CXB2530-0000-000N0BV240E
    WOLFSPEED
    LED COB CXB2530 4000K WHT SMD
CXB2530-0000-000N0BV240E 数据手册
PRODUCT FAMILY DATA SHEET XLamp® CXB2530 LED PRODUCT DESCRIPTION FEATURES TABLE OF CONTENTS The XLamp® CXB2530 LED Array is a • 19‑mm optical source Characteristics................................................ 2 member of the second generation of the • Mechanical and optical design Operating Limits.............................................. 2 CXA family that delivers up to 30% higher consistent with other CXA25 and Flux Characteristics, EasyWhite® Order efficacy and up to 20% higher lumens than CXB25 LEDs Codes and Bins............................................... 3 the first generation in the same LES. The • Available in 70-, 80-, 90- and Flux Characteristics, Premium Color Order higher performance second generation Codes and Bins............................................... 5 CXA LED Arrays provide a 95-minimum CRI options drop-in • EasyWhite 2‑, 3‑ and 5-step binning ® Flux Characteristics, Premium Color Order performance upgrade to existing CXA LED • Premium Color 2- and 3-step binning Codes and Bins............................................... 6 designs to shorten product development • Forward voltage option: 36‑V class Relative Spectral Power Distribution, time. In addition, the CXB LEDs also • 85 °C binning and characterization EasyWhite® ..................................................... 7 allow lighting manufacturers to achieve • Extremely uniform color over viewing Relative Spectral Power Distribution, the same or better performance with a Premium Color................................................ 7 angle smaller LES, enabling a smaller, more • Top-side solder connections Electrical Characteristics................................ 8 impactful luminaire. Available in 2‑step, • Thermocouple attach point Relative Luminous Flux vs. Current................ 9 3‑step and 5‑step EasyWhite Typical Spatial Distribution........................... 10 ® bins and • NEMA SSL-3 2011 standard flux bins 2‑step and 3‑step Premium Color bins, the • RoHS and REACh compliant Performance Groups - Brightness............... 10 CXB2530 LED delivers high lumen output EasyWhite® Performance Groups - • UL® recognized component (E349212) and high efficacy in a single, easy‑to‑use Chromaticity.................................................. 11 package that eliminates the need for reflow Premium Color Performance Groups - soldering. Chromaticity.................................................. 12 EasyWhite® Bins Plotted on the 1931 CIE The CX Family LED Design Guide provides Color Space................................................... 13 basic information on the requirements Premium Color Bins Plotted on the 1931 to use the CXB2530 LED successfully in CIE Color Space............................................ 14 luminaire designs. Bin and Order Code Formats........................ 16 Mechanical Dimensions............................... 16 Thermal Design............................................. 17 Notes............................................................. 18 Packaging...................................................... 19 Cree LED / 4400 Silicon Drive / Durham, NC 27703 USA / +1.919.313.5330 / www.cree-led.com © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS122 REV 10A 1 XLAMP ® CXB2530 LED CHARACTERISTICS Characteristics Unit Viewing angle (FWHM) Minimum Typical degrees ESD classification (HBM per Mil-Std-883D) Maximum 115 V 8000 DC forward current mA 1600* Reverse current mA 0.1 Forward voltage (@ 800 mA, 85 °C) * V 34.2 38 Refer to the Operating Limits section. OPERATING LIMITS The maximum current rating of the CXB2530 depends on the case temperature (Tc) when the LED has reached thermal equilibrium under steady-state operation. The graph shown below assumes that the system design employs good thermal management (thermal interface material and heat sink) and may vary when poor thermal management is employed. Please refer to the Mechanical Dimensions section on page 16 for the location of the Tc measurement point. Another important factor in good thermal management is the temperature of the Light Emitting Surface (LES). Cree LED recommends a maximum LES temperature of 135 °C to ensure optimal LED lifetime. Please refer to the Thermal Design section on page 17 for more information on LES temperature measurement. CXB2530 - Standard 1800 85 °C, 1600 mA 1600 1400 If (mA) 1200 1000 800 125 °C, 615 mA 600 400 200 0 0 25 50 75 100 125 150 Case Temperature (°C) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS122 REV 10A 2 XLAMP ® CXB2530 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS (IF = 800 mA, TJ = 85 °C) The following table provides order codes for XLamp CXB2530 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 16). CRI* Nominal CCT Min 70 Minimum Luminous Flux Typ 70 --- --- 5-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** U2 3680 4031 CXB2530-0000000N0BU265E U4 3955 4332 CXB2530-0000000N0BU465E V2 4230 4670 CXB2530-0000000N0BV265E V4 4545 5018 CXB2530-0000000N0BV465E U2 3680 4031 CXB2530-0000000N0HU265E U4 3955 4366 V2 4230 4670 CXB2530-0000000N0HV265E U2 3680 4031 CXB2530-0000000N0BU257E U4 3955 4332 CXB2530-0000000N0BU457E V2 4230 4670 CXB2530-0000000N0BV257E V4 4545 5018 CXB2530-0000000N0BV457E U2 3680 4031 CXB2530-0000000N0HU257E U4 3955 4366 V2 4230 4670 Group Order Code Group Order Code Group 65E --- 5700 K 80 3-Step --- 6500 K 80 2-Step 65E 57E 57E Order Code CXB2530-0000000N0HU465E CXB2530-0000000N0HU457E CXB2530-0000000N0HV257E Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 18). • CXB2530 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS122 REV 10A 3 XLAMP ® CXB2530 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS (IF = 800 mA, TJ = 85 °C) - CONTINUED CRI* Nominal CCT Min 70 Minimum Luminous Flux Typ 90 70 Flux (lm) @ 85 °C Flux (lm) @ 25 °C** U2 3680 4031 U4 3955 4332 Group 90 Group Order Code --- Order Code CXB2530-0000000N0BU450E V2 4230 4670 CXB2530-0000000N0BV250E V4 4545 5018 CXB2530-0000000N0BV450E U2 3680 4031 U4 3955 4366 V2 4230 4670 CXB2530-0000000N0HV250G T4 3440 3768 CXB2530-0000000N0UT450G U2 3680 4031 U2 3680 4031 CXB2530-0000000N0BU240E U4 3955 4332 CXB2530-0000000N0BU440E V2 4230 4670 CXB2530-0000000N0BV240E V4 4545 5018 CXB2530-0000000N0BV440E U2 3680 4031 U4 3955 4366 V2 4230 4670 CXB2530-0000000N0HV240H CXB2530-0000000N0HV240G T2 3200 3505 CXB2530-0000000N0UT240H CXB2530-0000000N0UT240G T4 3440 3798 U2 3680 4063 CXB2530-0000000N0HU250G 50G 50G CXB2530-0000000N0HU450G CXB2530-0000000N0HU250E 50E 40E CXB2530-0000000N0HU240H 40H 40H CXB2530-0000000N0HU440H CXB2530-0000000N0UT440H CXB2530-0000000N0UU240H CXB2530-0000000N0HU450E CXB2530-0000000N0UU250G --- 92 Group 50E 92 --- 5-Step CXB2530-0000000N0BU250E 4000 K 80 Order Code 3-Step --- 5000 K 80 Group 2-Step CXB2530-0000000N0HU240G 40G 40G CXB2530-0000000N0HU440G CXB2530-0000000N0UT440G CXB2530-0000000N0UU240G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 18). • CXB2530 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS122 REV 10A 4 XLAMP ® CXB2530 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS (IF = 800 mA, TJ = 85 °C) - CONTINUED CRI* Nominal CCT Min 80 Minimum Luminous Flux Typ --- 2-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** T4 3440 3768 U2 3680 4063 U4 3955 4366 CXB2530-0000000N0HU435H CXB2530-0000000N0HU435G S4 2990 3275 CXB2530-0000000N0US435H CXB2530-0000000N0US435G T2 3200 3533 T4 3440 3798 CXB2530-0000000N0UT435H CXB2530-0000000N0UT435G T4 3440 3768 CXB2530-0000000N0HT430H CXB2530-0000000N0HT430G U2 3680 4063 U4 3955 4366 CXB2530-0000000N0HU430H CXB2530-0000000N0HU430G S4 2990 3275 CXB2530-0000000N0US430H CXB2530-0000000N0US430G T2 3200 3533 T4 3440 3798 CXB2530-0000000N0UT430H CXB2530-0000000N0UT430G T2 3200 3505 CXB2530-0000000N0HT227H CXB2530-0000000N0HT227G T4 3440 3798 U2 3680 4063 CXB2530-0000000N0HU227H CXB2530-0000000N0HU227G S2 2780 3045 CXB2530-0000000N0US227H CXB2530-0000000N0US227G S4 2990 3301 T2 3200 3533 T2 3200 3533 Group 80 92 --- 35H 35H 30H 3000 K 90 80 92 --- 30H 27H 2700 K 90 2200 K 80 92 --- Order Code Group CXB2530-0000000N0HT435H 3500 K 90 3-Step 27H CXB2530-0000000N0HU235H CXB2530-0000000N0UT235H CXB2530-0000000N0HU230H CXB2530-0000000N0UT230H CXB2530-0000000N0HT427H CXB2530-0000000N0US427H Order Code 5-Step Group Order Code CXB2530-0000000N0HT435G 35G 35G 30G 30G 27G 27G CXB2530-0000000N0UT227H CXB2530-0000000N0HU235G CXB2530-0000000N0UT235G CXB2530-0000000N0HU230G CXB2530-0000000N0UT230G CXB2530-0000000N0HT427G CXB2530-0000000N0US427G CXB2530-0000000N0UT227G 22G CXB2530-0000000N0HT222G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 18). • CXB2530 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS122 REV 10A 5 XLAMP ® CXB2530 LED FLUX CHARACTERISTICS, PREMIUM COLOR ORDER CODES AND BINS (IF = 800 mA, TJ = 85 °C) Fidelity CRI* Nominal CCT Minimum Luminous Flux Min Typ Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** 4000 K 95 98 S4 2990 3301 3500 K 95 98 S2 2780 3000 K 95 98 S2 2700 K 95 98 R4 Typical Luminous Flux (lm) @ 85 °C 2-Step Group Order Code 3238 L5A CXB2530-0000-000N0ZS4L5A 3069 3118 35H CXB2530-0000-000N0ZS235H 2780 3069 2998 30H CXB2530-0000-000N0ZS230H 2600 2870 2829 27H CXB2530-0000-000N0ZR427H Specialty CRI Nominal CCT 3100 K Min 90 80 3000 K 90 95 Minimum Luminous Flux Typ Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** S4 2990 3301 T2 3200 3533 T4 3440 3798 S4 2990 3301 T2 3200 3533 R4 2600 2870 92 --- 2-Step Group Order Code 3455 92 98 Typical Luminous Flux (lm) @ 85 °C 4018 Group 31Q L7B 30Q L7C Order Code Group Order Code CXB2530-0000000N0US431Q CXB2530-0000000N0UT231Q CXB2530-0000000N0HT4L7B 3455 2829 3-Step CXB2530-0000000N0US430Q CXB2530-0000000N0UT230Q 30U CXB2530-0000000N0US430U CXB2530-0000000N0UT230U CXB2530-0000000N0ZR4L7C Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 18). • CXB2530 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS122 REV 10A 6 XLAMP ® CXB2530 LED RELATIVE SPECTRAL POWER DISTRIBUTION, EASYWHITE® The following graph is the result of a series of pulsed measurements at 800 mA and TJ = 85 °C. 100% Relative Spectral Power 90% 80% 70% 5000 K, 70 CRI 60% 4000 K, 70 CRI 50% 3000 K, 80 CRI 40% 3000 K, 90 CRI 30% 2200 K, 80 CRI 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) RELATIVE SPECTRAL POWER DISTRIBUTION, PREMIUM COLOR The following graphs are the result of a series of pulsed measurements at 800 mA and TJ = 85 °C. Fidelity 100% Relative Spectral Power 90% 80% 70% 60% 4000 K, Z CRI 50% 3500 K, Z CRI 3000 K, Z CRI 40% 2700 K, Z CRI 30% 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS122 REV 10A 7 XLAMP ® CXB2530 LED RELATIVE SPECTRAL POWER DISTRIBUTION, PREMIUM COLOR - CONTINUED Relative Spectral Power Distribution Specialty 100% 90% Relative Spectral Power 80% 70% 31Q, 3100 K, 90 CRI 60% 30Q, 3000 K, 90 CRI 50% 30U, 3000 K, 90 CRI 40% L7B, 3000 K 80 CRI 30% L7C, 3000 K, Z CRI 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) ELECTRICAL CHARACTERISTICS The following graph is the result of a series of steady-state measurements. 37.5 36.5 Voltage (V) 35.5 Tc = 25 °C Tc = 55 °C 34.5 Tc = 85 °C Tc = 105 °C 33.5 32.5 31.5 300 560 820 1080 1340 1600 Current (mA) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS122 REV 10A 8 XLAMP ® CXB2530 LED RELATIVE LUMINOUS FLUX VS. CURRENT (TJ = 85 °C) The relative luminous flux values provided below are the ratio of measurements of the CXB2530 LED at steady-state operation at the given conditions, divided by flux measured during binning, which is a pulsed measurement at 800 mA at TJ = 85 °C. For example, at steady-state operation of Tc = 25 °C, IF = 1080 mA, the relative luminous flux ratio is 140% in the chart below. A CXB2530 LED that measures 3200 lm during binning will deliver 4480 lm (3200 * 1.4) at steady-state operation of Tc = 25 °C, IF = 1080 mA. 200% 180% Relative Luminous Flux 160% 140% Tc = 25 °C 120% Tc = 55 °C 100% Tc = 85 °C 80% Tc = 105 °C 60% 40% 20% 0% 300 560 820 1080 1340 1600 Current (mA) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS122 REV 10A 9 XLAMP ® CXB2530 LED Far Field TYPICAL SPATIAL DISTRIBUTION Relative Luminous Intensity (%) 100% 80% 60% 40% 20% -90 -70 -50 -30 -10 0% 10 30 50 70 90 Angle (º) PERFORMANCE GROUPS - BRIGHTNESS (I F = 800 mA, TJ = 85 °C) XLamp CXB2530 LEDs are tested for luminous flux and placed into one of the following bins. Group Code Minimum Luminous Flux Maximum Luminous Flux R4 2600 2780 S2 2780 2990 S4 2990 3200 T2 3200 3440 T4 3440 3680 U2 3680 3955 U4 3955 4230 V2 4230 4545 V4 4545 4860 W2 4860 5225 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS122 REV 10A 10 XLAMP ® CXB2530 LED EASYWHITE® PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) XLamp CXB2530 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. EasyWhite Color Temperatures – 2-Step Code 40H 35H 30H 27H CCT 4000 K 3500 K 3000 K 2700 K x y 0.3777 0.3739 0.3797 0.3816 0.3861 0.3855 0.3838 0.3777 0.4022 0.3858 0.4053 0.3942 0.4125 0.3977 0.4091 0.3891 0.4287 0.3975 0.4328 0.4064 0.4390 0.4086 0.4347 0.3996 0.4524 0.4048 0.4574 0.4140 0.4633 0.4154 0.4581 0.4062 EasyWhite Color Temperatures – 3-Step Ellipse Bin Code CCT 50G 40G Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 5000 K 0.3447 0.3553 0.00840 0.00312 65.0 4000 K 0.3818 0.3797 0.00939 0.00402 53.7 35G 3500 K 0.4073 0.3917 0.00927 0.00414 54.0 30G 3000 K 0.4338 0.4030 0.00834 0.00408 53.2 27G 2700 K 0.4577 0.4099 0.00834 0.00420 48.5 22G 2200 K 0.5066 0.4158 0.00980 0.00480 45.5 EasyWhite Color Temperatures – 5-Step Ellipse Bin Code CCT 65E Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 6500 K 0.3123 0.3282 0.01110 0.00550 61.0 57E 5700 K 0.3287 0.3417 0.01230 0.00600 72.0 50E 5000 K 0.3447 0.3553 0.01400 0.00520 65.0 40E 4000 K 0.3818 0.3797 0.01565 0.00670 53.7 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS122 REV 10A 11 XLAMP ® CXB2530 LED PREMIUM COLOR PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) XLamp CXB2530 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. Fidelity EasyWhite Color Temperatures – 2-Step Code L5A 35H 30H 27H CCT 4000 K 3500 K 3000 K 2700 K x y 0.3764 0.3711 0.3784 0.3787 0.3847 0.3826 0.3825 0.3748 0.4022 0.3858 0.4053 0.3942 0.4125 0.3977 0.4091 0.3891 0.4287 0.3975 0.4328 0.4064 0.4390 0.4086 0.4347 0.3996 0.4524 0.4048 0.4574 0.4140 0.4633 0.4154 0.4581 0.4062 Specialty EasyWhite Color Temperatures – 2-Step Code L7B L7C CCT 3000 K 3000 K x y 0.4263 0.3848 0.4296 0.3916 0.4361 0.3938 0.4326 0.3868 0.4192 0.3754 0.4224 0.3823 0.4291 0.3847 0.4257 0.3777 EasyWhite Color Temperatures – 3-Step Ellipse Center Point Major Axis Minor Axis Rotation Angle (°) Bin Code CCT x y a b 31Q 3100 K 0.4236 0.3888 0.00848 0.00455 50.3 30Q 3000 K 0.4305 0.3935 0.00834 0.00408 53.2 30U 3000 K 0.4274 0.3837 0.00834 0.00408 53.2 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS122 REV 10A 12 XLAMP ® CXB2530 LED EASYWHITE® BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) 0.45 ANSI C78.377 Quadrangle 0.44 2700 K EasyWhite 5-step 0.43 2200 K 2450 K 3000 K EasyWhite 3-step 0.42 EasyWhite 2-step 3500 K 0.41 4000 K 0.40 CCy 0.39 5000 K 4500 K 5700 K 0.38 0.37 6500 K 0.36 0.35 7000K 0.34 0.33 0.32 0.54 0.53 0.52 0.51 0.50 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.31 CCx © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS122 REV 10A 13 XLAMP ® CXB2530 LED PREMIUM COLOR BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) Fidelity (2-step) 0.44 2700K ANSI C78.377 Quadrangle 0.43 3000K 0.42 3500K 0.41 27H 4000K CCy 0.40 30H 4500K 35H 0.39 0.38 L5A 0.37 0.36 0.35 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. 0.48 0.47 0.46 0.45 0.44 CCx 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 CLD-DS122 REV 10A 14 XLAMP ® CXB2530 LED PREMIUM COLOR BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) - CONTINUED Speciality (2-step) 0.44 ANSI C78.377 Quadrangle 3000 K 0.43 0.42 3500 K CCy 0.41 0.40 0.39 L7B L7C 0.38 0.46 0.45 CCx 0.44 0.43 0.42 0.41 0.37 Speciality (3-step) 0.44 ANSI C78.377 Quadrangle 3000K 0.43 0.42 3500K CCy 0.41 0.40 30Q 0.39 31Q 30U 0.38 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. 0.46 0.45 CCx 0.44 0.43 0.42 0.41 0.37 CLD-DS122 REV 10A 15 XLAMP ® CXB2530 LED BIN AND ORDER CODE FORMATS Bin codes and order codes are configured as follows: Order Code Bin Code Series = CXB25 Series = CXB25 Internal code Chromaticity bin CRI Specification B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Z = 95 CRI minimum Vf class N0 = 36-V class Internal code SSSSSCC-WWW-FF-GGR-AAAAA CRI Specification B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Z = 95 CRI minimum SSSSSCC-HHHH-HHHGGRNNNNN Kit code Vf class N0 = 36-V class Flux bin Performance class Performance class MECHANICAL DIMENSIONS Dimensions are in mm. Tolerances unless otherwise specified: +.13 x° +1° B2530N = 36‑V CXB2530 B2530N Meaning of B2530N © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS122 REV 10A 16 XLAMP ® CXB2530 LED THERMAL DESIGN The CXB family of LED arrays can include over a hundred different LED die inside one package, and thus over a hundred different junction temperatures (TJ). Cree LED has intentionally removed junction-temperature-based operating limits and replaced the commonplace maximum TJ calculations with maximum ratings based on forward current (IF) and case temperature (Tc). No additional calculations are required to ensure that the CXB LED is being operated within its designed limits. LES temperature measurement provides additional verification of good thermal design. Please refer to page 2 for the Operating Limit specifications. There is no need to calculate for TJ inside the package, as the thermal management design process, specifically from TSP to ambient (Ta), remains identical to any other LED component. For more information on thermal management of XLamp LEDs, please refer to the Thermal Management application note. For CXB soldering recommendations and more information on thermal interface materials (TIM), LES temperature measurement, and connection methods, please refer to the XLamp CX Family LEDs soldering and handling document. The CX Family LED Design Guide provides basic information on the requirements to use XLamp CXB LEDs successfully in luminaire designs. To keep the CXB2530 LED at or below the maximum rated Tc, the case to ambient temperature thermal resistance (R_c-a) must be at or below the maximum R_c-a value shown on the following R_j-c R_j-c scale. Tc Tc As the figure at right shows, the R_c-a value is the sum of the thermal resistance of the TIM (R_tim) R_tim graph, depending on the operating environment. The y‑axis in the graph is a base 10 logarithmic R_c-a plus the thermal resistance of the heat sink (R_hs). R_hs CXB2530 Ta Ta 100.00 Maximum R_c-a 10.00 Ta = 25 °C Ta = 55 °C 1.00 Ta = 85 °C Ta = 105 °C 0.10 0.01 300 560 820 1080 1340 1600 Current (mA) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS122 REV 10A 17 XLAMP ® CXB2530 LED NOTES Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs. Lumen Maintenance Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. REACh Compliance REACh substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative to insure you get the most up-to-date REACh Declaration. REACh banned substance information (REACh Article 67) is also available upon request. UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS122 REV 10A 18 XLAMP ® CXB2530 LED PACKAGING 6 CXB2530 LEDs are packaged5in trays of 20. Five trays are sealed in an anti-static bag and placed inside a carton, for a total of 4 3 2 100 LEDs per carton. Each carton contains 100 LEDs from the same performance bin. NOTICE NTIAL. THIS PLOT AND THE INFORMATION THIN ARE THE PROPRIETARY AND NFORMATION OF CREE, INC. THIS PLOT PIED, REPRODUCED OR DISCLOSED TO ANY D PERSON WITHOUT THE WRITTEN CONSENT Dimensions are in inches. Tolerances: +.13 7.125 4 5 5 R .375 4 3 x° +1° 2 3 1 2 1 E PLOT AND THE INFORMATION E PROPRIETARY AND ON OF CREE, INC. THIS PLOT NSENT ODUCED OR DISCLOSED TO ANY WITHOUTTHE WRITTEN CONSENT 5.875 1.188 7.125 R .375 R.375 7.625 .875 1.188 7.625 .38 1.188 LABEL WITH CREE BIN CODE, QUANTITY, LOT # BAG PATENT LABEL IS LOCATED ON UNDERSIDE OF COVER PATENT LABEL IS LOCATED ON UNDERSIDE OF CARTON 1.188 LABEL WITH CREE BIN CODE, QTY, LOT# TH CREE BIN ANTITY, LOT # .38 BAG BAG .38 .875 LABEL WITH CREE BIN CODE, QUANTITY, LOT # PATENT LABEL IS LOCATED ON UNDERSIDE OF CARTON L IS LOCATED IDE OF COVER LABEL WITH CREE BIN CODE, QTY, LOT# LABEL WITH CREE BIN CODE, QUANTITY, LOT # LABEL WITH CREE BIN CODE, QUANTITY, LOT # LABEL WITH CREE BIN CODE, QUANTITY, LOT # UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS & BEFORE FINISH. TOLERANCE UNLESS SPECIFIED: .X ± .XX ± .XXX ± X° ± THIRD ANGLE PROJECTION 5 .X ± .XX 3± .XXX ± X° ± 4 THIRD ANGLE PROJECTION WITH CREE BIN QUANTITY, LOT # 0.1 .05 .005 1° APPROVED DRAWN BY MATERIAL ± DATE TITLE SCALE DRAWING Phone (919) 361-477 Fax (919) 313-5303 0.500 2 CXA25XX_DATASHEET DATE DATE FINAL PROTECTIVE FINISH C TITLE 4600 Silicon Drive Durham, N.C 27703 DRAWING NO. CLD-DS122 0.500 REV 10A 19 Fax (919) 313-5303 SHEET 1 CXA15XX_DATASHEET SIZE R CXA25XX_DATASHEET_BAG2013 Phone (919) 361-4770 SCALE DATE 1 ° FINAL PROTECTIVE FINISH C 4600 Silicon Drive CXA25 Durham, N.C 27703 FINAL PROTECTIVE FINISH DATE 2 CXA25X SIZE SIZE © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered APPROVED X° 2 ° and .X ± trademarks, 0.1 ± ® ® .XXUL logo ± .05 the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite are registered trademarks of Cree LED. UL and the are registered 5 4 3 .XXX ± .005 trademarks of UL LLC. THIRD ANGLE PROJECTION MATERIAL X° DATE APPROVED TITLE UNLESS OTHERWISE SPECIFIED FOR SHEET DIMENSIONS ARE INMETAL PARTS ONLY .X ± .06 CHECK MILLIMETERS & BEFORE FINISH. .XX ± .03 TOLERANCE UNLESS SPECIFIED: .XXX ± .010 FOR SHEET METAL PARTS ONLY .X ± .06 DATE MATERIAL FOR SHEET METAL PARTS DATE ONLY DRAWN BY UNLESS OTHERWISE SPECIFIED .X ± .06 DIMENSIONS ARE IN .XX ± .03 CHECK DATE MILLIMETERS & BEFORE FINISH. .XXX ± .010 TOLERANCE UNLESS SPECIFIED: X° ± 2 ° LABEL WITH CREE BIN CODE, QTY, LOT# 6 0.1 .05 .005 1 ° DRAWN BY CHECK DRAWING NO. CXA15XX_DATASHEET_BAG2013 OF
物料型号:XLamp® CXB2530 LED
器件简介: - Cree XLamp® CXB2530 LED是第二代CXA家族的一部分,提供比第一代更高的效率和亮度。 - 该LED设计用于简化照明制造商的产品开发时间,提供一致的机械和光学设计,以缩短产品设计周期。 - 提供2步、3步和5步EasyWhite®色温分级和2步、3步高级色彩分级。
引脚分配:文档中未明确列出引脚分配,但提到了顶侧焊接连接。
参数特性: - 视角(FWHM):115度 - 静电放电分类:8000V (HBM per Mil-Std-883D) - 直流正向电流:最高1600mA - 反向电流:最高0.1mA - 正向电压:在800mA和85°C时,典型值34.2V至38V
功能详解: - 提供高达30%的更高效率和20%的更高亮度。 - 支持小尺寸照明解决方案,有助于制造更小、更高效的照明设备。 - 提供多种色温和色彩分级选项,以满足不同的照明需求。
应用信息: - 适用于需要高亮度和高效率的照明应用。 - 根据色温和色彩分级的不同,适用于不同的照明环境和需求。
封装信息: - 尺寸和公差信息在文档中有详细描述。 - Cree XLamp® CXB2530 LED符合RoHS和REACh标准,并被UL®认可为组件。
注意事项: - 文档中提到了热管理设计的重要性,以及如何确保LED在最大额定温度下运行。 - 提供了关于LED的长期可靠性测试和预测的信息。
其他: - 文档还包含了关于LED的光学参考、机械尺寸、热设计指南和包装信息。
CXB2530-0000-000N0BV240E 价格&库存
很抱歉,暂时无法提供与“CXB2530-0000-000N0BV240E”相匹配的价格&库存,您可以联系我们找货
