PRODUCT FAMILY DATA SHEET
XLamp® CXA1830 LED
PRODUCT DESCRIPTION
FEATURES
TABLE OF CONTENTS
The XLamp® CXA1830 LED array expands • Available in 4-step, 3‑step and 2-step
Characteristics................................................ 2
Cree LED’s family of high‑flux, multi‑die
EasyWhite bins at 2700 K, 3000 K,
Operating Limits.............................................. 2
arrays in a smaller, easy‑to‑use platform.
3500 K, 4000 K & 5000 K CCT and
Flux Characteristics, EasyWhite® Order
With XLamp LED lighting‑class reliability,
4-step EasyWhite bins at 5700 K &
Codes and Bins............................................... 3
the CXA1830’s small, uniform emitting
6500 K CCT
Flux Characteristics, ANSI White Order
surface enables both directional and • Available in ANSI white bins at 4000 K,
Codes and Bins............................................... 6
non‑directional
lighting
Relative Spectral Power Distribution............. 7
including
retrofit
lamp
applications
and
5000 K, 5700 K & 6500 K CCT
luminaire • Available in 70-, 80-, 90- and
designs. Available in 2‑step, 3‑step and
93‑minimum CRI options
Electrical Characteristics................................ 7
Relative Luminous Flux................................... 8
4‑step color consistency, and featuring a • Forward voltage option: 36‑V class
Typical Spatial Distribution............................. 9
14-mm optical source, the CXA1830 brings • 85 °C binning and characterization
Performance Groups - Brightness................. 9
new levels of flux and efficacy to this form
• Maximum drive current: 1400 mA
Performance Groups - Chromaticity............ 10
factor.
• 115° viewing angle, uniform
EasyWhite® Bins Plotted on the 1931 CIE
chromaticity profile
Color Space................................................... 13
The CX Family LED Design Guide provides • Top-side solder connections
ANSI White Bins Plotted on the 1931 CIE
basic information on the requirements • Thermocouple attach point
to use the CXA1830 LED successfully in • NEMA SSL-3 2011 standard flux bins
Bin and Order Code Formats........................ 14
luminaire designs.
• RoHS and REACh compliant
Mechanical Dimensions............................... 14
• UL recognized component (E349212)
Thermal Design............................................. 15
Notes............................................................. 16
Packaging...................................................... 17
Cree LED / 4400 Silicon Drive / Durham, NC 27703 USA / +1.919.313.5330 / www.cree-led.com
© 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and
the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered
trademarks of UL LLC.
CLD-DS79
REV 7A
1
XLAMP ® CXA1830 LED
CHARACTERISTICS
Characteristics
Unit
Viewing angle (FWHM)
Minimum
Typical
degrees
ESD withstand voltage (HBM per Mil-Std-883D)
Maximum
115
V
8000
DC forward current
mA
1400*
Reverse current
mA
0.1
Forward voltage (800 mA, 85 °C)
V
Forward voltage (800 mA, 25 °C)
V
36.4
42
Refer to the Operating Limits section.
OPERATING LIMITS
The maximum current rating of the CXA1830 depends on the case temperature (Tc) when the LED has reached thermal equilibrium under
steady-state operation. The graph shown below assumes that the system design employs good thermal management (thermal interface
material and heat sink) and may vary when poor thermal management is employed. Please refer to the Mechanical Dimensions section
on page 14 for the location of the Tc measurement point.
Another important factor in good thermal management is the temperature of the Light Emitting Surface (LES). Cree LED recommends a
maximum LES temperature of 135 °C to ensure optimal LED lifetime. Please refer to the Thermal Design section on page 15 for more
CXA1830
information on LES temperature measurement.
1500
1200
If (mA)
900
600
300
50
75
100
125
150
Case Temperature (°C)
the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered
CLD-DS79
REV 7A
2
XLAMP ® CXA1830 LED
FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS (IF = 800 mA, TJ = 85 °C)
The following table provides order codes for XLamp CXA1830 LEDs. For a complete description of the order code nomenclature, please
see the Bin and Order Code Formats section (page 14).
Nominal
CCT
CRI
Min
70
Minimum Luminous Flux
Typ
75
6500 K
80
70
70
5000 K
80
90
3-Step
75
Flux (lm)
@ 85 °C
Flux (lm)
@ 25 °C*
T4
3440
3887
U2
3680
4158
U4
3955
4424
CXA1830-0000000N00U465F
T4
3440
3887
CXA1830-0000000N0HT465F
U2
3680
4158
CXA1830-0000000N0HU265F
T4
3440
3887
CXA1830-0000000N00T457F
U2
3680
4158
U4
3955
4424
CXA1830-0000000N00U457F
T4
3440
3887
CXA1830-0000000N0HT457F
U2
3680
4158
T4
3440
3887
U2
3680
4158
U4
3955
4424
CXA1830-0000000N00U450H
CXA1830-0000000N00U450F
T2
3200
3616
CXA1830-0000000N0HT250H
CXA1830-0000000N0HT250F
T4
3440
3887
U2
3680
4158
CXA1830-0000000N0HU250H
CXA1830-0000000N0HU250G
CXA1830-0000000N0HU250F
R4
2600
2938
CXA1830-0000000N0UR450H
CXA1830-0000000N0UR450G
CXA1830-0000000N0UR450F
S2
2780
3141
S4
2990
3379
Group
Order Code
Group
Order Code
95
Group
Order Code
CXA1830-0000000N00T465F
65F
65F
57F
75
4-Step
Group
5700 K
80
2-Step
57F
CXA1830-0000000N00T450H
50H
50H
50H
CXA1830-0000000N0US250H
CXA1830-0000000N0US450H
CXA1830-0000000N00U257F
CXA1830-0000000N0HU257F
CXA1830-0000000N00T450F
CXA1830-0000000N00U250H
CXA1830-0000000N0HT450H
CXA1830-0000000N00U265F
50F
50G
50G
CXA1830-0000000N0HT450G
CXA1830-0000000N0US250G
CXA1830-0000000N0US450G
50F
50F
CXA1830-0000000N00U250F
CXA1830-0000000N0HT450F
CXA1830-0000000N0US250F
CXA1830-0000000N0US450F
Notes
Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on
CRI measurements. See the Measurements section (page 16).
CXA1830 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum
specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code.
Flux values @ 25 °C are calculated and for reference only.
CLD-DS79
REV 7A
3
XLAMP ® CXA1830 LED
FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS (IF = 800 mA, TJ = 85 °C) - CONTINUED
Nominal
CCT
CRI
Min
70
4000 K
80
90
80
Typ
75
95
2-Step
80
95
Flux (lm)
@ 85 °C
Flux (lm)
@ 25 °C*
T4
3440
3887
U2
3680
4158
U4
3955
4424
CXA1830-0000000N00U440H
CXA1830-0000000N00U440F
T2
3200
3616
CXA1830-0000000N0HT240H
CXA1830-0000000N0HT240F
T4
3440
3887
U2
3680
4158
CXA1830-0000000N0HU240H
R4
2600
2938
CXA1830-0000000N0UR440H
S2
2780
3141
S4
2990
3379
CXA1830-0000000N0US440H
S4
2990
3379
CXA1830-0000000N00S435H
T2
3200
3616
T4
3440
3887
CXA1830-0000000N00T435H
R2
2420
2735
CXA1830-0000000N0YR235H
R4
2600
2938
S2
2780
3141
CXA1830-0000000N0YS235H
S4
2990
3379
CXA1830-0000000N00S430H
T2
3200
3616
T4
3440
3887
CXA1830-0000000N00T430H
Q4
2260
2554
CXA1830-0000000N0YQ430H
R2
2420
2735
R4
2600
2938
Group
95
Order Code
Group
Order Code
Group
CXA1830-0000000N00T440H
40H
40H
40H
35H
35H
30H
3000 K
93
4-Step
Group
3500 K
93
3-Step
30H
CXA1830-0000000N00T440F
CXA1830-0000000N00U240H
CXA1830-0000000N0HT440H
CXA1830-0000000N0US240H
CXA1830-0000000N00T235H
CXA1830-0000000N0YR435H
CXA1830-0000000N00T230H
CXA1830-0000000N0YR230H
CXA1830-0000000N0YR430H
Order Code
40F
40G
CXA1830-0000000N0HT440G
40F
CXA1830-0000000N0HU240G
CXA1830-0000000N00U240F
CXA1830-0000000N0HT440F
CXA1830-0000000N0HU240F
CXA1830-0000000N0UR440F
40G
CXA1830-0000000N0US240G
40F
CXA1830-0000000N0US440G
CXA1830-0000000N0US240F
CXA1830-0000000N0US440F
CXA1830-0000000N00S435F
35G
CXA1830-0000000N00T235G
35F
CXA1830-0000000N00T435G
CXA1830-0000000N00T235F
CXA1830-0000000N00T435F
CXA1830-0000000N0YR235F
35G
CXA1830-0000000N0YR435G
35F
CXA1830-0000000N0YS235G
CXA1830-0000000N0YR435F
CXA1830-0000000N0YS235F
CXA1830-0000000N00S430F
30G
CXA1830-0000000N00T230G
30F
CXA1830-0000000N00T430G
CXA1830-0000000N00T230F
CXA1830-0000000N00T430F
CXA1830-0000000N0YQ430F
30G
CXA1830-0000000N0YR230G
CXA1830-0000000N0YR430G
30F
CXA1830-0000000N0YR230F
CXA1830-0000000N0YR430F
Notes
CLD-DS79
REV 7A
4
XLAMP ® CXA1830 LED
Nominal
CCT
CRI
Min
80
Typ
2-Step
Group
Flux (lm)
@ 85 °C
Flux (lm)
@ 25 °C*
S2
2780
3141
S4
2990
3379
T2
3200
3616
CXA1830-0000000N00T227H
Q2
2100
2373
CXA1830-0000000N0YQ227H
Q4
2260
2554
R2
2420
2735
Group
95
Group
Order Code
4-Step
Group
CXA1830-0000000N00S227H
27H
2700 K
93
Order Code
3-Step
27H
CXA1830-0000000N00S427H
CXA1830-0000000N0YQ427H
CXA1830-0000000N0YR227H
Order Code
CXA1830-0000000N00S227F
27G
CXA1830-0000000N00S427G
27F
CXA1830-0000000N00T227G
CXA1830-0000000N00S427F
CXA1830-0000000N00T227F
CXA1830-0000000N0YQ227F
27G
CXA1830-0000000N0YQ427G
CXA1830-0000000N0YR227G
27F
CXA1830-0000000N0YQ427F
CXA1830-0000000N0YR227F
Notes
CLD-DS79
REV 7A
5
XLAMP ® CXA1830 LED
FLUX CHARACTERISTICS, ANSI WHITE ORDER CODES AND BINS (IF = 800 mA, TJ = 85 °C)
Nominal
CCT
CRI
Min
70
Typ
75
6500 K
80
70
75
5700 K
80
70
75
5000 K
80
4000 K
70
75
Chromaticity Regions
Order Code
Group
Flux (lm)
@ 85 °C
Flux (lm)
@ 25 °C*
T4
3440
3887
U2
3680
4158
U4
3955
4424
T4
3440
3887
U2
3680
4158
T4
3440
3887
U2
3680
4158
U4
3955
4424
T4
3440
3887
U2
3680
4158
T4
3440
3887
U2
3680
4158
U4
3955
4424
CXA1830-0000-000N00U40E3
T2
3200
3616
CXA1830-0000-000N0HT20E3
T4
3440
3887
U2
3680
4158
CXA1830-0000-000N0HU20E3
T4
3440
3887
CXA1830-0000-000N00T40E5
U2
3680
4158
U4
3955
4424
CXA1830-0000-000N00T40E1
1A0, 1B0, 1C0, 1D0, 65F
CXA1830-0000-000N00U20E1
CXA1830-0000-000N00U40E1
CXA1830-0000-000N0HT40E1
CXA1830-0000-000N0HU20E1
CXA1830-0000-000N00T40E2
2A0, 2B0, 2C0, 2D0, 57F
CXA1830-0000-000N00U20E2
CXA1830-0000-000N00U40E2
CXA1830-0000-000N0HT40E2
CXA1830-0000-000N0HU20E2
CXA1830-0000-000N00T40E3
3A0, 3B0, 3C0, 3D0, 50F
5A0, 5B0, 5C0, 5D0, 40F
CXA1830-0000-000N00U20E3
CXA1830-0000-000N0HT40E3
CXA1830-0000-000N00U20E5
CXA1830-0000-000N00U40E5
Notes
CLD-DS79
REV 7A
6
XLAMP ® CXA1830 LED
RELATIVE SPECTRAL POWER DISTRIBUTION
The following graph is the result of a series of pulsed measurements at 800 mA and TJ = 85 °C.
100%
90%
80%
70%
60%
5000 K, 70 CRI
50%
4000 K, 70 CRI
40%
3000 K, 80 CRI
30%
3000 K, 93 CRI
20%
10%
0%
380
430
480
530
580
630
680
730
780
Wavelength (nm)
ELECTRICAL CHARACTERISTICS
The following graph is the result of a series of steady-state measurements.
41
40
Voltage (V)
39
38
Tc = 25 °C
Tc = 55 °C
37
Tc = 85 °C
36
Tc = 105 °C
35
34
33
400
500
600
700
800
900
1000
1100
1200
1300
1400
Current (mA)
CLD-DS79
REV 7A
7
XLAMP ® CXA1830 LED
RELATIVE LUMINOUS FLUX
The relative luminous flux values provided below are the ratio of:
• Measurements of CXA1830 at steady-state operation at the given conditions, divided by
• Flux measured during binning, which is a pulsed measurement at 800 mA at TJ = 85 °C.
For example, at steady-state operation of Tc = 25 °C, IF = 1100 mA, the relative luminous flux ratio is 140% in the chart below. A CXA1830
LED that measures 2100 lm during binning will deliver 2940 lm (2100 * 1.4) at steady-state operation of Tc = 25 °C, IF = 1100 mA.
180%
160%
140%
120%
Tc = 25 °C
100%
Tc = 55 °C
80%
Tc = 85 °C
Tc = 105 °C
60%
40%
20%
0%
400
500
600
700
800
900
1000
1100
1200
1300
1400
Current (mA)
CLD-DS79
REV 7A
8
XLAMP ® CXA1830 LED
Far Field
TYPICAL SPATIAL DISTRIBUTION
100%
Relative Luminous Intensity
80%
60%
40%
20%
-90
-70
-50
-30
-10
0%
10
30
50
70
90
Angle (º)
PERFORMANCE GROUPS - BRIGHTNESS (I F = 800 mA, TJ = 85 °C)
XLamp CXA1830 LEDs are tested for luminous flux and placed into one of the following bins.
Group Code
Maximum Luminous Flux
Q2
2100
2260
Q4
2260
2420
R2
2420
2600
R4
2600
2780
S2
2780
2990
S4
2990
3200
T2
3200
3440
T4
3440
3680
U2
3680
3955
U4
3955
4230
V2
4230
4545
CLD-DS79
REV 7A
9
XLAMP ® CXA1830 LED
PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C)
XLamp CXA1830 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates.
EasyWhite Color Temperatures – 2-Step
Code
50H
40H
35H
30H
27H
CCT
5000 K
4000 K
3500 K
3000 K
2700 K
x
y
0.3429
0.3507
0.3434
0.3571
0.3475
0.3604
0.3469
0.3539
0.3784
0.3741
0.3804
0.3818
0.3867
0.3857
0.3844
0.3778
0.4030
0.3857
0.4061
0.3941
0.4132
0.3976
0.4099
0.3890
0.4291
0.3973
0.4333
0.4062
0.4395
0.4084
0.4351
0.3994
0.4528
0.4046
0.4578
0.4138
0.4638
0.4152
0.4586
0.4060
EasyWhite Color Temperatures – 3-Step Ellipse
Bin Code
CCT
50G
40G
Center Point
Major Axis
Minor Axis
Rotation Angle
x
y
a
b
5000 K
0.3447
0.3553
0.00840
0.00312
65.0
4000 K
0.3818
0.3797
0.00939
0.00402
53.7
35G
3500 K
0.4073
0.3917
0.00927
0.00414
54.0
30G
3000 K
0.4338
0.4030
0.00834
0.00408
53.2
27G
2700 K
0.4577
0.4099
0.00834
0.00420
48.5
CLD-DS79
REV 7A
10
XLAMP ® CXA1830 LED
PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) - CONTINUED
EasyWhite Color Temperatures – 4-Step
Code
65F
57F
50F
40F
35F
30F
27F
CCT
6500 K
5700 K
5000 K
4000 K
3500 K
3000 K
2700 K
x
y
0.3097
0.3196
0.3079
0.3297
0.3164
0.3382
0.3176
0.3275
0.3253
0.3325
0.3249
0.3439
0.3331
0.3514
0.3330
0.3393
0.3407
0.3459
0.3415
0.3586
0.3499
0.3654
0.3484
0.3521
0.3744
0.3685
0.3782
0.3837
0.3912
0.3917
0.3863
0.3758
0.3981
0.3800
0.4040
0.3966
0.4186
0.4037
0.4116
0.3865
0.4242
0.3919
0.4322
0.4096
0.4449
0.4141
0.4359
0.3960
0.4475
0.3994
0.4573
0.4178
0.4695
0.4207
0.4589
0.4021
CLD-DS79
REV 7A
11
XLAMP ® CXA1830 LED
ANSI White Bins
Code
Bin
Code
CCT
1A0
1B0
0E1
6500 K
1C0
1D0
ANSI White Bins
x
y
0.3048
0.3207
0.3130
0.3290
0.3144
0.3186
0.3068
Code
x
y
0.3215
0.3350
0.3290
0.3417
0.3290
0.3300
0.3113
0.3222
0.3243
0.3028
0.3304
0.3207
0.3462
0.3115
0.3391
0.3290
0.3538
0.3130
0.3290
0.3290
0.3417
0.3048
0.3207
0.3215
0.3350
0.3115
0.3391
0.3290
0.3538
0.3205
0.3481
0.3376
0.3616
0.3213
0.3373
0.3371
0.3490
0.3130
0.3290
0.3290
0.3417
0.3130
0.3290
0.3290
0.3417
0.3213
0.3373
0.3371
0.3490
0.3221
0.3261
0.3366
0.3369
0.3144
0.3186
0.3290
0.3300
2A0
2B0
0E2
5700 K
2C0
2D0
ANSI White Bins
Code
CCT
Bin
Code
3A0
3B0
0E3
5000 K
3C0
3D0
Bin
Code
CCT
ANSI White Bins
x
y
Code
CCT
Bin
Code
x
y
.3371
.3490
.3670
.3578
.3451
.3554
.3702
.3722
.3440
.3427
.3825
.3798
.3366
.3369
.3783
.3646
.3376
.3616
.3702
.3722
.3463
.3687
.3736
.3874
.3451
.3554
.3869
.3958
.3371
.3490
.3825
.3798
.3825
.3798
.3869
.3958
.4006
.4044
5A0
5B0
0E5
4000 K
.3463
.3687
.3551
.3760
.3533
.3620
.3451
.3554
.3950
.3875
.3451
.3554
.3783
.3646
.3533
.3620
.3825
.3798
.3515
.3487
.3950
.3875
.3440
.3427
.3898
.3716
5C0
5D0
CLD-DS79
REV 7A
12
XLAMP ® CXA1830 LED
EASYWHITE® BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C)
0.44
2700 K
ANSI C78.377 Quadrangle
0.43
3000 K
EasyWhite 4-Step
EasyWhite 3-Step
0.42
EasyWhite 2-Step
3500 K
0.41
4000 K
0.40
4500 K
CCy
0.39
5000 K
0.38
0.37
5700 K
0.36
6500 K
0.35
0.34
0.33
0.32
0.49
0.48
0.47
0.45
0.41
0.46
0.44
0.40
0.43
0.42
0.41
0.40
0.39
0.38
0.37
0.36
0.35
0.34
0.33
0.32
0.31
0.30
0.31
CCx
ANSI WHITE BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C)
0.41
4000 K
0.40
4500 K
5C
0.39
5D
0.37
CCy
5B
5000 K
0.38
5700 K
0.36
5A
3C
3B
6500 K
0.35
2B
0.34
1C
1B
0.33
3D
2C
1D
3A
2D
2A
1A
0.32
0.39
0.38
0.37
0.36
0.35
0.34
0.33
0.32
0.31
0.30
0.31
CCx
CLD-DS79
REV 7A
13
XLAMP ® CXA1830 LED
BIN AND ORDER CODE FORMATS
Bin codes and order codes are configured as follows:
Order Code
Bin Code
Series = CXA18
Series = CXA18
Internal code
Chromaticity bin
CRI Specification
0 = Standard CRI
H = 80 CRI minimum
U = 90 CRI minimum
Y = 93 CRI minimum
Vf class
N0 = 36-V class
Internal code
SSSSSCC-WWW-FF-GGR-AAAAA
CRI Specification
B = 70 CRI minimum
H = 80 CRI minimum
U = 90 CRI minimum
Y = 93 CRI minimum
SSSSSCC-HHHH-HHHGGRNNNNN
Kit code
Vf class
N0 = 36-V class
Flux bin
Performance class
Performance class
MECHANICAL DIMENSIONS
Dimensions are in mm.
Tolerances unless otherwise
specified: +.13
x° +1°
1830N = 36‑V CXA1830
1830N
Meaning of 1830N
CLD-DS79
REV 7A
14
XLAMP ® CXA1830 LED
THERMAL DESIGN
The CXA family of LED arrays can include over a hundred different LED die inside one package, and thus over a hundred different junction
temperatures (TJ). Cree LED has intentionally removed junction-temperature-based operating limits and replaced the commonplace
maximum TJ calculations with maximum ratings based on forward current (IF) and case temperature (Tc). No additional calculations
are required to ensure that the CXA LED is being operated within its designed limits. LES temperature measurement provides additional
verification of good thermal design. Please refer to page 2 for the Operating Limit specifications.
There is no need to calculate for TJ inside the package, as the thermal management design process, specifically from TSP to ambient (Ta),
remains identical to any other LED component. For more information on thermal management of XLamp LEDs, please refer to the Thermal
Management application note. For CXA soldering recommendations and more information on thermal interface materials (TIM), LES
temperature measurement, and connection methods, please refer to the XLamp CX Family LEDs soldering and handling document. The
CX Family LED Design Guide provides basic information on the requirements to use XLamp CXA LEDs successfully in luminaire designs.
To keep the CXA1830 LED at or below the maximum rated Tc, the case to ambient temperature
thermal resistance (R_c-a) must be at or below the maximum R_c-a value shown on the following
R_j-c
R_j-c
scale.
Tc
Tc
As the figure at right shows, the R_c-a value is the sum of the thermal resistance of the TIM (R_tim)
R_tim
graph, depending on the operating environment. The y‑axis in the graph is a base 10 logarithmic
R_c-a
plus the thermal resistance of the heat sink (R_hs).
R_hs
CXA1830
Ta
Ta
100.00
Maximum R_c-a
10.00
Ta = 25 °C
Ta = 55 °C
1.00
Ta = 85 °C
Ta = 105 °C
0.10
0.01
400
500
600
700
800
900
1000
1100
1200
1300
1400
Current (mA)
CLD-DS79
REV 7A
15
XLAMP ® CXA1830 LED
NOTES
Measurements
The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only
and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number
of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated
values are provided for informational purposes only and are not intended or provided as specifications.
Pre‑Release Qualification Testing
Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp
LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs.
Lumen Maintenance
Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen
maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document.
Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and
forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive
current affect the LED junction temperature.
RoHS Compliance
The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold
limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as
implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product
Ecology section of the Cree LED website.
REACh Compliance
REACh substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA)
has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative
to insure you get the most up-to-date REACh Declaration. REACh banned substance information (REACh Article 67) is also available upon
request.
UL® Recognized Component
This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED
package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750.
Vision Advisory
WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please
refer to the LED Eye Safety application note.
CLD-DS79
REV 7A
16
XLAMP ® CXA1830 LED
PACKAGING
CXA1830 LEDs are packaged in trays of 20. Five trays are sealed in an anti-static bag and placed inside a carton, for a total of 100 LEDs
per carton. Each carton contains 100 LEDs from the same performance bin.
REV
5
7.875
6
4
3
5
R.375
4
NOTICE
FIDENTIAL. THIS PLOT AND THE INFORMATION
D WITHIN ARE THE PROPRIETARY AND
TIAL
INFORMATION OF CREE, INC. THIS PLOT
NSENT
E COPIED, REPRODUCED OR DISCLOSED TO ANY
IZED PERSON WITHOUTTHE WRITTEN CONSENT
C.
Dimensions are in inches.
DESC.
DATE
BY
CHK.
Tolerances: +.13
x° +1°
2
3
1
2
1
.75
5.875
5.875
R .375
1.125
R.375
7.125
.875
.875
5.875
.38
1.125
.38
.75
PATENT LABEL IS LOCATED
WITH CREE
ON LABEL
UNDERSIDE
OF CARTON
BIN CODE, QTY, LOT#
SECTION C-C
.19
.38
.875
.38
PATENT
TH CREE BIN
.875LABEL
ANTITY, LOTIS# LOCATED ON UNDERSIDE OF
CARTON
BAG
DO NOT
SCALE DWG.
L IS LOCATED
IDE OF COVER
UNLESS OTHERWISE NOTED ALL
TOLERANCES ARE AS FOLLOWS:
FRACT ±1/64 X.X" ±.030 X.0mm ±.75mm
ANGLES ±0°-30' X.XX" ±.015 X.Xmm ±.30mm
DRAFT ±1°
X.XXX" ±.005 X.XXmm ±.10mm
PART DRAWING
DATE:
DR. BY:
CHK. BY:
4-3-13
KJS
SCALE: 0.750
SIZE
B
DWG. NO.
022489-00
SHEET 2 OF 2
LABEL WITH CREE
BIN CODE, QTY, LOT#
LABEL WITH CREE BIN
CODE, QUANTITY, LOT #
LABEL WITH CREE BIN
UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN
MILLIMETERS & BEFORE FINISH.
TOLERANCE UNLESS SPECIFIED:
LABEL WITH CREE
BIN CODE, QTY, LOT#
THIRD ANGLE PROJECTION
WITH CREE
BIN
6
QUANTITY, LOT #
BAG
THIS DRAWING CONTAINS PROPRIETARY DESIGN INFORMATION
AND REMAINS ALONG WITH THE PRODUCT OR PRODUCTS
REPRESENTED HEREIN THE PROPERTY OF TEK PAK, INCORPORATED.
THIS DOCUMENT AND THE INFORMATION IT CONTAINS
DWG.TITLE
MAY NOT BE COPIED, TRANSMITTED, OR USED BY ANY
THIRD PARTY WITHOUT THE EXPRESS WRITTEN APPROVAL
.X
.XX ±
.XXX ±
X°
0.1
.05
.005
1°
FOR SHEET METAL PARTS ONLY
.X
.06
.XX ±
.03
.XXX ±
.010
DRAWN BY
X°
2
5
4
DIMENSIONS
ARE IN
3
CHECK
and
APPROVED
.X
± trademarks,
0.1
.05 registered
the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the.XXUL logo
are
.XXX ± .005
MATERIAL
X°
1 °
.X
.06
DRAWN BY
DATE
CHECK
DATE
APPROVED
DATE
Phone (919) 361
Fax (919) 313-5
TITLE
CXA15XX_DATASHEET
MATERIAL
SIZE
FINAL PROTECTIVE FINISH
SCALE
DATE
DATE
C
DRAWING NO.
CXA15XX_DATASHEET_BAG2013
SHEET
0.500
OF
4600 Silicon Drive
1 27703
Durham, N.C
2
Phone (919) 361-4770
DATE
TITLE
CLD-DS79
REV 7A
17
Fax (919) 313-5303
CXA15XX_DATASHEET
SIZE
4600 Silicon Dri
Durham, N.C 27
DRAWING NO.
