CXA1830-0000-000N0US240F
    WOLFSPEED
    LEDCOBCXA1830NEUTRALWHITESQ
CXA1830-0000-000N0US240F 数据手册
PRODUCT FAMILY DATA SHEET XLamp® CXA1830 LED PRODUCT DESCRIPTION FEATURES TABLE OF CONTENTS The XLamp® CXA1830 LED array expands • Available in 4-step, 3‑step and 2-step Characteristics................................................ 2 Cree LED’s family of high‑flux, multi‑die EasyWhite bins at 2700 K, 3000 K, Operating Limits.............................................. 2 arrays in a smaller, easy‑to‑use platform. 3500 K, 4000 K & 5000 K CCT and Flux Characteristics, EasyWhite® Order With XLamp LED lighting‑class reliability, 4-step EasyWhite bins at 5700 K & Codes and Bins............................................... 3 the CXA1830’s small, uniform emitting 6500 K CCT Flux Characteristics, ANSI White Order ® surface enables both directional and • Available in ANSI white bins at 4000 K, Codes and Bins............................................... 6 non‑directional lighting Relative Spectral Power Distribution............. 7 including retrofit lamp applications and 5000 K, 5700 K & 6500 K CCT luminaire • Available in 70-, 80-, 90- and designs. Available in 2‑step, 3‑step and 93‑minimum CRI options Electrical Characteristics................................ 7 Relative Luminous Flux................................... 8 4‑step color consistency, and featuring a • Forward voltage option: 36‑V class Typical Spatial Distribution............................. 9 14-mm optical source, the CXA1830 brings • 85 °C binning and characterization Performance Groups - Brightness................. 9 new levels of flux and efficacy to this form • Maximum drive current: 1400 mA Performance Groups - Chromaticity............ 10 factor. • 115° viewing angle, uniform EasyWhite® Bins Plotted on the 1931 CIE chromaticity profile Color Space................................................... 13 The CX Family LED Design Guide provides • Top-side solder connections ANSI White Bins Plotted on the 1931 CIE basic information on the requirements • Thermocouple attach point Color Space................................................... 13 to use the CXA1830 LED successfully in • NEMA SSL-3 2011 standard flux bins Bin and Order Code Formats........................ 14 luminaire designs. • RoHS and REACh compliant Mechanical Dimensions............................... 14 • UL recognized component (E349212) Thermal Design............................................. 15 ® Notes............................................................. 16 Packaging...................................................... 17 Cree LED / 4400 Silicon Drive / Durham, NC 27703 USA / +1.919.313.5330 / www.cree-led.com © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS79 REV 7A 1 XLAMP ® CXA1830 LED CHARACTERISTICS Characteristics Unit Viewing angle (FWHM) Minimum Typical degrees ESD withstand voltage (HBM per Mil-Std-883D) Maximum 115 V 8000 DC forward current mA 1400* Reverse current mA 0.1 Forward voltage (800 mA, 85 °C) V Forward voltage (800 mA, 25 °C) V * 36.4 42 Refer to the Operating Limits section. OPERATING LIMITS The maximum current rating of the CXA1830 depends on the case temperature (Tc) when the LED has reached thermal equilibrium under steady-state operation. The graph shown below assumes that the system design employs good thermal management (thermal interface material and heat sink) and may vary when poor thermal management is employed. Please refer to the Mechanical Dimensions section on page 14 for the location of the Tc measurement point. Another important factor in good thermal management is the temperature of the Light Emitting Surface (LES). Cree LED recommends a maximum LES temperature of 135 °C to ensure optimal LED lifetime. Please refer to the Thermal Design section on page 15 for more CXA1830 information on LES temperature measurement. 1500 1200 If (mA) 900 600 300 0 0 25 50 75 100 125 150 Case Temperature (°C) © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS79 REV 7A 2 XLAMP ® CXA1830 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS (IF = 800 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA1830 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 14). Nominal CCT CRI Min 70 Minimum Luminous Flux Typ 75 6500 K 80 70 70 5000 K 80 90 3-Step 75 Flux (lm) @ 85 °C Flux (lm) @ 25 °C* T4 3440 3887 U2 3680 4158 U4 3955 4424 CXA1830-0000000N00U465F T4 3440 3887 CXA1830-0000000N0HT465F U2 3680 4158 CXA1830-0000000N0HU265F T4 3440 3887 CXA1830-0000000N00T457F U2 3680 4158 U4 3955 4424 CXA1830-0000000N00U457F T4 3440 3887 CXA1830-0000000N0HT457F U2 3680 4158 T4 3440 3887 U2 3680 4158 U4 3955 4424 CXA1830-0000000N00U450H CXA1830-0000000N00U450F T2 3200 3616 CXA1830-0000000N0HT250H CXA1830-0000000N0HT250F T4 3440 3887 U2 3680 4158 CXA1830-0000000N0HU250H CXA1830-0000000N0HU250G CXA1830-0000000N0HU250F R4 2600 2938 CXA1830-0000000N0UR450H CXA1830-0000000N0UR450G CXA1830-0000000N0UR450F S2 2780 3141 S4 2990 3379 Group Order Code Group Order Code --- 95 Group Order Code CXA1830-0000000N00T465F 65F 65F 57F --- 75 4-Step Group --- 5700 K 80 2-Step 57F CXA1830-0000000N00T450H 50H 50H 50H CXA1830-0000000N0US250H CXA1830-0000000N0US450H CXA1830-0000000N00U257F CXA1830-0000000N0HU257F CXA1830-0000000N00T450F CXA1830-0000000N00U250H CXA1830-0000000N0HT450H CXA1830-0000000N00U265F 50F 50G 50G CXA1830-0000000N0HT450G CXA1830-0000000N0US250G CXA1830-0000000N0US450G 50F 50F CXA1830-0000000N00U250F CXA1830-0000000N0HT450F CXA1830-0000000N0US250F CXA1830-0000000N0US450F Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 16). • CXA1830 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS79 REV 7A 3 XLAMP ® CXA1830 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS (IF = 800 mA, TJ = 85 °C) - CONTINUED Nominal CCT CRI Min 70 4000 K 80 90 80 Minimum Luminous Flux Typ 75 --- 95 --- 2-Step 80 95 --- Flux (lm) @ 85 °C Flux (lm) @ 25 °C* T4 3440 3887 U2 3680 4158 U4 3955 4424 CXA1830-0000000N00U440H CXA1830-0000000N00U440F T2 3200 3616 CXA1830-0000000N0HT240H CXA1830-0000000N0HT240F T4 3440 3887 U2 3680 4158 CXA1830-0000000N0HU240H R4 2600 2938 CXA1830-0000000N0UR440H S2 2780 3141 S4 2990 3379 CXA1830-0000000N0US440H S4 2990 3379 CXA1830-0000000N00S435H T2 3200 3616 T4 3440 3887 CXA1830-0000000N00T435H R2 2420 2735 CXA1830-0000000N0YR235H R4 2600 2938 S2 2780 3141 CXA1830-0000000N0YS235H S4 2990 3379 CXA1830-0000000N00S430H T2 3200 3616 T4 3440 3887 CXA1830-0000000N00T430H Q4 2260 2554 CXA1830-0000000N0YQ430H R2 2420 2735 R4 2600 2938 Group 95 Order Code Group Order Code Group CXA1830-0000000N00T440H 40H 40H 40H 35H 35H 30H 3000 K 93 4-Step Group 3500 K 93 3-Step 30H CXA1830-0000000N00T440F CXA1830-0000000N00U240H CXA1830-0000000N0HT440H CXA1830-0000000N0US240H CXA1830-0000000N00T235H CXA1830-0000000N0YR435H CXA1830-0000000N00T230H CXA1830-0000000N0YR230H CXA1830-0000000N0YR430H Order Code 40F 40G CXA1830-0000000N0HT440G 40F CXA1830-0000000N0HU240G CXA1830-0000000N00U240F CXA1830-0000000N0HT440F CXA1830-0000000N0HU240F CXA1830-0000000N0UR440F 40G CXA1830-0000000N0US240G 40F CXA1830-0000000N0US440G CXA1830-0000000N0US240F CXA1830-0000000N0US440F CXA1830-0000000N00S435F 35G CXA1830-0000000N00T235G 35F CXA1830-0000000N00T435G CXA1830-0000000N00T235F CXA1830-0000000N00T435F CXA1830-0000000N0YR235F 35G CXA1830-0000000N0YR435G 35F CXA1830-0000000N0YS235G CXA1830-0000000N0YR435F CXA1830-0000000N0YS235F CXA1830-0000000N00S430F 30G CXA1830-0000000N00T230G 30F CXA1830-0000000N00T430G CXA1830-0000000N00T230F CXA1830-0000000N00T430F CXA1830-0000000N0YQ430F 30G CXA1830-0000000N0YR230G CXA1830-0000000N0YR430G 30F CXA1830-0000000N0YR230F CXA1830-0000000N0YR430F Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 16). • CXA1830 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS79 REV 7A 4 XLAMP ® CXA1830 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS (IF = 800 mA, TJ = 85 °C) - CONTINUED Nominal CCT CRI Min 80 Minimum Luminous Flux Typ --- 2-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* S2 2780 3141 S4 2990 3379 T2 3200 3616 CXA1830-0000000N00T227H Q2 2100 2373 CXA1830-0000000N0YQ227H Q4 2260 2554 R2 2420 2735 Group 95 Group Order Code 4-Step Group CXA1830-0000000N00S227H 27H 2700 K 93 Order Code 3-Step 27H CXA1830-0000000N00S427H CXA1830-0000000N0YQ427H CXA1830-0000000N0YR227H Order Code CXA1830-0000000N00S227F 27G CXA1830-0000000N00S427G 27F CXA1830-0000000N00T227G CXA1830-0000000N00S427F CXA1830-0000000N00T227F CXA1830-0000000N0YQ227F 27G CXA1830-0000000N0YQ427G CXA1830-0000000N0YR227G 27F CXA1830-0000000N0YQ427F CXA1830-0000000N0YR227F Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 16). • CXA1830 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS79 REV 7A 5 XLAMP ® CXA1830 LED FLUX CHARACTERISTICS, ANSI WHITE ORDER CODES AND BINS (IF = 800 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA1830 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 14). Nominal CCT CRI Min 70 Minimum Luminous Flux Typ 75 6500 K 80 70 --- 75 5700 K 80 70 --- 75 5000 K 80 4000 K 70 --- 75 Chromaticity Regions Order Code Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* T4 3440 3887 U2 3680 4158 U4 3955 4424 T4 3440 3887 U2 3680 4158 T4 3440 3887 U2 3680 4158 U4 3955 4424 T4 3440 3887 U2 3680 4158 T4 3440 3887 U2 3680 4158 U4 3955 4424 CXA1830-0000-000N00U40E3 T2 3200 3616 CXA1830-0000-000N0HT20E3 T4 3440 3887 U2 3680 4158 CXA1830-0000-000N0HU20E3 T4 3440 3887 CXA1830-0000-000N00T40E5 U2 3680 4158 U4 3955 4424 CXA1830-0000-000N00T40E1 1A0, 1B0, 1C0, 1D0, 65F CXA1830-0000-000N00U20E1 CXA1830-0000-000N00U40E1 1A0, 1B0, 1C0, 1D0, 65F CXA1830-0000-000N0HT40E1 CXA1830-0000-000N0HU20E1 CXA1830-0000-000N00T40E2 2A0, 2B0, 2C0, 2D0, 57F CXA1830-0000-000N00U20E2 CXA1830-0000-000N00U40E2 2A0, 2B0, 2C0, 2D0, 57F CXA1830-0000-000N0HT40E2 CXA1830-0000-000N0HU20E2 CXA1830-0000-000N00T40E3 3A0, 3B0, 3C0, 3D0, 50F 3A0, 3B0, 3C0, 3D0, 50F 5A0, 5B0, 5C0, 5D0, 40F CXA1830-0000-000N00U20E3 CXA1830-0000-000N0HT40E3 CXA1830-0000-000N00U20E5 CXA1830-0000-000N00U40E5 Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 16). • CXA1830 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS79 REV 7A 6 XLAMP ® CXA1830 LED Relative Spectral Power Distribution RELATIVE SPECTRAL POWER DISTRIBUTION The following graph is the result of a series of pulsed measurements at 800 mA and TJ = 85 °C. 100% Relative Spectral Power 90% 80% 70% 60% 5000 K, 70 CRI 50% 4000 K, 70 CRI 40% 3000 K, 80 CRI 30% 3000 K, 93 CRI 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) ELECTRICAL CHARACTERISTICS The following graph is the result of a series of steady-state measurements. 41 40 Voltage (V) 39 38 Tc = 25 °C Tc = 55 °C 37 Tc = 85 °C 36 Tc = 105 °C 35 34 33 400 500 600 700 800 900 1000 1100 1200 1300 1400 Current (mA) © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS79 REV 7A 7 XLAMP ® CXA1830 LED RELATIVE LUMINOUS FLUX The relative luminous flux values provided below are the ratio of: • Measurements of CXA1830 at steady-state operation at the given conditions, divided by • Flux measured during binning, which is a pulsed measurement at 800 mA at TJ = 85 °C. For example, at steady-state operation of Tc = 25 °C, IF = 1100 mA, the relative luminous flux ratio is 140% in the chart below. A CXA1830 LED that measures 2100 lm during binning will deliver 2940 lm (2100 * 1.4) at steady-state operation of Tc = 25 °C, IF = 1100 mA. 180% 160% Relative Luminous Flux 140% 120% Tc = 25 °C 100% Tc = 55 °C 80% Tc = 85 °C Tc = 105 °C 60% 40% 20% 0% 400 500 600 700 800 900 1000 1100 1200 1300 1400 Current (mA) © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS79 REV 7A 8 XLAMP ® CXA1830 LED Far Field TYPICAL SPATIAL DISTRIBUTION 100% Relative Luminous Intensity 80% 60% 40% 20% -90 -70 -50 -30 -10 0% 10 30 50 70 90 Angle (º) PERFORMANCE GROUPS - BRIGHTNESS (I F = 800 mA, TJ = 85 °C) XLamp CXA1830 LEDs are tested for luminous flux and placed into one of the following bins. Group Code Minimum Luminous Flux Maximum Luminous Flux Q2 2100 2260 Q4 2260 2420 R2 2420 2600 R4 2600 2780 S2 2780 2990 S4 2990 3200 T2 3200 3440 T4 3440 3680 U2 3680 3955 U4 3955 4230 V2 4230 4545 © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS79 REV 7A 9 XLAMP ® CXA1830 LED PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) XLamp CXA1830 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. EasyWhite Color Temperatures – 2-Step Code 50H 40H 35H 30H 27H CCT 5000 K 4000 K 3500 K 3000 K 2700 K x y 0.3429 0.3507 0.3434 0.3571 0.3475 0.3604 0.3469 0.3539 0.3784 0.3741 0.3804 0.3818 0.3867 0.3857 0.3844 0.3778 0.4030 0.3857 0.4061 0.3941 0.4132 0.3976 0.4099 0.3890 0.4291 0.3973 0.4333 0.4062 0.4395 0.4084 0.4351 0.3994 0.4528 0.4046 0.4578 0.4138 0.4638 0.4152 0.4586 0.4060 EasyWhite Color Temperatures – 3-Step Ellipse Bin Code CCT 50G 40G Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 5000 K 0.3447 0.3553 0.00840 0.00312 65.0 4000 K 0.3818 0.3797 0.00939 0.00402 53.7 35G 3500 K 0.4073 0.3917 0.00927 0.00414 54.0 30G 3000 K 0.4338 0.4030 0.00834 0.00408 53.2 27G 2700 K 0.4577 0.4099 0.00834 0.00420 48.5 © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS79 REV 7A 10 XLAMP ® CXA1830 LED PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) - CONTINUED EasyWhite Color Temperatures – 4-Step Code 65F 57F 50F 40F 35F 30F 27F CCT 6500 K 5700 K 5000 K 4000 K 3500 K 3000 K 2700 K x y 0.3097 0.3196 0.3079 0.3297 0.3164 0.3382 0.3176 0.3275 0.3253 0.3325 0.3249 0.3439 0.3331 0.3514 0.3330 0.3393 0.3407 0.3459 0.3415 0.3586 0.3499 0.3654 0.3484 0.3521 0.3744 0.3685 0.3782 0.3837 0.3912 0.3917 0.3863 0.3758 0.3981 0.3800 0.4040 0.3966 0.4186 0.4037 0.4116 0.3865 0.4242 0.3919 0.4322 0.4096 0.4449 0.4141 0.4359 0.3960 0.4475 0.3994 0.4573 0.4178 0.4695 0.4207 0.4589 0.4021 © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS79 REV 7A 11 XLAMP ® CXA1830 LED PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) - CONTINUED ANSI White Bins Code Bin Code CCT 1A0 1B0 0E1 6500 K 1C0 1D0 ANSI White Bins x y 0.3048 0.3207 0.3130 0.3290 0.3144 0.3186 0.3068 Code x y 0.3215 0.3350 0.3290 0.3417 0.3290 0.3300 0.3113 0.3222 0.3243 0.3028 0.3304 0.3207 0.3462 0.3115 0.3391 0.3290 0.3538 0.3130 0.3290 0.3290 0.3417 0.3048 0.3207 0.3215 0.3350 0.3115 0.3391 0.3290 0.3538 0.3205 0.3481 0.3376 0.3616 0.3213 0.3373 0.3371 0.3490 0.3130 0.3290 0.3290 0.3417 0.3130 0.3290 0.3290 0.3417 0.3213 0.3373 0.3371 0.3490 0.3221 0.3261 0.3366 0.3369 0.3144 0.3186 0.3290 0.3300 2A0 2B0 0E2 5700 K 2C0 2D0 ANSI White Bins Code CCT Bin Code 3A0 3B0 0E3 5000 K 3C0 3D0 Bin Code CCT ANSI White Bins x y Code CCT Bin Code x y .3371 .3490 .3670 .3578 .3451 .3554 .3702 .3722 .3440 .3427 .3825 .3798 .3366 .3369 .3783 .3646 .3376 .3616 .3702 .3722 .3463 .3687 .3736 .3874 .3451 .3554 .3869 .3958 .3371 .3490 .3825 .3798 .3825 .3798 .3869 .3958 .4006 .4044 5A0 5B0 0E5 4000 K .3463 .3687 .3551 .3760 .3533 .3620 .3451 .3554 .3950 .3875 .3451 .3554 .3783 .3646 .3533 .3620 .3825 .3798 .3515 .3487 .3950 .3875 .3440 .3427 .3898 .3716 5C0 5D0 © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS79 REV 7A 12 XLAMP ® CXA1830 LED EASYWHITE® BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) 0.44 2700 K ANSI C78.377 Quadrangle 0.43 3000 K EasyWhite 4-Step EasyWhite 3-Step 0.42 EasyWhite 2-Step 3500 K 0.41 4000 K 0.40 4500 K CCy 0.39 5000 K 0.38 0.37 5700 K 0.36 6500 K 0.35 0.34 0.33 0.32 0.49 0.48 0.47 0.45 0.41 0.46 0.44 0.40 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.31 CCx ANSI WHITE BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) 0.41 4000 K ANSI C78.377 Quadrangle 0.40 4500 K 5C 0.39 5D 0.37 CCy 5B 5000 K 0.38 5700 K 0.36 5A 3C 3B 6500 K 0.35 2B 0.34 1C 1B 0.33 3D 2C 1D 3A 2D 2A 1A 0.32 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.31 CCx © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS79 REV 7A 13 XLAMP ® CXA1830 LED BIN AND ORDER CODE FORMATS Bin codes and order codes are configured as follows: Order Code Bin Code Series = CXA18 Series = CXA18 Internal code Chromaticity bin CRI Specification 0 = Standard CRI H = 80 CRI minimum U = 90 CRI minimum Y = 93 CRI minimum Vf class N0 = 36-V class Internal code SSSSSCC-WWW-FF-GGR-AAAAA CRI Specification B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Y = 93 CRI minimum SSSSSCC-HHHH-HHHGGRNNNNN Kit code Vf class N0 = 36-V class Flux bin Performance class Performance class MECHANICAL DIMENSIONS Dimensions are in mm. Tolerances unless otherwise specified: +.13 x° +1° 1830N = 36‑V CXA1830 1830N Meaning of 1830N © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS79 REV 7A 14 XLAMP ® CXA1830 LED THERMAL DESIGN The CXA family of LED arrays can include over a hundred different LED die inside one package, and thus over a hundred different junction temperatures (TJ). Cree LED has intentionally removed junction-temperature-based operating limits and replaced the commonplace maximum TJ calculations with maximum ratings based on forward current (IF) and case temperature (Tc). No additional calculations are required to ensure that the CXA LED is being operated within its designed limits. LES temperature measurement provides additional verification of good thermal design. Please refer to page 2 for the Operating Limit specifications. There is no need to calculate for TJ inside the package, as the thermal management design process, specifically from TSP to ambient (Ta), remains identical to any other LED component. For more information on thermal management of XLamp LEDs, please refer to the Thermal Management application note. For CXA soldering recommendations and more information on thermal interface materials (TIM), LES temperature measurement, and connection methods, please refer to the XLamp CX Family LEDs soldering and handling document. The CX Family LED Design Guide provides basic information on the requirements to use XLamp CXA LEDs successfully in luminaire designs. To keep the CXA1830 LED at or below the maximum rated Tc, the case to ambient temperature thermal resistance (R_c-a) must be at or below the maximum R_c-a value shown on the following R_j-c R_j-c scale. Tc Tc As the figure at right shows, the R_c-a value is the sum of the thermal resistance of the TIM (R_tim) R_tim graph, depending on the operating environment. The y‑axis in the graph is a base 10 logarithmic R_c-a plus the thermal resistance of the heat sink (R_hs). R_hs CXA1830 Ta Ta 100.00 Maximum R_c-a 10.00 Ta = 25 °C Ta = 55 °C 1.00 Ta = 85 °C Ta = 105 °C 0.10 0.01 400 500 600 700 800 900 1000 1100 1200 1300 1400 Current (mA) © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS79 REV 7A 15 XLAMP ® CXA1830 LED NOTES Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs. Lumen Maintenance Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. REACh Compliance REACh substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative to insure you get the most up-to-date REACh Declaration. REACh banned substance information (REACh Article 67) is also available upon request. UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS79 REV 7A 16 XLAMP ® CXA1830 LED PACKAGING CXA1830 LEDs are packaged in trays of 20. Five trays are sealed in an anti-static bag and placed inside a carton, for a total of 100 LEDs per carton. Each carton contains 100 LEDs from the same performance bin. REV 5 7.875 6 4 3 5 R.375 4 NOTICE FIDENTIAL. THIS PLOT AND THE INFORMATION D WITHIN ARE THE PROPRIETARY AND TIAL INFORMATION OF CREE, INC. THIS PLOT NSENT E COPIED, REPRODUCED OR DISCLOSED TO ANY IZED PERSON WITHOUTTHE WRITTEN CONSENT C. Dimensions are in inches. DESC. DATE BY CHK. Tolerances: +.13 x° +1° 2 3 1 2 1 .75 5.875 5.875 R .375 1.125 R.375 7.125 .875 .875 5.875 .38 1.125 .38 .75 PATENT LABEL IS LOCATED WITH CREE ON LABEL UNDERSIDE OF CARTON BIN CODE, QTY, LOT# SECTION C-C .19 .38 .875 .38 PATENT TH CREE BIN .875LABEL ANTITY, LOTIS# LOCATED ON UNDERSIDE OF CARTON BAG DO NOT SCALE DWG. L IS LOCATED IDE OF COVER UNLESS OTHERWISE NOTED ALL TOLERANCES ARE AS FOLLOWS: FRACT ±1/64 X.X" ±.030 X.0mm ±.75mm ANGLES ±0°-30' X.XX" ±.015 X.Xmm ±.30mm DRAFT ±1° X.XXX" ±.005 X.XXmm ±.10mm PART DRAWING DATE: DR. BY: CHK. BY: 4-3-13 KJS SCALE: 0.750 SIZE B DWG. NO. 022489-00 SHEET 2 OF 2 LABEL WITH CREE BIN CODE, QTY, LOT# LABEL WITH CREE BIN CODE, QUANTITY, LOT # LABEL WITH CREE BIN CODE, QUANTITY, LOT # UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS & BEFORE FINISH. TOLERANCE UNLESS SPECIFIED: LABEL WITH CREE BIN CODE, QTY, LOT# THIRD ANGLE PROJECTION WITH CREE BIN 6 QUANTITY, LOT # BAG THIS DRAWING CONTAINS PROPRIETARY DESIGN INFORMATION AND REMAINS ALONG WITH THE PRODUCT OR PRODUCTS REPRESENTED HEREIN THE PROPERTY OF TEK PAK, INCORPORATED. THIS DOCUMENT AND THE INFORMATION IT CONTAINS DWG.TITLE MAY NOT BE COPIED, TRANSMITTED, OR USED BY ANY THIRD PARTY WITHOUT THE EXPRESS WRITTEN APPROVAL OF TEK PAK, INCORPORATED. .X ± .XX ± .XXX ± X° ± 0.1 .05 .005 1° FOR SHEET METAL PARTS ONLY .X ± .06 .XX ± .03 .XXX ± .010 DRAWN BY X° ± 2 ° UNLESS OTHERWISE SPECIFIED 5 4 DIMENSIONS ARE IN 3 MILLIMETERS & BEFORE FINISH. TOLERANCE UNLESS SPECIFIED: CHECK © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered and APPROVED .X ± trademarks, 0.1 ± .05 registered the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the.XXUL logo are .XXX ± .005 trademarks of UL LLC. THIRD ANGLE PROJECTION MATERIAL X° ± 1 ° FOR SHEET METAL PARTS ONLY .X ± .06 DRAWN BY DATE CHECK DATE APPROVED DATE Phone (919) 361 Fax (919) 313-5 TITLE CXA15XX_DATASHEET MATERIAL SIZE FINAL PROTECTIVE FINISH SCALE DATE DATE C DRAWING NO. CXA15XX_DATASHEET_BAG2013 SHEET 0.500 OF 4600 Silicon Drive 1 27703 Durham, N.C 2 Phone (919) 361-4770 DATE TITLE CLD-DS79 REV 7A 17 Fax (919) 313-5303 CXA15XX_DATASHEET SIZE FINAL PROTECTIVE FINISH 4600 Silicon Dri Durham, N.C 27 DRAWING NO. CXA15XX_DATASHEET_BAG2013
物料型号:XLamp® CXA1830 LED
器件简介:XLamp® CXA1830 LED阵列扩展了Cree LED的高通量多芯片阵列产品线,采用更小、易于使用的平台。具有XLamp LED照明级可靠性,CXA1830的小尺寸、均匀的发射表面支持定向和非定向照明应用设计。
引脚分配:文档中未明确提供引脚分配信息。
参数特性: - 视场角(FWHM):115° - ESD承受电压(HBM per MIL-STD-883D):8000V - 直流正向电流:最高1400 mA - 反向电流:最高0.1 mA - 正向电压(800 mA, 85°C):36.4V - 正向电压(800 mA, 25°C):42V
功能详解:CXA1830提供2步、3步和4步EasyWhite®色温选项,以及ANSI白色选项,包括70-、80-、90-和93-最小CRI选项。具有4步颜色一致性,前向电压选项为36V级别,85°C分档和特性,最大驱动电流为1400 mA,115°视场角,均匀色度配置文件,顶部侧面焊接连接,热电偶附着点,符合NEMA SSL-3 2011标准通量分档,符合RoHS和REACh标准,UL®认可组件(E349212)。
应用信息:适用于包括灯具改造和照明设备在内的多种照明应用。
封装信息:CXA1830 LED采用14毫米光学源,具有93%的CRI选项,并且是UL®认可的组件。
文档还包含了详细的电气特性、相对光谱功率分布、相对光通量、典型空间分布、性能组-亮度、性能组-色度、EasyWhite®色温选项的CIE 1931色度图、ANSI白色选项的CIE 1931色度图、热设计、注意事项、包装信息等。
CXA1830-0000-000N0US240F 价格&库存
很抱歉,暂时无法提供与“CXA1830-0000-000N0US240F”相匹配的价格&库存,您可以联系我们找货
