CXB1830-0000-000N0UT230G
    WOLFSPEED
    LEDCOBCXB18303000KWHTSMD
CXB1830-0000-000N0UT230G 数据手册
PRODUCT FAMILY DATA SHEET XLamp® CXB1830 LED PRODUCT DESCRIPTION FEATURES TABLE OF CONTENTS The XLamp® CXB1830 LED Array is a • 14‑mm optical source Characteristics................................................ 2 member of the second generation of the • Optical design consistent with Operating Limits.............................................. 2 CXA family that delivers up to 30% higher Flux Characteristics, EasyWhite® Order CXA1830 LEDs efficacy and up to 20% higher lumens than • Available in 70-, 80-, 90- and Codes and Bins............................................... 3 the first generation in the same LES. The Flux Characteristics, Premium Color Order 95-minimum CRI options higher performance second generation • EasyWhite 2‑, 3‑ and 5-step binning Codes and Bins............................................... 6 CXA Relative Spectral Power Distribution, ® LED Arrays provide a drop-in • Premium Color 2- and 3-step binning performance upgrade to existing CXA LED • Forward voltage option: 36‑V class EasyWhite® ..................................................... 7 designs to shorten product development • 85 °C binning and characterization Relative Spectral Power Distribution, time. In addition, the CXB LEDs also • Extremely uniform color over viewing Premium Color................................................ 7 allow lighting manufacturers to achieve Electrical Characteristics................................ 8 the same or better performance with a angle • Top-side solder connections Relative Luminous Flux................................... 9 smaller LES, enabling a smaller, more • Thermocouple attach point Typical Spatial Distribution........................... 10 impactful luminaire. Available in 2‑step, • NEMA SSL-3 2011 standard flux bins Performance Groups - Brightness............... 10 3‑step and 5‑step EasyWhite EasyWhite® Performance Groups - ® bins and • RoHS and REACH compliant 2‑step and 3‑step Premium Color bins, the • UL® recognized component (E349212) Chromaticity.................................................. 11 CXB1830 LED delivers high lumen output Premium Color Performance Groups - and high efficacy in a single, easy‑to‑use Chromaticity.................................................. 12 package that eliminates the need for reflow EasyWhite® Bins Plotted on the 1931 CIE soldering. Color Space................................................... 13 Premium Color Bins Plotted on the 1931 The CX Family LED Design Guide provides CIE Color Space............................................ 14 basic information on the requirements Bin and Order Code Formats........................ 16 to use the CXB1830 LED successfully in Mechanical Dimensions............................... 16 luminaire designs. Thermal Design............................................. 17 Notes............................................................. 18 Packaging...................................................... 19 Cree LED / 4400 Silicon Drive / Durham, NC 27703 USA / +1.919.313.5330 / www.cree-led.com © 2015-2022 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks, and the Cree LED logo is a trademark, of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS121 REV 10 1 XLAMP ® CXB1830 LED CHARACTERISTICS Characteristics Unit Viewing angle (FWHM) Minimum Typical degrees ESD withstand voltage (HBM per Mil-Std-883D) Maximum 115 V 8000 DC forward current mA 1400* Reverse current mA 0.1 Forward voltage (@ 800 mA, 85 °C) * V 35 38 Refer to the Operating Limits section. OPERATING LIMITS The maximum current rating of the CXB1830 depends on the case temperature (Tc) when the LED has reached thermal equilibrium under steady-state operation. The graph shown below assumes that the system design employs good thermal management (thermal interface material and heat sink) and may vary when poor thermal management is employed. Please refer to the Mechanical Dimensions section on page 16 for the location of the Tc measurement point. Another important factor in good thermal management is the temperature of the Light Emitting Surface (LES). Cree LED recommends a maximum LES temperature of 135 °C to ensure optimal LED lifetime. Please refer to the Thermal Design section on page 17 for more CXB1830 - Standard information on LES temperature measurement. 1500 90 °C, 1400 mA 1200 Standard If (mA) 900 125 °C, 583 mA 600 300 0 0 25 50 75 100 125 150 Case Temperature (°C) © 2015-2022 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks, and the Cree LED logo is a trademark, of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS121 REV 10 2 XLAMP ® CXB1830 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS (IF = 800 mA, TJ = 85 °C) The following table provides order codes for XLamp CXB1830 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 16). CRI* Nominal CCT Min 70 Minimum Luminous Flux Typ --- 6500 K 80 70 70 5000 K 80 90 3-Step --- Flux (lm) @ 85 °C Flux (lm) @ 25 °C** U4 3955 4332 V2 4230 4633 V4 4545 4978 CXB1830-0000000N0BV465E U4 3955 4332 CXB1830-0000000N0HU465E V2 4230 4633 CXB1830-0000000N0HV265E U4 3955 4332 CXB1830-0000000N0BU457E V2 4230 4633 V4 4545 4978 CXB1830-0000000N0BV457E U4 3955 4332 CXB1830-0000000N0HU457E V2 4230 4633 CXB1830-0000000N0HV257E U4 3955 4332 CXB1830-0000000N0BU450E V2 4230 4633 V4 4545 4978 U4 3955 4332 V2 4230 4633 CXB1830-0000000N0HV250G T4 3440 3768 CXB1830-0000000N0UT450G U2 3680 4031 U4 3955 4332 Group Order Code Group Order Code 65E 65E 57E 57E --- 92 Group Order Code CXB1830-0000000N0BU465E --- --- 5-Step Group --- 5700 K 80 2-Step 50E CXB1830-0000000N0BV265E CXB1830-0000000N0BV257E CXB1830-0000000N0BV250E CXB1830-0000000N0BV450E 50G 50G CXB1830-0000000N0HU450G 50E CXB1830-0000000N0HU450E CXB1830-0000000N0HV250E CXB1830-0000000N0UU250G CXB1830-0000000N0UU450G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 18). • CXB1830 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2022 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks, and the Cree LED logo is a trademark, of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS121 REV 10 3 XLAMP ® CXB1830 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS (IF = 800 mA, TJ = 85 °C) - CONTINUED CRI* Nominal CCT Min 70 4000 K 80 90 80 Minimum Luminous Flux Typ --- --- 92 --- 3500 K 90 80 90 Flux (lm) @ 85 °C Flux (lm) @ 25 °C** U4 3955 4332 V2 4230 4633 V4 4545 4978 U2 3680 4031 U4 3955 4332 V2 4230 4633 CXB1830-0000000N0HV240H CXB1830-0000000N0HV240G T2 3200 3505 CXB1830-0000000N0UT240H CXB1830-0000000N0UT240G T4 3440 3768 U2 3680 4031 CXB1830-0000000N0UU240H CXB1830-0000000N0UU240G U2 3680 4031 CXB1830-0000000N0HU235H CXB1830-0000000N0HU235G U4 3955 4332 V2 4230 4633 CXB1830-0000000N0HV235H CXB1830-0000000N0HV235G S4 2990 3275 CXB1830-0000000N0US435H CXB1830-0000000N0US435G T2 3200 3505 Group Order Code Group Order Code 5-Step Group Order Code CXB1830-0000000N0BU440E 40E CXB1830-0000000N0BV240E CXB1830-0000000N0BV440E CXB1830-0000000N0HU240H 40H 40H 35H 35H CXB1830-0000000N0HU440H CXB1830-0000000N0UT440H CXB1830-0000000N0HU435H CXB1830-0000000N0UT235H CXB1830-0000000N0HU240G 40G 40G 35G 35G CXB1830-0000000N0HU440G CXB1830-0000000N0UT440G CXB1830-0000000N0HU435G CXB1830-0000000N0UT235G T4 3440 3768 CXB1830-0000000N0UT435H U2 3680 4031 CXB1830-0000000N0UU235H CXB1830-0000000N0UU235G U2 3680 4031 CXB1830-0000000N0HU230H CXB1830-0000000N0HU230G U4 3955 4332 CXB1830-0000000N0HU430H S4 2990 3275 CXB1830-0000000N0US430H T2 3200 3505 T4 3440 3768 --- 92 3-Step Group 92 3000 K 2-Step 30H 30H CXB1830-0000000N0UT230H CXB1830-0000000N0UT430H 30G CXB1830-0000000N0UT435G CXB1830-0000000N0HU430G CXB1830-0000000N0US430G 30G CXB1830-0000000N0UT230G CXB1830-0000000N0UT430G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 18). • CXB1830 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2022 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks, and the Cree LED logo is a trademark, of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS121 REV 10 4 XLAMP ® CXB1830 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS (IF = 800 mA, TJ = 85 °C) - CONTINUED CRI* Nominal CCT Min 80 Minimum Luminous Flux Typ --- 2-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** T4 3440 3768 U2 3680 4031 U4 3955 4332 CXB1830-0000000N0HU427H CXB1830-0000000N0HU427G S2 2780 3045 CXB1830-0000000N0US227H CXB1830-0000000N0US227G S4 2990 3275 T2 3200 3505 T2 3200 3505 Group 2200 K 80 92 --- Order Code Group CXB1830-0000000N0HT427H 27H 2700 K 90 3-Step 27H CXB1830-0000000N0HU227H CXB1830-0000000N0US427H Order Code 5-Step Group Order Code CXB1830-0000000N0HT427G 27G 27G CXB1830-0000000N0UT227H CXB1830-0000000N0HU227G CXB1830-0000000N0US427G CXB1830-0000000N0UT227G 22G CXB1830-0000000N0HT222G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 18). • CXB1830 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2022 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks, and the Cree LED logo is a trademark, of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS121 REV 10 5 XLAMP ® CXB1830 LED FLUX CHARACTERISTICS, PREMIUM COLOR ORDER CODES AND BINS (IF = 800 mA, TJ = 85 °C) Fidelity CRI* Nominal CCT Minimum Luminous Flux Min Typ Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** 4000 K 95 98 S4 2990 3275 3500 K 95 98 S4 2990 3000 K 95 98 S2 2700 K 95 98 S2 Typical Luminous Flux (lm) @ 85 °C 2-Step Group Order Code 3346 L5A CXB1830-0000-000N0ZS4L5A 3275 3222 35H CXB1830-0000-000N0ZS435H 2780 3045 3098 30H CXB1830-0000-000N0ZS230H 2780 3045 2923 27H CXB1830-0000-000N0ZS227H Specialty CRI Nominal CCT 3100 K Min 90 80 3000 K 90 95 Minimum Luminous Flux Typ Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** S4 2990 3275 T2 3200 3505 U2 3680 4031 S2 2780 3030 S4 2990 3275 T2 3200 3505 R4 2600 2848 92 --- 92 98 Typical Luminous Flux (lm) @ 85 °C 2-Step Group Order Code 3571 4152 3-Step Group 31Q L7B Order Code Group Order Code CXB1830-0000000N0US431Q CXB1830-0000000N0UT231Q CXB1830-0000000N0HU2L7B CXB1830-0000000N0US230U 3571 30Q CXB1830-0000000N0US430Q CXB1830-0000000N0UT230Q 3098 L7C 30U CXB1830-0000000N0US430U CXB1830-0000000N0UT230U CXB1830-0000000N0ZR4L7C Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 18). • CXB1830 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2022 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks, and the Cree LED logo is a trademark, of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS121 REV 10 6 XLAMP ® CXB1830 LED RELATIVE SPECTRAL POWER DISTRIBUTION, EASYWHITE® The following graph is the result of a series of pulsed measurements at 800 mA and TJ = 85 °C. 100% Relative Spectral Power 90% 80% 70% 5000 K, 70 CRI 60% 4000 K, 70 CRI 50% 3000 K, 80 CRI 40% 3000 K, 90 CRI 30% 2200 K, 80 CRI 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) RELATIVE SPECTRAL POWER DISTRIBUTION, PREMIUM COLOR The following graphs are the result of a series of pulsed measurements at 800 mA and TJ = 85 °C. Fidelity 100% Relative Spectral Power 90% 80% 70% 60% 4000 K, Z CRI 50% 3500 K, Z CRI 3000 K, Z CRI 40% 2700 K, Z CRI 30% 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) © 2015-2022 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks, and the Cree LED logo is a trademark, of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS121 REV 10 7 XLAMP ® CXB1830 LED RELATIVE SPECTRAL POWER DISTRIBUTION, PREMIUM COLOR - CONTINUED Relative Spectral Power Distribution Specialty 100% 90% Relative Spectral Power 80% 70% 31Q, 3100 K, 90 CRI 60% 30Q, 3000 K, 90 CRI 50% 30U, 3000 K, 90 CRI 40% L7B, 3000 K 80 CRI 30% L7C, 3000 K, Z CRI 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) ELECTRICAL CHARACTERISTICS The following graph is the result of a series of steady-state measurements. 39 38 Voltage (V) 37 Tc = 25 °C 36 Tc = 55 °C Tc = 85 °C 35 Tc = 105 °C 34 33 32 400 500 600 700 800 900 1000 1100 1200 1300 1400 Current (mA) © 2015-2022 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks, and the Cree LED logo is a trademark, of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS121 REV 10 8 XLAMP ® CXB1830 LED RELATIVE LUMINOUS FLUX The relative luminous flux values provided below are the ratio of measurements of the CXB1830 LED at steady-state operation at the given conditions, divided by the flux measured during binning, which is a pulsed measurement at 800 mA at TJ = 85 °C. For example, at steady-state operation of Tc = 25 °C, IF = 900 mA, the relative luminous flux ratio is 120% in the chart below. A CXB1830 LED that measures 3200 lm during binning will deliver 3840 lm (3200 * 1.2) at steady-state operation of Tc = 25 °C, IF = 900 mA. 180% 160% Relative Luminous Flux 140% 120% Tc = 25 °C 100% Tc = 55 °C Tc = 85 °C 80% Tc = 105 °C 60% 40% 20% 0% 400 600 800 1000 1200 1400 Current (mA) © 2015-2022 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks, and the Cree LED logo is a trademark, of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS121 REV 10 9 XLAMP ® CXB1830 LED Far Field TYPICAL SPATIAL DISTRIBUTION 100% Relative Luminous Intensity 80% 60% 40% 20% -90 -70 -50 -30 -10 0% 10 30 50 70 90 Angle (º) PERFORMANCE GROUPS - BRIGHTNESS (I F = 800 mA, TJ = 85 °C) XLamp CXB1830 LEDs are tested for luminous flux and placed into one of the following bins. Group Code Minimum Luminous Flux Maximum Luminous Flux R4 2600 2780 S2 2780 2990 S4 2990 3200 T2 3200 3440 T4 3440 3680 U2 3680 3955 U4 3955 4230 V2 4230 4545 V4 4545 4860 W2 4860 5225 © 2015-2022 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks, and the Cree LED logo is a trademark, of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS121 REV 10 10 XLAMP ® CXB1830 LED EASYWHITE® PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) XLamp CXB1830 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. EasyWhite Color Temperatures – 2-Step Code 40H 35H 30H 27H CCT 4000 K 3500 K 3000 K 2700 K x y 0.3777 0.3739 0.3797 0.3816 0.3861 0.3855 0.3838 0.3777 0.4022 0.3858 0.4053 0.3942 0.4125 0.3977 0.4091 0.3891 0.4287 0.3975 0.4328 0.4064 0.4390 0.4086 0.4347 0.3996 0.4524 0.4048 0.4574 0.4140 0.4633 0.4154 0.4581 0.4062 EasyWhite Color Temperatures – 3-Step Ellipse Bin Code CCT 50G 40G Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 5000 K 0.3447 0.3553 0.00840 0.00312 65.0 4000 K 0.3818 0.3797 0.00939 0.00402 53.7 35G 3500 K 0.4073 0.3917 0.00927 0.00414 54.0 30G 3000 K 0.4338 0.4030 0.00834 0.00408 53.2 27G 2700 K 0.4577 0.4099 0.00834 0.00420 48.5 22G 2200 K 0.5066 0.4158 0.00980 0.00480 45.5 EasyWhite Color Temperatures – 5-Step Ellipse Bin Code CCT 65E Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 6500 K 0.3123 0.3282 0.01110 0.00550 61.0 57E 5700 K 0.3287 0.3417 0.01230 0.00600 72.0 50E 5000 K 0.3447 0.3553 0.01400 0.00520 65.0 40E 4000 K 0.3818 0.3797 0.01565 0.00670 53.7 © 2015-2022 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks, and the Cree LED logo is a trademark, of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS121 REV 10 11 XLAMP ® CXB1830 LED PREMIUM COLOR PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) XLamp CXB1830 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. Fidelity EasyWhite Color Temperatures – 2-Step Code L5A 35H 30H 27H CCT 4000 K 3500 K 3000 K 2700 K x y 0.3764 0.3711 0.3784 0.3787 0.3847 0.3826 0.3825 0.3748 0.4022 0.3858 0.4053 0.3942 0.4125 0.3977 0.4091 0.3891 0.4287 0.3975 0.4328 0.4064 0.4390 0.4086 0.4347 0.3996 0.4524 0.4048 0.4574 0.4140 0.4633 0.4154 0.4581 0.4062 Specialty EasyWhite Color Temperatures – 2-Step Code L7B L7C CCT 3000 K 3000 K x y 0.4263 0.3848 0.4296 0.3916 0.4361 0.3938 0.4326 0.3868 0.4192 0.3754 0.4224 0.3823 0.4291 0.3847 0.4257 0.3777 EasyWhite Color Temperatures – 3-Step Ellipse Center Point Major Axis Minor Axis Rotation Angle (°) Bin Code CCT x y a b 31Q 3100 K 0.4236 0.3888 0.00848 0.00455 50.3 30Q 3000 K 0.4305 0.3935 0.00834 0.00408 53.2 30U 3000 K 0.4274 0.3837 0.00834 0.00408 53.2 © 2015-2022 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks, and the Cree LED logo is a trademark, of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS121 REV 10 12 XLAMP ® CXB1830 LED EASYWHITE® BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) 0.45 ANSI C78.377 Quadrangle 0.44 2700 K EasyWhite 5-step 0.43 2200 K 2450 K 3000 K EasyWhite 3-step 0.42 EasyWhite 2-step 3500 K 0.41 4000 K 0.40 CCy 0.39 5000 K 4500 K 5700 K 0.38 0.37 6500 K 0.36 0.35 7000K 0.34 0.33 0.32 0.54 0.53 0.52 0.51 0.50 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.31 CCx © 2015-2022 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks, and the Cree LED logo is a trademark, of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS121 REV 10 13 XLAMP ® CXB1830 LED PREMIUM COLOR BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) Fidelity (2-step) 0.44 2700K ANSI C78.377 Quadrangle 0.43 3000K 0.42 3500K 0.41 27H 4000K CCy 0.40 30H 4500K 35H 0.39 0.38 L5A 0.37 0.36 0.35 © 2015-2022 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks, and the Cree LED logo is a trademark, of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. 0.48 0.47 0.46 0.45 0.44 CCx 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 CLD-DS121 REV 10 14 XLAMP ® CXB1830 LED PREMIUM COLOR BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) - CONTINUED Speciality (2-step) 0.44 ANSI C78.377 Quadrangle 3000 K 0.43 0.42 3500 K CCy 0.41 0.40 0.39 L7B L7C 0.38 0.46 0.45 CCx 0.44 0.43 0.42 0.41 0.37 Speciality (3-step) 0.44 ANSI C78.377 Quadrangle 3000K 0.43 0.42 3500K CCy 0.41 0.40 30Q 0.39 31Q 30U 0.38 © 2015-2022 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks, and the Cree LED logo is a trademark, of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. 0.46 0.45 CCx 0.44 0.43 0.42 0.41 0.37 CLD-DS121 REV 10 15 XLAMP ® CXB1830 LED BIN AND ORDER CODE FORMATS Bin codes and order codes are configured as follows: Order Code Bin Code Series = CXB18 Series = CXB18 Internal code Chromaticity bin CRI Specification B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Vf class N0 = 36-V class SSSSSCC-HHHH-HHHGGRNNNNN Internal code SSSSSCC-WWW-FF-GGR-AAAAA CRI Specification B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Kit code Vf class N0 = 36-V class Flux bin Performance class 6 Performance class 5 4 3 2 NOTICE CREE CONFIDENTIAL. THIS PLOT AND THE INFORMATION CONTAINED WITHIN ARE THE PROPRIETARY AND CONFIDENTIAL INFORMATION OF CREE, INC. THIS PLOT MAY NOT BE COPIED, REPRODUCED OR DISCLOSED TO ANY UNAUTHORIZED PERSON WITHOUT THE WRITTEN CONSENT OF CREE INC. MECHANICAL DIMENSIONS Dimensions are in mm. D Tolerances unless otherwise 17.85 ±0.02 0.65 specified: +.13 6.37 0.65 Meaning of B1830N B1830N = 36‑V CXB1830 Tc 2.95 x° +1° 1.15 ±0.15 OPTICAL REFERENCE 2.95 R0.50 C 1.30 6.92 17.85 ±0.20 R0.50 14.00±0.2 B 2.95 16.00±0.3 0.65 2.95 0.55 ±0.1 0.65 OPTICAL REFERENCE A © 2015-2022 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® areTHIRD ANGLE PROJECTION registered trademarks, and the Cree LED logo is a trademark, of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLMETERS & BEFORE FINISH. TOLERANCE UNLESS SPECIFIED: .X ± 0.3 .XX ± 0.13 5 4 3 D ATE D ATE APPR O VED D ATE TITLE 16 CLD-DS121 FOR SHEET METAL PARTS ONLYREV 10 X° ± 1° .X ± 0.25 .XX ± 0.10 X° 6 D R AW N BY C H EC K STRINKLE 10/19/22 M ATER IAL SIZE FINAL PROTECTIVE FINISH SCALE ± 2° 2 CXB1830N C 10:1 DRAWING NO. CXB1830N XLAMP ® CXB1830 LED THERMAL DESIGN The CXB family of LED arrays can include over a hundred different LED die inside one package, and thus over a hundred different junction temperatures (TJ). Cree LED has intentionally removed junction-temperature-based operating limits and replaced the commonplace maximum TJ calculations with maximum ratings based on forward current (IF) and case temperature (Tc). No additional calculations are required to ensure that the CXB LED is being operated within its designed limits. LES temperature measurement provides additional verification of good thermal design. Please refer to page 2 for the Operating Limit specifications. There is no need to calculate for TJ inside the package, as the thermal management design process, specifically from TSP to ambient (Ta), remains identical to any other LED component. For more information on thermal management of XLamp LEDs, please refer to the Thermal Management application note. For CXB soldering recommendations and more information on thermal interface materials (TIM), LES temperature measurement, and connection methods, please refer to the XLamp CX Family LEDs soldering and handling document. The CX Family LED Design Guide provides basic information on the requirements to use XLamp CXB LEDs successfully in luminaire designs. To keep the CXB1830 LED at or below the maximum rated Tc, the case to ambient temperature thermal resistance (R_c-a) must be at or below the maximum R_c-a value shown on the following graph, depending on the operating environment. The y‑axis in the graph is a base 10 logarithmic scale. R_j-c R_j-c Tc Tc R_tim As the figure at right shows, the R_c-a value is the sum of the thermal resistance of the TIM R_c-a (R_tim) plus the thermal resistance of the heat sink (R_hs). R_hs CXB1830 Ta Ta 100.00 Maximum R_c-a 10.00 Ta = 25 °C Ta = 55 °C 1.00 Ta = 85 °C Ta = 105 °C 0.10 0.01 400 500 600 700 800 900 1000 1100 1200 1300 1400 Current (mA) © 2015-2022 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks, and the Cree LED logo is a trademark, of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS121 REV 10 17 XLAMP ® CXB1830 LED NOTES Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs. Lumen Maintenance Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. REACH Compliance REACH substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative to insure you get the most up-to-date REACH Declaration. REACH banned substance information (REACH Article 67) is also available upon request. UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. © 2015-2022 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks, and the Cree LED logo is a trademark, of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS121 REV 10 18 XLAMP ® CXB1830 LED PACKAGING CXB1830 LEDs are packaged in trays of 20. Five trays are sealed in an anti-static bag and placed inside a carton, for a total of 100 LEDs per carton. Each carton contains 100 LEDs from the same performance bin. REV 5 7.875 R.375 6 DESC. DATE 4 BY CHK. REV Dimensions are in inches. DESC. 3 DATE BY CHK. Tolerances: +.13 x° +1° 2 1 R.375 5 4 3 NOTICE FIDENTIAL. THIS PLOT AND THE INFORMATION NSENT D WITHIN ARE THE PROPRIETARY AND TIAL INFORMATION OF CREE, INC. THIS PLOT E COPIED, REPRODUCED OR DISCLOSED TO ANY IZED PERSON WITHOUTTHE WRITTEN CONSENT C. 2 1 .75 .75 5.875 1.125 5.875 R .375 1.125 R.375 7.125 .875 .875 5.875 .38 1.125 .19 .75 PATENT LABELTHIS ISDRAWING LOCATED CONTAINS PROPRIETARY DESIGN INFORMATION REMAINS ALONG WITH THE PRODUCT OR PRODUCTS ON UNDERSIDEAND OF CARTON REPRESENTED HEREIN THE PROPERTY OF TEK PAK, INCORPORATED. .875 THIS DOCUMENT AND THE INFORMATION IT CONTAINS LABEL WITH CREE SECTION C-C OR USED BY ANY MAY NOT BE COPIED, TRANSMITTED, .38 .38 BIN CODE, QTY, LOT# THIRD PARTY WITHOUT THE EXPRESS WRITTEN APPROVAL ITH CREE BIN ANTITY, LOT # OF TEK PAK, INCORPORATED. .875 UNLESS OTHERWISE NOTED ALL TOLERANCES ARE AS FOLLOWS: DO NOT PATENT LABEL SCALE ON DWG. IS LOCATED UNDERSIDE OF FRACT ±1/64 X.X" ±.030 X.0mm ±.75mm ANGLES ±0°-30' X.XX" ±.015 X.Xmm ±.30mm DRAFT ±1° X.XXX" ±.005 X.XXmm ±.10mm CARTON THIS DRAWING CONTAINS PROPRIETARY DESIGN INFORMATION AND REMAINS ALONG WITH THE PRODUCT OR PRODUCTS REPRESENTED HEREIN THE PROPERTY OF TEK PAK, INCORPORATED. THIS DOCUMENT AND THE INFORMATION IT CONTAINS DWG.TITLE MAY NOT BE COPIED, TRANSMITTED, OR USED BY ANY THIRD PARTY WITHOUT THE EXPRESS WRITTEN APPROVAL OF TEK PAK, INCORPORATED. .38 DWG.TITLE PART DRAWING .38DATE: 4-3-13 DOKJS NOT DR. BY: SCALE CHK. BY: SIZE B DWG. BAG UNLESS0.750 OTHERWISE NOTED ALL SCALE: DWG.TOLERANCES NO. ARE AS FOLLOWS: 022489-00 FRACT ±1/64 X.X" ±.030 X.0mm ±.75mm ANGLES ±0°-30' X.XX" ±.015 X.Xmm ±.30mm DRAFT ±1° X.XXX" ±.005 X.XXmm ±.10mm SHEET 2 OF 2 BAG PART DRAWING DATE: DR. BY: CHK. BY: 4-3-13 KJS SCALE: 0.750 SIZE B DWG. NO. 022489-00 SHEET 2 OF 2 EL IS LOCATED IDE OF COVER LABEL WITH CREE BIN CODE, QTY, LOT# LABEL WITH CREE BIN CODE, QUANTITY, LOT # LABEL WITH CREE BIN CODE, QUANTITY, LOT # UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS & BEFORE FINISH. TOLERANCE UNLESS SPECIFIED: LABEL WITH CREE BIN CODE, QTY, LOT# .X ± .XX ± .XXX ± X° ± THIRD ANGLE PROJECTION L WITH CREE BIN QUANTITY, LOT # 6 0.1 .05 .005 1° FOR SHEET METAL PARTS ONLY .X ± DRAWN .06BY .03 UNLESS OTHERWISE SPECIFIED .XX ± .XXX ± .010 DIMENSIONS ARE IN X° ± CHECK 2° 5 MILLIMETERS & BEFORE FINISH. 3 UNLESS SPECIFIED: TOLERANCE 4 ® © 2015-2022 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp.X® and are APPROVED ± EasyWhite 0.1 .05 registered trademarks, and the Cree LED logo is a trademark, of Cree LED. UL® and the UL logo are registered trademarks of UL.XX LLC.± THIRD ANGLE PROJECTION .XXX ± X° ± .005 1 ° FOR SHEET METAL PARTS ONLY .X ± .06 DRAWN BY DATE CHECK DATE APPROVED DATE Phone (919) 361 Fax (919) 313-5 TITLE CXA15XX_DATASHEET MATERIAL SIZE FINALDATE PROTECTIVE FINISH SCALE DATE C DRAWING NO. CXA15XX_DATASHEET_BAG2013 4600 Silicon Drive SHEET OF Durham, N.C 27703 0.500 Phone (919) 361-4770 2 DATE TITLE CLD-DS121 REV 10 19 1 Fax (919) 313-5303 CXA15XX_DATASHEET MATERIAL SIZE FINAL PROTECTIVE FINISH 4600 Silicon Dri Durham, N.C 27 DRAWING NO. CXA15XX_DATASHEET_BAG2013
CXB1830-0000-000N0UT230G 价格&库存
很抱歉,暂时无法提供与“CXB1830-0000-000N0UT230G”相匹配的价格&库存,您可以联系我们找货
