LECGP2W-7U5V-1-0-F00-T01
    AMSOSRAM(艾迈斯半导体)
    LEDOSTARPROJ600NMGREEN
LECGP2W-7U5V-1-0-F00-T01 数据手册
2014-12-05 OSRAM OSTAR Projection Power Datasheet Version 2.6 LE CG P2W OSRAM OSTAR Projection Power is a high luminance LED for projection applications. Die OSRAM OSTAR Projection Power ist eine LED mit hoher Leuchtdichte für Projektionsanwendungen. Features: Besondere Merkmale: • • • • Package: OSTAR High Power Projection Technology: ThinGaN (UX:3) Viewing angle at 50 % IV: 130° Color: Cx = 0.32, Cy = 0.64 acc. to CIE 1931 (converted green) within λ = 500 ... 600 nm; 0.32 / 0.54 for full spectral range • Corrosion Robustness: Improved corrosion robustness • • • • Applications Anwendungen • Projection • Projektion 2014-12-05 Gehäusetyp: OSTAR High Power Projection Technologie: ThinGaN (UX:3) Abstrahlwinkel bei 50 % IV: 130° Farbe: Cx = 0.32, Cy = 0.64 nach CIE 1931 (konvertiertes Grün) im Bereich λ = 500 ... 600 nm; 0.32 / 0.54 für den gesamten Spektralbereich • Korrosionsstabilität: Verbesserte Korrosionsstabilität 1 Version 2.6 LE CG P2W Ordering Information Bestellinformation Type: Luminous Flux 1) page 22 Ordering Code Typ: Lichtstrom 1) Seite 22 Bestellnummer IF = 24000 mA ΦV [lm] LE CG P2W-7U6V-1 Note: 5600 ... 9000 Q65111A4304 The above Type Numbers represent the order groups which include only a few brightness groups (see page 5). Only one group will be shipped on each packing unit (there will be no mixing of two groups on each packing unit). E. g. LE CG P2W-7U6V-1 means that only one group 5V, 6V, 7U, 8U will be shippable for any packing unit. In order to ensure availability, single brightness groups will not be orderable. In a similar manner for colors where color chromaticity coordinate groups are measured and binned, single groups will be shipped on any one packing unit. LE CG P2W-7U6V-1 means that the device will be shipped within the specified limits. In order to ensure availability, single color chromaticity groups groups will not be orderable. Anm.: Die oben genannten Typbezeichnungen umfassen die bestellbaren Selektionen. Diese bestehen aus wenigen Helligkeitsgruppen (siehe Seite 5). Es wird nur eine einzige Helligkeitsgruppe pro Verpackungseinheit geliefert. Z. B. LE CG P2W-7U6V-1 bedeutet, dass in einer Verpackungseinheit nur eine der Helligkeitsgruppen 5V, 6V, 7U, 8U enhalten ist. Um die Liefersicherheit zu gewährleisten, können einzelne Helligkeitsgruppen nicht bestellt werden. Gleiches gilt für die Farben, bei denen Farbortgruppen gemessen und gruppiert werden. Pro Verpackungseinheit wird nur eine Farbortgruppe geliefert. Z.B. LE CG P2W-7U6V-1 bedeutet, dass in einer Verpackungseinheit nur eine der Farbortgruppen enthalten ist. LE CG P2W-7U6V-1 bedeutet, dass das Bauteil innerhalb der spezifizierten Grenzen geliefert wird. Um die Liefersicherheit zu gewährleisten, können einzelne Farbortgruppen nicht bestellt werden. 2014-12-05 2 Version 2.6 LE CG P2W Maximum Ratings Grenzwerte Parameter Symbol Values Unit Bezeichnung Symbol Werte Einheit Operating temperature range Betriebstemperatur Top -40 ... 125 °C Storage temperature range Lagertemperatur Tstg -40 ... 125 °C Junction temperature Sperrschichttemperatur Tj 150 °C Forward current Durchlassstrom (Tj = 150 °C; all dies operated in parallel) IF 400 ... 20000 mA 400 ... 32000 mA mA Forward current pulsed IF pulse Durchlassstrom gepulst (D = 0.7; f = 240 Hz; Tj = 150°C; all dies operated in parallel) Surge current Stoßstrom (tp ≤ 10 µs; D = 0.1; Tj = 150 °C; all dies operated in parallel) IFM 40000 Reverse voltage Sperrspannung (TBoard = 25 °C) VR not designed for reverse operation V 2 kV ESD withstand voltage VESD ESD Festigkeit (acc. to ANSI/ESDA/JEDEC JS-001 - HBM, Class 2) 2014-12-05 3 Version 2.6 LE CG P2W Characteristics (TBoard = 25 °C; IF = 24000 mA; all dies operated in parallel; f = 1000 Hz; tint = 100 ms; D = 0.5) Kennwerte Parameter Bezeichnung Symbol Values Unit Symbol Werte Einheit (typ.) (typ.) Cx Cy 0.318 0.642 - Wavelength at peak emission Wellenlänge d. emittierten Lichtes (typ.) λpeak 520 nm Spectral bandwidth at 50% Irel max Spektrale Bandbreite b. 50% Irel max (typ.) ∆λ 100 nm Viewing angle at 50 % IV Abstrahlwinkel bei 50 % IV (typ.) 2ϕ 130 ° Forward voltage 3) page 22 Durchlassspannung 3) Seite 22 (min.) (typ.) (max.) VF VF VF 3.20 3.55 4.30 V V V Deviation of forward voltage of all chips Abweichung der Durchlassspannung aller Chips (max.) VF 135 mV IR not designed for reverse operation Chromaticity coordinates acc. to CIE 1931 2) page 22 Farbkoordinaten nach CIE 1931 2) Seite 22 (within λ = 500 ... 600 nm) Reverse current Sperrstrom Partial Flux acc. CIE 127:2007 Partieller Fluss (ΦV 120° = x * ΦV 180°) (typ.) ΦE/V, 120° Radiating surface Abstrahlende Fläche (typ.) Acolor Thermal resistance junction / board 4) page 22 Wärmewiderstand Sperrschicht / Board 4) Seite 22 (typ.) Thermal resistance junction / board 4) page 22 Wärmewiderstand Sperrschicht / Board 4) Seite 22 (with efficiency η e = 18 %) (typ.) 2014-12-05 4 0.77 2.6 x 3.2 mm² Rth JB real 0.7 K/W Rth JB el 0.6 K/W Version 2.6 LE CG P2W Brightness Groups Helligkeitsgruppen Luminous Flux 1) page 22 Group 1) Seite 22 Luminous Flux 1) page 22 Lichtstrom 1) Seite 22 Gruppe Lichtstrom (min.) ΦV [lm] (max.) ΦV [lm] 7U 5600 6300 8U 6300 7100 5V 7100 8000 6V 8000 9000 Note: The standard shipping format for serial types includes either a lower family group, an upper family group or a grouping of all individual brightness groups of only a few brightness groups. Individual brightness groups cannot be ordered. Anm.: Die Standardlieferform von Serientypen beinhaltet entweder eine untere Familiengruppe, eine obere Familiengruppe oder eine Sammelgruppe, die aus nur wenigen Helligkeitsgruppen besteht. Einzelne Helligkeitsgruppen sind nicht bestellbar. 2014-12-05 5 Version 2.6 LE CG P2W Chromaticity Coordinate Groups 2) page 22 Farbortgruppen 2) Seite 22 within λ = 500 ... 600 nm 0,650 0,90 Cy Cy 0,80 0,70 0,60 0,50 0,640 0,40 0,30 0,20 0,10 0,00 0,00 0,10 0,20 0,30 0,40 0,50 0,60 0,630 0,310 0,70 Coordinates in reference to CIE 1931 (cx cy) Cx Color Chromaticity Groups 2) page 22 Farbortgruppen 2) Seite 22 Group Gruppe 1 2014-12-05 Cx Cy 0.3123 0.6378 0.3190 0.6478 0.3223 0.6311 0.3290 0.6411 6 0,320 0,330 Cx Version 2.6 LE CG P2W Group Name on Label Gruppenbezeichnung auf Etikett Example: 5V-1 Beispiel: 5V-1 Brightness Helligkeit Chromaticity Coordinate Farbort 5V 1 Note: No packing unit / tape ever contains more than one group for each selection. Anm.: In einer Verpackungseinheit / Gurt ist immer nur eine Gruppe für jede Selektion enthalten. 2014-12-05 7 Version 2.6 LE CG P2W Relative Spectral Emission - V(λ) = Standard eye response curve 5) page 22 Relative spektrale Emission - V(λ) = spektrale Augenempfindlichkeit 5) Seite 22 Φrel = f (λ); TJ = 25 °C; IF = 24000 mA; all dies operated in parallel Irel LE CG P2W 1,0 : true green : Vλ 0,8 0,6 0,4 0,2 0,0 350 400 450 500 550 600 650 700 750 800 λ [nm] Radiation Characteristics 5) page 22 Abstrahlcharakteristik 5) Seite 22 Irel = f (ϕ); TJ = 25 °C -20° -30° -10° ϕ [°] 0° 10° 20° 30° 40° 50° 60° 70° 80° 90° 100° 1,0 Ιv rel 0,9 -40° 0,8 -50° 0,7 0,6 -60° 0,5 0,4 -70° 0,3 0,2 -80° 0,1 -90° 0,0 -100° 2014-12-05 8 Version 2.6 LE CG P2W Relative partial flux 5) page 22 Relativer zonaler Lichtstromanteil 5) Seite 22 ΦV (2ϕ)/ΦV(180°) = f (ϕ); TJ = 25 °C ΦV(2ϕ) 1,0 ΦV(180°) 0,9 0,8 0,7 0,6 0,5 0,4 0,3 0,2 0,1 0,0 0 10 20 30 40 50 60 70 80 90 100 110 120 130 140 150 160 170 180 2*ϕ [°] Rel. cum. flux Φvrel-cum Relative cumulated Luminous flux 5) page 22 , 1) page 22 Relativer kummulierter Lichtstrom 5) Seite 22 , 1) Seite 22 ΦVrel - cum = f(λ), TJ = 25 °C 1,0 0,9 0,8 0,7 0,6 0,5 0,4 0,3 0,2 0,1 0,0 2014-12-05 400 450 500 550 600 9 650 700 750 800 λ [nm] Version 2.6 LE CG P2W Forward Current 5) page 22 Durchlassstrom 5) Seite 22 IF = f (VF); TJ = 25 °C; all dies operated in parallel Relative Luminous Flux 5) page 22 , 6) page 22 Relativer Lichtstrom 5) Seite 22 , 6) Seite 22 ΦV/ΦV (24000 mA) = f(IF); TJ = 25 °C; all dies operated in parallel LE CG P2W IF [mA] ΦV 30000 LE CG P2W 1,4 ΦV(24000mA) 1,2 25000 1,0 20000 0,8 15000 0,6 10000 0,4 5000 0,2 0,0 0 40 2,4 2,6 2,8 3,0 3,2 3,4 3,6 3,8 4,0 VF [V] 00 50 0 00 10 0 00 15 0 00 20 0 00 25 0 00 30 IF [mA] 2014-12-05 10 Version 2.6 LE CG P2W Chromaticity Coordinate Shift 5) page 22 Farbortverschiebung 5) Seite 22 ΔCx, ΔCy = f(IF); TJ = 25 °C full spectral range ∆Cx ∆Cy Chromaticity Coordinate Shift Farbortverschiebung 5) Seite 22 ΔCx, ΔCy = f(IF); TJ = 25 °C within λ = 500 ... 600 nm LE CG P2W 0,03 ∆Cx ∆Cy : ∆Cx : ∆Cy : ∆Cx : ∆Cy 0,02 0,01 0,01 0,00 0,00 -0,01 -0,01 -0,02 -0,02 -0,03 00 50 0 00 10 0 00 15 0 00 20 0 00 25 0 00 30 00 50 IF [mA] 2014-12-05 LE CG P2W(F) 0,03 0,02 -0,03 5) page 22 0 00 10 0 00 15 0 00 20 0 00 25 0 00 30 IF [mA] 11 Version 2.6 LE CG P2W Relative Forward Voltage 5) page 22 Relative Vorwärtsspannung 5) Seite 22 ΔVF = VF - VF(25 °C) = f(Tj); IF = 24000 mA; all dies operated in parallel ∆VF [V] Relative Luminous Flux 5) page 22 Relativer Lichtstrom 5) Seite 22 ΦV/ΦV (25 °C) = f(Tj); IF = 24000 mA; all dies operated in parallel Φv LE CG Q8WP 0,20 LE CG P2W 1,2 Φv(25°C) 0,15 1,0 0,10 0,8 0,05 0,6 0,00 -0,05 0,4 -0,10 0,2 -0,15 -0,20 -40 -20 0 20 40 60 0,0 -40 -20 80 100 120 Tj [°C] 2014-12-05 0 20 40 60 80 100 120 Tj [°C] 12 Version 2.6 LE CG P2W Chromaticity Coordinate Shift 5) page 22 Farbortverschiebung 5) Seite 22 ΔCx, ΔCy = f(Tj); IF = 24000 mA; all dies operated in parallel within λ = 500 ... 600 nm ∆Cx ∆Cy Chromaticity Coordinate Shift 5) page 22 Farbortverschiebung 5) Seite 22 ΔCx, ΔCy = f(Tj); IF = 24000 mA; all dies operated in parallel full spectral range LE CG P2W(F) 0,03 ∆Cx ∆Cy : ∆ Cx : ∆ Cy 0,02 0,01 0,01 0,00 0,00 -0,01 -0,01 -0,02 -0,02 0 20 40 60 -0,03 -40 -20 80 100 120 Tj [°C] 2014-12-05 : ∆ Cx : ∆ Cy 0,02 -0,03 -40 -20 LE CG P2W 0,03 0 20 40 60 80 100 120 Tj [°C] 13 Version 2.6 LE CG P2W Package Outline 7) page 22 Maßzeichnung 7) Seite 22 Approximate Weight: 5.0 g Gewicht: 5.0 g Connector Recommended connector: TARNG YU ENTERPRISE CO.,LTD / TA8051WNR-02S-A / PO: 4510445465 Stecker Empfohlener Stecker: TARNG YU ENTERPRISE CO.,LTD / TA8051WNR-02S-A / PO: 4510445465 Corrosion robustness: Test conditions: 40 °C / 90 % rh / 15 ppm H2S / 336 h = Stricter than IEC 60068-2-43 (H 2S) [25°C / 75 % rh / 10 ppm H 2S / 21 days] = Regarding relevant gas (H2S) stricter than EN 60068-2-60 (method 4) [25 °C / 75 % rh / 200 ppb SO2, 200 ppb NO2,10 ppb Cl2 / 21 days] 2014-12-05 14 Version 2.6 LE CG P2W Korrosionsfestigkeit: Test Kondition: 40°C / 90 % rh / 15 ppm H 2S / 336 h = Besser als IEC 60068-2-43 (H2S) [25°C / 75 % rh / 10 ppm H2S / 21 Tage] = Bezogen auf das Gas (H 2S) besser als EN 60068-2-60 (method 4) [25°C / 75 % rh / 200ppb SO2, 200ppb NO2,10ppb Cl2 / 21 Tage] Note: Package not suitable for any kind of wet cleaning or ultrasonic cleaning. Anm.: Das Gehäuse ist für alle Arten eine r nasschemischen Reinigung oder Ultraschallreinigung nicht geeignet. Data Matrix Code Description Data Matrix Code Beschreibung The Data Matrix Code bin information is Laser marked during testing Content: aaaa@bbbb@ccc@ddddd@eeeee Data Matrix Code Type: ECC200 a = Luminous Flux (Phiv) [lm] or Radiant Flux (Phie) [W] b = Forward Voltage (Vf ) [V] c = Wavelength (Ldom) [nm] d = Color Coordinate Cx e = Color Coordinate Cy @: Seperator = Blank (example: 3306) (example: 3.46) (example: 618) (example: 0.321) (example: 0.641) Die Bin -Information auf dem Datamatrix Code wird während des Testens geschrieben Inhalt: aaaa@bbbb@ccc@ddddd@eeeee Data Matrix Code Typ: ECC200 a = Lichtstrom (Phiv) [lm] oder Strahlleistung (Phie) [W] b = Vorwärtsspannung (Vf ) [V] c = Wellenlänge (Ldom) [nm] d = Farbkoordinate Cx d = Farbkoordinate Cy @: Platzhalter = Leerzeichen 2014-12-05 15 (Beispiel: 3306) (Beispiel: 3.46) (Beispiel: 618) (Beispiel: 0.321) (Beispiel: 0.641) Version 2.6 LE CG P2W Electrical Internal Circuit Internes Elektrisches Schaltbild 2014-12-05 16 Version 2.6 LE CG P2W Reflow Soldering Profile Reflow-Lötprofil OHA04525 300 ˚C T 250 Tp 245 ˚C 240 ˚C tP 217 ˚C 200 tL 150 tS 100 50 25 ˚C 0 0 50 100 150 200 250 s 300 t OHA04612 Profile Feature Profil-Charakteristik Symbol Symbol Pb-Free (SnAgCu) Assembly Minimum Ramp-up rate to preheat*) 25 °C to 150 °C Time tS TSmin to TSmax tS 60 Ramp-up rate to peak*) TSmax to TP Recommendation Maximum 2 3 100 120 2 3 Unit Einheit K/s s K/s Liquidus temperature TL 217 Time above liquidus temperature tL 80 100 s Peak temperature TP 245 260 °C Time within 5 °C of the specified peak temperature TP - 5 K tP 20 30 s 3 6 K/s 10 Ramp-down rate* TP to 100 °C 480 Time 25 °C to TP All temperatures refer to the center of the package, measured on the top of the component * slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range 2014-12-05 °C 17 s Version 2.6 LE CG P2W Tray Bauteilträger 38 pcs. per tray Barcode-Product-Label (BPL) Barcode-Produkt-Etikett (BPL) Data Matrix Code BIN BIn Nr. 2014-12-05 EXA M LE xxx xxx MATERIAL: Group: xxxx-xxxx-xxxx P LE Batch Material Number 18 DC: Date Code Batch Number OHA02684 Version 2.6 LE CG P2W Note: Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card. Regarding dry pack you will find further information in the internet and in the Short Form Catalog in chapter “Tape and Reel” under the topic “Dry Pack”. Here you will also find the normative references like JEDEC. Anm.: Feuchteempfindliche Produkte sind verpackt in einem Trockenbeutel zusammen mit einem Trockenmittel und einer Feuchteindikatorkarte. Bezüglich Trockenverpackung finden Sie weitere Hinweise im Internet und in unserem Short Form Catalog im Kapitel “Gurtung und Verpackung” unter dem Punkt “Trockenverpackung”. Hier sind Normenbezüge, unter anderem ein Auszug der JEDEC-Norm, enthalten. Transportation Packing and Materials Kartonverpackung und Materialien Box MY DE 8 R1 Q1 lti LS TO Y T6 PL 76 CK P1+ PA GR OU (G) 44 Mu 99 8 D/C : 01 21 00 (9D ) 00 21 : 4 20 23 Y: OS H1 QT Se mi RA co M nd Op uc tor to NO s TC H (Q) 3G BA ) (6P 5 ) (1T NO OD (X) PR : 11 00 LO T 14 2 NO : 12 P: Muster ED Bin Bin 1: Bin 2: P-1 3: Q-1 -20 ML -20 2 Tem 2a 220 3 240 p ST Add 260 C R C R07 ition C R 7 al RT TEX VA T R: Barcode label Original packing label OHA02886 Dimensions of transportation box in mm Dimensions of transportation box in mm Width / Breite Length / Länge Height / Höhe 333 ± 5 337 ± 5 218 ± 5 218 ± 5 28 ± 5 63 ± 5 2014-12-05 19 Version 2.6 LE CG P2W Notes Hinweise The evaluation of eye safety occurs according to the standard IEC 62471:2008 ("photobiological safety of lamps and lamp systems"). Within the risk grouping system of this CIE standard, the LED specified in this data sheet fall into the class Moderate risk (exposure time 0.25 s). Under real circumstances (for exposure time, eye pupils, observation distance), it is assumed that no endangerment to the eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light sources have a high secondary exposure potential due to their blinding effect. As is also true when viewing other bright light sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation. Die Bewertung der Augensicherheit erfolgt nach dem Standard IEC 62471:2008 ("photobiological safety of lamps and lamp systems"). Im Risikogruppensystem dieser CIE- Norm erfüllen die in diesem Datenblatt angegebenen LEDs folgende Gruppenanforderung - Moderate risk (Expositionsdauer 0,25 s). Unter realen Umständen (für Expositionsdauer, Augenpupille, Betrachtungsabstand) geht damit von diesen Bauelementen keinerlei Augengefährdung aus. Grundsätzlich sollte jedoch erwähnt werden, dass intensive Lichtquellen durch ihre Blendwirkung ein hohes sekundäres Gefahrenpotenzial besitzen. Nach einem Blick in eine helle Lichtquelle (z.B. Autoscheinwerfer), kann ein temporär eingeschränktes Sehvermögen oder auch Nachbilder zu Irritationen, Belästigungen, Beeinträchtigungen oder sogar Unfällen führen. Subcomponents of this LED contain, among other substances, goldplated and Ag-filled materials. In spite of the improved corrosion stability of this LED, it can be affected by environments that contain very high concentrations of aggressive substances. Therefore, we recommend avoiding aggressive atmospheres during storage, production and use. Einzelkomponenten dieser LED enthalten u.a. goldbeschichtete und Ag-gefüllte Materialien. Trotz der verbesserten Korrosionsstabilität dieser LED können Einzelkomponenten durch sehr hohe Konzentration aggressiver Substanzen angegriffen werden. Aus diesem Grund wird empfohlen, aggressive Umgebungen während der Lagerung, Produktion und im Betrieb zu vermeiden. 2014-12-05 20 Version 2.6 LE CG P2W Disclaimer Disclaimer Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version in the Internet. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Components used in life-support devices or systems must be expressly authorized for such purpose! Critical components* may only be used in life-support devices** or systems with the express written approval of OSRAM OS. Bitte beachten! Lieferbedingungen und Änderungen im Design vorbehalten. Aufgrund technischer Anforderungen können die Bauteile Gefahrstoffe enthalten. Für weitere Informationen zu gewünschten Bauteilen, wenden Sie sich bitte an unseren Vertrieb. Falls Sie dieses Datenblatt ausgedruckt oder heruntergeladen haben, finden Sie die aktuellste Version im Internet. Verpackung Benutzen Sie bitte die Ihnen bekannten Recyclingwege. Wenn diese nicht bekannt sein sollten, wenden Sie sich bitte an das nächstgelegene Vertriebsbüro. Wir nehmen das Verpackungsmaterial zurück, falls dies vereinbart wurde und das Material sortiert ist. Sie tragen die Transportkosten. Für Verpackungsmaterial, das unsortiert an uns zurückgeschickt wird oder das wir nicht annehmen müssen, stellen wir Ihnen die anfallenden Kosten in Rechnung. Bauteile, die in lebenserhaltenden Apparaten und Systemen eingesetzt werden, müssen für diese Zwecke ausdrücklich zugelassen sein! Kritische Bauteile* dürfen in lebenserhaltenden Apparaten und Systemen** nur dann eingesetzt werden, wenn ein schriftliches Einverständnis von OSRAM OS vorliegt. *) A critical component is a component used in a life-support device or system whose failure can reasonably be expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that device or system. **) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be endangered. *) Ein kritisches Bauteil ist ein Bauteil, das in lebenserhaltenden Apparaten oder Systemen eingesetzt wird und dessen Defekt voraussichtlich zu einer Fehlfunktion dieses lebenserhaltenden Apparates oder Systems führen wird oder die Sicherheit oder Effektivität dieses Apparates oder Systems beeinträchtigt. **) Lebenserhaltende Apparate oder Systeme sind für (a) die Implantierung in den menschlichen Körper oder (b) für die Lebenserhaltung bestimmt. Falls Sie versagen, kann davon ausgegangen werden, dass die Gesundheit und das Leben des Patienten in Gefahr ist. 2014-12-05 21 Version 2.6 LE CG P2W Glossary Glossar 1) Brightness: Brightness values are measured during a pulse train of 100 ms with a pulse width of 500 µs and a frequencey of 1 kHz, with an internal reproducibility of +/- 8 % and an expanded uncertainty of +/- 11 % (acc. to GUM with a coverage factor of k = 3). The peak brightness is calculated according to the pulse duration and frequency. 1) Helligkeit: Helligkeitswerte werden während einer Pulsfolge der Dauer 100 ms mit einer Pulsbreite von 500 µs bei einer Frequenz von 1 kHz gemessen, mit einer internen Reproduzierbarkeit von +/- 8 % und einer erweiterten Messunsicherheit von +/- 11 % (gemäß GUM mit Erweiterungsfaktor k = 3). Die Helligkeitswerte werden gemäß der Pulsdauer und Frequenz berechnet. 2) Chromaticity coordinate groups: Chromaticity coordinates are measured during a pulse train of 100 ms with a pulse width of 500 µs and a frequencey of 1 kHz , with an internal reproducibility of +/- 0,005 and an expanded uncertainty of +/- 0,01 (acc. to GUM with a coverage factor of k = 3). 2) Farbortgruppen: Farbkoordinaten werden während einer Pulsfolge der Dauer 100 ms mit einer Pulsbreite von 500 µs bei einer Frequenz von 1 kHz, mit einer internen Reproduzierbarkeit von +/- 0,005 und einer erweiterten Messunsicherheit von +/- 0,01 gemessen (gemäß GUM mit Erweiterungsfaktor k = 3). 3) Forward Voltage: The forward voltage is measured during a pulse of typical 500 µs, with an internal reproducibility of +/- 0,05 V and an expanded uncertainty of +/- 0,1 V (acc. to GUM with a coverage factor of k=3). 3) Durchlassspannung: Vorwärtsspannungen werden während eines Strompulses einer typischen Dauer von 500 µs, mit einer internen Reproduzierbarkeit von +/- 0,05 V und einer erweiterten Messunsicherheit von +/- 0,1 V gemessen (gemäß GUM mit Erweiterungsfaktor k=3). 4) Thermal Resistance: Rth max is based on statistic values (6σ). 4) Wärmewiderstand: Rth statistischen Werten (6σ). 5) Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 5) Typische Werte: Wegen der besonderen Prozessbedingungen bei der Herstellung von LED können typische oder abgeleitete technische Parameter nur aufgrund statistischer Werte wiedergegeben werden. Diese stimmen nicht notwendigerweise mit den Werten jedes einzelnen Produktes überein, dessen Werte sich von typischen und abgeleiteten Werten oder typischen Kennlinien unterscheiden können. Falls erforderlich, z.B. aufgrund technischer Verbesserungen, werden diese typischen Werte ohne weitere Ankündigung geändert. 6) Relative Brightness Curve: In the range where the line of the graph is broken, you must expect higher brightness differences between single LEDs within one packing unit. 6) Relative Helligkeitskurve: Im gestrichelten Bereich der Kennlinien muss mit erhöhten Helligkeitsunterschieden zwischen Leuchtdioden innerhalb einer Verpackungseinheit gerechnet werden. 7) Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and dimensions are specified in mm. 7) Maßtoleranz: Wenn in der Zeichnung nicht anders angegeben, gilt eine Toleranz von ±0,1. Maße werden in mm angegeben. 2014-12-05 22 max basiert auf Version 2.6 LE CG P2W Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 2014-12-05 23
LECGP2W-7U5V-1-0-F00-T01 价格&库存
很抱歉,暂时无法提供与“LECGP2W-7U5V-1-0-F00-T01”相匹配的价格&库存,您可以联系我们找货
