JDHT-ALK24-A1450-803-S02-NSA
    HEATRON
    Module
    LED 80CRI 24-LEDS 4250LM IP65
JDHT-ALK24-A1450-803-S02-NSA 数据手册
ALK SERIES High Performance LED Area Light Kit Overview The ALK Series is a family of versatile high lumen LED modules designed for use in a variety of interior and exterior applications. The IP65 rated precision optics are available in Type III and Type V beam distributions. Modules are constructed from a single-piece anodized extrusion for optimal thermal management and ease of fixture integration. Modules are available in arrays of 24, 36 and 48 LEDs. ALK replicates the lumen output of HID sources from 70 to 150 watts while saving energy and significantly reducing maintenance costs. ALK is available in 4000 K and 5000 K CCT, with a nominal 80 CRI. Contact Heatron for custom beam angles, CCT’s and CRI’s. Transforming Your Vision into Higher Performance Solutions 3000 Wilson Avenue • Leavenworth, KS 66048-4637 • 1.877.553.9070 • 1.913.651.4420 • www.heatron.com • sales@heatron.com ALK Series Optical Beam Pattern Key Features      High lumen output, up to 8600 lumens 24, 36 or 48 LED arrays Color Temperatures: 4000 K and 5000 K Optimized thermal management for maximum performance, long life and reliability Environmentally green: Mercury and UV Free, RoHS compliant Type III Distribution Product Features     Type III optics provide asymmetric distribution for perimeters Type V optics provide symmetric distribution for wide open areas Capable of 100+ lm/W efficacy Lighting class LEDs mounted to MCPCB affixed to a single-piece thermal management anodized extrusion Type V Distribution Certification and Compliance     IESNA LM-79 tested by an independent laboratory Lumen maintenance tested per LM80 UL8750 recognized Class 1 - Pending IP65 rated Warranty  5 year limited warranty Applications  Parking Garage and Canopy  Street and Pathway  Interior and Exterior Area Lighting Dimensions Length A Width B Height C Wire Egress D Module Weight ALK24 5.67” (144 mm) 7.09” (180 mm) 2.60” (66.10 mm) 1.43” (36.40 mm) 3.30 (1.49 kg) ALK36 7.87” (200 mm) 7.09” (180 mm) 2.60” (66.10 mm) 1.43” (36.40 mm) 4.45 (2.00 kg) ALK48 10.51” (267 mm) 7.09” (180 mm) 2.60” (66.10 mm) 1.43” (36.40 mm) 5.90 (2.68 kg) D - wiring exit port denotes pole side E - 4X mounting holes for use with 10-24 cutting screws ALK Series Optical Parameters Maximum Operating Conditions CCT Kelvin 4000 K | 5000 K CRI Minimum 80 Contact Heatron for other CCT and CRI options ALK __ # of LEDs Drive Current 350 mA 24 500 mA 700 mA 350 mA 36 500 mA 700 mA 350 mA 48 500 mA 700 mA Ambient Temperature °C 35° Case Temperature °C 80° Operation beyond recommended temperatures may result in reduced product performance and life Distribution Type CCT Lumens B Backlight U Uplight G Glare 3 4000 K 2559 1 2 1 5 5000K 2589 2 1 1 3 4000 K 3376 1 2 1 5 5000 K 3416 2 1 1 3 4000 K 4257 1 2 1 5 5000 K 4307 2 2 1 3 4000 K 3839 1 2 1 5 5000K 3884 2 2 1 3 4000 K 5063 1 2 2 5 5000 K 5123 3 2 1 3 4000 K 6385 2 2 2 5 5000 K 6461 3 2 1 3 4000 K 5118 2 2 2 5 5000K 5178 3 2 1 3 4000 K 6751 2 2 2 5 5000 K 6831 3 2 1 3 4000 K 8513 2 3 2 5 5000 K 8614 3 2 2 Forward Voltage Watts 71.2 25 72.5 36 74.1 52 106.8 37 108.8 54 111.2 78 142.3 50 143.6 72 148.2 104 Values shown include optical and thermal losses at a stabilized 25° C. All LED modules are suitable for the drive current values shown. Actual drive current used is determined by the separately specified LED driver. Higher values up to 1000 mA may are possible, depending on thermal management of the complete luminaire assembly. Contact Heatron for IES files. Ordering Information Example: JDHT-ALK48-A1440-803-S02-NSA Internal Series Internal JDHT ALK24 ALK36 ALK48 A14 Color Temperature (Kelvin) Minimum CRI Beam Angle Wiring Port Location 40 50 80 Type I - 1* Type II - 2* Type III - 3 Type IV - 4* Type V - 5 S Side *Subject to minimum order quantity contact Heatron for details In the effort to improve our products, Heatron reserves the right to make changes. Internal Internal 02 Module without driver NSA About Heatron LED Integration Heatron LED Integration, a leader in LED lighting solutions, helps OEMs reduce cost and speed time to market while ensuring superior quality and performance. Our proficiency in the disciplines of optical, electrical and mechanical design, along with expertise in thermal management, provides you with a world-class LED light source. Heatron offers various levels of integration ranging from the design and manufacture of LED light engine components to assisting customers with the design of complete LED lighting fixtures for commercial and industrial lighting applications. Transforming Your Vision into Higher Performance Solutions. For more information about Heatron LED Integration, its products, services and manufacturing, visit www.heatron.com. 3000 Wilson Avenue Leavenworth, KS 66048-4637 USA 877.553.9070 P: 1.913.651.4420 • F: 1.913.651.5352 www.heatron.com • sales@heatron.com ISO 9001 • Registered by Underwriters Laboratories, Inc. ALK 0214 Rev B
JDHT-ALK24-A1450-803-S02-NSA 价格&库存
很抱歉,暂时无法提供与“JDHT-ALK24-A1450-803-S02-NSA”相匹配的价格&库存,您可以联系我们找货
