ZFS-8500-WW
ZFS-8500-WW
    JKLCOMPONENTS
    ZFS-8500-WW
ZFS-8500-WW 数据手册
LED FLEX RIBBON Features VOLTAGE: 12V DC CURRENT: 1800mA LED VIEWING ANGLE (2 0 1/2): 120° STANDARD PACKAGING: 5 Meter Reel (300 LED's) OPTIONAL PACKAGING: Individual 500mm Sections (30 LED's) Order as ZFS-8500-XX/SEC Note: Individual Sections ARE NOT supplied with insulated wire connection. E365522 Maximum Ratings Accessories Parameter Symbol Rating Unit Electrostatic Discharge ESD 800 V Operating Temperature Topr -30~+85 ºC Storage Temperature Tstg -40~+100 ºC ZPS-1220 ZPS-1225 ZPS-1235 ZPS-1260 ZDM-01 12V, 20 Watt Power Supply 12V, 25 Watt Power Supply 12V, 35 Watt Power Supply 12V, 60 Watt Power Supply PWM LED Dimmer Note: ZPS-1235 and ZPS-1260 require use of wire nuts for connections. Mating Components ZFS-CH138-8J: Solderless Joiner Connector Note ATTENTION Please refer to JKL Application Sheet JKL-AS-ZFS-LED FLEX for Installation and Power Recommendations. OBSERVE PRECAUTION FOR HANDLING ELECTROSTATIC DISCHARGE SENSITIVE DEVICES G F E D C B A REV. NO. DELETE PART NO. ZFS-8500-Y ADD UL SYMBOL CHANGE MATING COMPONENTS ADD ACCESSORIES NOTES ADD WIRE TYPE AND SIZE SHOW WIRES ON BOTH ENDS ADD ZFS-8500-Y PART NO & ASSESSORIES RELEASED DESCRIPTION/ECO NUMBER ZFS-CHO-8J: Solderless Connector ZFS-CH140-8 I: Solderless Input Connector 6/13/14 METRIC 12/9/13 5/1713 8/16/11 THIRD ANGLE 6/27/11 PROJECTION 2/15/11 DRAWN BY 12/28/10 L. WENGSTROM 8/18/10 APPV'D DATE DIMENSIONS ARE IN mm (INCHES) TOLERANCE UNLESS OTHERWISE SPECIFIED REF. REF. 1 PL +/2 PL +/ANGLE +/APPV'D BY S.C. DATE 6/13/14 - CAD DRAWING - MANUAL REVISIONS NOT PERMITTED COMPONENTS CORPORATION TITLE LED FLEX RIBBON, 12V SIZE A SCALE FSCM NO. 55335 NONE DRAWING NO. ZFS-8500 MULTI RELEASED DATE 8/18/10 REVISION DATE 6/13/14 REV. NO. G SHEET 1 OF 2 LED FLEX RIBBON Dimensions 16.54mm (.65") 8.46mm (.33") [2] 5000mm (196.85") 8.0±0.35mm (.315±.014") 50.0±0.25mm (1.97±.010") 145.0mm REF. (5.70") UL-1007 24 AWG WIRES 2.43mm REF. (.10") Adhesive Tape for Mounting Electro-Optical Characteristics (Ta = 25°C) JKL Part Number Color Input Number Voltage Power Current of LED's (V DC) (W) (mA) ZFS-8500-CW Cool White 300 12 21.60 1800 120º 6000 1092 ZFS-8500-NW Neutral White 300 12 21.60 1800 120º 4100 1014 ZFS-8500-WW Warm White 300 12 21.60 1800 120º 3050 936 Circuit Diagram R1 R2 Radiance CCT (K) Angle Lumen Flux (lm) (+) R99 R100 DC 12V (-) COMPONENTS CORPORATION DRAWING NO. RELEASED DATE ZFS-8500 MULTI 8/18/10 REVISION DATE 6/13/14 REV. NO. G SHEET 2 OF 2
ZFS-8500-WW 价格&库存
很抱歉,暂时无法提供与“ZFS-8500-WW”相匹配的价格&库存,您可以联系我们找货
