CXA2540-0000-000N0UT227F
    WOLFSPEED
    LED HB XLAMP CXA2540
CXA2540-0000-000N0UT227F 数据手册
PRODUCT FAMILY DATA SHEET XLamp® CXA2540 LED PRODUCT DESCRIPTION FEATURES TABLE OF CONTENTS The XLamp® CXA2540 LED array expands • Available in 4-step, 3‑step and 2-step Characteristics................................................ 2 Cree LED’s family of high‑flux, multi‑die EasyWhite bins at 2700 K, 3000 K, Operating Limits.............................................. 2 integrated arrays, offering high performance 3500 K, 4000 K & 5000 K CCT and Flux Characteristics, EasyWhite® Order in an easy-to-use platform. With XLamp 4-step EasyWhite bins at 5700 K & Codes and Bins............................................... 3 LED lighting-class reliability, the CXA2540’s 6500 K CCT Flux Characteristics, ANSI White Order ® uniform emitting surface enables both • Available in ANSI white bins at 4000 K, Codes and Bins............................................... 6 directional and non-directional lighting Relative Spectral Power Distribution............. 7 5000 K, 5700 K & 6500 K CCT applications and luminaire and lamp • Available in 70-, 80-, 90- and Electrical Characteristics................................ 7 designs. Available in 2‑step, 3‑step and 93‑minimum CRI options Relative Luminous Flux................................... 8 4‑step color consistency, and featuring a • Forward voltage option: 36‑V class Typical Spatial Distribution............................. 9 19‑mm optical source, the CXA2540 brings • 85 °C binning and characterization Performance Groups - Brightness................. 9 new levels of flux and efficacy to this form • Maximum drive current: 2100 mA Performance Groups - Chromaticity............ 10 factor. • 115° viewing angle, uniform EasyWhite® Bins Plotted on the 1931 CIE chromaticity profile Color Space................................................... 13 The CX Family LED Design Guide provides • Top-side solder connections ANSI White Bins Plotted on the 1931 CIE basic information on the requirements • Thermocouple attach point Color Space................................................... 13 to use the CXA2540 LED successfully in • NEMA SSL-3 2011 standard flux bins Bin and Order Code Formats........................ 14 luminaire designs. Mechanical Dimensions............................... 14 • Mechanical and optical footprint consistent with CXA2520 and CXA2530 Thermal Design............................................. 15 • RoHS and REACh compliant Notes............................................................. 16 • UL® recognized component (E349212) Packaging...................................................... 17 Cree LED / 4400 Silicon Drive / Durham, NC 27703 USA / +1.919.313.5330 / www.cree-led.com © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS67 REV 10A 1 XLAMP ® CXA2540 LED CHARACTERISTICS Characteristics Unit Viewing angle (FWHM) Minimum Typical degrees ESD withstand voltage (HBM per Mil-Std-883D) Maximum 115 V 8000 DC forward current mA 2100* Reverse current mA 0.1 Forward voltage (@ 1100 mA, Tj = 85 °C) V Forward voltage (@ 1100 mA, Tj = 25 °C) V * 36.2 42 Refer to the Operating Limits section. OPERATING LIMITS The maximum current rating of the CXA2540 depends on the case temperature (Tc) when the LED has reached thermal equilibrium under steady-state operation. The graph shown below assumes that the system design employs good thermal management (thermal interface material and heat sink) and may vary when poor thermal management is employed. Please refer to the Mechanical Drawings section on page 14 for the location of the Tc measurement point. Another important factor in good thermal management is the temperature of the Light Emitting Surface (LES). Cree LED recommends a maximum LES temperature of 135 °C to ensure optimal LED lifetime. Please refer to the Thermal Design section on page 15 for more information on LES temperature measurement. CXA2540 2400 2100 1800 If (mA) 1500 1200 900 600 300 0 0 25 50 75 100 125 150 Case Temperature (°C) © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS67 REV 10A 2 XLAMP ® CXA2540 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS (IF = 1100 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA2540 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 14). Nominal CCT CRI Min 70 Minimum Luminous Flux Typ 75 2-Step 3-Step 4-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* W2 4860 5435 W4 5225 5843 X2 5590 6244 CXA2540-0000000N00X265F V4 4545 5083 CXA2540-0000000N0HV465F W2 4860 5435 W4 5225 5843 CXA2540-0000000N0HW465F W2 4860 5435 CXA2540-0000000N00W257F W4 5225 5843 X2 5590 6244 CXA2540-0000000N00X257F V4 4545 5083 CXA2540-0000000N0HV457F W2 4860 5435 W4 5225 5843 W2 4860 5435 W4 5225 5843 X2 5590 6244 CXA2540-0000000N00X250H CXA2540-0000000N00X250F V4 4545 5083 CXA2540-0000000N0HV450H CXA2540-0000000N0HV450F W2 4860 5435 W4 5225 5843 CXA2540-0000000N0HW450H U2 3680 4115 CXA2540-0000000N0UU250H U4 3955 4391 V2 4230 4730 Group Order Code Group Order Code Group CXA2540-0000000N00W265F 65F 6500 K 80 70 --- 75 65F 57F 5700 K 80 70 5000 K 80 90 --- 75 --- 95 Order Code 57F CXA2540-0000000N00W465F CXA2540-0000000N0HW265F CXA2540-0000000N00W457F CXA2540-0000000N0HW257F CXA2540-0000000N0HW457F CXA2540-0000000N00W250H 50H 50H 50H CXA2540-0000000N00W250F CXA2540-0000000N00W450H CXA2540-0000000N0HW250H CXA2540-0000000N0UU450H CXA2540-0000000N0UV250H 50F 50G CXA2540-0000000N0HW250G 50F CXA2540-0000000N0HW450G CXA2540-0000000N00W450F CXA2540-0000000N0HW250F CXA2540-0000000N0HW450F CXA2540-0000000N0UU250F 50G CXA2540-0000000N0UU450G CXA2540-0000000N0UV250G 50F CXA2540-0000000N0UU450F CXA2540-0000000N0UV250F Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 16). • CXA2540 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS67 REV 10A 3 XLAMP ® CXA2540 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS (IF = 1100 mA, TJ = 85 °C) - CONTINUED Nominal CCT CRI Min 70 4000 K 80 90 80 Minimum Luminous Flux Typ 75 --- 95 --- 2-Step 95 4-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* V4 4545 5083 W2 4860 5435 W4 5225 5843 CXA2540-0000000N00W440H CXA2540-0000000N00W440F V2 4230 4730 CXA2540-0000000N0HV240H CXA2540-0000000N0HV240F V4 4545 5083 W2 4860 5435 CXA2540-0000000N0HW240H T4 3440 3818 CXA2540-0000000N0UT40H U2 3680 4115 U4 3955 4423 CXA2540-0000000N0UU440H V2 4230 4730 CXA2540-0000000N00V235H V4 4545 5083 W2 4860 5435 CXA2540-0000000N00W235H T2 3200 3552 CXA2540-0000000N0YT235H T4 3440 3818 U2 3680 4115 Group Order Code Group Order Code Group CXA2540-0000000N00V440H 40H 40H 40H 35H 3500 K 93 3-Step 35H CXA2540-0000000N00V440F CXA2540-0000000N00W240H CXA2540-0000000N0HV440H CXA2540-0000000N0UU240H CXA2540-0000000N00V435H CXA2540-0000000N0YT435H CXA2540-0000000N0YU235H Order Code 40F 40G CXA2540-0000000N0HV440G 40F CXA2540-0000000N0HW240G CXA2540-0000000N00W240F CXA2540-0000000N0HV440F CXA2540-0000000N0HW240F CXA2540-0000000N0UT440F 40G CXA2540-0000000N0UU240G 40F CXA2540-0000000N0UU440G CXA2540-0000000N0UU240F CXA2540-0000000N0UU440F CXA2540-0000000N00V235F 35G CXA2540-0000000N00V435G 35F CXA2540-0000000N00W235G CXA2540-0000000N00V435F CXA2540-0000000N00W235F CXA2540-0000000N0YT235F 35G CXA2540-0000000N0YT435G CXA2540-0000000N0YU235G 35F CXA2540-0000000N0YT435F CXA2540-0000000N0YU235F Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 16). • CXA2540 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS67 REV 10A 4 XLAMP ® CXA2540 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS (IF = 1100 mA, TJ = 85 °C) - CONTINUED Nominal CCT CRI Min 80 3000 K 90 93 80 2700 K 90 93 Minimum Luminous Flux Typ --- 95 95 --- 95 95 2-Step 3-Step 4-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* V2 4230 4730 V4 4545 5083 W2 4860 5435 CXA2540-0000000N00W230H CXA2540-0000000N00W230G CXA2540-0000000N00W230F T4 3440 3818 CXA2540-0000000N0UT430H CXA2540-0000000N0UT430G CXA2540-0000000N0UT430F U2 3680 4115 U4 3955 4423 CXA2540-0000000N0UU430H CXA2540-0000000N0UU430F T2 3200 3552 CXA2540-0000000N0YT230H CXA2540-0000000N0YT230F T4 3440 3818 U2 3680 4115 CXA2540-0000000N0YU230H U4 3955 4423 CXA2540-0000000N00U427H V2 4230 4730 V4 4545 5083 CXA2540-0000000N00V427H CXA2540-0000000N00V427G CXA2540-0000000N00V427F S4 2990 3319 CXA2540-0000000N0US427H CXA2540-0000000N0US427G CXA2540-0000000N0US427F T2 3200 3552 T4 3440 3818 CXA2540-0000000N0UT427H S4 2990 3319 CXA2540-0000000N0YS427H T2 3200 3552 T4 3440 3818 Group Order Code Group Order Code Group CXA2540-0000000N00V230H 30H 30H 30H 27H 27H 27H CXA2540-0000000N00V430H CXA2540-0000000N0UU230H CXA2540-0000000N0YT430H CXA2540-0000000N00V227H CXA2540-0000000N0UT227H CXA2540-0000000N0YT227H CXA2540-0000000N0YT427H Order Code CXA2540-0000000N00V230F 30G 30G 30G CXA2540-0000000N00V430G CXA2540-0000000N0UU230G CXA2540-0000000N0YT430G 30F 30F 30F CXA2540-0000000N0YU230G CXA2540-0000000N00V430F CXA2540-0000000N0UU230F CXA2540-0000000N0YT430F CXA2540-0000000N0YU230F CXA2540-0000000N00U427F 27G 27G CXA2540-0000000N00V227G CXA2540-0000000N0UT227G 27F 27F CXA2540-0000000N0UT427G CXA2540-0000000N00V227F CXA2540-0000000N0UT227F CXA2540-0000000N0UT427F CXA2540-0000000N0YS427F 27G CXA2540-0000000N0YT227G CXA2540-0000000N0YT427G 27F CXA2540-0000000N0YT227F CXA2540-0000000N0YT427F Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 16). • CXA2540 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS67 REV 10A 5 XLAMP ® CXA2540 LED FLUX CHARACTERISTICS, ANSI WHITE ORDER CODES AND BINS (IF = 1100 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA2540 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 14). Nominal CCT CRI Min 70 Minimum Luminous Flux Typ 75 6500 K 80 70 --- 75 5700 K 80 70 --- 75 5000 K 80 4000 K 70 --- 75 Chromaticity Regions Order Code Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* W2 4860 5435 W4 5225 5843 X2 5590 6244 CXA2540-0000-000N00X20E1 V4 4545 5083 CXA2540-0000-000N0HV40E1 W2 4860 5435 W4 5225 5843 CXA2540-0000-000N0HW40E1 W2 4860 5435 CXA2540-0000-000N00W20E2 W4 5225 5843 X2 5590 6244 CXA2540-0000-000N00X20E2 V4 4545 5083 CXA2540-0000-000N0HV40E2 W2 4860 5435 W4 5225 5843 CXA2540-0000-000N0HW40E2 W2 4860 5435 CXA2540-0000-000N00W20E3 W4 5225 5843 X2 5590 6244 CXA2540-0000-000N00X20E3 V4 4545 5083 CXA2540-0000-000N0HV40E3 W2 4860 5435 W4 5225 5843 CXA2540-0000-000N0HW40E3 V4 4545 5083 CXA2540-0000-000N00V40E5 W2 4860 5435 W4 5225 5843 CXA2540-0000-000N00W20E1 1A0, 1B0, 1C0, 1D0, 65F 1A0, 1B0, 1C0, 1D0, 65F 2A0, 2B0, 2C0, 2D0, 57F 2A0, 2B0, 2C0, 2D0, 57F 3A0, 3B0, 3C0, 3D0, 50F 3A0, 3B0, 3C0, 3D0, 50F 5A0, 5B0, 5C0, 5D0, 40F CXA2540-0000-000N00W40E1 CXA2540-0000-000N0HW20E1 CXA2540-0000-000N00W40E2 CXA2540-0000-000N0HW20E2 CXA2540-0000-000N00W40E3 CXA2540-0000-000N0HW20E3 CXA2540-0000-000N00W20E5 CXA2540-0000-000N00W40E5 Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 16). • CXA2540 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS67 REV 10A 6 XLAMP ® CXA2540 LED Relative Spectral Power Distribution RELATIVE SPECTRAL POWER DISTRIBUTION The following graph is the result of a series of pulsed measurements at 1100 mA and TJ = 85 °C. 100% Relative Spectral Power 90% 80% 70% 60% 5000 K, 70 CRI 50% 4000 K, 70 CRI 40% 3000 K, 80 CRI 30% 3000 K, 93 CRI 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) ELECTRICAL CHARACTERISTICS The following graph is the result of a series of steady-state measurements. 42 Voltage (V) 40 Tc = 25 °C 38 Tc = 55 °C Tc = 85 °C 36 Tc = 105 °C 34 32 400 740 1080 1420 1760 2100 Current (mA) © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS67 REV 10A 7 XLAMP ® CXA2540 LED RELATIVE LUMINOUS FLUX The relative luminous flux values provided below are the ratio of: • Measurements of CXA2540 at steady-state operation at the given conditions, divided by • Flux measured during binning, which is a pulsed measurement at 1100 mA at TJ = 85 °C. For example, at steady-state operation of Tc = 55 °C, IF = 1760 mA, the relative luminous flux ratio is 140% in the chart below. A CXA2540 LED that measures 4600 lm during binning will deliver 6440 lm (4600 * 1.4) at steady-state operation of Tc = 55 °C, IF = 1760 mA. 180% 160% Relative Luminous Flux 140% 120% Tc = 25 °C 100% Tc = 55 °C 80% Tc = 85 °C Tc = 105 °C 60% 40% 20% 0% 400 740 1080 1420 1760 2100 Current (mA) © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS67 REV 10A 8 XLAMP ® CXA2540 LED Far Field TYPICAL SPATIAL DISTRIBUTION 100% Relative Luminous Intensity 80% 60% 40% 20% -90 -70 -50 -30 -10 0% 10 30 50 70 90 Angle (º) PERFORMANCE GROUPS - BRIGHTNESS (I F = 1100 mA, TJ = 85 °C) XLamp CXA2540 LEDs are tested for luminous flux and placed into one of the following bins. Group Code Minimum Luminous Flux Maximum Luminous Flux S4 2990 3200 T2 3200 3440 T4 3440 3680 U2 3680 3955 U4 3955 4230 V2 4230 4545 V4 4545 4860 W2 4860 5225 W4 5225 5590 X2 5590 6010 X4 6010 6430 © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS67 REV 10A 9 XLAMP ® CXA2540 LED PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) XLamp CXA2540 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. EasyWhite Color Temperatures – 2-Step Code 50H 40H 35H 30H 27H CCT 5000 K 4000 K 3500 K 3000 K 2700 K x y 0.3429 0.3507 0.3434 0.3571 0.3475 0.3604 0.3469 0.3539 0.3784 0.3741 0.3804 0.3818 0.3867 0.3857 0.3844 0.3778 0.4030 0.3857 0.4061 0.3941 0.4132 0.3976 0.4099 0.3890 0.4291 0.3973 0.4333 0.4062 0.4395 0.4084 0.4351 0.3994 0.4528 0.4046 0.4578 0.4138 0.4638 0.4152 0.4586 0.4060 EasyWhite Color Temperatures – 3-Step Ellipse Bin Code CCT 50G 40G Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 5000 K 0.3447 0.3553 0.00840 0.00312 65.0 4000 K 0.3818 0.3797 0.00939 0.00402 53.7 35G 3500 K 0.4073 0.3917 0.00927 0.00414 54.0 30G 3000 K 0.4338 0.4030 0.00834 0.00408 53.2 27G 2700 K 0.4577 0.4099 0.00834 0.00420 48.5 © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS67 REV 10A 10 XLAMP ® CXA2540 LED PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) - CONTINUED EasyWhite Color Temperatures – 4-Step Code 65F 57F 50F 40F 35F 30F 27F CCT 6500 K 5700 K 5000 K 4000 K 3500 K 3000 K 2700 K x y 0.3097 0.3196 0.3079 0.3297 0.3164 0.3382 0.3176 0.3275 0.3253 0.3325 0.3249 0.3439 0.3331 0.3514 0.3330 0.3393 0.3407 0.3459 0.3415 0.3586 0.3499 0.3654 0.3484 0.3521 0.3744 0.3685 0.3782 0.3837 0.3912 0.3917 0.3863 0.3758 0.3981 0.3800 0.4040 0.3966 0.4186 0.4037 0.4116 0.3865 0.4242 0.3919 0.4322 0.4096 0.4449 0.4141 0.4359 0.3960 0.4475 0.3994 0.4573 0.4178 0.4695 0.4207 0.4589 0.4021 © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS67 REV 10A 11 XLAMP ® CXA2540 LED PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) - CONTINUED ANSI White Bins Code Bin Code CCT 1A0 1B0 0E1 6500 K 1C0 1D0 ANSI White Bins x y 0.3048 0.3207 0.3130 0.3290 0.3144 0.3186 0.3068 Code x y 0.3215 0.3350 0.3290 0.3417 0.3290 0.3300 0.3113 0.3222 0.3243 0.3028 0.3304 0.3207 0.3462 0.3115 0.3391 0.3290 0.3538 0.3130 0.3290 0.3290 0.3417 0.3048 0.3207 0.3215 0.3350 0.3115 0.3391 0.3290 0.3538 0.3205 0.3481 0.3376 0.3616 0.3213 0.3373 0.3371 0.3490 0.3130 0.3290 0.3290 0.3417 0.3130 0.3290 0.3290 0.3417 0.3213 0.3373 0.3371 0.3490 0.3221 0.3261 0.3366 0.3369 0.3144 0.3186 0.3290 0.3300 2A0 2B0 0E2 5700 K 2C0 2D0 ANSI White Bins Code CCT Bin Code 3A0 3B0 0E3 5000 K 3C0 3D0 Bin Code CCT ANSI White Bins x y Code CCT Bin Code x y .3371 .3490 .3670 .3578 .3451 .3554 .3702 .3722 .3440 .3427 .3825 .3798 .3366 .3369 .3783 .3646 .3376 .3616 .3702 .3722 .3463 .3687 .3736 .3874 .3451 .3554 .3869 .3958 .3371 .3490 .3825 .3798 .3825 .3798 .3869 .3958 .4006 .4044 5A0 5B0 0E5 4000 K .3463 .3687 .3551 .3760 .3533 .3620 .3451 .3554 .3950 .3875 .3451 .3554 .3783 .3646 .3533 .3620 .3825 .3798 .3515 .3487 .3950 .3875 .3440 .3427 .3898 .3716 5C0 5D0 © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS67 REV 10A 12 XLAMP ® CXA2540 LED EASYWHITE® BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) 0.44 2700 K ANSI C78.377 Quadrangle 0.43 3000 K EasyWhite 4-Step EasyWhite 3-Step 0.42 EasyWhite 2-Step 3500 K 0.41 4000 K 0.40 4500 K CCy 0.39 5000 K 0.38 0.37 5700 K 0.36 6500 K 0.35 0.34 0.33 0.32 0.49 0.48 0.47 0.45 0.41 0.46 0.44 0.40 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.31 CCx ANSI WHITE BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) 0.41 4000 K ANSI C78.377 Quadrangle 0.40 4500 K 5C 0.39 5D 0.37 CCy 5B 5000 K 0.38 5700 K 0.36 5A 3C 3B 6500 K 0.35 2B 0.34 1C 1B 0.33 3D 2C 1D 3A 2D 2A 1A 0.32 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.31 CCx © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS67 REV 10A 13 XLAMP ® CXA2540 LED BIN AND ORDER CODE FORMATS Bin codes and order codes are configured as follows: Order Code Bin Code Series = CXA25 Series = CXA25 Internal code Chromaticity bin CRI Specification 0 = Standard CRI H = 80 CRI minimum U = 90 CRI minimum Y = 93 CRI minimum Vf class N0 = 36-V class Internal code SSSSSCC-WWW-FF-GGR-AAAAA SSSSSCC-HHHH-HHHGGRNNNNN CRI Specification B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Y = 93 CRI minimum Kit code Vf class N0 = 36-V class Flux bin Performance class Performance class MECHANICAL DIMENSIONS Dimensions are in mm. Tolerances unless otherwise specified: ±.13 Meaning of 2540N 2540N = 36‑V CXA2540 2540N x° ± 1° © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS67 REV 10A 14 XLAMP ® CXA2540 LED THERMAL DESIGN The CXA family of LED arrays can include over a hundred different LED die inside one package, and thus over a hundred different junction temperatures (TJ). Cree LED has intentionally removed junction-temperature-based operating limits and replaced the commonplace maximum TJ calculations with maximum ratings based on forward current (IF) and case temperature (Tc). No additional calculations are required to ensure that the CXA LED is being operated within its designed limits. LES temperature measurement provides additional verification of good thermal design. Please refer to page 2 for the Operating Limit specifications. There is no need to calculate for TJ inside the package, as the thermal management design process, specifically from TSP to ambient (Ta), remains identical to any other LED component. For more information on thermal management of XLamp LEDs, please refer to the Thermal Management application note. For CXA soldering recommendations and more information on thermal interface materials (TIM), LES temperature measurement, and connection methods, please refer to the XLamp CX Family LEDs soldering and handling document. The CX Family LED Design Guide provides basic information on the requirements to use XLamp CXA LEDs successfully in luminaire designs. To keep the CXA2540 LED at or below the maximum rated Tc, the case to ambient temperature thermal resistance (R_c-a) must be at or below the maximum R_c-a value shown on the following R_j-c R_j-c scale. Tc Tc As the figure at right shows, the R_c-a value is the sum of the thermal resistance of the TIM (R_tim) R_tim graph, depending on the operating environment. The y‑axis in the graph is a base 10 logarithmic R_c-a plus the thermal resistance of the heat sink (R_hs). R_hs CXA2540 Ta Ta Maximum R_c-a 10.00 1.00 Ta = 25 °C Ta = 55 °C Ta = 85 °C Ta = 105 °C 0.10 0.01 400 740 1080 1420 1760 2100 Current (mA) © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS67 REV 10A 15 XLAMP ® CXA2540 LED NOTES Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs. Lumen Maintenance Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. REACh Compliance REACh substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative to insure you get the most up-to-date REACh Declaration. REACh banned substance information (REACh Article 67) is also available upon request. UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS67 REV 10A 16 XLAMP ® CXA2540 LED PACKAGING 6 CXA2540 LEDs are packaged5in trays of 20. Five trays are sealed in an anti-static bag and placed inside a carton, for a total of 100 LEDs 4 3 2 per carton. Each carton contains 100 LEDs from the same performance bin. NOTICE NTIAL. THIS PLOT AND THE INFORMATION THIN ARE THE PROPRIETARY AND NFORMATION OF CREE, INC. THIS PLOT PIED, REPRODUCED OR DISCLOSED TO ANY D PERSON WITHOUT THE WRITTEN CONSENT Dimensions are in inches. Tolerances: ±.13 7.125 4 5 3 x° ±1° 2 R .375 5 4 3 1 2 1 AND THE INFORMATION NSENT OPRIETARY AND F CREE, INC. THIS PLOT ED OR DISCLOSED TO ANY OUT THE WRITTEN CONSENT 1.188 5.875 R .375 7.125 R .375 7.625 .875 1.188 7.625 .38 1.188 LABEL WITH CREE BIN CODE, QUANTITY, LOT # BAG PATENT LABEL IS LOCATED ON UNDERSIDE COVER PATENT LABELOF IS LOCATED ON UNDERSIDE OF CARTON LABEL WITH CREE BIN TH CREECODE, BIN QUANTITY, LOT # .875 .38 1.188 BAG .38 ANTITY, LOT # BAG LABEL WITH CREE BIN CODE, QUANTITY, LOT # PATENT LABEL IS LOCATED ON UNDERSIDE OF COVER L IS LOCATED IDE OF COVER LABEL WITH CREE BIN CODE, QUANTITY, LOT # LABEL WITH CREE BIN CODE, QUANTITY, LOT # LABEL WITH CREE BIN CODE, QUANTITY, LOT # LABEL WITH CREE BIN CODE, QUANTITY, LOT # UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS & BEFORE FINISH. TOLERANCE UNLESS SPECIFIED: .X ± .XX ± .XXX ± X° ± THIRD ANGLE PROJECTION 6 LABEL WITH CREE BIN CODE, QUANTITY, LOT # 5 UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS & BEFORE FINISH. TOLERANCE UNLESS 3SPECIFIED: 4 .X ± .XX ± UNLESS OTHERWISE SPECIFIED .XXX ± THIRD ANGLE PROJECTION DIMENSIONS AREX°IN ± WITH CREE BIN QUANTITY, LOT # 0.1 .05 .005 1 ° DATE TITLE CXA25X SIZE FINAL PROTECTIVE FINISH SCALE DRAWING CXA25 4600 Silicon Drive Durham, N.C 27703 0.500 Phone (919) 361-4770 Fax (919) 313-5303 TITLE CXA25XX_DATASHEET 4600 Silicon Drive Durham, N.C 27703 MATERIAL DATE Phone (919) 361-4770 SIZE TITLE SCALE 2 DRAWING NO. Fax (919) 313-5303 CLD-DS67 CXA25XX_DATASHEET_BAG2013 C 17 REV 10A 0.500 CXA15XX_DATASHEET SHEET 1 SIZE FINAL PROTECTIVE FINISH C DATE DATE 3 FOR SHEET METAL PARTS ONLY .X ± .06 DATE APPROVED 2 APPROVED DRAWN BY .X ± .06 and © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered APPROVED FINAL PROTECTIVE FINISH DATE .X ± trademarks, 0.1 ± .XX .03 ± .05 registered the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the.XXUL logo are .XXX ± .010 .XXX ± X° .005 ± 2 ° trademarks of UL LLC. THIRD ANGLE PROJECTION MATERIAL X° ± 1 ° 4 DATE MATERIAL FOR SHEET METAL PARTS ONLY .X ± .06 DATE DRAWN.XX BY ± .03 .XXX ± .010 X° ± 2 ° CHECK DATE CHECK MILLIMETERS & BEFORE FINISH. FOR SHEET METAL PARTS ONLY TOLERANCE UNLESS SPECIFIED: 5 0.1 .05 .005 1 ° DRAWN BY CHECK DRAWING NO. CXA15XX_DATASHEET_BAG2013 OF R
物料型号:CXA2540 LED
器件简介:CXA2540 LED是CREE公司生产的一款高流量、多芯片集成阵列LED,具有高可靠性和易用性。它适用于定向和非定向照明应用,以及灯具和灯的设计。
引脚分配:文档中没有明确提供引脚分配的详细信息。
参数特性: - 视场角:115° - ESD耐压:8000V(人体模型,根据Mil-Std-883D标准) - 直流正向电流:最高2100 mA - 反向电流:最高0.1 mA - 正向电压:在1100 mA和85°C时为36.2V,在1100 mA和25°C时为42V
功能详解: - 提供2步、3步和4步EasyWhite®色温选项,包括2700K、3000K、3500K、4000K、5000K、5700K和6500K的CCT。 - 提供70、80、90和93的最低CRI选项。 - 具有4步颜色一致性。 - 视场角为115°,提供统一的色度配置文件。 - 符合NEMA SSL-3 2011标准通量箱。
应用信息: - 适用于照明应用,包括灯具和灯的设计。
封装信息: - 符合RoHS和REACh标准。 - UL®认可的组件(E349212)。
CXA2540-0000-000N0UT227F 价格&库存
很抱歉,暂时无法提供与“CXA2540-0000-000N0UT227F”相匹配的价格&库存,您可以联系我们找货
