CXB3070-0000-000N0UZ435G
    WOLFSPEED
    LED Lighting COBs, Engines, Modules Chip On Board (COB) Xlamp® CXB3070 White, Warm Square
CXB3070-0000-000N0UZ435G 数据手册
PRODUCT FAMILY DATA SHEET XLamp® CXB3070 LED PRODUCT DESCRIPTION FEATURES TABLE OF CONTENTS The XLamp® CXB3070 LED Array is a • 23‑mm optical source Characteristics................................................ 2 member of the second generation of the • Mechanical and optical design Operating Limits.............................................. 2 CXA family that delivers up to 30% higher consistent with other CXA30 and Flux Characteristics, EasyWhite® Order efficacy and up to 20% higher lumens than CXB30 LEDs Codes and Bins............................................... 3 the first generation in the same LES. The • Available in 70-, 80- and 90-minimum Relative Spectral Power Distribution............. 6 higher performance second generation Electrical Characteristics................................ 6 CXA LED Arrays provide a CRI options drop-in • EasyWhite 2-, 3‑ and 5-step binning ® Relative Luminous Flux................................... 7 performance upgrade to existing CXA LED • Forward voltage option: 36‑V class Typical Spatial Distribution............................. 8 designs to shorten product development • 85 °C binning and characterization Performance Groups - Brightness................. 8 time. In addition, the CXB LEDs also • Extremely uniform color over viewing Performance Groups - Chromaticity.............. 9 allow lighting manufacturers to achieve EasyWhite® Bins Plotted on the 1931 CIE the same or better performance with a angle • Top-side solder connections Color Space................................................... 10 smaller LES, enabling a smaller, more • Thermocouple attach point Bin and Order Code Formats........................ 11 impactful luminaire. Available in 2‑step, • NEMA SSL-3 2011 standard flux bins Mechanical Dimensions............................... 11 3‑step and 5‑step EasyWhite Thermal Design............................................. 12 ® bins, the • RoHS and REACh compliant CXB3070 LED delivers high lumen output and high efficacy in a single, easy‑to‑use • UL recognized component (E349212) ® Notes............................................................. 13 Packaging...................................................... 14 package that eliminates the need for reflow soldering. The CX Family LED Design Guide provides basic information on the requirements to use the CXB3070 LED successfully in luminaire designs. Cree LED / 4400 Silicon Drive / Durham, NC 27703 USA / +1.919.313.5330 / www.cree-led.com © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS125 REV 7A 1 XLAMP ® CXB3070 LED CHARACTERISTICS Characteristics Unit Viewing angle (FWHM) Minimum Typical degrees ESD withstand voltage (HBM per Mil-Std-883D) Maximum 115 V 8000 DC forward current mA 2800* Reverse current mA 0.1 Forward voltage (@ 1900 mA, Tj = 85 °C) * V 36 39 Refer to the Operating Limits section. OPERATING LIMITS The maximum current rating of the CXB3070 depends on the case temperature (Tc) when the LED has reached thermal equilibrium under steady-state operation. The graph shown below assumes that the system design employs good thermal management (thermal interface material and heat sink) and may vary when poor thermal management is employed. Please refer to the Mechanical Dimensions section on page 11 for the location of the Tc measurement point. Another important factor in good thermal management is the temperature of the Light Emitting Surface (LES). Cree LED recommends a maximum LES temperature of 135 °C to ensure optimal LED lifetime. Please refer to the Thermal Design section on page 12 for more information onCXB3070 LES temperature measurement. - Standard 3000 90 °C, 2800 mA 2750 2500 2250 If (mA) 2000 1750 1500 125 °C, 1167 mA 1250 1000 750 500 250 0 0 25 50 75 100 125 150 Case Temperature (°C) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS125 REV 7A 2 XLAMP ® CXB3070 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS (IF = 1900 mA, TJ = 85 °C) The following table provides order codes for XLamp CXB3070 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 11). CRI* Nominal CCT Min 70 Minimum Luminous Flux Typ --- 6500 K 80 70 70 5000 K 80 90 3-Step --- Flux (lm) @ 85 °C Flux (lm) @ 25 °C** BB 9,500 10,520 BD 10,000 11,074 CB 11,000 12,181 CXB3070-0000000N0BCB65E BB 9,500 10,520 CXB3070-0000000N0HBB65E BD 10,000 11,074 CXB3070-0000000N0HBD65E BB 9,500 10,520 CXB3070-0000000N0BBB57E BD 10,000 11,074 CB 11,000 12,181 CXB3070-0000000N0BCB57E BB 9,500 10,520 CXB3070-0000000N0HBB57E BD 10,000 11,074 CXB3070-0000000N0HBD57E BB 9,500 10,520 CXB3070-0000000N0BBB50E BD 10,000 11,074 CB 11,000 12,181 BB 9,500 10,520 BD 10,000 11,074 CXB3070-0000000N0HBD50G Z4 7,945 8,798 CXB3070-0000000N0UZ450G AB 8,500 9,413 AD 9,000 9,967 Group Order Code Group Order Code 65E 65E 57E 57E --- 92 Group Order Code CXB3070-0000000N0BBB65E --- --- 5-Step Group --- 5700 K 80 2-Step 50E CXB3070-0000000N0BBD65E CXB3070-0000000N0BBD57E CXB3070-0000000N0BBD50E CXB3070-0000000N0BCB50E 50G 50G CXB3070-0000000N0HBB50G 50E CXB3070-0000000N0HBB50E CXB3070-0000000N0HBD50E CXB3070-0000000N0UAB50G CXB3070-0000000N0UAD50G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 13). • CXB3070 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS125 REV 7A 3 XLAMP ® CXB3070 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS (IF = 1900 mA, TJ = 85 °C) - CONTINUED CRI* Nominal CCT Min 70 Minimum Luminous Flux Typ --- Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** BB 9,500 10,520 BD 10,000 11,074 CB 11,000 12,181 AD 9,000 9,967 BB 9,500 10,520 BD 10,000 11,074 Z4 7,945 8,798 2-Step Group 90 80 --- 92 90 80 92 --- 92 Group Order Code CXB3070-0000000N0BBD40E CXB3070-0000000N0BCB40E CXB3070-0000000N0HAD40H 40H CXB3070-0000000N0HBB40H CXB3070-0000000N0HAD40G 40G CXB3070-0000000N0HBD40H CXB3070-0000000N0UZ440H CXB3070-0000000N0HBB40G CXB3070-0000000N0HBD40G 40G CXB3070-0000000N0UZ440G AB 8,500 9,413 CXB3070-0000000N0UAB40H AD 9,000 9,967 CXB3070-0000000N0HAD35H BB 9,500 10,520 CXB3070-0000000N0HBB35H Z2 7,390 8,184 CXB3070-0000000N0UZ235H Z4 7,945 8,798 AB 8,500 9,413 CXB3070-0000000N0UAB35H CXB3070-0000000N0UAB35G AB 8,500 9,413 CXB3070-0000000N0HAB30H CXB3070-0000000N0HAB30G AD 9,000 9,967 BB 9,500 10,520 CXB3070-0000000N0HBB30H CXB3070-0000000N0HBB30G Y4 6,910 7,652 CXB3070-0000000N0UY430H CXB3070-0000000N0UY430G Z2 7,390 8,184 Z4 7,945 8,798 35H 35H 30H 3000 K 90 Order Code 40E 40H --- 3500 K Group 5-Step CXB3070-0000000N0BBB40E 4000 K 80 Order Code 3-Step 30H CXB3070-0000000N0UZ435H CXB3070-0000000N0HAD30H CXB3070-0000000N0UZ230H CXB3070-0000000N0UZ430H 35G CXB3070-0000000N0UAB40G CXB3070-0000000N0HAD35G CXB3070-0000000N0HBB35G CXB3070-0000000N0UZ235G 35G 30G 30G CXB3070-0000000N0UZ435G CXB3070-0000000N0HAD30G CXB3070-0000000N0UZ230G CXB3070-0000000N0UZ430G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 13). • CXB3070 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS125 REV 7A 4 XLAMP ® CXB3070 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS (IF = 1900 mA, TJ = 85 °C) - CONTINUED CRI* Nominal CCT Min 80 Minimum Luminous Flux Typ --- 2700 K 90 2200 K 80 3-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** Z4 7,945 8,798 AB 8,500 9,413 AD 9,000 9,967 CXB3070-0000000N0HAD27H CXB3070-0000000N0HAD27G Y4 6,910 7,652 CXB3070-0000000N0UY427H CXB3070-0000000N0UY427G Z2 7,390 8,184 Z2 7,390 8,184 92 --- 2-Step Group Order Code Group CXB3070-0000000N0HZ427H 27H 27H CXB3070-0000000N0HAB27H CXB3070-0000000N0UZ227H Order Code 5-Step Group Order Code CXB3070-0000000N0HZ427G 27G 27G 22G CXB3070-0000000N0HAB27G CXB3070-0000000N0UZ227G CXB3070-0000000N0HZ222G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 13). • CXB3070 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS125 REV 7A 5 XLAMP ® CXB3070 LED RELATIVE SPECTRAL POWER DISTRIBUTION The following graph is the result of a series of pulsed measurements at 1900 mA and TJ = 85 °C. 100% Relative Spectral Power 90% 80% 70% 5000 K, 70 CRI 60% 4000 K, 70 CRI 50% 3000 K, 80 CRI 40% 3000 K, 90 CRI 30% 2200 K, 80 CRI 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) ELECTRICAL CHARACTERISTICS The following graph is the result of a series of steady-state measurements. 39 38 Voltage (V) 37 36 Tc = 25 °C Tc = 55 °C 35 Tc = 85 °C 34 Tc = 105 °C 33 32 31 300 800 1300 1800 2300 2800 Current (mA) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS125 REV 7A 6 XLAMP ® CXB3070 LED RELATIVE LUMINOUS FLUX The relative luminous flux values provided below are the ratio of: • Measurements of CXB3070 at steady-state operation at the given conditions, divided by • Flux measured during binning, which is a pulsed measurement at 1900 mA at TJ = 85 °C. For example, at steady-state operation of Tc = 25 °C, IF = 1300 mA, the relative luminous flux ratio is 80% in the chart below. A CXB3070 LED that measures 8500 lm during binning will deliver 6800 lm (8500 * 0.8) at steady-state operation of Tc = 25 °C, IF = 1300 mA. 160% Relative Luminous Flux 140% 120% Tc = 25 °C 100% Tc = 55 °C 80% Tc = 85 °C Tc = 105 °C 60% 40% 20% 0% 300 800 1300 1800 2300 2800 Current (mA) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS125 REV 7A 7 XLAMP ® CXB3070 LED Far Field TYPICAL SPATIAL DISTRIBUTION 100% Relative Luminous Intensity 80% 60% 40% 20% -90 -70 -50 -30 -10 0% 10 30 50 70 90 Angle (º) PERFORMANCE GROUPS - BRIGHTNESS (I F = 1900 mA, TJ = 85 °C) XLamp CXB3070 LEDs are tested for luminous flux and placed into one of the following bins. Group Code Minimum Luminous Flux Maximum Luminous Flux Y4 6910 7390 Z2 7390 7945 Z4 7945 8500 AB 8500 9000 AD 9000 9500 BB 9500 10,000 BD 10,000 11,000 CB 11,000 12,000 CD 12,000 13,000 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS125 REV 7A 8 XLAMP ® CXB3070 LED PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) XLamp CXB3070 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. EasyWhite Color Temperatures – 2-Step Code 40H 35H 30H 27H CCT 4000 K 3500 K 3000 K 2700 K x y 0.3777 0.3739 0.3797 0.3816 0.3861 0.3855 0.3838 0.3777 0.4022 0.3858 0.4053 0.3942 0.4125 0.3977 0.4091 0.3891 0.4287 0.3975 0.4328 0.4064 0.4390 0.4086 0.4347 0.3996 0.4524 0.4048 0.4574 0.4140 0.4633 0.4154 0.4581 0.4062 EasyWhite Color Temperatures – 3-Step Ellipse Bin Code CCT 50G 40G Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 5000 K 0.3447 0.3553 0.00840 0.00312 65.0 4000 K 0.3818 0.3797 0.00939 0.00402 53.7 35G 3500 K 0.4073 0.3917 0.00927 0.00414 54.0 30G 3000 K 0.4338 0.4030 0.00834 0.00408 53.2 27G 2700 K 0.4577 0.4099 0.00834 0.00420 48.5 22G 2200 K 0.5066 0.4158 0.00980 0.00480 45.5 EasyWhite Color Temperatures – 5-Step Ellipse Bin Code CCT 65E Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 6500 K 0.3123 0.3282 0.01110 0.00550 61.0 57E 5700 K 0.3287 0.3417 0.01230 0.00600 72.0 50E 5000 K 0.3447 0.3553 0.01400 0.00520 65.0 40E 4000 K 0.3818 0.3797 0.01565 0.00670 53.7 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS125 REV 7A 9 XLAMP ® CXB3070 LED EASYWHITE® BINS PLOTTED ON THE 1931 CIE COLOR SPACE 0.45 ANSI C78.377 Quadrangle 0.44 2700 K EasyWhite 5-step 0.43 2200 K 2450 K 3000 K EasyWhite 3-step 0.42 EasyWhite 2-step 3500 K 0.41 4000 K 0.40 CCy 0.39 5000 K 4500 K 5700 K 0.38 0.37 6500 K 0.36 0.35 7000K 0.34 0.33 0.32 0.54 0.53 0.52 0.51 0.50 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.31 CCx © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS125 REV 7A 10 XLAMP ® CXB3070 LED BIN AND ORDER CODE FORMATS Bin codes and order codes are configured as follows: Order Code Bin Code Series = CXB30 Series = CXB30 Internal code Chromaticity bin CRI Specification B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum SSSSSCC-HHHH-HHHGGRNNNNN Vf class N0 = 36-V class Internal code SSSSSCC-WWW-FF-GGR-AAAAA CRI Specification B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Kit code Vf class N0 = 36-V class Flux bin Performance class Performance class MECHANICAL DIMENSIONS Dimensions are in mm. Tolerances unless otherwise specified: ±.13 x° ±1° B3070N = 36‑V CXB3070 B3070N Meaning of B3070N © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS125 REV 7A 11 XLAMP ® CXB3070 LED THERMAL DESIGN The CXB family of LED arrays can include over a hundred different LED die inside one package, and thus over a hundred different junction temperatures (TJ). Cree LED has intentionally removed junction-temperature-based operating limits and replaced the commonplace maximum TJ calculations with maximum ratings based on forward current (IF) and case temperature (Tc). No additional calculations are required to ensure that the CXB LED is being operated within its designed limits. LES temperature measurement provides additional verification of good thermal design. Please refer to page 2 for the Operating Limit specifications. There is no need to calculate for TJ inside the package, as the thermal management design process, specifically from TSP to ambient (Ta), remains identical to any other LED component. For more information on thermal management of XLamp LEDs, please refer to the Thermal Management application note. For CXB soldering recommendations and more information on thermal interface materials (TIM), LES temperature measurement, and connection methods, please refer to the XLamp CX Family LEDs soldering and handling document. The CX Family LED Design Guide provides basic information on the requirements to use XLamp CXB LEDs successfully in luminaire designs. To keep the CXB3070 LED at or below the maximum rated Tc, the case to ambient temperature thermal resistance (R_c-a) must be at or below the maximum R_c-a value shown on the following graph, depending on the operating environment. The y‑axis in the graph is a base 10 logarithmic scale. As the figure at right shows, the R_c-a value is the sum of the thermal resistance of the TIM (R_tim) R_j-c R_j-c Tc Tc R_tim R_c-a plus the thermal resistance of the heat sink (R_hs). R_hs CXB3070 Ta Ta Maximum R_c-a 100.00 10.00 Ta = 25 °C Ta = 55 °C 1.00 Ta = 85 °C Ta = 105 °C 0.10 0.01 300 800 1300 1800 2300 2800 Current (mA) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS125 REV 7A 12 XLAMP ® CXB3070 LED NOTES Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs. Lumen Maintenance Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. REACh Compliance REACh substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative to insure you get the most up-to-date REACh Declaration. REACh banned substance information (REACh Article 67) is also available upon request. UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS125 REV 7A 13 XLAMP ® CXB3070 LED PACKAGING CXB3070 LEDs are packaged in trays of 20. Five trays are sealed in an anti-static bag and placed inside a carton, for a total of 100 LEDs per carton. Each carton contains 100 LEDs from the same performance bin. 6 5 4 3 2 . Tolerances: ±.13 5 7.53 6 1 Dimensions are in inches. NOTICE DENTIAL. THIS PLOT AND THE INFORMATION WITHIN ARE THE PROPRIETARY AND AL INFORMATION OF CREE, INC. THIS PLOT COPIED, REPRODUCED OR DISCLOSED TO ANY 4 3 5 R .375 4 x° ±1° 2 3 1 2 1 OTICE PLOT AND THE INFORMATION HE PROPRIETARY AND ION OF CREE, INC. THIS PLOT NSENT RODUCED OR DISCLOSED TO ANY 7.53 R .375 5.875 R .375 D 1.313 8.15 .875 1.313 8.15 C .38 LABEL WITH CREE BIN CODE, QUANTITY, LOT# BAG 1.313 PATENT LABELIS LOCATED ON UNDERSIDE OF CARTON .38 PATENT IS LOCATED LABEL WITH CREELABEL BIN ON UNDERSIDE OF 1.313 CARTON CODE, QUANTITY, LOT# PATENT LABELIS LOCATED BAG LABEL WITH BAG CREE BIN CODE, QUANTITY, LOT# .38 TH CREE BIN .875 ON UNDERSIDE OF CARTON ANTITY, LOT # B L IS LOCATED IDE OF COVER LABEL WITH CREE BIN CODE, QUANTITY, LOT# OTHERWISE SPECIFIED LABEL WITH CREE BINUNLESSDIMENSIONS ARE IN & BEFORE FINISH. CODE, QUANTITY, LOTMILLIMETERS # TOLERANCE UNLESS SPECIFIED: LABEL WITH CREE BIN LABEL WITH CREE BIN CODE, QUANTITY, LOT# CODE, QUANTITY, LOT # .X ± .XX ± .XXX ± X° ± THIRD ANGLE PROJECTION 6 LABEL WITH CREE BIN CODE, QUANTITY, LOT# 4 .X ± .XX ± .XXX ± X° ± 0.1 .05 .005 1 ° FOR SHEET METAL PARTS ONLY .X ± .06 .XX ± .03 .XXX ± .010 X° ± 2 ° 5 4 DATE APPROVED DATE UNLESS OTHERWISE SPECIFIED 3 DIMENSIONS ARE IN MILLIMETERS & BEFORE FINISH. TOLERANCE UNLESS SPECIFIED: X° ± Phone (919) 36 CXA30XX_DATASHEET MATERIAL SIZE DATE FINAL PROTECTIVE FINISH SCALE DATE C 0.500 2 APPROVED DRAWING NO. CXA30XX_DATASHEET_BAG_2013 4600 Silicon Drive Durham, N.C 27703 SHEET Phone (919) 361-4770 1 Fax (919) 313-5303 DATE TITLE SIZE FINAL PROTECTIVE FINISH DATE DRAWN BY SCALE CXA30XX_DATASHEET_BAG_2013 SHEET 0.500 1 DATE A OF 1 /1 4600 Silicon Drive Durham, N.C 27703 Phone (919) 361-4770 DATE TITLE CLD-DS125 REV 7A 14 Fax (919) 313-5303 CXA15XX_DATASHEET 1 ° SIZE FINAL PROTECTIVE FINISH A REV. DRAWING NO. C 2 CHECK O CXA30XX_DATASHEET MATERIAL © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered and APPROVED .X ± trademarks, 0.1 .XXUL logo ± .05 the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the are registered .XXX ± .005 trademarks of UL LLC. THIRD ANGLE PROJECTION MATERIAL FOR SHEET METAL PARTS ONLY .X ± .06 4600 Silicon Dr Durham, N.C 2 TITLE TOLERANCE UNLESS SPECIFIED: 3 THIRD ANGLE PROJECTION WITH CREE BIN 6 QUANTITY, LOT # DATE CHECK Fax (919) 313-5 0.1 .05 .005 1 ° FOR SHEET METAL PARTS ONLY .X ± .06 DRAWN BY ± .03 UNLESS OTHERWISE SPECIFIED.XX .010 DIMENSIONS ARE IN .XXX ± ± CHECK 2 ° MILLIMETERS & BEFORE FINISH. X° 5 DRAWN BY DRAWING NO. CXA15XX_DATASHEET_BAG2013
CXB3070-0000-000N0UZ435G 价格&库存
很抱歉,暂时无法提供与“CXB3070-0000-000N0UZ435G”相匹配的价格&库存,您可以联系我们找货
