GWKAHJB1.CM-SRSS-35S3
    AMSOSRAM(艾迈斯半导体)
    LEDCOBSOLERIQ3500KSQUARE
GWKAHJB1.CM-SRSS-35S3 数据手册
2015-12-10 SOLERIQ® S 19 Datasheet Version 1.3 GW KAHJB1.CM The SOLERIQ® S products were specifically designed for applications requiring large flux packages out of a compact area. Die SOLERIQ® S Produkte wurden speziell für Anwendungen entwickelt, die großen Lichtstrom aus einer kompakten Fläche benötigen. Features: • Package: Chip-on-Board • Viewing angle at 50 % IV: 120° • Color: 2700 K - 4000 K (white) • CRI: min. 90 • Luminous Flux: typ. 2522 lm @ 4000 K, 85 °C • Luminous efficacy: typ. 108 lm/W @ 4000 K, 85 °C Besondere Merkmale: • Gehäusetyp: Chip-on-Board • Abstrahlwinkel bei 50 % IV: 120° • Farbe: 2700 K - 4000 K (weiß) • CRI: min. 90 • Lichtstrom: typ. 2522 lm @ 4000 K, 85 °C • Lichtausbeute: typ. 108 lm/W @ 4000 K, 85 °C Applications Spot lights • • Indoor General Lighting Anwendungen • Spot-Leuchten • Innen-Allgemeinbeleuchtung 2015-12-10 1 Version 1.3 GW KAHJB1.CM Ordering Information Bestellinformation Type: Typ: Color Temperature Luminous Flux Farbtemperatur Lichtstrom Ordering Code 1) page 18 Bestellnummer 1) Seite 18 IF = 500 mA, TS = 85 °C [K] ΦV [lm] GW KAHJB1.CM-SQSR-27S3 2700 1940 ... 2240 Q65111A7434 GW KAHJB1.CM-SRSS-27S3 2700 2100 ... 2400 Q65112A0055 GW KAHJB1.CM-SRSS-30S3 3000 2100 ... 2400 Q65111A7432 GW KAHJB1.CM-SRSS-35S3 3500 2100 ... 2400 Q65111A7446 GW KAHJB1.CM-SSST-35S3 3500 2240 ... 2590 Q65111A7444 GW KAHJB1.CM-SSST-40S3 4000 2240 ... 2590 Q65111A7443 GW KAHJB1.CM-SQSR-27B3 2700 Brilliant White 1940 ... 2240 Q65111A7916 GW KAHJB1.CM-SRSS-30B3 3000 Brilliant White 2100 ... 2400 Q65111A7915 GW KAHJB1.CM-SSST-35B3 3500 Brilliant White 2240 ... 2590 Q65111A7914 Note: The above Type Numbers represent the order groups which include only a few brightness groups (see page 5). Only one group will be shipped on each packing unit (there will be no mixing of two groups on each packing unit). E. g. GW KAHJB1.CM-SRSS-27S3 means that only one group SR, SS will be shippable for any packing unit. In a similar manner for colors where color chromaticity coordinate groups are measured and binned, single groups will be shipped on any one packing unit. GW KAHJB1.CM-SRSS-27S3 means that the device will be shipped within the specified limits. Anm.: Die oben genannten Typbezeichnungen umfassen die bestellbaren Selektionen. Diese bestehen aus wenigen Helligkeitsgruppen (siehe Seite 5). Es wird nur eine einzige Helligkeitsgruppe pro Verpackungseinheit geliefert. Z. B. GW KAHJB1.CM-SRSS-27S3 bedeutet, dass in einer Verpackungseinheit nur eine der Helligkeitsgruppen SR, SS enhalten ist. Gleiches gilt für die Farben, bei denen Farbortgruppen gemessen und gruppiert werden. Pro Verpackungseinheit wird nur eine Farbortgruppe geliefert. Z.B. GW KAHJB1.CM-SRSS-27S3 bedeutet, dass in einer Verpackungseinheit nur eine der Farbortgruppen enthalten ist. GW KAHJB1.CM-SRSS-27S3 bedeutet, dass das Bauteil innerhalb der spezifizierten Grenzen geliefert wird. 2015-12-10 2 Version 1.3 GW KAHJB1.CM Maximum Ratings Grenzwerte Parameter Symbol Values Unit Bezeichnung Symbol Werte Einheit Operating temperature range Betriebstemperatur Top -30 ... 105 °C Storage temperature range Lagertemperatur Tstg -40 ... 100 °C Junction temperature Sperrschichttemperatur Tj 125 °C Forward current Durchlassstrom (TS = 85 °C) IF 700 mA Surge current Stoßstrom (t ≤ 10 µs; D = 0.005; TS = 85 °C) IFM 720 mA Reverse current Sperrstrom IR 20 mA 2 kV ESD withstand voltage VESD ESD Festigkeit (acc. to ANSI/ESDA/JEDEC JS-001 - HBM, Class 2) 2015-12-10 3 Version 1.3 GW KAHJB1.CM Characteristics (TS = 85 °C; IF = 500 mA) Kennwerte Parameter Symbol Values Unit Bezeichnung Symbol Werte Einheit Viewing angle at 50 % IV Abstrahlwinkel bei 50 % IV (typ.) 2ϕ 120 ° Forward voltage 2) page 18 Durchlassspannung 2) Seite 18 (min.) (typ.) (max.) VF VF VF 42.0 46.5 50.0 V V V Reverse voltage Sperrspannung (IR = 20 mA) (max.) VR 1.2 V Color rendering index 3) page 18 Farbwiedergabe Index 3) Seite 18 (min.) Ra 90 - Real thermal resistance junction / solder point (typ.) (max.) Rth JS real Rth JS real 0.9 1.1 K/W K/W Rth JS el Rth JS el 0.6 0.7 K/W K/W 4) page 18 Realer Wärmewiderstand Sperrschicht / Lötpad 4) Seite 18 "Electrical" thermal resistance junction / solder point (typ.) 4) page 18 (max.) "Elektrischer" Wärmewiderstand Sperrschicht / Lötpad 4) Seite 18 (with efficiency ηe = 35 %) 2015-12-10 4 Version 1.3 GW KAHJB1.CM Brightness Groups Helligkeitsgruppen Group Luminous Flux Luminous Flux Luminous Flux Luminous Flux 1) page 18 1) page 18 5) page 18 5) page 18 Lichtstrom Lichtstrom Lichtstrom Lichtstrom 1) Seite 18 1) Seite 18 5) Seite 18 5) Seite 18 TS = 85 °C TS = 85 °C TS = 25 °C TS = 25 °C (min.) ΦV [lm] (max.) ΦV [lm] (extrapolated min.) ΦV [lm] (extrapolated max.) ΦV [lm] SQ 1940 2100 2170 2350 SR 2100 2240 2350 2510 SS 2240 2400 2510 2690 ST 2400 2590 2690 2900 Gruppe Note: The standard shipping format for serial types includes either a lower family group, an upper family group or a grouping of all individual brightness groups of only a few brightness groups. Individual brightness groups cannot be ordered. Anm.: Die Standardlieferform von Serientypen beinhaltet entweder eine untere Familiengruppe, eine obere Familiengruppe oder eine Sammelgruppe, die aus nur wenigen Helligkeitsgruppen besteht. Einzelne Helligkeitsgruppen sind nicht bestellbar. 2015-12-10 5 Version 1.3 GW KAHJB1.CM Chromaticity Coordinate Groups 5) page 17 Farbortgruppen 5) Seite 17 Color Chromaticity Groups 5) page 17 Farbortgruppen 5) Seite 17 Group Cx Cy a b Θ 40S3 0.3823 0.3790 0.0094 0.0040 53 35S3 0.4077 0.3908 0.0093 0.0041 53 30S3 0.4339 0.4020 0.0085 0.0041 53 27S3 0.4578 0.4092 0.0079 0.0041 54 35B3 0.4035 0.3837 0.0093 0.0041 54 30B3 0.4300 0.3950 0.0083 0.0041 53 27B3 0.4540 0.4021 0.0081 0.0042 54 Note: Cx and Cy are the center coordinates of the ellipse, a the length of the major axis, b the length of the minor axis and Θ the angle of the major axis as defined in IEC 60081. Cx und Cy sind die Mittelpunktkoordinaten der Ellipse, a die Länge der Hauptachse, b die Länge der Nebenachse und Θ der Winkel der Hauptachse wie in IEC 60081 definiert. 2015-12-10 6 Version 1.3 GW KAHJB1.CM Group Name on Label Gruppenbezeichnung auf Etikett Example: SQ-27S3 Beispiel: SQ-27S3 Brightness Helligkeit Chromaticity Coordinate Farbort SQ 27S3 Note: No packing unit / tape ever contains more than one group for each selection. Anm.: In einer Verpackungseinheit / Gurt ist immer nur eine Gruppe für jede Selektion enthalten. 2015-12-10 7 Version 1.3 GW KAHJB1.CM Relative Spectral Emission - V(λ) = Standard eye response curve 7) page 19 Relative spektrale Emission - V(λ) = spektrale Augenempfindlichkeit 7) Seite 19 Φrel = f (λ); TS = 85 °C; IF = 500 mA Irel GW KAHJB1.CM 1,0 : Vλ 0,8 0,6 0,4 0,2 0,0 350 400 450 500 550 600 650 700 750 800 λ [nm] Radiation Characteristics 7) page 19 Abstrahlcharakteristik 7) Seite 19 Irel = f (ϕ); TS = 85 °C GW KAHJB1.CM ϕ [°] -10° 0° 10° -20° 20° 30° 40° 50° 60° 70° 80° 90° 1,0 -30° -40° 0,8 -50° 0,6 -60° 0,4 -70° 0,2 -80° 0,0 -90° -100° 2015-12-10 8 Irel Version 1.3 GW KAHJB1.CM Forward Current 6) page 18 , 7) page 18 Durchlassstrom 6) Seite 18 , 7) Seite 18 IF = f (VF); TS = 85 °C IF [mA] Relative Luminous Flux 6) page 18 , 7) page 18 Relativer Lichtstrom 6) Seite 18 , 7) Seite 18 ΦV/ΦV(500 mA) = f(IF); TS = 85 °C ΦV GW KAHJB1.EM 700 ΦV(500mA) 600 1.2 500 1.0 400 0.8 300 0.6 0.4 200 0.2 100 0.0 0 40 42 44 46 48 0 50 Chromaticity Coordinate Shift 6) page 18 Farbortverschiebung 6) Seite 18 Cx, Cy = f(IF); TS = 85 °C GW KAHJB1.CM Cx 0,44 Cy 0,43 0,42 0,41 0,40 : Cx - White : Cy - White 0 0 10 0 20 0 30 0 40 0 50 0 60 0 10 20 0 0 30 0 40 50 0 0 60 0 70 IF [mA] VF [V] 0 70 IF [mA] 2015-12-10 GW KAHJB1.EM 1.4 9 Version 1.3 GW KAHJB1.CM Relative Forward Voltage 6) page 18 Relative Vorwärtsspannung 6) Seite 18 ΔVF = VF - VF(85 °C) = f(Tj); IF = 500 mA Relative Luminous Flux 6) page 18 Relativer Lichtstrom 6) Seite 18 ΦV/ΦV(85 °C) = f(Tj); IF = 500 mA GW KAHJB1.EM Φv ∆VF [V] GW KAHJB1.CM 1,4 Φv(85°C) 4 1,2 3 1,0 0,8 2 0,6 1 0,4 0 0,2 -1 -40 -20 0 20 40 60 80 0,0 -40 -20 100 120 Tj [°C] GW KAHJB1.CM Cx 0,44 Cy 0,43 0,42 0,41 0,40 : Cx - White : Cy - White 0 20 40 60 80 100 120 Tj [°C] 2015-12-10 20 40 60 80 100 120 Tj [°C] Chromaticity Coordinate Shift 6) page 18 Farbortverschiebung 6) Seite 18 Cx, Cy = f(Tj); IF = 500 mA 0,39 -40 -20 0 10 Version 1.3 GW KAHJB1.CM Max. Permissible Forward Current Max. zulässiger Durchlassstrom IF = f (T) IF [A] GW KAHJB1.CM 800 700 600 500 : Ts 400 300 200 100 Do not use below 90 mA 0 0 20 40 60 80 100 120 T [°C] 2015-12-10 11 Version 1.3 GW KAHJB1.CM Package Outline 9) page 19 Maßzeichnung 9) Seite 19 Approximate Weight: 1.4 g Gewicht: 1.4 g ESD information: LED is protected by ESD device which is connected in parallel to LED-Chip. ESD Information: Die LED enthält ein ESD-Bauteil, das parallel zum Chip geschaltet ist. 2015-12-10 12 Version 1.3 GW KAHJB1.CM Tray Bauteilträger Min. 40 pcs. per packing unit (20 units per tray, min. 2 trays per vacuum bag) / 20 Teile pro Bauteilträger, 2 Bauteilträger pro Vakuumverpackung Barcode-Product-Label (BPL) Barcode-Produkt-Etikett (BPL) OSRAM Opto EX A RoHS Compliant (6P) BATCH NO: 1234567890 (1T) LOT NO: 1234567890 BIN1: XX-XX-X-XXX-X LX XXXX Semiconductors MP ML Temp ST X XXX °C X (9D) D/C: 1234 Pack: RXX LE DEMY XXX X_X123_1234.1234 X (X) PROD NO: 123456789(Q)QTY: 9999 (G) GROUP: XX-XX-X-X OHA04563 Note: Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card. Regarding dry pack you will find further information in the internet and in the Short Form Catalog in chapter “Tape and Reel” under the topic “Dry Pack”. Here you will also find the normative references like JEDEC. Anm.: Feuchteempfindliche Produkte sind verpackt in einem Trockenbeutel zusammen mit einem Trockenmittel und einer Feuchteindikatorkarte. Bezüglich Trockenverpackung finden Sie weitere Hinweise im Internet und in unserem Short Form Catalog im Kapitel “Gurtung und Verpackung” unter dem Punkt “Trockenverpackung”. Hier sind Normenbezüge, unter anderem ein Auszug der JEDEC-Norm, enthalten. 2015-12-10 13 Version 1.3 GW KAHJB1.CM Transportation Packing and Materials Kartonverpackung und Materialien Box MY DE 18 R +Q -1 -1 P P: GR OU 01 44 C: D/ D) (9 00 20 : (G ) M ul LS ti Y TO T6 P 76 LE Muster : (Q )Q TY m RA ic M on du O p ct to or NO s 12 34 Se BA TC H (6 P) NO : 12 5 14 2 110 0 (X ) PR OD NO : (1 T) LO T 3G H O S 8 2199 2100 D Bi Bin1 Bi n2 : Pn3 : Q- 1ML : 1- 20 20 2 Te 2a 22 mp 3 24 0 ST Ad 26 0 C R 0 C R0 dit ion C R PA 77 al RT CK TE VA XT R: Barcode label Original packing label OHA02886 Dimensions of transportation box in mm Width Length Height Breite Länge Höhe 333 ± 5 218 ± 5 28 ± 5 2015-12-10 14 Version 1.3 GW KAHJB1.CM Notes Hinweise The evaluation of eye safety occurs according to the standard IEC 62471:2008 ("photobiological safety of lamps and lamp systems"). Within the risk grouping system of this CIE standard, the LED specified in this data sheet fall into the class Low risk (exposure time 100 s). Under real circumstances (for exposure time, eye pupils, observation distance), it is assumed that no endangerment to the eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light sources have a high secondary exposure potential due to their blinding effect. As is also true when viewing other bright light sources (e.g. spotlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation. Die Bewertung der Augensicherheit erfolgt nach dem Standard IEC 62471:2008 ("photobiological safety of lamps and lamp systems"). Im Risikogruppensystem dieser CIE- Norm erfüllen die in diesem Datenblatt angegebenen LEDs folgende Gruppenanforderung - Low risk (Expositionsdauer 100 s). Unter realen Umständen (für Expositionsdauer, Augenpupille, Betrachtungsabstand) geht damit von diesen Bauelementen keinerlei Augengefährdung aus. Grundsätzlich sollte jedoch erwähnt werden, dass intensive Lichtquellen durch ihre Blendwirkung ein hohes sekundäres Gefahrenpotenzial besitzen. Nach einem Blick in eine helle Lichtquelle (z.B. Spotlights), kann ein temporär eingeschränktes Sehvermögen oder auch Nachbilder zu Irritationen, Belästigungen, Beeinträchtigungen oder sogar Unfällen führen. This LED contains metal materials. Corroded metal may lead to a worsening of the optical performance of the LED and can in the worst case lead to a failure of the LED. Do not expose this LED to aggressive atmospheres. Note, that corrosive gases may as well be emitted from materials close to the LED in the final product. Diese LED enthält teilweise metallische Bestandteile. Korrodiertes Metall kann zu einer Verschlechterung der optischen Eigenschaften und im schlimmsten Fall zum Ausfall der LED führen. Diese LED darf aggressiven Bedingungen nicht ausgesetzt werden. Es ist zu beachten, dass korrosive Gase auch von Materialien emittiert werden können, die sich im Endprodukt in unmittelbarer Umgebung der LED befinden. This LED is designed for specific/recommended applications only. Please consult OSRAM Opto Semiconductors Sales Staff in advance for detailed information on other non-recommended applications (e.g. automotive) OR Please visit www.osram-os.com/appnotes. Change management for this component is aligned with the requirements of the lighting market. Die LED ist ausschließlich für spezifisch empfohlene Anwendungen konzipiert. Bitte kontaktieren Sie das OSRAM Opto Semiconductors Vertriebspersonal für detailierte Informationen über nicht empfohlene Anwendungsbereiche (z.B. Automobilbereich). oder besuchen Sie www.osram-os.com/appnotes Das Änderungsmanagement dieses Bauteils ist an den Anforderungen des Lichtmarktes ausgerichtet. 2015-12-10 15 Version 1.3 GW KAHJB1.CM Disclaimer Disclaimer Language english will prevail in case of any discrepancies or deviations between the two language wordings. Bei abweichenden Angaben im zweisprachigen Wortlaut haben die Angaben in englischer Sprache Vorrang. Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version in the Internet. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Components used in life-support devices or systems must be expressly authorized for such purpose! Critical components* may only be used in life-support devices** or systems with the express written approval of OSRAM OS. Bitte beachten! Lieferbedingungen und Änderungen im Design vorbehalten. Aufgrund technischer Anforderungen können die Bauteile Gefahrstoffe enthalten. Für weitere Informationen zu gewünschten Bauteilen, wenden Sie sich bitte an unseren Vertrieb. Falls Sie dieses Datenblatt ausgedruckt oder heruntergeladen haben, finden Sie die aktuellste Version im Internet. Verpackung Benutzen Sie bitte die Ihnen bekannten Recyclingwege. Wenn diese nicht bekannt sein sollten, wenden Sie sich bitte an das nächstgelegene Vertriebsbüro. Wir nehmen das Verpackungsmaterial zurück, falls dies vereinbart wurde und das Material sortiert ist. Sie tragen die Transportkosten. Für Verpackungsmaterial, das unsortiert an uns zurückgeschickt wird oder das wir nicht annehmen müssen, stellen wir Ihnen die anfallenden Kosten in Rechnung. Bauteile, die in lebenserhaltenden Apparaten und Systemen eingesetzt werden, müssen für diese Zwecke ausdrücklich zugelassen sein! Kritische Bauteile* dürfen in lebenserhaltenden Apparaten und Systemen** nur dann eingesetzt werden, wenn ein schriftliches Einverständnis von OSRAM OS vorliegt. *) A critical component is a component used in a life-support device or system whose failure can reasonably be expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that device or system. **) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be endangered. 2015-12-10 *) Ein kritisches Bauteil ist ein Bauteil, das in lebenserhaltenden Apparaten oder Systemen eingesetzt wird und dessen Defekt voraussichtlich zu einer Fehlfunktion dieses lebenserhaltenden Apparates oder Systems führen wird oder die Sicherheit oder Effektivität dieses Apparates oder Systems beeinträchtigt. **) Lebenserhaltende Apparate oder Systeme sind für (a) die Implantierung in den menschlichen Körper oder (b) für die Lebenserhaltung bestimmt. Falls Sie versagen, kann davon ausgegangen werden, dass die Gesundheit und das Leben des Patienten in Gefahr ist. 16 Version 1.3 GW KAHJB1.CM Glossary Glossar 1) Brightness: Brightness values are measured during a current pulse of typically 10 ms, with a tolerance of ± 7 %. 1) Helligkeit: Helligkeitswerte werden während eines Strompulses einer typischen Dauer von 10 ms, mit einer Genauigkeit von ± 7 % ermittelt. 2) Forward Voltage: The forward voltage is measured during a current pulse duration of typically 1 ms with a tolerance of ± 0.05 V. 2) Durchlassspannung: Spannungswerte werden mit einer Stromeinprägedauer von 1 ms, mit einer Genauigkeit von ± 0.05 V ermittelt. 3) Characteristic curve: In the range where the line of the graph is broken, you must expect higher differences between single LEDs within one packing unit. 3) Kennlinien: Im gestrichelten Bereich der Kennlinien muss mit erhöhten Abweichungen zwischen Leuchtdioden innerhalb einer Verpackungseinheit gerechnet werden. 4) Color reproduction index: Color reproduction index values (CRI-RA) are measured during a current pulse of typically 10 ms and with a tolerance of ± 2. 4) Farbwiedergabe Index: Werte des Farbwiedergabe Index (CRI-RA) werden während eines Strompulses einer typischen Dauer von 10 ms, mit einer Genauigkeit ± 2 ermittelt. 5) Thermal Resistance: Rth max is based on statistic values (6σ). 5) Wärmewiderstand: Rth statistischen Werten (6σ). 6) Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 6) Typische Werte: Wegen der besonderen Prozessbedingungen bei der Herstellung von LED können typische oder abgeleitete technische Parameter nur aufgrund statistischer Werte wiedergegeben werden. Diese stimmen nicht notwendigerweise mit den Werten jedes einzelnen Produktes überein, dessen Werte sich von typischen und abgeleiteten Werten oder typischen Kennlinien unterscheiden können. Falls erforderlich, z.B. aufgrund technischer Verbesserungen, werden diese typischen Werte ohne weitere Ankündigung geändert. 7) Chromaticity coordinate groups: Chromaticity coordinate groups are measured during a current pulse duration of typically 10 ms with a tolerance of ±0.005. 7) 8) Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and dimensions are specified in mm. 8) 2015-12-10 17 max basiert auf Farbortgruppen: Farbortgruppen werden mit einer Stromeinprägedauer von 10 ms, mit einer Genauigkeit von ±0.005 ermittelt. Maßtoleranz: Wenn in der Zeichnung nicht anders angegeben, gilt eine Toleranz von ±0,1. Maße werden in mm angegeben. Version 1.3 GW KAHJB1.CM Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 2015-12-10 18
GWKAHJB1.CM-SRSS-35S3 价格&库存
很抱歉,暂时无法提供与“GWKAHJB1.CM-SRSS-35S3”相匹配的价格&库存,您可以联系我们找货
