PRODUCT FAMILY DATA SHEET
XLamp® CXA3050 LED
PRODUCT DESCRIPTION
FEATURES
TABLE OF CONTENTS
The XLamp® CXA3050 LED array expands • Available in 4-step, 3‑step and 2-step
Characteristics................................................ 2
Cree LED’s family of high‑flux, multi‑die
EasyWhite bins at 2700 K, 3000 K,
Operating Limits.............................................. 2
integrated arrays, offering high performance
3500 K, 4000 K & 5000 K CCT and
Flux Characteristics, EasyWhite® Order
in an easy-to-use platform. With XLamp
4-step EasyWhite bins at 5700 K &
Codes and Bins............................................... 3
LED lighting‑class reliability, the CXA3050’s
6500 K CCT
Flux Characteristics, ANSI White Order
uniform emitting surface enables both • Available in ANSI white bins at 4000 K,
Codes and Bins............................................... 6
directional and non‑directional lighting
Relative Spectral Power Distribution............. 7
5000 K, 5700 K & 6500 K CCT
applications and luminaire and lamp
• Available in 70-, 80-, 90- and
Electrical Characteristics................................ 7
designs. Available in 2‑step, 3‑step and
93‑minimum CRI options
Relative Luminous Flux................................... 8
4‑step color consistency, and featuring a • Forward voltage option: 36‑V class
Typical Spatial Distribution............................. 9
23‑mm optical source, the CXA3050 brings • 85 °C binning and characterization
Performance Groups - Brightness................. 9
new levels of flux and efficacy to this form
• Maximum drive current: 2500 mA
Performance Groups - Chromaticity............ 10
factor.
• 115° viewing angle, uniform
EasyWhite® Bins Plotted on the 1931 CIE
chromaticity profile
Color Space................................................... 13
The CX Family LED Design Guide provides • Top-side solder connections
ANSI White Bins Plotted on the 1931 CIE
basic information on the requirements • Thermocouple attach point
to use the CXA3050 LED successfully in • NEMA SSL-3 2011 standard flux bins
Bin and Order Code Formats........................ 14
luminaire designs.
• RoHS and REACh compliant
Mechanical Dimensions............................... 14
• UL recognized component (E349212)
Thermal Design............................................. 15
Notes............................................................. 16
Packaging...................................................... 17
Cree LED / 4400 Silicon Drive / Durham, NC 27703 USA / +1.919.313.5330 / www.cree-led.com
© 2012-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and
the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered
trademarks of UL LLC.
CLD-DS68
REV 10A
1
XLAMP ® CXA3050 LED
CHARACTERISTICS
Characteristics
Unit
Viewing angle (FWHM)
Minimum
Typical
degrees
ESD withstand voltage (HBM per Mil-Std-883D)
Maximum
115
V
8000
DC forward current
mA
2500*
Reverse current
mA
0.1
Forward voltage (@ 1400 mA, Tj = 85 °C)
V
Forward voltage (@ 1400 mA, Tj = 25 °C)
V
36
42
Refer to the Operating Limits section.
OPERATING LIMITS
The maximum current rating of the CXA3050 depends on the case temperature (Tc) when the LED has reached thermal equilibrium under
steady-state operation. The graph shown below assumes that the system design employs good thermal management (thermal interface
material and heat sink) and may vary when poor thermal management is employed. Please refer to the Mechanical Dimensions section
on page 14 for the location of the Tc measurement point.
Another important factor in good thermal management is the temperature of the Light Emitting Surface (LES). Cree LED recommends a
maximum LES temperature of 135 °C to ensure optimal LED lifetime. Please refer to the Thermal Design section on page 15 for more
information on LES temperature measurement.
CXA3050
2750
2500
2250
2000
If (mA)
1750
1500
1250
1000
750
500
250
50
75
100
125
150
Case Temperature (°C)
CLD-DS68
REV 10A
2
XLAMP ® CXA3050 LED
FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS (IF = 1400 mA, TJ = 85 °C)
The following table provides order codes for XLamp CXA3050 LEDs. For a complete description of the order code nomenclature, please
see the Bin and Order Code Formats section (page 14).
Nominal
CCT
CRI
Min
70
Minimum Luminous Flux
Typ
75
2-Step
3-Step
4-Step
Group
Flux (lm)
@ 85 °C
Flux (lm)
@ 25 °C*
X4
6010
6773
Y2
6430
7246
Y4
6910
7485
CXA3050-0000000N00Y465F
X2
5590
6299
CXA3050-0000000N0HX265F
X4
6010
6773
Y2
6430
7246
CXA3050-0000000N0HY265F
X4
6010
6773
CXA3050-0000000N00X457F
Y2
6430
7246
Y4
6910
7485
CXA3050-0000000N00Y457F
X2
5590
6299
CXA3050-0000000N0HX257F
X4
6010
6773
Y2
6430
7246
X4
6010
6773
Y2
6430
7246
Y4
6910
7485
CXA3050-0000000N00Y450H
CXA3050-0000000N00Y450F
X2
5590
6299
CXA3050-0000000N0HX250H
CXA3050-0000000N0HX250F
X4
6010
6773
Y2
6430
7246
CXA3050-0000000N0HY250H
W2
4860
5477
CXA3050-0000000N0UW250H
W4
5225
5888
X2
5590
6299
Group
Order Code
Group
Order Code
Group
CXA3050-0000000N00X465F
65F
6500 K
80
70
75
65F
57F
5700 K
80
70
5000 K
80
90
75
95
Order Code
57F
CXA3050-0000000N00Y265F
CXA3050-0000000N0HX465F
CXA3050-0000000N00Y257F
CXA3050-0000000N0HX457F
CXA3050-0000000N0HY257F
CXA3050-0000000N00X450H
50H
50H
50H
CXA3050-0000000N00X450F
CXA3050-0000000N00Y250H
CXA3050-0000000N0HX450H
CXA3050-0000000N0UW450H
CXA3050-0000000N0UX250H
50F
50G
CXA3050-0000000N0HX450G
50F
CXA3050-0000000N0HY250G
CXA3050-0000000N00Y250F
CXA3050-0000000N0HX450F
CXA3050-0000000N0HY250F
CXA3050-0000000N0UW250F
50G
CXA3050-0000000N0UW450G
CXA3050-0000000N0UX250G
50F
CXA3050-0000000N0UW450F
CXA3050-0000000N0UX250F
Notes
Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on
CRI measurements. See the Measurements section (page 16).
CXA3050 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum
specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code.
Flux values @ 25 °C are calculated and for reference only.
CLD-DS68
REV 10A
3
XLAMP ® CXA3050 LED
FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS (IF = 1400 mA, TJ = 85 °C) - CONTINUED
Nominal
CCT
CRI
Min
70
4000 K
80
90
80
Typ
75
95
2-Step
80
95
Flux (lm)
@ 85 °C
Flux (lm)
@ 25 °C*
X4
6010
6773
Y2
6430
7246
Y4
6910
7485
CXA3050-0000000N00Y440H
CXA3050-0000000N00Y440F
X2
5590
6299
CXA3050-0000000N0HX240H
CXA3050-0000000N0HX240F
X4
6010
6773
Y2
6430
7246
CXA3050-0000000N0HY240H
V4
4545
5122
CXA3050-0000000N0UV440H
W2
4860
5477
W4
5225
5888
CXA3050-0000000N0UW440H
X2
5590
6299
CXA3050-0000000N00X235H
X4
6010
6773
Y2
6430
7246
CXA3050-0000000N00Y235H
CXA3050-0000000N00Y235G
CXA3050-0000000N00Y235F
V2
4230
4767
CXA3050-0000000N0YV235H
CXA3050-0000000N0YV235G
CXA3050-0000000N0YV235F
V4
4545
5122
W2
4860
5477
CXA3050-0000000N0YW235H
W4
5225
5888
CXA3050-0000000N00W430H
X2
5590
6299
X4
6010
6773
CXA3050-0000000N00X430H
CXA3050-0000000N00X430G
CXA3050-0000000N00X430F
U4
3955
4469
CXA3050-0000000N0YU430H
CXA3050-0000000N0YU430G
CXA3050-0000000N0YU430F
V2
4230
4767
V4
4545
5122
Group
95
Order Code
Group
Order Code
Group
CXA3050-0000000N00X440H
40H
40H
40H
35H
35H
30H
3000 K
93
4-Step
Group
3500 K
93
3-Step
30H
CXA3050-0000000N00X440F
CXA3050-0000000N00Y240H
CXA3050-0000000N0HX440H
CXA3050-0000000N0UW240H
CXA3050-0000000N00X435H
CXA3050-0000000N0YV435H
CXA3050-0000000N00X230H
CXA3050-0000000N0YV230H
CXA3050-0000000N0YV430H
Order Code
40F
40G
CXA3050-0000000N0HX440G
40F
CXA3050-0000000N0HY240G
CXA3050-0000000N00Y240F
CXA3050-0000000N0HX440F
CXA3050-0000000N0HY240F
CXA3050-0000000N0UV440F
40G
CXA3050-0000000N0UW240G
40F
CXA3050-0000000N0UW440G
CXA3050-0000000N0UW240F
CXA3050-0000000N0UW440F
CXA3050-0000000N00X235F
35G
35G
CXA3050-0000000N00X435G
CXA3050-0000000N0YV435G
35F
35F
CXA3050-0000000N0YW235G
CXA3050-0000000N00X435F
CXA3050-0000000N0YV435F
CXA3050-0000000N0YW235F
CXA3050-0000000N00W430F
30G
30G
CXA3050-0000000N00X230G
CXA3050-0000000N0YV230G
CXA3050-0000000N0YV430G
30F
30F
CXA3050-0000000N00X230F
CXA3050-0000000N0YV230F
CXA3050-0000000N0YV430F
Notes
CLD-DS68
REV 10A
4
XLAMP ® CXA3050 LED
Nominal
CCT
CRI
Min
80
Typ
2-Step
95
4-Step
Group
Flux (lm)
@ 85 °C
Flux (lm)
@ 25 °C*
W2
4860
5477
W4
5225
5888
X2
5590
6299
CXA3050-0000000N00X227H
CXA3050-0000000N00X227G
CXA3050-0000000N00X227F
U2
3680
4158
CXA3050-0000000N0YU227H
CXA3050-0000000N0YU227G
CXA3050-0000000N0YU227F
U4
3955
4469
V2
4230
4767
Group
Order Code
Group
Order Code
Group
CXA3050-0000000N00W227H
27H
2700 K
93
3-Step
27H
CXA3050-0000000N00W427H
CXA3050-0000000N0YU427H
CXA3050-0000000N0YV227H
Order Code
CXA3050-0000000N00W227F
27G
27G
CXA3050-0000000N00W427G
CXA3050-0000000N0YU427G
CXA3050-0000000N0YV227G
27F
27F
CXA3050-0000000N00W427F
CXA3050-0000000N0YU427F
CXA3050-0000000N0YV227F
Notes
CLD-DS68
REV 10A
5
XLAMP ® CXA3050 LED
FLUX CHARACTERISTICS, ANSI WHITE ORDER CODES AND BINS (IF = 1400 mA, TJ = 85 °C)
rsee the Bin and Order Code Formats section (page 14).
Nominal
CCT
CRI
Min
70
Typ
75
6500 K
80
70
75
5700 K
80
70
75
5000 K
80
4000 K
70
75
Chromaticity Regions
Order Code
Group
Flux (lm)
@ 85 °C
Flux (lm)
@ 25 °C*
X4
6010
6773
Y2
6430
7246
Y4
6910
7485
CXA3050-0000-000N00Y40E1
X2
5590
6299
CXA3050-0000-000N0HX20E1
X4
6010
6773
Y2
6430
7246
CXA3050-0000-000N0HY20E1
X4
6010
6773
CXA3050-0000-000N00X40E2
Y2
6430
7246
Y4
6910
7485
CXA3050-0000-000N00Y40E2
X2
5590
6299
CXA3050-0000-000N0HX20E2
X4
6010
6773
Y2
6430
7246
CXA3050-0000-000N0HY20E2
X4
6010
6773
CXA3050-0000-000N00X40E3
Y2
6430
7246
Y4
6910
7485
CXA3050-0000-000N00Y40E3
X2
5590
6299
CXA3050-0000-000N0HX20E3
X4
6010
6773
CXA3050-0000-000N00X40E1
1A0, 1B0, 1C0, 1D0, 65F
2A0, 2B0, 2C0, 2D0, 57F
3A0, 3B0, 3C0, 3D0, 50F
CXA3050-0000-000N00Y20E1
CXA3050-0000-000N0HX40E1
CXA3050-0000-000N00Y20E2
CXA3050-0000-000N0HX40E2
CXA3050-0000-000N00Y20E3
CXA3050-0000-000N0HX40E3
Y2
6430
7246
CXA3050-0000-000N0HY20E3
X4
6010
6773
CXA3050-0000-000N00X40E5
Y2
6430
7246
Y4
6910
7485
5A0, 5B0, 5C0, 5D0, 40F
CXA3050-0000-000N00Y20E5
CXA3050-0000-000N00Y40E5
Notes
CLD-DS68
REV 10A
6
XLAMP ® CXA3050 LED
RELATIVE SPECTRAL POWER DISTRIBUTION
The following graph is the result of a series of pulsed measurements at 1400 mA and TJ = 85 °C.
100%
90%
80%
70%
60%
5000 K, 70 CRI
50%
4000 K, 70 CRI
40%
3000 K, 80 CRI
30%
3000 K, 93 CRI
20%
10%
0%
380
430
480
530
580
630
680
730
780
Wavelength (nm)
ELECTRICAL CHARACTERISTICS
The following graph is the result of a series of steady-state measurements.
41
40
39
Voltage (V)
38
Tc = 25 °C
37
Tc = 55 °C
36
Tc = 85 °C
35
Tc = 105 °C
34
33
32
31
400
700
1000
1300
1600
1900
2200
2500
Current (mA)
CLD-DS68
REV 10A
7
XLAMP ® CXA3050 LED
RELATIVE LUMINOUS FLUX
The relative luminous flux values provided below are the ratio of:
• Measurements of CXA3050 at steady-state operation at the given conditions, divided by
• Flux measured during binning, which is a pulsed measurement at 1400 mA at TJ = 85 °C.
For example, at steady-state operation of Tc = 25 °C, IF = 1600 mA, the relative luminous flux ratio is 120% in the chart below. A CXA3050
LED that measures 6000 lm during binning will deliver 7200 lm (6000 * 1.2) at steady-state operation of Tc = 25 °C, IF = 1600 mA.
180%
160%
140%
120%
Tc = 25 °C
100%
Tc = 55 °C
80%
Tc = 85 °C
Tc = 105 °C
60%
40%
20%
0%
400
700
1000
1300
1600
1900
2200
2500
Current (mA)
CLD-DS68
REV 10A
8
XLAMP ® CXA3050 LED
Far Field
TYPICAL SPATIAL DISTRIBUTION
Relative Luminous Intensity (%)
100%
80%
60%
40%
20%
-90
-70
-50
-30
-10
0%
10
30
50
70
90
Angle (º)
PERFORMANCE GROUPS - BRIGHTNESS (I F = 1400 mA, TJ = 85 °C)
XLamp CXA3050 LEDs are tested for luminous flux and placed into one of the following bins.
Group Code
Maximum Luminous Flux
U2
3680
3955
U4
3955
4230
V2
4230
4545
V4
4545
4860
W2
4860
5225
W4
5225
5590
X2
5590
6010
X4
6010
6430
Y2
6430
6910
Y4
6910
7390
Z2
7390
7945
CLD-DS68
REV 10A
9
XLAMP ® CXA3050 LED
PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C)
XLamp CXA3050 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates.
EasyWhite Color Temperatures – 2-Step
Code
50H
40H
35H
30H
27H
CCT
5000 K
4000 K
3500 K
3000 K
2700 K
x
y
0.3429
0.3507
0.3434
0.3571
0.3475
0.3604
0.3469
0.3539
0.3784
0.3741
0.3804
0.3818
0.3867
0.3857
0.3844
0.3778
0.4030
0.3857
0.4061
0.3941
0.4132
0.3976
0.4099
0.3890
0.4291
0.3973
0.4333
0.4062
0.4395
0.4084
0.4351
0.3994
0.4528
0.4046
0.4578
0.4138
0.4638
0.4152
0.4586
0.4060
EasyWhite Color Temperatures – 3-Step Ellipse
Bin Code
CCT
50G
40G
Center Point
Major Axis
Minor Axis
Rotation Angle
x
y
a
b
5000 K
0.3447
0.3553
0.00840
0.00312
65.0
4000 K
0.3818
0.3797
0.00939
0.00402
53.7
35G
3500 K
0.4073
0.3917
0.00927
0.00414
54.0
30G
3000 K
0.4338
0.4030
0.00834
0.00408
53.2
27G
2700 K
0.4577
0.4099
0.00834
0.00420
48.5
CLD-DS68
REV 10A
10
XLAMP ® CXA3050 LED
PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) - CONTINUED
EasyWhite Color Temperatures – 4-Step
Code
65F
57F
50F
40F
35F
30F
27F
CCT
6500 K
5700 K
5000 K
4000 K
3500 K
3000 K
2700 K
x
y
0.3097
0.3196
0.3079
0.3297
0.3164
0.3382
0.3176
0.3275
0.3253
0.3325
0.3249
0.3439
0.3331
0.3514
0.3330
0.3393
0.3407
0.3459
0.3415
0.3586
0.3499
0.3654
0.3484
0.3521
0.3744
0.3685
0.3782
0.3837
0.3912
0.3917
0.3863
0.3758
0.3981
0.3800
0.4040
0.3966
0.4186
0.4037
0.4116
0.3865
0.4242
0.3919
0.4322
0.4096
0.4449
0.4141
0.4359
0.3960
0.4475
0.3994
0.4573
0.4178
0.4695
0.4207
0.4589
0.4021
CLD-DS68
REV 10A
11
XLAMP ® CXA3050 LED
ANSI White Bins
Code
Bin
Code
CCT
1A0
1B0
0E1
6500 K
1C0
1D0
ANSI White Bins
x
y
0.3048
0.3207
0.3130
0.3290
0.3144
0.3186
0.3068
Code
x
y
0.3215
0.3350
0.3290
0.3417
0.3290
0.3300
0.3113
0.3222
0.3243
0.3028
0.3304
0.3207
0.3462
0.3115
0.3391
0.3290
0.3538
0.3130
0.3290
0.3290
0.3417
0.3048
0.3207
0.3215
0.3350
0.3115
0.3391
0.3290
0.3538
0.3205
0.3481
0.3376
0.3616
0.3213
0.3373
0.3371
0.3490
0.3130
0.3290
0.3290
0.3417
0.3130
0.3290
0.3290
0.3417
0.3213
0.3373
0.3371
0.3490
0.3221
0.3261
0.3366
0.3369
0.3144
0.3186
0.3290
0.3300
2A0
2B0
0E2
5700 K
2C0
2D0
ANSI White Bins
Code
CCT
Bin
Code
3A0
3B0
0E3
5000 K
3C0
3D0
Bin
Code
CCT
ANSI White Bins
x
y
Code
CCT
Bin
Code
x
y
.3371
.3490
.3670
.3578
.3451
.3554
.3702
.3722
.3440
.3427
.3825
.3798
.3366
.3369
.3783
.3646
.3376
.3616
.3702
.3722
.3463
.3687
.3736
.3874
.3451
.3554
.3869
.3958
.3371
.3490
.3825
.3798
.3825
.3798
.3869
.3958
.4006
.4044
5A0
5B0
0E5
4000 K
.3463
.3687
.3551
.3760
.3533
.3620
.3451
.3554
.3950
.3875
.3451
.3554
.3783
.3646
.3533
.3620
.3825
.3798
.3515
.3487
.3950
.3875
.3440
.3427
.3898
.3716
5C0
5D0
CLD-DS68
REV 10A
12
XLAMP ® CXA3050 LED
EASYWHITE® BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C)
0.44
2700 K
ANSI C78.377 Quadrangle
0.43
3000 K
EasyWhite 4-Step
EasyWhite 3-Step
0.42
EasyWhite 2-Step
3500 K
0.41
4000 K
0.40
4500 K
CCy
0.39
5000 K
0.38
0.37
5700 K
0.36
6500 K
0.35
0.34
0.33
0.32
0.49
0.48
0.47
0.45
0.41
0.46
0.44
0.40
0.43
0.42
0.41
0.40
0.39
0.38
0.37
0.36
0.35
0.34
0.33
0.32
0.31
0.30
0.31
CCx
ANSI WHITE BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C)
0.41
4000 K
0.40
4500 K
5C
0.39
5D
0.37
CCy
5B
5000 K
0.38
5700 K
0.36
5A
3C
3B
6500 K
0.35
2B
0.34
1C
1B
0.33
3D
2C
1D
3A
2D
2A
1A
0.32
0.39
0.38
0.37
0.36
0.35
0.34
0.33
0.32
0.31
0.30
0.31
CCx
CLD-DS68
REV 10A
13
XLAMP ® CXA3050 LED
BIN AND ORDER CODE FORMATS
Bin codes and order codes are configured as follows:
Order Code
Bin Code
Series = CXA30
Series = CXA30
Internal code
Chromaticity bin
CRI Specification
0 = Standard CRI
H = 80 CRI minimum
U = 90 CRI minimum
Y = 93 CRI minimum
Vf class
N0 = 36-V class
SSSSSCC-HHHH-HHHGGRNNNNN
Internal code
SSSSSCC-WWW-FF-GGR-AAAAA
Vf class
N0 = 36-V class
CRI Specification
B = 70 CRI minimum
H = 80 CRI minimum
U = 90 CRI minimum
Y = 93 CRI minimum
Performance class
Flux bin
Kit code
Performance class
MECHANICAL DIMENSIONS
Dimensions are in mm.
Tolerances unless otherwise
specified: +.13
Meaning of 3050N
3050N = 36‑V CXA3050
3050N
x° +1°
CLD-DS68
REV 10A
14
XLAMP ® CXA3050 LED
THERMAL DESIGN
The CXA family of LED arrays can include over a hundred different LED die inside one package, and thus over a hundred different junction
temperatures (TJ). Cree LED has intentionally removed junction-temperature-based operating limits and replaced the commonplace
maximum TJ calculations with maximum ratings based on forward current (IF) and case temperature (Tc). No additional calculations
are required to ensure that the CXA LED is being operated within its designed limits. LES temperature measurement provides additional
verification of good thermal design. Please refer to page 2 for the Operating Limit specifications.
There is no need to calculate for TJ inside the package, as the thermal management design process, specifically from TSP to ambient (Ta),
remains identical to any other LED component. For more information on thermal management of XLamp LEDs, please refer to the Thermal
Management application note. For CXA soldering recommendations and more information on thermal interface materials (TIM), LES
temperature measurement, and connection methods, please refer to the XLamp CX Family LEDs soldering and handling document. The
CX Family LED Design Guide provides basic information on the requirements to use XLamp CXA LEDs successfully in luminaire designs.
To keep the CXA3050 LED at or below the maximum rated Tc, the case to ambient temperature
thermal resistance (R_c-a) must be at or below the maximum R_c-a value shown on the following
R_j-c
R_j-c
scale.
Tc
Tc
As the figure at right shows, the R_c-a value is the sum of the thermal resistance of the TIM (R_tim)
R_tim
graph, depending on the operating environment. The y‑axis in the graph is a base 10 logarithmic
R_c-a
plus the thermal resistance of the heat sink (R_hs).
R_hs
CXA3050
Ta
Ta
Maximum R_c-a
10.00
1.00
Ta = 25 °C
Ta = 55 °C
Ta = 85 °C
Ta = 105 °C
0.10
0.01
400
700
1000
1300
1600
1900
2200
2500
Current (mA)
CLD-DS68
REV 10A
15
XLAMP ® CXA3050 LED
NOTES
Measurements
The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only
and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number
of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated
values are provided for informational purposes only and are not intended or provided as specifications.
Pre‑Release Qualification Testing
Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp
LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs.
Lumen Maintenance
Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen
maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document.
Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and
forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive
current affect the LED junction temperature.
RoHS Compliance
The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold
limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as
implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product
Ecology section of the Cree LED website.
REACh Compliance
REACh substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA)
has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative
to insure you get the most up-to-date REACh Declaration. REACh banned substance information (REACh Article 67) is also available upon
request.
UL® Recognized Component
This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED
package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750.
Vision Advisory
WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please
refer to the LED Eye Safety application note.
CLD-DS68
REV 10A
16
XLAMP ® CXA3050 LED
PACKAGING
CXA3050 LEDs are packaged in trays of 20. Five trays are sealed in an anti-static bag and placed inside a carton, for a total of 100 LEDs
per carton. Each carton contains 100 LEDs from the same performance bin.
6
5
4
2
Dimensions
are in inches.
3
NOTICE
NTIAL. THIS PLOT AND THE INFORMATION
THIN ARE THE PROPRIETARY AND
INFORMATION OF CREE, INC. THIS PLOT
OPIED, REPRODUCED OR DISCLOSED TO ANY
Tolerances: +.13
5
6
1
7.53
5
4
3
R .375
4
x° +1°
2
3
1
2
1
OTICE
HE PROPRIETARY AND
NSENT
7.53
R .375
5.875
R .375
D
1.313
8.15
.875
1.313
8.15
C
.38
LABEL WITH CREE BIN
CODE, QUANTITY, LOT#
BAG
1.313
PATENT LABELIS LOCATED
ON UNDERSIDE OF CARTON
.38
PATENT
IS LOCATED
LABEL WITH
CREE LABEL
BIN
ON UNDERSIDE
OF 1.313
CARTON
CODE, QUANTITY,
LOT#
BAG
BAG
LABEL WITH
CREE BIN
.38
TH CREE BIN
.875
ANTITY, LOT #
B
L IS LOCATED
IDE OF COVER
LABEL WITH CREE BIN
LABEL WITH CREE BIN
UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN
CODE, QUANTITY, LOT
# & BEFORE FINISH.
MILLIMETERS
LABEL
WITHCREE
CREE BIN
LABEL
WITH
BIN
CODE,
QUANTITY, LOT
LOT##
CODE,
QUANTITY,
.X
.XX
.XXX ±
X°
5
4
3
THIRD ANGLE PROJECTION
.X
.XX
.XXX ±
X°
0.1
.05
.005
1 °
FOR SHEET METAL PARTS ONLY
.X
.06
.XX
.03
.XXX ±
.010
X°
2 °
5
DATE
APPROVED
DATE
4600 Silicon Drive
Durham, N.C 27703
Phone (919) 361-47
4
Fax (919) 313-5303
0.1
.05
.005
1 °
TITLE
3
DIMENSIONS ARE IN
MILLIMETERS & BEFORE FINISH.
TOLERANCE UNLESS SPECIFIED:
SIZE
C
DATE
FINAL PROTECTIVE FINISH
DATE
APPROVED
DATE
SCALE
DRAWING NO.
CXA30XX_DATASHEET_BAG_2013
0.500
4600 Silicon Drive
Durham, N.C 27703
SHEET
OF
Phone (919) 361-4770
Fax (919) 313-5303
2
1
A
TITLE
CXA30XX_DATASHEET
MATERIAL
SIZE
DATE
DRAWN BY
C
SCALE
SHEET
0.500
1
DATE
A
OF
1 /1
4600 Silicon Drive
Durham, N.C 27703
DATE
TITLE
CLD-DS68
REV 10A
17
Fax (919) 313-5303
CXA15XX_DATASHEET
SIZE
REV.
DRAWING NO.
2
CHECK
and
APPROVED
.X
± trademarks,
0.1
.05 registered
the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the.XXUL logo
are
.XXX ± .005
MATERIAL
X°
1 °
.X
.06
CXA30XX_DATASHEET
MATERIAL
DRAWN BY
.X
.06
.XX
.03
DIMENSIONS ARE IN
.XXX ±
.010
CHECK
X°
2 °
LABEL WITH CREE BIN
WITH
CREE BIN
6
QUANTITY, LOT #
DATE
CHECK
6
DRAWN BY
DRAWING NO.
CXA15XX_DATASHEET_BAG2013
