PRODUCT FAMILY DATA SHEET
XLamp® CXB1512 LED
PRODUCT DESCRIPTION
FEATURES
TABLE OF CONTENTS
The XLamp® CXB1512 LED Array is a
• 9‑mm optical source
Characteristics................................................ 2
member of the second generation of the • Mechanical and optical design
Operating Limits.............................................. 3
CXA family that delivers up to 30% higher
consistent with other CXA15 and
Flux Characteristics, EasyWhite® Order
efficacy and up to 20% higher lumens than
CXB15 LEDs
Codes and Bins - 18 V..................................... 4
the first generation in the same LES. The • Available in 70-, 80-, 90- and
Flux Characteristics, Premium Color Order
higher performance second generation
Codes and Bins - 18 V..................................... 7
CXA
LED
Arrays
provide
a
95-minimum CRI options
drop-in • EasyWhite 2-, 3‑ and 5-step binning
performance upgrade to existing CXA LED • Premium Color 2- and 3-step binning
Codes and Bins - 36 V..................................... 8
designs to shorten product development • Forward voltage options: 18‑V class &
time. In addition, the CXB LEDs also
Codes and Bins - 36 V................................... 11
36‑V class
allow lighting manufacturers to achieve • 85 °C binning and characterization
Relative Spectral Power Distribution,
the same or better performance with a
EasyWhite® ................................................... 12
smaller LES, enabling a smaller, more
• Extremely uniform color over viewing
angle
impactful luminaire. Available in 2‑step, • Top-side solder connections
Premium Color.............................................. 13
3‑step and 5‑step EasyWhite
Electrical Characteristics.............................. 14
bins and • Thermocouple attach point
2‑step and 3‑step Premium Color bins, the • NEMA SSL-3 2011 standard flux bins
Relative Luminous Flux................................. 15
CXB1512 LED delivers high lumen output
Typical Spatial Distribution........................... 17
• RoHS and REACh compliant
and high efficacy in a single, easy‑to‑use • UL recognized component (E349212)
Performance Groups - Brightness............... 17
package that eliminates the need for reflow
EasyWhite® Performance Groups -
soldering.
Chromaticity.................................................. 18
Premium Color Performance Groups The CX Family LED Design Guide provides
Chromaticity.................................................. 19
basic information on the requirements to
EasyWhite® Bins Plotted on the 1931 CIE
use the CXB1512 LED array successfully in
Color Space................................................... 20
luminaire designs.
Premium Color Bins Plotted on the 1931
CIE Color Space............................................ 21
Bin and Order Code Formats........................ 23
Mechanical Dimensions............................... 23
Thermal Design............................................. 24
Notes............................................................. 26
Packaging...................................................... 27
Cree LED / 4400 Silicon Drive / Durham, NC 27703 USA / +1.919.313.5330 / www.cree-led.com
© 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and
the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered
trademarks of UL LLC.
CLD-DS118
REV 9A
1
XLAMP ® CXB1512 LED
CHARACTERISTICS
Characteristics
Viewing angle (FWHM)
ESD withstand voltage (HBM per Mil-Std-883D)
Unit
Minimum
Typical
degrees
Maximum
115
V
8000
DC forward current (18 V)
mA
1200*
DC forward current (36 V)
mA
600*
Reverse current (18 V, 36 V)
mA
0.1
Forward voltage (18 V, @ 700 mA, 85 °C)
V
17.2
19
Forward voltage (36 V, @ 350 mA, 85 °C)
V
34.3
38
Refer to the Operating Limits section.
CLD-DS118
REV 9A
2
XLAMP ® CXB1512 LED
OPERATING LIMITS
The maximum current rating of the CXB1512 depends on the case temperature (Tc) when the LED has reached thermal equilibrium under
steady-state operation. The graphs shown below assume that the system design employs good thermal management (thermal interface
material and heat sink) and may vary when poor thermal management is employed. Please refer to the Mechanical Dimensions section
on page 23 for the location of the Tc measurement point.
Another important factor in good thermal management is the temperature of the Light Emitting Surface (LES). Cree LED recommends a
maximum LES temperature of 135 °C to ensure optimal LED lifetime. Please refer to the Thermal Design section on page 24 for more
CXB1512 - 18 V Standard
information on LES temperature measurement.
1400
90 °C, 1200 mA
1200
If (mA)
1000
800
18 V
600
125 °C,
498 mA
400
200
50
75
100
125
150
Case Temperature (°C)
CXB1512 - 36 V Standard
700
90 °C, 600 mA
600
If (mA)
500
400
36 V
300
125 °C,
249 mA
200
100
50
75
100
125
150
CLD-DS118
REV 9A
3
XLAMP ® CXB1512 LED
FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 18 V (IF = 700 mA, TJ = 85 °C)
The following table provides order codes for XLamp CXB1512 LEDs. For a complete description of the order code nomenclature, please
see the Bin and Order Code Formats section (page 23).
CRI*
Nominal
CCT
Min
70
Minimum Luminous Flux
Typ
6500 K
80
70
70
90
5-Step
Group
Flux (lm)
@ 85 °C
Flux
(lm) @
25 °C**
N4
1710
1871
P2
1830
2002
P4
1965
2150
CXB1512-0000000F0BP465E
N2
1590
1739
CXB1512-0000000F0HN265E
N4
1710
1871
CXB1512-0000000F0HN465E
N4
1710
1871
CXB1512-0000000F0BN457E
P2
1830
2002
P4
1965
2150
CXB1512-0000000F0BP457E
N2
1590
1739
CXB1512-0000000F0HN257E
N4
1710
1871
CXB1512-0000000F0HN457E
N4
1710
1871
CXB1512-0000000F0BN450E
P2
1830
2002
P4
1965
2150
N2
1590
1739
N4
1710
1871
CXB1512-0000000F0HN450G
M4
1485
1625
CXB1512-0000000F0UM450G
N2
1590
1739
Group
Order Code
Group
Order Code
Group
65E
65E
57E
57E
50E
CXB1512-0000000F0BP265E
CXB1512-0000000F0BP257E
CXB1512-0000000F0BP250E
CXB1512-0000000F0BP450E
50G
92
Order Code
CXB1512-0000000F0BN465E
5000 K
80
3-Step
5700 K
80
2-Step
50G
CXB1512-0000000F0HN250G
50E
CXB1512-0000000F0HN250E
CXB1512-0000000F0HN450E
CXB1512-0000000F0UN250G
Notes
Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on
CRI measurements. See the Measurements section (page 26).
CXB1512 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum
specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code.
For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60.
** Flux values @ 25 °C are calculated and for reference only.
CLD-DS118
REV 9A
4
XLAMP ® CXB1512 LED
FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 18 V (IF = 700 mA, TJ = 85 °C) - CONTINUED
CRI*
Nominal
CCT
Min
70
4000 K
80
90
80
Typ
92
2-Step
Group
Flux (lm)
@ 85 °C
Flux
(lm) @
25 °C**
N4
1710
1871
P2
1830
2002
P4
1965
2150
N2
1590
1739
N4
1710
1871
P2
1830
2002
CXB1512-0000000F0HP240H
CXB1512-0000000F0HP240G
M2
1380
1510
CXB1512-0000000F0UM240H
CXB1512-0000000F0UM240G
M4
1485
1625
N2
1590
1739
CXB1512-0000000F0UN240H
CXB1512-0000000F0UN240G
N2
1590
1739
CXB1512-0000000F0HN235H
CXB1512-0000000F0HN235G
N4
1710
1871
P2
1830
2002
CXB1512-0000000F0HP235H
CXB1512-0000000F0HP235G
K4
1290
1411
CXB1512-0000000F0UK435H
CXB1512-0000000F0UK435G
M2
1380
1510
M4
1485
1625
CXB1512-0000000F0UM435H
CXB1512-0000000F0UM435G
M4
1485
1625
CXB1512-0000000F0HM430H
CXB1512-0000000F0HM430G
N2
1590
1739
N4
1710
1871
CXB1512-0000000F0HN430H
CXB1512-0000000F0HN430G
K4
1290
1411
CXB1512-0000000F0UK430H
CXB1512-0000000F0UK430G
M2
1380
1510
M4
1485
1625
Group
80
92
92
Group
Order Code
Group
40E
Order Code
CXB1512-0000000F0BP240E
CXB1512-0000000F0BP440E
CXB1512-0000000F0HN240H
40H
40H
35H
35H
30H
3000 K
90
Order Code
5-Step
CXB1512-0000000F0BN440E
3500 K
90
3-Step
30H
CXB1512-0000000F0HN440H
CXB1512-0000000F0UM440H
CXB1512-0000000F0HN435H
CXB1512-0000000F0UM235H
CXB1512-0000000F0HN230H
CXB1512-0000000F0UM230H
CXB1512-0000000F0UM430H
CXB1512-0000000F0HN240G
40G
40G
35G
35G
30G
30G
CXB1512-0000000F0HN440G
CXB1512-0000000F0UM440G
CXB1512-0000000F0HN435G
CXB1512-0000000F0UM235G
CXB1512-0000000F0HN230G
CXB1512-0000000F0UM230G
CXB1512-0000000F0UM430G
Notes
CLD-DS118
REV 9A
5
XLAMP ® CXB1512 LED
CRI*
Nominal
CCT
Min
80
Typ
90
2200 K
80
Group
Flux (lm)
@ 85 °C
Flux
(lm) @
25 °C**
M4
1485
1625
N2
1590
1739
CXB1512-0000000F0HN227H
K2
1200
1313
CXB1512-0000000F0UK227H
K4
1290
1411
M2
1380
1510
M2
1380
1510
2700 K
92
2-Step
Group
27H
27H
Order Code
CXB1512-0000000F0HM427H
CXB1512-0000000F0UK427H
3-Step
Group
27G
Order Code
5-Step
Group
Order Code
CXB1512-0000000F0HM427G
CXB1512-0000000F0HN227G
CXB1512-0000000F0UK227G
27G
CXB1512-0000000F0UM227H
CXB1512-0000000F0UK427G
CXB1512-0000000F0UM227G
22G
CXB1512-0000000F0HM222G
Notes
CLD-DS118
REV 9A
6
XLAMP ® CXB1512 LED
FLUX CHARACTERISTICS, PREMIUM COLOR ORDER CODES AND BINS - 18 V (I F = 700 mA, TJ = 85 °C)
Fidelity
CRI*
Nominal
CCT
Min
Typ
Group
Flux (lm)
@ 85 °C
Flux
(lm) @
25 °C**
4000 K
95
98
K4
1290
1411
3500 K
95
98
K2
1200
3000 K
95
98
K2
2700 K
95
98
J4
Typical
Luminous
Flux (lm)
@ 85 °C
2-Step
Group
Order Code
1407
L5A
CXB1512-0000-000F0ZK4L5A
1313
1355
35H
CXB1512-0000-000F0ZK235H
1200
1313
1303
30H
CXB1512-0000-000F0ZK230H
1120
1225
1229
27H
CXB1512-0000-000F0ZJ427H
Specialty
CRI
Nominal
CCT
3100 K
Min
90
80
3000 K
90
95
Typ
Group
Flux (lm)
@ 85 °C
Flux
(lm) @
25 °C**
K4
1290
1411
M2
1380
1510
M4
1485
1625
J4
1120
1225
K2
1200
1313
K4
1290
1411
J4
1120
1225
92
92
98
Typical
Luminous
Flux (lm)
@ 85 °C
2-Step
Group
Order Code
1502
1746
3-Step
Group
31Q
L7B
Order Code
Group
Order Code
CXB1512-0000000F0UK431Q
CXB1512-0000000F0UM231Q
CXB1512-0000000F0HM4L7B
CXB1512-0000000F0UJ430U
1502
30Q
CXB1512-0000000F0UK230Q
CXB1512-0000000F0UK430Q
1303
L7C
30U
CXB1512-0000000F0UK230U
CXB1512-0000000F0UK430U
CXB1512-0000000F0ZJ4L7C
Notes
CLD-DS118
REV 9A
7
XLAMP ® CXB1512 LED
FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 36 V (IF = 350 mA, TJ = 85 °C)
CRI*
Nominal
CCT
Min
70
Typ
6500 K
80
70
70
90
5-Step
Group
Flux (lm)
@ 85 °C
Flux
(lm) @
25 °C**
N4
1710
1871
P2
1830
2002
P4
1965
2150
CXB1512-0000000N0BP465E
N2
1590
1739
CXB1512-0000000N0HN265E
N4
1710
1871
CXB1512-0000000N0HN465E
N4
1710
1871
CXB1512-0000000N0BN457E
P2
1830
2002
P4
1965
2150
CXB1512-0000000N0BP457E
N2
1590
1739
CXB1512-0000000N0HN257E
N4
1710
1871
CXB1512-0000000N0HN457E
N4
1710
1871
CXB1512-0000000N0BN450E
P2
1830
2002
P4
1965
2150
N2
1590
1739
N4
1710
1871
CXB1512-0000000N0HN450G
M4
1485
1625
CXB1512-0000000N0UM450G
N2
1590
1739
Group
Order Code
Group
Order Code
Group
65E
65E
57E
57E
50E
CXB1512-0000000N0BP265E
CXB1512-0000000N0BP257E
CXB1512-0000000N0BP250E
CXB1512-0000000N0BP450E
50G
92
Order Code
CXB1512-0000000N0BN465E
5000 K
80
3-Step
5700 K
80
2-Step
50G
CXB1512-0000000N0HN250G
50E
CXB1512-0000000N0HN250E
CXB1512-0000000N0HN450E
CXB1512-0000000N0UN250G
Notes
CLD-DS118
REV 9A
8
XLAMP ® CXB1512 LED
FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 36 V (IF = 350 mA, TJ = 85 °C) - CONTINUED
CRI*
Nominal
CCT
Min
70
4000 K
80
90
80
Typ
92
2-Step
Group
Flux (lm)
@ 85 °C
Flux
(lm) @
25 °C**
N4
1710
1871
P2
1830
2002
P4
1965
2150
N2
1590
1739
N4
1710
1871
P2
1830
2002
CXB1512-0000000N0HP240H
CXB1512-0000000N0HP240G
M2
1380
1510
CXB1512-0000000N0UM240H
CXB1512-0000000N0UM240G
M4
1485
1625
N2
1590
1739
CXB1512-0000000N0UN240H
CXB1512-0000000N0UN240G
N2
1590
1739
CXB1512-0000000N0HN235H
CXB1512-0000000N0HN235G
N4
1710
1871
P2
1830
2002
CXB1512-0000000N0HP235H
CXB1512-0000000N0HP235G
K4
1290
1411
CXB1512-0000000N0UK435H
CXB1512-0000000N0UK435G
M2
1380
1510
M4
1485
1625
CXB1512-0000000N0UM435H
CXB1512-0000000N0UM435G
M4
1485
1625
CXB1512-0000000N0HM430H
CXB1512-0000000N0HM430G
N2
1590
1739
N4
1710
1871
CXB1512-0000000N0HN430H
CXB1512-0000000N0HN430G
K4
1290
1411
CXB1512-0000000N0UK430H
CXB1512-0000000N0UK430G
M2
1380
1510
M4
1485
1625
Group
80
92
92
Group
Order Code
Group
40E
Order Code
CXB1512-0000000N0BP240E
CXB1512-0000000N0BP440E
CXB1512-0000000N0HN240H
40H
40H
35H
35H
30H
3000 K
90
Order Code
5-Step
CXB1512-0000000N0BN440E
3500 K
90
3-Step
30H
CXB1512-0000000N0HN440H
CXB1512-0000000N0UM440H
CXB1512-0000000N0HN435H
CXB1512-0000000N0UM235H
CXB1512-0000000N0HN230H
CXB1512-0000000N0UM230H
CXB1512-0000000N0UM430H
CXB1512-0000000N0HN240G
40G
40G
35G
35G
30G
30G
CXB1512-0000000N0HN440G
CXB1512-0000000N0UM440G
CXB1512-0000000N0HN435G
CXB1512-0000000N0UM235G
CXB1512-0000000N0HN230G
CXB1512-0000000N0UM230G
CXB1512-0000000N0UM430G
Notes
CLD-DS118
REV 9A
9
XLAMP ® CXB1512 LED
CRI*
Nominal
CCT
Min
80
Typ
90
2200 K
80
Group
Flux (lm)
@ 85 °C
Flux
(lm) @
25 °C**
M4
1485
1625
N2
1590
1739
CXB1512-0000000N0HN227H
K2
1200
1313
CXB1512-0000000N0UK227H
K4
1290
1411
M2
1380
1510
M2
1380
1510
2700 K
92
2-Step
Group
27H
27H
Order Code
CXB1512-0000000N0HM427H
CXB1512-0000000N0UK427H
3-Step
Group
27G
Order Code
5-Step
Group
Order Code
CXB1512-0000000N0HM427G
CXB1512-0000000N0HN227G
CXB1512-0000000N0UK227G
27G
CXB1512-0000000N0UM227H
CXB1512-0000000N0UK427G
CXB1512-0000000N0UM227G
22G
CXB1512-0000000N0HM222G
Notes
CLD-DS118
REV 9A
10
XLAMP ® CXB1512 LED
FLUX CHARACTERISTICS, PREMIUM COLOR ORDER CODES AND BINS - 36 V (I F = 350 mA, TJ = 85 °C)
Fidelity
CRI*
Nominal
CCT
Min
Typ
Group
Flux (lm)
@ 85 °C
Flux
(lm) @
25 °C**
4000 K
95
98
K4
1290
1411
3500 K
95
98
K2
1200
3000 K
95
98
K2
2700 K
95
98
J4
Typical
Luminous
Flux (lm)
@ 85 °C
2-Step
Group
Order Code
1407
L5A
CXB1512-0000-000N0ZK4L5A
1313
1355
35H
CXB1512-0000-000N0ZK235H
1200
1313
1303
30H
CXB1512-0000-000N0ZK230H
1120
1225
1229
27H
CXB1512-0000-000N0ZJ427H
Specialty
CRI
Nominal
CCT
3100 K
Min
90
80
3000 K
90
95
Typ
Group
Flux (lm)
@ 85 °C
Flux
(lm) @
25 °C**
K4
1290
1411
M2
1380
1510
M4
1485
1625
J4
1120
1225
K2
1200
1313
K4
1290
1411
J4
1120
1225
92
92
98
Typical
Luminous
Flux (lm)
@ 85 °C
2-Step
Group
Order Code
1502
1746
3-Step
Group
31Q
L7B
Order Code
Group
Order Code
CXB1512-0000000N0UK431Q
CXB1512-0000000N0UM231Q
CXB1512-0000000N0HM4L7B
CXB1512-0000000N0UJ430U
1502
30Q
CXB1512-0000000N0UK230Q
CXB1512-0000000N0UK430Q
1303
L7C
30U
CXB1512-0000000N0UK230U
CXB1512-0000000N0UK430U
CXB1512-0000000N0ZJ4L7C
Notes
CLD-DS118
REV 9A
11
XLAMP ® CXB1512 LED
RELATIVE SPECTRAL POWER DISTRIBUTION, EASYWHITE®
The following graphs are the result of a series of pulsed measurements at 700 mA for the 18-V CXB1512 LED and 350 mA for the 36-V
CXB1512 LED and TJ = 85 °C.
100%
90%
80%
70%
5000 K, 70 CRI
60%
4000 K, 70 CRI
50%
3000 K, 80 CRI
40%
3000 K, 90 CRI
30%
2200 K, 80 CRI
20%
10%
0%
380
430
480
530
580
630
680
730
780
Wavelength (nm)
CLD-DS118
REV 9A
12
XLAMP ® CXB1512 LED
RELATIVE SPECTRAL POWER DISTRIBUTION, PREMIUM COLOR
Fidelity
100%
90%
80%
70%
60%
4000 K, Z CRI
50%
3500 K, Z CRI
3000 K, Z CRI
40%
2700 K, Z CRI
30%
20%
10%
0%
380
430
480
530
580
630
680
730
780
Wavelength (nm)
Specialty
100%
90%
80%
70%
31Q, 3100 K, 90 CRI
60%
30Q, 3000 K, 90 CRI
50%
30U, 3000 K, 90 CRI
40%
L7B, 3000 K 80 CRI
30%
L7C, 3000 K, Z CRI
20%
10%
0%
380
430
480
530
580
630
680
730
780
Wavelength (nm)
CLD-DS118
REV 9A
13
XLAMP ® CXB1512 LED
ELECTRICAL CHARACTERISTICS
The following graphs are the result of a series of steady-state measurements.
18.5
Voltage (V)
18.0
18 V
17.5
Tc = 25 °C
Tc = 55 °C
17.0
Tc = 85 °C
Tc = 105 °C
16.5
16.0
15.5
200
300
400
500
600
700
800
900
1000
1100
1200
Current (mA)
37.0
Voltage (V)
36.0
36 V
35.0
Tc = 25 °C
Tc = 55 °C
34.0
Tc = 85 °C
Tc = 105 °C
33.0
32.0
31.0
100
150
200
250
300
350
400
450
500
550
600
Current (mA)
CLD-DS118
REV 9A
14
XLAMP ® CXB1512 LED
RELATIVE LUMINOUS FLUX
The relative luminous flux values provided below are the ratio of:
• Measurements of CXB1512 at steady-state operation at the given conditions, divided by
• Flux measured during binning, which is a pulsed measurement at 700 mA at TJ = 85 °C for the 18‑V CXB1512 LED.
Using the 18‑V CXB1512 LED as an example, at steady-state operation of Tc = 25 °C, IF = 800 mA, the relative luminous flux ratio is 120%
in the chart below. A CXB1512 LED that measures 1290 lm during binning will deliver 1548 lm (1290 * 1.2) at steady-state operation of
Tc = 25 °C, IF = 800 mA.
180%
160%
18 V
140%
120%
Tc = 25 °C
100%
Tc = 55 °C
Tc = 85 °C
80%
Tc = 105 °C
60%
40%
20%
0%
200
300
400
500
600
700
800
900
1000
1100
1200
Current (mA)
CLD-DS118
REV 9A
15
XLAMP ® CXB1512 LED
RELATIVE LUMINOUS FLUX - CONTINUED
• Flux measured during binning, which is a pulsed measurement at 350 mA at TJ = 85 °C for the 36‑V CXB1512 LED.
Using the 36‑V CXB1512 LED as an example, at steady-state operation of Tc = 25 °C, IF = 400 mA, the relative luminous flux ratio is 120%
Tc = 25 °C, IF = 400 mA.
180%
160%
36 V
140%
120%
Tc = 25 °C
100%
Tc = 55 °C
Tc = 85 °C
80%
Tc = 105 °C
60%
40%
20%
0%
100
150
200
250
300
350
400
450
500
550
600
Current (mA)
CLD-DS118
REV 9A
16
XLAMP ® CXB1512 LED
Far Field
TYPICAL SPATIAL DISTRIBUTION
100%
Relative Luminous Intensity
80%
60%
40%
20%
-90
-70
-50
-30
-10
0%
10
30
50
70
90
Angle (º)
PERFORMANCE GROUPS - BRIGHTNESS (18 V, I F = 700 mA; 36 V, IF = 350 mA, TJ = 85 °C)
XLamp CXB1512 LEDs are tested for luminous flux and placed into one of the following bins.
Group Code
Maximum Luminous Flux
J4
1120
1200
K2
1200
1290
K4
1290
1380
M2
1380
1485
M4
1485
1590
N2
1590
1710
N4
1710
1830
P2
1830
1965
P4
1965
2100
Q2
2100
2260
CLD-DS118
REV 9A
17
XLAMP ® CXB1512 LED
EASYWHITE® PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C)
XLamp CXB1512 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates.
EasyWhite Color Temperatures – 2-Step
Code
40H
35H
30H
27H
CCT
4000 K
3500 K
3000 K
2700 K
x
y
0.3777
0.3739
0.3797
0.3816
0.3861
0.3855
0.3838
0.3777
0.4022
0.3858
0.4053
0.3942
0.4125
0.3977
0.4091
0.3891
0.4287
0.3975
0.4328
0.4064
0.4390
0.4086
0.4347
0.3996
0.4524
0.4048
0.4574
0.4140
0.4633
0.4154
0.4581
0.4062
EasyWhite Color Temperatures – 3-Step Ellipse
Bin Code
CCT
50G
40G
Center Point
Major Axis
Minor Axis
Rotation Angle
x
y
a
b
5000 K
0.3447
0.3553
0.00840
0.00312
65.0
4000 K
0.3818
0.3797
0.00939
0.00402
53.7
35G
3500 K
0.4073
0.3917
0.00927
0.00414
54.0
30G
3000 K
0.4338
0.4030
0.00834
0.00408
53.2
27G
2700 K
0.4577
0.4099
0.00834
0.00420
48.5
22G
2200 K
0.5066
0.4158
0.00980
0.00480
45.5
EasyWhite Color Temperatures – 5-Step Ellipse
Bin Code
CCT
65E
Center Point
Major Axis
Minor Axis
Rotation Angle
x
y
a
b
6500 K
0.3123
0.3282
0.01110
0.00550
61.0
57E
5700 K
0.3287
0.3417
0.01230
0.00600
72.0
50E
5000 K
0.3447
0.3553
0.01400
0.00520
65.0
40E
4000 K
0.3818
0.3797
0.01565
0.00670
53.7
CLD-DS118
REV 9A
18
XLAMP ® CXB1512 LED
PREMIUM COLOR PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C)
Fidelity
Code
L5A
35H
30H
27H
CCT
4000 K
3500 K
3000 K
2700 K
x
y
0.3764
0.3711
0.3784
0.3787
0.3847
0.3826
0.3825
0.3748
0.4022
0.3858
0.4053
0.3942
0.4125
0.3977
0.4091
0.3891
0.4287
0.3975
0.4328
0.4064
0.4390
0.4086
0.4347
0.3996
0.4524
0.4048
0.4574
0.4140
0.4633
0.4154
0.4581
0.4062
Specialty
Code
L7B
L7C
CCT
3000 K
3000 K
x
y
0.4263
0.3848
0.4296
0.3916
0.4361
0.3938
0.4326
0.3868
0.4192
0.3754
0.4224
0.3823
0.4291
0.3847
0.4257
0.3777
Center Point
Major Axis
Minor Axis
Rotation Angle
Bin Code
CCT
x
y
a
b
31Q
3100 K
0.4236
0.3888
0.00848
0.00455
50.3
30Q
3000 K
0.4305
0.3935
0.00834
0.00408
53.2
30U
3000 K
0.4274
0.3837
0.00834
0.00408
53.2
CLD-DS118
REV 9A
19
XLAMP ® CXB1512 LED
EASYWHITE® BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C)
0.45
ANSI C78.377 Quadrangle
0.44
2700 K
EasyWhite 5-step
0.43
2200 K
2450 K
3000 K
EasyWhite 3-step
0.42
EasyWhite 2-step
3500 K
0.41
4000 K
0.40
CCy
0.39
5000 K
4500 K
5700 K
0.38
0.37
6500 K
0.36
0.35
7000K
0.34
0.33
0.32
0.54
0.53
0.52
0.51
0.50
0.49
0.48
0.47
0.46
0.45
0.44
0.43
0.42
0.41
0.40
0.39
0.38
0.37
0.36
0.35
0.34
0.33
0.32
0.31
0.30
0.29
0.31
CCx
CLD-DS118
REV 9A
XLAMP ® CXB1512 LED
PREMIUM COLOR BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C)
Fidelity (2-step)
0.44
2700K
0.43
3000K
0.42
3500K
0.41
27H
4000K
CCy
0.40
30H
4500K
35H
0.39
0.38
L5A
0.37
0.36
0.35
0.48
0.47
0.46
0.45
0.44
CCx
0.43
0.42
0.41
0.40
0.39
0.38
0.37
0.36
0.35
0.34
CLD-DS118
REV 9A
21
XLAMP ® CXB1512 LED
PREMIUM COLOR BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) - CONTINUED
Speciality (2-step)
0.44
3000 K
0.43
0.42
3500 K
CCy
0.41
0.40
0.39
L7B
L7C
0.38
0.46
0.45
CCx
0.44
0.43
0.42
0.41
0.37
Speciality (3-step)
0.44
3000K
0.43
0.42
3500K
CCy
0.41
0.40
30Q
0.39
31Q
30U
0.38
0.46
0.45
CCx
0.44
0.43
0.42
0.41
0.37
CLD-DS118
REV 9A
22
XLAMP ® CXB1512 LED
BIN AND ORDER CODE FORMATS
Bin codes and order codes are configured as follows:
Order Code
Bin Code
Series = CXB15
Series = CXB15
Internal code
Chromaticity bin
CRI Specification
B = 70 CRI minimum
H = 80 CRI minimum
U = 90 CRI minimum
Z = 95 CRI minimum
Vf class:
F0 = 18-V class
N0 = 36-V class
Internal code
SSSSSCC-WWW-FF-GGR-AAAAA
SSSSSCC-HHHH-HHHGGRNNNNN
Vf class:
F0 = 18-V class
N0 = 36-V class
CRI Specification
B = 70 CRI minimum
H = 80 CRI minimum
U = 90 CRI minimum
Z = 95 CRI minimum
Performance class
Flux bin
Kit code
Performance class
MECHANICAL DIMENSIONS
Dimensions are in mm.
Tolerances unless otherwise
specified: +.13
x° +1°
B1512F = 18‑V CXB1512
B1512N = 36‑V CXB1512
B1512X
Meaning of B1512X
CLD-DS118
REV 9A
23
XLAMP ® CXB1512 LED
THERMAL DESIGN
The CXB family of LED arrays can include over a hundred different LED die inside one package, and thus over a hundred different junction
temperatures (TJ). Cree LED has intentionally removed junction-temperature-based operating limits and replaced the commonplace
maximum TJ calculations with maximum ratings based on forward current (IF) and case temperature (Tc). No additional calculations
are required to ensure that the CXB LED is being operated within its designed limits. LES temperature measurement provides additional
verification of good thermal design. Please refer to page 3 for the Operating Limit specifications.
There is no need to calculate for TJ inside the package, as the thermal management design process, specifically from TSP to ambient (Ta),
remains identical to any other LED component. For more information on thermal management of XLamp LEDs, please refer to the Thermal
Management application note. For CXB soldering recommendations and more information on thermal interface materials (TIM), LES
temperature measurement, and connection methods, please refer to the XLamp CX Family LEDs soldering and handling document. The
CX Family LED Design Guide provides basic information on the requirements to use XLamp CXB LEDs successfully in luminaire designs.
To keep the CXB1512 LED at or below the maximum rated Tc, the case to ambient temperature
thermal resistance (R_c-a) must be at or below the maximum R_c-a value shown on the following
graphs, depending on the operating environment. The y‑axis in the graphs is a base 10 logarithmic
scale.
R_j-c
R_j-c
Tc
Tc
R_tim
As the figure at right shows, the R_c-a value is the sum of the thermal resistance of the TIM (R_tim)
R_c-a
plus the thermal resistance of the heat sink (R_hs).
R_hs
CXB1512 - 18 V
Ta
Ta
100.00
18 V
Maximum R_c-a
10.00
Ta = 25 °C
Ta = 55 °C
1.00
Ta = 85 °C
Ta = 105 °C
0.10
0.01
200
300
400
500
600
700
800
900
1000
1100
1200
Current (mA)
CLD-DS118
REV 9A
24
XLAMP ® CXB1512 LED
V
THERMALCXB1512
DESIGN -- 37
CONTINUED
100.00
36 V
Maximum R_c-a
10.00
Ta = 25 °C
Ta = 55 °C
1.00
Ta = 85 °C
Ta = 105 °C
0.10
0.01
100
200
300
400
500
600
Current (mA)
CLD-DS118
REV 9A
25
XLAMP ® CXB1512 LED
NOTES
Measurements
The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only
and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number
of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated
values are provided for informational purposes only and are not intended or provided as specifications.
Pre‑Release Qualification Testing
Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp
LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs.
Lumen Maintenance
Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen
maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document.
Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and
forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive
current affect the LED junction temperature.
RoHS Compliance
The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold
limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as
implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product
Ecology section of the Cree LED website.
REACh Compliance
REACh substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA)
has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative
to insure you get the most up-to-date REACh Declaration. REACh banned substance information (REACh Article 67) is also available upon
request.
UL® Recognized Component
This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED
package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750.
Vision Advisory
WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please
refer to the LED Eye Safety application note.
CLD-DS118
REV 9A
26
XLAMP ® CXB1512 LED
PACKAGING
6
CXB1512 LEDs are packaged in5 trays of 20. Five trays are sealed
in an anti-static bag and placed
inside a carton, for a total of2 100 LEDs
4
3
per carton. Each carton contains 100 LEDs from the same performance bin.
NOTICE
ENTIAL. THIS PLOT AND THE INFORMATION
WITHIN ARE THE PROPRIETARY AND
AL INFORMATION OF CREE, INC. THIS PLOT
COPIED, REPRODUCED OR DISCLOSED TO ANY
ED PERSON WITHOUT
THE WRITTEN CONSENT
NSENT
Dimensions are in inches.
Tolerances: +.13
5
4
3
5.875
x° +1°
2
1
R .375
6
5
4
NOTICE
FIDENTIAL. THIS PLOT AND THE INFORMATION
D WITHIN ARE THE PROPRIETARY AND
TIAL INFORMATION OF CREE, INC. THIS PLOT
E COPIED, REPRODUCED OR DISCLOSED TO ANY
IZED PERSON WITHOUTTHE WRITTEN CONSENT
C.
3
5.875
2
1
.875
R .375
5.875
R.375
5.875
.875
.875
5.875
LABEL WITH CREE BIN
CODE, QUANTITY, LOT #
BAG
.38
.875
PATENT LABEL IS LOCATED
PATENT
LABEL IS
ON UNDERSIDE
OFLOCATED
COVER
ON UNDERSIDE OF CARTON
ITH CREE BIN
ANTITY, LOT #
.875
LABEL WITH
CREE
.875
BIN CODE, QTY, LOT#
.38
BAG
BAG
.38
LABEL WITH CREE BIN
PATENT LABEL
EL IS LOCATED
IS LOCATED ON UNDERSIDE OF
CARTON
IDE OF COVER
LABEL WITH CREE
BIN CODE, QTY, LOT#
LABEL WITH CREE BIN
LABEL WITH CREE BIN
UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN
MILLIMETERS & BEFORE FINISH.
TOLERANCE UNLESS SPECIFIED:
LABEL WITH CREE BIN
.X
.XX
.XXX ±
X°
THIRD ANGLE PROJECTION
5
L WITH CREE BIN
QUANTITY, LOT #
6
3.X
.XX
0.1
.05
.XXX ±DRAWN
.005BY
X°
1°
4
DIMENSIONS AREFOR
IN SHEET METAL PARTS ONLY
CHECK
.X
.06
TOLERANCE UNLESS SPECIFIED: .XX ±
.03
.XXX and
±APPROVED
.010
.X
± trademarks,
0.1
X°
2°
.05 registered
the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the.XXUL logo
are
5
4
3.XXX ± .005
MATERIAL
X°
1 °
FOR SHEET METAL PARTS ONLY
.X
.06
APPROVED
DATE
APPROVED
DATE
TITLE
CXA15
SIZE
FINAL PROTECTIVE FINISH
DRAW
C
CXA
4600 Silicon Dri
Durham, N.C 27
SCALE
Phone (919) 361
0.500
Fax (919) 313-5
2
DATE
TITLE
CXA15XX_DATASHEET
DATE
MATERIAL
SIZE
DATE
DATE
TITLE
2
C
DRAWING NO.
4600 Silicon Drive
Durham, N.C 27703
Phone (919) 361-4770
CXA15XX_DATASHEET_BAG2013
CLD-DS118
SCALE
0.500
REV 9A
27
Fax (919) 313-5303
SHEET
CXA15XX_DATASHEET
SIZE
DATE
MATERIAL
DRAWN BY
.06 DATE
UNLESS OTHERWISE SPECIFIED .X
.XX
.03
DIMENSIONS ARE IN
CHECK ±
.XXX
.010 DATE
2 °
TOLERANCE UNLESS SPECIFIED: X°
LABEL WITH CREE
BIN CODE, QTY, LOT#
6
0.1
.05
.005
1 °
DRAWN BY
CHECK
1
DRAWING NO.
OF
