CXB3590-0000-000R0BDB50E
    WOLFSPEED
    LEDCOBCXB35905000KWHTSMD
CXB3590-0000-000R0BDB50E 数据手册
PRODUCT FAMILY DATA SHEET XLamp® CXB3590 LED PRODUCT DESCRIPTION FEATURES TABLE OF CONTENTS The XLamp® CXB3590 LED Array is the • 30‑mm optical source Characteristics................................................ 2 brightest member of the second generation • Mechanical and optical design Operating Limits.............................................. 3 of the CXA family that delivers up to 30% consistent with CXA35 LED Flux Characteristics, EasyWhite® Order higher efficacy and up to 20% higher lumens • Available in 70-, 80- and 90-minimum Codes and Bins - 36 V..................................... 4 than the first generation in the same LES. Flux Characteristics, EasyWhite® Order CRI options The higher performance second generation • EasyWhite 2-, 3‑ and 5-step binning Codes and Bins - 72 V..................................... 7 CXA Relative Spectral Power Distribution........... 10 ® LED Arrays provide a drop-in • Forward voltage options: 36‑V class & performance upgrade to existing CXA LED 72‑V class Electrical Characteristics.............................. 11 designs to shorten product development • 85 °C binning and characterization Relative Luminous Flux................................. 12 time. Available in 2‑step, 3‑step and 5‑step • Extremely uniform color over viewing Typical Spatial Distribution........................... 14 EasyWhite bins, the CXB3590 LED delivers Performance Groups - Brightness............... 14 ® high lumen output and high efficacy in a angle • Top-side solder connections Performance Groups - Chromaticity............ 15 single, easy-to-use package that eliminates • Thermocouple attach point EasyWhite® Bins Plotted on the 1931 CIE the need for reflow soldering. • NEMA SSL-3 2011 standard flux bins Curve.............................................................. 16 • RoHS and REACh compliant Bin and Order Code Formats........................ 17 The CX Family LED Design Guide provides • UL recognized component (E349212) Mechanical Dimensions............................... 17 basic information on the requirements Thermal Design............................................. 18 to use the CXB3590 LED successfully in Notes............................................................. 20 luminaire designs. Packaging...................................................... 21 ® Cree LED / 4400 Silicon Drive / Durham, NC 27703 USA / +1.919.313.5330 / www.cree-led.com © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS126 REV 4A 1 XLAMP ® CXB3590 LED CHARACTERISTICS Characteristics Viewing angle (FWHM) ESD withstand voltage (HBM per Mil-Std-883D) Unit Minimum Typical degrees Maximum 115 V 8000 DC forward current (36 V) mA 3600* DC forward current (72 V) mA 1800* Reverse current (36 V, 72 V ) mA 0.1 Forward voltage (36 V, @ 2400 mA, Tj = 85 °C) V 36 39 Forward voltage (72 V, @ 1200 mA, Tj = 85 °C) V 72 78 * Refer to the Operating Limits section. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS126 REV 4A 2 XLAMP ® CXB3590 LED OPERATING LIMITS The maximum current rating of the CXB3590 depends on the case temperature (Tc) when the LED has reached thermal equilibrium under steady-state operation. The graphs shown below assume that the system design employs good thermal management (thermal interface material and heat sink) and may vary when poor thermal management is employed. Please refer to the Mechanical Dimensions section on page 17 for the location of the Tc measurement point. Another important factor in good thermal management is the temperature of the Light Emitting Surface (LES). Cree LED recommends a maximum LES temperature of 135 °C to ensure optimal LED lifetime. Please refer to the Thermal Design section on page 18 for more information on LES temperature measurement. 4000 3600 3200 2800 If (mA) 2400 36 V 2000 1600 1200 800 400 0 0 25 50 75 100 125 150 Case Temperature (°C) CXB3590 2000 1800 1600 1400 If (mA) 1200 72 V 1000 800 600 400 200 0 0 25 50 75 100 125 150 Case Temperature (°C) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS126 REV 4A 3 XLAMP ® CXB3590 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 36 V (IF = 2400 mA, TJ = 85 °C) The following table provides order codes for XLamp CXB3590 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 17). CRI* Nominal CCT Min 70 Minimum Luminous Flux Typ --- 2-Step 3-Step 5-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** CD 12,000 13,237 DB 13,000 14,340 DD 14,000 15,443 CXB3590-0000000N0BDD65E CB 11,000 12,134 CXB3590-0000000N0HCB65E CD 12,000 13,237 DB 13,000 14,340 CXB3590-0000000N0HDB65E CD 12,000 13,237 CXB3590-0000000N0BCD57E DB 13,000 14,340 DD 14,000 15,443 CXB3590-0000000N0BDD57E CB 11,000 12,134 CXB3590-0000000N0HCB57E CD 12,000 13,237 DB 13,000 14,340 BD 10,000 11,031 CB 11,000 12,134 CD 12,000 13,237 Group Order Code Group Order Code Group CXB3590-0000000N0BCD65E 65E 6500 K 80 70 5700 K 80 90 --- --- --- 92 Order Code 65E 57E 57E CXB3590-0000000N0BDB65E CXB3590-0000000N0HCD65E CXB3590-0000000N0BDB57E CXB3590-0000000N0HCD57E CXB3590-0000000N0HDB57E CXB3590-0000000N0UBD57G 57G CXB3590-0000000N0UCB57G CXB3590-0000000N0UCD57G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 20). • CXB3590 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS126 REV 4A 4 XLAMP ® CXB3590 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 36 V (IF = 2400 mA, TJ = 85 °C) - CONTINUED CRI* Nominal CCT Min 70 5000 K 80 90 70 4000 K 80 90 Minimum Luminous Flux Typ --- --- 92 --- --- 92 2-Step 3-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** CD 12,000 13,237 DB 13,000 14,340 DD 14,000 15,443 CB 11,000 12,134 CD 12,000 13,237 DB 13,000 14,340 CXB3590-0000000N0HDB50G BD 10,000 11,031 CXB3590-0000000N0UBD50G CB 11,000 12,134 CD 12,000 13,237 CD 12,000 13,237 DB 13,000 14,340 DD 14,000 15,443 CB 11,000 12,134 CD 12,000 13,237 DB 13,000 14,340 CXB3590-0000000N0HDB40H CXB3590-0000000N0HDB40G BB 9,500 10,479 CXB3590-0000000N0UBB40H CXB3590-0000000N0UBB40G BD 10,000 11,031 CB 11,000 12,134 Group Order Code Group Order Code 5-Step Group Order Code CXB3590-0000000N0BCD50E 50E CXB3590-0000000N0BDB50E CXB3590-0000000N0BDD50E CXB3590-0000000N0HCB50G 50G 50G CXB3590-0000000N0HCD50G CXB3590-0000000N0HCB50E 50E CXB3590-0000000N0HCD50E CXB3590-0000000N0UCB50G CXB3590-0000000N0UCD50G CXB3590-0000000N0BCD40E 40E CXB3590-0000000N0BDB40E CXB3590-0000000N0BDD40E CXB3590-0000000N0HCB40H 40H 40H CXB3590-0000000N0HCD40H CXB3590-0000000N0UBD40H CXB3590-0000000N0UCB40H CXB3590-0000000N0HCB40G 40G 40G CXB3590-0000000N0HCD40G CXB3590-0000000N0UBD40G CXB3590-0000000N0UCB40G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 20). • CXB3590 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS126 REV 4A 5 XLAMP ® CXB3590 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 36 V (IF = 2400 mA, TJ = 85 °C) - CONTINUED CRI* Nominal CCT Min 80 Minimum Luminous Flux Typ 90 80 92 --- 3000 K 90 80 90 Flux (lm) @ 85 °C Flux (lm) @ 25 °C** CB 11,000 12,134 CD 12,000 13,237 CXB3590-0000000N0HCD35H BB 9,500 10,479 CXB3590-0000000N0UBB35H BD 10,000 11,031 CB 11,000 12,134 CXB3590-0000000N0UCB35H CXB3590-0000000N0UCB35G BD 10,000 11,031 CXB3590-0000000N0HBD30H CXB3590-0000000N0HBD30G CB 11,000 12,134 CD 12,000 13,237 CXB3590-0000000N0HCD30H CXB3590-0000000N0HCD30G BB 9,500 10,479 CXB3590-0000000N0UBB30H CXB3590-0000000N0UBB30G BD 10,000 11,031 BD 10,000 11,031 35H 30H 30H --- 92 Group 35H 92 2700 K 3-Step Group --- 3500 K 2-Step 27H Order Code CXB3590-0000000N0HCB35H CXB3590-0000000N0UBD35H CXB3590-0000000N0HCB30H CXB3590-0000000N0UBD30H CXB3590-0000000N0HBD27H CB 11,000 12,134 CXB3590-0000000N0HCB27H AD 9,000 9,928 CXB3590-0000000N0UAD27H BB 9,500 10,479 BD 10,000 11,031 27H CXB3590-0000000N0UBB27H CXB3590-0000000N0UBD27H Group 35G Order Code 5-Step Group Order Code CXB3590-0000000N0HCB35G CXB3590-0000000N0HCD35G CXB3590-0000000N0UBB35G 35G 30G 30G 27G CXB3590-0000000N0UBD35G CXB3590-0000000N0HCB30G CXB3590-0000000N0UBD30G CXB3590-0000000N0HBD27G CXB3590-0000000N0HCB27G CXB3590-0000000N0UAD27G 27G CXB3590-0000000N0UBB27G CXB3590-0000000N0UBD27G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 20). • CXB3590 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS126 REV 4A 6 XLAMP ® CXB3590 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 72 V (IF = 1200 mA, TJ = 85 °C) The following table provides order codes for XLamp CXB3590 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 17). CRI* Nominal CCT Min 70 Minimum Luminous Flux Typ --- 2-Step 3-Step 5-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** CD 12,000 13,237 DB 13,000 14,340 DD 14,000 15,443 CXB3590-0000000R0BDD65E CB 11,000 12,134 CXB3590-0000000R0HCB65E CD 12,000 13,237 DB 13,000 14,340 CXB3590-0000000R0HDB65E CD 12,000 13,237 CXB3590-0000000R0BCD57E DB 13,000 14,340 DD 14,000 15,443 CXB3590-0000000R0BDD57E CB 11,000 12,134 CXB3590-0000000R0HCB57E CD 12,000 13,237 DB 13,000 14,340 BD 10,000 11,031 CB 11,000 12,134 CD 12,000 13,237 Group Order Code Group Order Code Group CXB3590-0000000R0BCD65E 65E 6500 K 80 70 5700 K 80 90 --- --- --- 92 Order Code 65E 57E 57E CXB3590-0000000R0BDB65E CXB3590-0000000R0HCD65E CXB3590-0000000R0BDB57E CXB3590-0000000R0HCD57E CXB3590-0000000R0HDB57E CXB3590-0000000R0UBD57G 57G CXB3590-0000000R0UCB57G CXB3590-0000000R0UCD57G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 20). • CXB3590 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS126 REV 4A 7 XLAMP ® CXB3590 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 72 V (IF = 1200 mA, TJ = 85 °C) - CONTINUED CRI* Nominal CCT Min 70 5000 K 80 90 70 4000 K 80 90 Minimum Luminous Flux Typ --- --- 92 --- --- 92 2-Step 3-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C** CD 12,000 13,237 DB 13,000 14,340 DD 14,000 15,443 CB 11,000 12,134 CD 12,000 13,237 DB 13,000 14,340 CXB3590-0000000R0HDB50G BD 10,000 11,031 CXB3590-0000000R0UBD50G CB 11,000 12,134 CD 12,000 13,237 CD 12,000 13,237 DB 13,000 14,340 DD 14,000 15,443 CB 11,000 12,134 CD 12,000 13,237 DB 13,000 14,340 CXB3590-0000000R0HDB40H CXB3590-0000000R0HDB40G BB 9,500 10,479 CXB3590-0000000R0UBB40H CXB3590-0000000R0UBB40G BD 10,000 11,031 CB 11,000 12,134 Group Order Code Group Order Code 5-Step Group Order Code CXB3590-0000000R0BCD50E 50E CXB3590-0000000R0BDB50E CXB3590-0000000R0BDD50E CXB3590-0000000R0HCB50G 50G 50G CXB3590-0000000R0HCD50G CXB3590-0000000R0HCB50E 50E CXB3590-0000000R0HCD50E CXB3590-0000000R0UCB50G CXB3590-0000000R0UCD50G CXB3590-0000000R0BCD40E 40E CXB3590-0000000R0BDB40E CXB3590-0000000R0BDD40E CXB3590-0000000R0HCB40H 40H 40H CXB3590-0000000R0HCD40H CXB3590-0000000R0UBD40H CXB3590-0000000R0UCB40H CXB3590-0000000R0HCB40G 40G 40G CXB3590-0000000R0HCD40G CXB3590-0000000R0UBD40G CXB3590-0000000R0UCB40G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 20). • CXB3590 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS126 REV 4A 8 XLAMP ® CXB3590 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 72 V (IF = 1200 mA, TJ = 85 °C) - CONTINUED CRI* Nominal CCT Min 80 Minimum Luminous Flux Typ 90 80 92 --- 3000 K 90 80 90 Flux (lm) @ 85 °C Flux (lm) @ 25 °C** CB 11,000 12,134 CD 12,000 13,237 CXB3590-0000000R0HCD35H BB 9,500 10,479 CXB3590-0000000R0UBB35H BD 10,000 11,031 CB 11,000 12,134 CXB3590-0000000R0UCB35H CXB3590-0000000R0UCB35G BD 10,000 11,031 CXB3590-0000000R0HBD30H CXB3590-0000000R0HBD30G CB 11,000 12,134 CD 12,000 13,237 CXB3590-0000000R0HCD30H CXB3590-0000000R0HCD30G BB 9,500 10,479 CXB3590-0000000R0UBB30H CXB3590-0000000R0UBB30G BD 10,000 11,031 BD 10,000 11,031 35H 30H 30H --- 92 Group 35H 92 2700 K 3-Step Group --- 3500 K 2-Step 27H Order Code CXB3590-0000000R0HCB35H CXB3590-0000000R0UBD35H CXB3590-0000000R0HCB30H CXB3590-0000000R0UBD30H CXB3590-0000000R0HBD27H CB 11,000 12,134 CXB3590-0000000R0HCB27H AD 9,000 9,928 CXB3590-0000000R0UAD27H BB 9,500 10,479 BD 10,000 11,031 27H CXB3590-0000000R0UBB27H CXB3590-0000000R0UBD27H Group 35G Order Code 5-Step Group Order Code CXB3590-0000000R0HCB35G CXB3590-0000000R0HCD35G CXB3590-0000000R0UBB35G 35G 30G 30G 27G CXB3590-0000000R0UBD35G CXB3590-0000000R0HCB30G CXB3590-0000000R0UBD30G CXB3590-0000000R0HBD27G CXB3590-0000000R0HCB27G CXB3590-0000000R0UAD27G 27G CXB3590-0000000R0UBB27G CXB3590-0000000R0UBD27G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 20). • CXB3590 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. ** Flux values @ 25 °C are calculated and for reference only. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS126 REV 4A 9 XLAMP ® CXB3590 LED RELATIVE SPECTRAL POWER DISTRIBUTION Relative Spectral Power Distribution The following graph is the result of a series of pulsed measurements at 2400  mA for the 36-V CXB3590 and 1200  mA for the 72‑V CXB3590 and TJ = 85 °C. 100% Relative Spectral Power 90% 80% 70% 60% 5000 K, 70 CRI 50% 4000 K, 70 CRI 40% 3000 K, 80 CRI 30% 3000 K, 90 CRI 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS126 REV 4A 10 XLAMP ® CXB3590 LED ELECTRICAL CHARACTERISTICS The following graphs are the result of a series of steady-state measurements. 38.5 38.0 36 V 37.5 Voltage (V) 37.0 Tc = 25 °C 36.5 Tc = 55 °C 36.0 Tc = 85 °C 35.5 Tc = 105 °C 35.0 34.5 34.0 33.5 1400 1600 1800 2000 2200 2400 2600 2800 3000 3200 3400 3600 Current (mA) 77 76 72 V 75 Voltage (V) 74 Tc = 25 °C 73 Tc = 55 °C 72 Tc = 85 °C 71 Tc = 105 °C 70 69 68 67 700 800 900 1000 1100 1200 1300 1400 1500 1600 1700 1800 Current (mA) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS126 REV 4A 11 XLAMP ® CXB3590 LED RELATIVE LUMINOUS FLUX The relative luminous flux values provided below are the ratio of: • Measurements of CXB3590 at steady-state operation at the given conditions, divided by • Flux measured during binning, which is a pulsed measurement at 2400 mA at TJ = 85 °C for the 36‑V CXB3590. Using the 36-V CXB3590 LED as an example, at steady-state operation of Tc = 25 °C, IF = 2800 mA, the relative luminous flux ratio is 120% in the chart below. A CXB3590 LED that measures 11,000 lm during binning will deliver 13,200 lm (11,000 * 1.2) at steady-state operation of Tc = 25 °C, IF = 2800 mA. 150% 36 V Relative Luminous Flux 120% Tc = 25 °C 90% Tc = 55 °C Tc = 85 °C 60% Tc = 105 °C 30% 0% 1400 1600 1800 2000 2200 2400 2600 2800 3000 3200 3400 3600 Current (mA) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS126 REV 4A 12 XLAMP ® CXB3590 LED RELATIVE LUMINOUS FLUX - CONTINUED The relative luminous flux values provided below are the ratio of: • Measurements of CXB3590 at steady-state operation at the given conditions, divided by • Flux measured during binning, which is a pulsed measurement at 1200 mA at TJ = 85 °C for the 72‑V CXB3590. Using the 72-V CXB3590 LED as an example, at steady-state operation of Tc = 25 °C, IF = 1400 mA, the relative luminous flux ratio is 120% in the chart below. A CXB3590 LED that measures 11,000 lm during binning will deliver 13,200 lm (11,000 * 1.2) at steady-state operation of Tc = 25 °C, IF = 1400 mA. Relative Luminous Flux 150% 72 V 120% Tc = 25 °C 90% Tc = 55 °C Tc = 85 °C 60% Tc = 105 °C 30% 0% 700 800 900 1000 1100 1200 1300 1400 1500 1600 1700 1800 Current (mA) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS126 REV 4A 13 XLAMP ® CXB3590 LED Far Field TYPICAL SPATIAL DISTRIBUTION 100% Relative Luminous Intensity 80% 60% 40% 20% -90 -70 -50 -30 -10 0% 10 30 50 70 90 Angle (º) PERFORMANCE GROUPS - BRIGHTNESS (36 V, I F = 2400 mA; 72 V, IF = 1200 mA, TJ = 85 °C) XLamp CXB3590 LEDs are tested for luminous flux and placed into one of the following bins. Group Code Minimum Luminous Flux Maximum Luminous Flux AD 9,000 9,500 BB 9,500 10,000 BD 10,000 11,000 CB 11,000 12,000 CD 12,000 13,000 DB 13,000 14,000 DD 14,000 15,000 EB 15,000 16,000 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS126 REV 4A 14 XLAMP ® CXB3590 LED PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) XLamp CXB3590 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. EasyWhite Color Temperatures – 2-Step Code 40H 35H 30H 27H CCT 4000 K 3500 K 3000 K 2700 K x y 0.3777 0.3739 0.3797 0.3816 0.3861 0.3855 0.3838 0.3777 0.4022 0.3858 0.4053 0.3942 0.4125 0.3977 0.4091 0.3891 0.4287 0.3975 0.4328 0.4064 0.4390 0.4086 0.4347 0.3996 0.4524 0.4048 0.4574 0.4140 0.4633 0.4154 0.4581 0.4062 EasyWhite Color Temperatures – 3-Step Ellipse Bin Code CCT 65G 57G Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 6500 K 0.3123 0.3282 0.00666 0.00330 61.0 5700 K 0.3287 0.3417 0.00738 0.00360 72.0 50G 5000 K 0.3447 0.3553 0.00840 0.00312 65.0 40G 4000 K 0.3818 0.3797 0.00939 0.00402 53.7 35G 3500 K 0.4073 0.3917 0.00927 0.00414 54.0 30G 3000 K 0.4338 0.4030 0.00834 0.00408 53.2 27G 2700 K 0.4577 0.4099 0.00834 0.00420 48.5 EasyWhite Color Temperatures – 5-Step Ellipse Bin Code CCT 65E Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 6500 K 0.3123 0.3282 0.01110 0.00550 61.0 57E 5700 K 0.3287 0.3417 0.01230 0.00600 72.0 50E 5000 K 0.3447 0.3553 0.01400 0.00520 65.0 40E 4000 K 0.3818 0.3797 0.01565 0.00670 53.7 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS126 REV 4A 15 XLAMP ® CXB3590 LED EASYWHITE® BINS PLOTTED ON THE 1931 CIE CURVE 0.44 2700 K ANSI C78.377 Quadrangle 0.43 3000 K EasyWhite 5-step EasyWhite 3-step 0.42 3500 K EasyWhite 2-step 0.41 4000 K 0.40 4500 K CCy 0.39 5000 K 0.38 0.37 5700 K 0.36 6500 K 0.35 0.34 0.33 0.32 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.31 CCx © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS126 REV 4A 16 XLAMP ® CXB3590 LED BIN AND ORDER CODE FORMATS Bin codes and order codes are configured as follows: Order Code Bin Code Series = CXA35 Series = CXA35 Internal code Chromaticity bin CRI Specification 0 = Standard CRI H = 80 CRI minimum U = 90 CRI minimum Y = 93 CRI minimum SSSSSCC-HHHH-HHHGGRNNNNN Vf class N0 = 36-V class R0 = 72-V class Internal code SSSSSCC-WWW-FF-GGR-AAAAA CRI Specification B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Y = 93 CRI minimum Kit code Vf class N0 = 36-V class R0 = 72-V class Flux bin Performance class Performance class MECHANICAL DIMENSIONS Dimensions are in mm. Tolerances unless otherwise specified: ±.13 x° ±1° B3590X Meaning of B3590X B3590N = 36‑V CXB3590 B3590R = 72‑V CXB3590 © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS126 REV 4A 17 XLAMP ® CXB3590 LED THERMAL DESIGN The CXB family of LED arrays can include over a hundred different LED die inside one package, and thus over a hundred different junction temperatures (TJ). Cree LED has intentionally removed junction-temperature-based operating limits and replaced the commonplace maximum TJ calculations with maximum ratings based on forward current (IF) and case temperature (Tc). No additional calculations are required to ensure that the CXB LED is being operated within its designed limits. LES temperature measurement provides additional verification of good thermal design. Please refer to page 22 for the Operating Limit specifications. There is no need to calculate for TJ inside the package, as the thermal management design process, specifically from TSP to ambient (Ta), remains identical to any other LED component. For more information on thermal management of XLamp LEDs, please refer to the Thermal Management application note. For CXB soldering recommendations and more information on thermal interface materials (TIM), LES temperature measurement, and connection methods, please refer to the XLamp CX Family LEDs soldering and handling document. The CX Family LED Design Guide provides basic information on the requirements to use XLamp CXB LEDs successfully in luminaire designs. To keep the CXB3590 LED at or below the maximum rated Tc, the case to ambient temperature thermal resistance (R_c-a) must be at or below the maximum R_c-a value shown on the following graph, depending on the operating environment. The y‑axis in each graph is a base 10 logarithmic scale. As the figure at right shows, the R_c-a value is the sum of the thermal resistance of the TIM (R_tim) R_j-c R_j-c Tc Tc R_tim R_c-a plus the thermal resistance of the heat sink (R_hs). R_hs Ta Ta Maximum R_c-a 100.00 36 V 10.00 Ta = 25 °C Ta = 55 °C 1.00 Ta = 85 °C Ta = 105 °C 0.10 0.01 400 800 1200 1600 2000 2400 2800 3200 3600 Current (mA) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS126 REV 4A 18 XLAMP ® CXB3590 LED CXB3590 THERMAL DESIGN - CONTINUED Maximum R_c-a 100.00 72 V 10.00 Ta = 25 °C Ta = 55 °C 1.00 Ta = 85 °C Ta = 105 °C 0.10 0.01 200 400 600 800 1000 1200 1400 1600 1800 Current (mA) © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS126 REV 4A 19 XLAMP ® CXB3590 LED NOTES Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs. Lumen Maintenance Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. REACh Compliance REACh substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative to insure you get the most up-to-date REACh Declaration. REACh banned substance information (REACh Article 67) is also available upon request. UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS126 REV 4A 20 XLAMP ® CXB3590 LED PACKAGING CXB3590 LEDs are packaged in trays of 10. Five trays are sealed in an anti-static bag and placed inside a carton, for a total of 50 LEDs per carton. Each carton contains 50 LEDs from the same performance bin. 6 5 4 3 2 Dimensions are in inches. 1 REVISONS TICE HIS PLOT AND THE INFORMATION E THE PROPRIETARY AND ATION OF CREE, INC. THIS PLOT EPRODUCED OR DISCLOSED TO ANY ON WITHOUTTHE WRITTEN CONSENT 5 4 Tolerances: ±.13 DESCRIPTION REV 7.500 7.500 R .375 3 BY DATE x° ±1° 2 APP'D 1 R.375 NSENT 1.59 5.875 1.59 R .375 8.125 8.125 .875 LABEL WITH CREE BIN CODE, QUANTITY, LOT # LABEL WITH CREE BIN CODE, QTY, LOT # 0.38 1.59 1.59 LABEL ABELPATENT IS LOCATED TED ONOF UNDERSIDE ERSIDE COVER OF COVER BAG PATENT LABEL IS LOCATED ON UNDERSIDE OF CARTON ITH CREE BIN ANTITY, LOT # .875 BAG BAG .38 EL IS LOCATED IDE OF COVER LABEL WITH CREE BIN CODE, QUANTITY, LOT # LABEL WITH CREE BIN CODE, QTY, LOT # LABEL WITH CREE BIN CODE, QUANTITY, LOT # LABEL WITH CREE BIN CODE, QUANTITY, LOT # TH CREE BIN ANTITY, LOT # THIRD ANGLE PROJECTION LABEL WITH CREE BIN CODE, QTY, LOT # UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN INCHES AND AFTER FINISH. TOLERANCE UNLESS SPECIFIED: .XX ± .01 .XXX ± .005 X° ± .5 ° FOR SHEET METAL PARTS ONLY .X ± .06 .XX ± .03 .XXX ± .010 X° ± .5 ° SURFACE FINISH: 6 5 L WITH CREE BIN QUANTITY, LOT # 4 DATE DRAWN BY D. CRONIN 4600 Silicon Drive Durham, N.C 27703 7/30/13 CHECK DATE APPROVED DATE Phone (919) 313-5300 Fax (919) 313-5558 TITLE LE3501 MARKETING SPEC MATERIAL SIZE FINAL PROTECTIVE FINISH SCALE 63 3 C DRAWING NO. DRAWN BY DATE CHECK DATE © 2015-2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered and APPROVED .X ± trademarks, 0.1 ± .05 registered the Cree LED logo is a trademark, of Wolfspeed, Inc. XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the.XXUL logo are .XXX ± .005 trademarks of UL LLC. THIRD ANGLE PROJECTION MATERIAL X° ± 2 4600 Silicon Drive Durham, N.C 27703 Phone (919) 361-4770 DATE TITLE CLD-DS126 REV 4A 21 Fax (919) 313-5303 CXA15XX_DATASHEET SIZE FINAL PROTECTIVE FINISH OF 1 1 ° FOR SHEET METAL PARTS ONLY .X ± .06 A SHEET 3.000 2 UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS & BEFORE FINISH. TOLERANCE UNLESS SPECIFIED: REV. LE3501 DRAWING NO. CXA15XX_DATASHEET_BAG2013
物料型号:CXB3590
器件简介: - 第二代CXA系列,提供高达30%的亮度和20%的流明输出。 - 机械和光学设计与第一代CXA35 LED保持一致。 - 提供70、80和90 CRI选项。 - 符合NEMA SSL-3 2011标准和RoHS、REACh合规性。
引脚分配:文档中未明确列出引脚分配,但提到了顶侧焊接连接。
参数特性: - 视场角:115度 - ESD耐受电压:8000V - 直流正向电流(36V):最高3600mA - 直流正向电流(72V):最高1800mA - 反向电流(36V, 72V):最高0.1mA - 正向电压(36V, 2400mA, Tj=85°C):36V至39V - 正向电压(72V, 1200mA, Tj=85°C):72V至78V
功能详解: - EasyWhite® 2-, 3-, 5-step binning选项。 - 正向电压选项:36V类和72V类。 - 85°C binning和特性化。
应用信息: - 适用于需要高亮度和高效率的应用场合。 - 顶侧焊接连接点和热电偶附着点。
封装信息: - 提供UL®认可的组件(E349212)。 - 包装信息:每箱50个LED,每个LED托盘10个,5个托盘密封在防静电袋内。
CXB3590-0000-000R0BDB50E 价格&库存
很抱歉,暂时无法提供与“CXB3590-0000-000R0BDB50E”相匹配的价格&库存,您可以联系我们找货
