CXM-32-30-80-54-AC32-F4-3 数据手册
CXM-32 Product Datasheet
Generation 3
CXM-32 COB Arrays
White LED
Features:
Table of Contents
• High lumen output and efficacy typical
• Over 17,295 lm, 154 LPW @ 3000K, 80 CRI, Tj = 85ºC
Technology Overview. . . . . . 2
• Over 19,675 lm, 176 LPW @ 5000K, 70 CRI, Tj = 85ºC
Test Specifications . . . . . . . . . 2
• CCT 2700K, 3000K, 3500K, 4000K, 5000K, 5700K and 6500K
Chromaticity Bins. . . . . . . . . . 3
• CRI Ra 80, 90 and 95 min. in all colors (except 5000K, 5700K and 6500K)
Product Ordering & Shipping
Part Numbers. . . . . . . . . . . . . . 4
Product Typical Flux Range. 5
• CRI Ra 70 in 4000K, 5000K, 5700K and 6500K
• R9 up to 85 min. CRI 98 typical in 2700K, 3000K, 3500K and 4000K
• 3 SDCM color binning accuracy
• Excellent optical emission uniformity and color over angle consistency
Product Flux Bins. . . . . . . . . . . 6
• Exceptional long term color stability
Operating Characteristics . . 6
• Package thermal conductivity more than twice the industry average
Optical and Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . . . 7
• Environmentally friendly: RoHS and REACH compliant
• UL reconigized, file # E465703
Spectra. . . . . . . . . . . . . . . . . . . . 8
Mechanical Dimensions. . . . 9
Packaging Information. . . . . 9
Handling Notes. . . . . . . . . . . 10
Applications
• Architectural and Specialty
• Parking Lot and Area Lighting
• Street Lighting
• Tunnel Lighting
1
PDS-002858 Rev 04
© 2018 Luminus Devices, Inc. - All Rights Reserved
Technology Overview
Luminus Chip-on-Board (COB) LED series offers a complete lighting class solution designed for high performance
illumination applications. The selection covers a wide lumen range from less than
400lm to over 10,000lm, all major color temperatures
and can deliver
Reliability
Designed from the ground up, the Luminus COB LED is one of
the most reliable light sources in the world today. Having
passed a rigorous suite of environmental and mechanical stress
tests, including mechanical shock, vibration, temperature
cycling and humidity. Only then are the devices qualified for
use in a wide range of lighting application including some of the
most demanding commercial applications. Delivered with fully
qualified LM80 test data and TM21 lifetime results that certify
lumen maintenance at 35,000 hours or more, Luminus COB
LEDs are ready for the toughest challenges.
UL Recognized Compliance
Luminus COB arrays are tested in accordance with ANSI/UL 8750
to ensure safe operation for their intended applications.
REACH & RoHS Compliance
All LED products manufactured by Luminus are REACH and
RoHS compliant and free of hazardous materials, including lead
and mercury.
Understanding Luminus COB LED Test Specifications
Every Luminus LED is fully tested to ensure it meets the high quality standards customers have come to expect from Luminus’ products.
Traceability
Chromaticity Bin Range
Each Luminus COB LED is marked with a 2D bar code that
contains a unique serial number. With this serial number,
Luminus has the ability to provide customers with actual test
data measurements for a specific LED. In addition, the 2D bar
code is linked to manufacturing date codes that enables
traceability of production processes and materials.
Chromaticity binning delivers color consistency for every order.
Standard products are delivered with a 3-step MacAdam ellipse.
This ensures color performance matching in the application. For
the most demanding application, Luminus is one of only a few
companies that can provide a 2-step ellipse bin. These tightly
controlled, small distribution bins provide customers
predictable, repeatable colors.
Testing Temperature
Luminus COB products are measured at temperatures typical for
the LED operating in the fixture. Each device is tested at 85ºC
junction temperature eliminating the need to scale datasheet
specifications to real world situations.
2
PDS-002858 Rev 04
Chromaticity Bins
Chromaticity Bins: 1931 CIE Curve
0.46
0.46
ANSI
ANSIC78.377-2008
C78.377-2008
2-step
3-stepEllipse
Ellipse
3-step Ellipse
5-step
Ellipse
5-step Ellipse
0.44
0.44
2700K
2700K
3000K
3000K
3500K
3500K
0.42
0.42
Black Body
4000K
4000K
CIE
CIE y
y
0.4
0.4
Black Body
5000K
5000K
0.38
0.38
5700K
0.36
0.36
6500K
6500K
0.34
0.34
0.32
0.32
0.3
0.3
0.3
0.3
0.32
0.34
0.32
0.36
0.34
0.36
0.38
0.38
0.4
0.42
0.4
0.44
0.42
CIE x
CIE x
0.44
0.46
0.48
0.46
0.5
0.48
0.5
The following tables describe the ANSI bin center points, the orientation angle for the MacAdam ellipse (θ °), and the maximum radii for
the ellipses. The ANSI Bin is provided for reference.
CCT
Center Point
Angle
3-step Bin
5-step Bin
CIEx
CIEy
θ (°)
a
b
2700K
0.4578
0.4101
53.7
0.0081
0.0042
3000K
0.4338
0.403
53.2
0.00834
0.00408
3500K
0.4073
0.3917
54
0.00927
0.00414
4000K
0.3818
0.3797
53.7
0.00939
0.00402
5000K
0.3447
0.3553
59.6
0.00822
5700K
0.3287
0.3417
59.09
6500K
0.3123
0.3282
58.57
*Note:
a
b
0.00354
0.0137
0.0059
0.00746
0.0032
0.0124
0.0053
0.00669
0.00285
0.01115
0.00475
Luminus maintains a +/- 0.005 tolerance on chromaticity (CIEx and CIEy) measurements.
3
PDS-002858 Rev 04
Part Number Nomenclature
All CXM-32 products are packaged and labeled with part numbers as outlined in the table on page 5. Luminus may include any smaller
chromaticity bin that is contained in the larger bin as part of the ordered part. When shipped, each package will contain only a single
flux and chromaticity bin. The part number designation is as follows:
CXM
32
NN
Product Family
Light Emitting Surface
Diameter
CXM: Chip on
Board
32: LES
Diameter
(mm)
XX
54
QQPP
FG
W
Color
Temperature
Color Rendering Index
(CRI)
Voltage (typical)
Package
Configurator
Flux Bin
Chromaticity
Bin
Color
See Note 1
Below
CRI See Table
Below
Volts
AC00
(Basic package)
Lumens
See page 3 for
bins
Note 1: NN nomenclature corresponds to the following:
27 = 2700K
30 = 3000K
35 = 3500K
40 = 4000K
50 = 5000K
57 = 5700K
65 = 6500K
Color Temperature, CRI and R9 Values
Color Temperatures
XX Value
CRI
R9
4000K, 5000K, 5700K, 6500K
70
>70
2700K, 3000K, 3500K, 4000K, 5000K, 5700K, 6500K
80
>80
>0
90
>90
>50
95
>95
2700K, 3000K
3500K, 4000K
Note:
>85
>75
Luminus part numbers may be accompanied by prefixes or suffixes. The most common is the “Rev01” suffix indicating a part is fully released
and carries a full warranty. These additional characters may appear on shipping labels, packing slips and invoices. In all cases the basic part
number described above will always be included.
4
PDS-002858 Rev 04
CXM-32 Part Numbers
The following tables describe products with typical flux and minimum flux measured at 2,200mA and specified at Tj = 85ºC. The values at
25ºC are calculated and shown for reference only. Luminus may choose to ship a smaller chromaticity bin in an order for a larger.
Output Flux (lm)
CCT
3000K
3500K
4000K
3-step MacAdam Ellipse
15,225
18,005
80
CXM-32-27-80-54-AC30-F4-3
13,490
12,545
14,840
90
CXM-32-27-90-54-AC30-F4-3
12,905
12,000
14,195
95
CXM-32-27-95-54-AC30-F4-3
17,295
16,085
19,025
80
CXM-32-30-80-54-AC30-F4-3
14,550
13,530
16,005
90
CXM-32-30-90-54-AC30-F4-3
13,585
12,635
14,945
95
CXM-32-30-95-54-AC30-F4-3
17,810
16,565
19,590
80
CXM-32-35-80-54-AC30-F4-3
14,840
13,800
16,320
90
CXM-32-35-90-54-AC30-F4-3
14,190
13,200
15,610
95
CXM-32-35-95-54-AC30-F4-3
19,350
18,000
21,285
70
CXM-32-40-70-54-AC30-F4-3
18,045
16,780
19,850
80
CXM-32-40-80-54-AC30-F4-3
15,655
14,560
17,220
90
CXM-32-40-90-54-AC30-F4-3
14,530
13,515
15,675
95
CXM-32-40-95-54-AC30-F4-3
Reference
Color
Rendering
Index
Part Number
(25ºC)
Typ.
Min..
(85ºC)
(calculated)
19,675
18,300
18,170
Typ. (85ºC)
6500K
CRI (min.)
Typ.
16,370
CCT
5700K
Ordering Part Number
(calculated)
Output Flux (lm)
5000K
Color
Rendering
Index
Min.
(85ºC)
Typ. (85ºC)
2700K
Reference
CRI (min.)
5-step MacAdam Ellipse
21,645
70
CXM-32-50-70-54-AC30-F4-5
CXM-32-50-70-54-AC30-F4-3
16,895
19,985
80
CXM-32-50-80-54-AC30-F4-5
CXM-32-50-80-54-AC30-F4-3
15,730
14,630
17,305
90
CXM-32-50-90-54-AC30-F4-5
CXM-32-50-90-54-AC30-F4-3
19,690
18,310
21,660
70
CXM-32-57-70-54-AC30-F4-5
CXM-32-57-70-54-AC30-F4-3
18,140
16,865
19,950
80
CXM-32-57-80-54-AC30-F4-5
CXM-32-57-80-54-AC30-F4-3
19,700
18,320
21,670
70
CXM-32-65-70-54-AC30-F4-5
CXM-32-65-70-54-AC30-F4-3
18,100
16,835
19,910
80
CXM-32-65-80-54-AC30-F4-5
CXM-32-65-80-54-AC30-F4-3
(25ºC)
*Note:
Luminus maintains a +/- 6% tolerance on flux measurements.
Luminus maintains a +/- 2% tolerance on CRI measurements.
5
PDS-002858 Rev 04
CXM-32 Operating Characteristics1
Parameter
Forward Current
Symbol
2
If
Forward Voltage3
Vf
Minimum
48
Power
Operating Case Temperature4
Typical
Maximum
Unit
2,200
4,400
mA
51
56
V
112
240
W
105
ºC
Tc
Light Emitting Surface Diameter
LES
32
mm
Thermal Resistance (junction-to-case)
Qjc
0.11
ºC/W
Junction Temperature
Tj
Viewing Angle
140
120
ºC
Degree
Note 1: Ratings are based on operation at a constant junction temperature of Tj = 85ºC.
Note 2: To prevent damage refer to operating conditions and derating curves for appropriate maximum operating conditions
Note 3: Voltage is rated at typical forward current. For voltage at higher drive current, refer to performance graphs.
Note 4: CXM-32 COB LEDs are designed for operation up to an absolute maximum forward drive current as specified above. Refer to the current vs. case
temperature derating curves for further information.
Note 5: Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye.
6
PDS-002858 Rev 04
CXM-32 Optical & Electrical Characteristics
Relative Output Flux vs. Forward Current @ 85ºC
Forward Current vs. Forward Voltage @ 85ºC
200%
4400
180%
3900
160%
3400
Forward Current (mA)
Relative Luminous Flux
140%
120%
100%
80%
60%
2900
2400
1900
1400
40%
900
20%
0%
400
900
1400
1900
2400
2900
3400
3900
400
4400
Relative Output Flux vs. Junction Temperature
47
48
49
50
51
52
Forward Voltage (V)
53
54
55
Change in Voltage vs. Junction Temperature
120%
60
Forward Voltage (V)
58
100%
80%
56
54
52
60%
50
40%
5
15
25
35
45
55
65
75
85
95
105
48
5
15
25
35
55
65
75
85
95
105
Change in CIEy vs. Junction Temp. (3000K, 80CRI)
0.02
0.02
0.01
0.01
Δ CIEy
Δ CIEx
Change in CIEx vs. Junction Temp. (3000K, 80CRI)
-0.01
-0.02
45
Junction Temperature (ºC)
5
15
25
35
45
55
65
75
7
PDS-002858 Rev 04
85
95
105
-0.02
5
15
25
35
45
55
65
75
85
95
105
Typical Spectrum
120.00%
100.00%
Relative Intensity
80.00%
Warm White
60.00%
Neutral White
Cool White
40.00%
3000K-90CRI
3000K-97CRI
20.00%
0.00%
400
450
500
-20.00%
550
600
650
700
750
800
Wavelength (nm)
Typical Polar Radiation Pattern
Typical Angular Radiation Pattern
120%
100%
Relative Intensity (%)
80%
60%
40%
20%
0%
-80
-60
-40
-20
Anglular Displacement (Degrees)
8
PDS-002858 Rev 04
40
60
80
Shipping Container
60 pcs per box
Each bag is boxed for
easier storage/ stacking
20 pcs per tray
3 trays are stacked together
with separate cover
Trays are sealed in
an anti-static bag
Label
Luminus Label Model:
XXXXXX-XX-XX
(Manufacturer Part Number & Bin Kits)
XXX-XX-XX-XX-XX-XXXX-XX-X
XXXXXXXXXXXXXX
Bar code
9
PDS-002858 Rev 04
Rev XX
Bar code
Bar code
(Box ID)
(Customer Part Number)
Qty: XX
Bar code
RoHS Compliant
Luminus Devices Inc
CXM-32
Product Datasheet
(Part
#) Product
Handling Notes for Luminus COBs
Luminus products are designed for robust performance in general lighting application. However, care must be taken when handling and
assembling the LEDs into their fixtures. To avoid damaging Luminus COBs please follow these guidelines.
The following is an overview of the application notes detailing some of the practices to follow when working with these devices. More
detailed information is available on the Luminus web site at www.luminus.com.
General Handling
Electrical Contact
Devices are made to be lifted or carried with tweezers on two
adjacent corners opposite the contact pads. At no time should
the devices be handled by or should anything come in contact
with the light emitting surface (LES) area. This area includes the
yellow colored circular area and the ring surrounding it. There
are electrical connections under the LES which if damaged will
cause the device to fail.
Luminus COBs are designed with contact pads on their top
surface. These pads are clearly marked with + and – polarity.
Wires can be soldered to the contact pads for electrical
connections or other solderless connector products are
available.
In addition, the ring frame itself should not be used for moving,
lifting or carrying the device. Also do not attach any optics or
mechanical holders to the ring as it is not capable to handle the
mechanical stress.
If wires are being soldered to the COB product, we recommend
attaching these wires prior to mounting the devices to a heat
sink. Please contact Luminus for specific recommendations on
how to solder wires if not familiar with the standard practice.
Luminus can also offer design recommendations for jigs to
allow easily soldering multiple products in rapid succession.
Static Electricity
Chemical Compatibility
Luminus COBs are electronic devices which can be damaged by
electrostatic discharge (ESD). Please use appropriate measures
to assure the devices do not experience ESD during their
handling and or storage. ESD protection guidelines should be
used at all times when working with Luminus COBs.
The resin material used to form the LES can getter hydrocarbons
from the surrounding environment. As a results, certain
chemical compounds are not recommended for use with the
Luminus products. Use of these compounds can cause damage
to the light output of the device and may permanently damage
the device. Please refer to www.luminus.com for a list of the
compounds not recommended for use with the Luminus COB
products.
Storage: Luminus products are delivered in ESD shielded bags
and should be stored in these bags until used.
Assembly: Individuals handling Luminus COBs during assembly
should be trained in ESD protection practices. Assemblers
should maintain constant conductive contact with a path to
ground by means of a wrist strap, ankle straps, mat or other ESD
protection system.
Transporting: When transporting the devices from one
assembly area to another, ESD shielded carts and carriers should
be used.
10
PDS-002858 Rev 04
Thermal Interface Material (TIM)
Proper thermal management is critical for successful operation
of any LED system. Excess operating temperature can reduce
the light output of the device. And excessive heating can cause
permanent damage to the device. Proper TIM material is a
crucial component for effective heat transfer away from the LED
during normal operation. Please refer to www.luminus.com for
specific recommendations for TIM solutions.
