CXM-27-40-80-36-AA00-F2-2 数据手册
CXM-27 Product Datasheet
CXM-27 COB Arrays
White LED
Features:
• High lumen output and efficacy typical
Table of Contents
• Over 8,400 lm, 130 LPW @ 3000K, 25ºC
Technology Overview. . . . . . 2
• Over 9,200 lm, 142 LPW @ 5000K, 25ºC
Test Specifications . . . . . . . . . 2
• CCT range 2700K, 3000K, 3500K, 4000K, 5000K and 6500K
• 80 or 90 CRI min. up to 95 min. in warm white
Chromaticity Bins. . . . . . . . . . 3
• 3 SDCM color binning accuracy
Product Ordering & Shipping
Part Numbers. . . . . . . . . . . . . . 4
• Excellent optical emission uniformity and color over angle consistency
Orderring Part Number. . . . . 5
Operating Characteristics . . 7
• Exceptional long term color stability
• Superior thermal conductivity for uniform heat spreading
• Environmentally friendly: RoHS and REACh compliant
• UL recognized, file # E465703
Optical and Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . . . 8
Spectra. . . . . . . . . . . . . . . . . . . . 9
Mechanical Dimensions. . . 10
Packaging Information. . . . 11
Handling Notes. . . . . . . . . . . 12
Applications
• Architectural and Specialty
• Parking Lot and Area Lighting
• Street Lighting
• Tunnel Lighting
1
PDS-002219 Rev 08
© 2018 Luminus Devices, Inc. - All Rights Reserved
Technology Overview
Luminus Chip-on-Board (COB) LED series offers a complete lighting class solution designed for high performance illumination
applications. The selection covers a wide lumen range from less than 400lm to over 10,000lm, all major color temperatures and can
deliver color rendering greater than 97 at 2700K and 3000K and R9 equal to 95. These breakthroughs allow illumination engineers and
designers to develop lighting solutions with maximum efficacy, brightness and overall quality.
Reliability
Designed from the ground up, the Luminus COB LED is one of
the most reliable light sources in the world today. Having
passed a rigorous suite of environmental and mechanical stress
tests, including mechanical shock, vibration, temperature
cycling and humidity. Only then are the devices qualified for
use in a wide range of lighting application including some of the
most demanding commercial applications. Delivered with fully
qualified LM80 test data and TM21 lifetime results that certify
lumen maintenance at 35,000 hours or more, Luminus COB
LEDs are ready for the toughest challenges.
UL Recognized Compliance
Luminus COB arrays are tested in accordance with ANSI/UL 8750
to ensure safe operation for their intended applications.
REACh & RoHS Compliance
All LED products manufactured by Luminus are REACh and
RoHS compliant and free of hazardous materials, including lead
and mercury.
Understanding Luminus COB LED Test Specifications
Every Luminus LED is fully tested to ensure it meets the high quality standards customers have come to expect from Luminus’ products.
Traceability
Chromaticity Bin Range
Each Luminus COB LED is marked with a 2D bar code that
contains a unique serial number. With this serial number,
Luminus has the ability to provide customers with actual test
data measurements for a specific LED. In addition, the 2D bar
code is linked to manufacturing date codes that enables
traceability of production processes and materials.
Chromaticity binning delivers color consistency for every order.
Standard products are delivered with a 3-step MacAdam ellipse.
This ensures color performance matching in the application.
These tightly controlled, small distribution bins provide
customers predictable, repeatable colors.
Testing Temperature
Luminus COB products are measured at temperatures typical for
the LED operating in the fixture. Each device is tested at 85ºC
junction temperature eliminating the need to scale data sheet
specifications to real world situations.
2
PDS-002219 Rev 08
Chromaticity Bin Structure
Chromaticity Bins: 1931 CIE Curve
0.46
ANSI C78.377-2008
3-step Ellipse
5-step Ellipse
2700K
0.44
3000K
3500K
0.42
Black Body
4000K
CIE y
0.4
5000K
0.38
0.36
6500K
0.34
0.32
0.3
0.3
0.32
0.34
0.36
0.38
0.4
0.42
0.44
0.46
0.48
0.5
CIE x
CXM-27 White Chromaticity Bins
The following tables describe the ANSI bin center points, the orientation angle for the MacAdam ellipse (θ °), and the maximum radii for
the ellipses. The ANSI Bin is provided for reference.
CCT
Center Point
Angle
3-step Bin
5-step Bin
CIEx
CIEy
θ (°)
a
b
2700K
0.4578
0.4101
53.7
0.0081
0.0042
3000K
0.4338
0.403
53.2
0.00834
0.00408
3500K
0.4073
0.3917
54
0.00927
0.00414
4000K
0.3818
0.3797
53.7
0.00939
0.00402
5000K
0.3447
0.3553
59.6
0.00822
6500K
0.3123
0.3282
58.57
0.00669
*Note:
Luminus maintains a +/- 0.005 tolerance on chromaticity (CIEx and CIEy) measurements.
3
PDS-002219 Rev 08
a
b
0.00354
0.0137
0.0059
0.00285
0.01115
0.00475
Product Ordering and Shipping Part Number Nomenclature
All CXM-27 products are packaged and labeled with part numbers as outlined in the table on page 5 and 6. Luminus may include any
smaller chromaticity bin that is contained in the larger bin as part of the ordered part. When shipped, each package will contain only a
single flux and chromaticity bin. The part number designation is as follows:
CXM
27
NN
XX
36
QQPP
FG
W
Product Family
Light Emitting
Surface Diameter
Color
Temperature
Color Rendering Index (CRI)
Voltage
(typical)
Package
Configurator
Flux Bin
Chromaticity
Bin
CXM: Chip on
Board
26.5: LES
Diameter (mm)
Color
See Note 1
below
CRI See Note 2
below
Volts
AA00
(Basic package)
Lumens
See page 3 for
bins
Note 1: NN nomenclature corresponds to the following:
27 = 2700K
30 = 3000K
35 = 3500K
40 = 4000K
50 = 5000K
65 = 6500K
Note 2: AA is standard package configurator
AB is an alternative
Color Temperature, CRI and R9 Values
Color Temperatures
XX Value
CRI
R9
5000K
75
>75
2700K, 3000K, 3500K, 4000K, 5000K, 6500K
80
>80
>0
90
>90
>50
2700K, 3000K
95
>95
>85
Note:
Luminus part numbers may be accompanied by prefixes or suffixes. The most common is the “Rev01” suffix indicating a part is fully released
and carries a full warranty. These additional characters may appear on shipping labels, packing slips and invoices. In all cases the basic part
number described above will always be included.
4
PDS-002219 Rev 08
CXM-27 Part Numbers (AA00)
The following tables describe products with typical flux and minimum flux measured at 1,800mA and specified at Tj = 85ºC. The values at
25ºC are calculated and shown for reference only. Luminus may choose to ship a smaller chromatiticy bin in an order for a larger.
Color
Rendering
Index
Ordering Part Number
CRI (min.)
3-step MacAdam Ellipse
7,980
80
CXM-27-27-80-36-AA00-F2-3
5,330
6,230
90
CXM-27-27-90-36-AA00-F2-3
5,280
5,015
5,860
95
CXM-27-27-95-36-AA00-F2-3
7,580
7,200
8,420
80
CXM-27-30-80-36-AA00-F2-3
6,470
6,150
7,180
90
CXM-27-30-90-36-AA00-F2-3
5,970
5,670
6,630
95
CXM-27-30-95-36-AA00-F2-3
7,850
7,558
8,720
80
CXM-27-35-80-36-AA00-F2-3
6,760
6,420
7,510
90
CXM-27-35-90-36-AA00-F2-3
8,110
7,705
9,010
80
CXM-27-40-80-36-AA00-F2-3
6,990
6,640
7,760
90
CXM-27-40-90-36-AA00-F2-3
Color
Rendering
Index
Part Number
Output Flux (lm)
Reference
Typ.
(85ºC)
Min.
(85ºC)
(calculated)
7,190
6,830
5,610
CCT
2700K
3000K
3500K
4000K
Typ.
(25ºC)
Output Flux (lm) Reference
CCT
Typ.
Typ.
(85ºC)
Min.
(85ºC)
(calculated)
5000K
8,310
7,895
6500K
8,310
7,895
CRI (min.)
5-step MacAdam Ellipse
9,230
80
CXM-27-50-80-36-AA00-F2-5
CXM-27-50-80-36-AA00-F2-3
9,230
80
CXM-27-65-80-36-AA00-F2-5
CXM-27-65-80-36-AA00-F2-3
(25ºC)
*Note:
Luminus maintains a +/- 6% tolerance on flux measurements.
Luminus maintains a +/- 2% tolerance on CRI measurements.
5
PDS-002219 Rev 08
CXM-27 Part Numbers (AB00)
Color
Rendering
Index
CRI (min.)
7,980
80
CXM-27-27-80-36-AB00-F2-3
5,330
6,230
90
CXM-27-27-90-36-AB00-F2-3
5,280
5,015
5,860
95
CXM-27-27-95-36-AB00-F2-3
7,580
7,200
8,420
80
CXM-27-30-80-36-AB00-F2-3
6,470
6,150
7,180
90
CXM-27-30-90-36-AB00-F2-3
5,970
5,670
6,630
95
CXM-27-30-95-36-AB00-F2-3
7,850
7,558
8,720
80
CXM-27-35-80-36-AB00-F2-3
6,760
6,420
7,510
90
CXM-27-35-90-36-AB00-F2-3
8,110
7,705
9,010
80
CXM-27-40-80-36-AB00-F2-3
6,990
6,640
7,760
90
CXM-27-40-90-36-AB00-F2-3
Color
Rendering
Index
Part Number
Output Flux (lm)
Reference
Typ.
(85ºC)
Min.
(85ºC)
(calculated)
7,190
6,830
5,610
CCT
2700K
3000K
3500K
4000K
Typ.
(25ºC)
CCT
5000K
6500K
Typ.
Typ.
(85ºC)
Min.
(85ºC)
(calculated)
8310
7895
8,310
8,310
CRI (min.)
9230
75
CXM-27-50-75-36-AB00-F2-5
CXM-27-50-75-36-AB00-F2-3
7,895
9,230
80
CXM-27-50-80-36-AB00-F2-5
CXM-27-50-80-36-AB00-F2-3
7,895
9,230
80
CXM-27-65-80-36-AB00-F2-5
CXM-27-65-80-36-AB00-F2-3
(25ºC)
*Note:
6
PDS-002219 Rev 08
CXM-27 Operating Characteristics1
Parameter
Forward Current
Symbol
2
If
Forward Voltage3
Vf
Minimum
Power
Operating Case Temperature4
31.5
Typical
Maximum
Unit
1,800
3,600
mA
35
37.5
V
65
144
W
105
ºC
Tc
Light Emitting Surface Diameter
LES
26.5
mm
Thermal Resistance (junction-to-case)
Qjc
0.28
ºC/W
Junction Temperature
Tj
Viewing Angle
140
120
ºC
Degree
Note 1: Ratings are based on operation at a constant junction temperature Tj = 85ºC.
Note 2: To prevent damage refer to operating conditions and derating curves for appropriate maximum operating conditions
Note 3: Forward voltage is rated at typical forward current. For voltage at different forward currents, refer to the voltage versus current performance graphs.
Note 4: COB LEDs are designed for operation to a minimum of 20% of the typical forward current value. Operation at currents lower than this value will not
harm the device but may result in uneven light emission across the LES surface.
Note 5: Luminus may change any specifications without prior notice. Please refer to the company web site for the latest data sheet revision
Note 6: Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye.
7
PDS-002219 Rev 08
CXM-27 Optical & Electrical Characteristics
Relative Output Flux vs. Forward Current @ 85ºC
Forward Current vs. Forward Voltage @ 85ºC
4000
250.0%
3500
Forward Current (mA)
Relative Luminous Flux
200.0%
150.0%
100.0%
3000
2500
2000
1500
50.0%
1000
0.0%
500
800
1200
1600
2000
2400
2800
3200
3600
4000
33
34
35
36
Relative Output Flux vs. Junction Temperature
39
38
37.5
100.0%
37
Forward Voltage (V)
38
Change in Voltage vs. Junction Temperature
120.0%
80.0%
60.0%
40.0%
36.5
36
35.5
35
20.0%
0.0%
34.5
5
15
25
35
45
55
65
75
85
95
34
105
-30
-20
-10
Junction Temperature (ºC)
30
40
50
60
70
80
90
100
Change in CIEy vs. Junction Temp. (3000K, 80CRI)
0.02
0.01
0.01
Δ CIEy
0.02
-0.01
-0.02
Change in CIEx vs. Junction Temp. (3000K, 80CRI)
Δ CIEx
37
Forward Voltage (V)
5
15
25
35
45
55
65
75
Case Temperature (ºC)
8
PDS-002219 Rev 08
85
95
105
-0.02
5
15
25
35
45
55
65
75
85
95
105
Typical Spectrum
120.00%
100.00%
Relative Intensity
80.00%
Warm White
60.00%
Neutral White
Cool White
40.00%
3000K-90CRI
3000K-97CRI
20.00%
0.00%
400
450
500
-20.00%
550
600
650
700
750
800
Wavelength (nm)
Typical Polar Radiation Pattern
Typical Angular Radiation Pattern
120%
100%
Relative Intensity (%)
80%
60%
40%
20%
0%
-80
-60
-40
-20
Anglular Displacement (Degrees)
9
PDS-002219 Rev 08
40
60
80
Mechanical Dimensions (AA00)
0.87±0.15
.034±.006
27.90
1.098
2X 2.40
.094
2X 2.40
.094
2X 3.26
.128
2X 13.95
.549
HOLES
1.37
.054
2X 3.26
.128
2X 13.95
.549
HOLES
31.50±0.25
1.240±.010
27.90
1.098
26.50
1.043
LES
1.20
.047
TcPOINT
28.00
1.102
RING O.D.
0.50±0.10
.020±.004
RING HEIGHT
31.50±0.25
1.240±.010
Mechanical Dimensions (AB00)
31.50±0.25
1.240±.010
2X 3.02
.119
2X 2.40
.094
2X 2.40
.094
31.50±0.25
1.240±.010
0.87±0.15
.034±.006
2XR 1.60
.063
2X 2.55
.100
4XR 0.50
.020
26.50 LES
1.043
2X 3.02
.119
1.20
.047
TcPOINT
27.90
1.098
2X 13.95
.549
HOLES
2X 13.35
.526
2X 13.95
.549
HOLES
2X 13.35
.526
27.90
1.098
10
PDS-002219 Rev 08
1.37
.054
6XR 0.20
.008
28.00
1.102
RING O.D.
0.50±0.10
.020±.004
RING HEIGHT
Shipping Container
100 pcs per box
Each bag is boxed for
easier storage/ stacking
20 pcs per tray
5 trays are stacked together
with separate cover
Trays are sealed in
an anti-static bag
Label
Luminus Label Model:
(Manufacturer Part Number & Bin Kits)
Bar code
XXX-XX-XX-XX-XX-XXXX-XX-X
XXXXXXXXXXXXXX
Bar code
11
PDS-002219 Rev 08
(Box ID)
Rev XX
Bar code
(Customer Part Number)
Qty: XX
Bar code
RoHS Compliant
Luminus Devices Inc
XXXXXX-XX-XX
CXM-27
Product
Datasheet
(Part
#) Product
Datasheet
Handling Notes for Luminus COBs
Luminus products are designed for robust performance in general lighting application. However, care must be taken when handling and
assembling the LEDs into their fixtures. To avoid damaging Luminus COBs please follow these guide lines.
The following is an overview of the application notes detailing some of the practices to follow when working with these devices. More
detailed information is available on the Luminus web site at www.luminus.com.
General Handling
Electrical Contact
Devices are made to be lifted or carried with tweezers on two
adjacent corners opposite the contact pads. At no time should
the devices be handled by or should anything come in contact
with the light emitting surface (LES) area. This area includes the
yellow colored circular area and the ring surrounding it. There
are electrical connections under the LES which if damaged will
cause the device to fail.
Luminus COBs are designed with contact pads on their top
surface. These pads are clearly marked with + and – polarity.
Wires can be soldered to the contact pads for electrical
connections or other solderless connector products are
available.
In addition, the ring frame itself should not be used for moving,
lifting or carrying the device. Also do not attach any optics or
mechanical holders to the ring as it is not capable to handle the
mechanical stress.
If wires are being soldered to the COB product, we recommend
attaching these wires prior to mounting the devices to a heat
sink. Please contact Luminus for specific recommendations on
how to solder wires if not familiar with the standard practice.
Luminus can also offer design recommendations for jigs to
allow easily soldering multiple products in rapid succession.
Static Electricity
Chemical Compatibility
Luminus COBs are electronic devices which can be damaged by
electrostatic discharge (ESD). Please use appropriate measures
to assure the devices do not experience ESD during their
handling and or storage. ESD protection guidelines should be
used at all times when working with Luminus COBs.
The resin material used to form the LES can getter hydrocarbons
from the surrounding environment. As a results, certain
chemical compounds are not recommended for use with the
Luminus products. Use of these compounds can cause damage
to the light output of the device and may permanently damage
the device. Please refer to www.luminus.com for a list of the
compounds not recommended for use with the Luminus COB
products.
Storage: Luminus products are delivered in ESD shielded bags
and should be stored in these bags until used.
Assembly: Individuals handling Luminus COBs during assembly
should be trained in ESD protection practices. Assemblers
should maintain constant conductive contact with a path to
ground by means of a wrist strap, ankle straps, mat or other ESD
protection system.
Transporting: When transporting the devices from one
assembly area to another, ESD shielded carts and carriers should
be used.
12
PDS-002219 Rev 08
Thermal Interface Material (TIM)
Proper thermal management is critical for successful operation
of any LED system. Excess operating temperature can reduce
the light output of the device. And excessive heating can cause
permanent damage to the device. Proper TIM material is a
crucial component for effective heat transfer away from the LED
during normal operation. Please refer to www.luminus.com for
specific recommendations for TIM solutions.
