CXB1820-0000-000N0HR427H
    WOLFSPEED
    LED COB CXB1820 2700K WHT SMD
CXB1820-0000-000N0HR427H 数据手册
PRODUCT FAMILY DATA SHEET XLamp® CXB1820 LED PRODUCT DESCRIPTION FEATURES TABLE OF CONTENTS The XLamp® CXB1820 LED Array is a • 12‑mm optical source Characteristics................................................ 2 member of the second generation of the • Mechanical and optical design Operating Limits.............................................. 2 CXA family that delivers up to 30% higher consistent with other CXA18 and Flux Characteristics, EasyWhite® Order efficacy and up to 20% higher lumens than CXB18 LEDs with a 12‑mm optical Codes and Bins............................................... 3 the first generation in the same LES. The source Flux Characteristics, Premium Color Order higher performance second generation • Available in 70-, 80-, 90- and Codes and Bins............................................... 6 CXA Relative Spectral Power Distribution, LED Arrays provide a drop-in 95-minimum CRI options performance upgrade to existing CXA LED • EasyWhite 2-, 3‑ and 5-step binning EasyWhite® ..................................................... 7 designs to shorten product development • Premium Color 2- and 3-step binning Relative Spectral Power Distribution, time. In addition, the CXB LEDs also • Forward voltage option: 36‑V class Premium Color................................................ 7 allow lighting manufacturers to achieve • 85 °C binning and characterization Electrical Characteristics................................ 8 the same or better performance with a Relative Luminous Flux................................... 9 ® smaller LES, enabling a smaller, more • Extremely uniform color over viewing angle Typical Spatial Distribution........................... 10 impactful luminaire. Available in 2‑step, • Top-side solder connections Performance Groups - Brightness............... 10 3‑step and 5‑step EasyWhite EasyWhite® Performance Groups - ® bins and • Thermocouple attach point 2‑step and 3‑step Premium Color bins, the • NEMA SSL-3 2011 standard flux bins Chromaticity.................................................. 11 CXB1820 LED delivers high lumen output Premium Color Performance Groups - • RoHS and REACh compliant and high efficacy in a single, easy‑to‑use • UL recognized component (E349212) Chromaticity.................................................. 12 package that eliminates the need for reflow EasyWhite® Bins Plotted on the 1931 CIE soldering. Color Space................................................... 13 ® Premium Color Bins Plotted on the 1931 The CX Family LED Design Guide provides CIE Color Space............................................ 14 basic information on the requirements Bin and Order Code Formats........................ 16 to use the CXB1820 LED successfully in Mechanical Dimensions............................... 16 luminaire designs. Thermal Design............................................. 17 Notes............................................................. 18 Packaging...................................................... 19 Cree LED / 4400 Silicon Drive / Durham, NC 27703 USA / +1.919.313.5330 / www.cree-led.com © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS120 REV 9A 1 XLAMP ® CXB1820 LED CHARACTERISTICS Characteristics Unit Viewing angle (FWHM) Minimum Typical degrees ESD withstand voltage (HBM per Mil-Std-883D) Maximum 115 V 8000 DC forward current mA 1050* Reverse current mA 0.1 Forward voltage (@ 550 mA, 85 °C) * V 35 38 Refer to the Operating Limits section. OPERATING LIMITS The maximum current rating of the CXB1820 depends on the case temperature (Tc) when the LED has reached thermal equilibrium under steady-state operation. The graph shown below assumes that the system design employs good thermal management (thermal interface material and heat sink) and may vary when poor thermal management is employed. Please refer to the Mechanical Dimensions section on page 16 for the location of the Tc measurement point. Another important factor in good thermal management is the temperature of the Light Emitting Surface (LES). Cree LED recommends a maximum LES temperature of 135 °C to ensure optimal LED lifetime. Please refer to the Thermal Design section on page 17 for more information on CXB1820 LES temperature measurement. Standard 1200 85 °C, 1050 mA 1000 If (mA) 800 600 125 °C, 404 mA 400 200 0 0 25 50 75 100 125 150 Case Temperature (°C) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS120 REV 9A 2 XLAMP ® CXB1820 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS (IF = 550 mA, TJ = 85 °C) The following table provides order codes for XLamp CXB1820 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 16). CRI* Nominal CCT Min 70 Minimum Luminous Flux Typ --- 6500 K 80 70 70 --- --- 90 5-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** S2 2780 3050 S4 2990 3280 T2 3200 3510 CXB1820-0000000N0BT265E S2 2780 3050 CXB1820-0000000N0HS265E S4 2990 3280 CXB1820-0000000N0HS465E S2 2780 3050 CXB1820-0000000N0BS257E S4 2990 3280 T2 3200 3510 CXB1820-0000000N0BT257E S2 2780 3050 CXB1820-0000000N0HS257E S4 2990 3280 CXB1820-0000000N0HS457E S2 2780 3050 CXB1820-0000000N0BS250E S4 2990 3280 T2 3200 3510 S2 2780 3050 Group Order Code Group Order Code Group 65E 65E 57E 57E --- 50E CXB1820-0000000N0BS465E CXB1820-0000000N0BS457E CXB1820-0000000N0BS450E CXB1820-0000000N0BT250E 50G CXB1820-0000000N0HS250G S4 2990 3280 CXB1820-0000000N0HS450G R2 2420 2655 CXB1820-0000000N0UR250G R4 2600 2852 92 Order Code CXB1820-0000000N0BS265E --- 5000 K 80 3-Step --- 5700 K 80 2-Step 50G 50E CXB1820-0000000N0HS250E CXB1820-0000000N0HS450E CXB1820-0000000N0UR450G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 18). • CXB1820 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS120 REV 9A 3 XLAMP ® CXB1820 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS (IF = 550 mA, TJ = 85 °C) - CONTINUED CRI* Nominal CCT Min 70 4000 K 80 90 80 Minimum Luminous Flux Typ --- --- 92 2-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** S2 2780 3050 S4 2990 3280 T2 3200 3510 R4 2600 2852 S2 2780 3050 S4 2990 3280 CXB1820-0000000N0HS440H CXB1820-0000000N0HS440G Q4 2260 2479 CXB1820-0000000N0UQ440H CXB1820-0000000N0UQ440G R2 2420 2655 R4 2600 2852 R4 2600 2852 --- Group 80 92 Order Code Group Order Code CXB1820-0000000N0BS440E CXB1820-0000000N0BT240E CXB1820-0000000N0HR440H 40H 40H CXB1820-0000000N0HS240H CXB1820-0000000N0UR240H CXB1820-0000000N0HR440G 40G 40G CXB1820-0000000N0UR440H CXB1820-0000000N0HR435H CXB1820-0000000N0HS240G CXB1820-0000000N0UR240G CXB1820-0000000N0UR440G 35G CXB1820-0000000N0HR435G S2 2780 3050 CXB1820-0000000N0HS235H Q4 2260 2479 CXB1820-0000000N0UQ435H R2 2420 2655 CXB1820-0000000N0UR235H R2 2420 2655 CXB1820-0000000N0HR230H R4 2600 2852 S2 2780 3050 CXB1820-0000000N0HS230H CXB1820-0000000N0HS230G Q2 2100 2304 CXB1820-0000000N0UQ230H CXB1820-0000000N0UQ230G Q4 2260 2479 R2 2420 2655 35H 30H 3000 K 90 Group 40E 35H 92 --- Order Code 5-Step CXB1820-0000000N0BS240E 3500 K 90 3-Step 30H CXB1820-0000000N0HR430H CXB1820-0000000N0UQ430H CXB1820-0000000N0UR230H 35G CXB1820-0000000N0HS235G CXB1820-0000000N0UQ435G CXB1820-0000000N0UR235G CXB1820-0000000N0HR230G 30G 30G CXB1820-0000000N0HR430G CXB1820-0000000N0UQ430G CXB1820-0000000N0UR230G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 18). • CXB1820 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS120 REV 9A 4 XLAMP ® CXB1820 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS (IF = 550 mA, TJ = 85 °C) - CONTINUED CRI* Nominal CCT Min 80 Minimum Luminous Flux Typ 90 2200 K 80 Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** R2 2420 2655 R4 2600 2852 CXB1820-0000000N0HR427H P4 1965 2156 CXB1820-0000000N0UP427H Q2 2100 2304 Q4 2260 2479 Q4 2260 2479 --- 2700 K 92 --- 2-Step Group 27H 27H Order Code CXB1820-0000000N0HR227H CXB1820-0000000N0UQ227H 3-Step Group 27G Order Code 5-Step Group Order Code CXB1820-0000000N0HR227G CXB1820-0000000N0HR427G CXB1820-0000000N0UP427G 27G CXB1820-0000000N0UQ427H CXB1820-0000000N0UQ227G CXB1820-0000000N0UQ427G 22G CXB1820-0000000N0HQ422G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 18). • CXB1820 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS120 REV 9A 5 XLAMP ® CXB1820 LED FLUX CHARACTERISTICS, PREMIUM COLOR ORDER CODES AND BINS (IF = 550 mA, TJ = 85 °C) Fidelity CRI* Nominal CCT Minimum Luminous Flux Min Typ Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** 4000 K 95 98 Q2 2100 2304 3500 K 95 98 Q2 2100 3000 K 95 98 P4 2700 K 95 98 P2 Typical Luminous Flux (lm) @ 85 °C 2-Step Group Order Code 2297 L5A CXB1820-0000-000N0ZQ2L5A 2304 2212 35H CXB1820-0000-000N0ZQ235H 1965 2156 2127 30H CXB1820-0000-000N0ZP430H 1830 2007 2006 27H CXB1820-0000-000N0ZP227H Specialty CRI Nominal CCT 3100 K Min 90 80 3000 K 90 95 Minimum Luminous Flux Typ Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** N4 1710 1876 Q2 2100 2304 R2 2420 2655 P4 1965 2156 Q2 2100 2304 Q4 2260 2479 P2 1830 2007 92 --- 92 98 Typical Luminous Flux (lm) @ 85 °C 2-Step Group Order Code 2451 2850 3-Step Group 31Q L7B Order Code Group Order Code CXB1820-0000000N0UN431Q CXB1820-0000000N0UQ231Q CXB1820-0000000N0HR2L7B CXB1820-0000000N0UP430U 2451 30Q CXB1820-0000000N0UQ230Q CXB1820-0000000N0UQ430Q 2127 L7C 30U CXB1820-0000000N0UQ230U CXB1820-0000000N0UQ430U CXB1820-0000000N0ZP2L7C Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 18). • CXB1820 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS120 REV 9A 6 XLAMP ® CXB1820 LED RELATIVE SPECTRAL POWER DISTRIBUTION, EASYWHITE® The following graph is the result of a series of pulsed measurements at 550 mA and TJ = 85 °C. 100% Relative Spectral Power 90% 80% 70% 5000 K, 70 CRI 60% 4000 K, 70 CRI 50% 3000 K, 80 CRI 40% 3000 K, 90 CRI 30% 2200 K, 80 CRI 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) RELATIVE SPECTRAL POWER DISTRIBUTION, PREMIUM COLOR The following graphs are the result of a series of pulsed measurements at 550 mA and TJ = 85 °C. Fidelity 100% Relative Spectral Power 90% 80% 70% 60% 4000 K, Z CRI 50% 3500 K, Z CRI 3000 K, Z CRI 40% 2700 K, Z CRI 30% 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS120 REV 9A 7 XLAMP ® CXB1820 LED RELATIVE SPECTRAL POWER DISTRIBUTION, PREMIUM COLOR - CONTINUED Relative Spectral Power Distribution Specialty 100% 90% Relative Spectral Power 80% 70% 31Q, 3100 K, 90 CRI 60% 30Q, 3000 K, 90 CRI 50% 30U, 3000 K, 90 CRI 40% L7B, 3000 K 80 CRI 30% L7C, 3000 K, Z CRI 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) ELECTRICAL CHARACTERISTICS The following graph is the result of a series of steady-state measurements. 39 Voltage (V) 38 37 Tc = 25 °C Tc = 55 °C 36 Tc = 85 °C Tc = 105 °C 35 34 33 350 450 550 650 750 850 950 1050 Current (mA) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS120 REV 9A 8 XLAMP ® CXB1820 LED RELATIVE LUMINOUS FLUX The relative luminous flux values provided below are the ratio of measurements of the CXB1820 LED at steady-state operation at the given conditions, divided by the flux measured during binning, which is a pulsed measurement at 550 mA at TJ = 85 °C. For example, at steady-state operation of Tc = 55 °C, IF = 650 mA, the relative luminous flux ratio is 120% in the chart below. A CXB1820 LED that measures 2100 lm during binning will deliver 2520 lm (2100 * 1.2) at steady-state operation of Tc = 55 °C, IF = 650 mA. 200% 180% Relative Luminous Flux 160% 140% Tc = 25 °C 120% Tc = 55 °C 100% Tc = 85 °C 80% Tc = 105 °C 60% 40% 20% 0% 350 450 550 650 750 850 950 1050 Current (mA) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS120 REV 9A 9 XLAMP ® CXB1820 LED Far Field TYPICAL SPATIAL DISTRIBUTION 100% Relative Luminous Intensity 80% 60% 40% 20% -90 -70 -50 -30 -10 0% 10 30 50 70 90 Angle (º) PERFORMANCE GROUPS - BRIGHTNESS (I F = 550 mA, TJ = 85 °C) XLamp CXB1820 LEDs are tested for luminous flux and placed into one of the following bins. Group Code Minimum Luminous Flux Maximum Luminous Flux N4 1710 1830 P2 1830 1965 P4 1965 2100 Q2 2100 2260 Q4 2260 2420 R2 2420 2600 R4 2600 2780 S2 2780 2990 S4 2990 3200 T2 3200 3440 T4 3440 3680 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS120 REV 9A 10 XLAMP ® CXB1820 LED EASYWHITE® PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) XLamp CXB1820 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. EasyWhite Color Temperatures – 2-Step Code 40H 35H 30H 27H CCT 4000 K 3500 K 3000 K 2700 K x y 0.3777 0.3739 0.3797 0.3816 0.3861 0.3855 0.3838 0.3777 0.4022 0.3858 0.4053 0.3942 0.4125 0.3977 0.4091 0.3891 0.4287 0.3975 0.4328 0.4064 0.4390 0.4086 0.4347 0.3996 0.4524 0.4048 0.4574 0.4140 0.4633 0.4154 0.4581 0.4062 EasyWhite Color Temperatures – 3-Step Ellipse Bin Code CCT 50G 40G Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 5000 K 0.3447 0.3553 0.00840 0.00312 65.0 4000 K 0.3818 0.3797 0.00939 0.00402 53.7 35G 3500 K 0.4073 0.3917 0.00927 0.00414 54.0 30G 3000 K 0.4338 0.4030 0.00834 0.00408 53.2 27G 2700 K 0.4577 0.4099 0.00834 0.00420 48.5 22G 2200 K 0.5066 0.4158 0.00980 0.00480 45.5 EasyWhite Color Temperatures – 5-Step Ellipse Bin Code CCT 65E Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 6500 K 0.3123 0.3282 0.01110 0.00550 61.0 57E 5700 K 0.3287 0.3417 0.01230 0.00600 72.0 50E 5000 K 0.3447 0.3553 0.01400 0.00520 65.0 40E 4000 K 0.3818 0.3797 0.01565 0.00670 53.7 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS120 REV 9A 11 XLAMP ® CXB1820 LED PREMIUM COLOR PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) XLamp CXB1820 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. Fidelity EasyWhite Color Temperatures – 2-Step Code L5A 35H 30H 27H CCT 4000 K 3500 K 3000 K 2700 K x y 0.3764 0.3711 0.3784 0.3787 0.3847 0.3826 0.3825 0.3748 0.4022 0.3858 0.4053 0.3942 0.4125 0.3977 0.4091 0.3891 0.4287 0.3975 0.4328 0.4064 0.4390 0.4086 0.4347 0.3996 0.4524 0.4048 0.4574 0.4140 0.4633 0.4154 0.4581 0.4062 Specialty EasyWhite Color Temperatures – 2-Step Code L7B L7C CCT 3000 K 3000 K x y 0.4263 0.3848 0.4296 0.3916 0.4361 0.3938 0.4326 0.3868 0.4192 0.3754 0.4224 0.3823 0.4291 0.3847 0.4257 0.3777 EasyWhite Color Temperatures – 3-Step Ellipse Center Point Major Axis Minor Axis Rotation Angle (°) Bin Code CCT x y a b 31Q 3100 K 0.4236 0.3888 0.00848 0.00455 50.3 30Q 3000 K 0.4305 0.3935 0.00834 0.00408 53.2 30U 3000 K 0.4274 0.3837 0.00834 0.00408 53.2 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS120 REV 9A 12 XLAMP ® CXB1820 LED EASYWHITE® BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) 0.45 ANSI C78.377 Quadrangle 0.44 2700 K EasyWhite 5-step 0.43 2200 K 2450 K 3000 K EasyWhite 3-step 0.42 EasyWhite 2-step 3500 K 0.41 4000 K 0.40 CCy 0.39 5000 K 4500 K 5700 K 0.38 0.37 6500 K 0.36 0.35 7000K 0.34 0.33 0.32 0.54 0.53 0.52 0.51 0.50 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.31 CCx © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS120 REV 9A 13 XLAMP ® CXB1820 LED PREMIUM COLOR BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) Fidelity (2-step) 0.44 2700K ANSI C78.377 Quadrangle 0.43 3000K 0.42 3500K 0.41 27H 4000K CCy 0.40 30H 4500K 35H 0.39 0.38 L5A 0.37 0.36 0.35 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. 0.48 0.47 0.46 0.45 0.44 CCx 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 CLD-DS120 REV 9A 14 XLAMP ® CXB1820 LED PREMIUM COLOR BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) - CONTINUED Speciality (2-step) 0.44 ANSI C78.377 Quadrangle 3000 K 0.43 0.42 3500 K CCy 0.41 0.40 0.39 L7B L7C 0.38 0.46 0.45 CCx 0.44 0.43 0.42 0.41 0.37 Speciality (3-step) 0.44 ANSI C78.377 Quadrangle 3000K 0.43 0.42 3500K CCy 0.41 0.40 30Q 0.39 31Q 30U 0.38 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. 0.46 0.45 CCx 0.44 0.43 0.42 0.41 0.37 CLD-DS120 REV 9A 15 XLAMP ® CXB1820 LED BIN AND ORDER CODE FORMATS Bin codes and order codes are configured as follows: Order Code Bin Code Series = CXB18 Series = CXB18 Internal code Chromaticity bin CRI Specification B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Vf class N0 = 36-V class SSSSSCC-HHHH-HHHGGRNNNNN Internal code SSSSSCC-WWW-FF-GGR-AAAAA CRI Specification B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Kit code Vf class N0 = 36-V class Flux bin Performance class Performance class MECHANICAL DIMENSIONS Dimensions are in mm. Tolerances unless otherwise specified: ±.13 x° ±1° B1820N = 36‑V CXB1820 B1820N Meaning of B1820N © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS120 REV 9A 16 XLAMP ® CXB1820 LED THERMAL DESIGN The CXB family of LED arrays can include over a hundred different LED die inside one package, and thus over a hundred different junction temperatures (TJ). Cree LED has intentionally removed junction-temperature-based operating limits and replaced the commonplace maximum TJ calculations with maximum ratings based on forward current (IF) and case temperature (Tc). No additional calculations are required to ensure that the CXB LED is being operated within its designed limits. LES temperature measurement provides additional verification of good thermal design. Please refer to page 2 for the Operating Limit specifications. There is no need to calculate for TJ inside the package, as the thermal management design process, specifically from TSP to ambient (Ta), remains identical to any other LED component. For more information on thermal management of XLamp LEDs, please refer to the Thermal Management application note. For CXB soldering recommendations and more information on thermal interface materials (TIM), LES temperature measurement, and connection methods, please refer to the XLamp CX Family LEDs soldering and handling document. The CX Family LED Design Guide provides basic information on the requirements to use XLamp CXB LEDs successfully in luminaire designs. To keep the CXB1820 LED at or below the maximum rated Tc, the case to ambient temperature thermal resistance (R_c-a) must be at or below the maximum R_c-a value shown on the following graph, depending on the operating environment. The y‑axis in the graph is a base 10 logarithmic scale. As the figure at right shows, the R_c-a value is the sum of the thermal resistance of the TIM (R_tim) R_j-c R_j-c Tc Tc R_tim R_c-a plus the thermal resistance of the heat sink (R_hs). R_hs CXB1820 Ta Ta 100.00 Maximum R_c-a 10.00 Ta = 25 °C Ta = 55 °C 1.00 Ta = 85 °C Ta = 105 °C 0.10 0.01 350 450 550 650 750 850 950 1050 Current (mA) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS120 REV 9A 17 XLAMP ® CXB1820 LED NOTES Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs. Lumen Maintenance Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. REACh Compliance REACh substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative to insure you get the most up-to-date REACh Declaration. REACh banned substance information (REACh Article 67) is also available upon request. UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS120 REV 9A 18 XLAMP ® CXB1820 LED PACKAGING CXB1820 LEDs are packaged in trays of 20. Five trays are sealed in an anti-static bag and placed inside a carton, for a total of 100 LEDs per carton. Each carton contains 100 LEDs from the same performance bin. REV 5 7.875 6 4 Dimensions are in inches. DESC. 3 DATE BY CHK. Tolerances: +.13 x° +1° 2 1 R.375 5 4 3 NOTICE 2 1 .75 IDENTIAL. THIS PLOT AND THE INFORMATION NSENT WITHIN ARE THE PROPRIETARY AND IAL INFORMATION OF CREE, INC. THIS PLOT E COPIED, REPRODUCED OR DISCLOSED TO ANY IZED PERSON WITHOUTTHE WRITTEN CONSENT C. 5.875 R .375 5.875 1.125 R.375 7.125 .875 .875 5.875 .38 1.125 .38 .75 PATENT LABEL IS LOCATED ON UNDERSIDE OF CARTON LABEL WITH CREE SECTION C-C .19 .38 .875 BIN CODE, QTY, LOT# ITH CREE BIN ANTITY, LOT # .38 .875 PATENT LABEL IS LOCATED ON UNDERSIDE OF CARTON THIS DRAWING CONTAINS PROPRIETARY DESIGN INFORMATION AND REMAINS ALONG WITH THE PRODUCT OR PRODUCTS REPRESENTED HEREIN THE PROPERTY OF TEK PAK, INCORPORATED. THIS DOCUMENT AND THE INFORMATION IT CONTAINS DWG.TITLE MAY NOT BE COPIED, TRANSMITTED, OR USED BY ANY THIRD PARTY WITHOUT THE EXPRESS WRITTEN APPROVAL OF TEK PAK, INCORPORATED. BAG DO NOT SCALE DWG. UNLESS OTHERWISE NOTED ALL TOLERANCES ARE AS FOLLOWS: FRACT ±1/64 X.X" ±.030 X.0mm ±.75mm ANGLES ±0°-30' X.XX" ±.015 X.Xmm ±.30mm DRAFT ±1° X.XXX" ±.005 X.XXmm ±.10mm BAG PART DRAWING DATE: DR. BY: CHK. BY: 4-3-13 KJS SCALE: 0.750 SIZE B DWG. NO. 022489-00 SHEET 2 OF 2 EL IS LOCATED IDE OF COVER LABEL WITH CREE BIN CODE, QTY, LOT# LABEL WITH CREE BIN CODE, QUANTITY, LOT # LABEL WITH CREE BIN CODE, QUANTITY, LOT # UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS & BEFORE FINISH. TOLERANCE UNLESS SPECIFIED: LABEL WITH CREE BIN CODE, QTY, LOT# .X ± .XX ± .XXX ± X° ± THIRD ANGLE PROJECTION L WITH CREE BIN QUANTITY, LOT # 6 0.1 .05 .005 1° FOR SHEET METAL PARTS ONLY .X ± DRAWN .06BY .03 UNLESS OTHERWISE SPECIFIED .XX ± .XXX ± .010 DIMENSIONS ARE IN X° ± CHECK 2° 5 4 MILLIMETERS & BEFORE FINISH. 3 UNLESS SPECIFIED: TOLERANCE © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered and APPROVED .X ± trademarks, 0.1 ± .05 the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the.XXUL logo are registered .XXX ± .005 trademarks of UL LLC. THIRD ANGLE PROJECTION MATERIAL X° ± DRAWN BY DATE CHECK DATE APPROVED DATE Fax (919) 313-5 CXA15XX_DATASHEET MATERIAL SIZE FINALDATE PROTECTIVE FINISH SCALE DATE C DRAWING NO. CXA15XX_DATASHEET_BAG2013 4600 Silicon Drive SHEET OF Durham, N.C 27703 0.500 Phone (919) 361-4770 2 DATE TITLE CLD-DS120 REV 9A 19 1 Fax (919) 313-5303 CXA15XX_DATASHEET SIZE FINAL PROTECTIVE FINISH Phone (919) 361 TITLE 1 ° FOR SHEET METAL PARTS ONLY .X ± .06 4600 Silicon Driv Durham, N.C 27 DRAWING NO. CXA15XX_DATASHEET_BAG2013
物料型号:CXB1820 LED
器件简介:CXB1820 LED是Cree XLamp® CXA系列的第二代产品,提供比第一代更高的光效和光通量,兼容现有的CXA LED设计,具有更高的性能。
引脚分配:文档中未明确提供引脚分配信息。
参数特性: - 视场角:115度 - ESD承受电压:8000V (HBM per Mil-Std-883D) - 直流正向电流:最大1050mA - 反向电流:最大0.1mA - 正向电压:在550mA和85°C时,典型值38V
功能详解: - 提供70-95的CRI选项 - EasyWhite® 2-, 3-, 5步进的色温分选 - 高端颜色2-和3步进的色温分选 - 正向电压选项:36V级别 - 85°C的色温和特性分选 - 色彩一致性高 - 顶部焊接连接 - 热电偶附着点 - 符合NEMA SSL-3 2011标准光通量分选 - 符合RoHS和REACh标准 - UL®认可的组件
应用信息:适用于需要高性能照明解决方案的场合,如灯具设计。
封装信息:12mm光学光源,机械和光学设计与其他CXA18和CXB18 LED兼容。
CXB1820-0000-000N0HR427H 价格&库存
很抱歉,暂时无法提供与“CXB1820-0000-000N0HR427H”相匹配的价格&库存,您可以联系我们找货
