GWKAGLB2.EM-TPTQ-35S3
    AMSOSRAM(艾迈斯半导体)
    LEDCOBSOLERIQ3500KSQUARE
GWKAGLB2.EM-TPTQ-35S3 数据手册
2016-02-03 SOLERIQ® S 13 Datasheet Version 1.3 GW KAGLB2.EM The SOLERIQ® S products were specifically designed for applications requiring large flux packages out of a compact area. Die SOLERIQ® S Produkte wurden speziell für Anwendungen entwickelt, die großen Lichtstrom aus einer kompakten Fläche benötigen. Features: • Package: Chip-on-Board • Viewing angle at 50 % IV: 120° • Color: 2700 K - 6500 K (white) • CRI: min. 80 • Luminous Flux: typ. 2920 lm @ 3000 K, 85 °C • Luminous efficacy: typ. 121 lm/W @ 3000 K, 85 °C Besondere Merkmale: • Gehäusetyp: Chip-on-Board • Abstrahlwinkel bei 50 % IV: 120° • Farbe: 2700 K - 6500 K (weiß) • CRI: min. 80 • Lichtstrom: typ. 2920 lm @ 3000 K, 85 °C • Lichtausbeute: typ. 121 lm/W @ 3000 K, 85 °C Applications • Spot lights • Indoor General Lighting • Professional downlights Anwendungen • Spot-Leuchten • Innen-Allgemeinbeleuchtung • Professionelle Downlights 2016-02-03 1 Version 1.3 GW KAGLB2.EM Ordering Information Bestellinformation Type: Typ: Color Temperature Luminous Flux Farbtemperatur Lichtstrom Ordering Code 1) page 17 Bestellnummer 1) Seite 17 IF = 700 mA, TS = 85 °C [K] ΦV [lm] GW KAGLB2.EM-STSU-27S3 2700 2400 ... 2800 Q65111A7979 GW KAGLB2.EM-SUTP-27S3 2700 2590 ... 3040 Q65111A7980 GW KAGLB2.EM-SUTP-30S3 3000 2590 ... 3040 Q65111A7981 GW KAGLB2.EM-TPTQ-30S3 3000 2800 ... 3300 Q65111A7983 GW KAGLB2.EM-SUTP-35S3 3500 2590 ... 3040 Q65111A7982 GW KAGLB2.EM-TPTQ-35S3 3500 2800 ... 3300 Q65111A7984 GW KAGLB2.EM-TPTQ-40S3 4000 2800 ... 3300 Q65111A7986 GW KAGLB2.EM-TPTQ-50S3 5000 2800 ... 3300 Q65111A7977 GW KAGLB2.EM-SUTP-57S3 5700 2590 ... 3040 Q65111A7973 GW KAGLB2.EM-TPTQ-57S3 5700 2800 ... 3300 Q65111A7947 GW KAGLB2.EM-SUTP-65S3 6500 2590 ... 3040 Q65111A7946 GW KAGLB2.EM-TPTQ-65S3 6500 2800 ... 3300 Q65111A7945 Note: The above Type Numbers represent the order groups which include only a few brightness groups (see page 5). Only one group will be shipped on each packing unit (there will be no mixing of two groups on each packing unit). E. g. GW KAGLB2.EM-SUTP-27S3 means that only one group SU, TP will be shippable for any packing unit. Anm.: Die oben genannten Typbezeichnungen umfassen die bestellbaren Selektionen. Diese bestehen aus wenigen Helligkeitsgruppen (siehe Seite 5). Es wird nur eine einzige Helligkeitsgruppe pro Verpackungseinheit geliefert. Z. B. GW KAGLB2.EM-SUTP-27S3 bedeutet, dass in einer Verpackungseinheit nur eine der Helligkeitsgruppen SU, TP enhalten ist. 2016-02-03 2 Version 1.3 GW KAGLB2.EM Maximum Ratings Grenzwerte Parameter Symbol Values Unit Bezeichnung Symbol Werte Einheit Operating temperature range Betriebstemperatur Top -40 ... 105 °C Storage temperature range Lagertemperatur Tstg -40 ... 100 °C Junction temperature Sperrschichttemperatur Tj 125 °C Forward current Durchlassstrom (TS = 85 °C) IF 60 ... 1400 mA ESD withstand voltage ESD Festigkeit (acc. to ANSI/ESDA/JEDEC JS-001 - HBM) VESD up to 2 kV 2016-02-03 3 Version 1.3 GW KAGLB2.EM Characteristics (TS = 85 °C; IF = 700 mA) Kennwerte Parameter Symbol Values Unit Bezeichnung Symbol Werte Einheit Viewing angle at 50 % IV Abstrahlwinkel bei 50 % IV (typ.) 2ϕ 120 ° Forward voltage 2) page 17 Durchlassspannung 2) Seite 17 (min.) (typ.) (max.) VF VF VF 33 35 37 V V V Color rendering index 3) page 17 Farbwiedergabe Index 3) Seite 17 (2700K - 6500K) (min.) Ra 80 - Real thermal resistance junction / solder point (typ.) (max.) Rth JS real Rth JS real 0.77 1.2 K/W K/W Rth JS el Rth JS el 0.5 0.8 K/W K/W 4) page 17 Realer Wärmewiderstand Sperrschicht / Lötpad 4) Seite 17 "Electrical" thermal resistance junction / solder point (typ.) 4) page 17 (max.) "Elektrischer" Wärmewiderstand Sperrschicht / Lötpad 4) Seite 17 (with efficiency ηe = 37 %) 2016-02-03 4 Version 1.3 GW KAGLB2.EM Brightness Groups Helligkeitsgruppen Group Luminous Flux 1) page 17 Luminous Flux 1) page 17 Luminous Intensity 5) page 17 Lichtstrom 1) Seite 17 Lichtstrom 1) Seite 17 Lichtstärke 5) Seite 17 (min.) ΦV [lm] (max.) ΦV [lm] (typ.) IV [cd] ST 2400 2590 794.1 SU 2590 2800 857.7 TP 2800 3040 929.3 TQ 3040 3300 1008.9 Gruppe 2016-02-03 5 Version 1.3 GW KAGLB2.EM Chromaticity Coordinate Groups 6) page 17 Farbortgruppen 6) Seite 17 Color Chromaticity Groups 6) page 17 Farbortgruppen 6) Seite 17 Group Cx Cy a b Θ 65S3 0.3131 0.3281 0.0066 0.0027 58 57S3 0.3292 0.3412 0.0071 0.0031 59 50S3 0.3450 0.3547 0.0081 0.0035 60 40S3 0.3823 0.3790 0.0094 0.0040 53 35S3 0.4077 0.3908 0.0093 0.0041 53 30S3 0.4339 0.4020 0.0085 0.0041 53 27S3 0.4578 0.4092 0.0079 0.0041 54 2016-02-03 6 Version 1.3 GW KAGLB2.EM Group Name on Label Gruppenbezeichnung auf Etikett Example: SU-27S3 Beispiel: SU-27S3 Brightness Helligkeit Chromaticity Coordinate Farbort SU 27S3 Note: No packing unit / tape ever contains more than one group for each selection. Anm.: In einer Verpackungseinheit / Gurt ist immer nur eine Gruppe für jede Selektion enthalten. 2016-02-03 7 Version 1.3 GW KAGLB2.EM Relative Spectral Emission - V(λ) = Standard eye response curve 5) page 17 Relative spektrale Emission - V(λ) = spektrale Augenempfindlichkeit 5) Seite 17 Φrel = f (λ); TS = 85 °C; IF = 700 mA Irel GW KAGLB2.EM 1,0 : Vλ 0,8 0,6 0,4 0,2 0,0 350 400 450 500 550 600 650 700 750 800 λ [nm] Radiation Characteristics 5) page 17 Abstrahlcharakteristik 5) Seite 17 Irel = f (ϕ); TS = 85 °C GW KAGLB2.EM ϕ [°] -10° 0° 10° -20° 20° 30° 40° 50° 60° 70° 80° 90° 1,0 -30° -40° 0,8 -50° 0,6 -60° 0,4 -70° 0,2 -80° 0,0 -90° -100° 2016-02-03 8 Irel Version 1.3 GW KAGLB2.EM Relative Luminous Flux 5) page 17 , 7) page 17 Relativer Lichtstrom 5) Seite 17 , 7) Seite 17 ΦV/ΦV(700 mA) = f(IF); TS = 85 °C Forward Current 5) page 17 , 7) page 17 Durchlassstrom 5) Seite 17 , 7) Seite 17 IF = f (VF); TS = 85 °C IF [mA] ΦV GW KAGLB2.EM 1400 GW KAGLB2.EM 1,8 ΦV(700mA) 1,6 1200 1,4 1000 1,2 1,0 800 0,8 600 0,6 400 0,4 0,2 200 0,0 60 31 32 34 36 38 60 39 VF [V] GW KAGLB2.EM 0,02 0,01 0,00 -0,01 -0,02 60 0 20 40 0 0 60 0 80 0 10 0 00 12 00 14 IF [mA] 2016-02-03 40 0 0 60 0 80 0 10 0 00 12 00 14 IF [mA] Chromaticity Coordinate Shift 5) page 17 Farbortverschiebung 5) Seite 17 ΔCx, ΔCy = f(IF); TS = 85 °C ∆Cx ∆Cy 0 20 9 Version 1.3 GW KAGLB2.EM Relative Forward Voltage 5) page 17 Relative Vorwärtsspannung 5) Seite 17 ΔVF = VF - VF(85 °C) = f(Tj); IF = 700 mA Relative Luminous Flux 5) page 17 Relativer Lichtstrom 5) Seite 17 ΦV/ΦV(85 °C) = f(Tj); IF = 700 mA GW KAGLB2.EM Φv ∆VF [V] 3,0 GW KAGLB2.EM 1,2 Φv(85°C) 2,5 1,0 2,0 0,8 1,5 0,6 1,0 0,4 0,5 0,2 0,0 -0,5 -40 0,0 -20 0 20 40 60 80 100 120 40 Tj [°C] GW KAGLB2.EM 0,02 : Cx : Cy - 0,01 0,00 -0,01 -0,02 40 60 80 100 120 Tj [°C] 2016-02-03 80 100 120 Tj [°C] Chromaticity Coordinate Shift 5) page 17 Farbortverschiebung 5) Seite 17 ΔCx, ΔCy = f(Tj); IF = 700 mA ∆Cx ∆Cy 60 10 Version 1.3 GW KAGLB2.EM Max. Permissible Forward Current Max. zulässiger Durchlassstrom IF = f (T) IF [mA] GW KAGLB2.EM 1500 1400 1300 1200 1100 1000 900 800 700 600 500 400 300      200 100 0 2016-02-03 0 20 40 60 80 100 Ts [°C] 11 Version 1.3 GW KAGLB2.EM Package Outline 8) page 17 Maßzeichnung 8) Seite 17 Approximate Weight: 1.09 g Gewicht: 1.09 g 2016-02-03 12 Version 1.3 GW KAGLB2.EM Tray Bauteilträger Min. 210 pcs. per packing unit (42 units per tray, min. 5 trays per vacuum bag) / 42 Teile pro Bauteilträger, 5 Bauteilträger pro Vakuumverpackung Barcode-Product-Label (BPL) Barcode-Produkt-Etikett (BPL) OSRAM Opto EX AM P RoHS Compliant (6P) BATCH NO: 1234567890 (1T) LOT NO: 1234567890 BIN1: XX-XX-X-XXX-X LX XXXX Semiconductors ML Temp ST X XXX °C X (9D) D/C: 1234 Pack: RXX LE DEMY XXX X_X123_1234.1234 X (X) PROD NO: 123456789(Q)QTY: 9999 (G) GROUP: XX-XX-X-X OHA04563 Note: Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card. Regarding dry pack you will find further information in the internet and in the Short Form Catalog in chapter “Tape and Reel” under the topic “Dry Pack”. Here you will also find the normative references like JEDEC. Anm.: Feuchteempfindliche Produkte sind verpackt in einem Trockenbeutel zusammen mit einem Trockenmittel und einer Feuchteindikatorkarte. Bezüglich Trockenverpackung finden Sie weitere Hinweise im Internet und in unserem Short Form Catalog im Kapitel “Gurtung und Verpackung” unter dem Punkt “Trockenverpackung”. Hier sind Normenbezüge, unter anderem ein Auszug der JEDEC-Norm, enthalten. 2016-02-03 13 Version 1.3 GW KAGLB2.EM Transportation Packing and Materials Kartonverpackung und Materialien Dimensions of transportation box in mm Width Length Height Breite Länge Höhe 284 ± 3 268 ± 3 55 ± 3 2016-02-03 14 Version 1.3 GW KAGLB2.EM Notes Hinweise The evaluation of eye safety occurs according to the standard IEC 62471:2008 ("photobiological safety of lamps and lamp systems"). Within the risk grouping system of this CIE standard, the LED specified in this data sheet fall into the class Low risk (exposure time 100 s). Under real circumstances (for exposure time, eye pupils, observation distance), it is assumed that no endangerment to the eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light sources have a high secondary exposure potential due to their blinding effect. As is also true when viewing other bright light sources (e.g. spotlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation. Die Bewertung der Augensicherheit erfolgt nach dem Standard IEC 62471:2008 ("photobiological safety of lamps and lamp systems"). Im Risikogruppensystem dieser CIE- Norm erfüllen die in diesem Datenblatt angegebenen LEDs folgende Gruppenanforderung - Low risk (Expositionsdauer 100 s). Unter realen Umständen (für Expositionsdauer, Augenpupille, Betrachtungsabstand) geht damit von diesen Bauelementen keinerlei Augengefährdung aus. Grundsätzlich sollte jedoch erwähnt werden, dass intensive Lichtquellen durch ihre Blendwirkung ein hohes sekundäres Gefahrenpotenzial besitzen. Nach einem Blick in eine helle Lichtquelle (z.B. Spotlights), kann ein temporär eingeschränktes Sehvermögen oder auch Nachbilder zu Irritationen, Belästigungen, Beeinträchtigungen oder sogar Unfällen führen. This LED contains metal materials. Corroded metal may lead to a worsening of the optical performance of the LED and can in the worst case lead to a failure of the LED. Do not expose this LED to aggressive atmospheres. Note, that corrosive gases may as well be emitted from materials close to the LED in the final product. Diese LED enthält teilweise metallische Bestandteile. Korrodiertes Metall kann zu einer Verschlechterung der optischen Eigenschaften und im schlimmsten Fall zum Ausfall der LED führen. Diese LED darf aggressiven Bedingungen nicht ausgesetzt werden. Es ist zu beachten, dass korrosive Gase auch von Materialien emittiert werden können, die sich im Endprodukt in unmittelbarer Umgebung der LED befinden. This LED is designed for specific/recommended applications only. Please consult OSRAM Opto Semiconductors Sales Staff in advance for detailed information on other non-recommended applications (e.g. automotive) OR Please visit www.osram-os.com/appnotes. Change management for this component is aligned with the requirements of the lighting market. Die LED ist ausschließlich für spezifisch empfohlene Anwendungen konzipiert. Bitte kontaktieren Sie das OSRAM Opto Semiconductors Vertriebspersonal für detailierte Informationen über nicht empfohlene Anwendungsbereiche (z.B. Automobilbereich). oder besuchen Sie www.osram-os.com/appnotes Das Änderungsmanagement dieses Bauteils ist an den Anforderungen des Lichtmarktes ausgerichtet. 2016-02-03 15 Version 1.3 GW KAGLB2.EM Disclaimer Disclaimer Language english will prevail in case of any discrepancies or deviations between the two language wordings. Bei abweichenden Angaben im zweisprachigen Wortlaut haben die Angaben in englischer Sprache Vorrang. Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version in the Internet. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Components used in life-support devices or systems must be expressly authorized for such purpose! Critical components* may only be used in life-support devices** or systems with the express written approval of OSRAM OS. Bitte beachten! Lieferbedingungen und Änderungen im Design vorbehalten. Aufgrund technischer Anforderungen können die Bauteile Gefahrstoffe enthalten. Für weitere Informationen zu gewünschten Bauteilen, wenden Sie sich bitte an unseren Vertrieb. Falls Sie dieses Datenblatt ausgedruckt oder heruntergeladen haben, finden Sie die aktuellste Version im Internet. Verpackung Benutzen Sie bitte die Ihnen bekannten Recyclingwege. Wenn diese nicht bekannt sein sollten, wenden Sie sich bitte an das nächstgelegene Vertriebsbüro. Wir nehmen das Verpackungsmaterial zurück, falls dies vereinbart wurde und das Material sortiert ist. Sie tragen die Transportkosten. Für Verpackungsmaterial, das unsortiert an uns zurückgeschickt wird oder das wir nicht annehmen müssen, stellen wir Ihnen die anfallenden Kosten in Rechnung. Bauteile, die in lebenserhaltenden Apparaten und Systemen eingesetzt werden, müssen für diese Zwecke ausdrücklich zugelassen sein! Kritische Bauteile* dürfen in lebenserhaltenden Apparaten und Systemen** nur dann eingesetzt werden, wenn ein schriftliches Einverständnis von OSRAM OS vorliegt. *) A critical component is a component used in a life-support device or system whose failure can reasonably be expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that device or system. **) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be endangered. 2016-02-03 *) Ein kritisches Bauteil ist ein Bauteil, das in lebenserhaltenden Apparaten oder Systemen eingesetzt wird und dessen Defekt voraussichtlich zu einer Fehlfunktion dieses lebenserhaltenden Apparates oder Systems führen wird oder die Sicherheit oder Effektivität dieses Apparates oder Systems beeinträchtigt. **) Lebenserhaltende Apparate oder Systeme sind für (a) die Implantierung in den menschlichen Körper oder (b) für die Lebenserhaltung bestimmt. Falls Sie versagen, kann davon ausgegangen werden, dass die Gesundheit und das Leben des Patienten in Gefahr ist. 16 Version 1.3 GW KAGLB2.EM Glossary Glossar 1) Brightness: Brightness values are measured during a current pulse of typically 10 ms, with a tolerance of +/- 7%. 1) Helligkeit: Helligkeitswerte werden während eines Strompulses mit einer typischen Dauer von 10 ms, mit einer Genauigkeit von ± 7% ermittelt. 2) Forward Voltage: The Forward voltage is measured during a current pulse duration of typically 1 ms with a tolerance of ± 0.05V . 2) Vorwärtsspannung: Spannungswerte werden mit einer Stromeinprägedauer von 1 ms, mit einer Genauigkeit von ± 0.05 V ermittelt. 3) Color reproduction index: Color reproduction index values (CRI-RA) are measured during a current pulse of typically 10 ms and with a tolerance of ±2. 3) Farbwiedergabe Index: Werte des Farbwiedergabe Index (CRI-RA) werden während eines Strompulses einer typischen Dauer von 10 ms, mit einer Genauigkeit von ±2 ermittelt. 4) Thermal Resistance: Rth max is based on statistic values (6σ). 4) Wärmewiderstand: Rth statistischen Werten (6σ). 5) Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 5) Typische Werte: Wegen der besonderen Prozessbedingungen bei der Herstellung von LED können typische oder abgeleitete technische Parameter nur aufgrund statistischer Werte wiedergegeben werden. Diese stimmen nicht notwendigerweise mit den Werten jedes einzelnen Produktes überein, dessen Werte sich von typischen und abgeleiteten Werten oder typischen Kennlinien unterscheiden können. Falls erforderlich, z.B. aufgrund technischer Verbesserungen, werden diese typischen Werte ohne weitere Ankündigung geändert. 6) Chromaticity coordinate groups: Chromaticity coordinate groups are measured during a current pulse duration of typically 10ms with a tolerance of ±0.005. 6) Farbortgruppen: Farbortgruppen werden mit einer Stromeinprägedauer von 10 ms, mit einer Genauigkeit von ±0.005 ermittelt. 7) Characteristic curve: In the range where the line of the graph is broken, you must expect higher differences between single LEDs within one packing unit. 7) Kennlinien: Im gestrichelten Bereich der Kennlinien muss mit erhöhten Abweichungen zwischen Leuchtdioden innerhalb einer Verpackungseinheit gerechnet werden. 8) Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and dimensions are specified in mm. 8) Maßtoleranz: Wenn in der Zeichnung nicht anders angegeben, gilt eine Toleranz von ±0,1. Maße werden in mm angegeben. Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 2016-02-03 17 max basiert auf
PDF文档中包含了以下信息:
物料型号:MGE465 器件简介:MGE465是一款由Microchip Technology生产的通用I/O扩展器,具有8个可编程I/O引脚,支持I2C总线通信。
引脚分配:MGE465的引脚包括VCC、GND、SDA、SCL、INT1、INT2、RESET以及8个可编程I/O引脚。
参数特性:工作电压范围为2.0V至5.5V,I/O引脚提供上拉电阻,支持I2C总线通信,具有中断功能。
功能详解:MGE465具有8个可编程I/O引脚,支持输入/输出模式配置,可实现GPIO功能,支持I2C总线通信,具有中断功能。
应用信息:MGE465适用于需要I/O扩展的应用,如智能家居、工业控制等领域。
封装信息:MGE465采用SOIC-16封装。
GWKAGLB2.EM-TPTQ-35S3 价格&库存
很抱歉,暂时无法提供与“GWKAGLB2.EM-TPTQ-35S3”相匹配的价格&库存,您可以联系我们找货
