CXA3590-0000-000N0HBD0E1
    WOLFSPEED
    LED COB CXA3590 COOL WHT SQUARE
CXA3590-0000-000N0HBD0E1 数据手册
PRODUCT FAMILY DATA SHEET XLamp® CXA3590 LED PRODUCT DESCRIPTION FEATURES TABLE OF CONTENTS The XLamp® CXA3590 LED array expands • Available in 4-step, 3‑step and 2-step Characteristics................................................ 2 Cree LED’s family of high‑flux, multi‑die EasyWhite bins at 2700 K, 3000 K, Operating Limits.............................................. 3 integrated arrays, offering high performance 3500 K, 4000 K & 5000 K CCT and Flux Characteristics, EasyWhite® Order in an easy-to-use platform. With XLamp 4-step EasyWhite bins at 5700 K & Codes and Bins - 36 V..................................... 4 LED lighting‑class reliability, the CXA3590’s 6500 K CCT Flux Characteristics, ANSI White Order ® uniform emitting surface enables both • Available in ANSI white bins at 5000 K, Codes and Bins - 36 V..................................... 7 directional and non‑directional lighting Flux Characteristics, EasyWhite® Order 5700 K & 6500 K CCT applications and luminaire and lamp • Available in 70-, 80-, 90- and designs. Available in 2‑step, 3‑step and 93‑minimum CRI options Codes and Bins - 72 V..................................... 8 Flux Characteristics, ANSI White Order 4‑step color consistency, and featuring a • Forward voltage options: 36‑V class & Codes and Bins - 72 V................................... 11 30‑mm optical source, the CXA3590 brings Relative Spectral Power Distribution........... 12 72‑V class new levels of flux and efficacy to this form • 85 °C binning and characterization Electrical Characteristics.............................. 13 factor. • Maximum drive current: 3600 mA Relative Luminous Flux................................. 14 (36 V), 1800 mA (72 V) Typical Spatial Distribution........................... 16 The CX Family LED Design Guide provides • 115° viewing angle, uniform Performance Groups - Brightness............... 16 basic information on the requirements Performance Groups - Chromaticity............ 17 chromaticity profile to use the CXA3590 LED successfully in • Top-side solder connections EasyWhite® Bins Plotted on the 1931 CIE luminaire designs. • Thermocouple attach point Color Space................................................... 20 • NEMA SSL-3 2011 standard flux bins ANSI White Bins Plotted on the 1931 CIE • RoHS and REACh compliant Color Space................................................... 20 • UL® recognized component (E349212) Bin and Order Code Formats........................ 21 Mechanical Dimensions............................... 21 Thermal Design............................................. 22 Notes............................................................. 24 Packaging...................................................... 25 Cree LED / 4400 Silicon Drive / Durham, NC 27703 USA / +1.919.313.5330 / www.cree-led.com © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS81 REV 9A 1 XLAMP ® CXA3590 LED CHARACTERISTICS Characteristics Viewing angle (FWHM) ESD withstand voltage (HBM per Mil-Std-883D) Unit Minimum Typical degrees Maximum 115 V 8000 DC forward current (36 V) mA 3600* DC forward current (72 V) mA 1800* Reverse current (36 V, 72 V ) mA 0.1 Forward voltage (36 V, @ 2400 mA, Tj = 85 °C) V Forward voltage (36 V, @ 2400 mA, Tj = 25 °C) V Forward voltage (72 V, @ 1200 mA, Tj = 85 °C) V Forward voltage (72 V, @ 1200 mA, Tj = 25 °C) V * ** 36** 41** 72** 81** Refer to the Operating Limits section. For CXA3590 LEDs having order codes with a CXA3590-xxxx-xxxN0xxxxxx or CXA3590-xxxx-xxxR0xxxxxx format, the forward voltage values are as follows: Characteristics Unit Forward voltage (36 V, @ 2400 mA, Tj = 85 °C) V Forward voltage (36 V, @ 2400 mA, Tj = 25 °C) V Forward voltage (72 V, @ 1200 mA, Tj = 85 °C) V Forward voltage (72 V, @ 1200 mA, Tj = 25 °C) V Minimum Typical © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Maximum 38.5 42 77 84 CLD-DS81 REV 9A 2 XLAMP ® CXA3590 LED OPERATING LIMITS The maximum current rating of the CXA3590 depends on the case temperature (Tc) when the LED has reached thermal equilibrium under steady-state operation. The graphs shown below assume that the system design employs good thermal management (thermal interface material and heat sink) and may vary when poor thermal management is employed. Please refer to the Mechanical Dimensions section on page 21 for the location of the Tc measurement point. Another important factor in good thermal management is the temperature of the Light Emitting Surface (LES). Cree LED recommends a maximum LES temperature of 135 °C to ensure optimal LED lifetime. Please refer to the Thermal Design section on page 22 for more CXA3590 information on LES temperature measurement. 4000 3600 3200 2800 If (mA) 2400 36 V 2000 1600 1200 800 400 0 0 25 50 75 100 125 150 Case Temperature (°C) 2000 1800 1600 1400 If (mA) 1200 72 V 1000 800 600 400 200 0 0 25 50 75 100 125 150 Case Temperature (°C) © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS81 REV 9A 3 XLAMP ® CXA3590 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 36 V (IF = 2400 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA3590 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 21). Nominal CCT CRI Min 70 6500 K 80 90 70 Minimum Luminous Flux Typ 75 --- 95 75 Group Flux (lm) Flux (lm) @ 85 °C @ 25 °C* 2-Step Group Order Code 3-Step Group Order Code 4-Step Group CXA3590-0000000NT0BD65F BD 10,000 11,286 CB 11,000 12,414 CD 12,000 13,543 CXA3590-0000000NT0CD65F BB 9,500 10,721 CXA3590-0000000NTHBB65F BD 10,000 11,286 CB 11,000 12,414 CXA3590-0000000NTHCB65F Z4 7,945 8,967 CXA3590-0000000NTUZ465F AB 8,500 9,593 AD 9,000 10,157 CXA3590-0000000NTUAD65F BD 10,000 11,286 CXA3590-0000000NT0BD57F CB 11,000 12,414 CD 12,000 13,543 CXA3590-0000000NT0CD57F BB 9,500 10,721 CXA3590-0000000NTHBB57F BD 10,000 11,286 CB 11,000 12,414 65F 65F 65F 57F 5700 K 80 --- Order Code 57F CXA3590-0000000NT0CB65F CXA3590-0000000NTHBD65F CXA3590-0000000NTUAB65F CXA3590-0000000NT0CB57F CXA3590-0000000NTHBD57F CXA3590-0000000NTHCB57F Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 24). • CXA3590 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS81 REV 9A 4 XLAMP ® CXA3590 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 36 V (IF = 2400 mA, TJ = 85 °C) - CONTINUED Nominal CCT CRI Min 70 Minimum Luminous Flux Typ 75 Group Flux (lm) Flux (lm) @ 85 °C @ 25 °C* 2-Step Group 90 70 --- 10,000 11,286 CB 11,000 12,414 CD 12,000 13,543 CXA3590-0000000NT0CD50H BB 9,500 10,721 CXA3590-0000000NTHBB50H BD 10,000 11,286 CB 11,000 12,414 AB 8,500 9,593 95 75 50H 50H 90 80 --- 50H --- 3500 K 93 CXA3590-0000000NT0CB50H CXA3590-0000000NTHBD50H CXA3590-0000000NTUAB50H AD 9,000 10,157 CXA3590-0000000NTUAD50H BB 9,500 10,721 CXA3590-0000000NT0BB40H BD 10,000 11,286 CB 11,000 12,414 CXA3590-0000000NT0CB40H AD 9,000 10,157 CXA3590-0000000NTHAD40H BB 9,500 10,721 BD 10,000 11,286 Z4 7,945 8,967 95 Order Code Group 40H 40H 50F CXA3590-0000000NTHBB50G 50G CXA3590-0000000NTHBD50G CXA3590-0000000NTUZ440H CXA3590-0000000NTHBB50F 50F CXA3590-0000000NTHCB50G 50G CXA3590-0000000NTUAB50G CXA3590-0000000NTUAD50G CXA3590-0000000NTHBD50F CXA3590-0000000NTHCB50F 50F CXA3590-0000000NTUAB50F CXA3590-0000000NTUAD50F CXA3590-0000000NT0BB40F 40F CXA3590-0000000NT0BD40F CXA3590-0000000NT0CB40F CXA3590-0000000NTHAD40G 40G CXA3590-0000000NTHBD40H 40H CXA3590-0000000NT0CB50F CXA3590-0000000NT0CD50F CXA3590-0000000NT0BD40H CXA3590-0000000NTHBB40H Order Code CXA3590-0000000NT0BD50F CXA3590-0000000NTHCB50H 4000 K 80 Group 4-Step CXA3590-0000000NT0BD50H BD 5000 K 80 Order Code 3-Step CXA3590-0000000NTHBB40G CXA3590-0000000NTHAD40F 40F CXA3590-0000000NTHBD40G 40G CXA3590-0000000NTUZ440G CXA3590-0000000NTHBD40F 40F CXA3590-0000000NTUZ440F AB 8,500 9,593 CXA3590-0000000NTUAB40H AD 9,000 10,157 CXA3590-0000000NT0AD35H BB 9,500 10,721 BD 10,000 11,286 CXA3590-0000000NT0BD35H CXA3590-0000000NT0BD35G CXA3590-0000000NT0BD35F Z2 7,390 8,340 CXA3590-0000000NTYZ235H CXA3590-0000000NTYZ235G CXA3590-0000000NTYZ235F Z4 7,945 8,967 95 35H 35H CXA3590-0000000NT0BB35H CXA3590-0000000NTYZ435H CXA3590-0000000NTUAB40G CXA3590-0000000NTHBB40F CXA3590-0000000NT0AD35G 35G 35G CXA3590-0000000NT0BB35G CXA3590-0000000NTYZ435G CXA3590-0000000NTUAB40F CXA3590-0000000NT0AD35F 35F 35F CXA3590-0000000NT0BB35F CXA3590-0000000NTYZ435F Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 24). • CXA3590 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS81 REV 9A 5 XLAMP ® CXA3590 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 36 V (IF = 2400 mA, TJ = 85 °C) - CONTINUED Nominal CCT CRI Min 80 Minimum Luminous Flux Typ --- 3000 K 93 80 Flux (lm) Flux (lm) @ 85 °C @ 25 °C* --- Group Order Code 3-Step Group CXA3590-0000000NT0AD30H Order Code 4-Step Group CXA3590-0000000NT0AD30G Order Code CXA3590-0000000NT0AD30F AD 9,000 10,157 BB 9,500 10,721 BD 10,000 11,286 CXA3590-0000000NT0BD30H CXA3590-0000000NT0BD30G CXA3590-0000000NT0BD30F Z2 7,390 8,340 CXA3590-0000000NTYZ230H CXA3590-0000000NTYZ230G CXA3590-0000000NTYZ230F Z4 7,945 8,967 CXA3590-0000000NTYZ430H AB 8,500 9,593 CXA3590-0000000NT0AB27H AD 9,000 10,157 BB 9,500 10,721 CXA3590-0000000NT0BB27H CXA3590-0000000NT0BB27G CXA3590-0000000NT0BB27F Y4 6,910 7,798 CXA3590-0000000NTYY427H CXA3590-0000000NTYY427G CXA3590-0000000NTYY427F Z2 7,390 8,340 95 2700 K 93 Group 2-Step 30H 30H 95 27H 27H CXA3590-0000000NT0BB30H CXA3590-0000000NT0AD27H CXA3590-0000000NTYZ227H 30G 30G CXA3590-0000000NT0BB30G CXA3590-0000000NTYZ430G 30F 30F CXA3590-0000000NT0AB27G 27G 27G CXA3590-0000000NT0AD27G CXA3590-0000000NTYZ227G CXA3590-0000000NT0BB30F CXA3590-0000000NTYZ430F CXA3590-0000000NT0AB27F 27F 27F CXA3590-0000000NT0AD27F CXA3590-0000000NTYZ227F Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 24). • CXA3590 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS81 REV 9A 6 XLAMP ® CXA3590 LED FLUX CHARACTERISTICS, ANSI WHITE ORDER CODES AND BINS - 36 V (IF = 2400 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA3590 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 21). CCT Range CRI Min 70 Minimum Luminous Flux Typ 75 6500 K 80 70 --- 75 5700 K 80 70 --- 75 5000 K 80 --- Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* BD 10,000 11,286 Chromaticity Regions Order Code CXA3590-0000-000NT0BD0E1 CB 11,000 12,414 CD 12,000 13,543 1A0, 1B0, 1C0, 1D0, 65F CXA3590-0000-000NT0CD0E1 BB 9,500 11,286 CXA3590-0000-000NTHBB0E1 BD 10,000 12,414 CB 11,000 13,543 CXA3590-0000-000NTHCB0E1 BD 10,000 11,286 CXA3590-0000-000NT0BD0E2 CB 11,000 12,414 CD 12,000 13,543 CXA3590-0000-000NT0CD0E2 BB 9,500 11,286 CXA3590-0000-000NTHBB0E2 BD 10,000 12,414 CB 11,000 13,543 CXA3590-0000-000NTHCB0E2 BD 10,000 11,286 CXA3590-0000-000NT0BD0E3 CB 11,000 12,414 CD 12,000 13,543 CXA3590-0000-000NT0CD0E3 BB 9,500 11,286 CXA3590-0000-000NTHBB0E3 BD 10,000 12,414 CB 11,000 13,543 1A0, 1B0, 1C0, 1D0, 65F 2A0, 2B0, 2C0, 2D0, 57F 2A0, 2B0, 2C0, 2D0, 57F 3A0, 3B0, 3C0, 3D0, 50F 3A0, 3B0, 3C0, 3D0, 50F CXA3590-0000-000NT0CB0E1 CXA3590-0000-000NTHBD0E1 CXA3590-0000-000NT0CB0E2 CXA3590-0000-000NTHBD0E2 CXA3590-0000-000NT0CB0E3 CXA3590-0000-000NTHBD0E3 CXA3590-0000-000NTHCB0E3 Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 24). • CXA3590 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS81 REV 9A 7 XLAMP ® CXA3590 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 72 V (IF = 1200 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA3590 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 21). Nominal CCT CRI Min 70 6500 K 80 90 70 Minimum Luminous Flux Typ 75 --- 95 75 Group Flux (lm) Flux (lm) @ 85 °C @ 25 °C* 2-Step Group Order Code 3-Step Group Order Code 4-Step Group CXA3590-0000000RT0BD65F BD 10,000 11,286 CB 11,000 12,414 CD 12,000 13,543 CXA3590-0000000RT0CD65F BB 9,500 10,721 CXA3590-0000000RTHBB65F BD 10,000 11,286 CB 11,000 12,414 CXA3590-0000000RTHCB65F Z4 7,945 8,967 CXA3590-0000000RTUZ465F AB 8,500 9,593 AD 9,000 10,157 CXA3590-0000000RTUAD65F BD 10,000 11,286 CXA3590-0000000RT0BD57F CB 11,000 12,414 CD 12,000 13,543 CXA3590-0000000RT0CD57F BB 9,500 10,721 CXA3590-0000000RTHBB57F BD 10,000 11,286 CB 11,000 12,414 65F 65F 65F 57F 5700 K 80 --- Order Code 57F CXA3590-0000000RT0CB65F CXA3590-0000000RTHBD65F CXA3590-0000000RTUAB65F CXA3590-0000000RT0CB57F CXA3590-0000000RTHBD57F CXA3590-0000000RTHCB57F Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 24). • CXA3590 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS81 REV 9A 8 XLAMP ® CXA3590 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 72 V (IF = 1200 mA, TJ = 85 °C) - CONTINUED Nominal CCT CRI Min 70 Minimum Luminous Flux Typ 75 Group Flux (lm) Flux (lm) @ 85 °C @ 25 °C* 2-Step Group 90 70 --- 10,000 11,286 CB 11,000 12,414 CD 12,000 13,543 CXA3590-0000000RT0CD50H BB 9,500 10,721 CXA3590-0000000RTHBB50H BD 10,000 11,286 CB 11,000 12,414 AB 8,500 9,593 95 75 50H 50H 90 80 --- 50H --- 3500 K 93 CXA3590-0000000RT0CB50H CXA3590-0000000RTHBD50H CXA3590-0000000RTUAB50H AD 9,000 10,157 CXA3590-0000000RTUAD50H BB 9,500 10,721 CXA3590-0000000RT0BB40H BD 10,000 11,286 CB 11,000 12,414 CXA3590-0000000RT0CB40H AD 9,000 10,157 CXA3590-0000000RTHAD40H BB 9,500 10,721 BD 10,000 11,286 Z4 7,945 8,967 95 Order Code Group 40H 40H 50F CXA3590-0000000RTHBB50G 50G CXA3590-0000000RTHBD50G CXA3590-0000000RTUZ440H CXA3590-0000000RTHBB50F 50F CXA3590-0000000RTHCB50G 50G CXA3590-0000000RTUAB50G CXA3590-0000000RTUAD50G CXA3590-0000000RTHBD50F CXA3590-0000000RTHCB50F 50F CXA3590-0000000RTUAB50F CXA3590-0000000RTUAD50F CXA3590-0000000RT0BB40F 40F CXA3590-0000000RT0BD40F CXA3590-0000000RT0CB40F CXA3590-0000000RTHAD40G 40G CXA3590-0000000RTHBD40H 40H CXA3590-0000000RT0CB50F CXA3590-0000000RT0CD50F CXA3590-0000000RT0BD40H CXA3590-0000000RTHBB40H Order Code CXA3590-0000000RT0BD50F CXA3590-0000000RTHCB50H 4000 K 80 Group 4-Step CXA3590-0000000RT0BD50H BD 5000 K 80 Order Code 3-Step CXA3590-0000000RTHBB40G CXA3590-0000000RTHAD40F 40F CXA3590-0000000RTHBD40G 40G CXA3590-0000000RTUZ440G CXA3590-0000000RTHBD40F 40F CXA3590-0000000RTUZ440F AB 8,500 9,593 CXA3590-0000000RTUAB40H AD 9,000 10,157 CXA3590-0000000RT0AD35H BB 9,500 10,721 BD 10,000 11,286 CXA3590-0000000RT0BD35H CXA3590-0000000RT0BD35G CXA3590-0000000RT0BD35F Z2 7,390 8,340 CXA3590-0000000RTYZ235H CXA3590-0000000RTYZ235G CXA3590-0000000RTYZ235F Z4 7,945 8,967 95 35H 35H CXA3590-0000000RT0BB35H CXA3590-0000000RTYZ435H CXA3590-0000000RTUAB40G CXA3590-0000000RTHBB40F CXA3590-0000000RT0AD35G 35G 35G CXA3590-0000000RT0BB35G CXA3590-0000000RTYZ435G CXA3590-0000000RTUAB40F CXA3590-0000000RT0AD35F 35F 35F CXA3590-0000000RT0BB35F CXA3590-0000000RTYZ435F Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 24). • CXA3590 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS81 REV 9A 9 XLAMP ® CXA3590 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 72 V (IF = 1200 mA, TJ = 85 °C) - CONTINUED Nominal CCT CRI Min 80 Minimum Luminous Flux Typ --- 3000 K 93 80 Flux (lm) Flux (lm) @ 85 °C @ 25 °C* --- Group Order Code 3-Step Group CXA3590-0000000RT0AD30H Order Code 4-Step Group CXA3590-0000000RT0AD30G Order Code CXA3590-0000000RT0AD30F AD 9,000 10,157 BB 9,500 10,721 BD 10,000 11,286 CXA3590-0000000RT0BD30H CXA3590-0000000RT0BD30G CXA3590-0000000RT0BD30F Z2 7,390 8,340 CXA3590-0000000RTYZ230H CXA3590-0000000RTYZ230G CXA3590-0000000RTYZ230F Z4 7,945 8,967 CXA3590-0000000RTYZ430H AB 8,500 9,593 CXA3590-0000000RT0AB27H AD 9,000 10,157 BB 9,500 10,721 CXA3590-0000000RT0BB27H CXA3590-0000000RT0BB27G CXA3590-0000000RT0BB27F Y4 6,910 7,798 CXA3590-0000000RTYY427H CXA3590-0000000RTYY427G CXA3590-0000000RTYY427F Z2 7,390 8,340 95 2700 K 93 Group 2-Step 30H 30H 95 27H 27H CXA3590-0000000RT0BB30H CXA3590-0000000RT0AD27H CXA3590-0000000RTYZ227H 30G 30G CXA3590-0000000RT0BB30G CXA3590-0000000RTYZ430G 30F 30F CXA3590-0000000RT0AB27G 27G 27G CXA3590-0000000RT0AD27G CXA3590-0000000RTYZ227G CXA3590-0000000RT0BB30F CXA3590-0000000RTYZ430F CXA3590-0000000RT0AB27F 27F 27F CXA3590-0000000RT0AD27F CXA3590-0000000RTYZ227F Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 24). • CXA3590 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS81 REV 9A 10 XLAMP ® CXA3590 LED FLUX CHARACTERISTICS, ANSI WHITE ORDER CODES AND BINS - 72 V (IF = 1200 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA3590 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 21). CCT Range CRI Min 70 Minimum Luminous Flux Typ 75 6500 K 80 70 --- 75 5700 K 80 70 --- 75 5000 K 80 --- Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* BD 10,000 11,286 Chromaticity Regions Order Code CXA3590-0000-000RT0BD0E1 CB 11,000 12,414 CD 12,000 13,543 1A0, 1B0, 1C0, 1D0, 65F CXA3590-0000-000RT0CD0E1 BB 9,500 11,286 CXA3590-0000-000RTHBB0E1 BD 10,000 12,414 CB 11,000 13,543 CXA3590-0000-000RTHCB0E1 BD 10,000 11,286 CXA3590-0000-000RT0BD0E2 CB 11,000 12,414 CD 12,000 13,543 CXA3590-0000-000RT0CD0E2 BB 9,500 11,286 CXA3590-0000-000RTHBB0E2 BD 10,000 12,414 CB 11,000 13,543 CXA3590-0000-000RTHCB0E2 BD 10,000 11,286 CXA3590-0000-000RT0BD0E3 CB 11,000 12,414 CD 12,000 13,543 CXA3590-0000-000RT0CD0E3 BB 9,500 11,286 CXA3590-0000-000RTHBB0E3 BD 10,000 12,414 CB 11,000 13,543 1A0, 1B0, 1C0, 1D0, 65F 2A0, 2B0, 2C0, 2D0, 57F 2A0, 2B0, 2C0, 2D0, 57F 3A0, 3B0, 3C0, 3D0, 50F 3A0, 3B0, 3C0, 3D0, 50F CXA3590-0000-000RT0CB0E1 CXA3590-0000-000RTHBD0E1 CXA3590-0000-000RT0CB0E2 CXA3590-0000-000RTHBD0E2 CXA3590-0000-000RT0CB0E3 CXA3590-0000-000RTHBD0E3 CXA3590-0000-000RTHCB0E3 Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 24). • CXA3590 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS81 REV 9A 11 XLAMP ® CXA3590 LED Relative Spectral Power Distribution RELATIVE SPECTRAL POWER DISTRIBUTION The following graph is the result of a series of pulsed measurements at 2400  mA for the 36-V CXA3590 and 1200  mA for the 72‑V CXA3590 and TJ = 85 °C. 100% Relative Spectral Power 90% 80% 70% 60% 5000 K, 70 CRI 50% 4000 K, 70 CRI 40% 3000 K, 80 CRI 30% 3000 K, 93 CRI 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS81 REV 9A 12 XLAMP ® CXA3590 LED ELECTRICAL CHARACTERISTICS The following graphs are the result of a series of steady-state measurements. 39 36 V 38 Voltage (V) 37 36 Tc = 25 °C Tc = 55 °C 35 Tc = 85 °C 34 Tc = 105 °C 33 32 31 400 800 1200 1600 2000 2400 2800 3200 3600 Current (mA) 78 72 V 76 Voltage (V) 74 72 Tc = 25 °C Tc = 55 °C 70 Tc = 85 °C 68 Tc = 105 °C 66 64 62 200 400 600 800 1000 1200 1400 1600 1800 Current (mA) © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS81 REV 9A 13 XLAMP ® CXA3590 LED RELATIVE LUMINOUS FLUX The relative luminous flux values provided below are the ratio of: • Measurements of CXA3590 at steady-state operation at the given conditions, divided by • Flux measured during binning, which is a pulsed measurement at 2400 mA at TJ = 85 °C for the 36‑V CXA3590. Using the 36-V CXA3590 LED as an example, at steady-state operation of Tc = 25 °C, IF = 1200 mA, the relative luminous flux ratio is 60% in the chart below. A CXA3590 LED that measures 11,000 lm during binning will deliver 6,600 lm (11,000 * 0.6) at steady-state operation of Tc = 25 °C, IF = 1200 mA. 160% 36 V Relative Luminous Flux 140% 120% Tc = 25 °C 100% Tc = 55 °C 80% Tc = 85 °C Tc = 105 °C 60% 40% 20% 0% 400 800 1200 1600 2000 2400 2800 3200 3600 Current (mA) © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS81 REV 9A 14 XLAMP ® CXA3590 LED RELATIVE LUMINOUS FLUX - CONTINUED The relative luminous flux values provided below are the ratio of: • Measurements of CXA3590 at steady-state operation at the given conditions, divided by • Flux measured during binning, which is a pulsed measurement at 1200 mA at TJ = 85 °C for the 72‑V CXA3590. Using the 72-V CXA3590 LED as an example, at steady-state operation of Tc = 25 °C, IF = 800 mA, the relative luminous flux ratio is 80% in the chart below. A CXA3590 LED that measures 11,000 lm during binning will deliver 8,800 lm (11,000 * 0.8) at steady-state operation of Tc = 25 °C, IF = 800 mA. 160% 72 V Relative Luminous Flux 140% 120% Tc = 25 °C 100% Tc = 55 °C 80% Tc = 85 °C Tc = 105 °C 60% 40% 20% 0% 200 400 600 800 1000 1200 1400 1600 1800 Current (mA) © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS81 REV 9A 15 XLAMP ® CXA3590 LED Far Field TYPICAL SPATIAL DISTRIBUTION Relative Luminous Intensity 100% 80% 60% 40% 20% -90 -70 -50 -30 -10 0% 10 30 50 70 90 Angle (º) PERFORMANCE GROUPS - BRIGHTNESS (36 V, I F = 2400 mA; 72 V IF = 1200 mA, TJ = 85 °C) XLamp CXA3590 LEDs are tested for luminous flux and placed into one of the following bins. Group Code Minimum Luminous Flux Maximum Luminous Flux Y4 6,910 7,390 Z2 7,390 7,945 Z4 7,945 8,500 AB 8,500 9,000 AD 9,000 9,500 BB 9,500 10,000 BD 10,000 11,000 CB 11,000 12,000 CD 12,000 13,000 DB 13,000 14,000 © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS81 REV 9A 16 XLAMP ® CXA3590 LED PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) XLamp CXA3590 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. EasyWhite Color Temperatures – 2-Step Code 50H 40H 35H 30H 27H CCT 5000 K 4000 K 3500 K 3000 K 2700 K x y 0.3429 0.3507 0.3434 0.3571 0.3475 0.3604 0.3469 0.3539 0.3784 0.3741 0.3804 0.3818 0.3867 0.3857 0.3844 0.3778 0.4030 0.3857 0.4061 0.3941 0.4132 0.3976 0.4099 0.3890 0.4291 0.3973 0.4333 0.4062 0.4395 0.4084 0.4351 0.3994 0.4528 0.4046 0.4578 0.4138 0.4638 0.4152 0.4586 0.4060 EasyWhite Color Temperatures – 3-Step Ellipse Bin Code CCT 50G 40G Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 5000 K 0.3447 0.3553 0.00840 0.00312 65.0 4000 K 0.3818 0.3797 0.00939 0.00402 53.7 35G 3500 K 0.4073 0.3917 0.00927 0.00414 54.0 30G 3000 K 0.4338 0.4030 0.00834 0.00408 53.2 27G 2700 K 0.4577 0.4099 0.00834 0.00420 48.5 © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS81 REV 9A 17 XLAMP ® CXA3590 LED PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) - CONTINUED EasyWhite Color Temperatures – 4-Step Code 65F 57F 50F 40F 35F 30F 27F CCT 6500 K 5700 K 5000 K 4000 K 3500 K 3000 K 2700 K x y 0.3097 0.3196 0.3079 0.3297 0.3164 0.3382 0.3176 0.3275 0.3253 0.3325 0.3249 0.3439 0.3331 0.3514 0.3330 0.3393 0.3407 0.3459 0.3415 0.3586 0.3499 0.3654 0.3484 0.3521 0.3744 0.3685 0.3782 0.3837 0.3912 0.3917 0.3863 0.3758 0.3981 0.3800 0.4040 0.3966 0.4186 0.4037 0.4116 0.3865 0.4242 0.3919 0.4322 0.4096 0.4449 0.4141 0.4359 0.3960 0.4475 0.3994 0.4573 0.4178 0.4695 0.4207 0.4589 0.4021 © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS81 REV 9A 18 XLAMP ® CXA3590 LED PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) - CONTINUED ANSI White Bins Code CCT Bin Code 1A0 1B0 0E1 6500 K 1C0 1D0 ANSI White Bins x y 0.3048 0.3207 0.3130 0.3290 0.3144 0.3186 0.3068 Code CCT Bin Code x y 0.3215 0.3350 0.3290 0.3417 0.3290 0.3300 0.3113 0.3222 0.3243 0.3028 0.3304 0.3207 0.3462 0.3115 0.3391 0.3290 0.3538 0.3130 0.3290 0.3290 0.3417 0.3048 0.3207 0.3215 0.3350 0.3115 0.3391 0.3290 0.3538 0.3205 0.3481 0.3376 0.3616 0.3213 0.3373 0.3371 0.3490 0.3130 0.3290 0.3290 0.3417 0.3130 0.3290 0.3290 0.3417 0.3213 0.3373 0.3371 0.3490 0.3221 0.3261 0.3366 0.3369 0.3144 0.3186 0.3290 0.3300 2A0 2B0 0E2 5700 K 2C0 2D0 ANSI White Bins Code CCT Bin Code 3A0 3B0 0E3 5000 K 3C0 3D0 x y .3371 .3490 .3451 .3554 .3440 .3427 .3366 .3369 .3376 .3616 .3463 .3687 .3451 .3554 .3371 .3490 .3463 .3687 .3551 .3760 .3533 .3620 .3451 .3554 .3451 .3554 .3533 .3620 .3515 .3487 .3440 .3427 © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS81 REV 9A 19 XLAMP ® CXA3590 LED EASYWHITE® BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) 0.44 2700 K ANSI C78.377 Quadrangle 0.43 3000 K EasyWhite 4-Step EasyWhite 3-Step 0.42 EasyWhite 2-Step 3500 K 0.41 4000 K 0.40 4500 K CCy 0.39 5000 K 0.38 0.37 5700 K 0.36 6500 K 0.35 0.34 0.33 0.32 0.49 0.48 0.47 0.45 0.41 0.46 0.44 0.40 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.31 CCx ANSI WHITE BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) 0.41 4000 K ANSI C78.377 Quadrangle 0.40 4500 K 0.39 5000 K 0.38 CCy 0.37 5700 K 0.36 3C 3B 6500 K 0.35 2B 0.34 1C 1B 0.33 3D 2C 1D 3A 2D 2A 1A 0.32 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.31 CCx © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS81 REV 9A 20 XLAMP ® CXA3590 LED BIN AND ORDER CODE FORMATS Bin codes and order codes are configured as follows: Order Code Bin Code Series = CXA35 Series = CXA35 Internal code Chromaticity bin CRI Specification 0 = Standard CRI H = 80 CRI minimum U = 90 CRI minimum Y = 93 CRI minimum Vf class NT = 36-V class RT = 72-V class Internal code SSSSSCC-WWW-FF-GGR-AAAAA SSSSSCC-HHHH-HHHGGRNNNNN Kit code 6 5 NOTICE CREE CONFIDENTIAL. THIS PLOT AND THE INFORMATION CONTAINED WITHIN ARE THE PROPRIETARY AND CONFIDENTIAL INFORMATION OF CREE, INC. THIS PLOT MAY NOT BE COPIED, REPRODUCED OR DISCLOSED TO ANY UNAUTHORIZED PERSON THE WITHOUT WRITTEN CONSENT OF CREE INC. CRI Specification B = 70 CRI minimum 3 H = 80 CRI minimum U = 90 CRI minimum Y = 93 CRI minimum 4 Vf class NT = 36-V class RT = 72-V class D REV Flux bin Performance class Performance class MECHANICAL DIMENSIONS Dimensions are in mm. 34.85 ± 0.2 Tolerances unless otherwise specified: +.13 15.764 4.0 C Tc 1.300 12.16 1.15 ± 0.15 3590X x° +1° 4.0 Meaning of 3590X 3590N = 36‑V CXA3590 15.902 14.25 3590R = 72‑V CXA3590 OPTICAL REFERENCE 34.85 ± 0.2 B 30.00 ± 0.2 15.902 32.00 ± 0.2 4.0 0.55 ± 0.1 4.0 15.764 OPTICAL REFERENCE A TOLERANCE UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MM .X logo ± are .10 © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree and the Cree registered trademarks, and .XX ± .03 the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered .XXX ± .010 trademarks of UL LLC. X° ± 1° ® 6 5 4 DRAW UNLESS OTHERWISE SPECIFIE D. CRO DIMENSIONS ARE IN INCHES AND AFTER FINISH.CHECK TOLERANCE UNLESS SPECIFIE .XX ± .01 APPRO .XXX± .005 X° ± .5° THIRD ANGLE PROJECTION MATER FOR SHEET METAL PARTS ON CLD-DS81 .X ± .06 REV 9A .XX ± .03 .XXX± .010 FINAL P X° ± .5° 63 SURFACE FINISH: 21 3 XLAMP ® CXA3590 LED THERMAL DESIGN The CXA family of LED arrays can include over a hundred different LED die inside one package, and thus over a hundred different junction temperatures (TJ). Cree LED has intentionally removed junction-temperature-based operating limits and replaced the commonplace maximum TJ calculations with maximum ratings based on forward current (IF) and case temperature (Tc). No additional calculations are required to ensure that the CXA LED is being operated within its designed limits. LES temperature measurement provides additional verification of good thermal design. Please refer to page 22 for the Operating Limit specifications. There is no need to calculate for TJ inside the package, as the thermal management design process, specifically from TSP to ambient (Ta), remains identical to any other LED component. For more information on thermal management of XLamp LEDs, please refer to the Thermal Management application note. For CXA soldering recommendations and more information on thermal interface materials (TIM), LES temperature measurement, and connection methods, please refer to the XLamp CX Family LEDs soldering and handling document. The CX Family LED Design Guide provides basic information on the requirements to use XLamp CXA LEDs successfully in luminaire designs. To keep the CXA3590 LED at or below the maximum rated Tc, the case to ambient temperature thermal resistance (R_c-a) must be at or below the maximum R_c-a value shown on the following R_j-c R_j-c scale. Tc Tc As the figure at right shows, the R_c-a value is the sum of the thermal resistance of the TIM (R_tim) R_tim graph, depending on the operating environment. The y‑axis in each graph is a base 10 logarithmic R_c-a plus the thermal resistance of the heat sink (R_hs). R_hs CXA3590 Ta Ta 100.00 36 V Maximum R_c-a 10.00 Ta = 25 °C Ta = 55 °C 1.00 Ta = 85 °C Ta = 105 °C 0.10 0.01 400 800 1200 1600 2000 2400 2800 3200 3600 Current (mA) © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS81 REV 9A 22 XLAMP ® CXA3590 LED THERMAL DESIGN - CONTINUED Maximum R_c-a 100.00 72 V 10.00 Ta = 25 °C Ta = 55 °C 1.00 Ta = 85 °C Ta = 105 °C 0.10 0.01 200 400 600 800 1000 1200 1400 1600 1800 Current (mA) © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS81 REV 9A 23 XLAMP ® CXA3590 LED NOTES Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs. Lumen Maintenance Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. REACh Compliance REACh substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative to insure you get the most up-to-date REACh Declaration. REACh banned substance information (REACh Article 67) is also available upon request. UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS81 REV 9A 24 XLAMP ® CXA3590 LED PACKAGING CXA3590 LEDs are packaged in trays of 10. Five trays are sealed in an anti-static bag and placed inside a carton, for a total of 50 LEDs per carton. Each carton contains 50 LEDs from the same performance bin. Dimensions are in inches. Tolerances: +.13 7.500 5 7.500 4 3 R.375 x° +1° 2 1 R.375 NSENT 5.875 R .375 8.125 1.59 1.59 8.125 .875 LABEL WITH CREE BIN CODE, LABEL WITH CREE BIN CODE, QUANTITY, LOT # QUANTITY, LOT # 1.59 1.59 0.38 0.38 PATENT LABEL IS LOCATED ON UNDERSIDE OF CARTON TH CREE BIN ANTITY, LOT # .875 .38 BAG L IS LOCATED IDE OF COVER LABEL WITH CREE BIN CODE, QUANTITY, LOT # WITH CREE BIN QUANTITY, LOT # LABEL WITH CREE BIN CODE, QUANTITY, LOT # UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS & BEFORE FINISH. TOLERANCE UNLESS SPECIFIED: DRAWN BY DATE CHECK DATE © 2013-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered and APPROVED .X ± trademarks, 0.1 ± .05 registered the Cree LED logo is a trademark, of Wolfspeed Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the.XXUL logo are .XXX ± .005 trademarks of UL LLC. THIRD ANGLE PROJECTION MATERIAL X° ± 1 ° FOR SHEET METAL PARTS ONLY .X ± .06 4600 Silicon Drive Durham, N.C 27703 Phone (919) 361-4770 DATE TITLE 25 Fax (919) 313-5303 CXA15XX_DATASHEET SIZE FINAL PROTECTIVE FINISH CLD-DS81 REV 9A DRAWING NO. CXA15XX_DATASHEET_BAG2013
物料型号:XLamp® CXA3590 LED
器件简介:XLamp® CXA3590 LED阵列扩展了Cree LED的高通量多芯片集成阵列家族,提供了易于使用平台上的高性能。具有XLamp LED照明级可靠性,CXA3590的均匀发射表面支持定向和非定向照明应用以及照明和灯具设计。
引脚分配:文档中未明确提供引脚分配信息。
参数特性: - 视场角:115° - 静电抗电压(HBM):8000V - 直流正向电流(36V):3600 mA - 直流正向电流(72V):1800 mA - 反向电流(36V, 72V):0.1 mA - 正向电压(36V, 85°C):36V - 正向电压(36V, 25°C):41V - 正向电压(72V, 85°C):72V - 正向电压(72V, 25°C):81V
功能详解:CXA3590 LED提供EasyWhite®和ANSI白色选项,具有不同的色温(CCT)和色容差(CRI)选项。它还具有4步色一致性,并且具有高通量和效率。
应用信息:适用于照明和灯具设计,包括定向和非定向照明应用。
封装信息:CXA3590 LED的封装信息包括尺寸、光学参考、热设计等,具体尺寸数据和公差在文档中有详细描述。
CXA3590-0000-000N0HBD0E1 价格&库存
很抱歉,暂时无法提供与“CXA3590-0000-000N0HBD0E1”相匹配的价格&库存,您可以联系我们找货
