2520 LED PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) - CONTINUED EasyWhite Color Temperatures – 4-Step Code 65F 57F 50F 40F 35F 30F 27F CCT 6500 K 5700 K 5000 K 4000 K 3500 K 3000 K 2700 K x y 0.3097 0.3196 0.3079 0.3297 0.3164 0.3382 0.3176 0.3275 0.3253 0.3325 0.3249 0.3439 0.3331 0.3514 0.3330 0.3393 0.3407 0.3459 0.3415 0.3586 0.3499 0.3654 0.3484 0.3521 0.3744 0.3685 0.3782 0.3837 0.3912 0.3917 0.3863 0.3758 0.3981 0.3800 0.4040 0.3966 0.4186 0.4037 0.4116 0.3865 0.4242 0.3919 0.4322 0.4096 0.4449 0.4141 0.4359 0.3960 0.4475 0.3994 0.4573 0.4178 0.4695 0.4207 0.4589 0.4021 © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS53 REV 10A 11 XLAMP ® CXA2520 LED PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) - CONTINUED ANSI White Bins Code Bin Code CCT 1A0 1B0 0E1 6500 K 1C0 1D0 ANSI White Bins x y 0.3048 0.3207 0.3130 0.3290 0.3144 0.3186 0.3068 Code x y 0.3215 0.3350 0.3290 0.3417 0.3290 0.3300 0.3113 0.3222 0.3243 0.3028 0.3304 0.3207 0.3462 0.3115 0.3391 0.3290 0.3538 0.3130 0.3290 0.3290 0.3417 0.3048 0.3207 0.3215 0.3350 0.3115 0.3391 0.3290 0.3538 0.3205 0.3481 0.3376 0.3616 0.3213 0.3373 0.3371 0.3490 0.3130 0.3290 0.3290 0.3417 0.3130 0.3290 0.3290 0.3417 0.3213 0.3373 0.3371 0.3490 0.3221 0.3261 0.3366 0.3369 0.3144 0.3186 0.3290 0.3300 2A0 2B0 0E2 5700 K 2C0 2D0 ANSI White Bins Code CCT Bin Code 3A0 3B0 0E3 5000 K 3C0 3D0 Bin Code CCT ANSI White Bins x y Code CCT Bin Code x y .3371 .3490 .3670 .3578 .3451 .3554 .3702 .3722 .3440 .3427 .3825 .3798 .3366 .3369 .3783 .3646 .3376 .3616 .3702 .3722 .3463 .3687 .3736 .3874 .3451 .3554 .3869 .3958 .3371 .3490 .3825 .3798 .3825 .3798 .3869 .3958 .4006 .4044 5A0 5B0 0E5 4000 K .3463 .3687 .3551 .3760 .3533 .3620 .3451 .3554 .3950 .3875 .3451 .3554 .3783 .3646 .3533 .3620 .3825 .3798 .3515 .3487 .3950 .3875 .3440 .3427 .3898 .3716 5C0 5D0 © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS53 REV 10A 12 XLAMP ® CXA2520 LED EASYWHITE® BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) 0.44 2700 K ANSI C78.377 Quadrangle 0.43 3000 K EasyWhite 4-Step EasyWhite 3-Step 0.42 EasyWhite 2-Step 3500 K 0.41 4000 K 0.40 4500 K CCy 0.39 5000 K 0.38 0.37 5700 K 0.36 6500 K 0.35 0.34 0.33 0.32 0.49 0.48 0.47 0.45 0.41 0.46 0.44 0.40 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.31 CCx ANSI WHITE BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) 0.41 4000 K ANSI C78.377 Quadrangle 0.40 4500 K 5C 0.39 5D 0.37 CCy 5B 5000 K 0.38 5700 K 0.36 5A 3C 3B 6500 K 0.35 2B 0.34 1C 1B 0.33 3D 2C 1D 3A 2D 2A 1A 0.32 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.31 CCx © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS53 REV 10A 13 XLAMP ® CXA2520 LED BIN AND ORDER CODE FORMATS Bin codes and order codes are configured as follows: Order Code Bin Code Series = CXA25 Series = CXA25 Internal code Chromaticity bin CRI Specification 0 = Standard CRI H = 80 CRI minimum U = 90 CRI minimum Y = 93 CRI minimum Vf class N0 = 36-V class Internal code SSSSSCC-WWW-FF-GGR-AAAAA SSSSSCC-HHHH-HHHGGRNNNNN CRI Specification B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Y = 93 CRI minimum Kit code Vf class N0 = 36-V class Flux bin Performance class Performance class MECHANICAL DIMENSIONS Dimensions are in mm. Tolerances unless otherwise specified: ±.13 x° ± 1° 2520N = 36‑V CXA2520 2520N Meaning of 2520N © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS53 REV 10A 14 XLAMP ® CXA2520 LED THERMAL DESIGN The CXA family of LED arrays can include over a hundred different LED die inside one package, and thus over a hundred different junction temperatures (TJ). Cree LED has intentionally removed junction-temperature-based operating limits and replaced the commonplace maximum TJ calculations with maximum ratings based on forward current (IF) and case temperature (Tc). No additional calculations are required to ensure that the CXA LED is being operated within its designed limits. LES temperature measurement provides additional verification of good thermal design. Please refer to page 2 for the Operating Limit specifications. There is no need to calculate for TJ inside the package, as the thermal management design process, specifically from TSP to ambient (Ta), remains identical to any other LED component. For more information on thermal management of XLamp LEDs, please refer to the Thermal Management application note. For CXA soldering recommendations and more information on thermal interface materials (TIM), LES temperature measurement, and connection methods, please refer to the XLamp CX Family LEDs soldering and handling document. The CX Family LED Design Guide provides basic information on the requirements to use XLamp CXA LEDs successfully in luminaire designs. To keep the CXA2520 LED at or below the maximum rated Tc, the case to ambient temperature thermal resistance (R_c-a) must be at or below the maximum R_c-a value shown on the following R_j-c R_j-c scale. Tc Tc As the figure at right shows, the R_c-a value is the sum of the thermal resistance of the TIM (R_tim) R_tim graph, depending on the operating environment. The y‑axis in the graph is a base 10 logarithmic R_c-a plus the thermal resistance of the heat sink (R_hs). R_hs CXA2520 Ta Ta Maximum R_c-a 100.00 10.00 Ta = 25 °C Ta = 55 °C 1.00 Ta = 85 °C Ta = 105 °C 0.10 0.01 200 375 550 725 900 1075 1250 Current (mA) © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS53 REV 10A 15 XLAMP ® CXA2520 LED NOTES Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs. Lumen Maintenance Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. REACh Compliance REACh substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative to insure you get the most up-to-date REACh Declaration. REACh banned substance information (REACh Article 67) is also available upon request. UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS53 REV 10A 16 XLAMP ® CXA2520 LED PACKAGING 6 CXA2520 LEDs are packaged5in trays of 20. Five trays are sealed in an anti-static bag and placed inside a carton, for a total of 100 LEDs 4 3 2 per carton. Each carton contains 100 LEDs from the same performance bin. NOTICE NTIAL. THIS PLOT AND THE INFORMATION THIN ARE THE PROPRIETARY AND NFORMATION OF CREE, INC. THIS PLOT PIED, REPRODUCED OR DISCLOSED TO ANY D PERSON WITHOUT THE WRITTEN CONSENT Dimensions are in inches. Tolerances: ±.13 7.125 4 5 3 x° ±1° 2 1 R .375 5 4 3 2 1 AND THE INFORMATION NSENT OPRIETARY AND F CREE, INC. THIS PLOT ED OR DISCLOSED TO ANY OUT THE WRITTEN CONSENT 1.188 5.875 R .375 7.125 R .375 7.625 .875 1.188 7.625 .38 1.188 LABEL WITH CREE BIN CODE, QUANTITY, LOT # BAG PATENT LABEL IS LOCATED ON UNDERSIDE COVER PATENT LABELOF IS LOCATED ON UNDERSIDE OF CARTON LABEL WITH CREE BIN TH CREECODE, BIN QUANTITY, LOT # .875 .38 1.188 BAG .38 ANTITY, LOT # BAG LABEL WITH CREE BIN CODE, QUANTITY, LOT # PATENT LABEL IS LOCATED ON UNDERSIDE OF COVER L IS LOCATED IDE OF COVER LABEL WITH CREE BIN CODE, QUANTITY, LOT # LABEL WITH CREE BIN CODE, QUANTITY, LOT # LABEL WITH CREE BIN CODE, QUANTITY, LOT # LABEL WITH CREE BIN CODE, QUANTITY, LOT # UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS & BEFORE FINISH. TOLERANCE UNLESS SPECIFIED: .X ± .XX ± .XXX ± X° ± THIRD ANGLE PROJECTION 6 LABEL WITH CREE BIN CODE, QUANTITY, LOT # 5 UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS & BEFORE FINISH. TOLERANCE UNLESS 3SPECIFIED: 4 .X ± .XX ± UNLESS OTHERWISE SPECIFIED .XXX ± THIRD ANGLE PROJECTION DIMENSIONS AREX°IN ± WITH CREE BIN QUANTITY, LOT # 0.1 .05 .005 1 ° DATE TITLE CXA25X SIZE FINAL PROTECTIVE FINISH SCALE DRAWING CXA25 4600 Silicon Drive Durham, N.C 27703 0.500 Phone (919) 361-4770 Fax (919) 313-5303 TITLE CXA25XX_DATASHEET 4600 Silicon Drive Durham, N.C 27703 MATERIAL DATE Phone (919) 361-4770 SIZE TITLE SCALE 2 DRAWING NO. Fax (919) 313-5303 CLD-DS53 CXA25XX_DATASHEET_BAG2013 C 17 REV 10A 0.500 CXA15XX_DATASHEET SHEET 1 SIZE FINAL PROTECTIVE FINISH C DATE DATE 3 FOR SHEET METAL PARTS ONLY .X ± .06 DATE APPROVED 2 APPROVED DRAWN BY .X ± .06 and © 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered APPROVED FINAL PROTECTIVE FINISH DATE .X ± trademarks, 0.1 ± .XX .03 ± .05 registered the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the.XXUL logo are .XXX ± .010 .XXX ± X° .005 ± 2 ° trademarks of UL LLC. THIRD ANGLE PROJECTION MATERIAL X° ± 1 ° 4 DATE MATERIAL FOR SHEET METAL PARTS ONLY .X ± .06 DATE DRAWN.XX BY ± .03 .XXX ± .010 X° ± 2 ° CHECK DATE CHECK MILLIMETERS & BEFORE FINISH. FOR SHEET METAL PARTS ONLY TOLERANCE UNLESS SPECIFIED: 5 0.1 .05 .005 1 ° DRAWN BY CHECK DRAWING NO. CXA15XX_DATASHEET_BAG2013 OF R
物料型号:XLamp® CXA2520 LED
器件简介: - Cree LED的XLamp CXA2520是一款高流量、多芯片阵列,提供易于使用的平台上的高性能。 - 具有XLamp LED照明级可靠性,CXA2520的均匀发射表面支持定向和非定向照明应用以及照明设计。
引脚分配: - 文档中未明确列出引脚分配,但提到了“top-side solder connections”,即顶部焊接连接。
参数特性: - 视场角度:115° - 静电放电耐受电压:8000V (HBM per MIL-STD-883D) - 直流正向电流:最高1250 mA - 反向电流:最高0.1 mA - 正向电压:在550 mA和85°C时典型值为35V,在25°C时典型值为42V
功能详解: - 提供了2步、3步和4步色温(CCT)和流明通量及效率选项。 - 包括EasyWhite®和ANSI白色选项,以及不同的CRI(色彩还原指数)选项。
应用信息: - 适用于照明设计,包括定向和非定向照明应用。
封装信息: - 封装尺寸和公差在文档中有详细描述。 - 热设计部分提供了关于如何保持LED在最大额定温度下运行的信息。
其他信息: - Cree LED的XLamp CXA2520 LED遵循RoHS和REACh标准,并且是UL®认可的组件。
CXA2520-0000-000N0HR440F 价格&库存
很抱歉,暂时无法提供与“CXA2520-0000-000N0HR440F”相匹配的价格&库存,您可以联系我们找货
