CXB3050-0000-000N0HY240H 数据手册
PRODUCT FAMILY DATA SHEET
XLamp® CXB3050 LED
PRODUCT DESCRIPTION
FEATURES
TABLE OF CONTENTS
The XLamp® CXB3050 LED Array is a
• 23‑mm optical source
Characteristics................................................ 2
member of the second generation of the • Mechanical and optical design
Operating Limits.............................................. 2
CXA family that delivers up to 30% higher
consistent with other CXA30 and
Flux Characteristics, EasyWhite® Order
efficacy and up to 20% higher lumens than
CXB30 LEDs
Codes and Bins............................................... 3
the first generation in the same LES. The • Available in 70-, 80- and 90-minimum
Relative Spectral Power Distribution............. 6
higher performance second generation
Electrical Characteristics................................ 6
CXA
LED
Arrays
provide
a
CRI options
drop-in • EasyWhite 2-, 3‑ and 5-step binning
Relative Luminous Flux................................... 7
performance upgrade to existing CXA LED • Forward voltage option: 36‑V class
Typical Spatial Distribution............................. 8
designs to shorten product development • 85 °C binning and characterization
Performance Groups - Brightness................. 8
time. In addition, the CXB LEDs also • Extremely uniform color over viewing
Performance Groups - Chromaticity.............. 9
allow lighting manufacturers to achieve
EasyWhite® Bins Plotted on the 1931 CIE
the same or better performance with a
angle
• Top-side solder connections
Color Space................................................... 10
smaller LES, enabling a smaller, more • Thermocouple attach point
Bin and Order Code Formats........................ 11
impactful luminaire. Available in 2‑step, • NEMA SSL-3 2011 standard flux bins
Mechanical Dimensions............................... 11
3‑step and 5‑step EasyWhite
Thermal Design............................................. 12
bins, the • RoHS and REACh compliant
CXB3050 LED delivers high lumen output
and high efficacy in a single, easy‑to‑use
• UL recognized component (E349212)
Notes............................................................. 13
Packaging...................................................... 14
package that eliminates the need for reflow
soldering.
The CX Family LED Design Guide provides
basic information on the requirements
to use the CXB3050 LED successfully in
luminaire designs.
Cree LED / 4400 Silicon Drive / Durham, NC 27703 USA / +1.919.313.5330 / www.cree-led.com
© 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and
the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered
trademarks of UL LLC.
CLD-DS124
REV 8A
1
XLAMP ® CXB3050 LED
CHARACTERISTICS
Characteristics
Unit
Viewing angle (FWHM)
Minimum
Typical
degrees
ESD withstand voltage (HBM per Mil-Std-883D)
Maximum
115
V
8000
DC forward current
mA
2500*
Reverse current
mA
0.1
Forward voltage (@ 1400 mA, Tj = 85 °C)
V
34
38
Refer to the Operating Limits section.
OPERATING LIMITS
The maximum current rating of the CXB3050 depends on the case temperature (Tc) when the LED has reached thermal equilibrium under
steady-state operation. The graph shown below assumes that the system design employs good thermal management (thermal interface
material and heat sink) and may vary when poor thermal management is employed. Please refer to the Mechanical Dimensions section
on page 11 for the location of the Tc measurement point.
Another important factor in good thermal management is the temperature of the Light Emitting Surface (LES). Cree LED recommends a
maximum LES temperature of 135 °C to ensure optimal LED lifetime. Please refer to the Thermal Design section on page 12 for more
information on LES temperature measurement.
CXB3050 - Standard
2750
85 °C, 2500 mA
2500
2250
2000
If (mA)
1750
1500
1250
125 °C,
962 mA
1000
750
500
250
50
75
100
125
150
Case Temperature (°C)
CLD-DS124
REV 8A
2
XLAMP ® CXB3050 LED
FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS (IF = 1400 mA, TJ = 85 °C)
The following table provides order codes for XLamp CXB3050 LEDs. For a complete description of the order code nomenclature, please
see the Bin and Order Code Formats section (page 11).
CRI*
Nominal
CCT
Min
70
Minimum Luminous Flux
Typ
2-Step
3-Step
5-Step
Group
Flux (lm)
@ 85 °C
Flux
(lm) @
25 °C**
Y4
6910
7648
Z2
7390
8179
Z4
7945
8793
CXB3050-0000000N0BZ465E
Y2
6430
7116
CXB3050-0000000N0HY265E
Y4
6910
7648
Z2
7390
8179
CXB3050-0000000N0HZ265E
Y4
6910
7648
CXB3050-0000000N0BY457E
Z2
7390
8179
Z4
7945
8793
CXB3050-0000000N0BZ457E
Y2
6430
7116
CXB3050-0000000N0HY257E
Y4
6910
7648
Z2
7390
8179
Group
Order Code
Group
Order Code
Group
CXB3050-0000000N0BY465E
65E
6500 K
80
70
65E
57E
5700 K
80
Order Code
57E
CXB3050-0000000N0BZ265E
CXB3050-0000000N0HY465E
CXB3050-0000000N0BZ257E
CXB3050-0000000N0HY457E
CXB3050-0000000N0HZ257E
Notes
Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on
CRI measurements. See the Measurements section (page 13).
CXB3050 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum
specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code.
For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60.
** Flux values @ 25 °C are calculated and for reference only.
CLD-DS124
REV 8A
3
XLAMP ® CXB3050 LED
FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS (IF = 1400 mA, TJ = 85 °C) - CONTINUED
CRI*
Nominal
CCT
Min
70
5000 K
80
90
70
4000 K
80
90
Typ
92
92
2-Step
3-Step
Group
Flux (lm)
@ 85 °C
Flux
(lm) @
25 °C**
Y4
6910
7648
Z2
7390
8179
Z4
7945
8793
Y2
6430
7116
Y4
6910
7648
Z2
7390
8179
CXB3050-0000000N0HZ250G
X4
6010
6652
CXB3050-0000000N0UX450G
Y2
6430
7116
Y4
6910
7648
Y4
6910
7648
Z2
7390
8179
Z4
7945
8793
Y2
6430
7116
Y4
6910
7648
Z2
7390
8179
CXB3050-0000000N0HZ240H
CXB3050-0000000N0HZ240G
X2
5590
6187
CXB3050-0000000N0UX240H
CXB3050-0000000N0UX240G
X4
6010
6652
Y2
6430
7116
Group
Order Code
Group
Order Code
5-Step
Group
Order Code
CXB3050-0000000N0BY450E
50E
CXB3050-0000000N0BZ250E
CXB3050-0000000N0BZ450E
CXB3050-0000000N0HY250G
50G
50G
CXB3050-0000000N0HY450G
CXB3050-0000000N0HY250E
50E
CXB3050-0000000N0HY450E
CXB3050-0000000N0UY250G
CXB3050-0000000N0UY450G
CXB3050-0000000N0BY440E
40E
CXB3050-0000000N0BZ240E
CXB3050-0000000N0BZ440E
CXB3050-0000000N0HY240H
40H
40H
CXB3050-0000000N0HY440H
CXB3050-0000000N0UX440H
CXB3050-0000000N0UY240H
CXB3050-0000000N0HY240G
40G
40G
CXB3050-0000000N0HY440G
CXB3050-0000000N0UX440G
CXB3050-0000000N0UY240G
Notes
CLD-DS124
REV 8A
4
XLAMP ® CXB3050 LED
CRI*
Nominal
CCT
Min
80
Typ
90
80
92
Flux (lm)
@ 85 °C
Flux
(lm) @
25 °C**
Y2
6430
7116
Y4
6910
7648
CXB3050-0000000N0HY435H
X2
5590
6187
CXB3050-0000000N0UX235H
X4
6010
6652
Y2
6430
7116
CXB3050-0000000N0UY235H
CXB3050-0000000N0UY235G
X4
6010
6652
CXB3050-0000000N0HX430H
CXB3050-0000000N0HX430G
Y2
6430
7116
Y4
6910
7648
CXB3050-0000000N0HY430H
CXB3050-0000000N0HY430G
W4
5225
5783
CXB3050-0000000N0UW430H
CXB3050-0000000N0UW430G
X2
5590
6187
X4
6010
6652
CXB3050-0000000N0UX430H
CXB3050-0000000N0UX430G
X4
6010
6652
CXB3050-0000000N0HX427H
CXB3050-0000000N0HX427G
Y2
6430
7116
CXB3050-0000000N0HY227H
W2
4860
5379
CXB3050-0000000N0UW227H
W4
5225
5783
X2
5590
6187
X2
5590
6187
Group
35H
35H
30H
3000 K
90
80
92
2700 K
90
2200 K
80
92
3-Step
Group
3500 K
2-Step
30H
27H
27H
Order Code
CXB3050-0000000N0HY235H
CXB3050-0000000N0UX435H
CXB3050-0000000N0HY230H
CXB3050-0000000N0UX230H
CXB3050-0000000N0UW427H
Group
35G
Order Code
5-Step
Group
Order Code
CXB3050-0000000N0HY235G
CXB3050-0000000N0HY435G
CXB3050-0000000N0UX235G
35G
30G
30G
27G
CXB3050-0000000N0UX435G
CXB3050-0000000N0HY230G
CXB3050-0000000N0UX230G
CXB3050-0000000N0HY227G
CXB3050-0000000N0UW227G
27G
CXB3050-0000000N0UX227H
CXB3050-0000000N0UW427G
CXB3050-0000000N0UX227G
22G
CXB3050-0000000N0HX222G
Notes
CLD-DS124
REV 8A
5
XLAMP ® CXB3050 LED
RELATIVE SPECTRAL POWER DISTRIBUTION
The following graph is the result of a series of pulsed measurements at 1400 mA and TJ = 85 °C.
100%
90%
80%
70%
5000 K, 70 CRI
60%
4000 K, 70 CRI
50%
3000 K, 80 CRI
40%
3000 K, 90 CRI
30%
2200 K, 80 CRI
20%
10%
0%
380
430
480
530
580
630
680
730
780
Wavelength (nm)
ELECTRICAL CHARACTERISTICS
The following graph is the result of a series of steady-state measurements.
37
Voltage (V)
36
Tc = 25 °C
35
Tc = 55 °C
Tc = 85 °C
34
Tc = 105 °C
33
32
800
1000
1200
1400
1600
1800
2000
2200
2400
2600
Current (mA)
CLD-DS124
REV 8A
6
XLAMP ® CXB3050 LED
RELATIVE LUMINOUS FLUX
The relative luminous flux values provided below are the ratio of:
• Measurements of CXB3050 at steady-state operation at the given conditions, divided by
• Flux measured during binning, which is a pulsed measurement at 1400 mA at TJ = 85 °C.
For example, at steady-state operation of Tc = 25 °C, IF = 1600 mA, the relative luminous flux ratio is 120% in the chart below. A CXB3050
LED that measures 6010 lm during binning will deliver 7212 lm (6010 * 1.2) at steady-state operation of Tc = 25 °C, IF = 1600 mA.
180%
160%
140%
120%
Tc = 25 °C
100%
Tc = 55 °C
80%
Tc = 85 °C
Tc = 105 °C
60%
40%
20%
0%
800
1000
1200
1400
1600
1800
2000
2200
2400
2600
Current (mA)
CLD-DS124
REV 8A
7
XLAMP ® CXB3050 LED
Far Field
TYPICAL SPATIAL DISTRIBUTION
100%
Relative Luminous Intensity
80%
60%
40%
20%
-90
-70
-50
-30
-10
0%
10
30
50
70
90
Angle (º)
PERFORMANCE GROUPS - BRIGHTNESS (I F = 1400 mA, TJ = 85 °C)
XLamp CXB3050 LEDs are tested for luminous flux and placed into one of the following bins.
Group Code
Maximum Luminous Flux
W2
4860
5225
W4
5225
5590
X2
5590
6010
X4
6010
6430
Y2
6430
6910
Y4
6910
7390
Z2
7390
7945
Z4
7945
8500
AB
8500
9000
CLD-DS124
REV 8A
8
XLAMP ® CXB3050 LED
PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C)
XLamp CXB3050 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates.
EasyWhite Color Temperatures – 2-Step
Code
40H
35H
30H
27H
CCT
4000 K
3500 K
3000 K
2700 K
x
y
0.3777
0.3739
0.3797
0.3816
0.3861
0.3855
0.3838
0.3777
0.4022
0.3858
0.4053
0.3942
0.4125
0.3977
0.4091
0.3891
0.4287
0.3975
0.4328
0.4064
0.4390
0.4086
0.4347
0.3996
0.4524
0.4048
0.4574
0.4140
0.4633
0.4154
0.4581
0.4062
EasyWhite Color Temperatures – 3-Step Ellipse
Bin Code
CCT
50G
40G
Center Point
Major Axis
Minor Axis
Rotation Angle
x
y
a
b
5000 K
0.3447
0.3553
0.00840
0.00312
65.0
4000 K
0.3818
0.3797
0.00939
0.00402
53.7
35G
3500 K
0.4073
0.3917
0.00927
0.00414
54.0
30G
3000 K
0.4338
0.4030
0.00834
0.00408
53.2
27G
2700 K
0.4577
0.4099
0.00834
0.00420
48.5
22G
2200 K
0.5066
0.4158
0.00980
0.00480
45.5
EasyWhite Color Temperatures – 5-Step Ellipse
Bin Code
CCT
65E
Center Point
Major Axis
Minor Axis
Rotation Angle
x
y
a
b
6500 K
0.3123
0.3282
0.01110
0.00550
61.0
57E
5700 K
0.3287
0.3417
0.01230
0.00600
72.0
50E
5000 K
0.3447
0.3553
0.01400
0.00520
65.0
40E
4000 K
0.3818
0.3797
0.01565
0.00670
53.7
CLD-DS124
REV 8A
9
XLAMP ® CXB3050 LED
EASYWHITE® BINS PLOTTED ON THE 1931 CIE COLOR SPACE
0.45
ANSI C78.377 Quadrangle
0.44
2700 K
EasyWhite 5-step
0.43
2200 K
2450 K
3000 K
EasyWhite 3-step
0.42
EasyWhite 2-step
3500 K
0.41
4000 K
0.40
CCy
0.39
5000 K
4500 K
5700 K
0.38
0.37
6500 K
0.36
0.35
7000K
0.34
0.33
0.32
0.54
0.53
0.52
0.51
0.50
0.49
0.48
0.47
0.46
0.45
0.44
0.43
0.42
0.41
0.40
0.39
0.38
0.37
0.36
0.35
0.34
0.33
0.32
0.31
0.30
0.29
0.31
CCx
CLD-DS124
REV 8A
10
XLAMP ® CXB3050 LED
BIN AND ORDER CODE FORMATS
Bin codes and order codes are configured as follows:
Order Code
Bin Code
Series = CXB30
Series = CXB30
Internal code
Chromaticity bin
CRI Specification
B = 70 CRI minimum
H = 80 CRI minimum
U = 90 CRI minimum
SSSSSCC-HHHH-HHHGGRNNNNN
Vf class
N0 = 36-V class
Internal code
SSSSSCC-WWW-FF-GGR-AAAAA
CRI Specification
B = 70 CRI minimum
H = 80 CRI minimum
U = 90 CRI minimum
Kit code
Vf class
N0 = 36-V class
Flux bin
Performance class
Performance class
MECHANICAL DIMENSIONS
Dimensions are in mm.
Tolerances unless otherwise
specified: ±.13
x° ±1°
B3050N = 36‑V CXB3050
B3050N
Meaning of B3050N
CLD-DS124
REV 8A
11
XLAMP ® CXB3050 LED
THERMAL DESIGN
The CXB family of LED arrays can include over a hundred different LED die inside one package, and thus over a hundred different junction
temperatures (TJ). Cree LED has intentionally removed junction-temperature-based operating limits and replaced the commonplace
maximum TJ calculations with maximum ratings based on forward current (IF) and case temperature (Tc). No additional calculations
are required to ensure that the CXB LED is being operated within its designed limits. LES temperature measurement provides additional
verification of good thermal design. Please refer to page 2 for the Operating Limit specifications.
There is no need to calculate for TJ inside the package, as the thermal management design process, specifically from TSP to ambient
(Ta), remains identical to any other LED component. For more information on thermal management of Cree LED XLamp LEDs, please
refer to the Thermal Management application note. For CXB soldering recommendations and more information on thermal interface
materials (TIM), LES temperature measurement, and connection methods, please refer to the XLamp CX Family LEDs soldering and
handling document. The CX Family LED Design Guide provides basic information on the requirements to use Cree LED XLamp CXB LEDs
successfully in luminaire designs.
To keep the CXB3050 LED at or below the maximum rated Tc, the case to ambient temperature
thermal resistance (R_c-a) must be at or below the maximum R_c-a value shown on the following
graph, depending on the operating environment. The y‑axis in the graph is a base 10 logarithmic
scale.
As the figure at right shows, the R_c-a value is the sum of the thermal resistance of the TIM (R_tim)
R_j-c
R_j-c
Tc
Tc
R_tim
R_c-a
plus the thermal resistance of the heat sink (R_hs).
R_hs
CXB3050
Ta
Ta
Maximum R_c-a
10.00
1.00
Ta = 25 °C
Ta = 55 °C
Ta = 85 °C
Ta = 105 °C
0.10
0.01
400
700
1000
1300
1600
1900
2200
2500
Current (mA)
CLD-DS124
REV 8A
12
XLAMP ® CXB3050 LED
NOTES
Measurements
The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only
and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number
of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated
values are provided for informational purposes only and are not intended or provided as specifications.
Pre‑Release Qualification Testing
Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp
LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs.
Lumen Maintenance
Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen
maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document.
Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and
forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive
current affect the LED junction temperature.
RoHS Compliance
The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold
limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as
implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product
Ecology section of the Cree LED website.
REACh Compliance
REACh substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA)
has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative
to insure you get the most up-to-date REACh Declaration. REACh banned substance information (REACh Article 67) is also available upon
request.
UL® Recognized Component
This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED
package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750.
Vision Advisory
WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please
refer to the LED Eye Safety application note.
CLD-DS124
REV 8A
13
XLAMP ® CXB3050 LED
PACKAGING
CXB3050 LEDs are packaged in trays of 20. Five trays are sealed in an anti-static bag and placed inside a carton, for a total of 100 LEDs
per carton. Each carton contains 100 LEDs from the same performance bin.
6
5
4
3
2
Tolerances: +.13
5
7.53
6
1
Dimensions are in inches.
NOTICE
NTIAL. THIS PLOT AND THE INFORMATION
THIN ARE THE PROPRIETARY AND
INFORMATION OF CREE, INC. THIS PLOT
OPIED, REPRODUCED OR DISCLOSED TO ANY
4
3
5
R .375
4
x° +1°
2
3
1
2
1
OTICE
HE PROPRIETARY AND
NSENT
7.53
R .375
5.875
R .375
D
1.313
8.15
.875
1.313
8.15
C
.38
LABEL WITH CREE BIN
CODE, QUANTITY, LOT#
BAG
1.313
PATENT LABELIS LOCATED
ON UNDERSIDE OF CARTON
.38
PATENT
IS LOCATED
LABEL WITH
CREELABEL
BIN
ON UNDERSIDE
OF 1.313
CARTON
CODE, QUANTITY,
LOT#
BAG
LABEL WITH
CREE BIN
BAG
.38
TH CREE BIN
.875
ANTITY, LOT #
B
L IS LOCATED
IDE OF COVER
LABEL WITH CREE BIN
UNLESS OTHERWISE SPECIFIED
LABEL WITH CREE BIN
DIMENSIONS ARE IN
MILLIMETERS
CODE, QUANTITY, LOT
# & BEFORE FINISH.
TOLERANCE UNLESS SPECIFIED:
LABEL WITH CREE BIN
LABEL
WITH CREE BIN
CODE, QUANTITY, LOT #
.X
.XX
.XXX ±
X°
THIRD ANGLE PROJECTION
6
LABEL WITH CREE BIN
FOR SHEET METAL PARTS ONLY
.X
.06
DRAWN BY
.XX
.03
.010
DIMENSIONS ARE IN.XXX ±
X°
2CHECK
MILLIMETERS & BEFORE FINISH.
5
4
.X
.XX
.XXX ±
X°
0.1
.05
.005
1 °
.X
.06
.XX
.03
.XXX ±
.010
X°
2 °
5
4
DATE
CHECK
DATE
APPROVED
DATE
3
DIMENSIONS ARE IN
X°
Phone (919) 361-47
Fax (919) 313-5303
CXA30XX_DATASHEET
MATERIAL
SIZE
C
DATE FINISH
FINAL PROTECTIVE
SCALE
DATE
DRAWING NO.
CXA30XX_DATASHEET_BAG_2013
0.500
2
APPROVED
4600 Silicon Drive
SHEET
Durham, N.C 27703
OF
Phone (919) 361-4770
Fax (919) 313-5303
1
A
DATE
TITLE
CXA30XX_DATASHEET
MATERIAL
SIZE
FINAL PROTECTIVE FINISH
DATE
DRAWN BY
SCALE
SHEET
0.500
1
DATE
A
OF
1 /1
4600 Silicon Drive
Durham, N.C 27703
DATE
TITLE
CLD-DS124
REV 8A
14
Fax (919) 313-5303
CXA15XX_DATASHEET
1 °
SIZE
REV.
DRAWING NO.
C
2
CHECK
and
APPROVED
.X
± trademarks,
0.1
.XXUL logo
.05
are registered
.XXX ± .005
MATERIAL
.X
.06
4600 Silicon Drive
Durham, N.C 27703
TITLE
3TOLERANCE UNLESS SPECIFIED:
WITH
CREE BIN
6
QUANTITY, LOT #
0.1
.05
.005
1 °
DRAWN BY
DRAWING NO.
CXA15XX_DATASHEET_BAG2013
