CXM-22-50-90-54-AC30-F4-3 数据手册
CXM-22 Product Datasheet
Preliminary
Generation 3
CXM-22 COB Arrays
White LED
Features:
• High lumen output and efficacy typical
Table of Contents
• Over 8,280 lm, 148 LPW @ 3000K, 80 CRI, Tj = 85ºC
Technology Overview. . . . . . 2
• Over 9,420 lm, 168 LPW @ 5000K, 70 CRI, Tj = 85ºC
Test Specifications . . . . . . . . . 2
• CCT 2700K, 3000K, 3500K, 4000K, 5000K and 6500K
• CRI Ra 80 or 90 min. in all colors (except 6500K)
Chromaticity Bins. . . . . . . . . . 3
• R9 up to 90 min. CRI 98 typical in 2700K, 3000K, 3500K and 4000K
Product Ordering & Shipping
Part Numbers. . . . . . . . . . . . . . 4
• 3 SDCM color binning accuracy
Product Typical Flux Range. 5
Operating Characteristics . . 6
Optical and Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . . . 7
• Excellent optical emission uniformity and color over angle consistency
• Exceptional long term color stability
• Package thermal conductivity more than the industry average
• Environmentally friendly: RoHS and REACH compliant
Spectra. . . . . . . . . . . . . . . . . . . . 8
Mechanical Dimensions. . . . 9
Packaging Information. . . . . 9
Handling Notes. . . . . . . . . . . 10
Applications
• Architectural and Specialty
• Parking Lot and Area Lighting
• Street Lighting
• Tunnel Lighting
1
PDS-002831 Rev 04
© 2017 Luminus Devices, Inc. - All Rights Reserved
Preliminary
Technology Overview
Luminus Chip-on-Board (COB) LED series offers a complete lighting class solution designed for high performance illumination
applications. The selection covers a wide lumen range from less than 400lm to over 10,000lm, all major color temperatures and can
deliver color rendering greater than 97 at 2700K and 3000K and R9 equal to 95. These breakthroughs allow illumination engineers and
designers to develop lighting solutions with maximum efficacy, brightness and overall quality.
Reliability
Designed from the ground up, the Luminus COB LED is one of
the most reliable light sources in the world today. Having
passed a rigorous suite of environmental and mechanical stress
tests, including mechanical shock, vibration, temperature
cycling and humidity. Only then are the devices qualified for
use in a wide range of lighting application including some of the
most demanding commercial applications. Delivered with fully
qualified LM80 test data and TM21 lifetime results that certify
lumen maintenance at 35,000 hours or more, Luminus COB
LEDs are ready for the toughest challenges.
UL Recognized Compliance
Luminus COB arrays are tested in accordance with ANSI/UL 8750
to ensure safe operation for their intended applications.
REACh & RoHS Compliance
All LED products manufactured by Luminus are REACH and
RoHS compliant and free of hazardous materials, including lead
and mercury.
Understanding Luminus COB LED Test Specifications
Every Luminus LED is fully tested to ensure it meets the high quality standards customers have come to expect from Luminus’ products.
Traceability
Chromaticity Bin Range
Each Luminus COB LED is marked with a 2D bar code that
contains a unique serial number. With this serial number,
Luminus has the ability to provide customers with actual test
data measurements for a specific LED. In addition, the 2D bar
code is linked to manufacturing date codes that enables
traceability of production processes and materials.
Chromaticity binning delivers color consistency for every order.
Standard products are delivered with a 3-step MacAdam ellipse.
This ensures color performance matching in the application. For
the most demanding application, Luminus is one of only a few
companies that can provide a 2-step ellipse bin. These tightly
controlled, small distribution bins provide customers
predictable, repeatable colors.
Testing Temperature
Luminus COB products are measured at temperatures typical for
the LED operating in the fixture. Each device is tested at 85ºC
junction temperature eliminating the need to scale data sheet
specifications to real world situations.
2
PDS-002831 Rev 04
Preliminary
Chromaticity Bin Structure
Chromaticity Bins: 1931 CIE Curve
0.46
ANSI C78.377-2008
3-step Ellipse
5-step Ellipse
2700K
0.44
3000K
3500K
0.42
Black Body
4000K
CIE y
0.4
5000K
0.38
0.36
6500K
0.34
0.32
0.3
0.3
0.32
0.34
0.36
0.38
0.4
0.42
0.44
0.46
0.48
0.5
CIE x
CXM-22 White Chromaticity Bins
The following tables describe the ANSI bin center points, the orientation angle for the MacAdam ellipse (θ °), and the maximum radii for
the ellipses. The ANSI Bin is provided for reference.
CCT
Center Point
Angle
3-step Bin
5-step Bin
CIEx
CIEy
θ (°)
a
b
2700K
0.4578
0.4101
53.7
0.0081
0.0042
3000K
0.4338
0.403
53.2
0.00834
0.00408
3500K
0.4073
0.3917
54
0.00927
0.00414
4000K
0.3818
0.3797
53.7
0.00939
0.00402
5000K
0.3447
0.3553
59.6
0.00822
6500K
0.3123
0.3282
58.57
0.00669
*Note:
Luminus maintains a +/- 0.005 tolerance on chromaticity (CIEx and CIEy) measurements.
3
PDS-002831 Rev 04
a
b
0.00354
0.0137
0.0059
0.00285
0.01115
0.00475
Preliminary
Product Ordering and Shipping Part Number Nomenclature
All CXM-22 products are packaged and labeled with part numbers as outlined in the table on page 5. Luminus may include any smaller
chromaticity bin that is contained in the larger bin as part of the ordered part. When shipped, each package will contain only a single
flux and chromaticity bin. The part number designation is as follows:
CXM
22
NN
XX
54
QQPP
FG
W
Product Family
Light Emitting Surface
Diameter
Color
Temperature
Color Rendering Index
(CRI)
Voltage (typical)
Package
Configurator
Flux Bin
Chromaticity
Bin
CXM: Chip on
Board
22: LES
Diameter
(mm)
Color
See Note 1
below
CRI See Table
Below
Volts
AC30
Lumens
See page 3 for
bins
Note 1: NN nomenclature corresponds to the following:
27 = 2700K
30 = 3000K
35 = 3500K
40 = 4000K
50 = 5000K
65 = 6500K
Color Temperature, CRI and R9 Values
Color Temperatures
XX Value
CRI
R9
3000K, 4000K, 5000K, 6500K
70
>70
2700K, 3000K, 3500K, 4000K, 5000K, 6500K
80
>80
>0
90
>90
>50
95
>95
2700K, 3000K
3500K, 4000K
Note:
>85
>75
Luminus part numbers may be accompanied by prefixes or suffixes. The most common is the “Rev01” suffix indicating a part is fully released
and carries a full warranty. These additional characters may appear on shipping labels, packing slips and invoices. In all cases the basic part
number described above will always be included.
4
PDS-002831 Rev 04
Preliminary
CXM-22 Part Numbers
The following tables describe products with typical flux and minimum flux measured at 1,100mA and specified at Tj = 85ºC. The values at
25ºC are calculated and shown for reference only.
Output Flux (lm)
CCT
3000K
3500K
4000K
CRI (min.)
3-step MacAdam Ellipse
Typ.
7,840
7,290
8,470
80
CXM-22-27-80-54-AC30-F4-3
6,460
6,010
6,980
90
CXM-22-27-90-54-AC30-F4-3
6,180
5,750
6,675
95
CXM-22-27-95-54-AC30-F4-3
8,425
7,835
9,090
70
CXM-22-30-70-54-AC30-F4-3
8,285
7,705
8,950
80
CXM-22-30-80-54-AC30-F4-3
6,970
6,480
7,525
90
CXM-22-30-90-54-AC30-F4-3
6,510
6,050
7,030
95
CXM-22-30-95-54-AC30-F4-3
8,530
7,935
9,215
80
CXM-22-35-80-54-AC30-F4-3
7,105
6,610
7,675
90
CXM-22-35-90-54-AC30-F4-3
6,795
6,320
7,340
95
CXM-22-35-95-54-AC30-F4-3
9,270
8,620
10,010
70
CXM-22-40-70-54-AC30-F4-3
8,645
8,040
9,335
80
CXM-22-40-80-54-AC30-F4-3
7,500
6,970
8,100
90
CXM-22-40-90-54-AC30-F4-3
6,960
6,475
7,510
95
CXM-22-40-95-54-AC30-F4-3
Reference
Color
Rendering
Index
Part Number
CCT
(25ºC)
Typ.
Min.
(85ºC)
(calculated)
9,425
8,765
8,700
Typ. (85ºC)
6500K
Ordering Part Number
(calculated)
Output Flux (lm)
5000K
Color
Rendering
Index
Min.
(85ºC)
Typ. (85ºC)
2700K
Reference
CRI (min.)
5-step MacAdam Ellipse
10,180
70
CXM-22-50-70-54-AC30-F4-5
CXM-22-50-70-54-AC30-F4-3
8,095
9,400
80
CXM-22-50-80-54-AC30-F4-5
CXM-22-50-80-54-AC30-F4-3
7,535
7,010
8,140
90
CXM-22-50-90-54-AC30-F4-5
9,435
8,775
10,190
70
CXM-22-65-70-54-AC30-F4-5
CXM-22-65-70-54-AC30-F4-3
8,670
8,065
9,365
80
CXM-22-65-80-54-AC30-F4-5
CXM-22-65-80-54-AC30-F4-3
(25ºC)
*Note:
Luminus maintains a +/- 6% tolerance on flux measurements.
Luminus maintains a +/- 2% tolerance on CRI and R9 measurements.
5
PDS-002831 Rev 04
Preliminary
CXM-22 Operating Characteristics1
Parameter
Symbol
2
Forward Current
If
Forward Voltage3
Vf
Minimum
48
Power
Operating Case Temperature4
Typical
Maximum
Unit
1,100
2,200
mA
51.5
55
V
56
125
W
105
ºC
Tc
Light Emitting Surface Diameter
LES
22
mm
Thermal Resistance (junction-to-case)
Qjc
0.17
ºC/W
Junction Temperature
Tj
Viewing Angle
140
120
ºC
Degree
Note 1: Ratings are based on operation at a constant junction temperature of Tj = 85ºC.
Note 2: To prevent damage refer to operating conditions and derating curves for appropriate maximum operating conditions
Note 3: Voltage is rated at typical forward current. For voltage at higher drive current, refer to performance graphs.
Note 4:
Device operation not recommended at drive currents less than 10% of the typical value
Note 5:
Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye.
Note 6:
All product operating specifications are subject to change without advance notice.
6
PDS-002831 Rev 04
Preliminary
CXM-22 Optical & Electrical Characteristics
Forward Current vs. Forward Voltage @ 85ºC
200%
2200
180%
2000
160%
1800
140%
1600
Forward Current (mA)
Relative Luminous Flux
Relative Output Flux vs. Forward Current @ 85ºC
120%
100%
80%
60%
1400
1200
1000
800
40%
600
20%
400
0%
200
200
400
600
800
1000 1200 1400
1600
1800
2000
2200
48
Relative Output Flux vs. Junction Temperature
50
51
52
53
Forward Voltage (V)
54
55
56
57
Change in Voltage vs. Junction Temperature
56
120%
100%
Forward Voltage (V)
49
80%
54
52
60%
50
40%
5
15
25
35
45
55
65
75
85
95
5
105
15
25
35
Change CIEx vs. Junction Temperature (3000K, 80CRI)
55
65
75
85
95
105
Change CIEy vs. Junction Temperature (3000K, 80CRI)
0.02
0.02
0.01
0.01
Δ CIEy
Δ CIEx
45
Junction Temperature (ºC)
-0.01
-0.02
-0.02
5
15
25
35
45
55
65
75
7
PDS-002831 Rev 04
85
95
105
5
15
25
35
45
55
65
75
85
95
105
Preliminary
Typical Spectrum
120.00%
100.00%
Relative Intensity
80.00%
Warm White
60.00%
Neutral White
Cool White
40.00%
3000K-90CRI
3000K-97CRI
20.00%
0.00%
400
450
500
-20.00%
550
600
650
700
750
800
Wavelength (nm)
Typical Polar Radiation Pattern
Typical Angular Radiation Pattern
120%
100%
Relative Intensity (%)
80%
60%
40%
20%
0%
-80
-60
-40
-20
Anglular Displacement (Degrees)
8
PDS-002831 Rev 04
40
60
80
Preliminary
Shipping Container
100 pcs per box
Each bag is boxed for
easier storage/ stacking
20 pcs per tray
5 trays are stacked together
with separate cover
Trays are sealed in
an anti-static bag
Label
Luminus Label Model:
(Manufacturer Part Number & Bin Kits)
Bar code
XXX-XX-XX-XX-XX-XXXX-XX-X
XXXXXXXXXXXXXX
Bar code
9
PDS-002831 Rev 04
(Box ID)
Rev XX
Bar code
(Customer Part Number)
Qty: XX
Bar code
RoHS Compliant
Luminus Devices Inc
XXXXXX-XX-XX
CXM-22
Product
Datasheet
(Part
#) Product
Datasheet
Preliminary
Handling Notes for Luminus COBs
Luminus products are designed for robust performance in general lighting application. However, care must be taken when handling and
assembling the LEDs into their fixtures. To avoid damaging Luminus COBs please follow these guide lines.
The following is an overview of the application notes detailing some of the practices to follow when working with these devices. More
detailed information is available on the Luminus web site at www.luminus.com.
General Handling
Electrical Contact
Devices are made to be lifted or carried with tweezers on two
adjacent corners opposite the contact pads. At no time should
the devices be handled by or should anything come in contact
with the light emitting surface (LES) area. This area includes the
yellow colored circular area and the ring surrounding it. There
are electrical connections under the LES which if damaged will
cause the device to fail.
Luminus COBs are designed with contact pads on their top
surface. These pads are clearly marked with + and – polarity.
Wires can be soldered to the contact pads for electrical
connections or other solderless connector products are
available.
In addition, the ring frame itself should not be used for moving,
lifting or carrying the device. Also do not attach any optics or
mechanical holders to the ring as it is not capable to handle the
mechanical stress.
If wires are being soldered to the COB product, we recommend
attaching these wires prior to mounting the devices to a heat
sink. Please contact Luminus for specific recommendations on
how to solder wires if not familiar with the standard practice.
Luminus can also offer design recommendations for jigs to
allow easily soldering multiple products in rapid succession.
Static Electricity
Chemical Compatibility
Luminus COBs are electronic devices which can be damaged by
electrostatic discharge (ESD). Please use appropriate measures
to assure the devices do not experience ESD during their
handling and or storage. ESD protection guidelines should be
used at all times when working with XNova COBs.
The resin material used to form the LES can getter hydrocarbons
from the surrounding environment. As a results, certain
chemical compounds are not recommended for use with the
Luminus products. Use of these compounds can cause damage
to the light output of the device and may permanently damage
the device. Please refer to www.luminus.com for a list of the
compounds not recommended for use with the XNova COB
products.
Storage: Luminus products are delivered in ESD shielded bags
and should be stored in these bags until used.
Assembly: Individuals handling Luminus COBs during assembly
should be trained in ESD protection practices. Assemblers
should maintain constant conductive contact with a path to
ground by means of a wrist strap, ankle straps, mat or other ESD
protection system.
Transporting: When transporting the devices from one
assembly area to another, ESD shielded carts and carriers should
be used.
10
PDS-002831 Rev 04
Thermal Interface Material (TIM)
Proper thermal management is critical for successful operation
of any LED system. Excess operating temperature can reduce
the light output of the device. And excessive heating can cause
permanent damage to the device. Proper TIM material is a
crucial component for effective heat transfer away from the LED
during normal operation. Please refer to www.luminus.com for
specific recommendations for TIM solutions.
