CXB2540-0000-000N0BW450E
    WOLFSPEED
    LED COB CXB2540 5000K WHT SMD
CXB2540-0000-000N0BW450E 数据手册
PRODUCT FAMILY DATA SHEET XLamp® CXB2540 LED PRODUCT DESCRIPTION FEATURES TABLE OF CONTENTS The XLamp® CXB2540 LED Array is a • 19-mm optical source Characteristics................................................ 2 member of the second generation of the • Mechanical and optical design Operating Limits.............................................. 2 CXA family that delivers up to 30% higher consistent with other CXA25 and Flux Characteristics, EasyWhite® Order efficacy and up to 20% higher lumens than CXB25 LEDs Codes and Bins............................................... 3 the first generation in the same LES. The • Available in 70-, 80-, 90- and Flux Characteristics, Premium Color Order higher performance second generation Codes and Bins............................................... 6 CXA LED Arrays provide a 95-minimum CRI options drop-in • EasyWhite 2-, 3‑ and 5-step binning ® Relative Spectral Power Distribution............. 7 performance upgrade to existing CXA LED • Premium Color 2- and 3-step binning Relative Spectral Power Distribution, designs to shorten product development • Forward voltage option: 36‑V class Premium Color................................................ 7 time. In addition, the CXB LEDs also • 85 °C binning and characterization Electrical Characteristics................................ 8 allow lighting manufacturers to achieve • Extremely uniform color over viewing Relative Luminous Flux................................... 9 the same or better performance with a Typical Spatial Distribution........................... 10 angle smaller LES, enabling a smaller, more • Top-side solder connections Performance Groups - Brightness............... 10 impactful luminaire. Available in 2‑step, • Thermocouple attach point Performance Groups - Chromaticity............ 11 3‑step and 5‑step EasyWhite Premium Color Performance Groups - ® bins and • NEMA SSL-3 2011 standard flux bins 2‑step and 3‑step Premium Color bins, the • RoHS and REACh compliant Chromaticity.................................................. 12 CXB2540 LED delivers high lumen output EasyWhite® Bins Plotted on the 1931 CIE • UL® recognized component (E349212) and high efficacy in a single, easy‑to‑use Color Space................................................... 13 package that eliminates the need for reflow Premium Color Bins Plotted on the 1931 soldering. CIE Color Space............................................ 14 Bin and Order Code Formats........................ 16 The CX Family LED Design Guide provides Mechanical Dimensions............................... 16 basic information on the requirements Thermal Design............................................. 17 to use the CXB2540 LED successfully in Notes............................................................. 18 luminaire designs. Packaging...................................................... 19 Cree LED / 4400 Silicon Drive / Durham, NC 27703 USA / +1.919.313.5330 / www.cree-led.com © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS123 REV 10A 1 XLAMP ® CXB2540 LED CHARACTERISTICS Characteristics Unit Viewing angle (FWHM) Minimum Typical degrees ESD withstand voltage (HBM per Mil-Std-883D) Maximum 115 V 8000 DC forward current mA 2100* Reverse current mA 0.1 Forward voltage (@ 1100 mA, Tj = 85 °C) * V 34.1 38 Refer to the Operating Limits section. OPERATING LIMITS The maximum current rating of the CXB2540 depends on the case temperature (Tc) when the LED has reached thermal equilibrium under steady-state operation. The graph shown below assumes that the system design employs good thermal management (thermal interface material and heat sink) and may vary when poor thermal management is employed. Please refer to the Mechanical Dimensions section on page 16 for the location of the Tc measurement point. Another important factor in good thermal management is the temperature of the Light Emitting Surface (LES). Cree LED recommends a maximum LES temperature of 135 °C to ensure optimal LED lifetime. Please refer to the Thermal Design section on page 17 for more information on LES temperature measurement. CXB2540 - Standard 2400 85 °C, 2100 mA 2100 1800 If (mA) 1500 1200 900 125 °C, 808 mA 600 300 0 0 25 50 75 100 125 150 Case Temperature (°C) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS123 REV 10A 2 XLAMP ® CXB2540 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS (IF = 1100 mA, TJ = 85 °C) The following table provides order codes for XLamp CXB2540 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 16). CRI* Nominal CCT Min 70 Minimum Luminous Flux Typ --- 2-Step 3-Step 5-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** W4 5225 5784 X2 5590 6188 X4 6010 6653 CXB2540-0000000N0BX465E W4 5225 5784 CXB2540-0000000N0HW465E X2 5590 6188 X4 6010 6653 CXB2540-0000000N0HX465E W4 5225 5784 CXB2540-0000000N0BW457E X2 5590 6188 X4 6010 6653 CXB2540-0000000N0BX457E W4 5225 5784 CXB2540-0000000N0HW457E X2 5590 6188 X4 6010 6653 Group Order Code Group Order Code Group CXB2540-0000000N0BW465E 65E 6500 K 80 70 --- --- 65E 57E 5700 K 80 --- Order Code 57E CXB2540-0000000N0BX265E CXB2540-0000000N0HX265E CXB2540-0000000N0BX257E CXB2540-0000000N0HX257E CXB2540-0000000N0HX457E Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 18). • CXB2540 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS123 REV 10A 3 XLAMP ® CXB2540 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS (IF = 1100 mA, TJ = 85 °C) - CONTINUED CRI* Nominal CCT Min 70 5000 K 80 90 70 4000 K 80 90 Minimum Luminous Flux Typ --- --- 92 --- --- 92 2-Step 3-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** W4 5225 5784 X2 5590 6188 X4 6010 6653 W4 5225 5784 X2 5590 6188 X4 6010 6653 CXB2540-0000000N0HX450G V4 4545 5031 CXB2540-0000000N0UV450G W2 4860 5380 W4 5225 5784 W4 5225 5784 X2 5590 6188 X4 6010 6653 W2 4860 5380 W4 5225 5784 X2 5590 6188 CXB2540-0000000N0HX240H CXB2540-0000000N0HX240G V2 4230 4683 CXB2540-0000000N0UV240H CXB2540-0000000N0UV240G V4 4545 5031 W2 4860 5380 Group Order Code Group Order Code 5-Step Group Order Code CXB2540-0000000N0BW450E 50E CXB2540-0000000N0BX250E CXB2540-0000000N0BX450E CXB2540-0000000N0HW450G 50G 50G CXB2540-0000000N0HX250G CXB2540-0000000N0HW450E 50E CXB2540-0000000N0HX250E CXB2540-0000000N0HX450E CXB2540-0000000N0UW250G CXB2540-0000000N0UW450G CXB2540-0000000N0BW440E 40E CXB2540-0000000N0BX240E CXB2540-0000000N0BX440E CXB2540-0000000N0HW240H 40H 40H CXB2540-0000000N0HW440H CXB2540-0000000N0UV440H CXB2540-0000000N0UW240H CXB2540-0000000N0HW240G 40G 40G CXB2540-0000000N0HW440G CXB2540-0000000N0UV440G CXB2540-0000000N0UW240G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 18). • CXB2540 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS123 REV 10A 4 XLAMP ® CXB2540 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS (IF = 1100 mA, TJ = 85 °C) - CONTINUED CRI* Nominal CCT Min 80 Minimum Luminous Flux Typ --- 2-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** W2 4860 5380 W4 5225 5784 X2 5590 6188 CXB2540-0000000N0HX235H CXB2540-0000000N0HX235G V2 4230 4683 CXB2540-0000000N0UV235H CXB2540-0000000N0UV235G V4 4545 5031 W2 4860 5380 CXB2540-0000000N0UW235H CXB2540-0000000N0UW235G V4 4545 5031 CXB2540-0000000N0HV430H CXB2540-0000000N0HV430G W2 4860 5380 W4 5225 5784 CXB2540-0000000N0HW430H CXB2540-0000000N0HW430G U4 3955 4378 CXB2540-0000000N0UU430H CXB2540-0000000N0UU430G V2 4230 4683 V4 4545 5031 CXB2540-0000000N0UV430H CXB2540-0000000N0UV430G V4 4545 5031 CXB2540-0000000N0HV427H CXB2540-0000000N0HV427G W2 4860 5380 W4 5225 5784 CXB2540-0000000N0HW427H CXB2540-0000000N0HW427G U2 3680 4074 CXB2540-0000000N0UU227H CXB2540-0000000N0UU227G U4 3955 4378 V2 4230 4683 V2 4230 4683 Group 80 92 --- 35H 35H 30H 3000 K 90 80 92 --- 30H 27H 2700 K 90 2200 K 80 92 --- Order Code Group CXB2540-0000000N0HW235H 3500 K 90 3-Step 27H CXB2540-0000000N0HW435H CXB2540-0000000N0UV435H CXB2540-0000000N0HW230H CXB2540-0000000N0UV230H CXB2540-0000000N0HW227H CXB2540-0000000N0UU427H Order Code 5-Step Group Order Code CXB2540-0000000N0HW235G 35G 35G 30G 30G 27G 27G CXB2540-0000000N0UV227H CXB2540-0000000N0HW435G CXB2540-0000000N0UV435G CXB2540-0000000N0HW230G CXB2540-0000000N0UV230G CXB2540-0000000N0HW227G CXB2540-0000000N0UU427G CXB2540-0000000N0UV227G 22G CXB2540-0000000N0HV222G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 18). • CXB2540 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS123 REV 10A 5 XLAMP ® CXB2540 LED FLUX CHARACTERISTICS, PREMIUM COLOR ORDER CODES AND BINS (IF = 1100 mA, TJ = 85 °C) Fidelity CRI* Nominal CCT Minimum Luminous Flux Min Typ Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** 4000 K 95 98 U4 3955 4378 3500 K 95 98 U4 3955 3000 K 95 98 U2 2700 K 95 98 U2 Typical Luminous Flux (lm) @ 85 °C 2-Step Group Order Code 4451 L5A CXB2540-0000-000N0ZU4L5A 4378 4286 35H CXB2540-0000-000N0ZU435H 3680 4074 4121 30H CXB2540-0000-000N0ZU230H 3680 4074 3888 27H CXB2540-0000-000N0ZU227H Specialty CRI Nominal CCT 3100 K 3000 K Minimum Luminous Flux Typical Luminous Flux (lm) @ 85 °C Min Typ Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** 90 92 U4 3955 4378 4749 80 --- W2 4860 5380 5522 U2 3680 4074 U4 3955 4378 V2 4230 4683 U2 3680 4074 90 95 92 98 2-Step Group L7B Order Code 3-Step Group Order Code 31Q CXB2540-0000000N0UU431Q Group Order Code CXB2540-0000000N0HW2L7B CXB2540-0000000N0UU230U 4749 30Q CXB2540-0000000N0UU430Q CXB2540-0000000N0UV230Q 4121 L7C 30U CXB2540-0000000N0UU430U CXB2540-0000000N0UV230U CXB2540-0000000N0ZU2L7C Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 18). • CXB2540 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS123 REV 10A 6 XLAMP ® CXB2540 LED RELATIVE SPECTRAL POWER DISTRIBUTION The following graph is the result of a series of pulsed measurements at 1100 mA and TJ = 85 °C. 100% Relative Spectral Power 90% 80% 70% 5000 K, 70 CRI 60% 4000 K, 70 CRI 50% 3000 K, 80 CRI 40% 3000 K, 90 CRI 30% 2200 K, 80 CRI 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) RELATIVE SPECTRAL POWER DISTRIBUTION, PREMIUM COLOR The following graphs are the result of a series of pulsed measurements at 800 mA and TJ = 85 °C. Fidelity 100% Relative Spectral Power 90% 80% 70% 60% 4000 K, Z CRI 50% 3500 K, Z CRI 3000 K, Z CRI 40% 2700 K, Z CRI 30% 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS123 REV 10A 7 XLAMP ® CXB2540 LED RELATIVE SPECTRAL POWER DISTRIBUTION, PREMIUM COLOR - CONTINUED Relative Spectral Power Distribution Specialty 100% 90% Relative Spectral Power 80% 70% 31Q, 3100 K, 90 CRI 60% 30Q, 3000 K, 90 CRI 50% 30U, 3000 K, 90 CRI 40% L7B, 3000 K 80 CRI 30% L7C, 3000 K, Z CRI 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) ELECTRICAL CHARACTERISTICS The following graph is the result of a series of steady-state measurements. 37.0 36.5 36.0 Voltage (V) 35.5 35.0 Tc = 25 °C 34.5 Tc = 55 °C 34.0 Tc = 85 °C 33.5 Tc = 105 °C 33.0 32.5 32.0 31.5 400 740 1080 1420 1760 2100 Current (mA) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS123 REV 10A 8 XLAMP ® CXB2540 LED RELATIVE LUMINOUS FLUX The relative luminous flux values provided below are the ratio of measurements of the CXB2540 LED at steady-state operation at the given conditions, divided by the flux measured during binning, which is a pulsed measurement at 1100 mA at TJ = 85 °C. For example, at steady-state operation of Tc = 25 °C, IF = 740 mA, the relative luminous flux ratio is 80% in the chart below. A CXB2540 LED that measures 5225 lm during binning will deliver 4180 lm (5225 * 0.8) at steady-state operation of Tc = 25 °C, IF = 740 mA. 180% 160% Relative Luminous Flux 140% 120% Tc = 25 °C 100% Tc = 55 °C 80% Tc = 85 °C Tc = 105 °C 60% 40% 20% 0% 400 740 1080 1420 1760 2100 Current (mA) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS123 REV 10A 9 XLAMP ® CXB2540 LED Far Field TYPICAL SPATIAL DISTRIBUTION Relative Luminous Intensity 100% 80% 60% 40% 20% -90 -70 -50 -30 -10 0% 10 30 50 70 90 Angle (º) PERFORMANCE GROUPS - BRIGHTNESS (I F = 1100 mA, TJ = 85 °C) XLamp CXB2540 LEDs are tested for luminous flux and placed into one of the following bins. Group Code Minimum Luminous Flux Maximum Luminous Flux U2 3680 3955 U4 3955 4230 V2 4230 4545 V4 4545 4860 W2 4860 5225 W4 5225 5590 X2 5590 6010 X4 6010 6430 Y2 6430 6910 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS123 REV 10A 10 XLAMP ® CXB2540 LED PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) XLamp CXB2540 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. EasyWhite Color Temperatures – 2-Step Code 40H 35H 30H 27H CCT 4000 K 3500 K 3000 K 2700 K x y 0.3777 0.3739 0.3797 0.3816 0.3861 0.3855 0.3838 0.3777 0.4022 0.3858 0.4053 0.3942 0.4125 0.3977 0.4091 0.3891 0.4287 0.3975 0.4328 0.4064 0.4390 0.4086 0.4347 0.3996 0.4524 0.4048 0.4574 0.4140 0.4633 0.4154 0.4581 0.4062 EasyWhite Color Temperatures – 3-Step Ellipse Bin Code CCT 50G 40G Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 5000 K 0.3447 0.3553 0.00840 0.00312 65.0 4000 K 0.3818 0.3797 0.00939 0.00402 53.7 35G 3500 K 0.4073 0.3917 0.00927 0.00414 54.0 30G 3000 K 0.4338 0.4030 0.00834 0.00408 53.2 27G 2700 K 0.4577 0.4099 0.00834 0.00420 48.5 22G 2200 K 0.5066 0.4158 0.00980 0.00480 45.5 EasyWhite Color Temperatures – 5-Step Ellipse Bin Code CCT 65E Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 6500 K 0.3123 0.3282 0.01110 0.00550 61.0 57E 5700 K 0.3287 0.3417 0.01230 0.00600 72.0 50E 5000 K 0.3447 0.3553 0.01400 0.00520 65.0 40E 4000 K 0.3818 0.3797 0.01565 0.00670 53.7 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS123 REV 10A 11 XLAMP ® CXB2540 LED PREMIUM COLOR PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) XLamp CXB2540 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. Fidelity EasyWhite Color Temperatures – 2-Step Code L5A 35H 30H 27H CCT 4000 K 3500 K 3000 K 2700 K x y 0.3764 0.3711 0.3784 0.3787 0.3847 0.3826 0.3825 0.3748 0.4022 0.3858 0.4053 0.3942 0.4125 0.3977 0.4091 0.3891 0.4287 0.3975 0.4328 0.4064 0.4390 0.4086 0.4347 0.3996 0.4524 0.4048 0.4574 0.4140 0.4633 0.4154 0.4581 0.4062 Specialty EasyWhite Color Temperatures – 2-Step Code L7B L7C CCT 3000 K 3000 K x y 0.4263 0.3848 0.4296 0.3916 0.4361 0.3938 0.4326 0.3868 0.4192 0.3754 0.4224 0.3823 0.4291 0.3847 0.4257 0.3777 EasyWhite Color Temperatures – 3-Step Ellipse Center Point Major Axis Minor Axis Rotation Angle (°) Bin Code CCT x y a b 31Q 3100 K 0.4236 0.3888 0.00848 0.00455 50.3 30Q 3000 K 0.4305 0.3935 0.00834 0.00408 53.2 30U 3000 K 0.4274 0.3837 0.00834 0.00408 53.2 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS123 REV 10A 12 XLAMP ® CXB2540 LED EASYWHITE® BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) 0.45 ANSI C78.377 Quadrangle 0.44 2700 K EasyWhite 5-step 0.43 2200 K 2450 K 3000 K EasyWhite 3-step 0.42 EasyWhite 2-step 3500 K 0.41 4000 K 0.40 CCy 0.39 5000 K 4500 K 5700 K 0.38 0.37 6500 K 0.36 0.35 7000K 0.34 0.33 0.32 0.54 0.53 0.52 0.51 0.50 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.31 CCx © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS123 REV 10A 13 XLAMP ® CXB2540 LED PREMIUM COLOR BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) Fidelity (2-step) 0.44 2700K ANSI C78.377 Quadrangle 0.43 3000K 0.42 3500K 0.41 27H 4000K CCy 0.40 30H 4500K 35H 0.39 0.38 L5A 0.37 0.36 0.35 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. 0.48 0.47 0.46 0.45 0.44 CCx 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 CLD-DS123 REV 10A 14 XLAMP ® CXB2540 LED PREMIUM COLOR BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) - CONTINUED Speciality (2-step) 0.44 ANSI C78.377 Quadrangle 3000 K 0.43 0.42 3500 K CCy 0.41 0.40 0.39 L7B L7C 0.38 0.46 0.45 CCx 0.44 0.43 0.42 0.41 0.37 Speciality (3-step) 0.44 ANSI C78.377 Quadrangle 3000K 0.43 0.42 3500K CCy 0.41 0.40 30Q 0.39 31Q 30U 0.38 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. 0.46 0.45 CCx 0.44 0.43 0.42 0.41 0.37 CLD-DS123 REV 10A 15 XLAMP ® CXB2540 LED BIN AND ORDER CODE FORMATS Bin codes and order codes are configured as follows: Order Code Bin Code Series = CXB25 Series = CXB25 Internal code Chromaticity bin CRI Specification B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Z = 95 CRI minimum Vf class N0 = 36-V class Internal code SSSSSCC-WWW-FF-GGR-AAAAA CRI Specification B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Z = 95 CRI minimum SSSSSCC-HHHH-HHHGGRNNNNN Kit code Vf class N0 = 36-V class Flux bin Performance class Performance class MECHANICAL DIMENSIONS Dimensions are in mm. Tolerances unless otherwise specified: ±.13 x° ±1° B2540N = 36‑V CXB2540 B2540N Meaning of B2540N © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS123 REV 10A 16 XLAMP ® CXB2540 LED THERMAL DESIGN The CXB family of LED arrays can include over a hundred different LED die inside one package, and thus over a hundred different junction temperatures (TJ). Cree LED has intentionally removed junction-temperature-based operating limits and replaced the commonplace maximum TJ calculations with maximum ratings based on forward current (IF) and case temperature (Tc). No additional calculations are required to ensure that the CXB LED is being operated within its designed limits. LES temperature measurement provides additional verification of good thermal design. Please refer to page 2 for the Operating Limit specifications. There is no need to calculate for TJ inside the package, as the thermal management design process, specifically from TSP to ambient (Ta), remains identical to any other LED component. For more information on thermal management of XLamp LEDs, please refer to the Thermal Management application note. For CXB soldering recommendations and more information on thermal interface materials (TIM), LES temperature measurement, and connection methods, please refer to the XLamp CX Family LEDs soldering and handling document. The CX Family LED Design Guide provides basic information on the requirements to use XLamp CXB LEDs successfully in luminaire designs. To keep the CXB2540 LED at or below the maximum rated Tc, the case to ambient temperature thermal resistance (R_c-a) must be at or below the maximum R_c-a value shown on the following R_j-c R_j-c scale. Tc Tc As the figure at right shows, the R_c-a value is the sum of the thermal resistance of the TIM (R_tim) R_tim graph, depending on the operating environment. The y‑axis in the graph is a base 10 logarithmic R_c-a plus the thermal resistance of the heat sink (R_hs). R_hs CXB2540 Ta Ta Maximum R_c-a 10.00 1.00 Ta = 25 °C Ta = 55 °C Ta = 85 °C Ta = 105 °C 0.10 0.01 400 740 1080 1420 1760 2100 Current (mA) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS123 REV 10A 17 XLAMP ® CXB2540 LED NOTES Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs. Lumen Maintenance Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. REACh Compliance REACh substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative to insure you get the most up-to-date REACh Declaration. REACh banned substance information (REACh Article 67) is also available upon request. UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS123 REV 10A 18 XLAMP ® CXB2540 LED PACKAGING 6 5 4 3 2 CXB2540 LEDs are packaged in trays of 20. Five trays are sealed in an anti-static bag and placed inside a carton, for a total of 100 LEDs NOTICE TIAL. THIS PLOT AND THE INFORMATION HIN ARE THE PROPRIETARY AND NFORMATION OF CREE, INC. THIS PLOT PIED, REPRODUCED OR DISCLOSED TO ANY PERSON WITHOUT THE WRITTEN CONSENT per carton. Each carton contains 100 LEDs from the same performance bin. Dimensions are in inches. Tolerances: ±.13 7.125 5 R .375 4 5 4 3 x° ±1° 2 3 1 2 1 AND THE INFORMATION OPRIETARY AND F CREE, INC. THIS PLOT NSENT ED OR DISCLOSED TO ANY OUT THE WRITTEN CONSENT 5.875 1.188 7.125 R .375 R .375 7.625 .875 1.188 7.625 .38 1.188 LABEL WITH CREE BIN CODE, QUANTITY, LOT # BAG PATENT LABEL IS LOCATED ON UNDERSIDE OF COVER PATENT LABEL IS LOCATED 1.188 ON UNDERSIDE OF CARTON .38 BAG LABEL WITH CREE BIN CODE, QUANTITY, LOT # BAG .38 TH CREE BIN .875 PATENT ANTITY, LOT #LABEL IS LOCATED LABEL WITH CREE BIN CODE, QUANTITY, LOT # ON UNDERSIDE OF COVER L IS LOCATED IDE OF COVER LABEL WITH CREE BIN CODE, QUANTITY, LOT # LABEL WITH CREE BIN CODE, QUANTITY, LOT # LABEL WITH CREE BIN CODE, QUANTITY, LOT # LABEL WITH CREE BIN CODE, QUANTITY, LOT # UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS & BEFORE FINISH. TOLERANCE UNLESS SPECIFIED: .X ± .XX ± .XXX ± X° ± THIRD ANGLE PROJECTION LABEL WITH CREE BIN CODE, QUANTITY, LOT # 6 5 UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS & BEFORE FINISH. TOLERANCE UNLESS SPECIFIED: 4 3± .X .XX ± .XXX ± X° ± THIRD ANGLE PROJECTION WITH CREE BIN QUANTITY, LOT # 0.1 .05 .005 1 ° APPROVED ± DATE APPROVED DATE TITLE CXA25XX SIZE FINAL PROTECTIVE FINISH SCALE CXA25 4600 Silicon Drive Durham, N.C 27703 Phone (919) 361-4770 0.500 Fax (919) 313-5303 2 DATE DRAWING C TITLE DRAWN BY MATERIAL CXA25XX_DATASHEET DATE SIZE DATE FINAL PROTECTIVE FINISH © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered X°0.1 ± 2 ° and APPROVED .X ± trademarks, ® ® .XXUL logo ± .05 the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite are registered trademarks of Cree LED. UL are registered 5 4 3 and the .XXX ± .005 trademarks of UL LLC. THIRD ANGLE PROJECTION MATERIAL SCALE DATE 2 TITLE SIZE FINAL PROTECTIVE FINISH C 4600 Silicon Drive Durham, N.C 27703 DRAWING NO. CXA25XX_DATASHEET_BAG2013 R Phone (919) 361-4770 CLD-DS123 0.500 REV 10A 19 Fax (919) 313-5303 SHEET 1 CXA15XX_DATASHEET 1 ° FOR SHEET METAL PARTS ONLY .X ± .06 DATE MATERIAL FOR SHEET METAL PARTS ONLY DATE DRAWN.X BY ± .06 .XX ± .03 .XXX ± .010 CHECK DATE X° ± 2 ° UNLESS OTHERWISE SPECIFIED FOR SHEET METAL PARTS ONLY DIMENSIONS ARE IN .X ± .06 CHECK MILLIMETERS & BEFORE FINISH. .XX ± .03 TOLERANCE UNLESS SPECIFIED: .XXX ± .010 X° 0.1 .05 .005 1 ° DRAWN BY CHECK DRAWING NO. CXA15XX_DATASHEET_BAG2013 OF
物料型号:CXB2540N,属于36-V CXB2540系列。
器件简介:CXB2540 LED是Cree XLamp® CXA家族的第二代产品,提供比第一代更高的光效和光通量,同时保持或提高性能,且具有更好的色彩一致性和易用性。
引脚分配:文档中未明确提供引脚分配信息,但提到了顶侧焊接连接。
参数特性: - 视场角(FWHM):115度 - 静电耐受电压(HBM per Mil-Std-883D):最高8000V - 直流正向电流:最高2100mA - 反向电流:最高0.1mA - 正向电压(@ 1100 mA, T = 85°C):34.1V至38V
功能详解: - 提供70-95的最低CRI选项 - 支持EasyWhite® 2-, 3-和5步色温分级 - 提供优质色彩2-和3步色温分级 - 正向电压选项:36-V级别 - 85°C色温分级和特性描述 - 色彩一致性极高 - 符合NEMA SSL-3 2011标准光通量分级 - 符合RoHS和REACh标准 - UL®认可组件(E349212)
应用信息:适用于需要高性能和高光效的照明设计,可以作为现有CXA LED设计的升级选项。
封装信息:LED阵列包含超过一百个不同的LED芯片,具有优异的热管理特性,无需基于结温的额外计算。
CXB2540-0000-000N0BW450E 价格&库存
很抱歉,暂时无法提供与“CXB2540-0000-000N0BW450E”相匹配的价格&库存,您可以联系我们找货
