CXA3070-0000-000N0UZ250G
    WOLFSPEED
    LED COB CXA3070 5000K WHT SMD
CXA3070-0000-000N0UZ250G 数据手册
PRODUCT FAMILY DATA SHEET XLamp® CXA3070 LED PRODUCT DESCRIPTION FEATURES TABLE OF CONTENTS The XLamp® CXA3070 LED array expands • Available in 4-step, 3‑step and 2-step Characteristics................................................ 2 Cree LED’s family of high‑flux, multi‑die EasyWhite bins at 2700 K, 3000 K, Operating Limits.............................................. 2 integrated arrays, offering high performance 3500 K, 4000 K & 5000 K CCT and Flux Characteristics, EasyWhite® Order in an easy-to-use platform. With XLamp 4-step EasyWhite bins at 5700 K & Codes and Bins............................................... 3 LED lighting‑class reliability, the CXA3070’s 6500 K CCT Flux Characteristics, ANSI White Order ® uniform emitting surface enables both • Available in ANSI white bins at 5000 K, Codes and Bins............................................... 6 directional and non‑directional lighting Relative Spectral Power Distribution............. 7 5700 K & 6500 K CCT applications and luminaire and lamp • Available in 70-, 80-, 90- and Electrical Characteristics................................ 7 designs. Available in 2‑step, 3‑step and 93‑minimum CRI options Relative Luminous Flux................................... 8 4‑step color consistency, and featuring a • Forward voltage option: 36‑V class Typical Spatial Distribution............................. 9 23‑mm optical source, the CXA3070 brings • 85 °C binning and characterization Performance Groups - Brightness................. 9 new levels of flux and efficacy to this form • Maximum drive current: 2800 mA Performance Groups - Chromaticity............ 10 factor. • 115° viewing angle, uniform EasyWhite® Bins Plotted on the 1931 CIE chromaticity profile Color Space................................................... 13 The CX Family LED Design Guide provides • Top-side solder connections ANSI White Bins Plotted on the 1931 CIE basic information on the requirements • Thermocouple attach point Color Space................................................... 13 to use the CXA3070 LED successfully in • NEMA SSL-3 2011 standard flux bins Bin and Order Code Formats........................ 14 luminaire designs. • RoHS and REACh compliant Mechanical Dimensions............................... 14 • UL® recognized component (E349212) Thermal Design............................................. 15 Notes............................................................. 16 Packaging...................................................... 17 Cree LED / 4400 Silicon Drive / Durham, NC 27703 USA / +1.919.313.5330 / www.cree-led.com © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS80 REV 8A 1 XLAMP ® CXA3070 LED CHARACTERISTICS Characteristics Unit Viewing angle (FWHM) Minimum Typical degrees ESD withstand voltage (HBM per Mil-Std-883D) Maximum 115 V 8000 DC forward current mA 2800* Reverse current mA 0.1 Forward voltage (@ 1900 mA, Tj = 85 °C) V Forward voltage (@ 1900 mA, Tj = 25 °C) V * ** 36.2** 41** Refer to the Operating Limits section. For CXA3070 LEDs having order codes with a CXA3070-xxxx-xxxN0xxxxxx format, the forward voltage values are as follows: Characteristics Unit Forward voltage (@ 1900 mA, Tj = 85 °C) V Forward voltage (@ 1900 mA, Tj = 25 °C) V Minimum Typical Maximum 38.5 42 OPERATING LIMITS The maximum current rating of the CXA3070 depends on the case temperature (Tc) when the LED has reached thermal equilibrium under steady-state operation. The graph shown below assumes that the system design employs good thermal management (thermal interface material and heat sink) and may vary when poor thermal management is employed. Please refer to the Mechanical Drawings section on page 14 for the location of the Tc measurement point. Another important factor in good thermal management is the temperature of the Light Emitting Surface (LES). Cree LED recommends a maximum LES temperature of 135 °C to ensure optimal LED lifetime. Please refer to the Thermal Design section on page 15 for more information on LES temperature measurement. CXA3070 3000 2800 2600 2400 2200 2000 If (mA) 1800 1600 1400 1200 1000 800 600 400 200 0 0 25 50 75 100 125 150 Case Temperature (°C) © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS80 REV 8A 2 XLAMP ® CXA3070 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS (IF = 1900 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA3070 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 14). Nominal CCT CRI Min 70 Minimum Luminous Flux Typ 70 --- --- 4-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* Z4 7,945 8,851 CXA3070-0000000NT0Z465F AB 8,500 9,469 CXA3070-0000000NT0AB65F AD 9,000 10,026 CXA3070-0000000NT0AD65F BB 9,500 10,583 CXA3070-0000000NT0BB65F Z4 7,945 8,851 CXA3070-0000000NTHZ465F AB 8,500 9,469 AD 9,000 10,026 CXA3070-0000000NTHAD65F Z4 7,945 8,851 CXA3070-0000000NTHZ457F AB 8,500 9,469 CXA3070-0000000NT0AB57F AD 9,000 10,026 CXA3070-0000000NT0AD57F BB 9,500 10,583 CXA3070-0000000NT0BB57F Z4 7,945 8,851 CXA3070-0000000NTHZ457F AB 8,500 9,469 AD 9,000 10,026 Group Order Code Group Order Code Group 65F 75 5700 K 80 3-Step 75 6500 K 80 2-Step 65F 57F 57F Order Code CXA3070-0000000NTHAB65F CXA3070-0000000NTHAB57F CXA3070-0000000NTHAD57F Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 16). • CXA3070 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS80 REV 8A 3 XLAMP ® CXA3070 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS (IF = 1900 mA, TJ = 85 °C) - CONTINUED Nominal CCT CRI Min 70 Minimum Luminous Flux Typ Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* Z4 7,945 8,851 AB 8,500 9,469 75 2-Step Group 90 70 --- 95 75 4000 K 80 90 Group Order Code 4-Step Group CXA3070-0000000NT0Z450H 50H Order Code CXA3070-0000000NT0Z450F CXA3070-0000000NT0AB50H 50F CXA3070-0000000NT0AB50F AD 9,000 10,026 CXA3070-0000000NT0AD50H BB 9,500 10,583 CXA3070-0000000NT0BB50H Z4 7,945 8,851 CXA3070-0000000NTHZ450H AB 8,500 9,469 AD 9,000 10,026 CXA3070-0000000NTHAD50H CXA3070-0000000NTHAD50G CXA3070-0000000NTHAD50F Y2 6,430 7,163 CXA3070-0000000NTUY250H CXA3070-0000000NTUY250G CXA3070-0000000NTUY250F Y4 6,910 7,698 Z2 7,390 8,233 CXA3070-0000000NTUZ250H Z2 7,390 8,233 CXA3070-0000000NT0Z240H CXA3070-0000000NT0Z240F Z4 7,945 8,851 CXA3070-0000000NT0Z440H CXA3070-0000000NT0Z440F AB 8,500 9,469 AD 9,000 10,026 CXA3070-0000000NT0AD40H CXA3070-0000000NT0AD40F BB 9,500 10,583 CXA3070-0000000NT0BB40H CXA3070-0000000NT0BB40F Z2 7,390 8,233 CXA3070-0000000NTHZ240H CXA3070-0000000NTHZ240G CXA3070-0000000NTHZ240F Z4 7,945 8,851 CXA3070-0000000NTHZ440H CXA3070-0000000NTHZ440G CXA3070-0000000NTHZ440F AB 8,500 9,469 CXA3070-0000000NTHAB40H AD 9,000 10,026 CXA3070-0000000NTHAD40H CXA3070-0000000NTHAD40G CXA3070-0000000NTHAD40F Y2 6,430 7,163 CXA3070-0000000NTUY240H CXA3070-0000000NTUY240G CXA3070-0000000NTUY240F Y4 6,910 7,698 5000 K 80 Order Code 3-Step --- 50H 50H 40H 40H 95 40H CXA3070-0000000NTHAB50H CXA3070-0000000NTUY450H CXA3070-0000000NT0BB50F CXA3070-0000000NTHZ450G 50G 50G CXA3070-0000000NTHAB50G CXA3070-0000000NTUY450G CXA3070-0000000NTHZ450F 50F 50F CXA3070-0000000NTUZ250G CXA3070-0000000NT0AB40H CXA3070-0000000NTUY440H CXA3070-0000000NT0AD50F 40G CXA3070-0000000NTHAB40G CXA3070-0000000NTUY440G CXA3070-0000000NTUY450F CXA3070-0000000NTUZ250F 40F 40G CXA3070-0000000NTHAB50F 40F 40F CXA3070-0000000NT0AB40F CXA3070-0000000NTHAB40F CXA3070-0000000NTUY440F Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 16). • CXA3070 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS80 REV 8A 4 XLAMP ® CXA3070 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS (IF = 1900 mA, TJ = 85 °C) - CONTINUED Nominal CCT CRI Min 80 Minimum Luminous Flux Typ Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* Y4 6,910 7,698 Z2 7,390 8,233 --- 2-Step Group 80 35H 80 Group CXA3070-0000000NT0Y435G 35G CXA3070-0000000NT0Z235G CXA3070-0000000NT0Y435F 35F CXA3070-0000000NT0Z235F 8,851 CXA3070-0000000NT0Z435H AB 8,500 9,469 CXA3070-0000000NT0AB35H CXA3070-0000000NT0AB35G CXA3070-0000000NT0AB35F X4 6,010 6,695 CXA3070-0000000NTYX435H CXA3070-0000000NTYX435G CXA3070-0000000NTYX435F Y2 6,430 7,163 CXA3070-0000000NTYY235H Y4 6,910 7,698 CXA3070-0000000NT0Y430H CXA3070-0000000NT0Y430G CXA3070-0000000NT0Y430F Z2 7,390 8,233 CXA3070-0000000NT0Z230H CXA3070-0000000NT0Z230G CXA3070-0000000NT0Z230F Z4 7,945 8,851 CXA3070-0000000NT0Z430H AB 8,500 9,469 CXA3070-0000000NT0AB30H X4 6,010 6,695 95 35H --- 30H 95 30H CXA3070-0000000NTYX430H Y2 6,430 7,163 CXA3070-0000000NTYY230H Y2 6,430 7,163 CXA3070-0000000NT0Y227H Y4 6,910 7,698 --- 27H CXA3070-0000000NT0Y427H 35G 30G CXA3070-0000000NT0Z435G Order Code 7,945 CXA3070-0000000NTYY235G CXA3070-0000000NT0Z430G 35F 30F CXA3070-0000000NT0AB30G 30G CXA3070-0000000NTYX430G CXA3070-0000000NTYY230G CXA3070-0000000NT0Y427G CXA3070-0000000NT0Z430F 30F CXA3070-0000000NTYX430F CXA3070-0000000NTYY230F CXA3070-0000000NT0Y227F 27F CXA3070-0000000NT0Y427F 7,390 8,233 CXA3070-0000000NT0Z227H Z4 7,945 8,851 CXA3070-0000000NT0Z427H CXA3070-0000000NT0Z427G CXA3070-0000000NT0Z427F X2 5,590 6,227 CXA3070-0000000NTYX227H CXA3070-0000000NTYX227G CXA3070-0000000NTYX227F X4 6,010 6,695 95 27H CXA3070-0000000NTYX427H 27G CXA3070-0000000NT0Z227G CXA3070-0000000NTYY235F CXA3070-0000000NT0AB30F CXA3070-0000000NT0Y227G 27G CXA3070-0000000NT0Z435F Z2 2700 K 93 CXA3070-0000000NT0Z235H Order Code 4-Step Z4 3000 K 93 Group CXA3070-0000000NT0Y435H 3500 K 93 Order Code 3-Step CXA3070-0000000NTYX427G 27F CXA3070-0000000NT0Z227F CXA3070-0000000NTYX427F Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 16). • CXA3070 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS80 REV 8A 5 XLAMP ® CXA3070 LED FLUX CHARACTERISTICS, ANSI WHITE ORDER CODES AND BINS (IF = 1900 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA3070 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 14). Nominal CCT CRI Min 70 Minimum Luminous Flux Typ 75 6500 K 80 70 --- 75 5700 K 80 70 --- 75 5000 K 80 --- Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* Z4 7,945 8,851 Chromaticity Regions Order Code CXA3070-0000-000NT0Z40E1 AB 8,500 9,469 AD 9,000 10,026 BB 9,500 10,583 CXA3070-0000-000NT0BB0E1 Z4 7,945 8,851 CXA3070-0000-000NTHZ40E1 AB 8,500 9,469 AD 9,000 10,026 CXA3070-0000-000NTHAD0E1 Z4 7,945 8,851 CXA3070-0000-000NT0Z40E2 AB 8,500 9,469 AD 9,000 10,026 BB 9,500 10,583 CXA3070-0000-000NT0BB0E2 Z4 7,945 8,851 CXA3070-0000-000NTHZ40E2 AB 8,500 9,469 AD 9,000 10,026 CXA3070-0000-000NTHAD0E2 Z4 7,945 8,851 CXA3070-0000-000NT0Z40E3 AB 8,500 9,469 AD 9,000 10,026 BB 9,500 10,583 CXA3070-0000-000NT0BB0E3 Z4 7945 8,851 CXA3070-0000-000NTHZ40E3 AB 8500 9,469 AD 9000 10,026 1A0, 1B0, 1C0, 1D0, 65F 1A0, 1B0, 1C0, 1D0, 65F 2A0, 2B0, 2C0, 2D0, 57F 2A0, 2B0, 2C0, 2D0, 57F 3A0, 3B0, 3C0, 3D0, 50F 3A0, 3B0, 3C0, 3D0, 50F CXA3070-0000-000NT0AB0E1 CXA3070-0000-000NT0AD0E1 CXA3070-0000-000NTHAB0E1 CXA3070-0000-000NT0AB0E2 CXA3070-0000-000NT0AD0E2 CXA3070-0000-000NTHAB0E2 CXA3070-0000-000NT0AB0E3 CXA3070-0000-000NT0AD0E3 CXA3070-0000-000NTHAB0E3 CXA3070-0000-000NTHAD0E3 Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 16). • CXA3070 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS80 REV 8A 6 XLAMP ® CXA3070 LED Relative Spectral Power Distribution RELATIVE SPECTRAL POWER DISTRIBUTION The following graph is the result of a series of pulsed measurements at 1900 mA and TJ = 85 °C. 100% Relative Spectral Power 90% 80% 70% 60% 5000 K, 70 CRI 50% 4000 K, 70 CRI 40% 3000 K, 80 CRI 30% 3000 K, 93 CRI 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) ELECTRICAL CHARACTERISTICS The following graph is the result of a series of steady-state measurements. 39 38 Voltage (V) 37 36 Tc = 25 °C Tc = 55 °C 35 Tc = 85 °C 34 Tc = 105 °C 33 32 31 300 800 1300 1800 2300 2800 Current (mA) © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS80 REV 8A 7 XLAMP ® CXA3070 LED RELATIVE LUMINOUS FLUX The relative luminous flux values provided below are the ratio of: • Measurements of CXA3070 at steady-state operation at the given conditions, divided by • Flux measured during binning, which is a pulsed measurement at 1900 mA at TJ = 85 °C. For example, at steady-state operation of Tc = 25 °C, IF = 1300 mA, the relative luminous flux ratio is 80% in the chart below. A CXA3070 LED that measures 8500 lm during binning will deliver 6800 lm (8500 * 0.8) at steady-state operation of Tc = 25 °C, IF = 1300 mA. 160% Relative Luminous Flux 140% 120% Tc = 25 °C 100% Tc = 55 °C 80% Tc = 85 °C Tc = 105 °C 60% 40% 20% 0% 300 800 1300 1800 2300 2800 Current (mA) © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS80 REV 8A 8 XLAMP ® CXA3070 LED Far Field TYPICAL SPATIAL DISTRIBUTION 100% Relative Luminous Intensity 80% 60% 40% 20% -90 -70 -50 -30 -10 0% 10 30 50 70 90 Angle (º) PERFORMANCE GROUPS - BRIGHTNESS (I F = 1900 mA, TJ = 85 °C) XLamp CXA3070 LEDs are tested for luminous flux and placed into one of the following bins. Group Code Minimum Luminous Flux Maximum Luminous Flux X2 5590 6010 X4 6010 6430 Y2 6430 6910 Y4 6910 7390 Z2 7390 7945 Z4 7945 8500 AB 8500 9000 AD 9000 9500 BB 9500 10,000 BD 10,000 11,000 CB 11,000 12,000 © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS80 REV 8A 9 XLAMP ® CXA3070 LED PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) XLamp CXA3070 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. EasyWhite Color Temperatures – 2-Step Code 50H 40H 35H 30H 27H CCT 5000 K 4000 K 3500 K 3000 K 2700 K x y 0.3429 0.3507 0.3434 0.3571 0.3475 0.3604 0.3469 0.3539 0.3784 0.3741 0.3804 0.3818 0.3867 0.3857 0.3844 0.3778 0.4030 0.3857 0.4061 0.3941 0.4132 0.3976 0.4099 0.3890 0.4291 0.3973 0.4333 0.4062 0.4395 0.4084 0.4351 0.3994 0.4528 0.4046 0.4578 0.4138 0.4638 0.4152 0.4586 0.4060 EasyWhite Color Temperatures – 3-Step Ellipse Bin Code CCT 50G 40G Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 5000 K 0.3447 0.3553 0.00840 0.00312 65.0 4000 K 0.3818 0.3797 0.00939 0.00402 53.7 35G 3500 K 0.4073 0.3917 0.00927 0.00414 54.0 30G 3000 K 0.4338 0.4030 0.00834 0.00408 53.2 27G 2700 K 0.4577 0.4099 0.00834 0.00420 48.5 © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS80 REV 8A 10 XLAMP ® CXA3070 LED PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) - CONTINUED EasyWhite Color Temperatures – 4-Step Code 65F 57F 50F 40F 35F 30F 27F CCT 6500 K 5700 K 5000 K 4000 K 3500 K 3000 K 2700 K x y 0.3097 0.3196 0.3079 0.3297 0.3164 0.3382 0.3176 0.3275 0.3253 0.3325 0.3249 0.3439 0.3331 0.3514 0.3330 0.3393 0.3407 0.3459 0.3415 0.3586 0.3499 0.3654 0.3484 0.3521 0.3744 0.3685 0.3782 0.3837 0.3912 0.3917 0.3863 0.3758 0.3981 0.3800 0.4040 0.3966 0.4186 0.4037 0.4116 0.3865 0.4242 0.3919 0.4322 0.4096 0.4449 0.4141 0.4359 0.3960 0.4475 0.3994 0.4573 0.4178 0.4695 0.4207 0.4589 0.4021 © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS80 REV 8A 11 XLAMP ® CXA3070 LED PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) - CONTINUED ANSI White Bins Code CCT Bin Code 1A0 1B0 0E1 6500 K 1C0 1D0 ANSI White Bins x y 0.3048 0.3207 0.3130 0.3290 0.3144 0.3186 0.3068 Code CCT Bin Code x y 0.3215 0.3350 0.3290 0.3417 0.3290 0.3300 0.3113 0.3222 0.3243 0.3028 0.3304 0.3207 0.3462 0.3115 0.3391 0.3290 0.3538 0.3130 0.3290 0.3290 0.3417 0.3048 0.3207 0.3215 0.3350 0.3115 0.3391 0.3290 0.3538 0.3205 0.3481 0.3376 0.3616 0.3213 0.3373 0.3371 0.3490 0.3130 0.3290 0.3290 0.3417 0.3130 0.3290 0.3290 0.3417 0.3213 0.3373 0.3371 0.3490 0.3221 0.3261 0.3366 0.3369 0.3144 0.3186 0.3290 0.3300 2A0 2B0 0E2 5700 K 2C0 2D0 ANSI White Bins Code CCT Bin Code 3A0 3B0 0E3 5000 K 3C0 3D0 x y .3371 .3490 .3451 .3554 .3440 .3427 .3366 .3369 .3376 .3616 .3463 .3687 .3451 .3554 .3371 .3490 .3463 .3687 .3551 .3760 .3533 .3620 .3451 .3554 .3451 .3554 .3533 .3620 .3515 .3487 .3440 .3427 © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS80 REV 8A 12 XLAMP ® CXA3070 LED EASYWHITE® BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) 0.44 2700 K ANSI C78.377 Quadrangle 0.43 3000 K EasyWhite 4-Step EasyWhite 3-Step 0.42 EasyWhite 2-Step 3500 K 0.41 4000 K 0.40 4500 K CCy 0.39 5000 K 0.38 0.37 5700 K 0.36 6500 K 0.35 0.34 0.33 0.32 0.49 0.48 0.47 0.45 0.41 0.46 0.44 0.40 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.31 CCx ANSI WHITE BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) 0.41 4000 K ANSI C78.377 Quadrangle 0.40 4500 K 0.39 5000 K 0.38 CCy 0.37 5700 K 0.36 3C 3B 6500 K 0.35 0.34 1C 1B 0.33 3D 2C 2B 1D 3A 2D 2A 1A 0.32 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.31 CCx © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS80 REV 8A 13 XLAMP ® CXA3070 LED BIN AND ORDER CODE FORMATS Bin codes and order codes are configured as follows: Order Code Bin Code Series = CXA30 Series = CXA30 Internal code Chromaticity bin CRI Specification 0 = Standard CRI H = 80 CRI minimum U = 90 CRI minimum Y = 93 CRI minimum Vf class NT = 36-V class SSSSSCC-HHHH-HHHGGRNNNNN Internal code SSSSSCC-WWW-FF-GGR-AAAAA Vf class NT = 36-V class CRI Specification B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Y = 93 CRI minimum Performance class Flux bin Kit code Performance class MECHANICAL DIMENSIONS Dimensions are in mm. Tolerances unless otherwise specified: +.13 Meaning of 3070N 3070N = 36‑V CXA3070 3070N x° +1° © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS80 REV 8A 14 XLAMP ® CXA3070 LED THERMAL DESIGN The CXA family of LED arrays can include over a hundred different LED die inside one package, and thus over a hundred different junction temperatures (TJ). Cree LED has intentionally removed junction-temperature-based operating limits and replaced the commonplace maximum TJ calculations with maximum ratings based on forward current (IF) and case temperature (Tc). No additional calculations are required to ensure that the CXA LED is being operated within its designed limits. LES temperature measurement provides additional verification of good thermal design. Please refer to page 2 for the Operating Limit specifications. There is no need to calculate for TJ inside the package, as the thermal management design process, specifically from TSP to ambient (Ta), remains identical to any other LED component. For more information on thermal management of XLamp LEDs, please refer to the Thermal Management application note. For CXA soldering recommendations and more information on thermal interface materials (TIM), LES temperature measurement, and connection methods, please refer to the XLamp CX Family LEDs soldering and handling document. The CX Family LED Design Guide provides basic information on the requirements to use XLamp CXA LEDs successfully in luminaire designs. To keep the CXA3070 LED at or below the maximum rated Tc, the case to ambient temperature thermal resistance (R_c-a) must be at or below the maximum R_c-a value shown on the following R_j-c R_j-c scale. Tc Tc As the figure at right shows, the R_c-a value is the sum of the thermal resistance of the TIM (R_tim) R_tim graph, depending on the operating environment. The y‑axis in the graph is a base 10 logarithmic R_c-a plus the thermal resistance of the heat sink (R_hs). R_hs CXA3070 Ta Ta 100.00 Maximum R_c-a 10.00 Ta = 25 °C Ta = 55 °C 1.00 Ta = 85 °C Ta = 105 °C 0.10 0.01 300 800 1300 1800 2300 2800 Current (mA) © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS80 REV 8A 15 XLAMP ® CXA3070 LED NOTES Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs. Lumen Maintenance Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. REACh Compliance REACh substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative to insure you get the most up-to-date REACh Declaration. REACh banned substance information (REACh Article 67) is also available upon request. UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS80 REV 8A 16 XLAMP ® CXA3070 LED PACKAGING CXA3070 LEDs are packaged in trays of 20. Five trays are sealed in an anti-static bag and placed inside a carton, for a total of 100 LEDs 6 per carton. Each carton contains 100 LEDs from the same performance bin. 5 4 3 2 5 6 1 Dimensions are in inches. NOTICE NTIAL. THIS PLOT AND THE INFORMATION THIN ARE THE PROPRIETARY AND INFORMATION OF CREE, INC. THIS PLOT OPIED, REPRODUCED OR DISCLOSED TO ANY Tolerances: +.13 7.53 5 4 R .375 4 3 x° +1° 2 3 2 1 1 OTICE PLOT AND THE INFORMATION HE PROPRIETARY AND ON OF CREE, INC. THIS PLOT ODUCED OR DISCLOSED TO ANY NSENT 7.53 R .375 5.875 R .375 D 1.313 8.15 .875 1.313 8.15 C .38 LABEL WITH CREE BIN CODE, QUANTITY, LOT# BAG 1.313 PATENT LABELIS LOCATED ON UNDERSIDE OF CARTON .38 LABEL WITH CREE BIN 1.313 PATENT LABEL IS LOCATED CODE, QUANTITY, LOT# BAG ON UNDERSIDE OF CARTON PATENT LABELIS LOCATED ON UNDERSIDE OF CARTON TH CREE BIN .875 ANTITY, LOT # LABEL WITH CREE BIN BAG CODE, QUANTITY, LOT# .38 B L IS LOCATED IDE OF COVER LABEL WITH CREE BIN CODE, QUANTITY, LOT# LABEL WITH CREE BIN UNLESS OTHERWISE SPECIFIED LABEL WITH CREE BIN DIMENSIONS ARE IN MILLIMETERS & BEFORE FINISH. TOLERANCE CODE, QUANTITY, LOT # UNLESS SPECIFIED: LABEL CREELOT# BIN CODE,WITH QUANTITY, CODE, QUANTITY, LOT # .X ± .XX ± .XXX ± X° ± THIRD ANGLE PROJECTION 6 5 4 3 THIRD ANGLE PROJECTION .X ± .XX ± .XXX ± X° ± 0.1 .05 .005 1 ° FOR SHEET METAL PARTS ONLY .X ± .06 .XX ± .03 .XXX ± .010 X° ± 2 ° 6 5 4 DATE APPROVED DATE 4600 Silicon Drive Durham, N.C 27703 Phone (919) 361-47 TITLE CXA30XX_DATASHEET MATERIAL SIZE C DATE FINAL PROTECTIVE FINISH DATE APPROVED DATE SCALE DRAWING NO. CXA30XX_DATASHEET_BAG_2013 0.500 4600 Silicon Drive Durham, N.C 27703 SHEET OF Phone (919) 361-4770 Fax (919) 313-5303 2 1 A TITLE CXA30XX_DATASHEET MATERIAL SIZE FINAL PROTECTIVE FINISH C SCALE DRAWN BY 3 UNLESS OTHERWISE SPECIFIED WITH CREE BIN DIMENSIONS ARE IN CHECK MILLIMETERS & BEFORE FINISH. QUANTITY, LOT # TOLERANCE UNLESS SPECIFIED: © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered and APPROVED .X ± trademarks, 0.1 ± .05 registered the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the.XXUL logo are .XXX ± .005 trademarks of UL LLC. THIRD ANGLE PROJECTION MATERIAL X° ± 1 ° FOR SHEET METAL PARTS ONLY .X ± .06 DATE CHECK Fax (919) 313-5303 0.1 .05 .005 1 ° FOR SHEET METAL PARTS ONLY DRAWN BY .X ± .06 UNLESS OTHERWISE SPECIFIED .XX ± .03 DIMENSIONS ARE IN .XXX ± .010 CHECK MILLIMETERS & BEFORE FINISH. X° ± 2 ° TOLERANCE UNLESS SPECIFIED: LABEL WITH CREE BIN CODE, QUANTITY, LOT# DRAWN BY 2 SHEET 0.500 1 DATE DATE A OF 1 /1 4600 Silicon Drive Durham, N.C 27703 Phone (919) 361-4770 DATE TITLE CLD-DS80 REV 8A 17 Fax (919) 313-5303 CXA15XX_DATASHEET SIZE FINAL PROTECTIVE FINISH REV. DRAWING NO. CXA30XX_DATASHEET_BAG_2013 DRAWING NO. CXA15XX_DATASHEET_BAG2013
物料型号:CREE XLamp® CXA3070 LED阵列
器件简介: - 该LED阵列属于CREE的高通量多芯片集成阵列,易于使用,具有高可靠性。 - 提供2步、3步和4步色温一致性选项,以及70-93的最低CRI选项。 - 具有115°的视角和统一的色度特性。
引脚分配:文档中未明确提供引脚分配信息。
参数特性: - 正向电压选项:36V级 - 最大驱动电流:2800 mA - 热电偶连接点 - 符合NEMA SSL-3 2011标准通量箱 - 符合RoHS和REACh标准 - UL®认可组件
功能详解: - 提供EasyWhite®和ANSI白色订单代码和箱型 - 相对光谱功率分布图 - 电气特性和典型空间分布图 - 性能组 - 亮度和色度
应用信息: - 适用于定向和非定向照明应用,以及照明和灯具设计。
封装信息: - 封装尺寸和公差 - 热设计信息,包括热管理设计过程和热阻抗要求
注意事项: - 测量值仅代表发货日期的产品测量规格,不作为操作规格。 - 产品符合RoHS和REACh标准。 - UL®认可组件。
包装: - CXA3070 LED以每盘20个进行包装,每箱共100个LED。
CXA3070-0000-000N0UZ250G 价格&库存
很抱歉,暂时无法提供与“CXA3070-0000-000N0UZ250G”相匹配的价格&库存,您可以联系我们找货
