CXA1310-0000-000F0UH40E3
    WOLFSPEED
    LED COB CXA1310 COOL WHT SQUARE
CXA1310-0000-000F0UH40E3 数据手册
PRELIMINARY - January 17, 2014 ® CLD-DS87 Rev 0 Product family data sheet ® Cree XLamp CXA1310 LED Table of Contents Product Description features The XLamp CXA1310 is Cree’s • Available in 4-step and 2-step Characteristics............................... 2 newest High Density (HD) LED EasyWhite bins at 2700 K, Operating Limits............................. 3 array, 3000 K, 3500 K, 4000 K and Flux Characteristics, EasyWhite 5000 K CCT Order Codes and Bins - 18 V............ 4 featuring a 6‑mm optical source and enabling lighting manufacturers to create a new generation of products that delivers the same intensity and light quality as 20‑W ceramic metal halide (CMH) at up to 50 percent lower power. The new HD class of CXA arrays provide unrivaled lumen density that can reduce system cost for the next generation of LED ® • Available in ANSI white bins at 4000 K and 5000 K CCT • Available in 70-, 80-, 90- and 93‑minimum CRI options • Forward voltage options: 18 V & 36 V CXA LED Design Guide Flux Characteristics, EasyWhite Order Codes and Bins - 36 V............ 6 Flux Characteristics, ANSI White Order Codes and Bins - 36 V............ 7 Relative Spectral Power Distribution.. 8 characterization Electrical Characteristics.................. 9 • Maximum drive current: • 115° viewing angle, uniform The Order Codes and Bins - 18 V............ 5 • 85 °C binning and 900 mA (18 V), 450 mA (36 V) spotlights. Flux Characteristics, ANSI White chromaticity profile Relative Luminous Flux...................10 Relative Luminous Flux...................11 Typical Spatial Distribution..............12 Performance Groups - Brightness.....12 provides basic information on the • Top-side solder connections Performance Groups - Chromaticity.. 13 requirements to use the CXA1310 • Thermocouple attach point Cree EasyWhite Bins Plotted on the LED • NEMA SSL-3 2011 standard flux 1931 CIE Color Space....................14 successfully in luminaire designs. 1 bins Cree ANSI White Bins Plotted on www.cree.com/Xlamp the 1931 CIE Color Space...............15 Bin and Order Code Formats...........16 Mechanical Dimensions..................17 Thermal Design.............................18 Notes...........................................19 Packaging.....................................20 1 Cree XLamp CXA LED Design Guide, Design Guide DG02, www.cree.com/ xlamp_app_notes/cxa_design_guide Copyright © 2013 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 XLamp CXA1310 LED PRELIMINARY - January 17, 2014 Characteristics Characteristics Viewing angle (FWHM) ESD withstand voltage (HBM per Mil-Std-883D) Unit degrees Minimum Typical Maximum 115 V 8000 DC forward current (18 V) mA 900* DC forward current (36 V) mA 450* Reverse current mA 0.1 Forward voltage (18 V, @ 700 mA, 85 °C) V Forward voltage (36 V, @ 350 mA, 85 °C) V * 18 42 Refer to the Operating Limits section. Copyright © 2013 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. 2 XLamp CXA1310 LED PRELIMINARY - January 17, 2014 Operating Limits The maximum current rating of the CXA1310 is dependent on the case temperature (Tc) when the LED has reached thermal equilibrium under steady-state operation. Please refer to the Mechanical Dimensions section on page 3 for the location of the Tc measurement point. CXA1310-18V 1000 900 800 If (mA) 700 600 18 V 500 400 300 200 100 0 0 25 50 75 100 125 150 Case Temperature (°C) CXA1310-36V 500 450 400 If (mA) 350 300 250 36 V 200 150 100 50 0 0 25 50 75 100 125 150 Case Temperature (°C) Copyright © 2013 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. 3 XLamp CXA1310 LED PRELIMINARY - January 17, 2014 Flux Characteristics, EasyWhite Order Codes and Bins - 18 V (If = 700 mA, TJ = 85 °C) The following tables provide order codes for XLamp CXA1310 LEDs. For a complete description of the order code nomenclature, please reference Bin and Order Code Formats (page 16). Base Order Codes Min. Luminous Flux @ 700 mA CRI CCT Range 5000 K 4000 K Min Typ 70 75 80 --- 90 95 70 75 80 --- 90 95 80 --- 93 95 80 --- 93 95 80 --- 93 95 3500 K 3000 K 2700 K Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* K2 1200 1344 K4 1290 1445 J4 1120 1255 K2 1200 1344 H2 900 1008 H4 970 1086 K2 1200 1344 K4 1290 1445 J4 1120 1255 K2 1200 1344 H2 900 1008 H4 970 1086 J2 1040 1165 J4 1120 1255 G4 840 941 H2 900 1008 J2 1040 1165 J4 1120 1255 G2 780 881 G4 840 941 H4 970 1086 J2 1040 1165 F4 730 831 G2 780 881 2-Step Order Code Chromaticity Region 50H 50H 50H 40H 40H 40H 35H 35H 30H 30H 27H 27H 4-Step Order Code Chromaticity Region CXA1310-0000-000F00K250H CXA1310-0000-000F00K450H CXA1310-0000-000F0HJ450H CXA1310-0000-000F0HK250H CXA1310-0000-000F0UH250H CXA1310-0000-000F0UH450H CXA1310-0000-000F00K240H CXA1310-0000-000F00K440H CXA1310-0000-000F0HJ440H CXA1310-0000-000F0HK240H CXA1310-0000-000F0UH240H CXA1310-0000-000F0UH440H CXA1310-0000-000F00J235H CXA1310-0000-000F00J435H CXA1310-0000-000F0YG435H CXA1310-0000-000F0YH235H CXA1310-0000-000F00J230H CXA1310-0000-000F00J430H CXA1310-0000-000F0YG230H CXA1310-0000-000F0YG430H CXA1310-0000-000F00H427H CXA1310-0000-000F00J227H CXA1310-0000-000F0YF427H CXA1310-0000-000F0YG227H 50F 50F 50F 40F 40F 40F 35F 35F 30F 30H 27F 27F CXA1310-0000-000F00K250F CXA1310-0000-000F00K450F CXA1310-0000-000F0HJ450F CXA1310-0000-000F0HK250F CXA1310-0000-000F0UH250F CXA1310-0000-000F0UH450F CXA1310-0000-000F00K240F CXA1310-0000-000F00K440F CXA1310-0000-000F0HJ440F CXA1310-0000-000F0HK240F CXA1310-0000-000F0UH240F CXA1310-0000-000F0UH440F CXA1310-0000-000F00J235F CXA1310-0000-000F00J435F CXA1310-0000-000F0YG435F CXA1310-0000-000F0YH235F CXA1310-0000-000F00J230F CXA1310-0000-000F00J430F CXA1310-0000-000F0YG230F CXA1310-0000-000F0YG430F CXA1310-0000-000F00H427F CXA1310-0000-000F00J227F CXA1310-0000-000F0YF427F CXA1310-0000-000F0YG227F Notes • * Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. Flux values @ 25 °C are calculated and for reference only. Copyright © 2013 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. 4 XLamp CXA1310 LED PRELIMINARY - January 17, 2014 Flux Characteristics, ANSI White Order Codes and Bins - 18 V (If = 700 mA, TJ = 85 °C) The following tables provide order codes for XLamp CXA1310 LEDs. For a complete description of the order code nomenclature, please reference Bin and Order Code Formats (page 16). CCT Range 5000 K 4000 K Base Order Codes Min. Luminous Flux @ 350 mA CRI Min Typ 70 75 80 --- 90 95 70 75 80 --- 90 95 Chromaticity Regions Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* K2 1200 1344 K4 1290 1445 J4 1120 1255 K2 1200 1344 H2 900 1008 H4 970 1086 K2 1200 1344 K4 1290 1445 J4 1120 1255 K2 1200 1344 H2 900 1008 H4 970 1086 3A0, 3B0, 3C0, 3D0 3A0, 3B0, 3C0, 3D0 3A0, 3B0, 3C0, 3D0 5A0, 5B0, 5C0, 5D0 5A0, 5B0, 5C0, 5D0 5A0, 5B0, 5C0, 5D0 Order Code CXA1310-0000-000F00K20E3 CXA1310-0000-000F00K40E3 CXA1310-0000-000F0HJ40E3 CXA1310-0000-000F0HK20E3 CXA1310-0000-000F0UH20E3 CXA1310-0000-000F0UH40E3 CXA1310-0000-000F00K20E5 CXA1310-0000-000F00K40E5 CXA1310-0000-000F0HJ40E5 CXA1310-0000-000F0HK20E5 CXA1310-0000-000F0UH20E5 CXA1310-0000-000F0UH40E5 Notes • * Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. Flux values @ 25 °C are calculated and for reference only. Copyright © 2013 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. 5 XLamp CXA1310 LED PRELIMINARY - January 17, 2014 Flux Characteristics, EasyWhite Order Codes and Bins - 36 V (If = 350 mA, TJ = 85 °C) The following tables provide order codes for XLamp CXA1310 LEDs. For a complete description of the order code nomenclature, please reference Bin and Order Code Formats (page 16). Base Order Codes Min. Luminous Flux @ 350 mA CRI CCT Range 5000 K 4000 K Min Typ 70 75 80 --- 90 95 70 75 80 --- 90 95 80 --- 93 95 80 --- 93 95 80 --- 93 95 3500 K 3000 K 2700 K Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* K2 1200 1344 K4 1290 1445 J4 1120 1255 K2 1200 1344 H2 900 1008 H4 970 1086 K2 1200 1344 K4 1290 1445 J4 1120 1255 K2 1200 1344 H2 900 1008 H4 970 1086 J2 1040 1165 J4 1120 1255 G4 840 941 H2 900 1008 J2 1040 1165 J4 1120 1255 G2 780 881 G4 840 941 H4 970 1086 J2 1040 1165 F4 730 831 G2 780 881 2-Step Order Code Chromaticity Region 50H 50H 50H 40H 40H 40H 35H 35H 30H 30H 27H 27H 4-Step Order Code Chromaticity Region CXA1310-0000-000N00K250H CXA1310-0000-000N00K450H CXA1310-0000-000N0HJ450H CXA1310-0000-000N0HK250H CXA1310-0000-000N0UH250H CXA1310-0000-000N0UH450H CXA1310-0000-000N00K240H CXA1310-0000-000N00K440H CXA1310-0000-000N0HJ440H CXA1310-0000-000N0HK240H CXA1310-0000-000N0UH240H CXA1310-0000-000N0UH440H CXA1310-0000-000N00J235H CXA1310-0000-000N00J435H CXA1310-0000-000N0YG435H CXA1310-0000-000N0YH235H CXA1310-0000-000N00J230H CXA1310-0000-000N00J430H CXA1310-0000-000N0YG230H CXA1310-0000-000N0YG430H CXA1310-0000-000N00H427H CXA1310-0000-000N00J227H CXA1310-0000-000N0YF427H CXA1310-0000-000N0YG227H 50F 50F 50F 40F 40F 40F 35F 35F 30F 30H 27F 27F CXA1310-0000-000N00K250F CXA1310-0000-000N00K450F CXA1310-0000-000N0HJ450F CXA1310-0000-000N0HK250F CXA1310-0000-000N0UH250F CXA1310-0000-000N0UH450F CXA1310-0000-000N00K240F CXA1310-0000-000N00K440F CXA1310-0000-000N0HJ440F CXA1310-0000-000N0HK240F CXA1310-0000-000N0UH240F CXA1310-0000-000N0UH440F CXA1310-0000-000N00J235F CXA1310-0000-000N00J435F CXA1310-0000-000N0YG435F CXA1310-0000-000N0YH235F CXA1310-0000-000N00J230F CXA1310-0000-000N00J430F CXA1310-0000-000N0YG230F CXA1310-0000-000N0YG430F CXA1310-0000-000N00H427F CXA1310-0000-000N00J227F CXA1310-0000-000N0YF427F CXA1310-0000-000N0YG227F Notes • * Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. Flux values @ 25 °C are calculated and for reference only. Copyright © 2013 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. 6 XLamp CXA1310 LED PRELIMINARY - January 17, 2014 Flux Characteristics, ANSI White Order Codes and Bins - 36 V (If = 350 mA, TJ = 85 °C) The following tables provide order codes for XLamp CXA1310 LEDs. For a complete description of the order code nomenclature, please reference Bin and Order Code Formats (page 16). CCT Range 5000 K 4000 K Base Order Codes Min. Luminous Flux @ 350 mA CRI Min Typ 70 75 80 --- 90 95 70 75 80 --- 90 95 Chromaticity Regions Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* K2 1200 1344 K4 1290 1445 J4 1120 1255 K2 1200 1344 H2 900 1008 H4 970 1086 K2 1200 1344 K4 1290 1445 J4 1120 1255 K2 1200 1344 H2 900 1008 H4 970 1086 3A0, 3B0, 3C0, 3D0 3A0, 3B0, 3C0, 3D0 3A0, 3B0, 3C0, 3D0 5A0, 5B0, 5C0, 5D0 5A0, 5B0, 5C0, 5D0 5A0, 5B0, 5C0, 5D0 Order Code CXA1310-0000-000N00K20E3 CXA1310-0000-000N00K40E3 CXA1310-0000-000N0HJ40E3 CXA1310-0000-000N0HK20E3 CXA1310-0000-000N0UH20E3 CXA1310-0000-000N0UH40E3 CXA1310-0000-000N00K20E5 CXA1310-0000-000N00K40E5 CXA1310-0000-000N0HJ40E5 CXA1310-0000-000N0HK20E5 CXA1310-0000-000N0UH20E5 CXA1310-0000-000N0UH40E5 Notes • * Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. Flux values @ 25 °C are calculated and for reference only. Copyright © 2013 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. 7 XLamp CXA1310 LED - January 17, 2014Hot Binned, Baby Relative PRELIMINARY Spectral Power Distribution - White, Relative Spectral Power Distribution (18 V, If = 700 ma; 36 V, If = 350 ma, Tj = 85 °C) The following graph is the result of a series of pulsed measurements at 350 mA for the 18-V CXA1310 LED and 700 mA for the 36-V CXA1310 LED and TJ = 85 °C. Relative Spectral Power 100% 90% 80% 70% 60% 5000K, 70 CRI 50% 4000K, 70 CRI 40% 3000K, 80 CRI 30% 3000K, 93 CRI 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Copyright © 2013 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. 8 XLamp CXA1310 LED PRELIMINARY - January 17, 2014 Electrical Characteristics The following graph is the result of a series of steady-state measurements. 20.0 19.5 18 V Voltage (V) 19.0 Tc = 25 °C 18.5 Tc = 55 °C 18.0 Tc = 85 °C 17.5 Tc = 105 °C 17.0 16.5 16.0 300 400 500 600 700 800 900 Current (mA) 40.0 39.0 36 V Voltage (V) 38.0 Tc = 25 °C 37.0 Tc = 55 °C Tc = 85 °C 36.0 Tc = 105 °C 35.0 34.0 33.0 150 200 250 300 350 400 450 Current (mA) Copyright © 2013 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. 9 XLamp CXA1310 LED PRELIMINARY - January 17, 2014 Relative Luminous Flux The relative luminous flux values provided below are the ratio of: • Measurements of CXA1310 at steady-state operation at the given conditions, divided by • Flux measured during binning, which is a pulsed measurement at 700 mA at TJ = 85 °C for the 18‑V CXA1310 LED. • For example, at steady-state operation of Tc = 55 °C, IF = 500 mA, the relative luminous flux ratio is 80% in the chart below. A CXA1310 LED that measures  lm during binning will deliver  lm ( * 0.8) at steady-state operation of Tc = 55 °C, IF = 500 mA. Relative Luminous Flux 160% 120% 18 V Tc = 25 °C Tc = 55 °C 80% Tc = 85 °C Tc = 105 °C 40% 0% 300 400 500 600 700 800 900 Current (mA) Copyright © 2013 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. 10 XLamp CXA1310 LED PRELIMINARY - January 17, 2014 Relative Luminous Flux The relative luminous flux values provided below are the ratio of: • Measurements of CXA1310 at steady-state operation at the given conditions, divided by • Flux measured during binning, which is a pulsed measurement at 350 mA at TJ = 85 °C for the 36‑V CXA1310 LED. • For example, at steady-state operation of Tc = 55 °C, IF = 250 mA, the relative luminous flux ratio is 80% in the chart below. A CXA1310 LED that measures  lm during binning will deliver  lm ( * 0.8) at steady-state operation of Tc = 55 °C, IF = 250 mA. Relative Luminous Flux 160% 120% 36 V Tc = 25 °C Tc = 55 °C 80% Tc = 85 °C Tc = 105 °C 40% 0% 150 200 250 300 350 400 450 Current (mA) Copyright © 2013 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. 11 XLamp CXA1310 LED PRELIMINARY - January 17, 2014 Typical Spatial Distribution Relative Luminous Intensity 100% 80% 60% 40% 20% -90 -70 -50 -30 0% -10 10 30 50 70 90 Angle (º) Performance Groups - Brightness (18 V, If = 700 ma; 36 V, If = 350 ma, Tj = 85 °C) XLamp CXA1310 LEDs are tested for luminous flux and placed into one of the following bins. Group Code Min. Luminous Flux F4 730 Max. Luminous Flux 780 G2 780 840 G4 840 900 H2 900 970 H4 970 1040 J2 1040 1120 J4 1120 1200 K2 1200 1290 K4 1290 1380 Copyright © 2013 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. 12 XLamp CXA1310 LED PRELIMINARY - January 17, 2014 Performance Groups - Chromaticity (Tj = 85 °C) XLamp CXA1310 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. EasyWhite Color Temperatures – 4-Step EasyWhite Color Temperatures – 2-Step Code Code 50F 40F 35F 30F 27F CCT 5000K 4000K 3500K 3000K 2700K x y 0.3407 0.3459 0.3415 0.3586 0.3499 0.3654 x y 0.3429 0.3507 0.3434 0.3571 0.3475 0.3484 0.3604 0.3521 0.3469 0.3539 50H CCT 0.3744 0.3685 0.3784 0.3741 0.3837 0.3804 0.3818 0.3912 0.3917 0.3867 0.3857 0.3863 0.3758 0.3844 0.3778 0.3981 0.3800 0.4030 0.3857 0.4040 0.3966 0.4061 0.3941 0.4186 0.4037 0.4132 0.3976 0.4116 0.3865 0.4099 0.3890 40H 35H 4000K 3500K 0.4242 0.3919 0.4291 0.3973 0.4322 0.4096 0.4333 0.4062 0.4449 0.4141 0.4395 0.4084 0.4359 0.3960 0.4351 0.3994 0.4475 0.3994 0.4528 0.4046 0.4573 0.4178 0.4578 0.4138 0.4695 0.4207 0.4638 0.4152 0.4589C 0.4021 0.4586 0.4060 Bin Code 3A0 3B0 0E3 5000K 0.3782 30H 27H ANSI White Bins Code CCT 5000K 3C0 3D0 3000K 2700K ANSI White Bins x y .3371 .3490 .3451 .3554 .3440 .3427 .3366 Code CCT Bin Code x y .3670 .3578 .3702 .3722 .3825 .3798 .3369 .3783 .3646 .3376 .3616 .3702 .3722 .3463 .3687 .3736 .3874 .3451 .3554 .3869 .3958 .3371 .3490 .3825 .3798 .3463 .3687 .3825 .3798 .3551 .3760 .3869 .3958 .3533 .3620 .4006 .4044 .3451 .3554 .3950 .3875 5A0 5B0 0E5 4000K 5C0 .3451 .3554 .3783 .3646 .3533 .3620 .3825 .3798 .3515 .3487 .3950 .3875 .3440 .3427 .3898 .3716 5D0 Copyright © 2013 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. 13 XLamp CXA1310 LED PRELIMINARY - January 17, 2014 Cree EasyWhite Bins Plotted on the 1931 CIE Color Space (Tj = 85 °C) 0.45 ANSI C78.377 Quadrangle EasyWhite 4-step EasyWhite 2-step 0.44 2700K 3000K 0.43 3500K 0.42 4000K 0.41 4500K 0.40 5000K CCy 0.39 5700K 0.38 0.37 0.36 0.35 0.34 0.33 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.32 CCx Copyright © 2013 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. 14 XLamp CXA1310 LED PRELIMINARY - January 17, 2014 Cree ANSI White Bins Plotted on the 1931 CIE Color Space (Tj = 85 °C) 0.42 3500K 0.41 4000K 0.40 4500K 5C 0.39 5B 5000K CCy 0.38 5D 0.37 5A 5700K 0.36 3C 3B 3D 0.35 3A 0.34 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.33 CCx Copyright © 2013 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. 15 XLamp CXA1310 LED PRELIMINARY - January 17, 2014 Bin and Order Code Formats Bin codes and order codes are configured as follows: Order Code Bin Code Series = CXA13 Series = CXA13 Internal code Chromaticity bin CRI Specification 0 = Standard CRI H = 80 min CRI U = 90 min CRI Y = 93 min CRI SSSSSCC-HHHH-HHHGGNNNNNN Kit code Vf class: F0 = 18-V class N0 = 36-V class Performance class Vf class: F0 = 18-V class N0 = 36-V class Internal code SSSSSCC-WWW-FF-GGR-AAAAA CRI Specification B = 70 min CRI H = 80 min CRI U = 90 min CRI Y = 93 min CRI Flux bin Performance class Copyright © 2013 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. 16 XLamp CXA1310 LED PRELIMINARY - January 17, 2014 Mechanical Dimensions Dimensions are in mm. 13.35 ±0.2 Tolerances unless otherwise specified: .x + .10 2.60 .xx + .03 2.86 1.22 .xxx + .010 Tc 1.00±.15 x° + 1° 1.22 2.60 4.19 R.500 18 V 13.35 ±0.2 6.0 ±0.2 2.60 7.50 ±0.2 1.22 2.60 0.55 ± 0.1 1.22 13.35 ±0.2 2.60 1.22 2.86 Tc 1.00±.15 1.22 2.60 4.19 R.500 36 V 13.35 ±0.2 6.0 ±0.2 2.60 7.50 ±0.2 1.22 2.60 1.22 0.55 ± 0.1 Copyright © 2013 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. 17 XLamp CXA1310 LED PRELIMINARY - January 17, 2014 Thermal Design The CXA family of LED arrays can include over a hundred different LED die inside one package, and thus over a hundred different junction temperatures (TJ). Cree has intentionally removed junction-temperature-based operating limits and replaced the commonplace maximum TJ calculations with maximum ratings based on forward current (IF) and case temperature (Tc). No additional calculations are required to ensure the CXA LED is being operated within its designed limits. Please refer to page 2 for the Operating Limit specification. Cree has measured the temperature at the bottom of the package, commonly referred to as the solder point (TSP), and found this value to be equivalent to the temperature at the Tc location at the top of the package once the LED has reached thermal equilibrium. There is no need to calculate for TJ inside the package, as the thermal management design process, specifically from TSP to ambient (Ta), remains identical to any other LED component. For more information on thermal management of Cree XLamp LEDs, please refer to the XLamp Thermal Management application note at www.cree.com/xlamp_app_notes/thermal_management. For CXA soldering recommendations and more information on thermal interface materials (TIM) and connection methods, please refer to the Cree XLamp CXA Family LEDs soldering and handling document at www.cree.com/xlamp_app_notes/CXA_SH. To keep the CXA1310 LED at or below the maximum rated Tc, the case to ambient temperature thermal resistance (R_c-a) must be at or below the maximum R_c-a R_j-c R_j-c Tc Tc value shown on the following graphs, depending on the operating environment. The y‑axis in the graph is a base 10 logarithmic scale. R_tim As the figure at right shows, the R_c-a value is the sum of the thermal resistance of R_c-a the TIM (R_tim) plus the thermal resistance of the heat sink (R_hs). R_hs CXA1310-18V Ta Ta 100.00 18 V Maximum R_c-a 10.00 Ta = 25 °C Ta = 55 °C 1.00 Ta = 85 °C Ta = 105 °C 0.10 0.01 300 400 500 600 700 800 900 Current (mA) Copyright © 2013 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. 18 XLamp CXA1310 LED PRELIMINARY - January 17, 2014 CXA1310-36V Thermal Design - Continued 100.00 36 V Maximum R_c-a 10.00 Ta = 25 °C Ta = 55 °C 1.00 Ta = 85 °C Ta = 105 °C 0.10 0.01 150 200 250 300 350 400 450 Current (mA) Notes Lumen Maintenance Projections Cree now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document at www.cree.com/xlamp_app_notes/LM80_results. Please read the XLamp Long-Term Lumen Maintenance application note at www.cree.com/xlamp_app_notes/lumen_ maintenance for more details on Cree’s lumen maintenance testing and forecasting. Please read the XLamp Thermal Management application note at www.cree.com/xlamp_app_notes/thermal_management for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. Vision Advisory Claim Users should be cautioned not to stare at the light of this LED product. The bright light can damage the eye. Copyright © 2013 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. 19 XLamp CXA1310 LED PRELIMINARY - January 17, 2014 Packaging Cree CXA1310 LEDs are packaged in trays of 20. Five trays are sealed in an anti-static bag and placed inside a carton, 5 for a total of 100 LEDs per carton. Each carton4 contains 100 LEDs from the3 same performance bin. CE S PLOT AND THE INFORMATION HE PROPRIETARY AND ON OF CREE, INC. THIS PLOT RODUCED OR DISCLOSED TO ANY WITHOUTTHE WRITTEN CONSENT 2 REVISONS DESCRIPTION Dimensions are in inches. REV Tolerances: .x + .1 5.875 5 4 3 2 .xx + .03 1 REVISONS R.375 ORMATION AND THIS PLOT LOSED TO ANY TEN CONSENT .xxx + .010 DESCRIPTION REV BY DATE APP'D x° + 1° 5.875 R.375 .875 5.875 .875 75 LABEL WITH CREE BIN CODE, QTY, LOT # TENT LABEL UNDERSIDE ABEL WITH CREE BIN CODE, OF COVER QTY, LOT # .875 .875 LABEL WITH CREE BIN CODE, QTY, LOT # LABEL WITH CREE BIN CODE, QTY, LOT # BAG BAG E BIN CODE, QTY, LOT # THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS AND AFTER FINISH. TOLERANCE UNLESS SPECIFIED: .XX ± .25 .XXX ± .125 X° ± .5 ° DATE DRAWN BY D. CRONIN 05/08/12 CHECK DATE APPROVED DATE TITLE LE1401 MARKET FOR SHEET METAL PARTS ONLY MATERIAL .X ± 1.5 DRAWING NO. SIZE .XX ± .75 .XXX ± .25 FINAL PROTECTIVE FINISH DRAWN BY X° ± .5 ° DATE UNLESS OTHERWISE SPECIFIED 4600 Silicon Drive SCALE CRONIN 05/08/12 DIMENSIONS ARE IN SURFACE D. FINISH: 1.6 8.000 Durham, N.C 27703 CHECK DATE MILLIMETERS AND AFTER FINISH. Phone (919) 313-5300 4 3 2 TOLERANCE UNLESS SPECIFIED: Fax (919) 313-5558 .XX ± .25 APPROVED DATE TITLE .XXX ± .125 ® ® ® X° ± .5 ° this document is subject to change without notice. Cree , the Cree logo, XLamp and EasyWhite are registered THIRD ANGLE PROJECTION FOR SHEET METAL PARTS ONLY MATERIAL .X ± 1.5 REV. DRAWING NO. SIZE .XX ± .75 .XXX ± .25 FINAL PROTECTIVE FINISH X° ± .5 ° C 5 Copyright © 2013 Cree, Inc. All rights reserved. The information in trademarks of Cree, Inc. CXA1 LE1401 MARKETING SPEC C SURFACE FINISH: 1.6 SCALE 8.000 CXA1310 20 SHEET A OF 2 /2
CXA1310-0000-000F0UH40E3 价格&库存
很抱歉,暂时无法提供与“CXA1310-0000-000F0UH40E3”相匹配的价格&库存,您可以联系我们找货
