GWKAGJB3.EM-SRSS-27S3 数据手册
2016-04-21
SOLERIQ® S 13
Datasheet
Version 1.2
GW KAGJB3.EM
The SOLERIQ® S products are specifically designed
for applications that require large flux packages out of
a compact area. With TEN° binning, SOLERIQ ® S 13
is now available with unparalleled color consistency.
Die SOLERIQ® S Produkte wurden speziell für
Anwendungen entwickelt, die großen Lichtstrom aus
einer kompakten Fläche benötigen. Mit TEN° binning
ist SOLERIQ® S 13 jetzt in unerreichter
Farbkonsistenz erhältlich.
Features:
Package: Chip-on-Board
Viewing angle at 50 % IV: 120°
Color: 2700 K - 6500 K (white)
CRI: min. 80
Luminous Flux:
typ. 2325 lm @ 3000 K, 85 °C, 500mA
typ. 1710 lm @ 3000 K, 85 °C, 350mA
Besondere Merkmale:
Gehäusetyp: Chip-on-Board
Abstrahlwinkel bei 50 % IV: 120°
Farbe: 2700 K - 6500 K (weiß)
CRI: min. 80
Lichtstrom:
Luminous efficacy:
typ. 134 lm/W @ 3000 K, 85 °C, 500mA
typ. 145 lm/W @ 3000 K, 85 °C, 350mA
Applications
Downlights
Spot lights
Indoor General Lighting
Museum lighting
2016-04-21
Lichtausbeute:
Anwendungen
Downlights
Spot-Leuchten
Innen-Allgemeinbeleuchtung
Museumsbeleuchtung
1
Version 1.2
GW KAGJB3.EM
Ordering Information
Bestellinformation
Type:
Typ:
Color
Temperature
Luminous Flux
Farbtemperatur
Lichtstrom
Ordering Code
1) page 18
Bestellnummer
1) Seite 18
IF = 500 mA, TJ =
85 °C
[K]
ΦV [lm]
GW KAGJB3.EM-SRSS-27S3
2700
2100 ... 2400
Q65111A9597
GW KAGJB3.EM-SRSS-30S3
3000
2240 ... 2590
Q65111A9596
GW KAGJB3.EM-SRSS-35S3
3500
2240 ... 2590
Q65111A9595
GW KAGJB3.EM-SSST-40S3
4000
2240 ... 2590
Q65111A9594
GW KAGJB3.EM-SSST-50S3
5000
2240 ... 2590
Q65111A9608
GW KAGJB3.EM-SSST-57S3
5700
2240 ... 2590
Q65111A9607
GW KAGJB3.EM-SSST-65S3
6500
2240 ... 2590
Q65111A9606
Note:
The above Type Numbers represent the order groups which include only a few brightness groups (see page 5). Only one group will
be shipped on each packing unit (there will be no mixing of two groups on each packing unit). E. g. GW KAGJB3.EM-SRSS-30S3
means that only one group SS, ST will be shippable for any packing unit.
Anm.:
Die oben genannten Typbezeichnungen umfassen die bestellbaren Selektionen. Diese bestehen aus wenigen Helligkeitsgruppen
(siehe Seite 5). Es wird nur eine einzige Helligkeitsgruppe pro Verpackungseinheit geliefert. Z. B. GW KAGJB3.EM-SRSS-30S3
bedeutet, dass in einer Verpackungseinheit nur eine der Helligkeitsgruppen SS, ST enhalten ist.
2016-04-21
2
Version 1.2
GW KAGJB3.EM
Maximum Ratings
Grenzwerte
Parameter
Symbol
Values
Unit
Bezeichnung
Symbol
Werte
Einheit
Operating temperature range
Betriebstemperatur
Top
-40 ... 105
°C
Storage temperature range
Lagertemperatur
Tstg
-40 ... 100
°C
Junction temperature
Sperrschichttemperatur
Tj
125
°C
Forward current
Durchlassstrom
(TS = 85 °C)
IF
50 ... 1150
mA
Reverse current
Sperrstrom
IR
mA
2
kV
ESD withstand voltage
VESD
ESD Festigkeit
(acc. to ANSI/ESDA/JEDEC JS-001 - HBM, Class 2)
2016-04-21
3
Version 1.2
GW KAGJB3.EM
Characteristics (TS = 85 °C; IF = 500 mA)
Kennwerte
Parameter
Symbol
Values
Unit
Bezeichnung
Symbol
Werte
Einheit
(typ.)
2ϕ
120
Forward voltage
Durchlassspannung
(min.)
(typ.)
(max.)
VF
VF
VF
33
34.7
37
V
V
V
Color rendering index 2) page 18
Farbwiedergabe Index 2) Seite 18
(2700K - 6500K)
(min.)
Ra
80
Real thermal resistance junction / solder point
(typ.)
(max.)
Rth JS real
Rth JS real
3) page 18
0.83
1.31
K/W
K/W
0.5
0.8
K/W
K/W
Realer Wärmewiderstand Sperrschicht / Lötpad
3) Seite 18
"Electrical" thermal resistance junction / solder point (typ.)
3) page 18
(max.)
"Elektrischer" Wärmewiderstand Sperrschicht /
Lötpad 3) Seite 18
(with efficiency ηe = 39 %)
2016-04-21
4
Rth JS el
Rth JS el
Version 1.2
GW KAGJB3.EM
Brightness Groups
Helligkeitsgruppen
Group
Luminous Flux 1) page 18
Luminous Intensity
4) page 18
Lichtstrom 1) Seite 18
Lichtstärke 4) Seite 18
(min.) ΦV [lm]
(max.) ΦV [lm]
(typ.) IV [cd]
SR
2100
2240
690.6
SS
2240
2400
738.4
ST
2400
2590
794.1
Gruppe
2016-04-21
5
Version 1.2
GW KAGJB3.EM
Chromaticity Coordinate Groups 5) page 18 , 6) page 18
Farbortgruppen 5) Seite 18 , 6) Seite 18
Group
Cx
Cy
a
b
Θ
65S3
0.3131
0.3281
0.0066
0.0027
58
57S3
0.3292
0.3412
0.0071
0.0031
59
50S3
0.3450
0.3547
0.0081
0.0035
60
40S3
0.3823
0.3790
0.0094
0.0040
53
35S3
0.4077
0.3908
0.0093
0.0041
53
30S3
0.4339
0.4020
0.0085
0.0041
53
27S3
0.4578
0.4092
0.0079
0.0041
54
2016-04-21
6
Version 1.2
GW KAGJB3.EM
Color Chromaticity Groups 5) page 18 , 6) page 18
Note: TEN° binning offers superb color consistency by screening with CIE 2015 10º (u’F,10 v’F,10)
Observer in addition to conventional binning with CIE 1931. This ensures compliance to industry
standards.
Anm: TEN° binning bietet eine hervorragende Farbtreue durch das konventionelle CIE 1931 2°
Binning und die zusätzliche Überprüfung im CIE 2015 10° Farbraum. Gleichzeitig erfüllt es industrielle
Standards.
2016-04-21
7
Version 1.2
GW KAGJB3.EM
Group Name on Label
Gruppenbezeichnung auf Etikett
Example: SS-30S3
Beispiel: SS-30S3
Brightness
Helligkeit
Farbort
SS
30S3
Note:
No packing unit / tape ever contains more than one group for each selection.
Anm.:
In einer Verpackungseinheit / Gurt ist immer nur eine Gruppe für jede Selektion enthalten.
2016-04-21
8
Version 1.2
GW KAGJB3.EM
Relative Spectral Emission - V(λ) = Standard eye response curve 4) page 18
Relative spektrale Emission - V(λ) = spektrale Augenempfindlichkeit 4) Seite 18
Φrel = f (λ); TS = 85 °C; IF = 500 mA
Irel
GW KAGJB3.EM
1,0
: Vλ
0,8
0,6
0,4
0,2
0,0
350
400
450
500
550
600
650
700
750
800
λ [nm]
Radiation Characteristics 4) page 18
Abstrahlcharakteristik 4) Seite 18
Irel = f (ϕ); TS = 85 °C
GW KAGJB3.EM
ϕ [°]
-10°
0°
10°
-20°
20°
30°
40°
50°
60°
70°
80°
90°
1,0
-30°
-40°
0,8
-50°
0,6
-60°
0,4
-70°
0,2
-80°
-90°
0,0
-100°
2016-04-21
9
Irel
Version 1.2
GW KAGJB3.EM
Forward Current 4) page 18 , 7) page 18
Durchlassstrom 4) Seite 18 , 7) Seite 18
IF = f (VF); TS = 85 °C
IF [mA]
Relative Luminous Flux 4) page 18 , 7) page 18
Relativer Lichtstrom 4) Seite 18 , 7) Seite 18
ΦV/ΦV(500 mA) = f(IF); TS = 85 °C
ΦV
GW KAGJB3.EM
1150
GW KAGJB3.EM
2,0
ΦV(500mA)
1000
1,5
800
1,0
600
400
0,5
200
0,0
50
31
32
34
36
50
38
VF [V]
GW KAGJB3.EM
0,03
: ∆ Cx : ∆ Cy -
0,02
0,01
0,00
-0,01
-0,02
-0,03
50
00 150
10
1
IF [mA]
2016-04-21
00 150
1
10
IF [mA]
Chromaticity Coordinate Shift 4) page 18
Farbortverschiebung 4) Seite 18
ΔCx, ΔCy = f(IF); TS = 85 °C
∆Cx
∆Cy
Version 1.2
GW KAGJB3.EM
ΦV/ΦV(85 °C) = f(Tj); IF = 500 mA
Relative Forward Voltage 4) page 18
Relative Vorwärtsspannung 4) Seite 18
ΔVF = VF - VF(85 °C) = f(Tj); IF = 500 mA
∆V
F
[V]
GW KAGJB3.EM
GW KAGJB3.EM
Φ
Φ (85°C)
v
2,5
v
1,2
2,0
1,5
1,0
1,0
0,8
0,5
0,6
0,0
-0,5
-40
-20
60
80
100
T
j
0,4
-40
120
[°C]
GW KAGJB3.EM
0,02
: Cx : Cy 0,01
0,00
-0,01
-0,02
-40
-20
60
80
100
T
2016-04-21
j
60
80
100
T
ΔCx, ΔCy = f(Tj); IF = 500 mA
∆Cx
∆Cy
-20
120
[°C]
11
j
120
[°C]
Version 1.2
GW KAGJB3.EM
Max. Permissible Forward Current
Max. zulässiger Durchlassstrom
IF = f (T)
IF [mA]
GW KAGJB3.EM
1300
1200
1100
1000
900
800
700
600
500
400
300
200
100
60
80
100
Ts [°C]
2016-04-21
12
Version 1.2
GW KAGJB3.EM
Package Outline 8) page 18
Maßzeichnung 8) Seite 18
Approximate Weight:
1.78 g
Gewicht:
1.78 g
2016-04-21
13
Version 1.2
GW KAGJB3.EM
Tray
Bauteilträger
Min. 96 pcs. per packing unit (48 units per tray, min. 2 trays per vacuum bag) / 48 Teile pro Bauteilträger,
2 Bauteilträger pro Vakuumverpackung
Barcode-Product-Label (BPL)
Barcode-Produkt-Etikett (BPL)
OSRAM Opto
EX
AM
P
RoHS Compliant
(6P) BATCH NO: 1234567890
(1T) LOT NO: 1234567890
BIN1: XX-XX-X-XXX-X
LX XXXX
Semiconductors
ML Temp ST
X XXX °C X
(9D) D/C: 1234
Pack: RXX
LE
DEMY
XXX
X_X123_1234.1234 X
(X) PROD NO: 123456789(Q)QTY:
9999
(G) GROUP:
XX-XX-X-X
OHA04563
Note:
Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card.
Regarding dry pack you will find further information in the internet and in the Short Form Catalog in chapter “Tape and Reel” under the topic “Dry
Pack”. Here you will also find the normative references like JEDEC.
Anm.:
Feuchteempfindliche Produkte sind verpackt in einem Trockenbeutel zusammen mit einem Trockenmittel und einer Feuchteindikatorkarte.
Bezüglich Trockenverpackung finden Sie weitere Hinweise im Internet und in unserem Short Form Catalog im Kapitel “Gurtung und Verpackung”
unter dem Punkt “Trockenverpackung”. Hier sind Normenbezüge, unter anderem ein Auszug der JEDEC-Norm, enthalten.
2016-04-21
14
Version 1.2
GW KAGJB3.EM
Transportation Packing and Materials
Kartonverpackung und Materialien
Box
MY
DE
-1
P
-1
+Q
T6
P 76
LE
R
18
GR
OU
P:
ul LS
ti Y
TO
M
01
44
(G
Muster
D/
C:
(9
D)
34
(Q
)Q
TY
5
14 2
110 0
(X
PR
OD
NO
(1
T)
LO
T
NO
(6
P)
: 12
BA
3G
H
TC
H
O
2199
2100
12
Se S
m RA
ic M
on
du O
p
ct to
or
NO
s
8
D Bi Bin1
Bi n2 : Pn3 : Q- 1ML : 1- 20
Te
2a
22 mp
3
24 0 ST
Ad 26 0 C R
0 C
R0 dit
ion C R
PA 77 al RT
CK
TE
VA
XT
R:
Barcode label
Original packing label
OHA02886
Dimensions of transportation box in mm
Width
Length
Height
Breite
Länge
Höhe
333 ± 5
218 ± 5
28 ± 5
2016-04-21
15
Version 1.2
GW KAGJB3.EM
Notes
Hinweise
The evaluation of eye safety occurs according to the
standard IEC 62471:2008 ("photobiological safety of
lamps and lamp systems"). Within the risk grouping
system of this CIE standard, the LED specified in this
data sheet fall into the class Moderate risk (exposure
time 0.25 s). Under real circumstances (for exposure
time, eye pupils, observation distance), it is assumed
that no endangerment to the eye exists from these
devices. As a matter of principle, however, it should
be mentioned that intense light sources have a high
secondary exposure potential due to their blinding
effect. As is also true when viewing other bright light
sources (e.g. spotlights), temporary reduction in
visual acuity and afterimages can occur, leading to
irritation, annoyance, visual impairment, and even
accidents, depending on the situation.
Die Bewertung der Augensicherheit erfolgt nach
dem Standard IEC 62471:2008 ("photobiological
safety of lamps and lamp systems"). Im
Risikogruppensystem dieser CIE- Norm erfüllen die
in diesem Datenblatt angegebenen LEDs folgende
Gruppenanforderung - Moderate risk
(Expositionsdauer 0,25 s). Unter realen Umständen
(für Expositionsdauer, Augenpupille,
Betrachtungsabstand) geht damit von diesen
Bauelementen keinerlei Augengefährdung aus.
Grundsätzlich sollte jedoch erwähnt werden, dass
intensive Lichtquellen durch ihre Blendwirkung ein
hohes sekundäres Gefahrenpotenzial besitzen.
Nach einem Blick in eine helle Lichtquelle (z.B.
Spotlights), kann ein temporär eingeschränktes
Sehvermögen oder auch Nachbilder zu Irritationen,
Belästigungen, Beeinträchtigungen oder sogar
Unfällen führen.
Subcomponents of this LED contain, among other
substances, goldplated and Ag-filled materials. In
spite of the improved corrosion stability of this LED, it
can be affected by environments that contain very
high concentrations of aggressive substances.
Therefore, we recommend avoiding aggressive
atmospheres during storage, production and use.
Einzelkomponenten dieser LED enthalten u.a.
goldbeschichtete und Ag-gefüllte Materialien. Trotz
der verbesserten Korrosionsstabilität dieser LED
können Einzelkomponenten durch sehr hohe
Konzentration aggressiver Substanzen angegriffen
werden. Aus diesem Grund wird empfohlen,
aggressive Umgebungen während der Lagerung,
Produktion und im Betrieb zu vermeiden.
This LED is designed for specific/recommended
applications only. Please consult OSRAM Opto
Semiconductors Sales Staff in advance for detailed
information on other non-recommended applications
(e.g. automotive)
OR
Please visit www.osram-os.com/appnotes.
Change management for this component is aligned
with the requirements of the lighting market.
Die LED ist ausschließlich für spezifisch empfohlene
Anwendungen konzipiert. Bitte kontaktieren Sie das
OSRAM Opto Semiconductors Vertriebspersonal für
detailierte Informationen über nicht empfohlene
Anwendungsbereiche (z.B. Automobilbereich). oder
besuchen Sie
Das Änderungsmanagement dieses Bauteils ist an
den Anforderungen des Lichtmarktes ausgerichtet.
2016-04-21
16
Version 1.2
GW KAGJB3.EM
Disclaimer
Disclaimer
Language english will prevail in case of any
discrepancies or deviations between the two language
wordings.
Bei abweichenden Angaben im zweisprachigen
Wortlaut haben die Angaben in englischer Sprache
Vorrang.
Attention please!
The information describes the type of component and
shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved.
Due to technical requirements components may
contain dangerous substances.
For information on the types in question please contact
our Sales Organization.
If printed or downloaded, please find the latest version
in the Internet.
Packing
Please use the recycling operators known to you. We
can also help you – get in touch with your nearest sales
office.
By agreement we will take packing material back, if it is
sorted. You must bear the costs of transport. For
packing material that is returned to us unsorted or which
we are not obliged to accept, we shall have to invoice
you for any costs incurred.
Components used in life-support devices or
systems must be expressly authorized for such
purpose!
Critical components* may only be used in life-support
devices** or systems with the express written approval
of OSRAM OS.
Bitte beachten!
Lieferbedingungen und Änderungen im Design
vorbehalten. Aufgrund technischer Anforderungen
können die Bauteile Gefahrstoffe enthalten. Für weitere
Informationen zu gewünschten Bauteilen, wenden Sie
sich bitte an unseren Vertrieb. Falls Sie dieses
Datenblatt ausgedruckt oder heruntergeladen haben,
finden Sie die aktuellste Version im Internet.
Verpackung
Benutzen
Sie
bitte
die
Ihnen
bekannten
Recyclingwege. Wenn diese nicht bekannt sein sollten,
wenden Sie sich bitte an das nächstgelegene
Vertriebsbüro. Wir nehmen das Verpackungsmaterial
zurück, falls dies vereinbart wurde und das Material
sortiert ist. Sie tragen die Transportkosten. Für
Verpackungsmaterial,
das unsortiert
an uns
zurückgeschickt wird oder das wir nicht annehmen
müssen, stellen wir Ihnen die anfallenden Kosten in
Rechnung.
Bauteile, die in lebenserhaltenden Apparaten und
Systemen eingesetzt werden, müssen für diese
Zwecke ausdrücklich zugelassen sein!
Kritische Bauteile* dürfen in lebenserhaltenden
Apparaten und Systemen** nur dann eingesetzt
werden, wenn ein schriftliches Einverständnis von
OSRAM OS vorliegt.
*) A critical component is a component used in a
life-support device or system whose failure can
reasonably be expected to cause the failure of that
life-support device or system, or to affect its safety or
the effectiveness of that device or system.
**) Life support devices or systems are intended (a) to
be implanted in the human body, or (b) to support
and/or maintain and sustain human life. If they fail, it is
reasonable to assume that the health and the life of the
user may be endangered.
2016-04-21
*) Ein kritisches Bauteil ist ein Bauteil, das in
lebenserhaltenden
Apparaten
oder
Systemen
eingesetzt wird und dessen Defekt voraussichtlich zu
einer
Fehlfunktion
dieses
lebenserhaltenden
Apparates oder Systems führen wird oder die
Sicherheit oder Effektivität dieses Apparates oder
Systems beeinträchtigt.
**) Lebenserhaltende Apparate oder Systeme sind für
(a) die Implantierung in den menschlichen Körper oder
(b) für die Lebenserhaltung bestimmt. Falls Sie
versagen, kann davon ausgegangen werden, dass die
Gesundheit und das Leben des Patienten in Gefahr ist.
17
Version 1.2
GW KAGJB3.EM
Glossary
Glossar
1)
Brightness: Brightness values are measured during
a current pulse of typically 10 ms, with a tolerance of
+/- 7%.
1)
Helligkeit: Helligkeitswerte werden während eines
Strompulses mit einer typischen Dauer von 10 ms,
mit einer Genauigkeit von ± 7% ermittelt.
2)
Color reproduction index: Color
reproduction
index values (CRI-RA) are measured during a current
pulse of typically 10 ms and with a tolerance of ±2.
2)
Farbwiedergabe Index: Werte
des
Farbwiedergabe Index (CRI-RA) werden während
eines Strompulses einer typischen Dauer von 10 ms,
mit einer Genauigkeit von ±2 ermittelt.
3)
Thermal Resistance: Rth max is based on statistic
values (6σ).
3)
Wärmewiderstand: Rth
statistischen Werten (6σ).
4)
Typical Values: Due to the special conditions of the
manufacturing processes of LED, the typical data or
calculated correlations of technical parameters can
only reflect statistical figures. These do not
necessarily correspond to the actual parameters of
each single product, which could differ from the
typical data and calculated correlations or the typical
characteristic line. If requested, e.g. because of
technical improvements, these typ. data will be
changed without any further notice.
4)
Typische Werte: Wegen
der
besonderen
Prozessbedingungen bei der Herstellung von LED
können typische oder abgeleitete technische
Parameter nur aufgrund statistischer Werte
wiedergegeben werden. Diese stimmen nicht
notwendigerweise mit den Werten jedes einzelnen
Produktes überein, dessen Werte sich von typischen
und abgeleiteten Werten oder typischen Kennlinien
unterscheiden können. Falls erforderlich, z.B.
aufgrund technischer Verbesserungen, werden
diese typischen Werte ohne weitere Ankündigung
geändert.
5)
Chromaticity coordinate groups: Chromaticity
coordinate groups are measured during a current
pulse duration of typically 10ms with a tolerance of
±0.005.
5)
Farbortgruppen: Farbortgruppen werden mit einer
Stromeinprägedauer von 10 ms, mit einer
Genauigkeit von ±0.005 ermittelt.
6)
Extrapolated Values: The stated values are
extrapolated data. These values are based on the
devices testing limits. The extrapolation is based on
the typical temperature and forward current
characteristics of the device.
6)
Extrapolierte Werte: Bei den angegebenen Werten
handelt es sich um extrapolierte Angaben. Diese
basieren auf den für das Bauteil spezifizierten
Testgrenzen. Die Extrapolation erfolgte anhand der
typischen Temperatur- und Stromabhängigkeit des
Bauteils.
7)
Characteristic curve: In the range where the line of
the graph is broken, you must expect higher
differences between single LEDs within one packing
unit.
7)
Kennlinien: Im gestrichelten Bereich der Kennlinien
muss mit erhöhten Abweichungen zwischen
Leuchtdioden innerhalb einer Verpackungseinheit
gerechnet werden.
8)
Tolerance of Measure: Unless otherwise noted in
drawing, tolerances are specified with ±0.1 and
dimensions are specified in mm.
8)
Maßtoleranz: Wenn in der Zeichnung nicht anders
angegeben, gilt eine Toleranz von ±0,1. Maße
werden in mm angegeben.
Published by OSRAM Opto Semiconductors GmbH
Leibnizstraße 4, D-93055 Regensburg
www.osram-os.com © All Rights Reserved.
2016-04-21
18
max
basiert
auf
